    4. Zu viele Ereignise
    Zu viele Ereignise
      elektrofreak last edited by
      Ich habe jetzt nochmal alle Skripts gelöscht und alle Adapter gestoppt und des werden immer noch "zu viele Ereignisse" angezeigt.
      hier mal der log
      ! admin.0 2017-12-02 09:48:24.653 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:48:09.777 info received all states
      ! admin.0 2017-12-02 09:48:08.354 info Subscribe on all states again
      ! admin.0 2017-12-02 09:47:24.207 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:46:46.359 info Subscribe on all states again
      ! admin.0 2017-12-02 09:46:24.569 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:46:10.828 info received all states
      ! admin.0 2017-12-02 09:46:09.088 info Subscribe on all states again
      ! host.RBpi3-Master 2017-12-02 09:46:00.911 info 'system.adapter.vis.0' disabled
      ! host.RBpi3-Master 2017-12-02 09:46:00.909 info object change system.adapter.vis.0
      ! host.RBpi3-Master 2017-12-02 09:45:59.130 info instance system.adapter.web.0 terminated with code 0 (OK)
      ! web.0 2017-12-02 09:45:59.060 info terminating
      ! web.0 2017-12-02 09:45:58.977 info terminated http server on port 8082
      ! web.0 2017-12-02 09:45:58.976 info terminating http server on port 8082
      ! host.RBpi3-Master 2017-12-02 09:45:58.863 info stopInstance system.adapter.web.0 killing pid 13983
      ! host.RBpi3-Master 2017-12-02 09:45:58.862 info stopInstance system.adapter.web.0
      ! host.RBpi3-Master 2017-12-02 09:45:58.862 info 'system.adapter.web.0' disabled
      ! web.0 2017-12-02 09:45:58.975 info Adapter is disabled => stop
      ! web.0 2017-12-02 09:45:58.876 info terminated http server on port 8082
      ! web.0 2017-12-02 09:45:58.868 info terminating http server on port 8082
      ! host.RBpi3-Master 2017-12-02 09:45:58.860 info object change system.adapter.web.0
      ! host.RBpi3-Master 2017-12-02 09:45:54.290 info instance system.adapter.viessmann.0 terminated with code 0 (OK)
      ! viessmann.0 2017-12-02 09:45:54.223 info terminating
      ! viessmann.0 2017-12-02 09:45:54.193 info cleaned everything up…
      ! host.RBpi3-Master 2017-12-02 09:45:54.186 info stopInstance system.adapter.viessmann.0 killing pid 26458
      ! host.RBpi3-Master 2017-12-02 09:45:54.185 info stopInstance system.adapter.viessmann.0
      ! host.RBpi3-Master 2017-12-02 09:45:54.185 info 'system.adapter.viessmann.0' disabled
      ! host.RBpi3-Master 2017-12-02 09:45:54.184 info object change system.adapter.viessmann.0
      ! host.RBpi3-Master 2017-12-02 09:45:49.331 info object change system.adapter.javascript.0
      ! host.RBpi3-Master 2017-12-02 09:45:48.205 info instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
      ! hm-rpc.0 2017-12-02 09:45:48.160 info terminating
      ! hm-rpc.0 2017-12-02 09:45:48.132 info Disconnected
      ! hm-rpc.0 2017-12-02 09:45:48.055 info binrpc -> 192.168.170.53:2001 init ['xmlrpc_bin://192.168.170.16:2001','']
      ! host.RBpi3-Master 2017-12-02 09:45:48.033 info stopInstance system.adapter.hm-rpc.0 killing pid 14003
      ! host.RBpi3-Master 2017-12-02 09:45:48.032 info 'system.adapter.hm-rpc.0' disabled
      ! host.RBpi3-Master 2017-12-02 09:45:48.031 info object change system.adapter.hm-rpc.0
      ! host.RBpi3-Master 2017-12-02 09:45:47.311 info instance system.adapter.hm-rpc.1 terminated with code 0 (OK)
      ! hm-rpc.1 2017-12-02 09:45:47.246 info terminating
      ! hm-rpc.1 2017-12-02 09:45:47.211 info Disconnected
      ! hm-rpc.1 2017-12-02 09:45:47.152 info binrpc -> 192.168.170.53:8701 init ['xmlrpc_bin://192.168.170.16:8701','']
      ! host.RBpi3-Master 2017-12-02 09:45:47.133 info stopInstance system.adapter.hm-rpc.1 killing pid 15202
      ! host.RBpi3-Master 2017-12-02 09:45:47.132 info 'system.adapter.hm-rpc.1' disabled
      ! host.RBpi3-Master 2017-12-02 09:45:47.131 info object change system.adapter.hm-rpc.1
      ! host.RBpi3-Master 2017-12-02 09:45:46.958 info instance system.adapter.hm-rega.0 terminated with code 0 (OK)
      ! hm-rega.0 2017-12-02 09:45:46.903 info terminating
      ! hm-rega.0 2017-12-02 09:45:46.859 info Adapter is disabled => stop
      ! host.RBpi3-Master 2017-12-02 09:45:46.840 info stopInstance system.adapter.hm-rega.0 killing pid 17881
      ! host.RBpi3-Master 2017-12-02 09:45:46.839 info stopInstance system.adapter.hm-rega.0
      ! host.RBpi3-Master 2017-12-02 09:45:46.838 info object change system.adapter.hm-rega.0
      ! host.RBpi3-Master 2017-12-02 09:45:46.329 info instance system.adapter.history.0 terminated with code 0 (OK)
      ! host.RBpi3-Master 2017-12-02 09:45:46.011 info stopInstance system.adapter.history.0 killing pid 14422
      ! host.RBpi3-Master 2017-12-02 09:45:46.010 info stopInstance system.adapter.history.0
      ! host.RBpi3-Master 2017-12-02 09:45:46.010 info 'system.adapter.history.0' disabled
      ! host.RBpi3-Master 2017-12-02 09:45:46.008 info object change system.adapter.history.0
      ! host.RBpi3-Master 2017-12-02 09:45:44.607 info instance system.adapter.cloud.0 terminated with code 0 (OK)
      ! cloud.0 2017-12-02 09:45:44.517 info terminating
      ! cloud.0 2017-12-02 09:45:44.460 info Connection changed: DISCONNECTED3
      ! host.RBpi3-Master 2017-12-02 09:45:44.421 info stopInstance system.adapter.cloud.0 killing pid 15222
      ! host.RBpi3-Master 2017-12-02 09:45:44.420 info stopInstance system.adapter.cloud.0
      ! host.RBpi3-Master 2017-12-02 09:45:44.413 info 'system.adapter.cloud.0' disabled
      ! host.RBpi3-Master 2017-12-02 09:45:44.399 info object change system.adapter.cloud.0
      ! admin.0 2017-12-02 09:45:30.188 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:45:10.657 info Subscribe on all states again
      ! admin.0 2017-12-02 09:44:09.716 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:43:55.611 info Subscribe on all states again
      ! admin.0 2017-12-02 09:42:54.667 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:42:40.416 info Subscribe on all states again
      ! admin.0 2017-12-02 09:41:39.470 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:41:32.114 info Subscribe on all states again
      ! hm-rega.0 2017-12-02 09:41:23.366 info got state values
      ! hm-rega.0 2017-12-02 09:41:22.843 info request state values
      ! hm-rega.0 2017-12-02 09:41:22.842 info time difference local-ccu 1s
      ! hm-rega.0 2017-12-02 09:41:22.820 info ReGaHSS 192.168.170.53 up
      ! hm-rega.0 2017-12-02 09:40:52.651 error CCU 192.168.170.53 unreachable
      ! hm-rega.0 2017-12-02 09:40:52.650 error post request error: connect ENETUNREACH 192.168.170.53:8181 - Local (0.0.0.0:0)
      ! hm-rega.0 2017-12-02 09:40:52.635 info got 6 variables
      ! hm-rega.0 2017-12-02 09:40:52.313 info deleted 0 programs
      ! hm-rega.0 2017-12-02 09:40:52.312 info added/updated 6 programs
      ! hm-rega.0 2017-12-02 09:40:52.275 info got 6 programs
      ! hm-rega.0 2017-12-02 09:40:49.934 info added/updated rooms to enum.rooms
      ! hm-rega.0 2017-12-02 09:40:49.844 info added/updated functions to enum.functions
      ! hm-rega.0 2017-12-02 09:40:49.762 info added/updated 3 favorites to enum.favorites
      ! hm-rega.0 2017-12-02 09:40:49.712 info time difference local-ccu 1s
      ! hm-rega.0 2017-12-02 09:40:49.681 info ReGaHSS 192.168.170.53 up
      ! admin.0 2017-12-02 09:40:31.564 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! hm-rega.0 2017-12-02 09:40:19.517 error CCU 192.168.170.53 unreachable
      ! hm-rega.0 2017-12-02 09:40:19.515 error post request error: connect ENETUNREACH 192.168.170.53:8181 - Local (0.0.0.0:0)
      ! admin.0 2017-12-02 09:40:02.712 info Subscribe on all states again
      ! hm-rega.0 2017-12-02 09:39:23.596 info got state values
      ! hm-rega.0 2017-12-02 09:39:23.049 info request state values
      ! hm-rega.0 2017-12-02 09:39:23.048 info deleted 0 variables
      ! hm-rega.0 2017-12-02 09:39:23.047 info added/updated 6 variables
      ! hm-rega.0 2017-12-02 09:39:23.001 info got 6 variables
      ! hm-rega.0 2017-12-02 09:39:22.130 info deleted 0 programs
      ! hm-rega.0 2017-12-02 09:39:22.129 info added/updated 6 programs
      ! hm-rega.0 2017-12-02 09:39:22.098 info got 6 programs
      ! hm-rega.0 2017-12-02 09:39:19.873 info added/updated rooms to enum.rooms
      ! hm-rega.0 2017-12-02 09:39:19.758 info added/updated functions to enum.functions
      ! hm-rega.0 2017-12-02 09:39:19.671 info added/updated 3 favorites to enum.favorites
      ! hm-rega.0 2017-12-02 09:39:19.631 info time difference local-ccu 1s
      ! hm-rega.0 2017-12-02 09:39:19.602 info ReGaHSS 192.168.170.53 up
      ! cloud.0 2017-12-02 09:39:12.502 info 2017-12-02T08:39:12.502Z Connected system.user.admin
      ! cloud.0 2017-12-02 09:39:05.048 info Connection changed: CONNECTED1
      ! admin.0 2017-12-02 09:39:02.625 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! cloud.0 2017-12-02 09:38:54.539 info Connection changed: DISCONNECTED1
      ! cloud.0 2017-12-02 09:38:54.535 info Connection changed: DISCONNECTED3
      ! cloud.0 2017-12-02 09:38:54.530 error Ping timeout
      ! hm-rega.0 2017-12-02 09:38:49.450 error CCU 192.168.170.53 unreachable
      ! hm-rega.0 2017-12-02 09:38:49.449 error post request error: connect ENETUNREACH 192.168.170.53:8181 - Local (0.0.0.0:0)
      ! admin.0 2017-12-02 09:38:40.705 info Subscribe on all states again
      ! admin.0 2017-12-02 09:37:39.817 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:37:28.244 info Subscribe on all states again
      ! admin.0 2017-12-02 09:36:27.366 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! cloud.0 2017-12-02 09:36:19.489 info Connection changed: CONNECTED1
      ! cloud.0 2017-12-02 09:36:18.965 info 2017-12-02T08:36:18.965Z Connected system.user.admin
      ! cloud.0 2017-12-02 09:36:08.733 info Connection changed: DISCONNECTED1
      ! cloud.0 2017-12-02 09:36:08.720 info Connection changed: DISCONNECTED3
      ! cloud.0 2017-12-02 09:36:08.695 error Ping timeout
      ! admin.0 2017-12-02 09:36:01.051 info Subscribe on all states again
      ! hm-rega.0 2017-12-02 09:35:23.021 info got state values
      ! hm-rega.0 2017-12-02 09:35:22.471 info request state values
      ! hm-rega.0 2017-12-02 09:35:22.469 info deleted 0 variables
      ! hm-rega.0 2017-12-02 09:35:22.467 info added/updated 6 variables
      ! hm-rega.0 2017-12-02 09:35:22.413 info got 6 variables
      ! hm-rega.0 2017-12-02 09:35:21.532 info deleted 0 programs
      ! hm-rega.0 2017-12-02 09:35:21.531 info added/updated 6 programs
      ! hm-rega.0 2017-12-02 09:35:21.489 info got 6 programs
      ! hm-rega.0 2017-12-02 09:35:19.799 info added/updated rooms to enum.rooms
      ! hm-rega.0 2017-12-02 09:35:19.710 info added/updated functions to enum.functions
      ! hm-rega.0 2017-12-02 09:35:19.627 info added/updated 3 favorites to enum.favorites
      ! hm-rega.0 2017-12-02 09:35:19.588 info time difference local-ccu 1s
      ! hm-rega.0 2017-12-02 09:35:19.559 info ReGaHSS 192.168.170.53 up
      ! admin.0 2017-12-02 09:35:00.821 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! hm-rega.0 2017-12-02 09:34:49.414 error CCU 192.168.170.53 unreachable
      ! hm-rega.0 2017-12-02 09:34:49.413 error post request error: connect ENETUNREACH 192.168.170.53:8181 - Local (0.0.0.0:0)
      ! admin.0 2017-12-02 09:34:40.817 info Subscribe on all states again
      ! admin.0 2017-12-02 09:33:39.863 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:33:25.653 info Subscribe on all states again
      ! admin.0 2017-12-02 09:32:24.713 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:32:02.461 info Subscribe on all states again
      ! hm-rega.0 2017-12-02 09:31:22.291 info got state values
      ! hm-rega.0 2017-12-02 09:31:21.783 info request state values
      ! hm-rega.0 2017-12-02 09:31:21.782 info deleted 0 variables
      ! hm-rega.0 2017-12-02 09:31:21.781 info added/updated 6 variables
      ! hm-rega.0 2017-12-02 09:31:21.730 info got 6 variables
      ! hm-rega.0 2017-12-02 09:31:20.642 info deleted 0 programs
      ! hm-rega.0 2017-12-02 09:31:20.641 info added/updated 6 programs
      ! hm-rega.0 2017-12-02 09:31:20.609 info got 6 programs
      ! hm-rega.0 2017-12-02 09:31:19.764 info added/updated rooms to enum.rooms
      ! hm-rega.0 2017-12-02 09:31:19.681 info added/updated functions to enum.functions
      ! hm-rega.0 2017-12-02 09:31:19.596 info added/updated 3 favorites to enum.favorites
      ! hm-rega.0 2017-12-02 09:31:19.555 info time difference local-ccu 1s
      ! hm-rega.0 2017-12-02 09:31:19.531 info ReGaHSS 192.168.170.53 up
      ! admin.0 2017-12-02 09:31:02.232 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! hm-rega.0 2017-12-02 09:30:49.382 error CCU 192.168.170.53 unreachable
      ! hm-rega.0 2017-12-02 09:30:49.381 error post request error: connect ENETUNREACH 192.168.170.53:8181 - Local (0.0.0.0:0)
      ! admin.0 2017-12-02 09:30:40.524 info Subscribe on all states again
      ! hm-rega.0 2017-12-02 09:30:23.273 info got state values
      ! hm-rega.0 2017-12-02 09:30:22.729 info request state values
      ! hm-rega.0 2017-12-02 09:30:22.728 info deleted 0 variables
      ! hm-rega.0 2017-12-02 09:30:22.727 info added/updated 6 variables
      ! hm-rega.0 2017-12-02 09:30:22.683 info got 6 variables
      ! hm-rega.0 2017-12-02 09:30:21.453 info deleted 0 programs
      ! hm-rega.0 2017-12-02 09:30:21.452 info added/updated 6 programs
      ! hm-rega.0 2017-12-02 09:30:21.421 info got 6 programs
      ! hm-rega.0 2017-12-02 09:30:19.756 info added/updated rooms to enum.rooms
      ! hm-rega.0 2017-12-02 09:30:19.671 info added/updated functions to enum.functions
      ! hm-rega.0 2017-12-02 09:30:19.591 info added/updated 3 favorites to enum.favorites
      ! hm-rega.0 2017-12-02 09:30:19.549 info time difference local-ccu 1s
      ! hm-rega.0 2017-12-02 09:30:19.526 info ReGaHSS 192.168.170.53 up
      ! cloud.0 2017-12-02 09:30:03.628 info Connection changed: CONNECTED1
      ! cloud.0 2017-12-02 09:30:03.361 info 2017-12-02T08:30:03.360Z Connected system.user.admin
      ! cloud.0 2017-12-02 09:29:53.217 info Connection changed: DISCONNECTED1
      ! cloud.0 2017-12-02 09:29:53.215 info Connection changed: DISCONNECTED3
      ! cloud.0 2017-12-02 09:29:53.212 error Ping timeout
      ! hm-rega.0 2017-12-02 09:29:49.370 error CCU 192.168.170.53 unreachable
      ! hm-rega.0 2017-12-02 09:29:49.369 error post request error: connect ENETUNREACH 192.168.170.53:8181 - Local (0.0.0.0:0)
      ! admin.0 2017-12-02 09:29:39.588 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:29:26.296 info Subscribe on all states again
      ! admin.0 2017-12-02 09:28:25.347 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:28:17.849 info Subscribe on all states again
      ! admin.0 2017-12-02 09:27:16.894 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:27:10.740 info Subscribe on all states again
      ! admin.0 2017-12-02 09:26:09.801 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:25:56.199 info Subscribe on all states again
      ! admin.0 2017-12-02 09:24:55.225 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:24:45.636 info Subscribe on all states again
      ! admin.0 2017-12-02 09:23:45.205 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:23:24.910 info Subscribe on all states again
      ! admin.0 2017-12-02 09:22:23.963 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:22:18.843 info Subscribe on all states again
      ! cloud.0 2017-12-02 09:21:29.374 info 2017-12-02T08:21:29.373Z Connected system.user.admin
      ! admin.0 2017-12-02 09:21:18.248 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! cloud.0 2017-12-02 09:21:18.129 info Connection changed: CONNECTED1
      ! cloud.0 2017-12-02 09:21:07.640 info Connection changed: DISCONNECTED1
      ! cloud.0 2017-12-02 09:21:07.638 info Connection changed: DISCONNECTED3
      ! cloud.0 2017-12-02 09:21:07.634 error Ping timeout
      ! admin.0 2017-12-02 09:20:55.370 info Subscribe on all states again
      ! admin.0 2017-12-02 09:19:54.424 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:19:40.311 info Subscribe on all states again
      ! admin.0 2017-12-02 09:18:39.371 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:18:26.013 info Subscribe on all states again
      ! admin.0 2017-12-02 09:17:25.056 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:17:02.599 info Subscribe on all states again
      ! admin.0 2017-12-02 09:16:01.650 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:15:57.422 info Subscribe on all states again
      ! admin.0 2017-12-02 09:14:56.465 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! hm-rega.0 2017-12-02 09:14:56.380 info got state values
      ! hm-rega.0 2017-12-02 09:14:55.789 info request state values
      ! hm-rega.0 2017-12-02 09:14:55.789 info deleted 0 variables
      ! hm-rega.0 2017-12-02 09:14:55.783 info added/updated 6 variables
      ! hm-rega.0 2017-12-02 09:14:55.714 info got 6 variables
      ! hm-rega.0 2017-12-02 09:14:52.652 info deleted 0 programs
      ! hm-rega.0 2017-12-02 09:14:52.650 info added/updated 6 programs
      ! hm-rega.0 2017-12-02 09:14:52.603 info got 6 programs
      ! admin.0 2017-12-02 09:14:51.157 info Subscribe on all states again
      ! hm-rega.0 2017-12-02 09:14:49.653 info added/updated rooms to enum.rooms
      ! hm-rega.0 2017-12-02 09:14:49.561 info added/updated functions to enum.functions
      ! hm-rega.0 2017-12-02 09:14:49.479 info added/updated 3 favorites to enum.favorites
      ! hm-rega.0 2017-12-02 09:14:49.433 info time difference local-ccu 0s
      ! hm-rega.0 2017-12-02 09:14:49.410 info ReGaHSS 192.168.170.53 up
      ! hm-rega.0 2017-12-02 09:14:19.253 error CCU 192.168.170.53 unreachable
      ! hm-rega.0 2017-12-02 09:14:19.252 error post request error: connect ENETUNREACH 192.168.170.53:8181 - Local (0.0.0.0:0)
      ! cloud.0 2017-12-02 09:14:02.790 info Connection changed: CONNECTED4
      ! cloud.0 2017-12-02 09:14:02.572 info Connection changed: CONNECTED2
      ! cloud.0 2017-12-02 09:13:55.967 info Connection changed: DISCONNECTED3
      ! cloud.0 2017-12-02 09:13:55.950 error Connection error: Error: xhr poll error
      ! cloud.0 2017-12-02 09:13:55.772 info 2017-12-02T08:13:55.772Z Connected system.user.admin
      ! admin.0 2017-12-02 09:13:50.726 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! cloud.0 2017-12-02 09:13:40.689 info Connection changed: DISCONNECTED1
      ! cloud.0 2017-12-02 09:13:40.686 info Connection changed: DISCONNECTED3
      ! cloud.0 2017-12-02 09:13:40.682 error Ping timeout
      ! admin.0 2017-12-02 09:13:25.193 info Subscribe on all states again
      ! admin.0 2017-12-02 09:12:24.277 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:12:10.007 info Subscribe on all states again
      ! admin.0 2017-12-02 09:11:09.093 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:11:04.797 info Subscribe on all states again
      ! hm-rega.0 2017-12-02 09:10:24.755 info got state values
      ! hm-rega.0 2017-12-02 09:10:24.235 info request state values
      ! hm-rega.0 2017-12-02 09:10:24.234 info deleted 0 variables
      ! hm-rega.0 2017-12-02 09:10:24.233 info added/updated 6 variables
      ! hm-rega.0 2017-12-02 09:10:24.184 info got 6 variables
      ! hm-rega.0 2017-12-02 09:10:22.299 info deleted 0 programs
      ! hm-rega.0 2017-12-02 09:10:22.298 info added/updated 6 programs
      ! hm-rega.0 2017-12-02 09:10:22.269 info got 6 programs
      ! hm-rega.0 2017-12-02 09:10:19.601 info added/updated rooms to enum.rooms
      ! hm-rega.0 2017-12-02 09:10:19.514 info added/updated functions to enum.functions
      ! hm-rega.0 2017-12-02 09:10:19.435 info added/updated 3 favorites to enum.favorites
      ! hm-rega.0 2017-12-02 09:10:19.394 info time difference local-ccu 0s
      ! hm-rega.0 2017-12-02 09:10:19.372 info ReGaHSS 192.168.170.53 up
      ! cloud.0 2017-12-02 09:10:12.292 info 2017-12-02T08:10:12.292Z Connected system.user.admin
      ! cloud.0 2017-12-02 09:10:05.641 info Connection changed: CONNECTED1
      ! admin.0 2017-12-02 09:10:04.677 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! cloud.0 2017-12-02 09:09:54.595 info Connection changed: DISCONNECTED1
      ! cloud.0 2017-12-02 09:09:54.586 info Connection changed: DISCONNECTED3
      ! cloud.0 2017-12-02 09:09:54.560 error Ping timeout
      ! hm-rega.0 2017-12-02 09:09:49.222 error CCU 192.168.170.53 unreachable
      ! hm-rega.0 2017-12-02 09:09:49.221 error post request error: connect ENETUNREACH 192.168.170.53:8181 - Local (0.0.0.0:0)
      ! admin.0 2017-12-02 09:09:39.612 info Subscribe on all states again
      ! admin.0 2017-12-02 09:08:38.664 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:08:32.444 info Subscribe on all states again
      ! admin.0 2017-12-02 09:07:31.486 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:07:25.274 info Subscribe on all states again
      ! admin.0 2017-12-02 09:06:24.327 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:06:10.183 info Subscribe on all states again
      ! admin.0 2017-12-02 09:05:09.275 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:04:54.938 info Subscribe on all states again
      ! admin.0 2017-12-02 09:03:53.987 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:03:40.757 info Subscribe on all states again
      ! admin.0 2017-12-02 09:02:39.809 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:02:25.052 info Subscribe on all states again
      ! admin.0 2017-12-02 09:01:24.162 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 09:01:09.983 info Subscribe on all states again
      ! admin.0 2017-12-02 09:00:09.022 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 08:59:54.888 info Subscribe on all states again
      ! admin.0 2017-12-02 08:58:53.950 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 08:58:47.782 info Subscribe on all states again
      ! admin.0 2017-12-02 08:57:46.831 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 08:57:25.652 info Subscribe on all states again
      ! admin.0 2017-12-02 08:56:24.711 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 08:56:17.349 info Subscribe on all states again
      ! admin.0 2017-12-02 08:55:16.401 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 08:55:10.258 info Subscribe on all states again
      ! admin.0 2017-12-02 08:54:09.304 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 08:54:02.187 info Subscribe on all states again
      ! admin.0 2017-12-02 08:53:01.230 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 08:52:54.967 info Subscribe on all states again
      ! admin.0 2017-12-02 08:51:54.004 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
      ! admin.0 2017-12-02 08:51:46.836 info Subscribe on all states again
      ! hm-rega.0 2017-12-02 08:51:12.285 info got state values
      ! hm-rega.0 2017-12-02 08:51:11.445 info request state values
      ! hm-rega.0 2017-12-02 08:51:11.445 info deleted 0 variables
      ! hm-rega.0 2017-12-02 08:51:11.444 info added/updated 6 variables
      ! hm-rega.0 2017-12-02 08:51:11.402 info got 6 variables
      ! hm-rega.0 2017-12-02 08:51:11.320 info deleted 0 programs
      ! hm-rega.0 2017-12-02 08:51:11.319 info added/updated 6 programs
      ! hm-rega.0 2017-12-02 08:51:11.289 info got 6 programs
      ! hm-rega.0 2017-12-02 08:50:49.440 info added/updated rooms to enum.rooms
      ! hm-rega.0 2017-12-02 08:50:49.355 info added/updated functions to enum.functions
      ! hm-rega.0 2017-12-02 08:50:49.274 info added/updated 3 favorites to enum.favorites
      und hier die Ereignise
      ! stateChange system.adapter.admin.0.outputCount 8 true admin.0 2017-12-02 09:52:13.642 2017-12-01 21:03:46.825
      ! stateChange system.adapter.admin.0.inputCount 8 true admin.0 2017-12-02 09:52:13.642 2017-12-02 09:51:58.638
      ! stateChange system.adapter.admin.0.uptime 46173 true admin.0 2017-12-02 09:52:13.641 2017-12-02 09:52:13.641
      ! stateChange system.adapter.admin.0.memHeapUsed 18.16 true admin.0 2017-12-02 09:52:13.641 2017-12-02 09:52:13.641
      ! stateChange system.adapter.admin.0.memHeapTotal 28.98 true admin.0 2017-12-02 09:52:13.640 2017-12-02 09:51:28.630
      ! stateChange system.adapter.admin.0.memRss 54.48 true admin.0 2017-12-02 09:52:13.639 2017-12-02 09:51:58.635
      ! stateChange system.adapter.admin.0.connected true true admin.0 2017-12-02 09:52:13.638 2017-12-02 09:36:43.453
      ! stateChange system.adapter.admin.0.alive true true admin.0 2017-12-02 09:52:13.630 2017-12-02 09:36:43.444
      ! stateChange system.adapter.admin.0.outputCount 8 true admin.0 2017-12-02 09:51:58.638 2017-12-01 21:03:46.825
      ! stateChange system.adapter.admin.0.inputCount 8 true admin.0 2017-12-02 09:51:58.638 2017-12-02 09:51:58.638
      ! stateChange system.adapter.admin.0.uptime 46158 true admin.0 2017-12-02 09:51:58.637 2017-12-02 09:51:58.637
      ! stateChange system.adapter.admin.0.memHeapUsed 18.08 true admin.0 2017-12-02 09:51:58.637 2017-12-02 09:51:58.637
      ! stateChange system.adapter.admin.0.memHeapTotal 28.98 true admin.0 2017-12-02 09:51:58.636 2017-12-02 09:51:28.630
      ! stateChange system.adapter.admin.0.memRss 54.48 true admin.0 2017-12-02 09:51:58.635 2017-12-02 09:51:58.635
      ! stateChange system.adapter.admin.0.connected true true admin.0 2017-12-02 09:51:58.634 2017-12-02 09:36:43.453
      ! stateChange system.adapter.admin.0.alive true true admin.0 2017-12-02 09:51:58.626 2017-12-02 09:36:43.444
      ! stateChange system.adapter.admin.0.outputCount 8 true admin.0 2017-12-02 09:51:43.636 2017-12-01 21:03:46.825
      ! stateChange system.adapter.admin.0.inputCount 858 true admin.0 2017-12-02 09:51:43.635 2017-12-02 09:51:43.635
      ! stateChange system.adapter.admin.0.uptime 46143 true admin.0 2017-12-02 09:51:43.635 2017-12-02 09:51:43.635
      ! stateChange system.adapter.admin.0.memHeapUsed 17.98 true admin.0 2017-12-02 09:51:43.634 2017-12-02 09:51:43.634
      ! stateChange system.adapter.admin.0.memHeapTotal 28.98 true admin.0 2017-12-02 09:51:43.633 2017-12-02 09:51:28.630
      ! stateChange system.adapter.admin.0.memRss 54.25 true admin.0 2017-12-02 09:51:43.633 2017-12-02 09:51:43.633
      ! stateChange system.adapter.admin.0.connected true true admin.0 2017-12-02 09:51:43.631 2017-12-02 09:36:43.453
      ! stateChange system.adapter.admin.0.alive true true admin.0 2017-12-02 09:51:43.623 2017-12-02 09:36:43.444
      ! stateChange system.host.RBpi3-Sauna.outputCount 10 true host.RBpi3-Sauna 2017-12-02 09:51:31.822 2017-12-02 09:45:50.752
      ! stateChange system.host.RBpi3-Sauna.inputCount 0 true host.RBpi3-Sauna 2017-12-02 09:51:31.821 2017-12-02 09:51:29.182
      ! stateChange system.host.RBpi3-Sauna.freemem 534 true host.RBpi3-Sauna 2017-12-02 09:51:31.821 2017-12-02 09:51:31.821
      ! stateChange system.host.RBpi3-Sauna.uptime 2975747 true host.RBpi3-Sauna 2017-12-02 09:51:31.820 2017-12-02 09:51:31.703
      ! stateChange system.host.RBpi3-Sauna.memHeapUsed 12.98 true host.RBpi3-Sauna 2017-12-02 09:51:31.819 2017-12-02 09:51:31.819
      ! stateChange system.host.RBpi3-Sauna.memHeapTotal 16.99 true host.RBpi3-Sauna 2017-12-02 09:51:31.817 2017-12-02 09:45:50.748
      ! stateChange system.host.RBpi3-Sauna.memRss 41.82 true host.RBpi3-Sauna 2017-12-02 09:51:31.812 2017-12-02 09:51:31.812
      ! stateChange system.host.RBpi3-Sauna.mem 58 true host.RBpi3-Sauna 2017-12-02 09:51:31.811 2017-12-02 09:45:49.846
      ! stateChange system.host.RBpi3-Sauna.load 0.01 true host.RBpi3-Sauna 2017-12-02 09:51:31.806 2017-12-02 09:51:13.369
      ! stateChange system.host.RBpi3-Sauna.alive true true host.RBpi3-Sauna 2017-12-02 09:51:31.797 2017-12-02 09:36:23.047
      ! stateChange system.host.RBpi3-Garage.outputCount 10 true host.RBpi3-Garage 2017-12-02 09:51:31.783 2017-12-01 10:52:26.840
      ! stateChange system.host.RBpi3-Garage.inputCount 0 true host.RBpi3-Garage 2017-12-02 09:51:31.782 2017-12-02 09:51:28.688
      ! stateChange system.host.RBpi3-Garage.freemem 710 true host.RBpi3-Garage 2017-12-02 09:51:31.781 2017-12-02 09:50:19.132
      ! stateChange system.host.RBpi3-Garage.uptime 2414448 true host.RBpi3-Garage 2017-12-02 09:51:31.781 2017-12-02 09:51:31.747
      ! stateChange system.host.RBpi3-Garage.memHeapUsed 11.64 true host.RBpi3-Garage 2017-12-02 09:51:31.780 2017-12-02 09:51:31.780
      ! stateChange system.host.RBpi3-Garage.memHeapTotal 15.99 true host.RBpi3-Garage 2017-12-02 09:51:31.779 2017-12-02 09:47:45.197
      ! stateChange system.host.RBpi3-Garage.memRss 38.76 true host.RBpi3-Garage 2017-12-02 09:51:31.779 2017-12-02 09:51:31.779
      ! stateChange system.host.RBpi3-Garage.mem 77 true host.RBpi3-Garage 2017-12-02 09:51:31.778 2017-12-02 06:45:42.641
      ! stateChange system.host.RBpi3-Garage.load 0.11 true host.RBpi3-Garage 2017-12-02 09:51:31.777 2017-12-02 09:51:28.643
      ! stateChange system.host.RBpi3-Garage.alive true true host.RBpi3-Garage 2017-12-02 09:51:31.776 2017-12-02 09:36:28.962
      ! stateChange system.host.RBpi3-Garage.outputCount 10 true host.RBpi3-Garage 2017-12-02 09:51:31.766 2017-12-01 10:52:26.840
      ! stateChange system.host.RBpi3-Garage.inputCount 0 true host.RBpi3-Garage 2017-12-02 09:51:31.765 2017-12-02 09:51:28.688
      ! stateChange system.host.RBpi3-Garage.freemem 710 true host.RBpi3-Garage 2017-12-02 09:51:31.765 2017-12-02 09:50:19.132
      ! stateChange system.host.RBpi3-Garage.uptime 2414448 true host.RBpi3-Garage 2017-12-02 09:51:31.764 2017-12-02 09:51:31.747
      ! stateChange system.host.RBpi3-Garage.memHeapUsed 11.61 true host.RBpi3-Garage 2017-12-02 09:51:31.764 2017-12-02 09:51:31.764
      ! stateChange system.host.RBpi3-Garage.memHeapTotal 15.99 true host.RBpi3-Garage 2017-12-02 09:51:31.763 2017-12-02 09:47:45.197
      ! stateChange system.host.RBpi3-Garage.memRss 38.72 true host.RBpi3-Garage 2017-12-02 09:51:31.763 2017-12-02 09:51:31.763
      ! stateChange system.host.RBpi3-Garage.mem 77 true host.RBpi3-Garage 2017-12-02 09:51:31.762 2017-12-02 06:45:42.641
      ! stateChange system.host.RBpi3-Garage.load 0.11 true host.RBpi3-Garage 2017-12-02 09:51:31.761 2017-12-02 09:51:28.643
      ! stateChange system.host.RBpi3-Garage.alive true true host.RBpi3-Garage 2017-12-02 09:51:31.760 2017-12-02 09:36:28.962
      ! stateChange system.host.RBpi3-Garage.outputCount 10 true host.RBpi3-Garage 2017-12-02 09:51:31.760 2017-12-01 10:52:26.840
      ! stateChange system.host.RBpi3-Garage.inputCount 0 true host.RBpi3-Garage 2017-12-02 09:51:31.758 2017-12-02 09:51:28.688
      ! stateChange system.host.RBpi3-Garage.freemem 710 true host.RBpi3-Garage 2017-12-02 09:51:31.747 2017-12-02 09:50:19.132
      ! stateChange system.host.RBpi3-Garage.uptime 2414448 true host.RBpi3-Garage 2017-12-02 09:51:31.747 2017-12-02 09:51:31.747
      ! stateChange system.host.RBpi3-Garage.memHeapUsed 11.58 true host.RBpi3-Garage 2017-12-02 09:51:31.746 2017-12-02 09:51:31.746
      ! stateChange system.host.RBpi3-Garage.memHeapTotal 15.99 true host.RBpi3-Garage 2017-12-02 09:51:31.745 2017-12-02 09:47:45.197
      ! stateChange system.host.RBpi3-Garage.memRss 38.7 true host.RBpi3-Garage 2017-12-02 09:51:31.744 2017-12-02 09:51:31.744
      ! stateChange system.host.RBpi3-Garage.mem 77 true host.RBpi3-Garage 2017-12-02 09:51:31.743 2017-12-02 06:45:42.641
      ! stateChange system.host.RBpi3-Garage.load 0.11 true host.RBpi3-Garage 2017-12-02 09:51:31.738 2017-12-02 09:51:28.643
      ! stateChange system.host.RBpi3-Garage.alive true true host.RBpi3-Garage 2017-12-02 09:51:31.735 2017-12-02 09:36:28.962
      ! stateChange system.host.RBpi3-Sauna.outputCount 10 true host.RBpi3-Sauna 2017-12-02 09:51:31.707 2017-12-02 09:45:50.752
      ! stateChange system.host.RBpi3-Sauna.inputCount 0 true host.RBpi3-Sauna 2017-12-02 09:51:31.707 2017-12-02 09:51:29.182
      ! stateChange system.host.RBpi3-Sauna.freemem 533 true host.RBpi3-Sauna 2017-12-02 09:51:31.706 2017-12-02 09:51:29.225
      ! stateChange system.host.RBpi3-Sauna.uptime 2975747 true host.RBpi3-Sauna 2017-12-02 09:51:31.703 2017-12-02 09:51:31.703
      ! stateChange system.host.RBpi3-Sauna.memHeapUsed 12.95 true host.RBpi3-Sauna 2017-12-02 09:51:31.698 2017-12-02 09:51:31.698
      ! stateChange system.host.RBpi3-Sauna.memHeapTotal 16.99 true host.RBpi3-Sauna 2017-12-02 09:51:31.698 2017-12-02 09:45:50.748
      ! stateChange system.host.RBpi3-Sauna.memRss 41.79 true host.RBpi3-Sauna 2017-12-02 09:51:31.697 2017-12-02 09:51:31.697
      ! stateChange system.host.RBpi3-Sauna.mem 58 true host.RBpi3-Sauna 2017-12-02 09:51:31.695 2017-12-02 09:45:49.846
      ! stateChange system.host.RBpi3-Sauna.load 0.01 true host.RBpi3-Sauna 2017-12-02 09:51:31.691 2017-12-02 09:51:13.369
      ! stateChange system.host.RBpi3-Sauna.alive true true host.RBpi3-Sauna 2017-12-02 09:51:31.686 2017-12-02 09:36:23.047
      ! stateChange system.host.RBpi3-Master.outputCount 10 true host.RBpi3-Master 2017-12-02 09:51:31.175 2017-12-02 09:46:16.054
      ! stateChange system.host.RBpi3-Master.inputCount 1 true host.RBpi3-Master 2017-12-02 09:51:31.175 2017-12-02 09:49:46.132
      ! stateChange system.host.RBpi3-Master.freemem 552 true host.RBpi3-Master 2017-12-02 09:51:31.174 2017-12-02 09:51:31.174
      ! stateChange system.host.RBpi3-Master.uptime 46277 true host.RBpi3-Master 2017-12-02 09:51:31.173 2017-12-02 09:51:31.173
      ! stateChange system.host.RBpi3-Master.memHeapUsed 25.08 true host.RBpi3-Master 2017-12-02 09:51:31.172 2017-12-02 09:51:31.172
      ! stateChange system.host.RBpi3-Master.memHeapTotal 35.19 true host.RBpi3-Master 2017-12-02 09:51:31.171 2017-12-02 09:50:31.153
      ! stateChange system.host.RBpi3-Master.memRss 64.32 true host.RBpi3-Master 2017-12-02 09:51:31.170 2017-12-02 09:51:31.170
      ! stateChange system.host.RBpi3-Master.mem 60 true host.RBpi3-Master 2017-12-02 09:51:31.170 2017-12-02 09:50:31.152
      ! stateChange system.host.RBpi3-Master.load 0.45 true host.RBpi3-Master 2017-12-02 09:51:31.169 2017-12-02 09:51:31.169
      ! stateChange system.host.RBpi3-Master.alive true true host.RBpi3-Master 2017-12-02 09:51:31.167 2017-12-02 07:47:38.873
      ! stateChange system.host.RBpi3-Sauna.outputCount 10 true host.RBpi3-Sauna 2017-12-02 09:51:30.858 2017-12-02 09:45:50.752
      ! stateChange system.host.RBpi3-Sauna.inputCount 0 true host.RBpi3-Sauna 2017-12-02 09:51:30.858 2017-12-02 09:51:29.182
      ! stateChange system.host.RBpi3-Sauna.freemem 533 true host.RBpi3-Sauna 2017-12-02 09:51:30.857 2017-12-02 09:51:29.225
      ! stateChange system.host.RBpi3-Sauna.uptime 2975746 true host.RBpi3-Sauna 2017-12-02 09:51:30.857 2017-12-02 09:51:30.857
      ! stateChange system.host.RBpi3-Sauna.memHeapUsed 12.92 true host.RBpi3-Sauna 2017-12-02 09:51:30.856 2017-12-02 09:51:30.856
      ! stateChange system.host.RBpi3-Sauna.memHeapTotal 16.99 true host.RBpi3-Sauna 2017-12-02 09:51:30.855 2017-12-02 09:45:50.748
      ! stateChange system.host.RBpi3-Sauna.memRss 41.76 true host.RBpi3-Sauna 2017-12-02 09:51:30.855 2017-12-02 09:51:30.855
      ! stateChange system.host.RBpi3-Sauna.mem 58 true host.RBpi3-Sauna 2017-12-02 09:51:30.854 2017-12-02 09:45:49.846
      ! stateChange system.host.RBpi3-Sauna.load 0.01 true host.RBpi3-Sauna 2017-12-02 09:51:30.853 2017-12-02 09:51:13.369
      ! stateChange system.host.RBpi3-Sauna.alive true true host.RBpi3-Sauna 2017-12-02 09:51:30.852 2017-12-02 09:36:23.047
      ! stateChange system.host.RBpi3-Heizung.outputCount 10 true host.RBpi3-Heizung 2017-12-02 09:51:30.832 2017-12-01 13:29:28.573
      ! stateChange system.host.RBpi3-Heizung.inputCount 0 true host.RBpi3-Heizung 2017-12-02 09:51:30.832 2017-12-02 09:51:28.840
      ! stateChange system.host.RBpi3-Heizung.freemem 549 true host.RBpi3-Heizung 2017-12-02 09:51:30.831 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.uptime 2941827 true host.RBpi3-Heizung 2017-12-02 09:51:30.830 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.memHeapUsed 14.96 true host.RBpi3-Heizung 2017-12-02 09:51:30.830 2017-12-02 09:51:30.830
      ! stateChange system.host.RBpi3-Heizung.memHeapTotal 20 true host.RBpi3-Heizung 2017-12-02 09:51:30.828 2017-12-02 09:49:25.908
      ! stateChange system.host.RBpi3-Heizung.memRss 39.68 true host.RBpi3-Heizung 2017-12-02 09:51:30.827 2017-12-02 09:51:30.734
      ! stateChange system.host.RBpi3-Heizung.mem 59 true host.RBpi3-Heizung 2017-12-02 09:51:30.827 2017-12-02 09:48:40.893
      ! stateChange system.host.RBpi3-Heizung.load 0.11 true host.RBpi3-Heizung 2017-12-02 09:51:30.826 2017-12-02 09:51:30.425
      ! stateChange system.host.RBpi3-Heizung.alive true true host.RBpi3-Heizung 2017-12-02 09:51:30.825 2017-12-02 09:36:36.475
      ! stateChange system.host.RBpi3-Heizung.outputCount 10 true host.RBpi3-Heizung 2017-12-02 09:51:30.824 2017-12-01 13:29:28.573
      ! stateChange system.host.RBpi3-Heizung.inputCount 0 true host.RBpi3-Heizung 2017-12-02 09:51:30.824 2017-12-02 09:51:28.840
      ! stateChange system.host.RBpi3-Heizung.freemem 549 true host.RBpi3-Heizung 2017-12-02 09:51:30.823 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.uptime 2941827 true host.RBpi3-Heizung 2017-12-02 09:51:30.822 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.memHeapUsed 14.91 true host.RBpi3-Heizung 2017-12-02 09:51:30.821 2017-12-02 09:51:30.821
      ! stateChange system.host.RBpi3-Heizung.memHeapTotal 20 true host.RBpi3-Heizung 2017-12-02 09:51:30.821 2017-12-02 09:49:25.908
      ! stateChange system.host.RBpi3-Heizung.memRss 39.68 true host.RBpi3-Heizung 2017-12-02 09:51:30.820 2017-12-02 09:51:30.734
      ! stateChange system.host.RBpi3-Heizung.mem 59 true host.RBpi3-Heizung 2017-12-02 09:51:30.819 2017-12-02 09:48:40.893
      ! stateChange system.host.RBpi3-Heizung.load 0.11 true host.RBpi3-Heizung 2017-12-02 09:51:30.819 2017-12-02 09:51:30.425
      ! stateChange system.host.RBpi3-Heizung.alive true true host.RBpi3-Heizung 2017-12-02 09:51:30.818 2017-12-02 09:36:36.475
      ! stateChange system.host.RBpi3-Heizung.outputCount 10 true host.RBpi3-Heizung 2017-12-02 09:51:30.817 2017-12-01 13:29:28.573
      ! stateChange system.host.RBpi3-Heizung.inputCount 0 true host.RBpi3-Heizung 2017-12-02 09:51:30.816 2017-12-02 09:51:28.840
      ! stateChange system.host.RBpi3-Heizung.freemem 549 true host.RBpi3-Heizung 2017-12-02 09:51:30.816 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.uptime 2941827 true host.RBpi3-Heizung 2017-12-02 09:51:30.815 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.memHeapUsed 14.9 true host.RBpi3-Heizung 2017-12-02 09:51:30.815 2017-12-02 09:51:30.815
      ! stateChange system.host.RBpi3-Heizung.memHeapTotal 20 true host.RBpi3-Heizung 2017-12-02 09:51:30.814 2017-12-02 09:49:25.908
      ! stateChange system.host.RBpi3-Heizung.memRss 39.68 true host.RBpi3-Heizung 2017-12-02 09:51:30.814 2017-12-02 09:51:30.734
      ! stateChange system.host.RBpi3-Heizung.mem 59 true host.RBpi3-Heizung 2017-12-02 09:51:30.813 2017-12-02 09:48:40.893
      ! stateChange system.host.RBpi3-Heizung.load 0.11 true host.RBpi3-Heizung 2017-12-02 09:51:30.812 2017-12-02 09:51:30.425
      ! stateChange system.host.RBpi3-Heizung.alive true true host.RBpi3-Heizung 2017-12-02 09:51:30.812 2017-12-02 09:36:36.475
      ! stateChange system.host.RBpi3-Heizung.outputCount 10 true host.RBpi3-Heizung 2017-12-02 09:51:30.811 2017-12-01 13:29:28.573
      ! stateChange system.host.RBpi3-Heizung.inputCount 0 true host.RBpi3-Heizung 2017-12-02 09:51:30.811 2017-12-02 09:51:28.840
      ! stateChange system.host.RBpi3-Heizung.freemem 549 true host.RBpi3-Heizung 2017-12-02 09:51:30.810 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.uptime 2941827 true host.RBpi3-Heizung 2017-12-02 09:51:30.809 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.memHeapUsed 14.87 true host.RBpi3-Heizung 2017-12-02 09:51:30.808 2017-12-02 09:51:30.808
      ! stateChange system.host.RBpi3-Heizung.memHeapTotal 20 true host.RBpi3-Heizung 2017-12-02 09:51:30.808 2017-12-02 09:49:25.908
      ! stateChange system.host.RBpi3-Heizung.memRss 39.68 true host.RBpi3-Heizung 2017-12-02 09:51:30.807 2017-12-02 09:51:30.734
      ! stateChange system.host.RBpi3-Heizung.mem 59 true host.RBpi3-Heizung 2017-12-02 09:51:30.806 2017-12-02 09:48:40.893
      ! stateChange system.host.RBpi3-Heizung.load 0.11 true host.RBpi3-Heizung 2017-12-02 09:51:30.806 2017-12-02 09:51:30.425
      ! stateChange system.host.RBpi3-Heizung.alive true true host.RBpi3-Heizung 2017-12-02 09:51:30.805 2017-12-02 09:36:36.475
      ! stateChange system.host.RBpi3-Heizung.outputCount 10 true host.RBpi3-Heizung 2017-12-02 09:51:30.805 2017-12-01 13:29:28.573
      ! stateChange system.host.RBpi3-Heizung.inputCount 0 true host.RBpi3-Heizung 2017-12-02 09:51:30.804 2017-12-02 09:51:28.840
      ! stateChange system.host.RBpi3-Heizung.freemem 549 true host.RBpi3-Heizung 2017-12-02 09:51:30.804 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.uptime 2941827 true host.RBpi3-Heizung 2017-12-02 09:51:30.803 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.memHeapUsed 14.84 true host.RBpi3-Heizung 2017-12-02 09:51:30.803 2017-12-02 09:51:30.803
      ! stateChange system.host.RBpi3-Heizung.memHeapTotal 20 true host.RBpi3-Heizung 2017-12-02 09:51:30.802 2017-12-02 09:49:25.908
      ! stateChange system.host.RBpi3-Heizung.memRss 39.68 true host.RBpi3-Heizung 2017-12-02 09:51:30.801 2017-12-02 09:51:30.734
      ! stateChange system.host.RBpi3-Heizung.mem 59 true host.RBpi3-Heizung 2017-12-02 09:51:30.801 2017-12-02 09:48:40.893
      ! stateChange system.host.RBpi3-Heizung.load 0.11 true host.RBpi3-Heizung 2017-12-02 09:51:30.800 2017-12-02 09:51:30.425
      ! stateChange system.host.RBpi3-Heizung.alive true true host.RBpi3-Heizung 2017-12-02 09:51:30.800 2017-12-02 09:36:36.475
      ! stateChange system.host.RBpi3-Heizung.outputCount 10 true host.RBpi3-Heizung 2017-12-02 09:51:30.799 2017-12-01 13:29:28.573
      ! stateChange system.host.RBpi3-Heizung.inputCount 0 true host.RBpi3-Heizung 2017-12-02 09:51:30.798 2017-12-02 09:51:28.840
      ! stateChange system.host.RBpi3-Heizung.freemem 549 true host.RBpi3-Heizung 2017-12-02 09:51:30.798 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.uptime 2941827 true host.RBpi3-Heizung 2017-12-02 09:51:30.797 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.memHeapUsed 14.81 true host.RBpi3-Heizung 2017-12-02 09:51:30.796 2017-12-02 09:51:30.796
      ! stateChange system.host.RBpi3-Heizung.memHeapTotal 20 true host.RBpi3-Heizung 2017-12-02 09:51:30.796 2017-12-02 09:49:25.908
      ! stateChange system.host.RBpi3-Heizung.memRss 39.68 true host.RBpi3-Heizung 2017-12-02 09:51:30.795 2017-12-02 09:51:30.734
      ! stateChange system.host.RBpi3-Heizung.mem 59 true host.RBpi3-Heizung 2017-12-02 09:51:30.795 2017-12-02 09:48:40.893
      ! stateChange system.host.RBpi3-Heizung.load 0.11 true host.RBpi3-Heizung 2017-12-02 09:51:30.794 2017-12-02 09:51:30.425
      ! stateChange system.host.RBpi3-Heizung.alive true true host.RBpi3-Heizung 2017-12-02 09:51:30.792 2017-12-02 09:36:36.475
      ! stateChange system.host.RBpi3-Heizung.outputCount 10 true host.RBpi3-Heizung 2017-12-02 09:51:30.744 2017-12-01 13:29:28.573
      ! stateChange system.host.RBpi3-Heizung.inputCount 0 true host.RBpi3-Heizung 2017-12-02 09:51:30.743 2017-12-02 09:51:28.840
      ! stateChange system.host.RBpi3-Heizung.freemem 549 true host.RBpi3-Heizung 2017-12-02 09:51:30.743 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.uptime 2941827 true host.RBpi3-Heizung 2017-12-02 09:51:30.742 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.memHeapUsed 14.77 true host.RBpi3-Heizung 2017-12-02 09:51:30.742 2017-12-02 09:51:30.742
      ! stateChange system.host.RBpi3-Heizung.memHeapTotal 20 true host.RBpi3-Heizung 2017-12-02 09:51:30.741 2017-12-02 09:49:25.908
      ! stateChange system.host.RBpi3-Heizung.memRss 39.68 true host.RBpi3-Heizung 2017-12-02 09:51:30.740 2017-12-02 09:51:30.734
      ! stateChange system.host.RBpi3-Heizung.mem 59 true host.RBpi3-Heizung 2017-12-02 09:51:30.740 2017-12-02 09:48:40.893
      ! stateChange system.host.RBpi3-Heizung.load 0.11 true host.RBpi3-Heizung 2017-12-02 09:51:30.739 2017-12-02 09:51:30.425
      ! stateChange system.host.RBpi3-Heizung.alive true true host.RBpi3-Heizung 2017-12-02 09:51:30.739 2017-12-02 09:36:36.475
      ! stateChange system.host.RBpi3-Heizung.outputCount 10 true host.RBpi3-Heizung 2017-12-02 09:51:30.738 2017-12-01 13:29:28.573
      ! stateChange system.host.RBpi3-Heizung.inputCount 0 true host.RBpi3-Heizung 2017-12-02 09:51:30.737 2017-12-02 09:51:28.840
      ! stateChange system.host.RBpi3-Heizung.freemem 549 true host.RBpi3-Heizung 2017-12-02 09:51:30.737 2017-12-02 09:51:30.429
      ! stateChange system.host.RBpi3-Heizung.uptime 2941827 true host.RBpi3-Heizung 2017-12-02 09:51:30.736 2017-12-02 09:51:30.429
      ich verstehe nicht warum die Ereignis immer noch auflaufen obwohl die Adapter Deaktiviert sind.
      • Dutchman
        Das hört sich nach einer endlosen Schleife an.
        Hast du nach deaktivieren der Adapter das System Mal neu durch gestartet ?
        Auf der console Kommando "top" eingehen könnte auch helfen um zu sehen ob da noch was läuft
        Send from mobile device
          Ja habe ioBroker und den Raspberry pi neugestartet
          ~~![](</s><URL url=)http://up.picr.de/31108457ks.png" />
          das sag mir nicht viel.~~
            hast du im log das hier gesehen?
            Rainer
            • ruhr70
              ruhr70 last edited by
              Deine Ausgabe von top sieht aus meiner Sicht gut aus.
              Man sieht, dass nur iobroker an sich (iobroker.js-con), der redis Server und iobroker admin läuft.
              Wie Du schon geschrieben hattest, tauchen in deinen Ereignissen eine Menge Ereignisse auf, die mit admin nichts zu tun haben. Warum das so ist, bin ich überfragt.
              Hattest Du den ganzen Rechner schon einmal neu gestartet?
                @Homoran:
                Rainer `
                Hab vermutet das das durch das vom Mehrmalige Neustarten kommt.
                Habe den Ganzen Raspberry schon mehrmals neu gestartet ohne Änderung.
                Was ich echt interessant finde ist das sogar der Adapter rpi2.0 die GPIO beschalteten Eingänge weiter verarbeitet obwohl dieser auch auf Stop ist.
                ![](</s><URL url=)http://up.picr.de/31111538tr.jpg" />
                  ÄHM,
                  hast du eine Multihost Umgebung?
                  Und alle RasPis richtig konfiguriert?
                  (Adapterversionen; Controller; Ports?)
                  Rainer
                    ~~![](</s><URL url=)http://up.picr.de/31112179tj.jpg" />
                    Das passt alles die Hosts habe ich schon vor Monaten eingerichtet, aber das hier ist neu.~~
                      @elektrofreak:
                      die Hosts habe ich schon vor Monaten eingerichtet, `
                      gut! Das ist die eine Aussage 😉
                      das die andere:
                      @elektrofreak:
                      Das passt alles `
                      und das hast du auch gelesen?
                      @[url=https://github.com/ioBroker/ioBroker.js-controller/blob/master/CHANGELOG.md#110-2017-06-08:
                      ~~Github"]~~1.1.0 (2017-06-08)
                      (bluefox) BREAKING Changes: For multihost systems the user MUST explicit allow connections from other IPs in /opt/iobroker/iobroker-data/iobroker.json
                      "host": "127.0.0.1",
                      "host": "0.0.0.0",
                      for objects (line 11) and for states (line 21). `
                      …und umgesetzt?
                      und warum ist "Adapter" grün?
                      Rainer
                        ja ist alles korrekt.
                        Warum der Register Adapter Grün war zu dem Zeitpunkt, kann ich nicht sagen ist mir gar nicht aufgefallen, weis auch gar nicht was das aussagen soll, das habe ich noch nie gesehen.
                        • eric2905
                          eric2905 last edited by
                          @elektrofreak:
                          …weis auch gar nicht was das aussagen soll, das habe ich noch nie gesehen. `
                          Wenn der Reiter "Adapter" grün wird, gibt es Updates für mind. einen Adapter (siehe auch Doku zum Admin ==> http://www.iobroker.net/docu/?page_id=5 … tes_suchen).
                          Gleiches gilt für den Reiter "Hosts" (siehe auch hier die Doku dazu ==> http://www.iobroker.net/docu/?page_id=5 … es_abrufen).
                          Gruß,
                          Eric
                            deshalb ist das Grün jetzt wenn hab das eine Update kurz darauf gemacht.
                            • SmarthomeMF
                              SmarthomeMF last edited by
                              Hallo
                              Habe das Problem auch.
                              weiß aber nicht warum.
                              Ich habe nur ein Skript laufen und ca15 Adapter.
                              Nun habe ich in den Log eine Menge Fehler gefunden!!!!
                              Die sind aber neu!!
                              ! host.ioBroker-Pi
                              ! 2018-01-12 18:45:19.199
                              ! info
                              ! instance system.adapter.hs100.0 terminated with code 0 (OK)
                              ! Caught
                              ! error
                              ! by controller[711]: TCP Timeout
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.198
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! by controller[711]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2453): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[711]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2452): Error: TCP Timeout
                              ! Caught
                              ! 2018-01-12 18:45:19.197
                              ! error
                              ! by controller[711]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2451): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[711]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2450): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[711]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2449): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[711]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2448): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[711]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2447): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[711]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2446): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[711]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2445): Error: TCP Timeout
                              ! Caught
                              ! 2018-01-12 18:45:19.196
                              ! error
                              ! by controller[711]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2444): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[711]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2443): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[710]: TCP Timeout
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.195
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.194
                              ! error
                              ! by controller[710]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2442): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[710]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2441): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[710]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2440): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[710]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2439): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[710]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2438): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[710]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2437): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[710]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2436): Error: TCP Timeout
                              ! Caught
                              ! 2018-01-12 18:45:19.193
                              ! error
                              ! by controller[710]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2435): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[710]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2434): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[710]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2433): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[710]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2432): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[710]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2431): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[710]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2430): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[709]: TCP Timeout
                              ! Caught
                              ! 2018-01-12 18:45:19.192
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.191
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! by controller[709]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2429): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[709]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2428): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[709]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2427): Error: TCP Timeout
                              ! Caught
                              ! 2018-01-12 18:45:19.190
                              ! error
                              ! by controller[709]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2426): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[709]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2425): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[709]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2424): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[709]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2423): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[709]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2422): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[709]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2421): Error: TCP Timeout
                              ! Caught
                              ! 2018-01-12 18:45:19.189
                              ! error
                              ! by controller[709]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2420): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[709]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2419): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.188
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.187
                              ! error
                              ! by controller[708]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2418): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[708]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2417): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[708]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2416): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[708]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2415): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[708]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2414): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[708]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2413): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[708]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2412): Error: TCP Timeout
                              ! Caught
                              ! 2018-01-12 18:45:19.186
                              ! error
                              ! by controller[708]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2411): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[708]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2410): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[708]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2409): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[707]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2408): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[706]: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[705]: TCP Timeout
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.185
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.184
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! by controller[704]: TCP Timeout
                              ! Caught
                              ! 2018-01-12 18:45:19.183
                              ! error
                              ! by controller[703]: TCP Timeout
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.182
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! by controller[702]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2407): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[701]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2406): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[700]: TCP Timeout
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.181
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.180
                              ! error
                              ! by controller[699]: TCP Timeout
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.179
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.178
                              ! error
                              ! by controller[698]: TCP Timeout
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.177
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! by controller[697]: TCP Timeout
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.176
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.175
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! by controller[696]: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[695]: TCP Timeout
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! by controller[694]: TCP Timeout
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.174
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2405): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2404): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2403): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2402): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2401): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2400): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2399): Error: TCP Timeout
                              ! Caught
                              ! 2018-01-12 18:45:19.173
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2398): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2397): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2396): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2395): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2394): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2393): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2392): Error: TCP Timeout
                              ! Caught
                              ! 2018-01-12 18:45:19.172
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2391): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2390): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2389): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2388): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2387): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2386): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2385): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2384): Error: TCP Timeout
                              ! Caught
                              ! 2018-01-12 18:45:19.171
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2383): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2382): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2381): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2380): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2379): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2378): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2377): Error: TCP Timeout
                              ! Caught
                              ! 2018-01-12 18:45:19.170
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2376): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2375): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2374): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2373): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[694]: [Poolhaus] device.send() Error: TCP Timeout
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.169
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.168
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.167
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.166
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.165
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! 2018-01-12 18:45:19.164
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! by controller[693]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2372): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[693]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2371): Error: TCP Timeout
                              ! Caught
                              ! 2018-01-12 18:45:19.163
                              ! error
                              ! by controller[693]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2370): Error: TCP Timeout
                              ! Caught
                              ! error
                              ! by controller[693]: (node:944) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2369): Error: TCP Timeout
                              ! admin.0
                              ! 2018-01-12 18:45:36.615
                              ! info
                              ! Subscribe on all states again
                              ! host.ioBroker-Pi
                              ! info
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! Caught
                              ! error
                              ! by controller[692]: (node:944) UnhandledPromiseRejectionWarning: Unha
                              Habe den ioBrober und den Pi schon neu gestartet….
                              aber beim Start gleich wieder das Problem!!!
                              was heißt das.... für einen Laien wie mich sieht das nicht gut aus!!!
                              Ich betreibe zwei Pi3 im Multihost schon sei ca 3 Wochen.
                              Hatte gedacht das dann die Leistung verteilt wird.
                              Bitte um Hilfe.
                              2821
