    3. Einsteigerfragen
    4. Installation
    5. Installation Docker Image auf Synology 920+
      Leahcim last edited by Leahcim
      ich habe mir das "latest-v9" Image runter geladen und den Container gestartet. Danach habe ich im Web-Portal Port 8081 auf Port 8081 von diesem Container gemapped. Wenn ich Port 8081 auf dem NAS aufrufe bekomme ich allerdings nur das ioBroker Logo in dem ein Virtel blau rotiert.
      In der Browser Konsole sehe ich jede Menge Websocket Verbindungsfehler.
      socket.io.js:67 [2024-01-09T07:00:18.133Z] No READY flag received in 3 seconds. Re-init
      (anonym) @ instrument.ts:144
      warn @ socket.io.js:67
      (anonym) @ socket.io.js:148
      o @ helpers.ts:98
      setTimeout (async)
      (anonym) @ trycatch.ts:122
      SocketClient.connect @ socket.io.js:146
      (anonym) @ socket.io.js:428
      o @ helpers.ts:98
      setTimeout (async)
      SocketClient._reconnect @ socket.io.js:423
      SocketClient.close @ socket.io.js:410
      socket.onerror @ socket.io.js:189
      error (async)
      SocketClient.connect @ socket.io.js:182
      o @ helpers.ts:98
      setTimeout (async)
      (anonym) @ socket.io.js:149
      o @ helpers.ts:98
      setTimeout (async)
      o @ helpers.ts:98
      setTimeout (async)
      o @ helpers.ts:98
      12 weitere Frames anzeigen
      Weniger anzeigen
      socket.io.js:396 WebSocket connection to 'ws://192.168.101.6:8081/?sid=1704783615128&name=admin' failed: WebSocket is closed before the connection is established.
      SocketClient.close @ socket.io.js:396
      o @ helpers.ts:98
      setTimeout (async)
      o @ helpers.ts:98
      setTimeout (async)
      error (async)
      o @ helpers.ts:98
      setTimeout (async)
      o @ helpers.ts:98
      setTimeout (async)
      o @ helpers.ts:98
      setTimeout (async)
      o @ helpers.ts:98
      11 weitere Frames anzeigen
      Weniger anzeigen
      socket.io.js:66 [2024-01-09T07:00:18.142Z] Start reconnect 5
      socket.io.js:66 [2024-01-09T07:00:18.142Z] Reconnect is already running 5
      socket.io.js:68 [2024-01-09T07:00:18.142Z] ws connection error: CLOSE_ABNORMAL
      error @ socket.io.js:68
      socket.onclose @ socket.io.js:177
      1 weiteren Frame anzeigen
      Weniger anzeigen
      socket.io.js:66 [2024-01-09T07:00:23.145Z] Try to connect
      Hat jemand einen Tip für mich?
      Viele Grüße
      Michael
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
      Codierknecht Marc Berg 2 Replies Last reply Reply Quote 0
      • Codierknecht
        Codierknecht Developer Most Active @Leahcim last edited by
        @leahcim
        Ich frag' mal ganz blöd:
        Du betreibst den Container im Bridge-Mode? Die benötigten Ports hast Du in den Container weitergereicht?
        • Marc Berg
          Marc Berg Most Active @Leahcim last edited by Marc Berg
          @leahcim sagte in Installation Docker Image auf Synology 920+:
          Wenn du das Web-Portal aktivierst, dann schaltet die Synology einen Reverse-Proxy vor den ioBroker, der mit Websockets im Standard nicht klar kommt.
          Also Web-Portal deaktivieren, diese Einstellungen wieder löschen, und nur das Port-Mapping (unter Port-Einstellungen) machen.
            Leahcim @Marc Berg last edited by
            @marc-berg super, danke.
