    4. Performance verbessern
      toki1973 @mcm1957 last edited by
      @mcm57 Device Watcher habe ich nun mal deaktiviert - scheint schon besser zu sein.
      Als nächstes dann auf Redis umstellen.
        arteck Developer Most Active @mcm1957 last edited by
        @mcm57 ist doch schon längst korrigiert
          toki1973 @Homoran last edited by
          Das diag sagt das node js nicht korrekt installiert ist:
          Recommended versions are nodejs 18.19.0 and npm 10.2.3
          *** nodejs is NOT correctly installed ***
          Wrong installation path detected. This needs to be fixed.
          Please check
          https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
          for more information on how to fix these errors.
          Damit bekomme ich keine neuer Version:
          sudo apt update
          sudo apt upgrade
            arteck Developer Most Active @toki1973 last edited by arteck
            @toki1973 sagte in Performance verbessern:
            Augen auf.. da stehen alle informationen
              toki1973 @arteck last edited by
              Die Verzeichnisse sind korrekt:
                                      v.2023-10-10
               Static hostname: iobroker
                     Icon name: computer-vm
                       Chassis: vm 🖴
                Virtualization: kvm
                        Kernel: Linux 6.1.0-16-amd64
                  Architecture: x86-64
               Hardware Vendor: QEMU
                Hardware Model: Standard PC _i440FX + PIIX, 1996_
              Firmware Version: rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org
              Installation:           kvm
              Kernel:                 x86_64
              Userland:               amd64
              Timezone:               Europe/Berlin (CET, +0100)
              User-ID:                1000
              X-Server:               false
              Boot Target:            graphical.target
              Pending OS-Updates:     0
              Pending iob updates:    0
              Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                      /usr/bin/node           v18.19.0
              /home/iobroker/.diag.sh: line 488: npm: command not found
              /home/iobroker/.diag.sh: line 489: npx: command not found
              /home/iobroker/.diag.sh: line 490: corepack: command not found
              Recommended versions are nodejs  Unable to enable Expiry Keyspace events from Redis Server: Connection is closed.
               Connection is closed. and npm
              Please check
              MEMORY:
              Mem:            6.3G        3.7G        1.4G        524K        1.5G        2.6G
              Swap:           1.0G        3.2M        1.0G
              Total:          7.4G        3.7G        2.4G
              Active iob-Instances:   35
              Active repo(s): stable
              ioBroker Core:          js-controller           5.0.17
                                      admin                   6.12.0
              Objects type: jsonl
              States  type: jsonl
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.web.1                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
              Objects:                118184
              States:                 91554
              Size of iob-Database:
              82M     /opt/iobroker/iobroker-data/objects.jsonl
              152M    /opt/iobroker/iobroker-data/states.jsonl
              • mcm1957
                mcm1957 @arteck last edited by
                @arteck
                a) schrieb ich GAB
                b) weiss ich nicht ob dieser user im latest unterwegs ist und den Performanceeinfluss gab es schon vor dem fehlerhaften Update mit der aktuellem stable - zumindest gab es es ein7ge (wenige) diesbezügliche Meldungen / Vermutungen. Da das testweise deaktivieren kaium Azfwand darstellt ist ein diesbezüglicher Test m.E. sinnvoll.
                Und ja
                Das fehlerhafte Update mit massivstem Einfluss wurde super rasch korrigiert. 1a Reaktion - besser gegrs nicht. Aber wie geschrueben betrifft das derzeit die latest Schiene.
                  Homoran Global Moderator Administrators @toki1973 last edited by Homoran
                  bitte eigenen Thread aufmachen, wenn nach lesen der angepinnten Ankündigungen noch fragen sind.
                  Die wichtigen Infos stehen auch nicht in der Summary.
                  EDIT: Ist ja schon dein Thread, sorry!
                  aber ich hatte ja nach full gefragt
                    Thomas Braun Most Active @toki1973 last edited by
                    Schon. Für nodejs und node jedenfalls. Dafür fehlt dir npm, npx und corepack komplett.
                    Da wirst du dir die dfsg-Version des Pakets 'nodejs' eingehandelt haben.
                    Siehe:
                    https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version-npm-fehlt
                    T 1 Reply Last reply Reply Quote 2
                      toki1973 @Thomas Braun last edited by
                      @thomas-braun Vielen Dank mal wieder! Auf diesem Weg wurde es repariert!
                      Das ist der Nachteil von regelmäßigen Updates 🙂
                        In dem Fall ist es aber kein 'Fehler' gewesen, denn dein Paketmanager hat genau das getan, was er tun soll: Die aktuellste Version die in den Repos bereitgestellt wird einspielen. Das die dfsg-Version nicht die für den ioBroker passende Variante darstellt kann der nicht wissen.
                          sunny9999 last edited by sunny9999
                          Hi an alle,
                          hab hier auch nochmal ein Thema bzgl. Performance.....mein System müsste anhand der Hardware und den in der VM gegebenen Ressourcen deutlich leistungsfähiger sein, der Aufruf z.b. der Objekte oder anderer Seiten im Browser ist manchmal sehr zäh......
                          Alles ist auf Redis am laufen ( Objekte und States)
                          Anbindung an die VM ist mit 10Gb
                          Iobroker VM auf ESXi 7 am laufen mit folgenden Specs :
                          Dual Socket System mit 16 Cores
                          16 GB Ram
                          Iobroker Diag Full Summary sieht wie folgt aus :
                                                  v.2023-10-10
                           Static hostname: IOBROKER-MASTER
                                   Chassis: vm 🖴
                            Virtualization: vmware
                                    Kernel: Linux 6.1.0-17-amd64
                           Hardware Vendor: VMware, Inc.
                            Hardware Model: VMware Virtual Platform
                          Firmware Version: 6.00
                          Installation:           vmware
                          Kernel:                 x86_64
                          Userland:               amd64
                          User-ID:                1000
                          X-Server:               false
                          Pending OS-Updates:     17
                          Pending iob updates:    1
                                                  /usr/bin/npm            10.2.3
                                                  /usr/bin/npx            10.2.3
                                                  /usr/bin/corepack       0.22.0
                          MEMORY:
                          Mem:             12G        8.0G        1.2G        3.2M        3.6G        4.5G
                          Swap:           2.1G        285M        1.9G
                          Total:           14G        8.3G        3.0G
                          Active iob-Instances:   76
                                                  admin                   6.13.16
                          At least one iobroker host is running.
                          Objects type: redis
                          States  type: redis
                          + system.adapter.admin.0                  : admin                 : IOBROKER-MASTER                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.web.0                    : web                   : IOBROKER-MASTER                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + system.adapter.webcal.0                 : webcal                : IOBROKER-MASTER                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          Objects:                56453
                          States:                 48398
                          46M     /opt/iobroker/iobroker-data/objects.jsonl
                          22M     /opt/iobroker/iobroker-data/objects.json.migrated
                          22M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                          612K    /opt/iobroker/iobroker-data/states.json
                          260K    /opt/iobroker/iobroker-data/states.json.bak
                          Paar krumme "Hunde" mit drin, aber daran kann es ja nicht liegen oder ?
                          BTW : Kann nicht das volle Log posten , da immer ne Meldung kommt " payload too large" .......komisch, Server überlastet ?
                          Danke für ne helping hand.......
                          Sunny
                            Thomas Braun Most Active @sunny9999 last edited by Thomas Braun
                            @sunny9999
                            Naja, 76 laufende Instanzen halten auch vermeintliche Dickschiffe auf Trab. Stichwort i/o-Last.
                              sunny9999 @Thomas Braun last edited by
                              Ja ist mir bewusst.....
                              was wäre Deine Empfehlung ?
                              Ram Auslastung und CPU Auslastung auf dem ESXI sieht eigentlich alles gut aus, da ist nichts am Limit...
                              Idee ?
                              Grüße und Danke
                              Sunny
                                Homoran Global Moderator Administrators @sunny9999 last edited by
                                @sunny9999 sagte in Performance verbessern:
                                und bei top?
                                  sunny9999 @Homoran last edited by
                                  Full Diag sieht so aus :
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                           Chassis: vm 🖴
                                  model name      : Intel(R) Xeon(R) Gold 6152 CPU @ 2.10GHz
                                  Docker          : false
                                  Virtualization  : vmware
                                  Kernel          : x86_64
                                  Userland        : amd64
                                  Systemuptime and Load:
                                   18:54:06 up 25 days, 10:19,  1 user,  load average: 0.28, 0.29, 0.34
                                  CPU threads: 16
                                  *** Time and Time Zones ***
                                                 Local time: Tue 2024-02-06 18:54:07 CET
                                             Universal time: Tue 2024-02-06 17:54:07 UTC
                                                   RTC time: Tue 2024-02-06 17:54:07
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** User and Groups ***
                                  debian
                                  /home/debian
                                  debian cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner iobroker
                                  *** X-Server-Setup ***
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:             12G        8.2G        1.2G        3.2M        3.4G        4.4G
                                  Swap:           2.1G        296M        1.8G
                                  Total:           14G        8.5G        3.1G
                                          11926 M total memory
                                           7776 M used memory
                                           1345 M active memory
                                           8112 M inactive memory
                                           1179 M free memory
                                            403 M buffer memory
                                           2883 M swap cache
                                           2043 M total swap
                                            283 M used swap
                                           1760 M free swap
                                  *** FAILED SERVICES ***
                                    UNIT            LOAD   ACTIVE SUB    DESCRIPTION
                                  * apcupsd.service loaded failed failed UPS power management daemon
                                  LOAD   = Reflects whether the unit definition was properly loaded.
                                  ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                  SUB    = The low-level unit activation state, values depend on unit type.
                                  1 loaded units listed.
                                  *** FILESYSTEM ***
                                  Filesystem                                                               Type      Size  Used Avail Use% Mounted on
                                  udev        devtmpfs  5.8G     0  5.8G   0% /dev
                                  tmpfs        tmpfs     1.2G  1.5M  1.2G   1% /run
                                  /dev/mapper/debian10--vg-root                                            ext4      107G   43G   59G  42% /
                                  tmpfs        tmpfs     5.9G     0  5.9G   0% /dev/shm
                                  tmpfs        tmpfs     5.0M     0  5.0M   0% /run/lock
                                  /dev/sda1        ext2      234M  128M   95M  58% /boot
                                  /dev/mapper/debian10--vg-tmp                                             ext4      1.2G  144K  1.1G   1% /tmp
                                  /dev/mapper/debian10--vg-home                                            ext4       70G  8.6G   58G  13% /home
                                  /dev/mapper/debian10--vg-var                                             ext4      6.4G  1.9G  4.1G  32% /var
                                  tmpfs        tmpfs     1.2G   68K  1.2G   1% /run/user/116
                                  192.168.10.47:/volume1/IOBROKER                                          nfs4      2.7T  1.6T  1.1T  61% /mnt/IOBROKERDATA
                                  192.168.10.47:/volume2/Backup                                            nfs4      1.9T  499G  1.4T  26% /mnt/BACKUP
                                  192.168.10.47:/volume2/photo/PROJEKTBILDER/Situationen/Diashow-MonitorPi nfs4      1.9T  499G  1.4T  26% /mnt/photosyno
                                  tmpfs        tmpfs     1.2G   60K  1.2G   1% /run/user/1000
                                  [Fri Jan 12 08:34:47 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Fri Jan 12 08:34:48 2024] EXT4-fs (dm-0): re-mounted. Quota mode: none.
                                  [Fri Jan 12 08:34:49 2024] EXT4-fs (sda1): mounting ext2 file system using the ext4 subsystem
                                  [Fri Jan 12 08:34:49 2024] EXT4-fs (sda1): mounted filesystem without journal. Quota mode: none.
                                  [Fri Jan 12 08:34:49 2024] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Fri Jan 12 08:34:49 2024] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Fri Jan 12 08:34:49 2024] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Quota mode: none.
                                  TARGET              SOURCE        FSTYPE OPTIONS
                                  /                   /dev/mapper/debian10--vg-root                                            ext4   rw,relatime,errors=remount-ro
                                  |-/boot             /dev/sda1        ext2   rw,relatime
                                  |-/tmp              /dev/mapper/debian10--vg-tmp                                             ext4   rw,relatime
                                  |-/home             /dev/mapper/debian10--vg-home                                            ext4   rw,relatime
                                  |-/var              /dev/mapper/debian10--vg-var                                             ext4   rw,relatime
                                  |-/mnt/IOBROKERDATA 192.168.10.47:/volume1/IOBROKER                                          nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
                                  |-/mnt/BACKUP       192.168.10.47:/volume2/Backup                                            nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
                                  `-/mnt/photosyno    192.168.10.47:/volume2/photo/PROJEKTBILDER/Situationen/Diashow-MonitorPi nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
                                  /var:
                                  1.9G    /var/
                                  1.5G    /var/lib
                                  525M    /var/lib/grafana
                                  520M    /var/lib/grafana/plugins
                                  516M    /var/lib/grafana/plugins/grafana-image-renderer
                                  Archived and active journals take up 11.1M in the file system.
                                  /opt/iobroker/backups:
                                  1.8G    /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  31G     /opt/iobroker/iobroker-data/
                                  30G     /opt/iobroker/iobroker-data/history
                                  947M    /opt/iobroker/iobroker-data/files
                                  195M    /opt/iobroker/iobroker-data/backup-objects
                                  176M    /opt/iobroker/iobroker-data/files/vis-2
                                  35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                  33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                                  24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                  24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                                  USB-Devices by-id:
                                  *** NodeJS-Installation ***
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  nodejs:
                                    Installed: 18.19.0-1nodesource1
                                    Candidate: 18.19.0-1nodesource1
                                    Version table:
                                       18.19.0+dfsg-6~deb12u1 500
                                          500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                                   *** 18.19.0-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                          100 /var/lib/dpkg/status
                                       18.18.2-1nodesource1 1001
                                       18.18.1-1nodesource1 1001
                                       18.18.0-1nodesource1 1001
                                       18.17.1-1nodesource1 1001
                                       18.17.0-1nodesource1 1001
                                       18.16.1-1nodesource1 1001
                                       18.16.0-1nodesource1 1001
                                       18.15.0-1nodesource1 1001
                                       18.14.2-1nodesource1 1001
                                       18.14.1-1nodesource1 1001
                                       18.14.0-1nodesource1 1001
                                       18.13.0+dfsg1-1 500
                                          500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                       18.13.0-1nodesource1 1001
                                       18.12.0-1nodesource1 1001
                                       18.11.0-1nodesource1 1001
                                       18.10.0-1nodesource1 1001
                                       18.9.1-1nodesource1 1001
                                       18.9.0-1nodesource1 1001
                                       18.8.0-1nodesource1 1001
                                       18.7.0-1nodesource1 1001
                                       18.6.0-1nodesource1 1001
                                       18.5.0-1nodesource1 1001
                                       18.4.0-1nodesource1 1001
                                       18.3.0-1nodesource1 1001
                                       18.2.0-1nodesource1 1001
                                       18.1.0-1nodesource1 1001
                                       18.0.0-1nodesource1 1001
                                  No problems detected
                                  Errors in npm tree:
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: redis
                                  States  type: redis
                                  Core adapters versions
                                  js-controller:  5.0.17
                                  admin:          6.13.16
                                  javascript:     7.1.6
                                  Adapters from github:   21
                                  Adapter State
                                  + system.adapter.alarm.0                  : alarm                 : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.alexa2.0                 : alexa2                : IOBROKER-MASTER                          -  enabled
                                    system.adapter.alias-manager.0          : alias-manager         : IOBROKER-MASTER                          -  enabled
                                    system.adapter.apcups.0                 : apcups                : IOBROKER-MASTER                          - disabled
                                  + system.adapter.asterisk.0               : asterisk              : IOBROKER-MASTER                          -  enabled, port: 5038
                                  + system.adapter.backitup.0               : backitup              : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.backitup.1               : backitup              : IOBROKER-SLAVE                           -  enabled
                                  + system.adapter.chromecast.0             : chromecast            : IOBROKER-MASTER                          -  enabled
                                    system.adapter.daswetter.0              : daswetter             : IOBROKER-MASTER                          -  enabled
                                    system.adapter.device-watcher.0         : device-watcher        : IOBROKER-MASTER                          - disabled
                                    system.adapter.devices.0                : devices               : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.discovery.0              : discovery             : IOBROKER-MASTER                          -  enabled
                                    system.adapter.dwd.0                    : dwd                   : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.echarts.0                : echarts               : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.email.0                  : email                 : IOBROKER-MASTER                          -  enabled
                                    system.adapter.feiertage.0              : feiertage             : IOBROKER-MASTER                          -  enabled
                                    system.adapter.flot.0                   : flot                  : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.fullybrowser.0           : fullybrowser          : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.govee-app.0              : govee-app             : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.ham.0                    : ham                   : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.hass.0                   : hass                  : IOBROKER-MASTER                          -  enabled, port: 8123
                                    system.adapter.heatingcontrol.0         : heatingcontrol        : IOBROKER-MASTER                          - disabled
                                    system.adapter.hiob.0                   : hiob                  : IOBROKER-MASTER                          - disabled
                                  + system.adapter.history.0                : history               : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.hm-rega.0                : hm-rega               : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.hm-rpc.0                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
                                  + system.adapter.hm-rpc.1                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
                                  + system.adapter.hm-rpc.2                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
                                  + system.adapter.hue.0                    : hue                   : IOBROKER-MASTER                          -  enabled, port: 80
                                    system.adapter.husq-automower.0         : husq-automower        : IOBROKER-MASTER                          - disabled
                                    system.adapter.ical.0                   : ical                  : IOBROKER-MASTER                          -  enabled
                                    system.adapter.ical.1                   : ical                  : IOBROKER-MASTER                          -  enabled
                                    system.adapter.ical.2                   : ical                  : IOBROKER-MASTER                          -  enabled
                                    system.adapter.icons-material-png.0     : icons-material-png    : IOBROKER-MASTER                          -  enabled
                                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : IOBROKER-MASTER                          -  enabled
                                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IOBROKER-MASTER                          -  enabled
                                    system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.influxdb.0               : influxdb              : IOBROKER-MASTER                          -  enabled, port: 8086
                                    system.adapter.info.0                   : info                  : IOBROKER-MASTER                          - disabled
                                  + system.adapter.javascript.0             : javascript            : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.kodi.0                   : kodi                  : IOBROKER-MASTER                          -  enabled, port: 9090
                                  + system.adapter.linkeddevices.0          : linkeddevices         : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.linktap.0                : linktap               : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.linux-control.0          : linux-control         : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IOBROKER-MASTER                          -  enabled, port: 54321
                                  + system.adapter.mqtt-client.0            : mqtt-client           : IOBROKER-MASTER                          -  enabled, port: 1883, bind: 0.0.0.0
                                  + system.adapter.mqtt.0                   : mqtt                  : IOBROKER-MASTER                          -  enabled, port: 1883, bind: 0.0.0.0
                                    system.adapter.mytime.0                 : mytime                : IOBROKER-MASTER                          - disabled
                                  + system.adapter.net-tools.0              : net-tools             : IOBROKER-MASTER                          -  enabled
                                    system.adapter.netatmo-crawler.0        : netatmo-crawler       : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.node-red.0               : node-red              : IOBROKER-MASTER                          -  enabled, port: 1880, bind: 0.0.0.0
                                  + system.adapter.notificationforandroidtv.0: notificationforandroidtv: IOBROKER-MASTER                          -  enabled
                                  + system.adapter.nuki-extended.0          : nuki-extended         : IOBROKER-MASTER                          -  enabled
                                    system.adapter.oasecontrol.0            : oasecontrol           : IOBROKER-MASTER                          - disabled
                                  + system.adapter.ocpp.0                   : ocpp                  : IOBROKER-MASTER                          -  enabled, port: 9220
                                  + system.adapter.onkyo.0                  : onkyo                 : IOBROKER-MASTER                          -  enabled
                                    system.adapter.onvif.0                  : onvif                 : IOBROKER-MASTER                          - disabled
                                  + system.adapter.ping.0                   : ping                  : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.pushover.0               : pushover              : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.reolink.0                : reolink               : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.robonect.0               : robonect              : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.samsung.0                : samsung               : IOBROKER-MASTER                          -  enabled
                                    system.adapter.samsung_tizen.0          : samsung_tizen         : IOBROKER-MASTER                          - disabled, port: 8002
                                  + system.adapter.sayit.0                  : sayit                 : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.scenes.0                 : scenes                : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.scheduler.0              : scheduler             : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.shelly.0                 : shelly                : IOBROKER-MASTER                          -  enabled, port: 1882, bind: 0.0.0.0
                                    system.adapter.shuttercontrol.0         : shuttercontrol        : IOBROKER-MASTER                          - disabled
                                  + system.adapter.simple-api.0             : simple-api            : IOBROKER-MASTER                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  + system.adapter.slideshow.0              : slideshow             : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.smartcontrol.0           : smartcontrol          : IOBROKER-MASTER                          -  enabled
                                    system.adapter.smartmeter.0             : smartmeter            : IOBROKER-SLAVE                           - disabled
                                  + system.adapter.smartthings.0            : smartthings           : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.sonoff.0                 : sonoff                : IOBROKER-MASTER                          -  enabled, port: 1885, bind: 0.0.0.0
                                  + system.adapter.sonos.0                  : sonos                 : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.sourceanalytix.0         : sourceanalytix        : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.synology.0               : synology              : IOBROKER-MASTER                          -  enabled, port: 5000
                                  + system.adapter.tahoma.0                 : tahoma                : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.tankerkoenig.0           : tankerkoenig          : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.telegram.0               : telegram              : IOBROKER-MASTER                          -  enabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.telegram.1               : telegram              : IOBROKER-MASTER                          -  enabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.telegram.2               : telegram              : IOBROKER-MASTER                          -  enabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.text2command.0           : text2command          : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.text2command.1           : text2command          : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.time-switch.0            : time-switch           : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.trashschedule.0          : trashschedule         : IOBROKER-MASTER                          -  enabled
                                    system.adapter.trashschedule.1          : trashschedule         : IOBROKER-MASTER                          - disabled
                                  + system.adapter.unifi.0                  : unifi                 : IOBROKER-MASTER                          -  enabled
                                    system.adapter.upnp.0                   : upnp                  : IOBROKER-MASTER                          - disabled
                                  + system.adapter.vaillant.0               : vaillant              : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.vis-2.0                  : vis-2                 : IOBROKER-MASTER                          -  enabled
                                    system.adapter.vis-bars.0               : vis-bars              : IOBROKER-MASTER                          -  enabled
                                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : IOBROKER-MASTER                          -  enabled
                                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : IOBROKER-MASTER                          -  enabled
                                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : IOBROKER-MASTER                          -  enabled
                                    system.adapter.vis-google-fonts.0       : vis-google-fonts      : IOBROKER-MASTER                          -  enabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IOBROKER-MASTER                          -  enabled
                                    system.adapter.vis-icontwo.0            : vis-icontwo           : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.vis-inventwo.0           : vis-inventwo          : IOBROKER-MASTER                          -  enabled
                                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IOBROKER-MASTER                          -  enabled
                                    system.adapter.vis-justgage.0           : vis-justgage          : IOBROKER-MASTER                          -  enabled
                                    system.adapter.vis-material-advanced.0  : vis-material-advanced : IOBROKER-MASTER                          -  enabled
                                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : IOBROKER-MASTER                          -  enabled
                                    system.adapter.vis-metro.0              : vis-metro             : IOBROKER-MASTER                          - disabled
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : IOBROKER-MASTER                          -  enabled
                                    system.adapter.vis-weather.0            : vis-weather           : IOBROKER-MASTER                          -  enabled
                                    system.adapter.vis.0                    : vis                   : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.vw-connect.0             : vw-connect            : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.vw-connect.1             : vw-connect            : IOBROKER-MASTER                          -  enabled
                                    system.adapter.weatherunderground.0     : weatherunderground    : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.yahka.0                  : yahka                 : IOBROKER-MASTER                          -  enabled
                                  + system.adapter.zigbee.1                 : zigbee                : IOBROKER-SLAVE                           -  enabled, port: /dev/ttyACM0
                                  + system.adapter.zigbee.2                 : zigbee                : IOBROKER-MASTER                          -  enabled, port: tcp://192.168.10.24:6638
                                  + instance is alive
                                  ioBroker-Repositories
                                  Installed ioBroker-Instances
                                  Used repository: stable
                                  Adapter    "alarm"        : 3.6.0    , installed 3.6.0
                                  Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                                  Adapter    "apcups"       : 1.0.15   , installed 1.0.15
                                  Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
                                  Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                                  Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
                                  Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                                  Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                  Adapter    "device-watcher": 2.9.6   , installed 2.9.6
                                  Adapter    "doorio"       : 2.1.4    , installed 2.1.4
                                  Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                  Adapter    "email"        : 1.2.2    , installed 1.2.2
                                  Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                                  Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
                                  Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                  Adapter    "hass"         : 1.4.0    , installed 1.4.0
                                  Adapter    "heatingcontrol": 2.12.3  , installed 2.12.3
                                  Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                  Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
                                  Adapter    "hue"          : 3.10.2   , installed 3.10.2
                                  Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                                  Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                  Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                                  Controller "js-controller": 5.0.17   , installed 5.0.17
                                  Adapter    "kodi"         : 3.0.0    , installed 3.0.0
                                  Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                                  Adapter    "linktap"      : 0.3.0    , installed 0.3.0
                                  Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                  Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
                                  Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                                  Adapter    "mpd"          : 1.1.1    , installed 1.1.1
                                  Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                                  Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
                                  Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                  Adapter    "node-red"     : 5.1.0    , installed 5.1.0
                                  Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                                  Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                                  Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
                                  Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                                  Adapter    "onvif"        : 1.1.1    , installed 1.1.1
                                  Adapter    "paw"          : 0.3.2    , installed 0.3.2
                                  Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                                  Adapter    "reolink"      : 1.0.3    , installed 1.0.3
                                  Adapter    "robonect"     : 1.3.4    , installed 1.3.4
                                  Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                                  Adapter    "samsung_tizen": 1.0.0    , installed 1.0.0
                                  Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                                  Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
                                  Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                  Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
                                  Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                                  Adapter    "smartthings"  : 0.0.4    , installed 0.1.1
                                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                  Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                                  Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                                  Adapter    "synology"     : 3.0.1    , installed 3.0.1
                                  Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
                                  Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                                  Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                  Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                                  Adapter    "unifi"        : 0.6.7    , installed 0.6.7
                                  Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                                  Adapter    "vaillant"     : 0.1.2    , installed 0.4.0
                                  Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
                                  Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
                                  Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
                                  Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                  Adapter    "volumio"      : 0.1.2    , installed 0.1.3
                                  Adapter    "vw-connect"   : 0.0.67   , installed 0.5.1
                                  Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                                  Adapter    "web"          : 6.2.3    , installed 6.2.3
                                  Adapter    "webcal"       : 1.3.0    , installed 1.1.0  [Updatable]
                                  Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                  Adapter    "ws"           : 2.5.10   , installed 2.5.10
                                  Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                  Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                                  Objects and States
                                  Objects:        56453
                                  States:         48398
                                  W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
                                  W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
                                  W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
                                  W: Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
                                  W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
                                  W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
                                  W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
                                  Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                                  Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                  Hit:4 https://repos.influxdata.com/debian stable InRelease
                                  Hit:5 https://apt.grafana.com stable InRelease
                                  Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Reading package lists...
                                  Pending Updates: 17
                                  *** Listening Ports ***
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          65         1/init
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16086      969/sshd: /usr/sbin
                                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       74578738   2501883/node-red
                                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       74583578   2502418/io.shelly.0
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       74587586   2502993/io.mqtt.0
                                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       74587587   2502993/io.mqtt.0
                                  tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       74591520   2502919/io.sonoff.0
                                  tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       75512632   2690492/nc
                                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          73118439   2210884/cupsd
                                  tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      121        18592      1008/asterisk
                                  tcp        0      0 192.168.10.16:2001      0.0.0.0:*               LISTEN      1001       74582911   2502463/io.hm-rpc.0
                                  tcp        0      0 192.168.10.16:2010      0.0.0.0:*               LISTEN      1001       74595393   2502564/io.hm-rpc.1
                                  tcp        0      0 192.168.10.16:9292      0.0.0.0:*               LISTEN      1001       74583000   2502888/io.hm-rpc.2
                                  tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      118        74603472   2507490/redis-serve
                                  tcp        0      0 127.0.0.1:44949         0.0.0.0:*               LISTEN      122        42316113   250044/plugin_start
                                  tcp6       0      0 :::111                  :::*                    LISTEN      0          1711       1/init
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          16088      969/sshd: /usr/sbin
                                  tcp6       0      0 :::9220                 :::*                    LISTEN      1001       74585814   2503615/io.ocpp.0
                                  tcp6       0      0 :::51989                :::*                    LISTEN      1001       74594491   2502433/io.nuki-ext
                                  tcp6       0      0 :::35615                :::*                    LISTEN      1001       74591906   2504296/io.yahka.0
                                  tcp6       0      0 :::3000                 :::*                    LISTEN      122        42309336   249599/grafana
                                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          73118438   2210884/cupsd
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       74592281   2501830/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       74598671   2504408/io.web.0
                                  tcp6       0      0 :::8086                 :::*                    LISTEN      998        22728      1022/influxd
                                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       74591795   2503730/io.simple-a
                                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15910      1/init
                                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          73118444   2210886/cups-browse
                                  udp        0      0 0.0.0.0:42823           0.0.0.0:*                           111        23664      879/avahi-daemon: r
                                  udp        0      0 192.168.10.16:1905      0.0.0.0:*                           1001       75515310   2502935/io.sonos.0
                                  udp        0      0 0.0.0.0:35072           0.0.0.0:*                           121        22715      1008/asterisk
                                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       74596509   2503080/io.mihome-v
                                  udp        0      0 0.0.0.0:4569            0.0.0.0:*                           121        18609      1008/asterisk
                                  udp        0      0 0.0.0.0:5060            0.0.0.0:*                           121        18610      1008/asterisk
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       74592712   2503132/io.chromeca
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           111        23662      879/avahi-daemon: r
                                  udp6       0      0 :::111                  :::*                                0          22563      1/init
                                  udp6       0      0 :::50118                :::*                                111        23665      879/avahi-daemon: r
                                  udp6       0      0 :::54441                :::*                                121        22716      1008/asterisk
                                  udp6       0      0 :::5353                 :::*                                111        23663      879/avahi-daemon: r
                                  2024-02-06 18:54:18.958  - info: ocpp.0 (2503615) Received Status Notification from "/2203020632A.2": Available
                                  2024-02-06 18:54:18.964  - info: sourceanalytix.0 (2503761) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.2.lastTransactionConsumption
                                  2024-02-06 18:54:18.966  - info: sourceanalytix.0 (2503761) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.2.transactionEndMeter
                                  2024-02-06 18:54:19.652  - info: ocpp.0 (2503615) Requesting StatusNotification from "/2203020632A"
                                  2024-02-06 18:54:19.769  - debug: ocpp.0 (2503615) {"connectorId":1,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T17:54:19.7116565Z","commandOcpp":"StatusNotification"}
                                  2024-02-06 18:54:19.770  - info: ocpp.0 (2503615) Received Status Notification from "/2203020632A.1": Available
                                  2024-02-06 18:54:19.929  - debug: ocpp.0 (2503615) {"connectorId":2,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T17:54:19.7116827Z","commandOcpp":"StatusNotification"}
                                  2024-02-06 18:54:19.930  - info: ocpp.0 (2503615) Received Status Notification from "/2203020632A.2": Available
                                  2024-02-06 18:54:20.726  - info: ocpp.0 (2503615) Requesting MeterValues from "/2203020632A"
                                  2024-02-06 18:54:21.798  - info: ocpp.0 (2503615) Sending GetConfiguration to "/2203020632A"
                                  2024-02-06 18:54:21.937  - debug: ocpp.0 (2503615) Received configuration from /2203020632A: {"configurationKey":[{"key":"NumberOfConnectors","readonly":true,"value":"2"},{"key":"DownLight","readonly":false,"value":"True"},{"key":"Dimmer","readonly":false,"value":"Low"},{"key":"Schuko","readonly":true,"value":"Off"},{"key":"DefaultIdTag","readonly":false,"value":"999999"},{"key":"DefaultIdTagEnabled","readonly":false,"value":"True"},{"key":"StopTransactionOnEVSideDisconnect","readonly":true,"value":"True"},{"key":"StopTransactionOnInvalidId","readonly":false,"value":"True"},{"key":"MeterValueSampleInterval","readonly":false,"value":"30"},{"key":"HeartbeatInterval","readonly":false,"value":"10"},{"key":"AuthorizeRemoteTxRequests","readonly":true,"value":"True"},{"key":"ClockAlignedDataInterval","readonly":false,"value":"0"},{"key":"ConnectionTimeOut","readonly":false,"value":"60"},{"key":"GetConfigurationMaxKeys","readonly":true,"value":"31"},{"key":"LocalAuthorizeOffline","readonly":false,"value":"True"},{"key":"LocalPreAuthorize","readonly":false,"value":"False"},{"key":"MeterValuesAlignedData","readonly":false,"value":""},{"key":"MeterValuesSampledData","readonly":false,"value":"Voltage,Current.Import,Energy.Active.Import.Register"},{"key":"ResetRetries","readonly":false,"value":"0"},{"key":"StopTxnAlignedData","readonly":false,"value":"False"},{"key":"StopTxnSampledData","readonly":false,"value":"False"},{"key":"TransactionMessageAttempts","readonly":false,"value":"0"},{"key":"TransactionMessageRetryInterval","readonly":false,"value":"0"},{"key":"UnlockConnectorOnEVSideDisconnect","readonly":false,"value":"False"},{"key":"ConnectorPhaseRotation","readonly":false,"value":"NotApplicable"},{"key":"SupportedFeatureProfiles","readonly":true,"value":"Core"},{"key":"AllowOfflineTxForUnknownId","readonly":false,"value":"False"},{"key":"AuthorizationCacheEnabled","readonly":false,"value":"True"},{"key":"AssignedCurrent","readonly":false,"value":"32.00;32.00"},{"key":"AuthorizationKey","readonly":false,"value":""},{"key":"SecurityProfile","readonly":false,"value":"0"}],"unknownKey":[]}
                                  2024-02-06 18:54:21.990  - info: ocpp.0 (2503615) Supported profiles by client "/2203020632A" are "Core"
                                  2024-02-06 18:54:22.001  - info: ocpp.0 (2503615) Removing SmartCharging functionality as unsupported
                                  2024-02-06 18:54:22.009  - info: ocpp.0 (2503615) Removing LocalAuthListManagement functionality as unsupported
                                  2024-02-06 18:54:27.560  - info: linktap.0 (2504393) updateWateringStatus started
                                  2024-02-06 18:54:28.086  - info: linktap.0 (2504393) Queried watering status for device Ventil-1. Status: 200
                                  2024-02-06 18:54:28.588  - info: linktap.0 (2504393) Queried watering status for device Ventil-2. Status: 200
                                  2024-02-06 18:54:29.087  - info: linktap.0 (2504393) Queried watering status for device Ventil-3. Status: 200
                                  2024-02-06 18:54:29.590  - info: linktap.0 (2504393) Queried watering status for device Ventil-4. Status: 200
                                  2024-02-06 18:54:30.091  - info: linktap.0 (2504393) Queried watering status for device Ventil-5. Status: 200
                                  2024-02-06 18:54:30.591  - info: linktap.0 (2504393) Queried watering status for device Ventil-6. Status: 200
                                  2024-02-06 18:54:30.592  - info: linktap.0 (2504393) updateWateringStatus finished
                                  2024-02-06 18:54:30.720  - info: javascript.0 (2501928) script.js.common.Diverses.BatterieUeberwachung185: Reaching CheckDeadBatt()
                                  2024-02-06 18:54:30.722  - info: javascript.0 (2501928) script.js.common.Diverses.BatterieUeberwachung185: Reaching MakeTable
                                  2024-02-06 18:54:30.726  - info: javascript.0 (2501928) script.js.common.Diverses.BatterieUeberwachung185: Reaching MakeJSONTable
                                  Top sieht so aus :
                                  top - 18:58:10 up 25 days, 10:23,  1 user,  load average: 0.47, 0.44, 0.39
                                  Tasks: 420 total,   1 running, 419 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):   1.0/0.5     1[|        ]
                                  MiB Mem :  11926.7 total,    930.9 free,   8022.1 used,   3290.3 buff/cache
                                  MiB Swap:   2044.0 total,   1761.0 free,    283.0 used.   3904.6 avail Mem
                                      PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                                  2502494 iobroker  20   0  970908 115660  39628 S   5.9   0.9   0:33.15 io.alexa2.0
                                  2502418 iobroker  20   0  718700 119496  38512 S   3.0   1.0   9:29.04 io.shelly.0
                                  2507490 redis     20   0 2380112 956748   8916 S   2.6   7.8  25:35.59 redis-server
                                  2501928 iobroker  20   0 1228744 348208  45036 S   2.3   2.9  26:04.94 io.javascript.0
                                  2501985 iobroker  20   0 1026816 164916  38276 S   1.7   1.4   9:44.20 io.influxdb.0
                                  2501872 iobroker  20   0  889924 156760  38196 S   1.0   1.3   9:43.59 io.history.0
                                  2502388 iobroker  20   0  677664 104916  38476 S   1.0   0.9   8:04.91 io.kodi.0
                                  2503052 iobroker  20   0   10.7g 112432  40076 S   1.0   0.9   1:53.66 io.synology.0
                                     1008 asterisk -11   0 5204544  35892  20324 S   0.7   0.3 312:22.63 asterisk
                                     1338 Debian-+  20   0 6338796 107844  35444 S   0.7   0.9  63:55.86 gnome-shell
                                  2692777 debian    20   0   11648   5448   3296 R   0.7   0.0   0:00.55 top
                                      802 root      20   0  241528   9844   6408 S   0.3   0.1  47:58.63 vmtoolsd
                                   249599 grafana   20   0 1677572 128360  51340 S   0.3   1.1  24:23.42 grafana
                                   250044 grafana   20   0  664160  61604  14420 S   0.3   0.5  72:02.49 plugin_start_li
                                  2501812 iobroker  20   0   11.1g 282464  45948 S   0.3   2.3   2:25.60 iobroker.js-con
                                  2501894 iobroker  20   0 1004340 131644  44840 S   0.3   1.1   1:03.47 io.telegram.2
                                  2501913 iobroker  20   0  687568  79528  38324 S   0.3   0.7   0:13.81 io.email.0
                                  2502001 iobroker  20   0 1003480 123116  39248 S   0.3   1.0   1:03.21 io.telegram.0
                                  2502018 iobroker  20   0  687428  81080  38204 S   0.3   0.7   0:13.52 io.pushover.0
                                  2502357 iobroker  20   0 1005648 130384  44844 S   0.3   1.1   1:03.65 io.telegram.1
                                  2502510 iobroker  20   0  698448  92956  38472 S   0.3   0.8   0:19.54 io.hass.0
                                  2502935 iobroker  20   0  686568  81752  38264 S   0.3   0.7   0:33.03 io.sonos.0
                                  2502993 iobroker  20   0  773696  98832  38352 S   0.3   0.8   0:28.60 io.mqtt.0
                                  2503080 iobroker  20   0  693196  88192  38196 S   0.3   0.7   0:29.98 io.mihome-vacuu
                                  2503148 iobroker  20   0  690772  83992  38244 S   0.3   0.7   1:53.38 io.net-tools.0
                                  2503429 iobroker  20   0  737980 112192  38280 S   0.3   0.9   0:50.42 io.mqtt-client.
                                  2504296 iobroker  20   0  760992  93404  39180 S   0.3   0.8   0:58.30 io.yahka.0
                                  2504393 iobroker  20   0  958140  93000  39352 S   0.3   0.8   1:01.79 io.linktap.0
                                  2662239 root      20   0       0      0      0 I   0.3   0.0   0:03.22 kworker/9:0-events
                                        1 root      20   0  169580  12604   7964 S   0.0   0.1   0:34.39 systemd
                                        2 root      20   0       0      0      0 S   0.0   0.0   0:04.01 kthreadd
                                        3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
                                        4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
                                        5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 slub_flushwq
                                        6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 netns
                                        8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/0:0H-events_highpri
                                       10 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_percpu_wq
                                       11 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_kthread
                                       12 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_rude_kthread
                                       13 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_trace_kthread
                                       14 root      20   0       0      0      0 S   0.0   0.0   0:23.37 ksoftirqd/0
                                  Da steht oben immer ein anderer Wert drin , je nach dem alle mit io.XXXX , aber nur so um die 9% bis max 30%
                                    achwas 🙂
                                    aber hiet
                                    ist kein Hinweis auf Überlastung durch I/O oder Prozesse
                                      @sunny9999
                                      Deine .list-Files für influxdb sind komplett chaotisch. Hat aber nix mit deinem 'Problem' direkt zu tun.
                                      Und wozu brauchst du die gnome-shell?
                                        keine Ahnung wo die herkommt........kann man die deinstallieren und wenn ja wie ? wenns was bringt.......
                                        Idee wie ich die Influxdb .list files hinbiegen kann ? ( nur so am Rande).......
                                          @sunny9999 was machst du mit den mounts?
                                          rauschen da die Daten dauerhaft und viel durch?
                                          bei diashow werde ich auch hellhörig
                                            die mounts sind nur für Backups.....die slideshow läuft nicht, war mal ein Versuch, danke für den Hinweis schon fast vergessen....jetzt disabled....
                                            1967
