    4. Iob Diag Mulitihost und VIS Edit Probleme
      toki1973 last edited by
      Habe Probleme, das der VIS Edito ständig keine Verbindung bekommt und ich keine Änderungen vornehmen kann. Hat das was mit dem Problem beim Multihost bei iob diag damit zu tun?
      toki@iobroker:~$ ======================= SUMMARY =======================
                              v.2023-10-10
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-16-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                              /usr/bin/node           v18.19.0
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
                              /usr/bin/corepack       0.22.0
      Recommended versions are nodejs 18.19.0 and npm  Cannot determine Lua scripts strategy: Connection is closed. ["cfg.o.system.host.iobroker"]
      No connection to databases possible ...
      MEMORY:
      Mem:            6.3G        4.7G        958M        532K        923M        1.6G
      Swap:           1.0G        471M        550M
      Total:          7.4G        5.2G        1.5G
      Active iob-Instances:   36
      Active repo(s): stable
      ioBroker Core:          js-controller           5.0.17
                              admin                   6.12.0
      Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
          at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:493:23)
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      ioBroker Status:         Connection is closed.
       Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
       Unable to subscribe to meta namespace "meta." changes: Connection is closed.
      /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
              throw e;
      Error: Connection is closed.
          at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
          at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
      =================== END OF SUMMARY ====================/process/task_queues:95:5):12:23)
        Thomas Braun Most Active @toki1973 last edited by
        @toki1973 sagte in Iob Diag Mulitihost und VIS Edit Probleme:
        Das dürfte schon dein Problem sein.
          toki1973 @Thomas Braun last edited by
          @thomas-braun Das bedeutet? Und was schafft Abhilfe? Ich habe noch kein Redis installiert.
            @toki1973
            Was ist denn das da genau für ein Konstrukt?
            Multihost? Ist das der Server oder der Client?
            Welche Datenbank wurde/wird da verwendet?
              Kein Multihost - das "dachte" das System schonmal. Datenbank ist eigentlich nur Influx im Einsatz . Aber das hat ja hier nichts zu bedeuten
                Homoran Global Moderator Administrators @toki1973 last edited by
                @toki1973 zeig mal den Objektbaum von system.host im Expertenmodus
                  Nein, es ist die Datenbank für states und objects gemeint.
                  Zeig mal die Langfassung von iob diag.
                    toki1973 @Homoran last edited by
                    Sind da noch Altlasten von alten VMs drin?
                    Inzwischen nennt sich das system iobroker welches aktiv ist
                      sieht so aus.
                      für den Screenshot bitte Fenster auf lesbare Größe verkleinern.
                      nicht jeder hat ein 8K-Handy
                      die wichtigere Frage ist, wo sind die alten hosts noch registriert?
                      Nach Restore kein iob host this gemacht?
                      Beim Restore seltsame Meldungen gehabt?
                        toki1973 @Thomas Braun last edited by toki1973
                        Skript v.2023-10-10
                          @homoran said in Iob Diag Mulitihost und VIS Edit Probleme:
                          Nein das habe ich nicht gemacht - jetzt noch tun? Objektbäume löschen?
                            nur, wenn du
                            @homoran sagte in Iob Diag Mulitihost und VIS Edit Probleme:
                            negativ bescheiden kannst
                              Das sind nicht mehr aktive VMs. Buster wurde durch Bookworm durch eine Neuinstallation ersetzt
                                hab ich verstanden.
                                Aber wissen das auch alle Adapter, Objekte usw.?
                                  @homoran Wie kann ich das prüfen?
                                    @toki1973 keine Ahnung!
                                    löschen, und wenn's dann nicht läuft hättest du es nicht löschen dürfen 😂
                                      @homoran 🙄 😄
                                      506
