    4. IOB keine Weboberfläche für Zigbee oder Objekte
      wolkenloser last edited by wolkenloser
      Mein IOB macht wieder Probleme.
      Eigendlich läuft alles incl. VIS , aber ich kann die IOB mir weder Zigbee noch Objekte oder den Admin ansehen.
      Hier mal der Output von IOB Diag:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: microsoft
        Operating System: Ubuntu 20.04.6 LTS
                  Kernel: Linux 5.4.0-169-generic
            Architecture: x86-64
      model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
      Docker          : false
      Virtualization  : microsoft
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       17:41:12 up 2 days, 52 min,  2 users,  load average: 1.63, 1.22, 1.16
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Mon 2024-01-08 17:41:13 CET
                 Universal time: Mon 2024-01-08 16:41:13 UTC
                       RTC time: Mon 2024-01-08 16:41:14
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      iobroker
      /home/iobroker
      iobroker adm tty dialout cdrom sudo audio dip video plugdev lxd
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           5.9G        3.1G        645M        0.0K        2.2G        2.7G
      Swap:          2.0G        175M        1.8G
      Total:         7.9G        3.3G        2.4G
               5929 M total memory
               3124 M used memory
               3259 M active memory
               1574 M inactive memory
                645 M free memory
                320 M buffer memory
               1839 M swap cache
               1969 M total swap
                175 M used swap
               1794 M free swap
      *** FAILED SERVICES ***
        UNIT           LOAD   ACTIVE SUB    DESCRIPTION
      * fstrim.service loaded failed failed Discard unused blocks on filesystems from /etc/fstab
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  2.9G     0  2.9G   0% /dev
      tmpfs          tmpfs     593M  1.2M  592M   1% /run
      /dev/sda2      ext4       50G   34G   14G  72% /
      tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     2.9G     0  2.9G   0% /sys/fs/cgroup
      /dev/loop1     squashfs  106M  106M     0 100% /snap/core/16091
      /dev/loop2     squashfs   56M   56M     0 100% /snap/core18/2796
      /dev/loop0     squashfs  106M  106M     0 100% /snap/core/16202
      /dev/loop3     squashfs   56M   56M     0 100% /snap/core18/2812
      /dev/loop4     squashfs   64M   64M     0 100% /snap/core20/2015
      /dev/loop5     squashfs   64M   64M     0 100% /snap/core20/2105
      /dev/loop6     squashfs   92M   92M     0 100% /snap/lxd/23991
      /dev/loop7     squashfs   92M   92M     0 100% /snap/lxd/24061
      /dev/loop8     squashfs  128K  128K     0 100% /snap/ncdu/62
      /dev/loop9     squashfs  128K  128K     0 100% /snap/ncdu/64
      /dev/loop10    squashfs  4.3M  4.3M     0 100% /snap/tree/18
      tmpfs          tmpfs     593M     0  593M   0% /run/user/1000
      [sudo] password for iobroker:
      [Sat Jan  6 16:49:13 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Jan  6 16:49:21 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
      TARGET                SOURCE      FSTYPE   OPTIONS
      /                     /dev/sda2   ext4     rw,relatime
      |-/sys/kernel/tracing tracefs     tracefs  rw,nosuid,nodev,noexec,relatime
      |-/snap/core/16091    /dev/loop1  squashfs ro,nodev,relatime
      |-/snap/core18/2796   /dev/loop2  squashfs ro,nodev,relatime
      |-/snap/core/16202    /dev/loop0  squashfs ro,nodev,relatime
      |-/snap/core18/2812   /dev/loop3  squashfs ro,nodev,relatime
      |-/snap/core20/2015   /dev/loop4  squashfs ro,nodev,relatime
      |-/snap/core20/2105   /dev/loop5  squashfs ro,nodev,relatime
      |-/snap/lxd/23991     /dev/loop6  squashfs ro,nodev,relatime
      |-/snap/lxd/24061     /dev/loop7  squashfs ro,nodev,relatime
      |-/snap/ncdu/62       /dev/loop8  squashfs ro,nodev,relatime
      |-/snap/ncdu/64       /dev/loop9  squashfs ro,nodev,relatime
      `-/snap/tree/18       /dev/loop10 squashfs ro,nodev,relatime
      /var:
      5.6G    /var/
      3.9G    /var/log/journal/4c4f1c196fd742fb8ea78816d6e03b15
      3.9G    /var/log
      1.5G    /var/lib
      Archived and active journals take up 3.8G in the file system.
      /opt/iobroker/backups:
      12M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      16G     /opt/iobroker/iobroker-data/
      15G     /opt/iobroker/iobroker-data/history
      690M    /opt/iobroker/iobroker-data/files
      155M    /opt/iobroker/iobroker-data/backup-objects
      113M    /opt/iobroker/iobroker-data/files/vis-2-beta
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.f79fb97a.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.2
      /usr/bin/node           v18.18.2
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
        Installed: 18.18.2-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
       *** 18.18.2-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           10.19.0~dfsg-3ubuntu1.3 500
              500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
              500 http://de.archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
           10.19.0~dfsg-3ubuntu1 500
              500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: eiscp@0.0.1 /opt/iobroker/node_modules/eiscp
      npm ERR! invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-08T16_42_22_423Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   0
      Adapter State
        system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
        system.adapter.easee.0                  : easee                 : iobroker                                 - disabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
      + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
        system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.8.67
      + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
        system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
      + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
      + system.adapter.onkyo.0                  : onkyo                 : iobroker                                 -  enabled
        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
        system.adapter.parser.0                 : parser                : iobroker                                 - disabled
        system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
        system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
        system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
        system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
        system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
      Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
      Adapter    "daswetter"    : 3.1.11   , installed 3.1.12
      Adapter    "device-reminder": 3.0.0  , installed 3.0.0
      Adapter    "easee"        : 1.0.10   , installed 1.0.10
      Adapter    "echarts"      : 1.5.4    , installed 1.5.4
      Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fronius"      : 2.0.2    , installed 2.0.2
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "harmony"      : 1.3.0    , installed 1.3.0
      Adapter    "ical"         : 1.13.3   , installed 1.13.6
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
      Adapter    "knx"          : 2.0.24   , installed 2.0.24
      Adapter    "lg-thinq"     : 0.3.1    , installed 0.3.1
      Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
      Adapter    "midea"        : 0.0.7    , installed 0.0.7
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "moma"         : 1.2.9    , installed 1.2.9
      Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
      Adapter    "openweathermap": 0.4.5   , installed 0.4.5
      Adapter    "parser"       : 2.0.7    , installed 2.0.7
      Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "unifi"        : 0.6.7    , installed 0.6.7
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "zigbee"       : 1.9.7    , installed 1.9.5  [Updatable]
      Objects and States
      Objects:        11386
      States:         10291
      Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
      Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
      Hit:4 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 11
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       126087     9520/io.shelly.0
      tcp        0      0 192.168.8.67:9093       0.0.0.0:*               LISTEN      1000       125408     9655/io.fakeroku.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       125045     9359/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       125038     9359/iobroker.js-co
      tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          28689      1062/perl
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        21994      663/systemd-resolve
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25974      849/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        26244      836/influxd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       125292     9536/io.sonoff.0
      tcp6       0      0 :::61991                :::*                    LISTEN      1000       126343     9690/io.harmony.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       126762     10203/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        28227      836/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          25976      849/sshd: /usr/sbin
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       126823     10382/io.simple-api
      tcp6       0      0 :::3000                 :::*                    LISTEN      111        26392      818/grafana-server
      udp        0      0 192.168.8.67:35335      0.0.0.0:*                           1000       204758     23136/io.knx.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       195031     20727/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       195032     20727/io.tuya.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        21993      663/systemd-resolve
      udp        0      0 192.168.8.67:68         0.0.0.0:*                           100        1364760    661/systemd-network
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       126344     9690/io.harmony.0
      udp        0      0 192.168.8.67:41557      0.0.0.0:*                           1000       1814430    23136/io.knx.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       156371     15744/io.wled.0
      udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          28690      1062/perl
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       125409     9655/io.fakeroku.0
      udp6       0      0 fe80::11:32ff:fe2d::546 :::*                                100        21998      661/systemd-network
      2024-01-08 17:43:01.558  - warn: sonoff.0 (9536) Client [] has invalid password or username
      2024-01-08 17:43:37.525  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.95 (shelly1 / shelly1-B8B540 / SHSW-1#B8B540#1) "/settings/relay/0": Wrong http username or http password! Please enter user credentials for restricted login.
      2024-01-08 17:43:37.578  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.95 (shelly1 / shelly1-B8B540 / SHSW-1#B8B540#1) "/settings": Wrong http username or http password! Please enter user credentials for restricted login.
      2024-01-08 17:43:37.630  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.95 (shelly1 / shelly1-B8B540 / SHSW-1#B8B540#1) "/status": Wrong http username or http password! Please enter user credentials for restricted login.
      2024-01-08 17:43:37.690  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.95 (shelly1 / shelly1-B8B540 / SHSW-1#B8B540#1) "/settings/ext_temperature/0": Wrong http username or http password! Please enter user credentials for restricted login.
      2024-01-08 17:43:37.749  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.95 (shelly1 / shelly1-B8B540 / SHSW-1#B8B540#1) "/settings/ext_temperature/1": Wrong http username or http password! Please enter user credentials for restricted login.
      2024-01-08 17:43:37.806  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.95 (shelly1 / shelly1-B8B540 / SHSW-1#B8B540#1) "/settings/ext_temperature/2": Wrong http username or http password! Please enter user credentials for restricted login.
      2024-01-08 17:43:47.937  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.22 (shelly1 / shelly1-769AB4 / SHSW-1#769AB4#1) "/settings/relay/0": Wrong http username or http password! Please enter user credentials for restricted login.
      2024-01-08 17:43:47.995  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.22 (shelly1 / shelly1-769AB4 / SHSW-1#769AB4#1) "/settings": Wrong http username or http password! Please enter user credentials for restricted login.
      2024-01-08 17:43:48.023  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.22 (shelly1 / shelly1-769AB4 / SHSW-1#769AB4#1) "/status": Wrong http username or http password! Please enter user credentials for restricted login.
      2024-01-08 17:43:48.969  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.22 (shelly1 / shelly1-769AB4 / SHSW-1#769AB4#1) "/settings/ext_temperature/0": Wrong http username or http password! Please enter user credentials for restricted login.
      2024-01-08 17:43:49.015  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.22 (shelly1 / shelly1-769AB4 / SHSW-1#769AB4#1) "/settings/ext_temperature/1": Wrong http username or http password! Please enter user credentials for restricted login.
      2024-01-08 17:43:49.049  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.22 (shelly1 / shelly1-769AB4 / SHSW-1#769AB4#1) "/settings/ext_temperature/2": Wrong http username or http password! Please enter user credentials for restricted login.
      2024-01-08 17:44:00.038  - warn: javascript.0 (11567) State "sonoff.0.WIFI-STECKDOSE-5.POWER" not found
      2024-01-08 17:44:00.041  - warn: javascript.0 (11567)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
      2024-01-08 17:44:00.042  - warn: javascript.0 (11567)     at Object.<anonymous> (script.js.Heizung.Gartenhütte_Heizung:15:5)
      2024-01-08 17:44:00.042  - warn: javascript.0 (11567)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
      2024-01-08 17:44:00.042  - warn: javascript.0 (11567)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
      2024-01-08 17:44:00.043  - warn: javascript.0 (11567)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
      2024-01-08 17:44:00.043  - warn: javascript.0 (11567)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
      2024-01-08 17:44:00.043  - warn: javascript.0 (11567)     at listOnTimeout (node:internal/timers:569:17)
      2024-01-08 17:44:00.044  - warn: javascript.0 (11567)     at processTimers (node:internal/timers:512:7)
      2024-01-08 17:44:00.044  - info: javascript.0 (11567) script.js.Heizung.Gartenhütte_Heizung: 25.2
      2024-01-08 17:44:00.044  - info: javascript.0 (11567) script.js.Heizung.Gartenhütte_Heizung: E-Heizung Gartenhütte - AUS
      2024-01-08 17:44:02.049  - warn: sonoff.0 (9536) Client [] has invalid password or username
      W Thomas Braun Glasfaser 3 Replies Last reply Reply Quote 0
        wolkenloser @wolkenloser last edited by
        ich sehe schon: Admin.0 läuft nicht.
        Den konnte ich manuell starten, aber dann funktioniert er nach einem Reboot wieder nicht, oder ?
        • Glasfaser
          Glasfaser @wolkenloser last edited by
          @wolkenloser
          Teste es , dann kann man immer noch nach einem Fehler suchen .
          Aber dein System ... hat schon einiges hintersich und ist nicht Aktuell !
            Thomas Braun Most Active @wolkenloser last edited by
            @wolkenloser
            Da musst du mal schauen wo die herkommen. Entweder löschen oder neuinstallieren.
            Veraltet, updaten.
            Pending Updates: 11
            Updates einspielen.
            • Glasfaser
              @Thomas-Braun
              gesehn ... sportliche Nummer :
                wolkenloser @Thomas Braun last edited by
                @thomas-braun Du weist doch, wei hatten vor ca 4 Wochen mal alles geupdatet.
                Das ist doch nicht normal, das man so schnell "veraltert" ist ?
                Wenn ich sehe das Adapter ein update haben wollen, mach ich das ja schon immer sofort.
                Kürzlich habe ich den Device-Reminder für Zigbee installiert und kurz danach war wieder alles kaputt, so das ich auf ein Backup gegangen bin.
                Das war bisher eigendlich nie ein Problem, aber seit ein paar Monaten hab ich andauernd irgendwas...
                ich weiss nicht was das sein soll.... schon gar nicht, wie ich das entfernen kann
                Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                  wolkenloser @Glasfaser last edited by
                  @glasfaser
                  Die History benutze ich eigendlich gar nicht mehr, Mach ja ales mit informix.
                  Ich lösch da erstmal altes Zeug
                  • Glasfaser
                    @wolkenloser
                    ... würde auch mal schauen warum der Ordner so aufgebläht ist , 16 Gigabyte ist schon groß
                    • Glasfaser
                      Glasfaser @wolkenloser last edited by Glasfaser
                      @wolkenloser
                      einer kommt vom ( eventuell eine anhängigkeit )
                      Adapter
                      der andere sagt mir gerade nichts
                        @wolkenloser
                        Man hält das Zeug ja auch laufend aktuell.
                          Ich habe mal in meine History Ordner geschaut was da überhaupt mitgeloggt wird.
                          Ich bin irgendwie irritiert.
                          Was ist das ?
                          Ich finde keine Objekte wo die History aktiviert ist.ich hab das früher mal für Temperaturen gemacht. Das mache ich jetzt aber alles über Influx.
                          Hier ein Beispiel:
                          • Glasfaser
                            @wolkenloser sagte in IOB keine Weboberfläche für Zigbee oder Objekte:
                            Filtere danach .. was zeigt er an :
                              @glasfaser
                              3.9G    /opt/iobroker/iobroker-data/
                              3.0G    /opt/iobroker/iobroker-data/history
                              hab viel gelöscht 🙂
                              wegen dem NPN Error: Ich habe den Onkyo Adapter der anscheinend EISCP benutzt einmal entfernt und neu intalliert, aber das hat nichts gebracht.
                                @wolkenloser
                                cd /opt/iobroker && npm ls buffer eiscp
                                  @thomas-braun sagte in IOB keine Weboberfläche für Zigbee oder Objekte:
                                  iobroker.inst@2.0.3 /opt/iobroker
                                  ├─┬ iobroker.bydhvs@1.5.0
                                  │ └─┬ crc@4.3.2
                                  │   └── buffer@5.7.1 invalid: ">=6.0.3" from node_modules/crc
                                  ├─┬ iobroker.onkyo@2.1.2
                                  │ └── eiscp@0.0.1 invalid: "https://github.com/GermanBluefox/node-eiscp/tarball/master/" from node_modules/iobroker.onkyo
                                  └─┬ iobroker.shelly@6.6.1
                                    ├─┬ mqtt-connection@4.1.0
                                    │ └─┬ mqtt-packet@6.10.0
                                    │   └─┬ bl@4.1.0
                                    │     └── buffer@5.7.1 deduped invalid: ">=6.0.3" from node_modules/crc
                                    └─┬ shelly-iot@1.1.2
                                      └─┬ coap@0.26.0
                                        └─┬ bl@5.1.0
                                          └── buffer@6.0.3
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-09T19_16_09_037Z-debug-0.log
                                    @wolkenloser
                                    Da siehst du wo es klemmt.
                                      @wolkenloser
                                      Installier den nochmal. Hier wird der nämlich dann richtig reingeholt:
                                      │ └─┬ crc@4.3.2
                                      │   └── buffer@6.0.3
                                        wolkenloser @Thomas Braun last edited by wolkenloser
                                        Ich versuch es mal
                                          @wolkenloser
                                          Gleiches gilt für den:
                                          └─┬ iobroker.onkyo@2.1.2
                                            └── eiscp@0.0.1
                                            Ich habe den BYD Adaper deinstalliert und neuinstalliert und nochmal deinstalliert, auch den Onkyo Adapter.
                                            Das Ergebnis ist folgendes
                                            :/opt/iobroker$ cd /opt/iobroker && npm ls buffer eiscp
                                              │   └─┬ bl@4.1.0
                                              │     └── buffer@5.7.1
                                                └─┬ coap@0.26.0
                                                  └─┬ bl@5.1.0
                                                    └── buffer@6.0.3
                                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-09T20_08_08_522Z-debug-0.log
                                            597
