    4. Test Adapter TP-Link Tapo
      tombox @tombox last edited by
      Die v0.2.1 kann jetzt auch Kamera Bewegung ein debug log für das P100 problem wäre auch hilfreich
      einfach via mail tombox2020@gmail.com
      • metaxa
        metaxa @tombox last edited by metaxa
        @tombox Servus und Danke!
        Ich habe jetzt über Github upgegradet auf 0.2.2.
        Folgendes finde ich beim Neustart im Log
        tapo.0
        2024-01-12 12:06:12.091	warn	Error: Unknown password encryption method
        tapo.0
        2024-01-12 12:06:02.091	warn	Error: Unknown password encryption method
        tapo.0
        2024-01-12 12:05:52.090	warn	Error: Unknown password encryption method
        tapo.0
        2024-01-12 12:05:42.088	warn	Error: Unknown password encryption method
        tapo.0
        2024-01-12 12:05:32.087	warn	Error: Unknown password encryption method
        tapo.0
        2024-01-12 12:05:22.087	warn	Error: Unknown password encryption method
        tapo.0
        2024-01-12 12:05:12.085	warn	Error: Unknown password encryption method
        tapo.0
        2024-01-12 12:05:02.085	warn	Error: Unknown password encryption method
        tapo.0
        2024-01-12 12:04:52.084	warn	Error: Unknown password encryption method
        tapo.0
        2024-01-12 12:04:42.082	warn	Error: Unknown password encryption method
        tapo.0
        2024-01-12 12:04:32.081	warn	Error: Unknown password encryption method
        tapo.0
        2024-01-12 12:04:32.001	info	Start first Update
        tapo.0
        2024-01-12 12:04:21.999	info	Wait for connections for non camera devices
        tapo.0
        2024-01-12 12:04:21.980	warn	No IP found for 8021314EFB57E17626EC16DBDB2A31A51E64292E put the device online or set the ip state manually
        tapo.0
        2024-01-12 12:04:21.976	error	{"error_code":-20571,"msg":"Device is offline"}
        tapo.0
        2024-01-12 12:04:21.575	info	Initialized 80219D887A52D32D03212C4C2DE37E4D21EC8028
        tapo.0
        2024-01-12 12:04:21.520	info	80219D887A52D32D03212C4C2DE37E4D21EC8028 Received device info {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.1.4 Build 230922 Rel.57957n","serialNumber":"31d87f97","hardwareId":1}
        tapo.0
        2024-01-12 12:04:21.451	info	Init device 80219D887A52D32D03212C4C2DE37E4D21EC8028 type C520WS 1.0 with ip 192.168.0.220
        tapo.0
        2024-01-12 12:04:21.244	warn	No IP found for 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 put the device online or set the ip state manually
        tapo.0
        2024-01-12 12:04:21.241	error	{"error_code":-20571,"msg":"Device is offline"}
        tapo.0
        2024-01-12 12:04:20.828	info	Found 3 devices
        tapo.0
        2024-01-12 12:04:20.623	info	Login succesfull
        tapo.0
        2024-01-12 12:04:20.275	info	Login tp TAPO App
        tapo.0
        2024-01-12 12:04:20.203	info	starting. Version 0.2.2 (non-npm: TA2k/ioBroker.tapo#e1cf6255f471f8e3271408e7f2cb0c82fc7049c0) in /opt/iobroker/node_modules/iobroker.tapo, node: v18.18.2, js-controller: 5.0.17
        Wie soll das Steuern funktionieren?
        Egal welche Werte ich eingebe, die Cam bewegt sich nicht.
        Edit: Mit dem onvif funktioniert das recht gut:
        H T 2 Replies Last reply Reply Quote 0
          HeliosFan @metaxa last edited by HeliosFan
          Hallo liebe Community,
          mit Spannung verfolge ich die Beiträge in diesem Thread.
          Ich selbst habe die TP-Link Tapo C 212 Kamera und wäre sehr an einer Steuerung über den ioBroker interessiert.
          Vorgestellt habe ich mir das so:
          Alarmanlage aus: --> Kamera aus.
          Alarmanlage ein: --> Kamera ein, Bewegungserkennung ein, Aufzeichnung bei erkannter Bewegung ein.
          Die Alarmanlage basiert auf HMIP Komponenten in Verbindung mit einer CCU 3. ( Dies zur Info ).
          Daher meine Frage: Funktioniert der TP-Link Tapo Adapter mittlerweilen 100%ig oder nicht ?
          • metaxa
            metaxa @ManiacKill last edited by
            @maniackill So weit bin ich noch nicht, habe mich mit der Visualisierung noch nicht beschäftigt.
              @metaxa Zur Steuerung mit onvif:
              Welche App benutzt Du auf dem Handy ? Gibt im Playstore mehrere.
              Und läuft der onvif Adapter gut ?
              metaxa 1 Reply Last reply Reply Quote 0
                tombox @metaxa last edited by
                @metaxa
                was kommt mit 0.2.3?
                • metaxa
                  metaxa @HeliosFan last edited by
                  @heliosfan Servus! Ich verwende den iO-Broker Adapter onvif zum steuern. Ich will kein Handy zum Steuern verwenden, wenn dann die normale Tapo App. Aber @tombox ist sehr, sehr bemüht mir zu helfen, die Steuerung über seinen Adapter hin zu bekommen. Danke dafür!
                  • metaxa
                    @tombox sagte in Test Adapter TP-Link Tapo:
                    @metaxa
                    tapo.0
                    2024-01-12 17:27:04.181	info	false
                    tapo.0
                    2024-01-12 17:26:32.131	error	Device 80219D887A52D32D03212C4C2DE37E4D21EC8028 has no command refresh
                    tapo.0
                    2024-01-12 17:26:25.552	error	Device 80219D887A52D32D03212C4C2DE37E4D21EC8028 has no command refresh
                    tapo.0
                    2024-01-12 17:26:12.309	info	false
                    tapo.0
                    2024-01-12 17:24:36.176	info	Start first Update
                    tapo.0
                    2024-01-12 17:24:26.175	info	Wait for connections for non camera devices
                    tapo.0
                    2024-01-12 17:24:26.170	warn	No IP found for 8021314EFB57E17626EC16DBDB2A31A51E64292E put the device online or set the ip state manually
                    tapo.0
                    2024-01-12 17:24:26.169	error	{"error_code":-20571,"msg":"Device is offline"}
                    tapo.0
                    2024-01-12 17:24:25.769	info	Initialized 80219D887A52D32D03212C4C2DE37E4D21EC8028
                    tapo.0
                    2024-01-12 17:24:25.765	info	80219D887A52D32D03212C4C2DE37E4D21EC8028 Received device info {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.1.4 Build 230922 Rel.57957n","serialNumber":"31d87f97","hardwareId":1}
                    tapo.0
                    2024-01-12 17:24:25.708	info	Init device 80219D887A52D32D03212C4C2DE37E4D21EC8028 type C520WS 1.0 with ip 192.168.0.220
                    tapo.0
                    2024-01-12 17:24:25.500	warn	No IP found for 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 put the device online or set the ip state manually
                    tapo.0
                    2024-01-12 17:24:25.497	error	{"error_code":-20571,"msg":"Device is offline"}
                    tapo.0
                    2024-01-12 17:24:25.034	info	Found 3 devices
                    tapo.0
                    2024-01-12 17:24:24.793	info	Login succesfull
                    tapo.0
                    2024-01-12 17:24:24.306	info	Login tp TAPO App
                    tapo.0
                    2024-01-12 17:24:24.278	info	starting. Version 0.2.3 (non-npm: TA2k/ioBroker.tapo#bbec46cc9c1e1ab503c391c237783108d1e02785) in /opt/iobroker/node_modules/iobroker.tapo, node: v18.18.2, js-controller: 5.0.17
                    Log sieht sehr unauffälliog aus, perfekt!
                    Die Steuerung jedoch, da passiert gar nichts. Die Cam bleibt stur auf ihrer Position und lässt sich nur mit onvif bewegen.
                      ManiacKill last edited by ManiacKill
                      Moien zusammen,
                      das mit der MoveMotor funktioniert ja soweit, hat jemand eine idee wie ich das ins Vis einbauen kann ? Mit einem kleinen Controller Joystick wenn es so was gibt ?
                      Mit onvif kann ich meine Tapo 225 nicht steuern !
                      • metaxa
                        @maniackill sagte in Test Adapter TP-Link Tapo:
                        Was gibst du da wie und wo ein?
                        Ist ja witzig, bei mir ist es genau umgekehrt.
                        Fixe Positionen könntest du über ein Kreuz mit durchsichtigen Tasten an steuern. Das gefällt mir bei onvif sehr gut. Die fixen Positionen habe ich in der Tapo App gespeichert un d rufe sie dann mit " GoToPreset 'x' " an.
                          ManiacKill @metaxa last edited by
                          @metaxa
                          Ja bei moveMotorStep hab ich mal 180 eingegeben, dann ist die Kamera gefahren. Aber weiß auch nicht so richtig wie ich das einbauen soll 😞
                          V M 3 Replies Last reply Reply Quote 0
                          • V
                            valiumbrause @ManiacKill last edited by
                            Hallo liebe Forum-Mitglieder,
                            ich wende mich mit einem Problem an euch, das ich mit meinen Tapo Cams C320WS erlebe. Speziell geht es um die Funktion des motionEvent. Nach dem Starten der Cams, zum Beispiel bei Schnee oder Regen, wird der entsprechende Datenpunkt für etwa 60 Sekunden oder weniger aktualisiert, was bedeutet, dass Bewegungen erkannt werden. Danach jedoch gibt es keine Aktualisierungen mehr.
                            Ich habe bereits einige Schritte zur Fehlerbehebung unternommen, wie das Löschen der Cams aus der App und einen Reset, leider ohne Erfolg. Auf den Cams ist die aktuelle Firmware-Version 1.1.7 Build 231122 Rel.55299n installiert. Zudem nutze ich die Version 0.2.3 des Tapo Adapters von GitHub.
                            In meinem ioBroker erhalte ich folgende Fehlermeldungen:
                            tapo.0
                            2024-01-13 09:42:58.712 warn Error: StokRefresh: Temporary Suspension: Try again in 540 seconds
                            tapo.0
                            2024-01-13 09:42:28.641 warn Error: StokRefresh: Temporary Suspension: Try again in 571 seconds
                            tapo.0
                            2024-01-13 09:41:58.644 warn Error: StokRefresh: Temporary Suspension: Try again in 600 seconds
                            Gibt es bekannte Lösungen für dieses Problem? Oder alternativ, gibt es andere Wege, um den motionEvent-Datenpunkt zu nutzen, um Bewegungen in ioBroker aufzuzeichnen?
                            Ich würde mich sehr über eure Hilfe und Ratschläge freuen.
                            Mit freundlichen Grüßen,
                            Dirk
                            ra juha 1 Reply Last reply Reply Quote 0
                            • ra juha
                              ra juha @valiumbrause last edited by ra juha
                              Nun auch 0.2.3 installiert.
                              Leider keine Änderung der Zustände Steckdosen p100 der Felder setpowerstate wenn ich über dieTapo App an- und ausschalte.
                              Tut das bei Euch? Oder ist das Problem nur bei mir?
                                tombox @ra juha last edited by
                                @ra-juha bitte immer mit log posten
                                  SaarlandUHU last edited by
                                  ich bin seit heute im Besitz einer C510W. Die Kamera taucht im Adapter auf, leider kann ich den Datenpunkt für die Bewegungserkennung nicht finden. Zuvor hatte ich eine C310 angeschlossen, dort gab es einen Datenpunkt motionevent. Ich würde die Kamera gerne zusätzlich als Bewegungsmelder nutzen, um eine Lampe einzuschalten. Ohne den Datenpunkt motionevent würde die Sache leider nicht funktionieren.
                                  Vielen Dank und Grüße
                                    @saarlanduhu mit der v0.2.3 im debug log mode kannst du genau sehen was passiert auch wenn ein motion event auslösen sollte
                                      SaarlandUHU @tombox last edited by
                                      @tombox Laut App wurde eine Bewegung um 22:18:01 Uhr erkannt.
                                      Ich hab mal für den Zeitraum das Log angehängt. Ich kann da für den Zeitpunkt keine Ausgabe einer Bewegungserkennung sehen. Es sei denn ich habe sie übersehen.
                                      v0.2.3 ist installiert
                                      2024-01-13 22:17:55.999 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                      2024-01-13 22:17:56.123 - debug: tapo.0 (4427) API response: 200
                                      2024-01-13 22:17:56.123 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                      2024-01-13 22:17:56.123 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                      2024-01-13 22:17:56.999 - debug: tapo.0 (4427) Receive camera status
                                      2024-01-13 22:17:57.000 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                      2024-01-13 22:17:57.131 - debug: tapo.0 (4427) API response: 200
                                      2024-01-13 22:17:57.131 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                      2024-01-13 22:17:57.132 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                      2024-01-13 22:17:58.000 - debug: tapo.0 (4427) Receive camera status
                                      2024-01-13 22:17:58.001 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                      2024-01-13 22:17:58.118 - debug: tapo.0 (4427) API response: 200
                                      2024-01-13 22:17:58.119 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                      2024-01-13 22:17:58.119 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                      2024-01-13 22:17:59.001 - debug: tapo.0 (4427) Receive camera status
                                      2024-01-13 22:17:59.002 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                      2024-01-13 22:17:59.147 - debug: tapo.0 (4427) API response: 200
                                      2024-01-13 22:17:59.148 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                      2024-01-13 22:17:59.148 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                      2024-01-13 22:18:00.002 - debug: tapo.0 (4427) Receive camera status
                                      2024-01-13 22:18:00.003 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                      2024-01-13 22:18:00.130 - debug: tapo.0 (4427) API response: 200
                                      2024-01-13 22:18:00.131 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                      2024-01-13 22:18:00.131 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                      2024-01-13 22:18:01.005 - debug: tapo.0 (4427) Receive camera status
                                      2024-01-13 22:18:01.006 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                      2024-01-13 22:18:01.210 - debug: tapo.0 (4427) API response: 200
                                      2024-01-13 22:18:01.210 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                      2024-01-13 22:18:01.210 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                      2024-01-13 22:18:02.007 - debug: tapo.0 (4427) Receive camera status
                                      2024-01-13 22:18:02.007 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                      2024-01-13 22:18:02.134 - debug: tapo.0 (4427) API response: 200
                                      2024-01-13 22:18:02.135 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                      2024-01-13 22:18:02.135 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                      2024-01-13 22:18:03.007 - debug: tapo.0 (4427) Receive camera status
                                      2024-01-13 22:18:03.008 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                      2024-01-13 22:18:03.178 - debug: tapo.0 (4427) API response: 200
                                      2024-01-13 22:18:03.178 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                      2024-01-13 22:18:03.179 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                      2024-01-13 22:18:04.008 - debug: tapo.0 (4427) Receive camera status
                                      2024-01-13 22:18:04.008 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                      2024-01-13 22:18:04.141 - debug: tapo.0 (4427) API response: 200
                                      2024-01-13 22:18:04.142 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                      2024-01-13 22:18:04.142 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                      2024-01-13 22:18:05.010 - debug: tapo.0 (4427) Receive camera status
                                      2024-01-13 22:18:05.010 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                      2024-01-13 22:18:05.209 - debug: tapo.0 (4427) API response: 200
                                      2024-01-13 22:18:05.210 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                      2024-01-13 22:18:05.210 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                      2024-01-13 22:18:06.010 - debug: tapo.0 (4427) Receive camera status
                                      2024-01-13 22:18:06.011 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                      2024-01-13 22:18:06.157 - debug: tapo.0 (4427) API response: 200
                                      2024-01-13 22:18:06.157 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                      2024-01-13 22:18:06.157 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                      2024-01-13 22:18:07.011 - debug: tapo.0 (4427) Receive camera status
                                      2024-01-13 22:18:07.011 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                      2024-01-13 22:18:07.273 - debug: tapo.0 (4427) API response: 200
                                      2024-01-13 22:18:07.274 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                      2024-01-13 22:18:07.274 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                      2024-01-13 22:18:08.012 - debug: tapo.0 (4427) Receive camera status
                                      2024-01-13 22:18:08.012 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                      2024-01-13 22:18:08.156 - debug: tapo.0 (4427) API response: 200
                                      2024-01-13 22:18:08.156 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                      2024-01-13 22:18:08.157 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                      2024-01-13 22:18:09.012 - debug: tapo.0 (4427) Receive camera status
                                      2024-01-13 22:18:09.015 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                      2024-01-13 22:18:09.304 - debug: tapo.0 (4427) API response: 200
                                      2024-01-13 22:18:09.305 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                      2024-01-13 22:18:09.305 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                      2024-01-13 22:18:10.013 - debug: tapo.0 (4427) Receive camera status
                                      metaxa T 2 Replies Last reply Reply Quote 0
                                      • metaxa
                                        metaxa @SaarlandUHU last edited by metaxa
                                        @saarlanduhu @tombox
                                        Ich kann bei meiner C520WS leider auch mit der 0.2.3 keinen Event erkennen.
                                        Ist der MFA Code verpflichtend? Den habe ich nie bekommen! Wann sollte der kommen?
                                          tombox @SaarlandUHU last edited by
                                          @saarlanduhu der start bei dem der motion event erstellt wird ist interessanter
                                            @tombox du meinst den Adapterstart?
                                            753
                                            191276
