    4. Test Adapter LG ThinQ
      Lucky_ESA Developer Most Active @ofri2607 last edited by
      @ofri2607 sagte in Test Adapter LG ThinQ v0.0.1:
      @Lucky_ESA
      Guten Morgen,
      folgende Einträge hatte ich heute in unregelmäßigen Abständen im Log:
      2024-01-08 23:00:17.622 - error: lg-thinq.0 (1325489) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2024-01-08 23:00:17.633 - error: lg-thinq.0 (1325489) unhandled promise rejection: undefined is not a valid state value
      2024-01-08 23:00:17.951 - error: lg-thinq.0 (1325489) Error: undefined is not a valid state value
      at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
      at LgThinq._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7593:26)
      at LgThinq.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7551:21)
      at LgThinq.setThinq1Interval (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:467:18)
      at /opt/iobroker/node_modules/iobroker.lg-thinq/main.js:369:22
      at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2024-01-08 23:00:17.952 - error: lg-thinq.0 (1325489) undefined is not a valid state value
      2024-01-08 23:00:18.514 - info: lg-thinq.0 (1325489) terminating
      2024-01-08 23:00:18.516 - warn: lg-thinq.0 (1325489) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-01-08 23:00:18.558 - info: lg-thinq.0 (1325489) terminating
      2024-01-08 23:00:19.134 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2024-01-08 23:00:19.134 - error: host.raspberrypi Caught by controller[1]: Error: undefined is not a valid state value
      2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17)
      2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at LgThinq._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7593:26)
      2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at LgThinq.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7551:21)
      2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at LgThinq.setThinq1Interval (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:467:18)
      2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.lg-thinq/main.js:369:22
      2024-01-08 23:00:19.135 - error: host.raspberrypi Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2024-01-08 23:00:19.135 - error: host.raspberrypi instance system.adapter.lg-thinq.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2024-01-08 23:00:19.135 - info: host.raspberrypi Restart adapter system.adapter.lg-thinq.0 because enabled
      2024-01-08 23:00:49.233 - info: host.raspberrypi instance system.adapter.lg-thinq.0 started with pid 1327629
      2024-01-08 23:00:52.448 - info: lg-thinq.0 (1327629) starting. Version 0.3.2 (non-npm: TA2k/ioBroker.lg-thinq) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v18.19.0, js-controller: 5.0.17
      2024-01-08 23:00:54.140 - info: lg-thinq.0 (1327629) Login successful
      2024-01-08 23:00:58.992 - info: lg-thinq.0 (1327629) Found: 3 devices
      2024-01-08 23:00:58.993 - info: lg-thinq.0 (1327629) Create or update datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
      2024-01-08 23:01:14.671 - info: lg-thinq.0 (1327629) Update raw datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
      2024-01-08 23:01:15.229 - info: lg-thinq.0 (1327629) Create or update datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
      2024-01-08 23:01:20.776 - info: lg-thinq.0 (1327629) Update raw datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
      2024-01-08 23:01:21.503 - info: lg-thinq.0 (1327629) Create or update datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
      2024-01-08 23:01:26.808 - info: lg-thinq.0 (1327629) Update raw datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
      2024-01-08 23:01:27.936 - info: lg-thinq.0 (1327629) Found MQTT Host
      2024-01-08 23:01:28.026 - info: lg-thinq.0 (1327629) Found AWS CER
      2024-01-08 23:01:28.678 - info: lg-thinq.0 (1327629) Create certification done
      2024-01-08 23:01:29.117 - info: lg-thinq.0 (1327629) Start MQTT Connection
      2024-01-08 23:01:29.647 - info: lg-thinq.0 (1327629) MQTT connected to: t20/op/7e0548ce9ab409359f1393e34f2529773cfe35ff338479a1d21060cdbe7d4db2/inbox
      Es ist keine eindeutige Zeitabfolge erkennbar, war aber von gestern nach der Installation der v0.3.2 bis heute insgesamt 5 mal, zuletzt heute um 1:43:13.
      OK, danke für die Info. Habe auf dem GIT den Fehler behoben. Dann konnte ca. 5 x keine Daten geholt werden. Das ist super und wahrscheinlich kommt noch die Zwangstrennung dazu.
      Kannst du bitte vom GIT laden und weiter testen. Besteht die Möglichkeit das du ein Blockly erstellt was den DP interval.status_devices triggert und bei Änderungen ein Logeintrag erstellt.
      Gruß//Lucky
      ofri2607 2 Replies Last reply Reply Quote 0
      • ofri2607
        ofri2607 @Lucky_ESA last edited by
        @lucky_esa
        Servus, ja kann ich gerne machen, geht aber erst heute am Abend.
        Blockly jetzt nicht so, mache das dann über JS.
        • ofri2607
          @lucky_esa
          Ist installiert, läuft und Skript mit Trigger vom Datenpunkt läuft auch.
          Ich lasse es mal über die Nacht durchlaufen und stelle dir dann morgen das Ergebnis der Logausgaben vom Skript ein.
            @lucky_esa
            Super, vielen Dank.
            Gruß//Lucky
            ofri2607 1 Reply Last reply Reply Quote 0
            • ofri2607
              @lucky_esa
              Hier mal die ersten Ausgaben vom Log des Skripts …
              javascript.3
              2024-01-09 21:15:44.759	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
              javascript.3
              2024-01-09 21:15:40.217	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
              javascript.3
              2024-01-09 20:45:19.725	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{}")
              javascript.3
              2024-01-09 20:45:17.951	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
              javascript.3
              2024-01-09 20:17:39.501	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
              javascript.3
              2024-01-09 20:17:19.881	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
              javascript.3
              2024-01-09 20:17:14.957	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
              javascript.3
              2024-01-09 20:03:04.792	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
              javascript.3
              2024-01-09 20:03:00.409	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
              javascript.3
              2024-01-09 19:15:47.479	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                @ofri2607 Das sieht doch recht gut aus. Bei "Fail" kommen trotzdem Daten und es wechselt dann auch wieder auf "OK".
                Gruß//Lucky
                • ofri2607
                  @lucky_esa
                  Das habe ich mir auch gedacht, tut so wie es soll 👍
                  Was ich mich gefragt habe, ist warum hin und wieder ein leerer Eintrag im json da ist?
                  Über die Nacht ist es vergleichbar weitergelaufen, da war auch eine Zwangstrennung durch meinen Internetprovider dabei, die hat es auch problemlos gemeistert, siehe ...
                  javascript.3
                  2024-01-10 06:59:18.890	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                  javascript.3
                  2024-01-10 06:59:09.050	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                  javascript.3
                  2024-01-10 06:00:53.338	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                  javascript.3
                  2024-01-10 06:00:49.114	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                  javascript.3
                  2024-01-10 05:03:02.938	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                  javascript.3
                  2024-01-10 05:02:58.308	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                  javascript.3
                  2024-01-10 04:03:57.614	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                  javascript.3
                  2024-01-10 04:03:47.989	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                  javascript.3
                  2024-01-10 04:03:42.989	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                  lg-thinq.0
                  2024-01-10 03:52:06.773	info	MQTT connected to: t20/op/d6dd60f0475926a7f83dd2cacbcf6c92eddb8512492affc08b1a36fa323fe8be/inbox
                  lg-thinq.0
                  2024-01-10 03:52:06.501	info	Thinq MQTT reconnect
                  javascript.3
                  2024-01-10 03:51:47.800	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                  javascript.3
                  2024-01-10 03:51:42.933	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error\"}")
                  javascript.3
                  2024-01-10 03:51:32.747	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - 0106\"}")
                  javascript.3
                  2024-01-10 03:51:30.175	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - 0106\"}"(alter Wert war "{}")
                  javascript.3
                  2024-01-10 03:38:58.253	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                  javascript.3
                  2024-01-10 03:05:42.127	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                  javascript.3
                  2024-01-10 03:05:37.539	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                  javascript.3
                  2024-01-10 02:08:21.801	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                  javascript.3
                  2024-01-10 02:07:12.200	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                  javascript.3
                  2024-01-10 02:07:07.203	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                  javascript.3
                  2024-01-10 01:31:41.560	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - 0106\"}")
                  javascript.3
                  2024-01-10 01:31:31.985	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - 0106\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                  javascript.3
                  2024-01-10 01:30:52.049	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                  javascript.3
                  2024-01-10 01:30:46.964	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                  javascript.3
                  2024-01-10 01:09:21.432	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                  javascript.3
                  2024-01-10 01:09:16.931	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                  javascript.3
                  2024-01-10 00:12:51.007	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                  javascript.3
                  2024-01-10 00:12:41.496	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                  javascript.3
                  2024-01-10 00:12:36.516	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                  javascript.3
                  2024-01-10 00:12:26.045	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}")
                  javascript.3
                  2024-01-10 00:12:21.426	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                  Soll ich das Logging noch weiter Laufen lassen, oder hast du gesehen was du sehen wolltest?
                    @ofri2607 Nein, musst du nicht weiterlaufen lassen. Beim ersten Intervall kommen auch Fehler die du nur im debug Modus siehst.
                    Mal schauen, ob ich das noch ein wenig ändern kann.
                    Gruß//Lucky
                    • ofri2607
                      @lucky_esa
                      Perfekt, Danke. Wenn ich noch etwas testen soll, melde dich einfach.
                        @lucky_esa
                        Gerne würde noch was testen. Lösche bitte noch nicht dein Script.
                        • ofri2607
                          @lucky_esa
                          Passt, mache ich nicht. Wäre aber auch wieder schnell erstellt, sind eh‘ nur zwei Zeilen 🙂
                            @lucky_esa
                            Es wäre super wenn du jetzt noch mal vom GIT lädst und über Nacht laufen lässt. Die Fehler die du jetzt siehst. kommen auch bem anderen Intervall aber sind nur im Debug-Modus sichtbar.
                            Gruß//Lucky
                              schorty @schorty last edited by
                              Nutzt keiner den LG ThinQ Adapter zum Fernstart einer Wama 🙄 ???
                              Schorty
                                Lucky_ESA Developer Most Active @schorty last edited by
                                @schorty sagte in Test Adapter LG ThinQ v0.0.1:
                                Schorty
                                Vielleicht der ein oder andere aber diese User schauen nicht immer in diesem Thread.
                                Hier ein Blockly wie du die Daten vorbereiten kannst und später dann per remote.start starten. Allerdings weiß ich nicht was passsiertm wenn die WaMa in Standby geht. Das musst du mal prüfen und ggfs. alfangen.
                                Du musst noch deine Seriennummer eintragen.
                                common.Washer(1).xml
                                Gruß//Lucky
                                • ofri2607
                                  ofri2607 @Lucky_ESA last edited by ofri2607
                                  @lucky_esa sagte in Test Adapter LG ThinQ v0.0.1:
                                  Es wäre super wenn du jetzt noch mal vom GIT lädst und über Nacht laufen lässt …
                                  Sorry, das die Rückmeldung jetzt etwas gedauert hat.
                                  Hab gerade aus GIt geladen, das Skript läuft auch wieder und nach dem Start sieht mal alles normal aus.
                                  Was ich heute insgesamt viermal im Log hatte (hatte ich schon länger nicht mehr) war:
                                  lg-thinq.0
                                  2024-01-12 14:32:19.561	error	AxiosError: Request failed with status code 500
                                  lg-thinq.0
                                  2024-01-12 14:32:19.560	error	SendMonitorCommand
                                  EDIT:
                                  Die ersten Einträge vom Skript sind schon da:
                                  javascript.3
                                  2024-01-12 17:31:22.679	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{}")
                                  javascript.3
                                  2024-01-12 17:31:17.426	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-12 17:31:12.657	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail - 0100\"}")
                                  javascript.3
                                  2024-01-12 17:31:07.775	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail - 0100\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-12 17:26:32.678	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{}")
                                  javascript.3
                                  2024-01-12 17:26:27.834	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-12 17:25:02.738	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{}")
                                  javascript.3
                                  2024-01-12 17:24:57.450	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-12 17:23:32.617	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{}")
                                  javascript.3
                                  2024-01-12 17:23:27.377	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-12 17:22:57.642	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{}")
                                  javascript.3
                                  2024-01-12 17:22:52.405	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                  javascript.3
                                  2024-01-12 17:21:49.323	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                  javascript.3
                                  2024-01-12 17:21:49.268	info	Start javascript script.js.common.Testumgebung.LGthinq1_Statusänderung
                                  Das leere Object kommt jetzt anscheinend häufiger?
                                    Lucky_ESA Developer Most Active @ofri2607 last edited by Lucky_ESA
                                    @ofri2607 Danke für diese Info. Eigentlich darf da nichts leer sein. Hab da was geändert, kannst du bitte erneut vom GIT laden.
                                    edit: Fehller 500 sagt lediglich das der LG Server nicht erreichbar ist.
                                    Gruß//Lucky
                                    • ofri2607
                                      @lucky_esa
                                      Geladen und wieder gestartet sieht so aus:
                                      javascript.3
                                      2024-01-12 19:06:23.088	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                      javascript.3
                                      2024-01-12 19:06:17.758	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                      javascript.3
                                      2024-01-12 19:06:07.996	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                      javascript.3
                                      2024-01-12 19:06:02.765	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                      javascript.3
                                      2024-01-12 19:05:48.183	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                      javascript.3
                                      2024-01-12 19:05:42.760	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                      javascript.3
                                      2024-01-12 19:05:23.031	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                      javascript.3
                                      2024-01-12 19:05:17.751	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                      javascript.3
                                      2024-01-12 19:05:03.135	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                      javascript.3
                                      2024-01-12 19:04:57.865	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                      javascript.3
                                      2024-01-12 19:03:03.085	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{}")
                                      javascript.3
                                      2024-01-12 19:02:57.535	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                      lg-thinq.0
                                      2024-01-12 19:02:57.296	info	MQTT connected to: t20/op/321964b1a4250688835741c9df226a611840004ac9537c80cddf1d10e8b7230b/inbox
                                      lg-thinq.0
                                      2024-01-12 19:02:56.828	info	Start MQTT Connection
                                      lg-thinq.0
                                      2024-01-12 19:02:56.549	info	Create certification done
                                      lg-thinq.0
                                      2024-01-12 19:02:55.893	info	Found AWS CER
                                      lg-thinq.0
                                      2024-01-12 19:02:55.821	info	Found MQTT Host
                                      lg-thinq.0
                                      2024-01-12 19:02:54.996	info	Update raw datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
                                      lg-thinq.0
                                      2024-01-12 19:02:49.726	info	Create or update datapoints for fd80ae07-21ef-18c3-bd4c-44cb8b63456e
                                      lg-thinq.0
                                      2024-01-12 19:02:49.191	info	Update raw datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
                                      lg-thinq.0
                                      2024-01-12 19:02:43.788	info	Create or update datapoints for dfbdfc44-8efb-148a-acc9-44cb8b32f2ea
                                      lg-thinq.0
                                      2024-01-12 19:02:43.160	info	Update raw datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
                                      lg-thinq.0
                                      2024-01-12 19:02:27.742	info	Create or update datapoints for d27d1380-7149-11d3-80b8-2c2bf9760c6d
                                      lg-thinq.0
                                      2024-01-12 19:02:27.740	info	Found: 3 devices
                                      lg-thinq.0
                                      2024-01-12 19:02:25.456	info	Login successful
                                      lg-thinq.0
                                      2024-01-12 19:02:22.529	info	starting. Version 0.3.2 (non-npm: TA2k/ioBroker.lg-thinq) in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v18.19.0, js-controller: 5.0.17
                                      EDIT: Ok, Danke für die Info.
                                        @ofri2607 Gehen die Änderungen so weiter? Kann hier bei mir auch ein wenig tesen aber leider habe ich kein einzelnes Geräte. Da läuft es alle 5 Sekunden lang ohne Fehler.
                                        • ofri2607
                                          @lucky_esa
                                          Sieht so aus, der Axios-Error 500 war auch gerade …
                                          javascript.3
                                          2024-01-12 19:29:48.313	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                          javascript.3
                                          2024-01-12 19:29:42.962	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-12 19:27:23.144	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error\"}")
                                          javascript.3
                                          2024-01-12 19:26:52.948	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - 0106\"}")
                                          javascript.3
                                          2024-01-12 19:26:48.645	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - 0106\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}")
                                          lg-thinq.0
                                          2024-01-12 19:26:48.415	error	AxiosError: Request failed with status code 500
                                          lg-thinq.0
                                          2024-01-12 19:26:48.413	error	SendMonitorCommand
                                          javascript.3
                                          2024-01-12 19:26:43.305	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Error - undefined\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail - 0100\"}")
                                          javascript.3
                                          2024-01-12 19:26:38.665	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Fail - 0100\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-12 19:23:38.127	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                          javascript.3
                                          2024-01-12 19:23:32.922	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-12 19:21:28.131	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                          javascript.3
                                          2024-01-12 19:21:22.852	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-12 19:19:43.079	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                          javascript.3
                                          2024-01-12 19:19:37.824	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-12 19:17:58.133	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                          javascript.3
                                          2024-01-12 19:17:52.817	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-12 19:17:38.075	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                          javascript.3
                                          2024-01-12 19:17:32.828	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-12 19:16:38.067	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                          javascript.3
                                          2024-01-12 19:16:33.011	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-12 19:14:33.628	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                          javascript.3
                                          2024-01-12 19:14:27.935	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-12 19:13:33.113	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                          javascript.3
                                          2024-01-12 19:13:27.856	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          2024-01-12 19:11:38.002	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}")
                                          javascript.3
                                          2024-01-12 19:11:32.866	info	script.js.common.Testumgebung.LGthinq1_Statusänderung: status_device: "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"Request\"}"(alter Wert war "{\"d27d1380-7149-11d3-80b8-2c2bf9760c6d\":\"OK\"}")
                                          javascript.3
                                          javascript.3
                                          javascript.3
                                          javascript.3
                                          javascript.3
                                          javascript.3
                                          javascript.3
                                          javascript.3
                                          javascript.3
                                          javascript.3
                                          javascript.3
                                          javascript.3
                                            @ofri2607 Hab mal einen anderen Header genommen. Kannst du bitte noch mal laden.
                                            908
                                            285829
