    4. Error herdsman start Failed to start Zigbee
    • V
      varg @Thomas Braun last edited by varg
      zigbee.0
      2024-01-05 12:17:42.424	error	Error herdsman start
      zigbee.0
      2024-01-05 12:17:42.423	error	Failed to start Zigbee
      zigbee.0
      2024-01-05 12:17:42.423	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      2024-01-05 12:17:42.303	info	Installed Version: iobroker.zigbee@1.9.5
      zigbee.0
      2024-01-05 12:17:42.297	info	Starting Zigbee npm ...
      zigbee.0
      2024-01-05 12:17:42.297	info	Try to reconnect. 1 attempts left
      zigbee.0
      2024-01-05 12:17:32.294	error	Error herdsman start
      zigbee.0
      2024-01-05 12:17:32.293	error	Failed to start Zigbee
      zigbee.0
      2024-01-05 12:17:32.293	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      pi@iobrokerpi5:~ $ ls -ls /dev/serial/by-id/
      total 0
      0 lrwxrwxrwx 1 root root 13 Jan  5 12:15 usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00 -> ../../ttyACM0
      0 lrwxrwxrwx 1 root root 13 Jan  5 12:15 usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03 -> ../../ttyACM1
      zigbee.0
      2024-01-05 12:19:29.585	error	Error herdsman start
      zigbee.0
      2024-01-05 12:19:29.584	error	Failed to start Zigbee
      zigbee.0
      2024-01-05 12:19:29.584	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      2024-01-05 12:19:29.459	info	Installed Version: iobroker.zigbee@1.9.5
      zigbee.0
      2024-01-05 12:19:29.451	info	Starting Zigbee npm ...
      zigbee.0
      2024-01-05 12:19:29.450	info	Try to reconnect. 1 attempts left
      zigbee.0
      2024-01-05 12:19:19.447	error	Error herdsman start
      zigbee.0
      2024-01-05 12:19:19.447	error	Failed to start Zigbee
      zigbee.0
      2024-01-05 12:19:19.447	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
      zigbee.0
      2024-01-05 12:19:19.376	error	Re-commissioning your network will require re-pairing of all devices!
      zigbee.0
      2024-01-05 12:19:19.375	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
      zigbee.0
      2024-01-05 12:19:19.375	error	Please update configuration to prevent further issues.
      zigbee.0
      2024-01-05 12:19:19.375	error	- Channel List: configured=11, adapter=11
      zigbee.0
      2024-01-05 12:19:19.374	error	- Network Key: configured=ffffffffffffffffaaaaaaaaaaaaaaaa, adapter=ffffffffffffffffbbbbbbbbbbbbbbbb
      zigbee.0
      2024-01-05 12:19:19.374	error	- Extended PAN ID: configured=ffffffffaaaaaaaa, adapter=ddddddddaaaaaaaa
      zigbee.0
      2024-01-05 12:19:19.374	error	- PAN ID: configured=6754, adapter=6754
      zigbee.0
      2024-01-05 12:19:19.373	error	Configuration is not consistent with adapter state/backup!
      Zeit
      debug
      Nachricht
      zigbee.0
      2024-01-05 12:22:15.518	error	Error herdsman start
      zigbee.0
      2024-01-05 12:22:15.518	error	Failed to start Zigbee
      zigbee.0
      2024-01-05 12:22:15.517	error	Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
      admin.0
      2024-01-05 12:22:13.107	info	<== Disconnect system.user.admin from ::ffff:192.168.178.55
      admin.0
      zigbee.0
      2024-01-05 12:22:04.147	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA10"}]
      zigbee.0
      2024-01-05 12:22:04.051	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      admin.0
      2024-01-05 12:22:03.973	info	==> Connected system.user.admin from ::ffff:192.168.178.55
      admin.0
      2024-01-05 12:22:02.099	info	<== Disconnect system.user.admin from ::ffff:192.168.178.55
      zigbee.0
      2024-01-05 12:21:58.972	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA10"}]
      zigbee.0
      2024-01-05 12:21:58.878	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      ich installier den adapter mal neu
      • V
        will leider nicht
        zigbee.0
        2024-01-05 12:32:22.961	error	Error herdsman start
        zigbee.0
        2024-01-05 12:32:22.961	error	Failed to start Zigbee
        zigbee.0
        2024-01-05 12:32:22.961	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        zigbee.0
        2024-01-05 12:32:22.824	info	Installed Version: iobroker.zigbee@1.9.5
        zigbee.0
        2024-01-05 12:32:22.816	info	Starting Zigbee npm ...
        zigbee.0
        2024-01-05 12:32:22.815	info	Try to reconnect. 1 attempts left
        admin.0
        2024-01-05 12:32:18.198	info	<== Disconnect system.user.admin from ::ffff:192.168.178.55
        admin.0
        zigbee.0
        2024-01-05 12:32:12.812	error	Error herdsman start
        zigbee.0
        2024-01-05 12:32:12.812	error	Failed to start Zigbee
        zigbee.0
        2024-01-05 12:32:12.812	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
        zigbee.0
        2024-01-05 12:32:05.356	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA10"}]
        zigbee.0
        2024-01-05 12:32:05.235	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
        • V
          varg @varg last edited by varg
          Ich vermute es hat was mit der neuen TI Platine zu tun.
          Wenn ich den alten Stick von Arteck anschliesse funzt es auch nach Neustart.
          @arteck hast Du eine Idee wie ich das Board richtig einbinde. Geflasht wurde es wie oben beschrieben
          Ich kann nur so viel sagen dass ich mit dem TI Board nach jedem neustart ein port problem bekomme
            Thomas Braun Most Active @varg last edited by
            @varg
            Ich kenne das Ding nicht, wie wird das denn angebunden? Über einen Seriellen Port?
            V Meister Mopper 2 Replies Last reply Reply Quote 0
            • V
              ich sag einfach mal ja hab aber wenig ahnung.
              vor 2 Jahren konnte ich die platine noch in nem anderen system ohne probleme einbinden.
              die neuere revision eben nicht
              youtube
              • Meister Mopper
                Meister Mopper @Thomas Braun last edited by
                Ich denke, hier ist der Wurm drin, oder?
                     20.0.0-1nodesource1 600
                        500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                     18.19.0+dfsg-6~deb12u1 500
                     18.13.0+dfsg1-1 500
                  Thomas Braun Most Active @Meister Mopper last edited by
                  @meister-mopper
                  Das ist bereits geändert worden:
                  v18.19.0 has been installed! You are using the latest version now!
                    @varg
                    Mach zur Sicherheit noch:
                    echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
                    sudo apt update
                    iob stop
                    sudo apt install nodejs=18.19.0-1nodesource1
                    iob start
                    • V
                      Ich hab das System nochmal komplett neu mit nodejs18 aufgesetzt und den alten Stick in Betrieb genommen.
                      Vielleicht hat noch jemand die neuere ti Platine mit der config und kann was dazu sagen.
                      Ich teste das Teil die Tage mal an einem PI4 mit buster und schau ob's damit läuft
                      Würde mich dann nochmal melden. Danke Euch
                        BigChris last edited by BigChris
                        Bist du weitergekommen?
                        Gleiches Problem bei mir, nach Update vom Zigbee Adapter und nodejs funtioniert der Zigbee Adapter nicht mehr.
                        Bei mir mit dem raspbee als Aufsteckplatine.
                        Copy text starting here:
                        			v.2023-10-10
                         Static hostname: pi-iobroker
                               Icon name: computer
                        Operating System: Raspbian GNU/Linux 12 (bookworm)
                                  Kernel: Linux 6.1.0-rpi4-rpi-v8
                            Architecture: arm64
                        Installation: 		native
                        Kernel: 		aarch64
                        Userland: 		armhf
                        Timezone: 		Europe/Berlin (CET, +0100)
                        User-ID: 		1000
                        X-Server: 		false
                        Boot Target: 		multi-user.target
                        Pending OS-Updates: 	0
                        Pending iob updates: 	0
                        Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
                        			/usr/bin/node 		v18.19.0
                        			/usr/bin/npm 		10.2.3
                        			/usr/bin/npx 		10.2.3
                        			/usr/bin/corepack 	0.22.0
                        Recommended versions are nodejs  and npm
                        MEMORY:
                        Mem:            8.2G        749M        7.1G        1.2M        477M        7.4G
                        Swap:           104M          0B        104M
                        Total:          8.3G        749M        7.2G
                        Active iob-Instances: 	9
                        Active repo(s): stable
                        ioBroker Core: 		js-controller 		5.0.17
                        			admin 			6.12.0
                        ioBroker Status: 	iobroker is running on this host.
                        Objects type: jsonl
                        States  type: jsonl
                        + system.adapter.admin.0                  : admin                 : pi-iobroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        Objects: 		1713
                        States: 		1506
                        Size of iob-Database:
                        19M	/opt/iobroker/iobroker-data/objects.jsonl
                        2.7M	/opt/iobroker/iobroker-data/states.jsonl
                        Was mich wundert ist das hier:
                        USB-Devices by-id:
                        USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                        Irgendwie wird die Platine nicht mehr erkannt. Das passiert bei zwei Systemen bei mir, jeweils Rasperry Pi 3 und raspbee.
                          Thomas Braun Most Active @BigChris last edited by
                          @bigchris sagte in Error herdsman start Failed to start Zigbee:
                          An der Stelle dürfte die noch nie erkannt worden sein. Da tauchen nur USB-Geräte auf. Du hast doch da ein IP-basiertes Ding laufen, oder?
                          • MartinP
                            MartinP @Thomas Braun last edited by
                            @thomas-braun Im ersten Logging finde ich "/dev/ttyACM0" das deutet doch auf USB hin, oder?
                            Braille-Reader Service?
                              Thomas Braun Most Active @MartinP last edited by
                              Gerade über 'raspbee' gestolpert...
                              @BigChris : Hast du in
                              sudo raspi-config
                              auch die Serielle Schnittstelle freigeschaltet?
                              MartinP B 2 Replies Last reply Reply Quote 0
                              • MartinP
                                @thomas-braun Für solche Sachen bin ich auch Spezialist - solche "Unterbau-Vorbereitungen", die man vor Urzeiten mal gemacht hat vergesse ich auch regelmäßig bei Umzügen ...
                                  Thomas Braun Most Active @MartinP last edited by Thomas Braun
                                  @martinp
                                  Es gibt Leute, die führen Buch über Änderungen / Ergänzungen am System.
                                  MartinP 1 Reply Last reply Reply Quote 1
                                    BigChris @Thomas Braun last edited by
                                    @thomas-braun sagte in Error herdsman start Failed to start Zigbee:
                                    sudo raspi-config
                                    Ja habe ich auch noch mal gemacht.
                                    Ich habe im Verdacht, dass das apt update / upgrade ein defekt eingespielt hat beim wechsel zu bookworm.
                                    Die Geräte an dem GPIO werden offensichtlich nicht mehr im System erkannt.
                                      @bigchris
                                      Gib uns mal die Langfassung von
                                      iob diag
                                      • MartinP
                                        @thomas-braun said in Error herdsman start Failed to start Zigbee:
                                        @martinp
                                        Gute Vorsätze fürs neue Jahr ... die Logbücher von Januar und Februar sind dann regelmäßig auch zumindest annähernd vollständig 😉
                                        Wenn die Laufschuhe wieder im Schrank versauern, wird auch das Logbuch nicht mehr geführt, und in der gesparten Zeit werden wieder Kartoffelchips gefuttert 😉
                                          @bigchris
                                          iob diag
                                          Ihr habt es gewollt 🙂
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                             Static hostname: raspberrypi
                                                   Icon name: computer
                                            Operating System: Raspbian GNU/Linux 11 (bullseye)
                                                      Kernel: Linux 6.1.21-v7+
                                                Architecture: arm
                                          Model		: Raspberry Pi 3 Model B Rev 1.2
                                          Docker          : false
                                          Virtualization  : none
                                          Kernel          : armv7l
                                          Userland        : armhf
                                          Systemuptime and Load:
                                           17:24:09 up 55 days, 46 min,  1 user,  load average: 0.60, 0.20, 0.06
                                          CPU threads: 4
                                          *** RASPBERRY THROTTLING ***
                                          Current issues:
                                          Previously detected issues:
                                          *** Time and Time Zones ***
                                                         Local time: Tue 2024-01-09 17:24:09 CET
                                                     Universal time: Tue 2024-01-09 16:24:09 UTC
                                                           RTC time: Tue 2024-01-09 16:24:10
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** User and Groups ***
                                          christian
                                          /home/christian
                                          christian adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                          *** X-Server-Setup ***
                                          X-Server: 	false
                                          Desktop:
                                          Terminal: 	tty
                                          *** MEMORY ***
                                          Mem:            921M        219M         96M        0.0K        605M        637M
                                          Swap:            99M        6.0M         93M
                                          Total:          1.0G        226M        190M
                                                    921 M total memory
                                                    219 M used memory
                                                    253 M active memory
                                                    486 M inactive memory
                                                     96 M free memory
                                                     92 M buffer memory
                                                    513 M swap cache
                                                     99 M total swap
                                                      6 M used swap
                                                     93 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FAILED SERVICES ***
                                          0 loaded units listed.
                                          *** FILESYSTEM ***
                                          /dev/root      ext4       30G  3.7G   25G  14% /
                                          devtmpfs       devtmpfs  333M     0  333M   0% /dev
                                          tmpfs          tmpfs     461M     0  461M   0% /dev/shm
                                          tmpfs          tmpfs     185M  976K  184M   1% /run
                                          /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                                          tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
                                          [Wed Nov 15 16:37:59 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=b99ea19d-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Wed Nov 15 16:38:02 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Wed Nov 15 16:38:02 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                          [Wed Nov 15 16:38:05 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                          TARGET  SOURCE         FSTYPE OPTIONS
                                          /       /dev/mmcblk0p2 ext4   rw,noatime
                                          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          1.3G	/var/
                                          946M	/var/log
                                          945M	/var/log/journal/57004f2f8ec94351a48e2dcaa2d03134
                                          165M	/var/cache
                                          Archived and active journals take up 944.1M in the file system.
                                          /opt/iobroker/backups:
                                          4.0K	/opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          20M	/opt/iobroker/iobroker-data/
                                          14M	/opt/iobroker/iobroker-data/files
                                          13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                          6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                          3.0M	/opt/iobroker/iobroker-data/objects.jsonl
                                          2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                                          1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                                          1.5M	/opt/iobroker/iobroker-data/states.jsonl
                                          USB-Devices by-id:
                                          *** NodeJS-Installation ***
                                          /usr/bin/npm 		10.2.3
                                          /usr/bin/npx 		10.2.3
                                          nodejs:
                                            Installed: 18.19.0-1nodesource1
                                            Candidate: 18.19.0-1nodesource1
                                            Version table:
                                           *** 18.19.0-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                                  100 /var/lib/dpkg/status
                                               18.18.2-1nodesource1 1001
                                               18.18.1-1nodesource1 1001
                                               18.18.0-1nodesource1 1001
                                               18.17.1-1nodesource1 1001
                                               18.17.0-1nodesource1 1001
                                               18.16.1-1nodesource1 1001
                                               18.16.0-1nodesource1 1001
                                               18.15.0-1nodesource1 1001
                                               18.14.2-1nodesource1 1001
                                               18.14.1-1nodesource1 1001
                                               18.14.0-1nodesource1 1001
                                               18.13.0-1nodesource1 1001
                                               18.12.0-1nodesource1 1001
                                               18.11.0-1nodesource1 1001
                                               18.10.0-1nodesource1 1001
                                               18.9.1-1nodesource1 1001
                                               18.9.0-1nodesource1 1001
                                               18.8.0-1nodesource1 1001
                                               18.7.0-1nodesource1 1001
                                               18.6.0-1nodesource1 1001
                                               18.5.0-1nodesource1 1001
                                               18.4.0-1nodesource1 1001
                                               18.3.0-1nodesource1 1001
                                               18.2.0-1nodesource1 1001
                                               18.1.0-1nodesource1 1001
                                               18.0.0-1nodesource1 1001
                                               12.22.12~dfsg-1~deb11u4 500
                                                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                          No problems detected
                                          Errors in npm tree:
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          At least one iobroker host is running.
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          js-controller: 	5.0.17
                                          admin: 		6.12.0
                                          javascript: 	"javascript" not found
                                          Adapters from github: 	0
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                          + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                                          + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
                                          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                          + system.adapter.backitup.1               : backitup              : raspberrypi                              -  enabled
                                          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                          + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                                          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                                          + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                                          + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                          + system.adapter.hs100.0                  : hs100                 : iobroker                                 -  enabled
                                            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                                            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
                                          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 10.10.12.2
                                            system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                                          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                          + system.adapter.pushbullet.0             : pushbullet            : iobroker                                 -  enabled
                                          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                                          + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                                          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                                            system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 - disabled
                                          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                          + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 10.10.12.108, run as: admin
                                            system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                                          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                            system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
                                          + system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 -  enabled
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                                            system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
                                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                                            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                                            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
                                          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                                          + system.adapter.zigbee.1                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyS0
                                          + instance is alive
                                          ioBroker-Repositories
                                          live-beta     :  http://iobroker.live/repo/sources-dist-latest.json
                                          live-stable   : http://iobroker.live/repo/sources-dist.json
                                          Installed ioBroker-Instances
                                          Used repository: stable
                                          Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                                          Controller "js-controller": 5.0.17   , installed 5.0.17
                                          Adapter    "sonos"        : 3.0.0    , installed 2.3.1  [Updatable]
                                          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                          Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
                                          Objects and States
                                          Objects: 	49939
                                          States: 	48566
                                          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                                          Reading package lists...
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          324144     19766/sshd: /usr/sb
                                          tcp6       0      0 :::8088                 :::*                    LISTEN      1001       338076     22576/io.terminal.0
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          324146     19766/sshd: /usr/sb
                                          udp        0      0 0.0.0.0:43478           0.0.0.0:*                           108        11153      381/avahi-daemon: r
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13777      583/dhcpcd
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11151      381/avahi-daemon: r
                                          udp6       0      0 :::60601                :::*                                108        11154      381/avahi-daemon: r
                                          udp6       0      0 :::5353                 :::*                                108        11152      381/avahi-daemon: r
                                          2024-01-09 11:38:34.586  - info: host.raspberrypi iobroker host.raspberrypi Adapter "system.adapter.backitup.1" is started
                                          2024-01-09 11:38:34.620  - info: host.raspberrypi "system.adapter.backitup.1" enabled
                                          2024-01-09 11:38:35.227  - info: host.raspberrypi instance system.adapter.backitup.1 started with pid 23057
                                          2024-01-09 11:38:35.799  - info: host.raspberrypi iobroker exit 0
                                          2024-01-09 11:38:41.054  - info: backitup.1 (23057) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
                                          2024-01-09 11:43:24.267  - info: host.raspberrypi iobroker upgrade discovery@4.2.0
                                          2024-01-09 11:43:32.337  - info: host.raspberrypi iobroker Update discovery from @3.1.0 to @4.2.0
                                          2024-01-09 11:43:34.573  - info: host.raspberrypi iobroker NPM version: 10.2.3
                                          2024-01-09 11:43:34.576  - info: host.raspberrypi iobroker Installing iobroker.discovery@4.2.0... (System call)
                                          2024-01-09 11:43:53.880  - info: host.raspberrypi iobroker
                                          2024-01-09 11:43:53.882  - info: host.raspberrypi iobroker added 3 packages, removed 32 packages, and changed 15 packages in 17s
                                          2024-01-09 11:43:53.885  - info: host.raspberrypi iobroker
                                          2024-01-09 11:43:53.888  - info: host.raspberrypi iobroker 55 packages are looking for funding  run `npm fund` for details
                                          2024-01-09 11:43:54.533  - info: host.raspberrypi iobroker upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                          2024-01-09 11:43:54.577  - info: host.raspberrypi iobroker upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                          2024-01-09 11:43:54.634  - info: host.raspberrypi iobroker upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                          2024-01-09 11:43:54.695  - info: host.raspberrypi iobroker upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                          2024-01-09 11:43:54.727  - info: host.raspberrypi iobroker upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                          2024-01-09 11:43:54.765  - info: host.raspberrypi iobroker upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                          2024-01-09 11:43:54.787  - info: host.raspberrypi iobroker upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                          2024-01-09 11:43:55.947  - info: host.raspberrypi iobroker exit 0
                                          2024-01-09 11:47:21.075  - error: zigbee.1 (22804) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                                          2024-01-09 11:47:21.255  - info: zigbee.1 (22804) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
                                          2024-01-09 11:47:37.991  - error: zigbee.1 (22804) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                                          2024-01-09 11:47:38.235  - info: zigbee.1 (22804) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
                                          iob diag has finished.
                                            @bigchris
                                            Das ist soweit unauffällig. Den ein oder anderen Adapter würde ich allerdings als entbehrlich betrachten, insbesondere die Doubletten. Würde ich mir anschauen, insbesondere bei der schmalbrüstigen Hardware.
                                            3072
