    4. Test Adapter LG ThinQ
      Lucky_ESA Developer Most Active @ofri2607 last edited by
      @ofri2607
      Besteht die Möglichkeit das du mal vom GIT lädst?
      ofri2607 1 Reply Last reply Reply Quote 0
      • ofri2607
        ofri2607 @Lucky_ESA last edited by
        @lucky_esa
        Klar kein Problem, siehe nachstehende Log (wieder alles inkl. Installation) brauchst ein debug-log auch?
        Adapter läuft damit grundsätzlich, schreibt aber alle 5 Sekunden zwei Log-Einträge zu WRONG WORKLIST und die Warnungen zum setObject bei den thinq2 Geräten sind noch da.
        2024-01-07 12:10:40.637 - info: host.raspberrypi iobroker url TA2k/ioBroker.lg-thinq --host raspberrypi --debug
        2024-01-07 12:10:43.456 - info: host.raspberrypi iobroker install TA2k/ioBroker.lg-thinq
        2024-01-07 12:10:44.585 - info: host.raspberrypi iobroker NPM version: 10.2.3
        2024-01-07 12:10:44.587 - info: host.raspberrypi iobroker Installing TA2k/ioBroker.lg-thinq... (System call)
        2024-01-07 12:11:00.120 - info: host.raspberrypi iobroker changed 1 package in 15s138 packages are looking for funding run `npm fund` for details
        2024-01-07 12:11:00.436 - info: host.raspberrypi iobroker upload [13] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/de/translations.json i18n/de/translations.json application/json
        2024-01-07 12:11:00.455 - info: host.raspberrypi iobroker upload [12] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/en/translations.json i18n/en/translations.json application/json
        2024-01-07 12:11:00.465 - info: host.raspberrypi iobroker upload [11] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/es/translations.json i18n/es/translations.json application/json
        2024-01-07 12:11:00.474 - info: host.raspberrypi iobroker upload [10] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        2024-01-07 12:11:00.483 - info: host.raspberrypi iobroker upload [9] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/it/translations.json i18n/it/translations.json application/json
        2024-01-07 12:11:00.494 - info: host.raspberrypi iobroker upload [8] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        2024-01-07 12:11:00.504 - info: host.raspberrypi iobroker upload [7] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        2024-01-07 12:11:00.514 - info: host.raspberrypi iobroker upload [6] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        2024-01-07 12:11:00.523 - info: host.raspberrypi iobroker upload [5] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        2024-01-07 12:11:00.534 - info: host.raspberrypi iobroker upload [4] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        2024-01-07 12:11:00.544 - info: host.raspberrypi iobroker upload [3] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        2024-01-07 12:11:00.554 - info: host.raspberrypi iobroker upload [2] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/index_m.html index_m.html text/html
        2024-01-07 12:11:00.563 - info: host.raspberrypi iobroker upload [1] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/jsonConfig.json jsonConfig.json application/json
        2024-01-07 12:11:00.572 - info: host.raspberrypi iobroker upload [0] lg-thinq.admin /opt/iobroker/node_modules/iobroker.lg-thinq/admin/lg-thinq.png lg-thinq.png image/png
        2024-01-07 12:11:00.663 - info: host.raspberrypi iobroker Update "system.adapter.lg-thinq.0"
        2024-01-07 12:11:01.732 - info: host.raspberrypi iobroker exit 0
        2024-01-07 12:11:23.290 - info: host.raspberrypi "system.adapter.lg-thinq.0" enabled
        2024-01-07 12:11:23.548 - info: host.raspberrypi instance system.adapter.lg-thinq.0 started with pid 1152227
        2024-01-07 12:11:26.337 - info: lg-thinq.0 (1152227) starting. Version 0.3.1 (non-npm: TA2k/ioBroker.lg-thinq) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v18.19.0, js-controller: 5.0.17
        2024-01-07 12:11:29.225 - info: lg-thinq.0 (1152227) Login successful
        2024-01-07 12:11:36.532 - info: lg-thinq.0 (1152227) Found: 3 devices
        2024-01-07 12:11:36.533 - info: lg-thinq.0 (1152227) Create or update datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
        2024-01-07 12:11:49.996 - info: lg-thinq.0 (1152227) Update raw datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
        2024-01-07 12:11:50.542 - info: lg-thinq.0 (1152227) Create or update datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
        2024-01-07 12:11:50.761 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.windStrength (type=state) property common.role missing!
        2024-01-07 12:11:50.766 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.wDirCtrl.hStep (type=state) property common.role missing!
        2024-01-07 12:11:50.767 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.qualityMngCtrl.sensorMon (type=state) property common.role missing!
        2024-01-07 12:11:50.767 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.target (type=state) property common.role missing!
        2024-01-07 12:11:50.768 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.operation (type=state) property common.role missing!
        2024-01-07 12:11:50.770 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.wDirCtrl.vStep (type=state) property common.role missing!
        2024-01-07 12:11:50.776 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.settingInfo.basic (type=state) property common.role missing!
        2024-01-07 12:11:50.777 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.settingInfo.autoDry (type=state) property common.role missing!
        2024-01-07 12:11:50.779 - warn: lg-thinq.0 (1152227) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.opMode (type=state) property common.role missing!
        2024-01-07 12:11:56.168 - info: lg-thinq.0 (1152227) Update raw datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
        2024-01-07 12:11:56.884 - info: lg-thinq.0 (1152227) Create or update datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
        2024-01-07 12:11:56.936 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.windStrength (type=state) property common.role missing!
        2024-01-07 12:11:56.937 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.wDirCtrl.hStep (type=state) property common.role missing!
        2024-01-07 12:11:56.938 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.qualityMngCtrl.sensorMon (type=state) property common.role missing!
        2024-01-07 12:11:56.939 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.target (type=state) property common.role missing!
        2024-01-07 12:11:56.939 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.operation (type=state) property common.role missing!
        2024-01-07 12:11:56.940 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.wDirCtrl.vStep (type=state) property common.role missing!
        2024-01-07 12:11:56.943 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.settingInfo.basic (type=state) property common.role missing!
        2024-01-07 12:11:56.945 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.settingInfo.autoDry (type=state) property common.role missing!
        2024-01-07 12:11:56.946 - warn: lg-thinq.0 (1152227) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.opMode (type=state) property common.role missing!
        2024-01-07 12:12:02.112 - info: lg-thinq.0 (1152227) Update raw datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
        2024-01-07 12:12:03.006 - info: lg-thinq.0 (1152227) Found MQTT Host
        2024-01-07 12:12:03.103 - info: lg-thinq.0 (1152227) Found AWS CER
        2024-01-07 12:12:03.742 - info: lg-thinq.0 (1152227) Create certification done
        2024-01-07 12:12:04.041 - info: lg-thinq.0 (1152227) Start MQTT Connection
        2024-01-07 12:12:04.571 - info: lg-thinq.0 (1152227) MQTT connected to: t20/op/b10dc87ae5e62b453822886bad2bc820cbffdf1d8ef833c2a2b862cdb104d59b/inbox
        2024-01-07 12:12:10.066 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
        2024-01-07 12:12:10.067 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"eyJPcGVyYXRpb24iOiIwIiwiT3BNb2RlIjoiMCIsIldpbmRTdHJlbmd0aCI6IjgiLCJUZW1wVW5pdCI6Ik5TIiwiVGVtcEN1ciI6IjIzIiwiVGVtcENmZyI6IjIyIiwiR3JvdXBUeXBlIjoiMSIsIlNsZWVwVGltZSI6IjAiLCJPblRpbWUiOiIwIiwiT2ZmVGltZSI6IjAiLCJSYWNBZGRGdW5jIjoiTlMiLCJFeHRyYU9wIjoiMCIsIkRpYWdDb2RlIjoiMDAiLCJUaW1lQnNPbiI6IjAiLCJUaW1lQnNPZmYiOiIwIiwiQWlyQ2xlYW4iOiIwIiwiQXV0b0RyeSI6IjAiLCJQb3dlclNhdmUiOiIwIiwiV0RpclZTdGVwIjoiMTAwIiwiV0RpckhTdGVwIjoiMCIsIlRlbXBMaW1pdE1heCI6IjAiLCJUZW1wTGltaXRNaW4iOiIwIiwiRHVjdFpvbmVUeXBlIjoiMCIsIlpvbmVDb250cm9sIjoiMCIsIkRSRUQiOiIwIiwiU2Vuc29yUE0xIjoiMCIsIlNlbnNvclBNMiI6IjAiLCJTZW5zb3JQTTEwIjoiMCIsIkFpclBvbHV0aW9uIjoiMCIsIkh1bWlkaXR5Q2ZnIjoiMCIsIldhdGVyVGVtcENvb2xNaW4iOiJOUyIsIldhdGVyVGVtcENvb2xNYXgiOiJOUyIsIldhdGVyVGVtcEhlYXRNaW4iOiJOUyIsIldhdGVyVGVtcEhlYXRNYXgiOiJOUyIsIkhvdFdhdGVyVGVtcE1pbiI6Ik5TIiwiSG90V2F0ZXJUZW1wTWF4IjoiTlMiLCJTZW5zb3JIdW1pZGl0eSI6IjAiLCJUb3RhbEFpclBvbHV0aW9uIjoiMCIsIlNlbnNvck1vbiI6IjAiLCJDbGVhbkRyeSI6IjAiLCJQcm9kdWN0U3RhdHVzIjoiMCIsIkFpck1vbml0b3JpbmciOiIwIiwiSHVtaWRpZmljYXRpb24iOiIwIiwiQWlyRmFzdCI6IjAiLCJBaXJSZW1vdmFsIjoiMCIsIkFpclVWRGlzaW5mZWN0aW9uIjoiMCIsIldhdGVydGFua0xpZ2h0IjoiMCIsIlNpZ25hbExpZ2h0aW5nIjoiMCIsIldEaXJVcERvd24iOiIwIiwiV0RpckxlZnRSaWdodCI6IjAiLCJXU3dpcmwiOiIwIiwiSmV0IjoiMCIsIkxvd0hlYXRpbmciOiIwIiwiQ2lyY3VsYXRlU3RyZW5ndGgiOiIwIiwiQ2lyY3VsYXRlRGlyIjoiMCIsIkFudGlCdWdzIjoiMCIsIkljZVZhbGxleSI6IjAiLCJIdW1zYXZlIjoiMCIsIldhdGVyVGVtcEN1ciI6IjAiLCJIb3RXYXRlclRlbXBDdXIiOiIwIiwiSG90V2F0ZXJUZW1wQ2ZnIjoiMCIsIkhvdFdhdGVyTW9kZSI6IjAiLCJIb3RXYXRlciI6IjAiLCJBV0hQVGVtcENmZ1N3aXRjaCI6IjAiLCJBaXJUZW1wQ29vbE1pbiI6Ik5TIiwiQWlyVGVtcENvb2xNYXgiOiJOUyIsIkFpclRlbXBIZWF0TWluIjoiTlMiLCJBaXJUZW1wSGVhdE1heCI6Ik5TIiwiV2F0ZXJJblRlbXBDdXIiOiIwIiwiQVdIUFdBVGVtcENvbnRyb2xTdGEiOiIwIiwiRGlzcGxheUNvbnRyb2wiOiIwIiwiU21hcnRDYXJlIjoiMCIsIlR3b1NldENvb2xUZW1wIjoiMCIsIlR3b1NldEhlYXRUZW1wIjoiMCIsIlR3b1NldENvb2xVU0wiOiIwIiwiVHdvU2V0Q29vbExTTCI6IjAiLCJUd29TZXRIZWF0VVNMIjoiMCIsIlR3b1NldEhlYXRMU0wiOiIwIiwiVHdvU2V0QUNPU3RhdGUiOiIwIiwiVHdvU2V0TW9kZURlYWRiYW5kIjoiMCIsIlR3b1NldFN0YXRlIjoiMCJ9","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
        2024-01-07 12:12:15.100 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
        2024-01-07 12:12:15.101 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
        2024-01-07 12:12:20.075 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
        2024-01-07 12:12:20.076 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
        2024-01-07 12:12:25.134 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
        2024-01-07 12:12:25.134 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
        2024-01-07 12:12:30.139 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
        2024-01-07 12:12:30.139 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
        2024-01-07 12:12:35.080 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
        2024-01-07 12:12:35.081 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
        2024-01-07 12:12:40.128 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
        2024-01-07 12:12:40.129 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"eyJPcGVyYXRpb24iOiIwIiwiT3BNb2RlIjoiMCIsIldpbmRTdHJlbmd0aCI6IjgiLCJUZW1wVW5pdCI6Ik5TIiwiVGVtcEN1ciI6IjIzIiwiVGVtcENmZyI6IjIyIiwiR3JvdXBUeXBlIjoiMSIsIlNsZWVwVGltZSI6IjAiLCJPblRpbWUiOiIwIiwiT2ZmVGltZSI6IjAiLCJSYWNBZGRGdW5jIjoiTlMiLCJFeHRyYU9wIjoiMCIsIkRpYWdDb2RlIjoiMDAiLCJUaW1lQnNPbiI6IjAiLCJUaW1lQnNPZmYiOiIwIiwiQWlyQ2xlYW4iOiIwIiwiQXV0b0RyeSI6IjAiLCJQb3dlclNhdmUiOiIwIiwiV0RpclZTdGVwIjoiMTAwIiwiV0RpckhTdGVwIjoiMCIsIlRlbXBMaW1pdE1heCI6IjAiLCJUZW1wTGltaXRNaW4iOiIwIiwiRHVjdFpvbmVUeXBlIjoiMCIsIlpvbmVDb250cm9sIjoiMCIsIkRSRUQiOiIwIiwiU2Vuc29yUE0xIjoiMCIsIlNlbnNvclBNMiI6IjAiLCJTZW5zb3JQTTEwIjoiMCIsIkFpclBvbHV0aW9uIjoiMCIsIkh1bWlkaXR5Q2ZnIjoiMCIsIldhdGVyVGVtcENvb2xNaW4iOiJOUyIsIldhdGVyVGVtcENvb2xNYXgiOiJOUyIsIldhdGVyVGVtcEhlYXRNaW4iOiJOUyIsIldhdGVyVGVtcEhlYXRNYXgiOiJOUyIsIkhvdFdhdGVyVGVtcE1pbiI6Ik5TIiwiSG90V2F0ZXJUZW1wTWF4IjoiTlMiLCJTZW5zb3JIdW1pZGl0eSI6IjAiLCJUb3RhbEFpclBvbHV0aW9uIjoiMCIsIlNlbnNvck1vbiI6IjAiLCJDbGVhbkRyeSI6IjAiLCJQcm9kdWN0U3RhdHVzIjoiMCIsIkFpck1vbml0b3JpbmciOiIwIiwiSHVtaWRpZmljYXRpb24iOiIwIiwiQWlyRmFzdCI6IjAiLCJBaXJSZW1vdmFsIjoiMCIsIkFpclVWRGlzaW5mZWN0aW9uIjoiMCIsIldhdGVydGFua0xpZ2h0IjoiMCIsIlNpZ25hbExpZ2h0aW5nIjoiMCIsIldEaXJVcERvd24iOiIwIiwiV0RpckxlZnRSaWdodCI6IjAiLCJXU3dpcmwiOiIwIiwiSmV0IjoiMCIsIkxvd0hlYXRpbmciOiIwIiwiQ2lyY3VsYXRlU3RyZW5ndGgiOiIwIiwiQ2lyY3VsYXRlRGlyIjoiMCIsIkFudGlCdWdzIjoiMCIsIkljZVZhbGxleSI6IjAiLCJIdW1zYXZlIjoiMCIsIldhdGVyVGVtcEN1ciI6IjAiLCJIb3RXYXRlclRlbXBDdXIiOiIwIiwiSG90V2F0ZXJUZW1wQ2ZnIjoiMCIsIkhvdFdhdGVyTW9kZSI6IjAiLCJIb3RXYXRlciI6IjAiLCJBV0hQVGVtcENmZ1N3aXRjaCI6IjAiLCJBaXJUZW1wQ29vbE1pbiI6Ik5TIiwiQWlyVGVtcENvb2xNYXgiOiJOUyIsIkFpclRlbXBIZWF0TWluIjoiTlMiLCJBaXJUZW1wSGVhdE1heCI6Ik5TIiwiV2F0ZXJJblRlbXBDdXIiOiIwIiwiQVdIUFdBVGVtcENvbnRyb2xTdGEiOiIwIiwiRGlzcGxheUNvbnRyb2wiOiIwIiwiU21hcnRDYXJlIjoiMCIsIlR3b1NldENvb2xUZW1wIjoiMCIsIlR3b1NldEhlYXRUZW1wIjoiMCIsIlR3b1NldENvb2xVU0wiOiIwIiwiVHdvU2V0Q29vbExTTCI6IjAiLCJUd29TZXRIZWF0VVNMIjoiMCIsIlR3b1NldEhlYXRMU0wiOiIwIiwiVHdvU2V0QUNPU3RhdGUiOiIwIiwiVHdvU2V0TW9kZURlYWRiYW5kIjoiMCIsIlR3b1NldFN0YXRlIjoiMCJ9","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
        2024-01-07 12:12:45.069 - info: lg-thinq.0 (1152227) WRONG WORKLIST: []
        2024-01-07 12:12:45.070 - info: lg-thinq.0 (1152227) WRONG WORKLIST RESULT: {"returnCd":"0000","returnMsg":"OK","workList":{"deviceId":"d27d1380-7149-11d3-80b8-2c2bf9760c6d","deviceState":"E","format":"B64","returnCode":"0000","returnData":"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","stateCode":"S","workId":"n-d27d1380-7149-11d3-80b8-2c2bf9760c6d"}}
          @ofri2607 Bitte mal 2 Minuten warten und dann erneut vom GIT laden.
          Gruß//Lucky
          • ofri2607
            @lucky_esa
            Sieht, denke ich an sich ganz gut aus und der Datenpunkt lg-thinq.0.interval.last_update wird auch alle 5 Sekunden aktualisiert.
            Log sieht ab dem Start so aus - schreibt jetzt alle 5 Sekunden die Einträge Length, Array und TypeOf
            2024-01-07 13:08:48.786 - info: lg-thinq.0 (1157199) starting. Version 0.3.1 (non-npm: TA2k/ioBroker.lg-thinq) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v18.19.0, js-controller: 5.0.17
            2024-01-07 13:08:51.056 - info: lg-thinq.0 (1157199) Login successful
            2024-01-07 13:08:53.420 - info: lg-thinq.0 (1157199) Found: 3 devices
            2024-01-07 13:08:53.421 - info: lg-thinq.0 (1157199) Create or update datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
            2024-01-07 13:09:06.975 - info: lg-thinq.0 (1157199) Update raw datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
            2024-01-07 13:09:07.444 - info: lg-thinq.0 (1157199) Create or update datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
            2024-01-07 13:09:07.596 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.windStrength (type=state) property common.role missing!
            2024-01-07 13:09:07.599 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.wDirCtrl.hStep (type=state) property common.role missing!
            2024-01-07 13:09:07.600 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.qualityMngCtrl.sensorMon (type=state) property common.role missing!
            2024-01-07 13:09:07.601 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.target (type=state) property common.role missing!
            2024-01-07 13:09:07.602 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.operation (type=state) property common.role missing!
            2024-01-07 13:09:07.603 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.wDirCtrl.vStep (type=state) property common.role missing!
            2024-01-07 13:09:07.615 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.settingInfo.basic (type=state) property common.role missing!
            2024-01-07 13:09:07.615 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.settingInfo.autoDry (type=state) property common.role missing!
            2024-01-07 13:09:07.617 - warn: lg-thinq.0 (1157199) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.opMode (type=state) property common.role missing!
            2024-01-07 13:09:12.760 - info: lg-thinq.0 (1157199) Update raw datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
            2024-01-07 13:09:13.227 - info: lg-thinq.0 (1157199) Create or update datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
            2024-01-07 13:09:13.273 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.windStrength (type=state) property common.role missing!
            2024-01-07 13:09:13.275 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.wDirCtrl.hStep (type=state) property common.role missing!
            2024-01-07 13:09:13.276 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.qualityMngCtrl.sensorMon (type=state) property common.role missing!
            2024-01-07 13:09:13.279 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.target (type=state) property common.role missing!
            2024-01-07 13:09:13.280 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.operation (type=state) property common.role missing!
            2024-01-07 13:09:13.281 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.wDirCtrl.vStep (type=state) property common.role missing!
            2024-01-07 13:09:13.282 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.settingInfo.basic (type=state) property common.role missing!
            2024-01-07 13:09:13.282 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.settingInfo.autoDry (type=state) property common.role missing!
            2024-01-07 13:09:13.283 - warn: lg-thinq.0 (1157199) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.opMode (type=state) property common.role missing!
            2024-01-07 13:09:18.336 - info: lg-thinq.0 (1157199) Update raw datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
            2024-01-07 13:09:18.901 - info: lg-thinq.0 (1157199) Found MQTT Host
            2024-01-07 13:09:18.976 - info: lg-thinq.0 (1157199) Found AWS CER
            2024-01-07 13:09:19.834 - info: lg-thinq.0 (1157199) Create certification done
            2024-01-07 13:09:20.102 - info: lg-thinq.0 (1157199) Start MQTT Connection
            2024-01-07 13:09:20.540 - info: lg-thinq.0 (1157199) MQTT connected to: t20/op/fecc8c25e098a918b7b40ae14c6d9fbe43a481afaf1afcdcea5e38410861c646/inbox
            2024-01-07 13:09:26.083 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:09:26.083 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:09:26.083 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:09:31.068 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:09:31.068 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:09:31.069 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:09:36.049 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:09:36.049 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:09:36.050 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:09:41.011 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:09:41.012 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:09:41.013 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:09:46.010 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:09:46.011 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:09:46.012 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:09:51.004 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:09:51.004 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:09:51.005 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:09:56.010 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:09:56.011 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:09:56.011 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:10:01.028 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:10:01.029 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:10:01.029 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:10:05.997 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:10:05.997 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:10:05.998 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:10:11.018 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:10:11.019 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:10:11.020 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:10:16.084 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:10:16.084 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:10:16.085 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:10:21.015 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:10:21.016 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:10:21.016 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:10:26.006 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:10:26.007 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:10:26.008 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:10:31.013 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:10:31.013 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:10:31.013 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:10:36.022 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:10:36.022 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:10:36.023 - info: lg-thinq.0 (1157199) Typeof: object
            2024-01-07 13:10:41.011 - info: lg-thinq.0 (1157199) Length: 7
            2024-01-07 13:10:41.012 - info: lg-thinq.0 (1157199) Array: false
            2024-01-07 13:10:41.013 - info: lg-thinq.0 (1157199) Typeof: object
              @ofri2607 Ups, vergessen die Logs zu löschen. Habe ich gerade neu auf dem GIT geladen.
              ofri2607 1 Reply Last reply Reply Quote 1
              • ofri2607
                @lucky_esa
                Alles gut 🙂 hole ich mir dann gleich.
                Die warn-Meldung zum setObject bei den thinq2 Geräten, denke ich, ist an sich unkritisch, oder?
                  @ofri2607 sagte in Test Adapter LG ThinQ v0.0.1:
                  @lucky_esa
                  Ist kritisch. Muss da mal schauen.
                  • ofri2607
                    @lucky_esa
                    Letzte GIT Version geholt und läuft 🙂 … mit den o.a. Warn-Meldungen zum setobject.
                    Herzlichen Dank für deine schnelle Lösung!
                    2024-01-07 13:26:54.283 - info: lg-thinq.0 (1158883) starting. Version 0.3.1 (non-npm: TA2k/ioBroker.lg-thinq) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v18.19.0, js-controller: 5.0.17
                    2024-01-07 13:26:56.802 - info: lg-thinq.0 (1158883) Login successful
                    2024-01-07 13:26:59.210 - info: lg-thinq.0 (1158883) Found: 3 devices
                    2024-01-07 13:26:59.213 - info: lg-thinq.0 (1158883) Create or update datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
                    2024-01-07 13:27:13.092 - info: lg-thinq.0 (1158883) Update raw datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
                    2024-01-07 13:27:13.587 - info: lg-thinq.0 (1158883) Create or update datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
                    2024-01-07 13:27:13.729 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.windStrength (type=state) property common.role missing!
                    2024-01-07 13:27:13.731 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.wDirCtrl.hStep (type=state) property common.role missing!
                    2024-01-07 13:27:13.735 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.qualityMngCtrl.sensorMon (type=state) property common.role missing!
                    2024-01-07 13:27:13.737 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.target (type=state) property common.role missing!
                    2024-01-07 13:27:13.738 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.operation (type=state) property common.role missing!
                    2024-01-07 13:27:13.739 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.wDirCtrl.vStep (type=state) property common.role missing!
                    2024-01-07 13:27:13.741 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.settingInfo.basic (type=state) property common.role missing!
                    2024-01-07 13:27:13.742 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.settingInfo.autoDry (type=state) property common.role missing!
                    2024-01-07 13:27:13.743 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.opMode (type=state) property common.role missing!
                    2024-01-07 13:27:18.835 - info: lg-thinq.0 (1158883) Update raw datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
                    2024-01-07 13:27:19.181 - info: lg-thinq.0 (1158883) Create or update datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
                    2024-01-07 13:27:19.226 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.windStrength (type=state) property common.role missing!
                    2024-01-07 13:27:19.227 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.wDirCtrl.hStep (type=state) property common.role missing!
                    2024-01-07 13:27:19.227 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.qualityMngCtrl.sensorMon (type=state) property common.role missing!
                    2024-01-07 13:27:19.228 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.target (type=state) property common.role missing!
                    2024-01-07 13:27:19.228 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.operation (type=state) property common.role missing!
                    2024-01-07 13:27:19.228 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.wDirCtrl.vStep (type=state) property common.role missing!
                    2024-01-07 13:27:19.229 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.settingInfo.basic (type=state) property common.role missing!
                    2024-01-07 13:27:19.229 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.settingInfo.autoDry (type=state) property common.role missing!
                    2024-01-07 13:27:19.230 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.opMode (type=state) property common.role missing!
                    2024-01-07 13:27:24.468 - info: lg-thinq.0 (1158883) Update raw datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
                    2024-01-07 13:27:24.992 - info: lg-thinq.0 (1158883) Found MQTT Host
                    2024-01-07 13:27:25.076 - info: lg-thinq.0 (1158883) Found AWS CER
                    2024-01-07 13:27:25.698 - info: lg-thinq.0 (1158883) Create certification done
                    2024-01-07 13:27:25.970 - info: lg-thinq.0 (1158883) Start MQTT Connection
                    2024-01-07 13:27:26.421 - info: lg-thinq.0 (1158883) MQTT connected to: t20/op/c506395e26728fd0340f7cf4a8e263719ced9d1b9effe7df9ec6d374156ea85c/inbox
                      @ofri2607 Der Fehler sollte nun auch behoben sein. Hab es gerade erst auf dem GIT geschoben daher mal 2 Minuten warten.
                      • ofri2607
                        @lucky_esa
                        Läuft ruhig durch - ohne eine warn-Meldung 👍
                        Nochmals herzlichen Dank für deine schnelle Lösung und noch einen schönen Sonntag.
                          @ofri2607 Kannst du eventuell noch mal vom GIT laden. Hab noch was geändert um mehr Info anzuzeigen. Leider weiß ich nicht was die Fehlermeldung 0100 bedeutet aber die Werte werden trotzdem aktualisiert.
                          • interval.status_devices
                            • OK: Intervall OK
                            • Fail; Intervall Fail (Fehlermeldung 0100)
                            • Error: Fehlende WorkID - WorkID wird neu erstellt
                            • Error <code>: Unbekannter Fehler - WorkID wird neu erstellt
                          Gruß//Lucky
                          • ofri2607
                            ofri2607 @Lucky_ESA last edited by ofri2607
                            @lucky_esa
                            Ist installiert und läuft.
                            Der neue Datenpunkt wurde als json mit dem Inhalt
                            {"d27d1380-7149-11d3-80b8-2c2bf9760c6d":"OK"}
                            angelegt.
                            Edit: gerade erste gesehen, der Adapter ist jetzt auf v0.3.2
                              @lucky_esa
                              angelegt.
                              Ja, musste jetzt schnell ein Release nachschieben da die Version 0.3.1 bei thinq1 User crasht. Da ich kein Thinq1 Geräte habe muss ich immer ein wenig vermuten.
                              • ofri2607
                                @Lucky_ESA
                                Guten Morgen,
                                folgende Einträge hatte ich heute in unregelmäßigen Abständen im Log:
                                2024-01-08 23:00:17.622 - error: lg-thinq.0 (1325489) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2024-01-08 23:00:17.633 - error: lg-thinq.0 (1325489) unhandled promise rejection: undefined is not a valid state value
                                2024-01-08 23:00:17.951 - error: lg-thinq.0 (1325489) Error: undefined is not a valid state value
                                at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
                                at LgThinq._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7593:26)
                                at LgThinq.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7551:21)
                                at LgThinq.setThinq1Interval (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:467:18)
                                at /opt/iobroker/node_modules/iobroker.lg-thinq/main.js:369:22
                                at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2024-01-08 23:00:17.952 - error: lg-thinq.0 (1325489) undefined is not a valid state value
                                2024-01-08 23:00:18.514 - info: lg-thinq.0 (1325489) terminating
                                2024-01-08 23:00:18.516 - warn: lg-thinq.0 (1325489) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                2024-01-08 23:00:18.558 - info: lg-thinq.0 (1325489) terminating
                                2024-01-08 23:00:19.134 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2024-01-08 23:00:19.134 - error: host.raspberrypi Caught by controller[1]: Error: undefined is not a valid state value
                                2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
                                2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at LgThinq._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7593:26)
                                2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at LgThinq.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7551:21)
                                2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at LgThinq.setThinq1Interval (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:467:18)
                                2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.lg-thinq/main.js:369:22
                                2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2024-01-08 23:00:19.135 - error: host.raspberrypi instance system.adapter.lg-thinq.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                2024-01-08 23:00:19.135 - info: host.raspberrypi Restart adapter system.adapter.lg-thinq.0 because enabled
                                2024-01-08 23:00:49.233 - info: host.raspberrypi instance system.adapter.lg-thinq.0 started with pid 1327629
                                2024-01-08 23:00:52.448 - info: lg-thinq.0 (1327629) starting. Version 0.3.2 (non-npm: TA2k/ioBroker.lg-thinq) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v18.19.0, js-controller: 5.0.17
                                2024-01-08 23:00:54.140 - info: lg-thinq.0 (1327629) Login successful
                                2024-01-08 23:00:58.992 - info: lg-thinq.0 (1327629) Found: 3 devices
                                2024-01-08 23:00:58.993 - info: lg-thinq.0 (1327629) Create or update datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
                                2024-01-08 23:01:14.671 - info: lg-thinq.0 (1327629) Update raw datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
                                2024-01-08 23:01:15.229 - info: lg-thinq.0 (1327629) Create or update datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
                                2024-01-08 23:01:20.776 - info: lg-thinq.0 (1327629) Update raw datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
                                2024-01-08 23:01:21.503 - info: lg-thinq.0 (1327629) Create or update datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
                                2024-01-08 23:01:26.808 - info: lg-thinq.0 (1327629) Update raw datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
                                2024-01-08 23:01:27.936 - info: lg-thinq.0 (1327629) Found MQTT Host
                                2024-01-08 23:01:28.026 - info: lg-thinq.0 (1327629) Found AWS CER
                                2024-01-08 23:01:28.678 - info: lg-thinq.0 (1327629) Create certification done
                                2024-01-08 23:01:29.117 - info: lg-thinq.0 (1327629) Start MQTT Connection
                                2024-01-08 23:01:29.647 - info: lg-thinq.0 (1327629) MQTT connected to: t20/op/7e0548ce9ab409359f1393e34f2529773cfe35ff338479a1d21060cdbe7d4db2/inbox
                                Es ist keine eindeutige Zeitabfolge erkennbar, war aber von gestern nach der Installation der v0.3.2 bis heute insgesamt 5 mal, zuletzt heute um 1:43:13.
                                  @Lucky_ESA
                                  Guten Morgen,
                                  OK, danke für die Info. Habe auf dem GIT den Fehler behoben. Dann konnte ca. 5 x keine Daten geholt werden. Das ist super und wahrscheinlich kommt noch die Zwangstrennung dazu.
                                  Kannst du bitte vom GIT laden und weiter testen. Besteht die Möglichkeit das du ein Blockly erstellt was den DP interval.status_devices triggert und bei Änderungen ein Logeintrag erstellt.
                                  Gruß//Lucky
                                  ofri2607 2 Replies Last reply Reply Quote 0
                                  • ofri2607
                                    @lucky_esa
                                    Servus, ja kann ich gerne machen, geht aber erst heute am Abend.
                                    Blockly jetzt nicht so, mache das dann über JS.
                                    • ofri2607
                                      @lucky_esa
                                      Ist installiert, läuft und Skript mit Trigger vom Datenpunkt läuft auch.
                                      Ich lasse es mal über die Nacht durchlaufen und stelle dir dann morgen das Ergebnis der Logausgaben vom Skript ein.
                                        @lucky_esa
                                        Super, vielen Dank.
                                        Gruß//Lucky
                                        • ofri2607
                                          @lucky_esa
                                          Hier mal die ersten Ausgaben vom Log des Skripts …
                                          javascript.3
                                          2024-01-09 21:15:44.759	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                          javascript.3
                                          2024-01-09 21:15:40.217	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-09 20:45:19.725	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{}")
                                          javascript.3
                                          2024-01-09 20:45:17.951	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-09 20:17:39.501	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                          javascript.3
                                          2024-01-09 20:17:19.881	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                          javascript.3
                                          2024-01-09 20:17:14.957	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-09 20:03:04.792	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                          javascript.3
                                          2024-01-09 20:03:00.409	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-09 19:15:47.479	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                            @ofri2607 Das sieht doch recht gut aus. Bei "Fail" kommen trotzdem Daten und es wechselt dann auch wieder auf "OK".
                                            Gruß//Lucky
                                            908
                                            285578
