    4. Test Adapter LG ThinQ
      Lucky_ESA Developer Most Active @ofri2607 last edited by
      @ofri2607 sagte in Test Adapter LG ThinQ v0.0.1:
      @lucky_esa
      Alles gut 🙂 hole ich mir dann gleich.
      Die warn-Meldung zum setObject bei den thinq2 Geräten, denke ich, ist an sich unkritisch, oder?
      Ist kritisch. Muss da mal schauen.
      ofri2607 1 Reply Last reply Reply Quote 0
      • ofri2607
        ofri2607 @Lucky_ESA last edited by
        @lucky_esa
        Letzte GIT Version geholt und läuft 🙂 … mit den o.a. Warn-Meldungen zum setobject.
        Herzlichen Dank für deine schnelle Lösung!
        2024-01-07 13:26:54.283 - info: lg-thinq.0 (1158883) starting. Version 0.3.1 (non-npm: TA2k/ioBroker.lg-thinq) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v18.19.0, js-controller: 5.0.17
        2024-01-07 13:26:56.802 - info: lg-thinq.0 (1158883) Login successful
        2024-01-07 13:26:59.210 - info: lg-thinq.0 (1158883) Found: 3 devices
        2024-01-07 13:26:59.213 - info: lg-thinq.0 (1158883) Create or update datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
        2024-01-07 13:27:13.092 - info: lg-thinq.0 (1158883) Update raw datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
        2024-01-07 13:27:13.587 - info: lg-thinq.0 (1158883) Create or update datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
        2024-01-07 13:27:13.729 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.windStrength (type=state) property common.role missing!
        2024-01-07 13:27:13.731 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.wDirCtrl.hStep (type=state) property common.role missing!
        2024-01-07 13:27:13.735 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.qualityMngCtrl.sensorMon (type=state) property common.role missing!
        2024-01-07 13:27:13.737 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.target (type=state) property common.role missing!
        2024-01-07 13:27:13.738 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.operation (type=state) property common.role missing!
        2024-01-07 13:27:13.739 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.wDirCtrl.vStep (type=state) property common.role missing!
        2024-01-07 13:27:13.741 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.settingInfo.basic (type=state) property common.role missing!
        2024-01-07 13:27:13.742 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.settingInfo.autoDry (type=state) property common.role missing!
        2024-01-07 13:27:13.743 - warn: lg-thinq.0 (1158883) setObject dfbdfc44-8efb-148a-acc9-44cb8b32f2ea.remote.basicCtrl.opMode (type=state) property common.role missing!
        2024-01-07 13:27:18.835 - info: lg-thinq.0 (1158883) Update raw datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
        2024-01-07 13:27:19.181 - info: lg-thinq.0 (1158883) Create or update datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
        2024-01-07 13:27:19.226 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.windStrength (type=state) property common.role missing!
        2024-01-07 13:27:19.227 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.wDirCtrl.hStep (type=state) property common.role missing!
        2024-01-07 13:27:19.227 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.qualityMngCtrl.sensorMon (type=state) property common.role missing!
        2024-01-07 13:27:19.228 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.target (type=state) property common.role missing!
        2024-01-07 13:27:19.228 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.operation (type=state) property common.role missing!
        2024-01-07 13:27:19.228 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.wDirCtrl.vStep (type=state) property common.role missing!
        2024-01-07 13:27:19.229 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.settingInfo.basic (type=state) property common.role missing!
        2024-01-07 13:27:19.229 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.settingInfo.autoDry (type=state) property common.role missing!
        2024-01-07 13:27:19.230 - warn: lg-thinq.0 (1158883) setObject fd80ae07-21ef-18c3-bd4c-44cb8b63456e.remote.basicCtrl.opMode (type=state) property common.role missing!
        2024-01-07 13:27:24.468 - info: lg-thinq.0 (1158883) Update raw datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
        2024-01-07 13:27:24.992 - info: lg-thinq.0 (1158883) Found MQTT Host
        2024-01-07 13:27:25.076 - info: lg-thinq.0 (1158883) Found AWS CER
        2024-01-07 13:27:25.698 - info: lg-thinq.0 (1158883) Create certification done
        2024-01-07 13:27:25.970 - info: lg-thinq.0 (1158883) Start MQTT Connection
        2024-01-07 13:27:26.421 - info: lg-thinq.0 (1158883) MQTT connected to: t20/op/c506395e26728fd0340f7cf4a8e263719ced9d1b9effe7df9ec6d374156ea85c/inbox
          @ofri2607 Der Fehler sollte nun auch behoben sein. Hab es gerade erst auf dem GIT geschoben daher mal 2 Minuten warten.
          ofri2607 1 Reply Last reply Reply Quote 1
          • ofri2607
            @lucky_esa
            Läuft ruhig durch - ohne eine warn-Meldung 👍
            Nochmals herzlichen Dank für deine schnelle Lösung und noch einen schönen Sonntag.
              @ofri2607 Kannst du eventuell noch mal vom GIT laden. Hab noch was geändert um mehr Info anzuzeigen. Leider weiß ich nicht was die Fehlermeldung 0100 bedeutet aber die Werte werden trotzdem aktualisiert.
              • interval.status_devices
                • OK: Intervall OK
                • Fail; Intervall Fail (Fehlermeldung 0100)
                • Error: Fehlende WorkID - WorkID wird neu erstellt
                • Error <code>: Unbekannter Fehler - WorkID wird neu erstellt
              Gruß//Lucky
              • ofri2607
                ofri2607 @Lucky_ESA last edited by ofri2607
                @lucky_esa
                Ist installiert und läuft.
                Der neue Datenpunkt wurde als json mit dem Inhalt
                {"d27d1380-7149-11d3-80b8-2c2bf9760c6d":"OK"}
                angelegt.
                Edit: gerade erste gesehen, der Adapter ist jetzt auf v0.3.2
                  @lucky_esa
                  angelegt.
                  Ja, musste jetzt schnell ein Release nachschieben da die Version 0.3.1 bei thinq1 User crasht. Da ich kein Thinq1 Geräte habe muss ich immer ein wenig vermuten.
                  • ofri2607
                    @Lucky_ESA
                    Guten Morgen,
                    folgende Einträge hatte ich heute in unregelmäßigen Abständen im Log:
                    2024-01-08 23:00:17.622 - error: lg-thinq.0 (1325489) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2024-01-08 23:00:17.633 - error: lg-thinq.0 (1325489) unhandled promise rejection: undefined is not a valid state value
                    2024-01-08 23:00:17.951 - error: lg-thinq.0 (1325489) Error: undefined is not a valid state value
                    at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
                    at LgThinq._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7593:26)
                    at LgThinq.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7551:21)
                    at LgThinq.setThinq1Interval (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:467:18)
                    at /opt/iobroker/node_modules/iobroker.lg-thinq/main.js:369:22
                    at processTicksAndRejections (node:internal/process/task_queues:95:5)
                    2024-01-08 23:00:17.952 - error: lg-thinq.0 (1325489) undefined is not a valid state value
                    2024-01-08 23:00:18.514 - info: lg-thinq.0 (1325489) terminating
                    2024-01-08 23:00:18.516 - warn: lg-thinq.0 (1325489) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2024-01-08 23:00:18.558 - info: lg-thinq.0 (1325489) terminating
                    2024-01-08 23:00:19.134 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                    2024-01-08 23:00:19.134 - error: host.raspberrypi Caught by controller[1]: Error: undefined is not a valid state value
                    2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
                    2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at LgThinq._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7593:26)
                    2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at LgThinq.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7551:21)
                    2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at LgThinq.setThinq1Interval (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:467:18)
                    2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.lg-thinq/main.js:369:22
                    2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                    2024-01-08 23:00:19.135 - error: host.raspberrypi instance system.adapter.lg-thinq.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2024-01-08 23:00:19.135 - info: host.raspberrypi Restart adapter system.adapter.lg-thinq.0 because enabled
                    2024-01-08 23:00:49.233 - info: host.raspberrypi instance system.adapter.lg-thinq.0 started with pid 1327629
                    2024-01-08 23:00:52.448 - info: lg-thinq.0 (1327629) starting. Version 0.3.2 (non-npm: TA2k/ioBroker.lg-thinq) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v18.19.0, js-controller: 5.0.17
                    2024-01-08 23:00:54.140 - info: lg-thinq.0 (1327629) Login successful
                    2024-01-08 23:00:58.992 - info: lg-thinq.0 (1327629) Found: 3 devices
                    2024-01-08 23:00:58.993 - info: lg-thinq.0 (1327629) Create or update datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
                    2024-01-08 23:01:14.671 - info: lg-thinq.0 (1327629) Update raw datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
                    2024-01-08 23:01:15.229 - info: lg-thinq.0 (1327629) Create or update datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
                    2024-01-08 23:01:20.776 - info: lg-thinq.0 (1327629) Update raw datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
                    2024-01-08 23:01:21.503 - info: lg-thinq.0 (1327629) Create or update datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
                    2024-01-08 23:01:26.808 - info: lg-thinq.0 (1327629) Update raw datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
                    2024-01-08 23:01:27.936 - info: lg-thinq.0 (1327629) Found MQTT Host
                    2024-01-08 23:01:28.026 - info: lg-thinq.0 (1327629) Found AWS CER
                    2024-01-08 23:01:28.678 - info: lg-thinq.0 (1327629) Create certification done
                    2024-01-08 23:01:29.117 - info: lg-thinq.0 (1327629) Start MQTT Connection
                    2024-01-08 23:01:29.647 - info: lg-thinq.0 (1327629) MQTT connected to: t20/op/7e0548ce9ab409359f1393e34f2529773cfe35ff338479a1d21060cdbe7d4db2/inbox
                    Es ist keine eindeutige Zeitabfolge erkennbar, war aber von gestern nach der Installation der v0.3.2 bis heute insgesamt 5 mal, zuletzt heute um 1:43:13.
                      @Lucky_ESA
                      Guten Morgen,
                      OK, danke für die Info. Habe auf dem GIT den Fehler behoben. Dann konnte ca. 5 x keine Daten geholt werden. Das ist super und wahrscheinlich kommt noch die Zwangstrennung dazu.
                      Kannst du bitte vom GIT laden und weiter testen. Besteht die Möglichkeit das du ein Blockly erstellt was den DP interval.status_devices triggert und bei Änderungen ein Logeintrag erstellt.
                      Gruß//Lucky
                      ofri2607 2 Replies Last reply Reply Quote 0
                      • ofri2607
                        @lucky_esa
                        Servus, ja kann ich gerne machen, geht aber erst heute am Abend.
                        Blockly jetzt nicht so, mache das dann über JS.
                        • ofri2607
                          @lucky_esa
                          Ist installiert, läuft und Skript mit Trigger vom Datenpunkt läuft auch.
                          Ich lasse es mal über die Nacht durchlaufen und stelle dir dann morgen das Ergebnis der Logausgaben vom Skript ein.
                            @lucky_esa
                            Super, vielen Dank.
                            Gruß//Lucky
                            • ofri2607
                              @lucky_esa
                              Hier mal die ersten Ausgaben vom Log des Skripts …
                              javascript.3
                              2024-01-09 21:15:44.759	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                              javascript.3
                              2024-01-09 21:15:40.217	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                              javascript.3
                              2024-01-09 20:45:19.725	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{}")
                              javascript.3
                              2024-01-09 20:45:17.951	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                              javascript.3
                              2024-01-09 20:17:39.501	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                              javascript.3
                              2024-01-09 20:17:19.881	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                              javascript.3
                              2024-01-09 20:17:14.957	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                              javascript.3
                              2024-01-09 20:03:04.792	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                              javascript.3
                              2024-01-09 20:03:00.409	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                              javascript.3
                              2024-01-09 19:15:47.479	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                @ofri2607 Das sieht doch recht gut aus. Bei "Fail" kommen trotzdem Daten und es wechselt dann auch wieder auf "OK".
                                Gruß//Lucky
                                • ofri2607
                                  @lucky_esa
                                  Das habe ich mir auch gedacht, tut so wie es soll 👍
                                  Was ich mich gefragt habe, ist warum hin und wieder ein leerer Eintrag im json da ist?
                                  Über die Nacht ist es vergleichbar weitergelaufen, da war auch eine Zwangstrennung durch meinen Internetprovider dabei, die hat es auch problemlos gemeistert, siehe ...
                                  javascript.3
                                  2024-01-10 06:59:18.890	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                  javascript.3
                                  2024-01-10 06:59:09.050	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-10 06:00:53.338	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                  javascript.3
                                  2024-01-10 06:00:49.114	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-10 05:03:02.938	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                  javascript.3
                                  2024-01-10 05:02:58.308	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-10 04:03:57.614	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                  javascript.3
                                  2024-01-10 04:03:47.989	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                  javascript.3
                                  2024-01-10 04:03:42.989	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  lg-thinq.0
                                  2024-01-10 03:52:06.773	info	MQTT connected to: t20/op/d6dd60f0475926a7f83dd2cacbcf6c92eddb8512492affc08b1a36fa323fe8be/inbox
                                  lg-thinq.0
                                  2024-01-10 03:52:06.501	info	Thinq MQTT reconnect
                                  javascript.3
                                  2024-01-10 03:51:47.800	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                  javascript.3
                                  2024-01-10 03:51:42.933	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error\"}")
                                  javascript.3
                                  2024-01-10 03:51:32.747	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - 0106\"}")
                                  javascript.3
                                  2024-01-10 03:51:30.175	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - 0106\"}"(alter Wert war "{}")
                                  javascript.3
                                  2024-01-10 03:38:58.253	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-10 03:05:42.127	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                  javascript.3
                                  2024-01-10 03:05:37.539	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-10 02:08:21.801	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                  javascript.3
                                  2024-01-10 02:07:12.200	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                  javascript.3
                                  2024-01-10 02:07:07.203	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-10 01:31:41.560	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - 0106\"}")
                                  javascript.3
                                  2024-01-10 01:31:31.985	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - 0106\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                  javascript.3
                                  2024-01-10 01:30:52.049	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                  javascript.3
                                  2024-01-10 01:30:46.964	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-10 01:09:21.432	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                  javascript.3
                                  2024-01-10 01:09:16.931	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-10 00:12:51.007	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                  javascript.3
                                  2024-01-10 00:12:41.496	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                  javascript.3
                                  2024-01-10 00:12:36.516	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-10 00:12:26.045	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                                  javascript.3
                                  2024-01-10 00:12:21.426	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  Soll ich das Logging noch weiter Laufen lassen, oder hast du gesehen was du sehen wolltest?
                                    @ofri2607 Nein, musst du nicht weiterlaufen lassen. Beim ersten Intervall kommen auch Fehler die du nur im debug Modus siehst.
                                    Mal schauen, ob ich das noch ein wenig ändern kann.
                                    Gruß//Lucky
                                    • ofri2607
                                      @lucky_esa
                                      Perfekt, Danke. Wenn ich noch etwas testen soll, melde dich einfach.
                                        @lucky_esa
                                        Gerne würde noch was testen. Lösche bitte noch nicht dein Script.
                                        • ofri2607
                                          @lucky_esa
                                          Passt, mache ich nicht. Wäre aber auch wieder schnell erstellt, sind eh‘ nur zwei Zeilen 🙂
                                            @lucky_esa
                                            Es wäre super wenn du jetzt noch mal vom GIT lädst und über Nacht laufen lässt. Die Fehler die du jetzt siehst. kommen auch bem anderen Intervall aber sind nur im Debug-Modus sichtbar.
                                            Gruß//Lucky
                                            908
                                            285563
