    4. Test Adapter BMW/Mini v2.0.0
      mike1429 @Marc Berg last edited by
      @marc-berg
      Kann das bestätigen
        mike1429 @mike1429 last edited by
        @mike1429
        Hmmm....
        admin.0
        2023-12-30 22:21:19.047 error Cannot subscribe "bmw.0.xxxxxxxxxxxxx.chargingSessions.2023-11.costsGroupedByCurrency.~ 24,78 EUR": Error The pattern "bmw.0.xxxxxxxxxxxxx.chargingSessions.2023-11.costsGroupedByCurrency.~ 24,78 EUR" is not a valid ID pattern
        host.buanet-iobroker1-Server
        2023-12-30 22:21:19.045 warn States 127.0.0.1:47846 Error from InMemDB: Error: The pattern "bmw.0.xxxxxxxxxxxxx.chargingSessions.2023-11.costsGroupedByCurrency.~ 24,78 EUR" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2470:15) at StatesInMemoryServer.handleSubscribe (/opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:324:59) at StatesInMemoryServer._subscribeForClient (/opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:258:14) at RedisHandler.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:395:26) at RedisHandler.emit (node:events:513:28) at RedisHandler.emit (node:domain:489:12) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:209:37) at processImmediate (node:internal/timers:466:21)
        admin.0
        2023-12-30 22:21:19.042 error Invalid pattern on subscribe: The pattern "bmw.0.xxxxxxxxxxxxx.chargingSessions.2023-11.costsGroupedByCurrency.~ 13,52 EUR" is not a valid ID pattern
          tombox @mike1429 last edited by
          @mike1429 Nochmal installieren
          • JB_Sullivan
            JB_Sullivan last edited by
            Läßt sich z.Zt. über die Katze nicht aktualisieren.
            $ iobroker url TA2k/ioBroker.bmw --host GLT --debug
            Server Cannot start inMem-states on port 9000: Failed to lock DB file "C:\ioBroker\GLT\iobroker-data\states.jsonl"!
            ERROR: Process exited with code 24
              lessthanmore last edited by lessthanmore
              Bei mir lässt es sich über die Katze installieren.
              Allerdings bekomme ich nun folgende Warnung recht unregelmäßig bei einem Interval von 10 Minuten.
              bmw.0
              2024-01-01 16:56:10.239	warn	Out of call volume quota. Quota will be replenished in 00:03:50.
              bmw.0
              2024-01-01 14:46:10.219	warn	Out of call volume quota. Quota will be replenished in 00:13:50.
              bmw.0
              2024-01-01 12:46:10.181	warn	Out of call volume quota. Quota will be replenished in 00:13:50.
              • Marc Berg
                Marc Berg Most Active @lessthanmore last edited by
                @lessthanmore sagte in Test Adapter BMW/Mini v2.0.0:
                Das kommt, wenn der Adapter ein paar mal hintereinander neu gestartet wurde, verschwindet dann aber nach Ablauf der Zeit.
                  lessthanmore @Marc Berg last edited by
                  @marc-berg Die Instanz wurde eigentlich nicht neugestartet.
                  Die Meldung kommt auch nicht jede Stunde.
                  Aber ich lasse ihn mal laufen.
                  Danke.
                  • Marc Berg
                    Ich dachte, du hättest den Adapter neu installiert? Das ist ja in jedem Fall mit einem Neustart verbunden.
                      tombox @lobomau last edited by
                      die GitHub version kann jetzt service demands und trips abrufen bitte mal testen ob das so sinn macht
                      bahnuhr vowill 2 Replies Last reply Reply Quote 0
                      • bahnuhr
                        bahnuhr Forum Testing Most Active @tombox last edited by
                        @tombox sagte in Test Adapter BMW/Mini v2.0.0:
                        Habe gerade von git installiert.
                        Unter den Objekten finde ich nix zu:
                        Wo sollen diese sein ?
                          tombox @bahnuhr last edited by
                          wird beim start erstellt
                          • JB_Sullivan
                            servicedemands und trips sind bei mir vorhanden. Allerdings ist bei den chargingsessions einiges durcheinander gekommen.
                            In jeden Monatsblock haben sich auch die Ladungen des jeweiligen Vormonat rein gemogelt. Also in 11/23 auch ein Teil der 10/23er Daten und in 12/23 auch wiederum ein Teil der 11/23er Daten - usw. Betrifft bei mir alle Sessions, seit ich das Fahrzeug in Besitz habe.
                              tombox @JB_Sullivan last edited by
                              @jb_sullivan ein debug log mit den rohen charging sessions wäre interessant via mail
                              tombox2020@gmail.com
                              • vowill
                                vowill @tombox last edited by vowill
                                @tombox
                                2.8.0 funktioniert bei mir bestens, VIELEN DANK! Die DPs unter bmw.0.xxx.servicedemands enthalten jetzt die Daten analog den früheren DPs unter bmw.0.VIN.properties.serviceRequiredxx.
                                Super!
                                  Karacho @vowill last edited by Karacho
                                  bei mir zeigt der Adapter 2 DP falsch oder nicht an:
                                  Und zwar
                                  • Ladestatus als "invalid", lädt aber
                                  • Chargerconnected "false" ist aber "true"
                                  remaining charging time wird richtig mit 299minangezeigt....
                                  Was läuft falsch?
                                  In der Vergangenheit waren die DP richtig.
                                  Karacho
                                  lobomau 1 Reply Last reply Reply Quote 0
                                  • lobomau
                                    lobomau @Karacho last edited by
                                    @karacho bei mir sind die DPs korrekt. Ich habe Adapterversion 2.7.0. Stable ist 2.5.7.
                                      mike1429 @tombox last edited by
                                      @tombox
                                      Bei mir ist die letzte Charging Session von Ende März. Andere Werte sind aktuell. Wo finde ich die jetzt? Oder was ist falsch? Version 2.8.0
                                        @mike1429
                                        Sieht jemand die Charging Sessions? Oder wird diese Funktion nicht mehr unterstützt?
                                        • lobomau
                                          lobomau @mike1429 last edited by lobomau
                                          @mike1429 sidht bei mir auch so aus. Letzte ChargingSession 28.3.24.
                                          Und chargingstatistics ging bei mir bis 2024-02.
                                          Habe beide Ordner gelöscht. Waren über 4500 Einträge (die ich nie gebraucht habe).
                                          • NWH
                                            NWH last edited by
                                            @tombox
                                            Ich habe den Adapter am laufen, funktioniert auch so wie er soll wie ich denke.
                                            Allerdings gibt es ein kleines Problem, zumindest bei mir.
                                            Ich muss den Adapter immer neu starten zumindest alles 2 Tage damit ich aktuelle Daten bekomme. Es sieht so aus, als würde das automatische updaten hängen bleiben.
                                            Könnte sein wenn man sich in der App einloggt das es dann hängen bleibt?
                                            Gibt es hierfür eine Lösung?
                                            Lg und Danke.
                                            674
                                            149582
