    4. Test Adapter TP-Link Tapo
    • metaxa
      metaxa @tombox last edited by metaxa
      @tombox Servus und Danke!
      Ich habe jetzt über Github upgegradet auf 0.2.2.
      Folgendes finde ich beim Neustart im Log
      tapo.0
      2024-01-12 12:06:12.091	warn	Error: Unknown password encryption method
      tapo.0
      2024-01-12 12:06:02.091	warn	Error: Unknown password encryption method
      tapo.0
      2024-01-12 12:05:52.090	warn	Error: Unknown password encryption method
      tapo.0
      2024-01-12 12:05:42.088	warn	Error: Unknown password encryption method
      tapo.0
      2024-01-12 12:05:32.087	warn	Error: Unknown password encryption method
      tapo.0
      2024-01-12 12:05:22.087	warn	Error: Unknown password encryption method
      tapo.0
      2024-01-12 12:05:12.085	warn	Error: Unknown password encryption method
      tapo.0
      2024-01-12 12:05:02.085	warn	Error: Unknown password encryption method
      tapo.0
      2024-01-12 12:04:52.084	warn	Error: Unknown password encryption method
      tapo.0
      2024-01-12 12:04:42.082	warn	Error: Unknown password encryption method
      tapo.0
      2024-01-12 12:04:32.081	warn	Error: Unknown password encryption method
      tapo.0
      2024-01-12 12:04:32.001	info	Start first Update
      tapo.0
      2024-01-12 12:04:21.999	info	Wait for connections for non camera devices
      tapo.0
      2024-01-12 12:04:21.980	warn	No IP found for 8021314EFB57E17626EC16DBDB2A31A51E64292E put the device online or set the ip state manually
      tapo.0
      2024-01-12 12:04:21.976	error	{"error_code":-20571,"msg":"Device is offline"}
      tapo.0
      2024-01-12 12:04:21.575	info	Initialized 80219D887A52D32D03212C4C2DE37E4D21EC8028
      tapo.0
      2024-01-12 12:04:21.520	info	80219D887A52D32D03212C4C2DE37E4D21EC8028 Received device info {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.1.4 Build 230922 Rel.57957n","serialNumber":"31d87f97","hardwareId":1}
      tapo.0
      2024-01-12 12:04:21.451	info	Init device 80219D887A52D32D03212C4C2DE37E4D21EC8028 type C520WS 1.0 with ip 192.168.0.220
      tapo.0
      2024-01-12 12:04:21.244	warn	No IP found for 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 put the device online or set the ip state manually
      tapo.0
      2024-01-12 12:04:21.241	error	{"error_code":-20571,"msg":"Device is offline"}
      tapo.0
      2024-01-12 12:04:20.828	info	Found 3 devices
      tapo.0
      2024-01-12 12:04:20.623	info	Login succesfull
      tapo.0
      2024-01-12 12:04:20.275	info	Login tp TAPO App
      tapo.0
      2024-01-12 12:04:20.203	info	starting. Version 0.2.2 (non-npm: TA2k/ioBroker.tapo#e1cf6255f471f8e3271408e7f2cb0c82fc7049c0) in /opt/iobroker/node_modules/iobroker.tapo, node: v18.18.2, js-controller: 5.0.17
      Wie soll das Steuern funktionieren?
      Egal welche Werte ich eingebe, die Cam bewegt sich nicht.
      Edit: Mit dem onvif funktioniert das recht gut:
      H T 2 Replies Last reply Reply Quote 0
        HeliosFan @metaxa last edited by HeliosFan
        Hallo liebe Community,
        mit Spannung verfolge ich die Beiträge in diesem Thread.
        Ich selbst habe die TP-Link Tapo C 212 Kamera und wäre sehr an einer Steuerung über den ioBroker interessiert.
        Vorgestellt habe ich mir das so:
        Alarmanlage aus: --> Kamera aus.
        Alarmanlage ein: --> Kamera ein, Bewegungserkennung ein, Aufzeichnung bei erkannter Bewegung ein.
        Die Alarmanlage basiert auf HMIP Komponenten in Verbindung mit einer CCU 3. ( Dies zur Info ).
        Daher meine Frage: Funktioniert der TP-Link Tapo Adapter mittlerweilen 100%ig oder nicht ?
        • metaxa
          metaxa @ManiacKill last edited by
          @maniackill So weit bin ich noch nicht, habe mich mit der Visualisierung noch nicht beschäftigt.
            @metaxa Zur Steuerung mit onvif:
            Welche App benutzt Du auf dem Handy ? Gibt im Playstore mehrere.
            Und läuft der onvif Adapter gut ?
            metaxa 1 Reply Last reply Reply Quote 0
              tombox @metaxa last edited by
              @metaxa
              was kommt mit 0.2.3?
              • metaxa
                metaxa @HeliosFan last edited by
                @heliosfan Servus! Ich verwende den iO-Broker Adapter onvif zum steuern. Ich will kein Handy zum Steuern verwenden, wenn dann die normale Tapo App. Aber @tombox ist sehr, sehr bemüht mir zu helfen, die Steuerung über seinen Adapter hin zu bekommen. Danke dafür!
                • metaxa
                  @tombox sagte in Test Adapter TP-Link Tapo:
                  @metaxa
                  tapo.0
                  2024-01-12 17:27:04.181	info	false
                  tapo.0
                  2024-01-12 17:26:32.131	error	Device 80219D887A52D32D03212C4C2DE37E4D21EC8028 has no command refresh
                  tapo.0
                  2024-01-12 17:26:25.552	error	Device 80219D887A52D32D03212C4C2DE37E4D21EC8028 has no command refresh
                  tapo.0
                  2024-01-12 17:26:12.309	info	false
                  tapo.0
                  2024-01-12 17:24:36.176	info	Start first Update
                  tapo.0
                  2024-01-12 17:24:26.175	info	Wait for connections for non camera devices
                  tapo.0
                  2024-01-12 17:24:26.170	warn	No IP found for 8021314EFB57E17626EC16DBDB2A31A51E64292E put the device online or set the ip state manually
                  tapo.0
                  2024-01-12 17:24:26.169	error	{"error_code":-20571,"msg":"Device is offline"}
                  tapo.0
                  2024-01-12 17:24:25.769	info	Initialized 80219D887A52D32D03212C4C2DE37E4D21EC8028
                  tapo.0
                  2024-01-12 17:24:25.765	info	80219D887A52D32D03212C4C2DE37E4D21EC8028 Received device info {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.1.4 Build 230922 Rel.57957n","serialNumber":"31d87f97","hardwareId":1}
                  tapo.0
                  2024-01-12 17:24:25.708	info	Init device 80219D887A52D32D03212C4C2DE37E4D21EC8028 type C520WS 1.0 with ip 192.168.0.220
                  tapo.0
                  2024-01-12 17:24:25.500	warn	No IP found for 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 put the device online or set the ip state manually
                  tapo.0
                  2024-01-12 17:24:25.497	error	{"error_code":-20571,"msg":"Device is offline"}
                  tapo.0
                  2024-01-12 17:24:25.034	info	Found 3 devices
                  tapo.0
                  2024-01-12 17:24:24.793	info	Login succesfull
                  tapo.0
                  2024-01-12 17:24:24.306	info	Login tp TAPO App
                  tapo.0
                  2024-01-12 17:24:24.278	info	starting. Version 0.2.3 (non-npm: TA2k/ioBroker.tapo#bbec46cc9c1e1ab503c391c237783108d1e02785) in /opt/iobroker/node_modules/iobroker.tapo, node: v18.18.2, js-controller: 5.0.17
                  Log sieht sehr unauffälliog aus, perfekt!
                  Die Steuerung jedoch, da passiert gar nichts. Die Cam bleibt stur auf ihrer Position und lässt sich nur mit onvif bewegen.
                    ManiacKill last edited by ManiacKill
                    Moien zusammen,
                    das mit der MoveMotor funktioniert ja soweit, hat jemand eine idee wie ich das ins Vis einbauen kann ? Mit einem kleinen Controller Joystick wenn es so was gibt ?
                    Mit onvif kann ich meine Tapo 225 nicht steuern !
                    • metaxa
                      @maniackill sagte in Test Adapter TP-Link Tapo:
                      Was gibst du da wie und wo ein?
                      Ist ja witzig, bei mir ist es genau umgekehrt.
                      Fixe Positionen könntest du über ein Kreuz mit durchsichtigen Tasten an steuern. Das gefällt mir bei onvif sehr gut. Die fixen Positionen habe ich in der Tapo App gespeichert un d rufe sie dann mit " GoToPreset 'x' " an.
                        ManiacKill @metaxa last edited by
                        @metaxa
                        Ja bei moveMotorStep hab ich mal 180 eingegeben, dann ist die Kamera gefahren. Aber weiß auch nicht so richtig wie ich das einbauen soll 😞
                        V M 3 Replies Last reply Reply Quote 0
                        • V
                          valiumbrause @ManiacKill last edited by
                          Hallo liebe Forum-Mitglieder,
                          ich wende mich mit einem Problem an euch, das ich mit meinen Tapo Cams C320WS erlebe. Speziell geht es um die Funktion des motionEvent. Nach dem Starten der Cams, zum Beispiel bei Schnee oder Regen, wird der entsprechende Datenpunkt für etwa 60 Sekunden oder weniger aktualisiert, was bedeutet, dass Bewegungen erkannt werden. Danach jedoch gibt es keine Aktualisierungen mehr.
                          Ich habe bereits einige Schritte zur Fehlerbehebung unternommen, wie das Löschen der Cams aus der App und einen Reset, leider ohne Erfolg. Auf den Cams ist die aktuelle Firmware-Version 1.1.7 Build 231122 Rel.55299n installiert. Zudem nutze ich die Version 0.2.3 des Tapo Adapters von GitHub.
                          In meinem ioBroker erhalte ich folgende Fehlermeldungen:
                          tapo.0
                          2024-01-13 09:42:58.712 warn Error: StokRefresh: Temporary Suspension: Try again in 540 seconds
                          tapo.0
                          2024-01-13 09:42:28.641 warn Error: StokRefresh: Temporary Suspension: Try again in 571 seconds
                          tapo.0
                          2024-01-13 09:41:58.644 warn Error: StokRefresh: Temporary Suspension: Try again in 600 seconds
                          Gibt es bekannte Lösungen für dieses Problem? Oder alternativ, gibt es andere Wege, um den motionEvent-Datenpunkt zu nutzen, um Bewegungen in ioBroker aufzuzeichnen?
                          Ich würde mich sehr über eure Hilfe und Ratschläge freuen.
                          Mit freundlichen Grüßen,
                          Dirk
                          ra juha 1 Reply Last reply Reply Quote 0
                          • ra juha
                            ra juha @valiumbrause last edited by ra juha
                            Nun auch 0.2.3 installiert.
                            Leider keine Änderung der Zustände Steckdosen p100 der Felder setpowerstate wenn ich über dieTapo App an- und ausschalte.
                            Tut das bei Euch? Oder ist das Problem nur bei mir?
                              tombox @ra juha last edited by
                              @ra-juha bitte immer mit log posten
                                SaarlandUHU last edited by
                                ich bin seit heute im Besitz einer C510W. Die Kamera taucht im Adapter auf, leider kann ich den Datenpunkt für die Bewegungserkennung nicht finden. Zuvor hatte ich eine C310 angeschlossen, dort gab es einen Datenpunkt motionevent. Ich würde die Kamera gerne zusätzlich als Bewegungsmelder nutzen, um eine Lampe einzuschalten. Ohne den Datenpunkt motionevent würde die Sache leider nicht funktionieren.
                                Vielen Dank und Grüße
                                  @saarlanduhu mit der v0.2.3 im debug log mode kannst du genau sehen was passiert auch wenn ein motion event auslösen sollte
                                    SaarlandUHU @tombox last edited by
                                    @tombox Laut App wurde eine Bewegung um 22:18:01 Uhr erkannt.
                                    Ich hab mal für den Zeitraum das Log angehängt. Ich kann da für den Zeitpunkt keine Ausgabe einer Bewegungserkennung sehen. Es sei denn ich habe sie übersehen.
                                    v0.2.3 ist installiert
                                    2024-01-13 22:17:55.999 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                    2024-01-13 22:17:56.123 - debug: tapo.0 (4427) API response: 200
                                    2024-01-13 22:17:56.123 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                    2024-01-13 22:17:56.123 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                    2024-01-13 22:17:56.999 - debug: tapo.0 (4427) Receive camera status
                                    2024-01-13 22:17:57.000 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                    2024-01-13 22:17:57.131 - debug: tapo.0 (4427) API response: 200
                                    2024-01-13 22:17:57.131 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                    2024-01-13 22:17:57.132 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                    2024-01-13 22:17:58.000 - debug: tapo.0 (4427) Receive camera status
                                    2024-01-13 22:17:58.001 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                    2024-01-13 22:17:58.118 - debug: tapo.0 (4427) API response: 200
                                    2024-01-13 22:17:58.119 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                    2024-01-13 22:17:58.119 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                    2024-01-13 22:17:59.001 - debug: tapo.0 (4427) Receive camera status
                                    2024-01-13 22:17:59.002 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                    2024-01-13 22:17:59.147 - debug: tapo.0 (4427) API response: 200
                                    2024-01-13 22:17:59.148 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                    2024-01-13 22:17:59.148 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                    2024-01-13 22:18:00.002 - debug: tapo.0 (4427) Receive camera status
                                    2024-01-13 22:18:00.003 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                    2024-01-13 22:18:00.130 - debug: tapo.0 (4427) API response: 200
                                    2024-01-13 22:18:00.131 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                    2024-01-13 22:18:00.131 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                    2024-01-13 22:18:01.005 - debug: tapo.0 (4427) Receive camera status
                                    2024-01-13 22:18:01.006 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                    2024-01-13 22:18:01.210 - debug: tapo.0 (4427) API response: 200
                                    2024-01-13 22:18:01.210 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                    2024-01-13 22:18:01.210 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                    2024-01-13 22:18:02.007 - debug: tapo.0 (4427) Receive camera status
                                    2024-01-13 22:18:02.007 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                    2024-01-13 22:18:02.134 - debug: tapo.0 (4427) API response: 200
                                    2024-01-13 22:18:02.135 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                    2024-01-13 22:18:02.135 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                    2024-01-13 22:18:03.007 - debug: tapo.0 (4427) Receive camera status
                                    2024-01-13 22:18:03.008 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                    2024-01-13 22:18:03.178 - debug: tapo.0 (4427) API response: 200
                                    2024-01-13 22:18:03.178 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                    2024-01-13 22:18:03.179 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                    2024-01-13 22:18:04.008 - debug: tapo.0 (4427) Receive camera status
                                    2024-01-13 22:18:04.008 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                    2024-01-13 22:18:04.141 - debug: tapo.0 (4427) API response: 200
                                    2024-01-13 22:18:04.142 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                    2024-01-13 22:18:04.142 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                    2024-01-13 22:18:05.010 - debug: tapo.0 (4427) Receive camera status
                                    2024-01-13 22:18:05.010 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                    2024-01-13 22:18:05.209 - debug: tapo.0 (4427) API response: 200
                                    2024-01-13 22:18:05.210 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                    2024-01-13 22:18:05.210 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                    2024-01-13 22:18:06.010 - debug: tapo.0 (4427) Receive camera status
                                    2024-01-13 22:18:06.011 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                    2024-01-13 22:18:06.157 - debug: tapo.0 (4427) API response: 200
                                    2024-01-13 22:18:06.157 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                    2024-01-13 22:18:06.157 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                    2024-01-13 22:18:07.011 - debug: tapo.0 (4427) Receive camera status
                                    2024-01-13 22:18:07.011 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                    2024-01-13 22:18:07.273 - debug: tapo.0 (4427) API response: 200
                                    2024-01-13 22:18:07.274 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                    2024-01-13 22:18:07.274 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                    2024-01-13 22:18:08.012 - debug: tapo.0 (4427) Receive camera status
                                    2024-01-13 22:18:08.012 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                    2024-01-13 22:18:08.156 - debug: tapo.0 (4427) API response: 200
                                    2024-01-13 22:18:08.156 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                    2024-01-13 22:18:08.157 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                    2024-01-13 22:18:09.012 - debug: tapo.0 (4427) Receive camera status
                                    2024-01-13 22:18:09.015 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                    2024-01-13 22:18:09.304 - debug: tapo.0 (4427) API response: 200
                                    2024-01-13 22:18:09.305 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                    2024-01-13 22:18:09.305 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                    2024-01-13 22:18:10.013 - debug: tapo.0 (4427) Receive camera status
                                    metaxa T 2 Replies Last reply Reply Quote 0
                                    • metaxa
                                      metaxa @SaarlandUHU last edited by metaxa
                                      @saarlanduhu @tombox
                                      Ich kann bei meiner C520WS leider auch mit der 0.2.3 keinen Event erkennen.
                                      Ist der MFA Code verpflichtend? Den habe ich nie bekommen! Wann sollte der kommen?
                                        tombox @SaarlandUHU last edited by
                                        @saarlanduhu der start bei dem der motion event erstellt wird ist interessanter
                                          @tombox du meinst den Adapterstart?
                                            @tombox ich habe jetzt den Adapter zum erzeugen des logs jetzt nochmal gestoppt und wieder gestartet, danach ist der Datenpunkt motionevent aufgetaucht und er funktioniert auch. warum er bei den vorherigen neustarts des Adapters nicht erzeugt wurde...man weiß es nicht. Auf jeden Fall ist er jetzt da und funktioniert.
                                            Dennoch vielen Dank für die unterstützung.
                                            Der Vollständigkeit halber hier noch das Log:
                                            2024-01-13 23:25:32.944  - info: tapo.0 (8915) Initialized 80227C9387D02CB80B2A97FAA7B45D451F6DBE41
                                            2024-01-13 23:25:32.944  - debug: tapo.0 (8915) initResult 80227C9387D02CB80B2A97FAA7B45D451F6DBE41 undefined
                                            2024-01-13 23:25:33.183  - debug: tapo.0 (8915) {"hwVer":"1.0","category":"camera","model":"C510W 1.0","ssid":"wINTERNETZ_is_coming","mac":"A842A1382FE0","hwId":"FE658AE4C353452D7B112AB94C679C3D","fwId":"0C03EB093C956BD3C9F7551B5C4795C6","oemId":"CBF298FDF6A1EA18D53CCB1E4D60CCB9","fwVer":"1.1.1 Build 231107 Rel.67816n","ip":"192.168.178.104","onboardingTime":1705167105,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                            2024-01-13 23:25:33.184  - info: tapo.0 (8915) Init device 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24 type C510W 1.0 with ip 192.168.178.104
                                            2024-01-13 23:25:33.186  - debug: tapo.0 (8915) Constructing Camera on host: 192.168.178.104
                                            2024-01-13 23:25:33.467  - info: tapo.0 (8915) 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24 Received device info {"manufacturer":"tp-link","model":"Tapo C510W","firmwareVersion":"1.1.1 Build 231107 Rel.67816n","serialNumber":"a1382fe0","hardwareId":1}
                                            2024-01-13 23:25:33.469  - debug: tapo.0 (8915) {"manufacturer":"tp-link","model":"Tapo C510W","firmwareVersion":"1.1.1 Build 231107 Rel.67816n","serialNumber":"a1382fe0","hardwareId":1}
                                            2024-01-13 23:25:33.470  - debug: tapo.0 (8915) Init event emitter for 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24
                                            2024-01-13 23:25:33.551  - debug: tapo.0 (8915) Init event listener for "motion"
                                            2024-01-13 23:25:33.552  - info: tapo.0 (8915) Initialized 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24
                                            2024-01-13 23:25:33.553  - debug: tapo.0 (8915) initResult 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24 undefined
                                            2024-01-13 23:25:33.759  - debug: tapo.0 (8915) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"d0lOVEVSTkVUWl9pc19jb21pbmc=","mac":"B0A7B9DD8161","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"192.168.178.48","onboardingTime":1,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                            2024-01-13 23:25:33.770  - info: tapo.0 (8915) Init device 8022409EF7482B099F90B71629A073D31F050586 type P100 with ip 192.168.178.48
                                            2024-01-13 23:25:33.773  - debug: tapo.0 (8915) Constructing P100 on host: 192.168.178.48
                                            2024-01-13 23:25:33.910  - debug: tapo.0 (8915) Handshake P100 on host: 192.168.178.48
                                            2024-01-13 23:25:36.975  - error: tapo.0 (8915) connect EHOSTUNREACH 192.168.178.48:80
                                            2024-01-13 23:25:36.976  - error: tapo.0 (8915) 52 - Get Device Info failed
                                            2024-01-13 23:25:36.976  - info: tapo.0 (8915) Initialized 8022409EF7482B099F90B71629A073D31F050586
                                            2024-01-13 23:25:36.976  - debug: tapo.0 (8915) initResult 8022409EF7482B099F90B71629A073D31F050586 undefined
                                            2024-01-13 23:25:37.152  - debug: tapo.0 (8915) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"d0lOVEVSTkVUWl9pc19jb21pbmc=","mac":"B4B024E5C6FD","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"192.168.178.85","onboardingTime":1,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                            2024-01-13 23:25:37.153  - info: tapo.0 (8915) Init device 8022F09FD11B3954491C051CBA331E321F6E863A type P100 with ip 192.168.178.85
                                            2024-01-13 23:25:37.155  - debug: tapo.0 (8915) Constructing P100 on host: 192.168.178.85
                                            2024-01-13 23:25:37.351  - debug: tapo.0 (8915) Handshake P100 on host: 192.168.178.85
                                            2024-01-13 23:25:38.941  - info: daswetter.1 (8891) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                            2024-01-13 23:25:39.527  - info: daswetter.1 (8891) cleaned everything up...
                                            2024-01-13 23:25:39.552  - info: host.raspberrypi instance system.adapter.daswetter.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2024-01-13 23:25:40.430  - error: tapo.0 (8915) connect EHOSTUNREACH 192.168.178.85:80
                                            2024-01-13 23:25:40.431  - error: tapo.0 (8915) 52 - Get Device Info failed
                                            2024-01-13 23:25:40.432  - info: tapo.0 (8915) Initialized 8022F09FD11B3954491C051CBA331E321F6E863A
                                            2024-01-13 23:25:40.432  - debug: tapo.0 (8915) initResult 8022F09FD11B3954491C051CBA331E321F6E863A undefined
                                            2024-01-13 23:25:40.478  - info: tapo.0 (8915) Wait for connections for non camera devices
                                            2024-01-13 23:25:50.480  - info: tapo.0 (8915) Start first Update
                                            2024-01-13 23:25:50.482  - debug: tapo.0 (8915) Receive camera status
                                            2024-01-13 23:25:50.484  - debug: tapo.0 (8915) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                            2024-01-13 23:25:50.651  - debug: tapo.0 (8915) {"size":0,"timeout":0}
                                            2024-01-13 23:25:50.656  - debug: tapo.0 (8915) isSecureConnection response :>> 200[object Object]
                                            2024-01-13 23:25:50.658  - debug: tapo.0 (8915) StokRefresh: Using secure connection
                                            2024-01-13 23:25:50.813  - debug: tapo.0 (8915) StokRefresh: Login response :>> 200{"result":{"data":{"code":-40401,"time":8,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBALf3HOqgCbEl58R8KxobE+QF6aC4fYBgFAR0Rko2NeUr1+i9ZJ3jvZqxwN+q1yMSt6G7VHKsmW8LAFieLHuL8RMCAwEAAQ==","nonce":"E80CEFF784371D31","device_confirm":"03A68326AC9437CB8EBC251DA490CBF4CA13B87D3DC046340144E7BFF57CE6C6E80CEFF784371D3126A07297E4FDC85E"}},"error_code":-40413}
                                            2024-01-13 23:25:50.954  - debug: tapo.0 (8915) StokRefresh: Start_seq response :>>
                                            2024-01-13 23:25:50.955  - debug: tapo.0 (8915) StokRefresh: Success :>>OW66BO6rCjC.613B8E6DDAXNjUAXC5Tv
                                            2024-01-13 23:25:51.098  - debug: tapo.0 (8915) API response: 200
                                            2024-01-13 23:25:51.098  - debug: tapo.0 (8915) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                            2024-01-13 23:25:51.099  - debug: tapo.0 (8915) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                            2024-01-13 23:25:52.101  - debug: tapo.0 (8915) Receive camera status
                                            2024-01-13 23:25:52.101  - debug: tapo.0 (8915) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                            2024-01-13 23:25:52.300  - debug: tapo.0 (8915) API response: 200
                                            753
                                            191115
