    4. [gelöst] Nach Restore IOB nicht erreichbar
      crunchip Forum Testing Most Active @Ianig Iro last edited by
      @ianig-iro die admin instanz läuft auch nicht
        Thomas Braun Most Active @crunchip last edited by
        @crunchip @Ianig-Iro
        Außer backitup läuft da gar nix.
        Ist der evtl. noch zugange?
        • I
          Ianig Iro @Thomas Braun last edited by Ianig Iro
          @thomas-braun jep, alles sehr veraltet, aber vorher lief es eigentlich.
          Backitup hatte gesagt, dass er durch ist.
          iob dialog
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
                    Kernel: Linux 6.1.0-rpi7-rpi-v8
              Architecture: arm64
          Model		: Raspberry Pi 4 Model B Rev 1.1
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           13:00:09 up  1:17,  4 users,  load average: 0.26, 0.16, 0.33
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Wed 2024-01-10 13:00:09 CET
                     Universal time: Wed 2024-01-10 12:00:09 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          Boot Target: 	graphical.target
          *** MEMORY ***
          Mem:            4.0G        574M        1.7G         42M        1.8G        3.4G
          Swap:           104M          0B        104M
          Total:          4.1G        574M        1.8G
                   3792 M total memory
                    548 M used memory
                    706 M active memory
                   1207 M inactive memory
                   1607 M free memory
                     92 M buffer memory
                   1660 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  1.6G     0  1.6G   0% /dev
          tmpfs          tmpfs     380M  1.3M  378M   1% /run
          /dev/sda2      ext4       29G  6.3G   22G  23% /
          tmpfs          tmpfs     1.9G  216K  1.9G   1% /dev/shm
          /dev/sda1      vfat      510M   74M  437M  15% /boot/firmware
          tmpfs          tmpfs     380M   40K  380M   1% /run/user/1000
          [Wed Jan 10 11:42:14 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:61:2A:FD vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=ee71d179-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=GB
          [Wed Jan 10 11:42:18 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Wed Jan 10 11:42:22 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
          TARGET               SOURCE    FSTYPE      OPTIONS
          /                    /dev/sda2 ext4        rw,noatime
          |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
          `-/boot/firmware     /dev/sda1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          611M	/var/
          191M	/var/lib
          187M	/var/cache
          174M	/var/cache/apt
          132M	/var/log/journal/a268e5d002bb48d195e4958fbaefe16d
          Archived and active journals take up 131.3M in the file system.
          /opt/iobroker/backups:
          6.5M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          232M	/opt/iobroker/iobroker-data/
          204M	/opt/iobroker/iobroker-data/files
          88M	/opt/iobroker/iobroker-data/files/echarts.admin
          57M	/opt/iobroker/iobroker-data/files/echarts
          32M	/opt/iobroker/iobroker-data/files/echarts/static/js
          23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
          23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
          23M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
          17M	/opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
          17M	/opt/iobroker/iobroker-data/files/echarts.admin/preview/static/js/main.1b04901d.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2255680-if00
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v18.19.0
          /usr/bin/node 		v18.19.0
          /usr/bin/npm 		10.2.3
          /usr/bin/npx 		10.2.3
          /usr/bin/corepack 	0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
               18.19.0+dfsg-6~deb12u1 500
           *** 18.19.0-1nodesource1 600
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 600
               18.18.1-1nodesource1 600
               18.18.0-1nodesource1 600
               18.17.1-1nodesource1 600
               18.17.0-1nodesource1 600
               18.16.1-1nodesource1 600
               18.16.0-1nodesource1 600
               18.15.0-1nodesource1 600
               18.14.2-1nodesource1 600
               18.14.1-1nodesource1 600
               18.14.0-1nodesource1 600
               18.13.0+dfsg1-1 500
               18.13.0-1nodesource1 600
               18.12.0-1nodesource1 600
               18.11.0-1nodesource1 600
               18.10.0-1nodesource1 600
               18.9.1-1nodesource1 600
               18.9.0-1nodesource1 600
               18.8.0-1nodesource1 600
               18.7.0-1nodesource1 600
               18.6.0-1nodesource1 600
               18.5.0-1nodesource1 600
               18.4.0-1nodesource1 600
               18.3.0-1nodesource1 600
               18.2.0-1nodesource1 600
               18.1.0-1nodesource1 600
               18.0.0-1nodesource1 600
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	5.0.17
          admin: 		5.1.25
          javascript: 	5.2.13
          Adapters from github: 	0
          Adapter State
            system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
            system.adapter.deconz.0                 : deconz                : raspberrypi                              - disabled, port: 80
            system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
            system.adapter.echarts.0                : echarts               : raspberrypi                              - disabled
            system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
            system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
            system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 192.168.178.21
            system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
            system.adapter.sureflap.0               : sureflap              : raspberrypi                              - disabled
            system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
            system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
            system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.wolf-smartset.0          : wolf-smartset         : raspberrypi                              - disabled
            system.adapter.yahka.0                  : yahka                 : raspberrypi                              - disabled
            system.adapter.yahka.1                  : yahka                 : raspberrypi                              - disabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.12.0   , installed 5.1.25 [Updatable]
          Adapter    "alias-manager": 1.2.6    , installed 1.2.3  [Updatable]
          Adapter    "backitup"     : 2.9.8    , installed 2.1.17 [Updatable]
          Adapter    "deconz"       : 1.3.23   , installed 1.3.19 [Updatable]
          Adapter    "discovery"    : 4.2.0    , installed 2.7.0  [Updatable]
          Adapter    "echarts"      : 1.7.2    , installed 1.5.1  [Updatable]
          Adapter    "influxdb"     : 3.2.0    , installed 1.9.5  [Updatable]
          Adapter    "javascript"   : 7.1.6    , installed 5.2.13 [Updatable]
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "mqtt"         : 5.1.0    , installed 2.4.0  [Updatable]
          Adapter    "shelly"       : 6.6.1    , installed 4.0.7  [Updatable]
          Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
          Adapter    "sureflap"     : 1.2.1    , installed 1.1.8  [Updatable]
          Adapter    "telegram"     : 3.0.1    , installed 1.10.0 [Updatable]
          Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
          Adapter    "web"          : 6.1.10   , installed 4.3.0  [Updatable]
          Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
          Adapter    "ws"           : 2.5.8    , installed 1.3.0  [Updatable]
          Adapter    "yahka"        : 1.0.3    , installed 0.13.1 [Updatable]
          Objects and States
          Objects: 	2850
          States: 	2217
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12191      839/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17653      814/cupsd
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       32026      7618/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32019      7618/iobroker.js-co
          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      1000       15100      1179/wayvnc
          tcp6       0      0 :::22                   :::*                    LISTEN      0          12193      839/sshd: /usr/sbin
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17652      814/cupsd
          udp        0      0 0.0.0.0:39203           0.0.0.0:*                           104        14656      608/avahi-daemon: r
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17215      1107/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14654      608/avahi-daemon: r
          udp6       0      0 :::59079                :::*                                104        14657      608/avahi-daemon: r
          udp6       0      0 fe80::bee6:def8:c02:546 :::*                                0          18561      744/NetworkManager
          udp6       0      0 fe80::4914:f794:31f:546 :::*                                0          12286      744/NetworkManager
          udp6       0      0 :::5353                 :::*                                104        14655      608/avahi-daemon: r
          2024-01-10 12:21:55.095  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules done
          2024-01-10 12:21:56.112  - info: host.raspberrypi iobroker npm-rebuild: exit 0
          2024-01-10 12:21:56.240  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 9646
          2024-01-10 12:21:57.438  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1137
          2024-01-10 12:21:57.439  - error: host.raspberrypi Caught by controller[0]:   throw err;
          2024-01-10 12:21:57.439  - error: host.raspberrypi Caught by controller[0]:   ^
          2024-01-10 12:21:57.440  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
          2024-01-10 12:21:57.440  - error: host.raspberrypi Caught by controller[0]: Require stack:
          2024-01-10 12:21:57.440  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
          2024-01-10 12:21:57.441  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          2024-01-10 12:21:57.441  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:975:27)
          2024-01-10 12:21:57.441  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
          2024-01-10 12:21:57.442  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
          2024-01-10 12:21:57.442  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
          2024-01-10 12:21:57.442  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
          2024-01-10 12:21:57.443  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          2024-01-10 12:21:57.443  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
          2024-01-10 12:21:57.443  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
          2024-01-10 12:21:57.444  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
          2024-01-10 12:21:57.444  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
          2024-01-10 12:21:57.444  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
          2024-01-10 12:21:57.445  - error: host.raspberrypi Caught by controller[0]: }
          2024-01-10 12:21:57.445  - error: host.raspberrypi Caught by controller[0]: Node.js v18.19.0
          2024-01-10 12:21:57.446  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-01-10 12:21:57.446  - info: host.raspberrypi Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
          und die summary
          			v.2023-10-10
                 Icon name: computer
              Architecture: arm64
          Installation: 		native
          Kernel: 		aarch64
          Userland: 		arm64
          Timezone: 		Europe/Berlin (CET, +0100)
          User-ID: 		1000
          X-Server: 		false
          Pending OS-Updates: 	0
          Pending iob updates: 	17
          Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
          			/usr/bin/npm 		10.2.3
          			/usr/bin/npx 		10.2.3
          Recommended versions are nodejs  and npm
          MEMORY:
          Mem:            4.0G        585M        1.7G         42M        1.9G        3.4G
          Swap:           104M          0B        104M
          Total:          4.1G        585M        1.8G
          Active iob-Instances: 	2
          ioBroker Core: 		js-controller 		5.0.17
          			admin 			5.1.25
          ioBroker Status: 	iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          Objects: 		2850
          States: 		2217
          Size of iob-Database:
          9.5M	/opt/iobroker/iobroker-data/objects.jsonl
          5.3M	/opt/iobroker/iobroker-data/objects.json.migrated
          5.3M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
          644K	/opt/iobroker/iobroker-data/states.jsonl
          396K	/opt/iobroker/iobroker-data/states.json.bak.migrated
          392K	/opt/iobroker/iobroker-data/states.json.migrated
          @crunchip woran erkennst du das? ich dachte wenn enabled dort steht, läuft er admin?
          Homoran Thomas Braun 4 Replies Last reply Reply Quote 0
            Homoran Global Moderator Administrators @Ianig Iro last edited by
            @ianig-iro sagte in Nach Restore IOB nicht erreichbar:
            dann ist backitup durch!
            Aber nicht der Restore
            Jetzt werden alle Adapter für die neuen Versionen OS und node neu gebaut
              + instance is alive
              am plus
                Thomas Braun Most Active @Ianig Iro last edited by
                Das rottet dann so lange vor sich hin, bis es nicht mehr läuft...
                Du musst die Kiste dauerhaft auf Stand halten...
                Ich vermute, du hast vor dem Umzug die Versionen nicht angeglichen und bist mit einem 4er js-controller auf den js-controller 5.0.17 gegangen. Das geht in die Hose.
                Versuch:
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.js-controller
                iob update
                iob upgrade all -y
                  sudo systemctl set-default multi-user.target
                  sudo reboot
                  • I
                    @thomas-braun du hattest recht und mit deiner lösung funktioniert es. vielen dank - das hätte ich nicht hinbekommen.
                    ab jetzt wird alles aktuell gehalten.
                      @ianig-iro sagte in [gelöst] Nach Restore IOB nicht erreichbar:
                      du hattest recht
                      dann ist aber eine entsprechende Meldung beim Versuch des Restores gekommen!
                      • I
                        Ianig Iro @Homoran last edited by
                        @homoran das kann sein, ich konnte aber nirgends eingreifen. nachdem dort sinngemäß successful stand, habe ich etwas voreilig auf refresh gedrückt und konnte mir den verlauf nicht mehr im detail ansehen.
                          die Meldung komm sofort zu Beginn und fordert dich auf die controller Version vor dem Restore herunterzusetzen.
                          @Thomas-Braun hat jetzt den umgekehrten Weg beschritten
                          421
