Ertrag (Tag, Monat, Jahr) berechnen und in Datei speichern
iob nodejs-update -
pi@raspberrypi:~ $ iob nodejs-update
curl: no URL specified!
curl: try 'curl --help' or 'curl --manual' for more information
pi@raspberrypi:~ $ -
iob stop iob fix iob start wget -q https://repos.influxdata.com/influxdata-archive_compat.key echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list rm influxdata-archive_compat.key iobroker nodejs-update -
ich habe das gemacht aber kann nicht mehr alles kopieren
es kommt:Nothing to do - Your installation is using the correct paths.
You are running nodejs v16.18.1. Do you want to install recommended version 18.19.0?
Press <y> to continue or any other key to quitalles mit y bestätigen ?
Ja, du willst nodejs@18 haben.
schaut gut aus
We tried our best to update or fix your nodejs. Please run iob diag again to verify. *** RESTARTING ioBroker NOW! *** Please refresh or restart your browser in a few moments. This system needs to be REBOOTED NOW!reboot oder erst noch was anderes ?
pi@raspberrypi:~ $ sudo apt update Hit:1 http://deb.debian.org/debian bullseye InRelease Hit:2 http://deb.debian.org/debian bullseye-updates InRelease Hit:3 http://security.debian.org/debian-security bullseye-security InRelease Hit:4 https://repos.influxdata.com/debian stable InRelease Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease Hit:6 https://apt.grafana.com stable InRelease Hit:7 http://archive.raspberrypi.org/debian bullseye InRelease Get:8 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5,127 B] Fetched 5,127 B in 2s (2,799 B/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done 2 packages can be upgraded. Run 'apt list --upgradable' to see them. pi@raspberrypi:~ $und
pi@raspberrypi:~ $ apt policy influxdb* influxdb2-cli: Installed: (none) Candidate: 2.7.3-1 Version table: 2.7.3-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.7.1-2 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.5.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.4.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.3.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages influxdb-client: Installed: (none) Candidate: 1.6.7~rc0-1+b5 Version table: 1.6.7~rc0-1+b5 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages influxdb-dev: Installed: (none) Candidate: (none) Version table: influxdb2-client: Installed: (none) Candidate: 2.7.1-1 Version table: 2.7.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages influxdb: Installed: (none) Candidate: 1.8.10-1 Version table: 1.8.10-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 1.6.7~rc0-1+b5 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages 100 /var/lib/dpkg/status influxdb2: Installed: 2.7.4-1 Candidate: 2.7.4-1 Version table: *** 2.7.4-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 100 /var/lib/dpkg/status 2.7.3-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.7.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.7.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.5.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.4.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.3.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.2.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages pi@raspberrypi:~ $ -
schaut ok aus
pi@raspberrypi:~ $ sudo apt full-upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following package was automatically installed and is no longer required: raspinfo Use 'sudo apt autoremove' to remove it. The following NEW packages will be installed: kms++-utils musl raspi-utils The following packages will be upgraded: grafana raspinfo 2 upgraded, 3 newly installed, 0 to remove and 0 not upgraded. Need to get 101 MB of archives. After this operation, 68.9 MB of additional disk space will be used. Do you want to continue? [Y/n] Get:1 http://deb.debian.org/debian bullseye/main arm64 musl arm64 1.2.2-1 [399 kB] Get:2 http://archive.raspberrypi.org/debian bullseye/main arm64 kms++-utils arm64 0~git20221104~171243+adc05b6-1 [81.4 kB] Get:3 http://archive.raspberrypi.org/debian bullseye/main arm64 raspinfo all 20230123-1 [2,564 B] Get:4 http://archive.raspberrypi.org/debian bullseye/main arm64 raspi-utils arm64 20230123-1 [41.8 kB] Get:5 https://apt.grafana.com stable/main arm64 grafana arm64 10.2.3 [100 MB] Fetched 101 MB in 19s (5,315 kB/s) Reading changelogs... Done Selecting previously unselected package musl:arm64. (Reading database ... 59837 files and directories currently installed.) Preparing to unpack .../musl_1.2.2-1_arm64.deb ... Unpacking musl:arm64 (1.2.2-1) ... Preparing to unpack .../grafana_10.2.3_arm64.deb ... Unpacking grafana (10.2.3) over (9.2.4) ... Selecting previously unselected package kms++-utils. Preparing to unpack .../kms++-utils_0~git20221104~171243+adc05b6-1_arm64.deb ... Unpacking kms++-utils (0~git20221104~171243+adc05b6-1) ... Preparing to unpack .../raspinfo_20230123-1_all.deb ... Unpacking raspinfo (20230123-1) over (20190624-1) ... Selecting previously unselected package raspi-utils. Preparing to unpack .../raspi-utils_20230123-1_arm64.deb ... Unpacking raspi-utils (20230123-1) ... Setting up kms++-utils (0~git20221104~171243+adc05b6-1) ... Setting up musl:arm64 (1.2.2-1) ... Setting up grafana (10.2.3) ... Installing new version of config file /etc/init.d/grafana-server ... Installing new version of config file /usr/lib/systemd/system/grafana-server.service ... Restarting grafana-server service... OK Setting up raspi-utils (20230123-1) ... Setting up raspinfo (20230123-1) ... Processing triggers for man-db (2.9.4-2) ... pi@raspberrypi:~ $ -
Jetzt solltest du wieder 'auf Spur' sein.
Schau dir das Bild jetzt in Gänze an.iob diaggibt dir den Überblick.
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Kernel : aarch64 Userland : arm64 Systemuptime and Load: 18:00:00 up 13 min, 1 user, load average: 0.48, 0.49, 0.39 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Mon 2024-01-08 18:00:00 CET Universal time: Mon 2024-01-08 17:00:00 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 7.8G 1.2G 5.4G 1.0M 1.3G 6.5G Swap: 99M 0B 99M Total: 7.9G 1.2G 5.5G 7811 M total memory 1169 M used memory 1509 M active memory 760 M inactive memory 5389 M free memory 49 M buffer memory 1202 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 220G 5.7G 206G 3% / devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 1.6G 1.2M 1.6G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/sda1 vfat 255M 31M 225M 13% /boot tmpfs tmpfs 782M 0 782M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Mon Jan 8 17:46:59 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:5F:78:11 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=c382a905-02 rootfstype=ext4 fsck.repair=yes rootwait [Mon Jan 8 17:47:01 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none. [Mon Jan 8 17:47:01 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [Mon Jan 8 17:47:02 2024] EXT4-fs (sda2): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 2.4G /var/ 1.1G /var/log/journal/06df86f59cbd48888af076fdae20e584 1.1G /var/log/journal 1.1G /var/log 903M /var/lib Archived and active journals take up 1.0G in the file system. /opt/iobroker/backups: 9.2M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 192M /opt/iobroker/iobroker-data/ 113M /opt/iobroker/iobroker-data/files 67M /opt/iobroker/iobroker-data/files/javascript.admin 55M /opt/iobroker/iobroker-data/backup-objects 48M /opt/iobroker/iobroker-data/files/javascript.admin/static The five largest files in iobroker-data are: 22M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map 21M /opt/iobroker/iobroker-data/objects.jsonl 8.9M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js 7.5M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map 7.1M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': find: '/dev/serial/by-id/': No such file or directory *** NodeJS-Installation *** /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.0-1nodesource1 Version table: *** 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 12.22.12~dfsg-1~deb11u4 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages 500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.17 admin: 6.12.0 javascript: 7.1.6 Adapters from github: 2 Adapter State + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin + system.adapter.backitup.0 : backitup : raspberrypi - enabled + system.adapter.discovery.0 : discovery : raspberrypi - enabled + system.adapter.email.0 : email : raspberrypi - enabled + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.javascript.0 : javascript : raspberrypi - enabled + system.adapter.modbus.0 : modbus : raspberrypi - enabled system.adapter.modbus.1 : modbus : raspberrypi - disabled + system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 system.adapter.solaredge.0 : solaredge : raspberrypi - disabled system.adapter.solarlog.0 : solarlog : raspberrypi - disabled, port: 80 + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : raspberrypi - enabled + system.adapter.wolf.0 : wolf : raspberrypi - enabled, port: 12004, bind: 0.0.0.0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.wolf.0 : wolf : raspberrypi - enabled, port: 12004, bind: 0.0.0.0 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.12.0 , installed 6.12.0 Adapter "backitup" : 2.9.8 , installed 2.9.8 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "email" : 1.2.1 , installed 1.2.1 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "javascript" : 7.1.6 , installed 7.1.6 Controller "js-controller": 5.0.17 , installed 5.0.17 Adapter "modbus" : 6.0.1 , installed 6.0.1 Adapter "mqtt" : 5.1.0 , installed 5.1.0 Adapter "shelly" : 6.6.1 , installed 6.6.1 Adapter "solarlog" : 2.2.8 , installed 2.2.8 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "wolf" : 1.7.0 , installed 1.7.0 Objects and States Please stand by - This may take a while Objects: 3856 States: 3341 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security bullseye-security InRelease Hit:2 http://deb.debian.org/debian bullseye InRelease Hit:3 http://deb.debian.org/debian bullseye-updates InRelease Hit:4 https://repos.influxdata.com/debian stable InRelease Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease Get:6 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B] Hit:7 https://apt.grafana.com stable InRelease Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease Fetched 5127 B in 2s (2723 B/s) Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 15375 889/iobroker.js-con tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 15368 889/iobroker.js-con tcp 0 0 0.0.0.0:12004 0.0.0.0:* LISTEN 1001 16425 988/io.wolf.0 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 13710 542/sshd: /usr/sbin tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 15489 1035/io.mqtt.0 tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 14994 1065/io.shelly.1 tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 15512 1050/io.sonoff.0 tcp6 0 0 :::7070 :::* LISTEN 112 24220 2003/evcc tcp6 0 0 :::3000 :::* LISTEN 111 23600 1868/grafana tcp6 0 0 :::8081 :::* LISTEN 1001 13891 916/io.admin.0 tcp6 0 0 :::8086 :::* LISTEN 110 12249 768/influxd tcp6 0 0 :::502 :::* LISTEN 112 24218 2003/evcc tcp6 0 0 :::22 :::* LISTEN 0 13712 542/sshd: /usr/sbin tcp6 0 0 :::80 :::* LISTEN 0 14638 553/apache2 udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 12071 391/avahi-daemon: r udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 16495 1020/io.shelly.0 udp 0 0 0.0.0.0:51516 0.0.0.0:* 1001 30382 - udp 0 0 0.0.0.0:52317 0.0.0.0:* 108 12073 391/avahi-daemon: r udp 0 0 0.0.0.0:68 0.0.0.0:* 0 13720 762/dhcpcd udp6 0 0 :::5353 :::* 108 12072 391/avahi-daemon: r udp6 0 0 :::49554 :::* 108 12074 391/avahi-daemon: r udp6 0 0 :::546 :::* 0 13805 762/dhcpcd *** Log File - Last 25 Lines *** 2024-01-08 17:59:47.868 - info: influxdb.0 (938) Influx DB Version used: 2.x 2024-01-08 17:59:47.876 - error: influxdb.0 (938) HttpError: unauthorized access 2024-01-08 17:59:57.875 - info: influxdb.0 (938) Connecting http://localhost:8086/ ... 2024-01-08 17:59:57.876 - info: influxdb.0 (938) Influx DB Version used: 2.x 2024-01-08 17:59:57.881 - error: influxdb.0 (938) HttpError: unauthorized access 2024-01-08 18:00:00.195 - info: javascript.0 (954) script.js.Strom_Shelly_Verbrauch-Historie_mqtt: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 0 2024-01-08 18:00:00.283 - info: javascript.0 (954) script.js.Strom_Shelly_Verbrauchs-Historie: Shelly Verbrauch: Verbrauchswerte aktualisiert: 26 | Reboots korrigiert: 0 | Unveränderte Werte: 51 2024-01-08 18:00:07.882 - info: influxdb.0 (938) Connecting http://localhost:8086/ ... 2024-01-08 18:00:07.882 - info: influxdb.0 (938) Influx DB Version used: 2.x 2024-01-08 18:00:07.887 - error: influxdb.0 (938) HttpError: unauthorized access 2024-01-08 18:00:17.889 - info: influxdb.0 (938) Connecting http://localhost:8086/ ... 2024-01-08 18:00:17.889 - info: influxdb.0 (938) Influx DB Version used: 2.x 2024-01-08 18:00:17.894 - error: influxdb.0 (938) HttpError: unauthorized access 2024-01-08 18:00:27.897 - info: influxdb.0 (938) Connecting http://localhost:8086/ ... 2024-01-08 18:00:27.898 - info: influxdb.0 (938) Influx DB Version used: 2.x 2024-01-08 18:00:27.906 - error: influxdb.0 (938) HttpError: unauthorized access 2024-01-08 18:00:37.906 - info: influxdb.0 (938) Connecting http://localhost:8086/ ... 2024-01-08 18:00:37.907 - info: influxdb.0 (938) Influx DB Version used: 2.x 2024-01-08 18:00:37.915 - error: influxdb.0 (938) HttpError: unauthorized access 2024-01-08 18:00:47.916 - info: influxdb.0 (938) Connecting http://localhost:8086/ ... 2024-01-08 18:00:47.916 - info: influxdb.0 (938) Influx DB Version used: 2.x 2024-01-08 18:00:47.921 - error: influxdb.0 (938) HttpError: unauthorized access 2024-01-08 18:00:57.921 - info: influxdb.0 (938) Connecting http://localhost:8086/ ... 2024-01-08 18:00:57.921 - info: influxdb.0 (938) Influx DB Version used: 2.x 2024-01-08 18:00:57.927 - error: influxdb.0 (938) HttpError: unauthorized access============ Mark until here for C&P =============
iob diag has finished.
Press any key for a summary
unten sind noch Fehler ?
bitte:
======================= SUMMARY ======================= v.2023-10-10 Static hostname: raspberrypi Icon name: computer Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Installation: native Kernel: aarch64 Userland: arm64 Timezone: Europe/Berlin (CET, +0100) User-ID: 1000 X-Server: false Boot Target: multi-user.target Pending OS-Updates: 0 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 Recommended versions are nodejs 18.19.0 and npm 10.2.3 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 7.8G 1.6G 4.9G 1.0M 1.3G 6.1G Swap: 99M 0B 99M Total: 7.9G 1.6G 5.0G Active iob-Instances: 14 Active repo(s): stable ioBroker Core: js-controller 5.0.17 admin 6.12.0 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin Objects: 3856 States: 3341 Size of iob-Database: 21M /opt/iobroker/iobroker-data/objects.jsonl 6.9M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ======================= Mark text until here for copying ===
Das System ist jetzt grundsätzlich richtig.
Bei den Fehlern aus dem Log kann dir vermutlich @Marc-Berg weiterhelfen. Von influxdb hab ich nämlich keine Ahnung. -
Vielen Danke.
Das heißt ich kann jetzt immer über den Paketmanager gehen?Der Influx Adapter läuft jetzt nicht mehr:
influxdb.0 2024-01-08 18:38:49.775 error HttpError: unauthorized access influxdb.0 2024-01-08 18:38:49.769 info Influx DB Version used: 2.x influxdb.0 2024-01-08 18:38:49.769 info Connecting http://localhost:8086/ ... -
@bitwicht sagte in Ertrag (Tag, Monat, Jahr) berechnen und in Datei speichern:
Ja, das schwimmt jetzt alles beim Paketmanager mit.
Persudo apt update sudo apt full-upgraderegelmäßig dabei bleiben.
jetzt habe ich aber ein Problem.
Wenn ich auf die Weboberfläche der Influx gehe, kommt "Get Started"Sind jetzt alle meine Daten weg ?
Das musst du @Marc-Berg fragen. Wie gesagt, ich verwende influxdb nicht. Da müssen irgendwie irgendwo irgendwelche Tokens (Die hast du noch?) hinterlegt werden, wenn ich das richtig weiß.
@Thomas Braun
Ich warte mal auf @Marc-Berg
Ich habe die Token noch aber es sieht so aus als ob die Influx komplett neu ist.
Auf der Weboberfläche kommt "Get Started" und ich soll den Admin User neu vergeben, etc.
Dann müsste man wohl die alten Datenbanken reinholen können.
