    3. Off Topic
    4. Logfile läuft voll mit TimeoutoverflowWarning etc.
      JoergH @Thomas Braun last edited by
      @thomas-braun sagte in Logfile läuft voll mit TimeoutoverflowWarning etc.:
      @joergh
      Dann versuch mal
      iob setup --first
      Vielleicht wird der DP dann angelegt.
      Yep, jetzt hat er den DP angelegt!
        Thomas Braun Most Active @JoergH last edited by
        @joergh
        Dann orgel jetzt nochmal
        iob diag
        durch.
          @joergh
          iob diag
          durch.
          Jetzt hat er auch die repo list angelegt
          pi@raspberrypi:/ $ iob repo list
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           22:19:02 up  6:02,  1 user,  load average: 1.42, 1.66, 1.87
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sun 2024-01-07 22:19:02 CET
                     Universal time: Sun 2024-01-07 21:19:02 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            7.8G        3.2G        503M        0.0K        4.1G        4.8G
          Swap:            99M        2.0M         97M
          Total:          7.9G        3.2G        601M
                   7811 M total memory
                   3204 M used memory
                   3912 M active memory
                   2938 M inactive memory
                    503 M free memory
                    125 M buffer memory
                   3977 M swap cache
                     99 M total swap
                      2 M used swap
                     97 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4      118G   16G   98G  14% /
          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
          /dev/sda1      vfat      255M   31M  225M  13% /boot
          tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
          [Sun Jan  7 16:16:54 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:640x480M@60 smsc95xx.macaddr=DC:A6:32:F1:62:5F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  usb-storage.quirk=152d:0579:u console=ttyS0,115200 console=tty1 root=PARTUUID=622a00f4-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Sun Jan  7 16:16:57 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sun Jan  7 16:16:57 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Sun Jan  7 16:16:59 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
          TARGET  SOURCE    FSTYPE OPTIONS
          /       /dev/sda2 ext4   rw,noatime
          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
          7.9G    /var/
          4.1G    /var/log/journal/ebf43f1ac9ac40f88ddf4138fee55e47
          4.1G    /var/log
          1.9G    /var/lib
          Archived and active journals take up 4.0G in the file system.
          /opt/iobroker/backups:
          333M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          436M    /opt/iobroker/iobroker-data/
          301M    /opt/iobroker/iobroker-data/files
          97M     /opt/iobroker/iobroker-data/backup-objects
          67M     /opt/iobroker/iobroker-data/files/javascript.admin
          48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
          23M     /opt/iobroker/iobroker-data/objects.jsonl
          22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
          14M     /opt/iobroker/iobroker-data/states.jsonl
          8.9M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          /usr/bin/corepack       0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0-1nodesource1 1001
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.12.0
          javascript:     7.1.6
          Adapters from github:   4
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
            system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
          + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
          + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
          + system.adapter.exchangerates.0          : exchangerates         : raspberrypi                              -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
          + system.adapter.firetv.0                 : firetv                : raspberrypi                              -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
          + system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
          + system.adapter.ham.0                    : ham                   : raspberrypi                              -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
            system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
            system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
          + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
          + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
          + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
          + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
            system.adapter.odl.0                    : odl                   : raspberrypi                              -  enabled
            system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
          + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
            system.adapter.powerfox2.0              : powerfox2             : raspberrypi                              -  enabled
          + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
          + system.adapter.renault.0                : renault               : raspberrypi                              -  enabled
          + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
            system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.solarmanpv.0             : solarmanpv            : raspberrypi                              -  enabled
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
          + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
            system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Objects and States
          Objects:        27225
          States:         22880
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 https://apt.grafana.com stable InRelease
          Hit:7 https://apt.pivccu.de/piVCCU stable InRelease
          Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1906       967/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       7998550    27771/io.sonoff.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7995351    27681/io.mqtt.0
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      111        15567      861/influxd
          tcp        0      0 192.168.178.55:2010     0.0.0.0:*               LISTEN      1001       7995389    27729/io.hm-rpc.1
          tcp        0      0 192.168.178.55:2001     0.0.0.0:*               LISTEN      1001       7997899    27546/io.hm-rpc.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7995036    27405/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7995757    27405/iobroker.js-c
          tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          15521      952/dnsmasq
          tcp6       0      0 :::22                   :::*                    LISTEN      0          1908       967/sshd: /usr/sbin
          tcp6       0      0 :::3000                 :::*                    LISTEN      112        16893      1651/grafana
          tcp6       0      0 :::8086                 :::*                    LISTEN      111        14917      861/influxd
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7999270    28241/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7997771    27426/io.admin.0
          udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          15520      952/dnsmasq
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          15517      952/dnsmasq
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15378      630/dhclient
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       7996368    27786/io.mihome-vac
          udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       7997286    27804/io.mihome-vac
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       7997079    27538/io.ham.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3671       425/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       7998484    27711/io.shelly.0
          udp        0      0 0.0.0.0:51826           0.0.0.0:*                           0          14535      -
          udp        0      0 0.0.0.0:44435           0.0.0.0:*                           108        3673       425/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        3672       425/avahi-daemon: r
          udp6       0      0 :::38694                :::*                                108        3674       425/avahi-daemon: r
          udp6       0      0 :::51826                :::*                                0          14536      -
          2024-01-07 22:20:15.021  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Zeit seit Anstecken an go-e charger: 1661.2710166666666
          2024-01-07 22:20:15.022  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Ladestrom GO-E: 0 A
          2024-01-07 22:20:15.025  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA: 0 A
          2024-01-07 22:20:15.025  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA FINAL: 0 A
          2024-01-07 22:20:15.027  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Überschuss brutto / netto: -13 / -13
          2024-01-07 22:20:15.028  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Gemittelt go-e: 0 - Restzeit go-e: 00:00
          2024-01-07 22:20:15.029  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Gemittelt TESLA: 0
          2024-01-07 22:20:15.029  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Restzeit TESLA: 11:04
          2024-01-07 22:20:15.327  - info: javascript.0 (27467) script.js.Heizung.Zirkulationspumpe_Bedarf: Zirk. WW 34.2 Alt 34.2 - RL Zirk. 37.5 Alt 37.6 - Differenz VL-RL: 3.299999999999997
          2024-01-07 22:20:15.328  - info: javascript.0 (27467) script.js.Heizung.Zirkulationspumpe_Bedarf: Speichertemperatur: 45.5 - Temperaturdifferenz Speicher - RL ( >25 Grad ? ): 8
          2024-01-07 22:20:15.329  - info: javascript.0 (27467) script.js.Heizung.Zirkulationspumpe_Bedarf: Zirkulation ist AUS - Temperaturdifferenz Vorlauf - Vorlauf ALT ( >0.1 Grad ?): 0 Zeit seit Ausschalten ( >900000 ) in ms: 720329
          2024-01-07 22:20:15.426  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-01-07 22:20:15.645  - info: dwd.0 (33523) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
          2024-01-07 22:20:17.136  - info: dwd.0 (33523) State value to set for "dwd.0.warning1.begin" has to be type "string" but received type "number"
          2024-01-07 22:20:17.182  - info: dwd.0 (33523) State value to set for "dwd.0.warning1.end" has to be type "string" but received type "number"
          2024-01-07 22:20:17.494  - info: dwd.0 (33523) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-01-07 22:20:18.052  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-01-07 22:20:30.038  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Zeit seit Anstecken an go-e charger: 1661.5213
          2024-01-07 22:20:30.041  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Ladestrom GO-E: 0 A
          2024-01-07 22:20:30.041  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA: 0 A
          2024-01-07 22:20:30.042  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA FINAL: 0 A
          2024-01-07 22:20:30.043  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Überschuss brutto / netto: -13 / -13
          2024-01-07 22:20:30.043  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Gemittelt go-e: 0 - Restzeit go-e: 00:00
          2024-01-07 22:20:30.044  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Gemittelt TESLA: 0
          2024-01-07 22:20:30.044  - info: javascript.0 (27467) script.js.Energiemanagement.PV_Laden_neu: Restzeit TESLA: 11:04
            @joergh sagte in Logfile läuft voll mit TimeoutoverflowWarning etc.:
            So ganz passt es aber nocht nicht.
            iob update
            iob list adapters
            sagt jeweils?
              iob update
              iob list adapters
              sagt jeweils?
              pi@raspberrypi:/ $ iob update
              pi@raspberrypi:/ $ iob list adapters
              system.adapter.admin                   : admin          - v6.12.0
              system.adapter.backitup                : backitup       - v2.9.8
              system.adapter.birthdays               : birthdays      - v2.4.1
              system.adapter.daikin-cloud            : daikin-cloud   - v0.3.1
              system.adapter.denon                   : denon          - v1.15.4
              system.adapter.discovery               : discovery      - v4.2.0
              system.adapter.dwd                     : dwd            - v2.8.5
              system.adapter.exchangerates           : exchangerates  - v0.0.14
              system.adapter.fb-checkpresence        : fb-checkpresence - v1.2.2
              system.adapter.firetv                  : firetv         - v2.0.2
              system.adapter.fullybrowser            : fullybrowser   - v3.0.6
              system.adapter.go-e                    : go-e           - v1.0.29
              system.adapter.ham                     : ham            - v5.3.1
              system.adapter.hm-rega                 : hm-rega        - v4.0.0
              system.adapter.hm-rpc                  : hm-rpc         - v1.15.19
              system.adapter.homekit-controller      : homekit-controller - v0.5.1
              system.adapter.ical                    : ical           - v1.13.3
              system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
              system.adapter.icons-icons8            : icons-icons8   - v0.0.1
              system.adapter.icons-material-png      : icons-material-png - v0.1.0
              system.adapter.icons-material-svg      : icons-material-svg - v0.1.0
              system.adapter.icons-mfd-png           : icons-mfd-png  - v1.2.1
              system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.2.0
              system.adapter.influxdb                : influxdb       - v3.2.0
              system.adapter.info                    : info           - v2.0.0
              system.adapter.javascript              : javascript     - v7.1.6
              system.adapter.miele                   : miele          - v0.1.5
              system.adapter.mielecloudservice       : mielecloudservice - v6.5.4
              system.adapter.mihome-vacuum           : mihome-vacuum  - v4.1.0
              system.adapter.modbus                  : modbus         - v6.0.1
              system.adapter.mqtt                    : mqtt           - v5.1.0
              system.adapter.netatmo-crawler         : netatmo-crawler - v0.8.1
              system.adapter.octoprint               : octoprint      - v5.1.0
              system.adapter.odl                     : odl            - v3.0.1
              system.adapter.openweathermap          : openweathermap - v0.4.5
              system.adapter.pollenflug              : pollenflug     - v1.0.6
              system.adapter.powerfox2               : powerfox2      - v0.0.14
              system.adapter.pvforecast              : pvforecast     - v2.9.0
              system.adapter.renault                 : renault        - v0.0.21
              system.adapter.sayit                   : sayit          - v3.0.5
              system.adapter.schoolfree              : schoolfree     - v1.1.3
              system.adapter.shelly                  : shelly         - v6.6.1
              system.adapter.simple-api              : simple-api     - v2.7.2
              system.adapter.socketio                : socketio       - v6.6.0
              system.adapter.solarmanpv              : solarmanpv     - v0.5.1
              system.adapter.sonoff                  : sonoff         - v3.0.3
              system.adapter.sourceanalytix          : sourceanalytix - v0.4.11
              system.adapter.telegram                : telegram       - v3.0.1
              system.adapter.tesla-motors            : tesla-motors   - v1.4.0
              system.adapter.trashschedule           : trashschedule  - v2.3.0
              system.adapter.vis                     : vis            - v1.5.4
              system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v1.0.1
              system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
              system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.4
              system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.4.0
              system.adapter.vis-icontwo             : vis-icontwo    - v1.3.0
              system.adapter.vis-inventwo            : vis-inventwo   - v3.3.3
              system.adapter.vis-justgage            : vis-justgage   - v2.1.0
              system.adapter.vis-material-advanced   : vis-material-advanced - v1.7.4
              system.adapter.vis-plumb               : vis-plumb      - v1.0.2
              system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
              system.adapter.vis-timeandweather      : vis-timeandweather - v1.2.2
              system.adapter.vis-weather             : vis-weather    - v2.5.6
              system.adapter.web                     : web            - v6.1.10
              system.adapter.ws                      : ws             - v2.5.8
                pi@raspberrypi:/
                Du stehst (wieder) im falschen Verzeichnis...
                Stell dich in das home des users...
                  pi@raspberrypi:/
                  Kein Unterschied...
                  pi@raspberrypi:~ $ iob update
                  pi@raspberrypi:~ $ iob list adapters
                    Kein Unterschied...
                    Ist was grundsätzliches... Man steht nicht irgendwo im Dateibaum herum.
                    Bei
                    iob update
                    sollte eigentlich eine Auflistung aller über ein Repo angelegten Adapter erscheinen. Keine Ahnung warum das da nicht funktioniert.
                    cd /opt/iobroker && npm ls
                    verrät?
                      Kein Unterschied...
                      Bei
                      iob update
                      verrät?
                      pi@raspberrypi:/home $ cd /opt/iobroker && npm ls
                      iobroker.inst@3.0.0 /opt/iobroker
                      ├── @types/caseless@0.12.5 extraneous
                      ├── @types/request@2.48.12 extraneous
                      ├── @types/tough-cookie@4.0.5 extraneous
                      ├── buffer-shims@1.0.0 extraneous
                      ├── coffeescript@2.7.0 extraneous
                      ├── decimal.js@10.4.3 extraneous
                      ├── futoin-hkdf@1.4.3 extraneous
                      ├── homebridge-plugin-wrapper@3.2.0 extraneous
                      ├── iobroker.admin@6.12.0
                      ├── iobroker.backitup@2.9.8
                      ├── iobroker.birthdays@2.4.1
                      ├── iobroker.daikin-cloud@0.3.1 (git+ssh://git@github.com/Apollon77/ioBroker.daikin-cloud.git#f421b24f2bbd5d90b810bc540337d0171fd6067d)
                      ├── iobroker.denon@1.15.4
                      ├── iobroker.discovery@4.2.0
                      ├── iobroker.dwd@2.8.5
                      ├── iobroker.exchangerates@0.0.14
                      ├── iobroker.fb-checkpresence@1.2.2
                      ├── iobroker.firetv@2.0.2
                      ├── iobroker.fullybrowser@3.0.6
                      ├── iobroker.go-e@1.0.29
                      ├── iobroker.ham@5.3.1
                      ├── iobroker.hm-rega@4.0.0
                      ├── iobroker.hm-rpc@1.15.19
                      ├── iobroker.ical@1.13.3
                      ├── iobroker.icons-addictive-flavour-png@0.1.0
                      ├── iobroker.icons-icons8@0.0.1
                      ├── iobroker.icons-material-png@0.1.0
                      ├── iobroker.icons-material-svg@0.1.0
                      ├── iobroker.icons-mfd-png@1.2.1
                      ├── iobroker.icons-mfd-svg@1.2.0
                      ├── iobroker.influxdb@3.2.0
                      ├── iobroker.info@2.0.0
                      ├── iobroker.javascript@7.1.6
                      ├── iobroker.js-controller@5.0.17
                      ├── iobroker.mielecloudservice@6.5.4
                      ├── iobroker.mihome-vacuum@4.1.0
                      ├── iobroker.modbus@6.0.1
                      ├── iobroker.mqtt@5.1.0
                      ├── iobroker.netatmo-crawler@0.8.1
                      ├── iobroker.octoprint@5.1.0
                      ├── iobroker.odl@3.0.1
                      ├── iobroker.openweathermap@0.4.5
                      ├── iobroker.pollenflug@1.0.6
                      ├── iobroker.powerfox2@0.0.14
                      ├── iobroker.pvforecast@2.9.0
                      ├── iobroker.renault@0.0.21 (git+ssh://git@github.com/TA2k/ioBroker.renault.git#3f910adb91397c9067a10d24f460e6c0a27f246e)
                      ├── iobroker.sayit@3.0.5
                      ├── iobroker.schoolfree@1.1.3
                      ├── iobroker.shelly@6.6.1
                      ├── iobroker.socketio@6.6.0
                      ├── iobroker.solarmanpv@0.5.1
                      ├── iobroker.sonoff@3.0.3
                      ├── iobroker.sourceanalytix@0.4.11 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b38a8fe911d56001a73b1fb5ba84e9ac39a06737)
                      ├── iobroker.telegram@3.0.1
                      ├── iobroker.tesla-motors@1.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.tesla-motors.git#337e8f00d715d02448e911cf11970af4e0a93922)
                      ├── iobroker.trashschedule@2.3.0
                      ├── iobroker.vis-canvas-gauges@1.0.1
                      ├── iobroker.vis-fancyswitch@1.1.0
                      ├── iobroker.vis-google-fonts@1.0.4
                      ├── iobroker.vis-hqwidgets@1.4.0
                      ├── iobroker.vis-icontwo@1.3.0
                      ├── iobroker.vis-inventwo@3.3.3
                      ├── iobroker.vis-justgage@2.1.0
                      ├── iobroker.vis-material-advanced@1.7.4
                      ├── iobroker.vis-plumb@1.0.2
                      ├── iobroker.vis-rgraph@0.0.2
                      ├── iobroker.vis-timeandweather@1.2.2
                      ├── iobroker.vis-weather@2.5.6
                      ├── iobroker.vis@1.5.4
                      ├── iobroker.web@6.1.10
                      ├── iobroker.ws@2.5.8
                      ├── jsonata@2.0.3 extraneous
                      ├── mock-require@3.0.3 extraneous
                      ├── node-inspect@2.0.0 extraneous
                      ├── node-persist@0.0.11 extraneous
                      ├── picocolors@1.0.0 extraneous
                      ├── q@1.1.2 extraneous
                      ├── remove-trailing-separator@1.1.0 extraneous
                      ├── string-argv@0.3.1 extraneous
                      ├── suncalc2@1.8.1 extraneous
                      ├── virtual-tsc@0.6.2 extraneous
                      └── wake_on_lan@1.0.0 extraneous
                        @joergh
                        Immer noch nicht das home des users...
                        cd
                        bringt dich hin.
                          @joergh
                          cd /opt/iobroker && npm prune
                          npm ls
                            @joergh
                            cd
                            bringt dich hin.
                            Ja, da war ich schon, hab es dann nochmal im home Verzeichnis aufgerufen. Kein Unterschied, hätte auch das andere posten können....
                              @joergh
                              npm ls
                              pi@raspberrypi:~ $ cd /opt/iobroker && npm prune
                              removed 323 packages in 18s
                              279 packages are looking for funding
                                run `npm fund` for details
                              pi@raspberrypi:/opt/iobroker $ npm ls
                              └── iobroker.ws@2.5.8
                                @joergh
                                In /home hast du auch nicht genügend Rechte. Du stehst mit dem User immer in dessen /home/USER (im Prompt mit ~ abgekürzt).
                                So etwa schaut das dann aus:
                                echad@chet:~ $
                                  @joergh
                                  Warum iob update nicht wie sonst reagiert sehe ich nicht.
                                  Aber der npm-Baum ist jetzt aufgeräumt.
                                    @joergh
                                    Wie reagiert es denn sonst?
                                      @joergh
                                      Es wird eine Liste der über ein Repo angelegten Adapter und die ggfls. ausstehenden Updates ausgegeben.
                                        @thomas-braun Danke erstmal. Für heute ist Feierabend.
                                        4660
