    4. <gelöst> Serieller Port defekt
      Homoran Global Moderator Administrators @searcher57 last edited by
      @searcher57 ich brauch das log ab Neustart der Instanz als debug-log
        searcher57 @Homoran last edited by
        @homoran said in Serieller Port defekt:
        smartmeter.0
        	2024-01-07 20:16:37.648	warn	No or too long answer from Serial Device after last request.
        smartmeter.0
        	2024-01-07 20:16:37.646	info	Error: No or too long answer from Serial Device after last request.
        smartmeter.0
        	2024-01-07 20:16:27.606	info	starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.19.0, js-controller: 5.0.17
        host.raspberrypi
        	2024-01-07 20:16:24.706	info	instance system.adapter.smartmeter.0 started with pid 7091
        host.raspberrypi
        	2024-01-07 20:16:22.105	info	instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        smartmeter.0
        	2024-01-07 20:16:21.992	info	terminating
        host.raspberrypi
        	2024-01-07 20:16:21.622	info	stopInstance system.adapter.smartmeter.0 send kill signal
        smartmeter.0
        	2024-01-07 20:16:21.489	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        smartmeter.0
        	2024-01-07 20:16:21.486	info	terminating
        smartmeter.0
        	2024-01-07 20:16:21.482	info	Got terminate signal TERMINATE_YOURSELF
        host.raspberrypi
        	2024-01-07 20:16:21.468	info	stopInstance system.adapter.smartmeter.0 (force=false, process=true)
        admin.0
        	2024-01-07 20:16:04.221	info	<== Disconnect system.user.admin from ::ffff:192.168.178.30
        host.raspberrypi
        	2024-01-07 20:15:40.113	info	instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        smartmeter.0
        	2024-01-07 20:15:33.596	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
        admin.0
        	2024-01-07 20:15:33.145	info	==> Connected system.user.admin from ::ffff:192.168.178.30
        smartmeter.0
        	2024-01-07 20:15:31.223	warn	No or too long answer from Serial Device after last request.
        smartmeter.0
        	2024-01-07 20:15:31.221	info	Error: No or too long answer from Serial Device after last request.
        host.raspberrypi
        	2024-01-07 20:15:00.034	info	instance system.adapter.yr.0 started with pid 7052
        javascript.0
        	2024-01-07 20:15:00.022	info	script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 12
        smartmeter.0
        	2024-01-07 20:14:21.218	warn	No or too long answer from Serial Device after last request.
        smartmeter.0
        	2024-01-07 20:14:21.217	info	Error: No or too long answer from Serial Device after last request.
        awtrix-light.0
        	2024-01-07 20:13:39.015	info	error ECONNABORTED from screen: timeout of 3000ms exceeded
        awtrix-light.0
        	2024-01-07 20:13:30.002	info	error ECONNABORTED from screen: timeout of 3000ms exceeded
        smartmeter.0
        	2024-01-07 20:13:11.212	warn	No or too long answer from Serial Device after last request.
        smartmeter.0
        	2024-01-07 20:13:11.210	info	Error: No or too long answer from Serial Device after last request.
          searcher57 @searcher57 last edited by
          @searcher57 said in Serieller Port defekt:
          @martinp said in Serieller Port defekt:
          Fette Lötbrücke/fetter Kurzschluss ... bitte entfernen ...
          Bei meinem Kopf war TXD der Pin, auf dem der Lesekopf empfangen hat ... Das würde dann passen mit Pin 8 -> Lesekopf TX Pin 10->Lesekopf RX
          Ist entfernt! Ich habe mittlerweile mehrere Versuche durchgeführt!
          Sorry ich beantworte im Moment mehreren Helfern1 Kannst Du oben sehen!
            @searcher57 sagte in Serieller Port defekt:
            da isses ja!
            wieso war das bisher nie im log?
            Wie gesagt habe ich mit GPIOs keinsterlei Erfahrung. Ich weiß daher auch nicht, ob
            @homoran sagte in Serieller Port defekt:
            kann @searcher57 via ls -la /dev/serial/by-id/ versuchen herauszufinden was er da hat
            das hilft.
            Was kommt denn dabei raus?
            Im Moment könnte S0 richtig sein, aber die Verdrahtung nicht
              Ich habe mehrfach die Anschlüsse gedreht!
              was sollte das bringen, wenn du auf USB nach dem Lesekopf suchst?
              Bitte sag mir doch, wo ich die Einstellung ändere, dass der USB Port eingestellt ist.
                tue ich die ganze Zeit!
                  Also ich habe den Anschluss folgendermaßen vorgenommen:
                  J8 PIN 1 +3,3V
                  J6 GND
                  J8 GPIO 14 TXD0
                  J10 GPIO 15 RXD0
                    Was willst du mir damit sagen?
                      da isses ja!
                      das hilft.
                      pi@raspberrypi:~ $ ls -la /dev/serial/by-id/
                      ls: Zugriff auf '/dev/serial/by-id/' nicht möglich: Datei oder Verzeichnis nicht gefunden
                        @searcher57 ok!
                        entweder geht das nicht mit GPIOs
                        oder die serielle Schnittstelle ist nicht korrekt freigeschaltet
                        oder der Lesekopf ist falsch angeschlossen
                        damit sind wir keinen Schritt weiter
                        du kannst jetzt nur noch überprüfen ob die serielle in raspi-config freigeschaltet wurde (danach rebootet???!|
                        Dann AMA0 und S0 ausprobieren.
                        Den Sitz des Lesekopfs (auch mal um 180 grad drehen) prüfen.
                        und natürlich bei jeder Einstellung der Schnittstelle die Verkabelung checken.
                        Aber da kann ich nicht helfen
                        Thomas Braun S 2 Replies Last reply Reply Quote 0
                          Das geht nur über USB-Geräte, die dann per udev-Regel dort als Link auf das richtige /dev-File gemappt werden. Ich meine per direktem GPIO-Anschluss geht das nicht.
                            @searcher57 ok!
                            Wie sagte schon Theo Lingen??... Schade, schade, schade..
                            Alle Deine Empfehlungen mehrfach durchgeführt und daher sooo frustriert!
                            Danke!
                            Homoran S 2 Replies Last reply Reply Quote 0
                              searcher57 @Thomas Braun last edited by
                              @thomas-braun said in Serieller Port defekt:
                              Aber ich habe den IR Lesekopf doch über mehrere Wochen ausgelesen! Warum seit ca. 3 Wochen(seit einem Jahr) nicht mehr?
                                kannst du doch gar nicht!
                                es gibt so viele Permutationen der variablen möglichen Ursachen.
                                Systematisch prüfen.
                                Erst einmal alles unter S0
                                Kabel kreuzem
                                Kopf ausrichten
                                dann das selbe mit AMA0
                                  @searcher57 ok!
                                  Danke!
                                  Ich glaube Mathias hatte mir die Einstellungen gegen, die finde ich aber nicht mehr!
                                    Kabel kreuzem
                                    Kopf ausrichten
                                    AMOO auf Rheinländisch?
                                      @searcher57 ok!
                                      Danke!
                                      AMAO
                                        Thomas Braun Most Active @searcher57 last edited by
                                        Mit welchen Einstellungen denn? Vermutlich nicht per Link aus /dev/serial/by-id
                                            @searcher57 ok!
                                            Danke!
                                            AMAO
                                            Du glaubst gar nicht, wieviel Stunden, Tage und Wochen ich mittlerweile damit beschäftigt bin. Meine Frau siezt mich schon...😁 😁
                                            362
                                            44587
