Ertrag (Tag, Monat, Jahr) berechnen und in Datei speichern
ich habe dein JS Script angepasst:
const {InfluxDB} = require('@influxdata/influxdb-client') const fs = require('fs') // vvvvvvvvvvvvvvv ANPASSEN!!! vvvvvvvvvvvvvvv const Token ='xxxxxxxxxx' const Url ='http://192.168.0.11:8086' const Org = 'home' const Bucket = 'iobroker' const measurement1 = "PV-SEWeb-Ertrag-Tag" const Outputfile = '/opt/iobroker/exports/daily_previous_month.txt' const query = ` import "date" import "timezone" option location = timezone.location(name: "Europe/Berlin") from(bucket: "${Bucket}") |> range(start:date.truncate(t:-1mo, unit:1mo), stop: date.truncate(t:-1s, unit:1mo)) |> filter(fn: (r) => r._measurement == "${measurement1}") |> filter(fn: (r) => r._field == "value") |> aggregateWindow(every: 1d,fn:max,timeSrc: "_start",createEmpty:false) |> pivot(rowKey:["_time"], columnKey: ["_measurement"], valueColumn: "_value") |> rename(columns: {"${measurement1}": "PV-SEWeb-Ertrag-Tag") |> keep(columns: ["_time", "PV-SEWeb-Ertrag-Tag"]) ` // ^^^^^^^^^^^^^^^ ANPASSEN!!! ^^^^^^^^^^^^^^^ const client = new InfluxDB({ url: Url, token: Token }) const queryApi = client.getQueryApi(Org) const stream = fs.createWriteStream(Outputfile) // , {flags: 'a'} zum Anhängen an die Datei const writeToFile = (fluxRow) => { let fluxdate = new Date(fluxRow._time) let formattedDate = fluxdate.toLocaleDateString('de-DE', { day: '2-digit', month: '2-digit', year: '2-digit' }) stream.write(`da[dx++]="${formattedDate}|${fluxRow.PV-SEWeb-Ertrag-Tag};0|"\n`) } queryApi.queryRows(query, { next: (row, tableMeta) => writeToFile(tableMeta.toObject(row)), error: error => { console.error(error); console.error('\nFinished ERROR'); }, complete: () => { stream.end(); console.info('\nFinished SUCCESS'); }, });Bekomme folgenden Fehler:
17:14:52.536 info javascript.0 (58979) Start javascript script.js.PV-SE-Web-Export-Datei-fuer-Solarlog 17:14:52.622 info javascript.0 (58979) script.js.PV-SE-Web-Export-Datei-fuer-Solarlog: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions 17:14:52.688 error javascript.0 (58979) script.js.PV-SE-Web-Export-Datei-fuer-Solarlog: {'statusCode':400,'statusMessage':'Bad Request','body':'{\'code\':\'invalid\',\'message\':\'compilation failed: error @11:36-11:82: expected RBRACE, got RPAREN\'}','contentType':'application/json; charset=utf-8','json':{'code':'invalid','message':'compilation failed: error @11:36-11:82: expected RBRACE, got RPAREN'},'message':'compilation failed: error @11:36-11:82: expected RBRACE, got RPAREN','code':'invalid','name':'HttpError','_retryAfter':0} 17:14:52.688 error javascript.0 (58979) script.js.PV-SE-Web-Export-Datei-fuer-Solarlog: Finished ERROR -
@bitwicht sagte in Ertrag (Tag, Monat, Jahr) berechnen und in Datei speichern:
ja, da hast du eine Klammer zu viel gelöscht:
|> rename(columns: {"${measurement1}": "PV-SEWeb-Ertrag-Tag"}) -
jetzt bekomme ich folgenden Fehler:
19:29:04.701 info javascript.0 (59677) Start javascript script.js.PV-SE-Web-Export-Datei-fuer-Solarlog 19:29:04.735 info javascript.0 (59677) script.js.PV-SE-Web-Export-Datei-fuer-Solarlog: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions 19:29:05.110 error javascript.0 (59677) script.js.PV-SE-Web-Export-Datei-fuer-Solarlog: TypeError: console.info is not a function 19:29:05.111 error javascript.0 (59677) at Object.complete (script.js.PV-SE-Web-Export-Datei-fuer-Solarlog:50:13) 19:29:05.276 error host.raspberrypi Caught by controller[1]: at Object.complete (script.js.PV-SE-Web-Export-Datei-fuer-Solarlog:51:13)Du schreibst die Datei in: /opt/iobroker/exports/
Das Verzeichnis exports gibt es noch nicht. Legt er es automatisch an? -
Ah, das liegt glaube ich an meiner aktuelleren Version des Javascript Adapters.
Mach mal aus
console.info ---> console.log
Das Verzeichnis exports gibt es noch nicht. Legt er es automatisch an?Nein, das musst du manuell anlegen, oder du schreibst irgendwo anders hin.
EDIT: natürlich an einer Stelle, wo der User iobroker Schreibrechte hat.
OK, die Datei hat er angelegt aber ist leer.
Wie oft aktualisiert er denn die Datei, wo sehe ich das?
19:53:34.529 info javascript.0 (59734) Start javascript script.js.PV-SE-Web-Export-Datei-fuer-Solarlog 19:53:34.578 info javascript.0 (59734) script.js.PV-SE-Web-Export-Datei-fuer-Solarlog: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions 19:53:34.609 info javascript.0 (59734) script.js.PV-SE-Web-Export-Datei-fuer-Solarlog: Finished SUCCESS -
Dann liefert die Abfrage (noch) keine Daten, weil du wohl im Dez. noch nicht in die DB geschreiben hast. Wenn du zu Testzwecken auch die Daten aus dem Januar haben willst, musst du
, stop: date.truncate(t:-1s, unit:1mo)löschen.
Im Moment nur, wenn du das Skript neu startest. Wenn du es regelmäßig laufen lassen willst, dann über einen Schedule. Da muss dann aber jemad anders helfen, ich nutze den Javascript-Adapter nur für einfache Einmal-Aufgaben.
Habe bisher nur im Jan Daten.
Sorry aber wenn ich das raus mache kommt der Fehler
20:15:02.390 error javascript.0 (59734) script.js.PV-SE-Web-Export-Datei-fuer-Solarlog: {} 20:15:02.391 error javascript.0 (59734) script.js.PV-SE-Web-Export-Datei-fuer-Solarlog: Finished ERROR 20:15:03.099 info javascript.0 (59734) Stop script script.js.PV-SE-Web-Export-Datei-fuer-Solarlog -
zeig bitte nochmal das aktuelle Skript, wie es jetzt bei dir aussieht.
bitte
const {InfluxDB} = require('@influxdata/influxdb-client') const fs = require('fs') // vvvvvvvvvvvvvvv ANPASSEN!!! vvvvvvvvvvvvvvv const Token ='xxxxxxxxxxxxx' const Url ='http://192.168.0.11:8086' const Org = 'home' const Bucket = 'iobroker' const measurement1 = "PV-SEWeb-Ertrag-Tag" const Outputfile = '/opt/iobroker/exports/daily_previous_month.txt' const query = ` import "date" import "timezone" option location = timezone.location(name: "Europe/Berlin") from(bucket: "${Bucket}") |> range(start:date.truncate(t:-1mo, unit:1mo)) |> filter(fn: (r) => r._measurement == "${measurement1}") |> filter(fn: (r) => r._field == "value") |> aggregateWindow(every: 1d,fn:max,timeSrc: "_start",createEmpty:false) |> pivot(rowKey:["_time"], columnKey: ["_measurement"], valueColumn: "_value") |> rename(columns: {"${measurement1}": "PV-SEWeb-Ertrag-Tag"}) |> keep(columns: ["_time", "PV-SEWeb-Ertrag-Tag"]) ` // ^^^^^^^^^^^^^^^ ANPASSEN!!! ^^^^^^^^^^^^^^^ const client = new InfluxDB({ url: Url, token: Token }) const queryApi = client.getQueryApi(Org) const stream = fs.createWriteStream(Outputfile) // , {flags: 'a'} zum Anhängen an die Datei const writeToFile = (fluxRow) => { let fluxdate = new Date(fluxRow._time) let formattedDate = fluxdate.toLocaleDateString('de-DE', { day: '2-digit', month: '2-digit', year: '2-digit' }) stream.write(`da[dx++]="${formattedDate}|${fluxRow.PV-SEWeb-Ertrag-Tag};0|"\n`) } queryApi.queryRows(query, { next: (row, tableMeta) => writeToFile(tableMeta.toObject(row)), error: error => { console.error(error); console.error('\nFinished ERROR'); }, complete: () => { stream.end(); console.log('\nFinished SUCCESS'); }, }); -
das kommt durch die Bindestriche in der Umbenennung in
|> rename(columns: {"${measurement1}": "PV-SEWeb-Ertrag-Tag"})Nimmt da mal ein Wert ohne Bindestriche.
das ist ein Problem.
So heißt mein AliasID in der Influx.Kann ich auch das nehmen 0_userdata.0.Systemdaten.Solaranlage.Anlagen.1565936.Erzeugung.Heute ?
Oder kennt die DB den Wert nicht?
Nein, ist es nicht.
Der Wert wird doch nur als Alias im Skript verwendet. Da kannst du auch "xyz" nehmen und hier natürlich auch:
stream.write(`da[dx++]="${formattedDate}|${fluxRow.xyz};0|"\n`) -
Perfekt. Geht.
In der Datei steht:
da[dx++]="04.01.24|15.62;0|"
da[dx++]="05.01.24|9.52;0|"
da[dx++]="06.01.24|3.13;0|"
da[dx++]="07.01.24|0;0|"Wie kann ich das umdrehen das der aktuelle Tag immer oben steht?
Dein Script geht jetzt bis "unendlich" zurück?
Einfach als letzte Zeile an die Query anhängen:
|> sort(columns: ["_time"], desc: true)Dein Script geht jetzt bis "unendlich" zurück?
Ne, im Moment ab dem 1. des Vormonats
|> range(start:date.truncate(t:-1mo, unit:1mo))Wenn es weiter zurück gehen soll, dann musst du "-1mo" anpassen.
wie ist der Syntax für 20 Jahre zurück = "-20y" ?
Ich habe ein anderes Script (Shelly) das sich automatisch alle 15 Minuten aktualisiert.
Im Script steht:
// Alle 15 Minuten das Skript für den Tagesverbrauch ausführen schedule('*/15 * * * *', shelly_verbrauch_update); function shelly_verbrauch_update() {Ich kenne mich ja leider nicht aus aber kann es sein, dass das Script in einer Funktion ist und der Scaduler einfach die Funktion startet ?!
Wenn wir dein Script so bauen:
function SE-Web-Update() { ##### hier dein Script rein ###### schedule('*/15 * * * *', SE-Web-Update);Doch ich habe es hinbekommen.
Es ging nicht wegen der "-"so geht es:
function SEWebUpdate() {
//// hier dein Script rein /////
schedule('*/15 * * * *', SEWebUpdate); -
ja, genau.
1s für Sekunde
1m für Minute
1h für Stunde
1d für Tag
1w für Woche
1mo für Monat
1y für Jahr -
Super, vielen Dank!
Jetzt versuche ich dein Script noch für Monat und Jahr anzupassen (brauch ich aber noch den Datenpunkt).
Und dann noch der FTP Upload.Das mit der Funktion geht auch:
schedule('*/1 * * * *', SEWebUpdate);Er Erstellt jetzt alle Minute die Datei neu.
Die Daten werden doch in der Influx in measurement = "PV-SEWeb-Ertrag-Tag" gespeichert.
In meiner App hätte ich die historischen Daten.
Wie könnte ich diese denn in die Datenbank manuell eintragen?
Gibt es da eine Art Web-Explorer, Manuelle Eingabe oder ev. CSV Import ?Den FTP Upload habe ich auch hinbekommen, sogar direkt im Script.
const Client = require('ftp'); const c = new Client(); c.on('ready', function() { c.put('/opt/iobroker/exports/daily_previous_month.txt', 'daily_previous_month.txt', function(err) { if (err) throw err; c.end(); }); }); c.connect({ host:"xxxxxx", user:"xxxxxx", password:"xxxxx" } ); -
Ich glaube, unter den Voraussetzungen wäre es am einfachsten, die Daten ins Line Protocol zu überführen, das ist ganz simpel aufgebaut. Einziger Haken ist dabei, dass du die Zeit in einen Unix Timestamp übersetzen musst.
measurementName fieldKey="field string value" <Zeitstempel>Bei dir müsste es also so aussehen:
PV-SEWeb-Ertrag-Tag value="15.62" 1704326400 PV-SEWeb-Ertrag-Tag value="9.52" 1704412800 PV-SEWeb-Ertrag-Tag value="3.13" 1704499200Diese Daten kannst du dann via InfluxDB Webgui (Sources-->File Upload-->Line Protocol) ganz einfach importieren. Wichtig ist dabei, dass du die passende Precision mit angibst. In meinem Beispiel wären das "Sekunden".
Unable to write.
bevor ich da was "kaputt" mache.
in der Weboberfläche steht sogar ein Beispiel:
myMeasurement = PV-SEWeb-Ertrag-Tag
Tag1 = habe ich nicht ?
Tag2 = habe ich nicht ?
fieldKey = mein Wert
Timestamp = Zeit in Unix -SekundenMüsste es dann so aussehen?
PV-SEWeb-Ertrag-Tag, fieldKey="15.616" 1704376800
