    4. [Aufruf] TP-Link HS100 HS110 Adapter Testen
      Bongo last edited by
      Habe die selben Meldungen wie muckel:
      http://forum.iobroker.net/viewtopic.php?p=84439#p84439
      Bei mir:
      hs100.0	2017-11-26 15:56:10.333	info	starting. Version 0.0.18 in /opt/iobroker/node_modules/iobroker.hs100, node: v6.12.0
      host.smarteos	2017-11-26 15:56:08.883	info	instance system.adapter.hs100.0 started with pid 4232
      host.smarteos	2017-11-26 15:56:08.863	info	object change system.adapter.hs100.0
      host.smarteos	2017-11-26 15:56:03.664	info	Restart adapter system.adapter.hs100.0 because enabled
      host.smarteos	2017-11-26 15:56:03.663	error	instance system.adapter.hs100.0 terminated with code 0 (OK)
      hs100.0	2017-11-26 15:56:03.621	info	terminating
      hs100.0	2017-11-26 15:56:03.106	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      hs100.0	2017-11-26 15:56:03.106	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      hs100.0	2017-11-26 15:56:03.106	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      hs100.0	2017-11-26 15:56:03.106	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      hs100.0	2017-11-26 15:56:03.106	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:703:25)
      hs100.0	2017-11-26 15:56:03.106	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4527:18)
      hs100.0	2017-11-26 15:56:03.106	error	at Adapter.emit (events.js:185:7)
      hs100.0	2017-11-26 15:56:03.106	error	at emitNone (events.js:86:13)
      hs100.0	2017-11-26 15:56:03.106	error	at Adapter. (/opt/iobroker/node_modules/iobroker.hs100/main.js:30:5)
      hs100.0	2017-11-26 15:56:03.106	error	at main (/opt/iobroker/node_modules/iobroker.hs100/main.js:377:32)
      hs100.0	2017-11-26 15:56:03.106	error	TypeError: Cannot read property 'length' of undefined
      hs100.0	2017-11-26 15:56:03.104	error	uncaught exception: Cannot read property 'length' of undefined
      Man kann die steckdosen aber schalten.
      Ich habe zwei Steckdosen. Aber es wird immer nur die Erste refresht.
      Es läuft nicht ganz rund. Oder gibt es da einen Bugfix?
      Ich hatte übrigen zuvor node v4. Da hat es auch funktioniert mit den gleichen Problemen.
        tomtom last edited by
        @onkelfrisko:
        @mamoel:
        Was mir dabei aufgefallen ist:
        In der Objektansicht des ioBroker.admin wird der state Wert offenbar nicht ausgelesen. Das Feld bleibt immer rot. `
        auch bei mir wird der State nicht aktualisiert wenn ich per App oder manuell die Steckdose einschalte. Ich benutze einen Pi3 mit Raspbian Stretch Image `
        dies kann ich bestätigen - keine Aktualisierung von "state" im iobroker, wenn in der KASA App geschalten wird.
        LG
        Thomas
        • cvidal
          Hi zusammen,
          hab den Adapter jetzt auch mal getestet, erstmal danke dafür.
          Einbindung ging bei mir ohne Probleme mit dem HS110 und Version 0.0.18 ,
          nur passt bei mir der Wert des Datenpunktes total nicht, laut Kasa App liegt der Wert Gesamtverbrauch bei 0,06kwh im broker zeigt der Datenpunkt mir aber 0,02 an…
          Was ich auch nicht verstehe ist der Datenpunkt Current was genau wird dort angezeigt?
          State wird bei mir auch nicht Aktualisiert wenn ich per App oder Manuell Schalte.
          Gruß Christian
          Edit: Current ist wohl Ampere 🙂
            neue Version verfügbar 0.0.21 basierend auf https://github.com/plasticrake/tplink-smarthome-api
            allerdings habe ich ein Problem mit dem Powermanagement von HS110.. Bekomme die Verbrauchsdaten nicht ausgelesen..
            Polling sollte jetzt klappen
              Hallo arteck,
              habe die Version 0.0.21 installiert - Herzlichen Dank dafür - leider startet der Adpater nicht.
              Die vorher installierte Version 0.0.18 lief.
              host.ioBroker-RasPi 2017-12-03 20:07:30.058 info Do not restart adapter system.adapter.hs100.0 because disabled or deleted
              host.ioBroker-RasPi 2017-12-03 20:07:30.057 error instance system.adapter.hs100.0 terminated with code 3 (Adapter disabled or invalid config)
              host.ioBroker-RasPi 2017-12-03 20:07:30.057 error Caught by controller[0]: at Function.Module._load (module.js:438:3) code: 'MODULE_NOT_FOUND' }
              host.ioBroker-RasPi 2017-12-03 20:07:30.056 error Caught by controller[0]: at tryModuleLoad (module.js:446:12)
              host.ioBroker-RasPi 2017-12-03 20:07:30.056 error Caught by controller[0]: at Module.load (module.js:487:32)
              host.ioBroker-RasPi 2017-12-03 20:07:30.056 error Caught by controller[0]: at Object.Module._extensions..js (module.js:579:10)
              host.ioBroker-RasPi 2017-12-03 20:07:30.055 error Caught by controller[0]: at Module._compile (module.js:570:32)
              host.ioBroker-RasPi 2017-12-03 20:07:30.053 error Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api/lib/client.js:3:18)
              host.ioBroker-RasPi 2017-12-03 20:07:30.052 error Caught by controller[0]: at require (internal/module.js:20:19)
              host.ioBroker-RasPi 2017-12-03 20:07:30.050 error Caught by controller[0]: at Module.require (module.js:497:17)
              host.ioBroker-RasPi 2017-12-03 20:07:30.049 error Caught by controller[0]: at Function.Module._load (module.js:417:25)
              host.ioBroker-RasPi 2017-12-03 20:07:30.047 error Caught by controller[0]: at Function.Module._resolveFilename (module.js:469:15)
              host.ioBroker-RasPi 2017-12-03 20:07:30.045 error Caught by controller[0]: { Error: Cannot find module 'babel-runtime/core-js/json/stringify'
              hs100.0 2017-12-03 20:07:29.966 error adapter disabled
              host.ioBroker-RasPi 2017-12-03 20:07:06.090 info object change system.adapter.hs100.0
              host.ioBroker-RasPi 2017-12-03 20:06:57.987 info Restart adapter system.adapter.hs100.0 because enabled
              host.ioBroker-RasPi 2017-12-03 20:06:57.987 error instance system.adapter.hs100.0 terminated with code 0 (OK)
              Caught 2017-12-03 20:06:57.987 error by controller[0]: at Function.Module._load (module.js:438:3) code: 'MODULE_NOT_FOUND' }
              Caught 2017-12-03 20:06:57.986 error by controller[0]: at tryModuleLoad (module.js:446:12)
              Caught 2017-12-03 20:06:57.986 error by controller[0]: at Module.load (module.js:487:32)
              Caught 2017-12-03 20:06:57.986 error by controller[0]: at Object.Module._extensions..js (module.js:579:10)
              Caught 2017-12-03 20:06:57.982 error by controller[0]: at Module._compile (module.js:570:32)
              Caught 2017-12-03 20:06:57.981 error by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api/lib/client.js:3:18)
              Caught 2017-12-03 20:06:57.981 error by controller[0]: at require (internal/module.js:20:19)
              Caught 2017-12-03 20:06:57.981 error by controller[0]: at Module.require (module.js:497:17)
              Caught 2017-12-03 20:06:57.980 error by controller[0]: at Function.Module._load (module.js:417:25)
              Caught 2017-12-03 20:06:57.980 error by controller[0]: at Function.Module._resolveFilename (module.js:469:15)
              Caught 2017-12-03 20:06:57.979 error by controller[0]: { Error: Cannot find module 'babel-runtime/core-js/json/stringify'
              hs100.0 2017-12-03 20:06:57.938 info terminating
              hs100.0 2017-12-03 20:06:57.758 info starting. Version 0.0.21 in /opt/iobroker/node_modules/iobroker.hs100, node: v6.10.0
              hs100.0 2017-12-03 20:06:57.701 info States connected to redis: 127.0.0.1:6379
              hs100.0 2017-12-03 20:06:57.433 error at Function.Module._load (module.js:438:3)
              hs100.0 2017-12-03 20:06:57.433 error at tryModuleLoad (module.js:446:12)
              hs100.0 2017-12-03 20:06:57.433 error at Module.load (module.js:487:32)
              hs100.0 2017-12-03 20:06:57.433 error at Object.Module._extensions..js (module.js:579:10)
              hs100.0 2017-12-03 20:06:57.433 error at Module._compile (module.js:570:32)
              hs100.0 2017-12-03 20:06:57.433 error at Object. (/opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api/lib/client.js:3:18)
              hs100.0 2017-12-03 20:06:57.433 error at require (internal/module.js:20:19)
              hs100.0 2017-12-03 20:06:57.433 error at Module.require (module.js:497:17)
              hs100.0 2017-12-03 20:06:57.433 error at Function.Module._load (module.js:417:25)
              hs100.0 2017-12-03 20:06:57.433 error at Function.Module._resolveFilename (module.js:469:15)
              hs100.0 2017-12-03 20:06:57.433 error Error: Cannot find module 'babel-runtime/core-js/json/stringify'
              hs100.0 2017-12-03 20:06:57.418 error uncaught exception: Cannot find module 'babel-runtime/core-js/json/stringify'
              host.ioBroker-RasPi 2017-12-03 20:06:56.080 info instance system.adapter.hs100.0 started with pid 10170
              host.ioBroker-RasPi 2017-12-03 20:06:56.007 info object change system.adapter.hs100.0
              LG
              Thomas
                mamoel last edited by
                Die Installation lief bei mir problemlos und der Adapter startet auch ohne Fehler im Log. Aber nach wie vor wird der Status nicht aktualisiert.
                  @tomtom:
                  Hallo arteck,
                  LG
                  Thomas `
                  ok schmal bitte nach ob du unter /opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api/node_modules babel-runtime findest
                  es scheint als ob irgendwas nicht mit installiert wurde
                    @mamoel:
                    Die Installation lief bei mir problemlos und der Adapter startet auch ohne Fehler im Log. Aber nach wie vor wird der Status nicht aktualisiert. `
                    stoppe den adapter
                    lösche unter objekte hs100.0
                    starte den adapter.. die objekte sollten jetzt neu erzeugt worden sein..
                      Vielen Dank. Ich kann bestätigen, dass es jetzt funktioniert.
                      • cvidal
                        @arteck:
                        Polling sollte jetzt klappen `
                        Ja Rückmeldung funtioniert jetzt, Danke für deine Mühe
                        Ich werde aber erst mal zu 0.0.18 zurückkehren denn das Powermanagment nutze ich gerade in der Vis.App.
                        Könntest du mir vielleicht sagen warum die Verbrauchsdaten im Broker anderes als in der Kasa App sind bzw. bin ich der einzige mit dem Problem?
                        Gruß Christian
                          Hallo arteck,
                          unter /opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api# ls
                          befindet sich nur:
                          CHANGELOG.md lib LICENSE package.json README.md
                          Der Ordner node_modules ist nicht vorhanden.
                          Ich habe den Adapter 0.0.21 über den 0.0.18, wie folgt manuell installiert:
                          cd /opt/iobroker
                          iobroker stop
                          npm install iobroker.hs100@0.0.21 –production
                          iobroker upload hs100
                          iobroker start
                          LG
                          Thomas
                          • Dolomiti
                            Dolomiti last edited by
                            Hallo arteck,
                            ich hatte auch eine Menge Fehlermeldungen
                            host.raspi3	2017-12-04 20:41:24.027	error	instance system.adapter.hs100.0 terminated with code 1 ()
                            Caught	2017-12-04 20:41:24.027	error	by controller[0]: at node.js:1043:3
                            Caught	2017-12-04 20:41:24.026	error	by controller[0]: at startup (node.js:140:18)
                            Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Function.Module.runMain (module.js:441:10)
                            Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Function.Module._load (module.js:300:12)
                            Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Module.load (module.js:343:32)
                            Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Object.Module._extensions..js (module.js:416:10)
                            Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Module._compile (module.js:373:25)
                            Caught	2017-12-04 20:41:24.025	error	by controller[0]: at exports.runInThisContext (vm.js:53:16)
                            Caught	2017-12-04 20:41:24.025	error	by controller[0]: SyntaxError: Unexpected token {
                            Caught	2017-12-04 20:41:24.025	error	by controller[0]: ^
                            Caught	2017-12-04 20:41:24.024	error	by controller[0]: const { Client } = require('./lib/tplink-smarthome-api/lib/index');
                            Caught	2017-12-04 20:41:24.024	error	by controller[0]: /opt/iobroker/node_modules/iobroker.hs100/main.js:14
                            Unter /opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api/node_modules babel-runtime habe ich die Verzeichnisse
                            core-js
                            helpers
                            regenerator
                            und noch 4 Dateien
                            Bin momentan zurück auf 0.0.18, die einwandfrei läuft. Der Trockner wird momentan geloggt. 🙂
                            Dolomiti
                              schon komisch .bei euch beiden.. es ist als ob nicht alles von GIT gezogen wurde..
                              so die hs110 liefert jetzt auch daten.. version 0.22
                              und die restlichen tp-link derivate sollten auch laufen.. (so hoffe ich :oops: )
                                Gerni last edited by
                                ich hatte auch das Problem, dass der State nicht übergeben wurde, entsprechendes UpDate steht ja zur Verfügung.
                                Also Adapter gestoppt, Unter Objekte HS100 alles gelöscht, UpDate gemacht -> Adapter startet
                                Adapter komplett deinstalliert und wieder installiert -> Adapter startet nicht.
                                Ideen?
                                • AlCalzone
                                  Ist da nicht-transpilierter Code auf NPM gelandet? Die Syntax ist relativ neu und wird aktuell nur von Babel/TypeScript unterstützt, evtl auch Node 8+
                                    @AlCalzone:
                                    Ist da nicht-transpilierter Code auf NPM gelandet? Die Syntax ist relativ neu und wird aktuell nur von Babel/TypeScript unterstützt, evtl auch Node 8+ `
                                    ich hab node 6.12 .. auf dem Pi und 6 nochwas auf dem Win Entwickler System
                                    ich check mal ob auf NPM alles gelandet ist .. da kann das Problem sein
                                    installier es bitte nur vom GIT..
                                    über admin
                                    • AlCalzone
                                      Node 8 war geraten, aber Node 4 kann es definitiv nicht und davon sind hier noch einige im Umlauf.
                                      Lässt sich aber relativ einfach fixen:
                                      const Client = require('./lib/tplink-smarthome-api/lib/index').Client;
                                        @AlCalzone:
                                        ok… ich check das mal
                                        wobei mit node 4 läuft der adapter nicht
                                          also ich habe die Version 6.10.0 im Einsatz:
                                          Was ist mit
                                          -installier es bitte nur vom GIT..
                                          -über admin
                                          gemeint?
                                          cd /opt/iobroker
                                          npm install https://github.com/arteck/ioBroker.hs10 … ll/master/
                                          LG
                                          Thomas
                                          • AlCalzone
                                            @tomtom:
                                            -über admin
                                            gemeint? `
                                            => ioBroker Admin öffnen
                                            => Auf das GitHub-Icon klicken
                                            => hs110 aus der Liste auswählen
                                            => OK
                                            31.7k
                                            79.8k
                                            215
                                            43190
