    3. Entwicklung
    4. [New Adapter] huawei fusionsolar api
      myssv last edited by
      ich bekomme sehr regelmäßig diesen Fehler und kann ihn nicht deuten:
      fusionsolar.0 	2023-12-06 13:14:59.026	error	Cannot read properties of null (reading '0')
      fusionsolar.0	2023-12-06 13:10:59.700	error	Cannot read properties of null (reading '0')
      fusionsolar.0	2023-12-06 13:07:00.539	error	Cannot read properties of null (reading '0')
      fusionsolar.0	2023-12-06 13:03:00.443	error	Cannot read properties of null (reading '0')
      fusionsolar.0	2023-12-06 12:58:57.389	error	Cannot read properties of null (reading '0')
      fusionsolar.0	2023-12-06 12:56:59.287	error	connect ETIMEDOUT 90.84.191.21:443
      fusionsolar.0	2023-12-06 12:50:45.391	error	Cannot read properties of null (reading '0')
      fusionsolar.0	2023-12-06 12:46:27.828	error	Cannot read properties of null (reading '0')
      fusionsolar.0	2023-12-06 12:44:33.846	error	Cannot read properties of null (reading '0')
      fusionsolar.0	2023-12-06 12:43:57.185	error	Cannot read properties of null (reading '0')
      fusionsolar.0	2023-12-06 12:39:58.542	error	Cannot read properties of null (reading '0')
      fusionsolar.0	2023-12-06 12:36:00.370	error	Cannot read properties of null (reading '0')
      Jann mir jemand helfen?
      mcm1957 E 2 Replies Last reply Reply Quote 0
      • mcm1957
        mcm1957 @myssv last edited by
        This is the ENGLISH SECTION
        Please use english language here
          myssv @mcm1957 last edited by
          @mcm57 sagte in [New Adapter] huawei fusionsolar api:
          • mcm1957
            mcm1957 @myssv last edited by mcm1957
            @myssv
            What do you fail to understand ?
            This topic is located at the ENGLISH section of the forum. So use english language only.
            See header lines for location of topic:
            ![9a668057-2e34-4029-8df2-a07be3d24f83-image.png](/assets/uploads/files/1704731224489-9a668057-2e34-4029-8df2-a07be3d24f83-image.png
            I've reqeusted a move to german area as this seems to be more appropiate
              @mcm57 From my point of view the thread is located in the German section
              Maybe it was moved after yor request?
              • mcm1957
                @myssv
                YEP - jetzt ist er im deutschen Bereich.
                  torkel last edited by
                  Hallo zusammen
                  Funktioniert dieser Adapter bei euch? Wenn ja, mit welcher Version betreibt ihr den Adapter und was habt ihr für Settings beim Adapter eingegeben?
                  Ich bekomme einfach keine Daten zurück. In der Schnittstelle habe ich alles freigegeben.
                  M H 2 Replies Last reply Reply Quote 0
                    myssv @torkel last edited by
                    @torkel sagte in [New Adapter] huawei fusionsolar api:
                    Yep, läuft bei mir ...
                    Das sind meine Einstellungen
                      EDE111 @myssv last edited by
                      @myssv hallo, ich habe gerade das selbe Problem. Hast du schon eine Lösung gefunden?
                        myssv @EDE111 last edited by
                        @ede111 Welches meinst Du?
                        Die "Cannot read properties of null (reading '0')" Meldungen? Die habe ich immer noch und auch keinen Hinweis dazu bekommen.
                          EDE111 @myssv last edited by EDE111
                          @myssv Danke für die schnelle Antwort.
                          Schade, hätte ja sein können. Bei mir sind es dann so 70 Fehlermeldungen am Tag. Schon irgendwie lästig.
                          Ich habe mal den IObroker auf einem anderen Rasp neu aufgesetzt mit fast nur diesem Adapter und trotzdem kommen die Fehlermeldungen. Keine Ahnung, vielleicht kommt ja nochmal eine Lösung.... Viel glück....
                            @ede111 Die Meldungen kommen eindeutig vom Fusionsolar Adapter
                            fusionsolar.0	2024-01-12 11:03:41.422	error	Cannot read properties of null (reading '0')
                            fusionsolar.0	2024-01-12 10:59:41.923	error	Cannot read properties of null (reading '0')
                            fusionsolar.0	2024-01-12 10:55:42.505	error	Cannot read properties of null (reading '0')
                            fusionsolar.0	2024-01-12 10:51:43.395	error	Cannot read properties of null (reading '0')
                            • mcm1957
                              @myssv
                              Dann erstell ein Issue beim Adapter wenn noch keines existiert.
                                @myssv
                                erledigt
                                  WoFried @myssv last edited by
                                  @myssv Ob sich da wohl schon was getan hat? Ich habe das Problem auch nach wie vor. 🤷‍♂️
                                  "fusionsolar.0 2024-02-18 18:42:54.835 error Cannot read properties of null (reading '0')"
                                  Das trat bei mir auch ganz plötzlich - von heute auf morgen - auf.
                                    myssv @WoFried last edited by
                                    @wofried Leider nein.
                                    Außer dass wohl einige den Fehler haben.
                                      hans_999 @torkel last edited by
                                      @torkel said in [New Adapter] huawei fusionsolar api:
                                      Ich habe gerade versucht, den Adapter via Github zu installieren https://github.com/KornSW/ioBroker.fusionsolar
                                      Leider klappt die Installation nicht. Ich bekomme diese Fehlermeldungen
                                      $ iobroker url https://github.com/KornSW/ioBroker.fusionsolar --host PIioBroker --debug
                                      install KornSW/ioBroker.fusionsolar#50f776fd8f991d0832be3d660de7a38a4763093d
                                      Installing KornSW/ioBroker.fusionsolar#50f776fd8f991d0832be3d660de7a38a4763093d... (System call)
                                      npm ERR! code ENOTEMPTY
                                      npm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/@types/caselessnpm ERR! dest /opt/iobroker/node_modules/@types/.caseless-biP5OApGnpm ERR! errno -39
                                      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@types/caseless' -> '/opt/iobroker/node_modules/@types/.caseless-biP5OApG'
                                      npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2024-02-18T21_17_14_731Z-debug-0.log
                                      Try to solve ENOTEMPTY error automatically
                                      Could not handle ENOTEMPTY, because no deletable files were foundnpm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/@types/caselessnpm ERR! dest /opt/iobroker/node_modules/@types/.caseless-biP5OApGnpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@types/caseless' -> '/opt/iobroker/node_modules/@types/.caseless-biP5OApG'npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2024-02-18T21_17_14_731Z-debug-0.loghost.PIioBroker Cannot install KornSW/ioBroker.fusionsolar#50f776fd8f991d0832be3d660de7a38a4763093d: 217
                                      ERROR: Process exited with code 25
                                      • mcm1957
                                        mcm1957 @hans_999 last edited by
                                        Der Adapter
                                        ist nicht in einem ioBroker Repository gelistet und hat daher bisher auch noch kein Review erhalten. Ob dieser noch entwickelt wird und in welchem Qualitätszustand er sich befindet kann nur der Entwickler sagen.
                                        Generell gilt aber:
                                        Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten. GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                                        Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                                        Adapter die nur via GitHub installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler darum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                                          lArSaY @ple last edited by
                                          @ple Hallo, sag mal fallen für mein Installateur irgendwelche Kosten an, wenn er mir ein API-Zugang in Fusion Solar anlegt. Mein Installateur stellt sich auf doof! 🤷‍♂️
                                          • Old_Engineer
                                            Old_Engineer last edited by
                                            Kann der Adapter auch Werte schreiben ?
                                            Z.b. Ladeleistung der Batterie ?
                                            1.0k
                                            adapter
                                            45
                                            112
                                            26975
