    4. Javascript adapter stürzt ab
    • Glasfaser
      Glasfaser @Segway last edited by
      @segway
      Das ist das Ende von iob diag also die Summary
      Den Anfang wollte ich haben !
      Segway 2 Replies Last reply Reply Quote 0
      • Segway
        Segway @Glasfaser last edited by
        @glasfaser sagte in Javascript adapter stürzt ab:
        Ah ok .. bitte schön 🙂
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: IoB
               Icon name: computer-vm
                 Chassis: vm 🖴
          Virtualization: kvm
                  Kernel: Linux 6.1.0-17-amd64
            Architecture: x86-64
         Hardware Vendor: QEMU
          Hardware Model: Standard PC _i440FX + PIIX, 1996_
        Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
        model name	: Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         21:30:17 up 33 min,  2 users,  load average: 0.21, 0.27, 0.21
        CPU threads: 8
        *** Time and Time Zones ***
                       Local time: Tue 2024-01-09 21:30:17 CET
                   Universal time: Tue 2024-01-09 20:30:17 UTC
                         RTC time: Tue 2024-01-09 20:30:17
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        dirk
        /home/dirk
        dirk cdrom floppy sudo audio dip video plugdev netdev iobroker
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:            8.3G        3.3G        4.5G        569K        748M        5.0G
        Swap:           1.0G          0B        1.0G
        Total:          9.3G        3.3G        5.5G
                 7940 M total memory
                 3192 M used memory
                  333 M active memory
                 2994 M inactive memory
                 4298 M free memory
                  101 M buffer memory
                  612 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  3.9G     0  3.9G   0% /dev
        tmpfs          tmpfs     795M  556K  794M   1% /run
        /dev/sda1      ext4       14G  8.2G  4.9G  63% /
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     795M     0  795M   0% /run/user/1000
        [Tue Jan  9 20:57:15 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
        [Tue Jan  9 20:57:16 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        580M	/var/
        309M	/var/log
        184M	/var/lib
        180M	/var/log/journal/8616d69689854e3181b5e43ad3eb0818
        Archived and active journals take up 87.6M in the file system.
        /opt/iobroker/backups:
        257M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        750M	/opt/iobroker/iobroker-data/
        472M	/opt/iobroker/iobroker-data/files
        140M	/opt/iobroker/iobroker-data/backup-objects
        78M	/opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        67M	/opt/iobroker/iobroker-data/files/javascript.admin
        47M	/opt/iobroker/iobroker-data/objects.jsonl
        36M	/opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
        22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
        21M	/opt/iobroker/iobroker-data/states.json.bak
        USB-Devices by-id:
        /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100JNU-if03
        /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100JNU-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.19.0
        /usr/bin/node 		v18.19.0
        /usr/bin/npm 		10.2.3
        /usr/bin/npx 		10.2.3
        /usr/bin/corepack 	0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
         *** 18.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
                500 http://ftp.debian.org/debian bookworm/main amd64 Packages
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        Core adapters versions
        js-controller: 	5.0.17
        admin: 		6.12.0
        javascript: 	7.1.6
        Adapters from github: 	4
        Adapter State
        + system.adapter.admin.0                  : admin                 : IoB                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alias-manager.0          : alias-manager         : IoB                                      -  enabled
        + system.adapter.backitup.0               : backitup              : IoB                                      -  enabled
          system.adapter.bmw.0                    : bmw                   : IoB                                      - disabled
          system.adapter.daswetter.0              : daswetter             : IoB                                      -  enabled
          system.adapter.device-watcher.0         : device-watcher        : IoB                                      - disabled
          system.adapter.devices.0                : devices               : IoB                                      - disabled
          system.adapter.discovery.0              : discovery             : IoB                                      - disabled
        + system.adapter.doorbird.0               : doorbird              : IoB                                      -  enabled
          system.adapter.dwd.0                    : dwd                   : IoB                                      -  enabled
        + system.adapter.enocean.0                : enocean               : IoB                                      -  enabled
          system.adapter.flot.0                   : flot                  : IoB                                      - disabled
        + system.adapter.hm-rega.0                : hm-rega               : IoB                                      -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : IoB                                      -  enabled, port: 18701
        + system.adapter.hm-rpc.1                 : hm-rpc                : IoB                                      -  enabled, port: 12001
        + system.adapter.hm-rpc.2                 : hm-rpc                : IoB                                      -  enabled, port: 12010
          system.adapter.hue.0                    : hue                   : IoB                                      - disabled, port: 80
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : IoB                                      - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : IoB                                      - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoB                                      - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IoB                                      - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: IoB                                      - disabled
        + system.adapter.influxdb.0               : influxdb              : IoB                                      -  enabled, port: 8086
        + system.adapter.influxdb.1               : influxdb              : IoB                                      -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : IoB                                      -  enabled
        + system.adapter.javascript.0             : javascript            : IoB                                      -  enabled
          system.adapter.javascript.1             : javascript            : IoB                                      - disabled
          system.adapter.klipper-moonraker.0      : klipper-moonraker     : IoB                                      - disabled
        + system.adapter.linux-control.0          : linux-control         : IoB                                      -  enabled
          system.adapter.luftdaten.0              : luftdaten             : IoB                                      - disabled
          system.adapter.mobile.0                 : mobile                : IoB                                      - disabled
        + system.adapter.modbus.0                 : modbus                : IoB                                      -  enabled
          system.adapter.node-red.0               : node-red              : IoB                                      - disabled, port: 1880, bind: 0.0.0.0
        + system.adapter.nut.0                    : nut                   : IoB                                      -  enabled
          system.adapter.octoprint.0              : octoprint             : IoB                                      - disabled
        + system.adapter.parser.0                 : parser                : IoB                                      -  enabled
          system.adapter.pegelalarm.0             : pegelalarm            : IoB                                      -  enabled
          system.adapter.pi-hole.0                : pi-hole               : IoB                                      - disabled
        + system.adapter.ping.0                   : ping                  : IoB                                      -  enabled
          system.adapter.proxmox.0                : proxmox               : IoB                                      - disabled, port: 8006
          system.adapter.rickshaw.0               : rickshaw              : IoB                                      - disabled
        + system.adapter.shelly.0                 : shelly                : IoB                                      -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : IoB                                      -  enabled, port: 8087, bind: 192.168.40.7, run as: admin
          system.adapter.snmp.0                   : snmp                  : IoB                                      - disabled
        + system.adapter.sonoff.0                 : sonoff                : IoB                                      -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : IoB                                      -  enabled
          system.adapter.statistics.0             : statistics            : IoB                                      - disabled
          system.adapter.systeminfo.0             : systeminfo            : IoB                                      - disabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : IoB                                      -  enabled
        + system.adapter.telegram-menu.0          : telegram-menu         : IoB                                      -  enabled
        + system.adapter.telegram.0               : telegram              : IoB                                      -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : IoB                                      -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.terminal.0               : terminal              : IoB                                      -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.text2command.0           : text2command          : IoB                                      -  enabled
          system.adapter.tr-064.0                 : tr-064                : IoB                                      - disabled
          system.adapter.upnp.0                   : upnp                  : IoB                                      - disabled
          system.adapter.vis-bars.0               : vis-bars              : IoB                                      - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : IoB                                      - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : IoB                                      - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : IoB                                      - disabled
          system.adapter.vis-history.0            : vis-history           : IoB                                      - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoB                                      - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : IoB                                      -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : IoB                                      -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IoB                                      - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : IoB                                      - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : IoB                                      - disabled
          system.adapter.vis-metro.0              : vis-metro             : IoB                                      - disabled
          system.adapter.vis-players.0            : vis-players           : IoB                                      -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : IoB                                      - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoB                                      - disabled
          system.adapter.vis-weather.0            : vis-weather           : IoB                                      - disabled
          system.adapter.vis.0                    : vis                   : IoB                                      -  enabled
        + system.adapter.web.0                    : web                   : IoB                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.wiffi-wz.0               : wiffi-wz              : IoB                                      -  enabled
          system.adapter.worx.0                   : worx                  : IoB                                      - disabled
        + system.adapter.ws.0                     : ws                    : IoB                                      -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : IoB                                      -  enabled, port: /dev/ttyACM0
        + system.adapter.zigbee.1                 : zigbee                : IoB                                      -  enabled, port: tcp://192.168.40.115:6638
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): Stable (default)
        Installed ioBroker-Instances
        Used repository: Stable (default)
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "bmw"          : 2.5.7    , installed 2.5.7
        Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
        Adapter    "device-watcher": 2.9.6   , installed 2.9.6
        Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "hue"          : 3.10.1   , installed 3.10.1
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "modbus"       : 6.0.1    , installed 6.0.1
        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
        Adapter    "parser"       : 2.0.7    , installed 2.0.7
        Adapter    "pegelalarm"   : 1.3.2    , installed 1.3.2
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
        Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "snmp"         : 3.1.0    , installed 3.1.0
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "telegram-menu": 1.5.1    , installed 1.6.1
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
        Adapter    "worx"         : 2.3.4    , installed 2.3.4
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "zigbee"       : 1.9.7    , installed 1.9.6  [Updatable]
        Objects and States
        Objects: 	49236
        States: 	34083
        Hit:1 http://ftp.debian.org/debian bookworm InRelease
        Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://ftp.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14132      715/io.sonoff.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1974       690/io.shelly.0
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       1691       452/iobroker.js-con
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13500      1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14817      443/sshd: /usr/sbin
        tcp        0      0 192.168.40.7:8100       0.0.0.0:*               LISTEN      1001       18511      823/io.doorbird.0
        tcp        0      0 192.168.40.7:8087       0.0.0.0:*               LISTEN      1001       18276      1710/io.simple-api.
        tcp        0      0 192.168.40.7:8181       0.0.0.0:*               LISTEN      1001       18427      1817/io.wiffi-wz.0
        tcp        0      0 192.168.40.7:12001      0.0.0.0:*               LISTEN      1001       14969      604/io.hm-rpc.1
        tcp        0      0 192.168.40.7:12010      0.0.0.0:*               LISTEN      1001       14998      619/io.hm-rpc.2
        tcp        0      0 192.168.40.7:18701      0.0.0.0:*               LISTEN      1001       14012      589/io.hm-rpc.0
        tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      108        13849      433/redis-server 0.
        tcp6       0      0 :::111                  :::*                    LISTEN      0          14494      1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14819      443/sshd: /usr/sbin
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       18297      1740/io.terminal.0
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21416      1889/io.ws.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1725       471/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19383      1798/io.web.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1422       1/init
        udp6       0      0 :::111                  :::*                                0          13501      1/init
        2024-01-09 21:00:12.747  - info: dwd.0 (1984) State value to set for "dwd.0.warning2.begin" has to be type "string" but received type "number"
        2024-01-09 21:00:12.749  - info: dwd.0 (1984) State value to set for "dwd.0.warning2.end" has to be type "string" but received type "number"
        2024-01-09 21:00:12.758  - info: dwd.0 (1984) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-01-09 21:00:13.268  - info: host.IoB instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-01-09 21:00:16.055  - error: javascript.0 (514) script.js.UserDefined.Systeminfos.Speedtest: Speedtest konnte nicht ausgeführt werden! Error: Command failed: /usr/bin/speedtest -f json --accept-license --accept-gdpr -s 29806
        2024-01-09 21:06:04.576  - info: admin.0 (471) ==> Connected system.user.admin from ::ffff:192.168.40.204
        2024-01-09 21:06:14.094  - info: admin.0 (471) <== Disconnect system.user.admin from ::ffff:192.168.40.204 telegram-menu
        2024-01-09 21:15:00.014  - info: host.IoB instance system.adapter.pegelalarm.0 started with pid 4124
        2024-01-09 21:15:01.140  - info: pegelalarm.0 (4124) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v18.19.0, js-controller: 5.0.17
        2024-01-09 21:15:17.574  - info: pegelalarm.0 (4124) Terminated (NO_ERROR): Without reason
        2024-01-09 21:15:18.088  - info: host.IoB instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
        2024-01-09 21:17:00.013  - info: host.IoB instance system.adapter.dwd.0 started with pid 5180
        2024-01-09 21:17:01.146  - info: dwd.0 (5180) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
        2024-01-09 21:17:01.712  - info: dwd.0 (5180) State value to set for "dwd.0.warning1.begin" has to be type "string" but received type "number"
        2024-01-09 21:17:01.714  - info: dwd.0 (5180) State value to set for "dwd.0.warning1.end" has to be type "string" but received type "number"
        2024-01-09 21:17:01.722  - info: dwd.0 (5180) State value to set for "dwd.0.warning2.begin" has to be type "string" but received type "number"
        2024-01-09 21:17:01.724  - info: dwd.0 (5180) State value to set for "dwd.0.warning2.end" has to be type "string" but received type "number"
        2024-01-09 21:17:01.733  - info: dwd.0 (5180) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-01-09 21:17:02.247  - info: host.IoB instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-01-09 21:29:44.057  - warn: zigbee.0 (734) DeviceAvailability:Stopping to ping 0x842e14fffefed133 TS011F after 4 ping attempts
        2024-01-09 21:30:00.012  - info: host.IoB instance system.adapter.pegelalarm.0 started with pid 7304
        2024-01-09 21:30:01.078  - info: pegelalarm.0 (7304) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.pegelalarm, node: v18.19.0, js-controller: 5.0.17
        2024-01-09 21:30:24.285  - info: pegelalarm.0 (7304) Terminated (NO_ERROR): Without reason
        2024-01-09 21:30:24.799  - info: host.IoB instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
        • Segway
          Segway @Glasfaser last edited by Segway
          @glasfaser
          Müssen in dem Report unbedingt interne IPs mit Ports aufgelistet werden ? Finde ich jetzt nicht so pralle
          Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
          • Glasfaser
            Glasfaser @Segway last edited by Glasfaser
            @segway sagte in Javascript adapter stürzt ab:
            Da kann keiner was mit anfangen .das sind ganz normal Ports die jeder hier hat
            .. solange du nicht deine Tür zum Server von Außen zur Verfügung stellst !
            sieht aber erstmal gut aus , und du hast hier auch ein vergleich eingestellt , wenn es mal wieder kommt.
            Darauf habe ich auch geschaut :
            der macht hier im Forum schon den Umlauf das er ein Ram Fresser ist
              Thomas Braun Most Active @Segway last edited by
              interne IPs
              Und genau wo soll das Problem liegen? Sind interne IPs, damit kann von außen keiner was anfangen. Und wenn jemand in deinem Netz ist, dann ist die IP dein kleinstes Problem, die scannt der böse Hacker in Sekunden eh.
              Die IPs und die Ports sind drin, damit man doppelte Portbelegungen sieht.
              • Glasfaser
                • system.adapter.terminal.0 : terminal : IoB - enabled, port: 8088, bind: 0.0.0.0, run as: admin
                den braucht keiner , würde ich deinstallieren.
                • Segway
                  Deswegen ist er deaktiviert 🙂
                  @thomas-braun sagte in Javascript adapter stürzt ab:
                  Ich sehe immer das böse, dass man die Ports dann weiss und mit den Möglichkeiten heute intelligente Scans macht. Klar hat man meine Externe IP nicht aber was weiss ich was heute alles geht mit den Sniffern.
                  Vielleicht gibts intelligente die sowas auswerten....keene Ahnung
                  Aber keine Sorge alle Ports gesperrt bei mir und geht alles nur über VPN von aussen
                  Ich dachte nur an andere die gar nicht wissen was da alles so passiert.
                  Ok fliegt raus 🙂
                  Glasfaser Thomas Braun OliverIO 3 Replies Last reply Reply Quote 0
                  • Glasfaser
                    Deshalb :
                      @segway
                      Wenn du bereits jemanden Ungebetenen im Netz hast, dann macht der exakt die gleiche Abfrage wie in dem Skript und dann sieht der die exakt gleichen Informationen auch. Es darf halt niemand 'von extern' andocken können.
                      • Segway
                        Segway @Thomas Braun last edited by
                        @segway
                        Genauso muss es sein ja 🙂
                        Nur leider gibts viel zu viel Iobroker Instanzen bei denen das nicht der Fall ist 😞
                        • OliverIO
                          OliverIO @Segway last edited by OliverIO
                          du meinst so?
                          iob diag && curl https://ipinfo.io/ip
                            Aber auch spielt es dann keine Rolle mehr, ob die IPs und Ports aus dem internen Netzwerk in der Ausgabe von iob diag stehen.
                            • Glasfaser
                              Glasfaser @OliverIO last edited by
                              @oliverio sagte in Javascript adapter stürzt ab:
                              du meinst so?
                              Ich hoffe er postet diese Ausgabe nicht 🙂
                              OliverIO Segway 2 Replies Last reply Reply Quote 0
                              • OliverIO
                                OliverIO @Glasfaser last edited by
                                @glasfaser
                                95% der leute hier tippen/kopieren blind ab, was hier einer reinschreibt.
                                eine gewisse gefahr gibt es schon.
                                allerdings haben die meisten router ja gott sei dank auch eine firewall.
                                drin ist man dann noch lange nicht
                                Glasfaser 1 Reply Last reply Reply Quote 1
                                • Segway
                                  du meinst so?
                                  Steht ja nicht in den Hochkomma 🙂
                                  • Glasfaser
                                    kopieren blind ab,
                                    ... richtig ... und dahinter verbirgt sich meistens ein anderer Code 😉
                                    1533
