    3. Einsteigerfragen
    4. Installation
    5. kann keinen Adapter mehr updaten
      Homoran Global Moderator Administrators @maximal1981 last edited by
      @maximal1981 sagte in kann keinen Adapter mehr updaten:
      ich hab nichts verbogen
      du bist als root unterwegs und hast mit
      npm install -g npm@8
      den Zusammenhalt von nodejs mit der npm Version unterbrochen
        Thomas Braun Most Active @maximal1981 last edited by
        @maximal1981
        Und wie IMMER: NICHT ALS ROOT HERUMKASPERN!!!!
        Als user probieren:
        iob nodejs-update 18
        maximal1981 1 Reply Last reply Reply Quote 1
        • maximal1981
          maximal1981 @Thomas Braun last edited by
          @thomas-braun sagte in kann keinen Adapter mehr updaten:
          ioBroker nodejs updater 2023-10-13
          You requested to intall latest version from nodejs v18 tree.
          Your current setup is:
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
          /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
          /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
          /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
          *** nodejs is NOT correctly installed ***
          We found these nodejs versions available for installation:
          nodejs:
            Installed: 18.19.0+dfsg-6~deb12u1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org bookworm-security/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0+dfsg1-1 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          Your nodejs-Installation seems to be faulty. Shall we try to fix it?
          Press <y> to continue or any other key to quit
          Fixing your nodejs setup
          *** Deleting  ***
          rm: cannot remove '': No such file or directory
          *** Deleting  ***
          Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
          You are running nodejs v18.19.0. Do you want to install latest version from nodejs v.18 tree?
          Trying to update your installation now. Please be patient.
          Virtualization: lxc
          Waiting for ioBroker to shut down - Give me a minute...
          *** These repos are active on your system:
          Hit:2 http://security.debian.org bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Reading package lists... Done
          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
          Package: nodejs
          Pin: origin deb.nodesource.com
          Pin-Priority: 1001
          *** These repos are active after the adjustments:
          Hit:1 http://security.debian.org bookworm-security InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
          Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [6634 B]
          Fetched 18.8 kB in 0s (48.2 kB/s)
          Installing the recommended nodejs version now!
          Installing the recommended nodejs version!
          E: Broken packages
          *** You need to manually restart your container/virtual machine now! ***
          We tried our best to update or fix your nodejs. Please run 'iob diag' again to verify.
          reboot
                                  v.2023-10-10
           Static hostname: iobroker
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
                    Kernel: Linux 6.2.16-3-pve
              Architecture: x86-64
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               amd64
          Timezone:               Europe/Vienna (CET, +0100)
          User-ID:                1000
          X-Server:               false
          Boot Target:            graphical.target
          Pending OS-Updates:     0
          Pending iob updates:    7
          Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
          /home/iobroker/.diag.sh: line 488: npm: command not found
          /home/iobroker/.diag.sh: line 489: npx: command not found
          /home/iobroker/.diag.sh: line 490: corepack: command not found
          Recommended versions are nodejs 18.19.0 and npm 10.2.3
          Wrong installation path detected. This needs to be fixed.
          Please check
          https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
          for more information on how to fix these errors.
          MEMORY:
          Mem:            6.4G        1.7G        4.3G        118K        485M        4.8G
          Swap:           1.1G          0B        1.1G
          Total:          7.5G        1.7G        5.4G
          Active iob-Instances:   20
          Active repo(s): stable
          ioBroker Core:          js-controller           5.0.12
                                  admin                   6.12.0
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                26635
          States:                 22791
          Size of iob-Database:
          39M     /opt/iobroker/iobroker-data/objects.jsonl
          26M     /opt/iobroker/iobroker-data/states.jsonl
            @maximal1981 ist das vollständig?
            wieso sehe ich die Eingabezeilen nie?
              Thomas Braun Most Active @maximal1981 last edited by Thomas Braun
              @maximal1981
              apt policy nodejs
              sudo apt install nodejs=18.19.0-1nodesource1
              maximal1981 1 Reply Last reply Reply Quote 0
              • maximal1981
                maximal1981 @Thomas Braun last edited by maximal1981
                @thomas-braun weil ich dann auch nicht mehr sehe. Das ist was ich nach den aufrufen bekomme.
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                /usr/bin/corepack       0.22.0
                nodejs:
                  Installed: 18.19.0-1nodesource1
                  Version table:
                 *** 18.19.0-1nodesource1 1001
                     18.13.0+dfsg1-1 500
                Nothing to do - Your installation is using the correct paths.
                Virtualization: lxc
                Package: nodejs
                Pin-Priority: 1001
                Fetched 18.8 kB in 0s (50.6 kB/s)
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                  Virtualization: lxc
                model name      : AMD Ryzen 5 5600U with Radeon Graphics
                Docker          : false
                Virtualization  : lxc
                Kernel          : x86_64
                Userland        : amd64
                Systemuptime and Load:
                 19:20:05 up 0 min,  2 users,  load average: 1.36, 1.07, 1.02
                CPU threads: 12
                *** Time and Time Zones ***
                               Local time: Fri 2024-01-12 19:20:05 CET
                           Universal time: Fri 2024-01-12 18:20:05 UTC
                                 RTC time: n/a
                                Time zone: Europe/Vienna (CET, +0100)
                              NTP service: inactive
                          RTC in local TZ: no
                *** User and Groups ***
                maximal1981
                /home/maximal1981
                maximal1981 sudo users iobroker
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:            6.4G        1.1G        5.0G        118K        298M        5.3G
                Swap:           1.1G          0B        1.1G
                Total:          7.5G        1.1G        6.1G
                         6144 M total memory
                         1071 M used memory
                          123 M active memory
                         1172 M inactive memory
                         4787 M free memory
                            0 M buffer memory
                          284 M swap cache
                         1024 M total swap
                            0 M used swap
                         1024 M free swap
                *** FAILED SERVICES ***
                  UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                LOAD   = Reflects whether the unit definition was properly loaded.
                ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                SUB    = The low-level unit activation state, values depend on unit type.
                1 loaded units listed.
                *** FILESYSTEM ***
                Filesystem                       Type      Size  Used Avail Use% Mounted on
                /dev/mapper/pve-vm--101--disk--0 ext4      7.8G  5.0G  2.4G  68% /
                none                             tmpfs     492K  4.0K  488K   1% /dev
                udev                             devtmpfs  7.5G     0  7.5G   0% /dev/tty
                tmpfs                            tmpfs     7.6G     0  7.6G   0% /dev/shm
                tmpfs                            tmpfs     3.1G  112K  3.1G   1% /run
                tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                dmesg: read kernel buffer failed: Operation not permitted
                TARGET SOURCE                           FSTYPE OPTIONS
                /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
                /var:
                862M    /var/
                470M    /var/log
                469M    /var/log/journal/fdf5cd495bb345a58900f9d60cd51d5c
                246M    /var/cache
                Archived and active journals take up 10.9M in the file system.
                /opt/iobroker/backups:
                453M    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                548M    /opt/iobroker/iobroker-data/
                342M    /opt/iobroker/iobroker-data/files
                136M    /opt/iobroker/iobroker-data/backup-objects
                78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                67M     /opt/iobroker/iobroker-data/files/javascript.admin
                39M     /opt/iobroker/iobroker-data/states.jsonl
                30M     /opt/iobroker/iobroker-data/objects.jsonl
                21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                21M     /opt/iobroker/iobroker-data/files/0_userdata.0/iobroker_2023_09_02-14_14_06_backupiobroker.tar.gz
                9.2M    /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
                USB-Devices by-id:
                *** NodeJS-Installation ***
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                     18.13.0+dfsg1-1 500
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  5.0.12
                admin:          6.12.0
                javascript:     7.1.6
                Adapters from github:   4
                Adapter State
                  system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                  system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                  system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
                  system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                  system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
                  system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                  system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 - disabled
                + system.adapter.daikin.0                 : daikin                : iobroker                                 -  enabled
                + system.adapter.daikin.1                 : daikin                : iobroker                                 -  enabled
                + system.adapter.daikin.2                 : daikin                : iobroker                                 -  enabled
                  system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                  system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                  system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                  system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                  system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
                  system.adapter.fakeroku.0               : fakeroku              : iobroker                                 - disabled
                  system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                  system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
                  system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : iobroker                                 -  enabled
                  system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                  system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : iobroker                                 -  enabled
                  system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                  system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                  system.adapter.iceroad.0                : iceroad               : iobroker                                 -  enabled
                  system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                  system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                  system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                  system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
                  system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                  system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                  system.adapter.roomba.0                 : roomba                : iobroker                                 -  enabled
                  system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                  system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
                  system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
                  system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                  system.adapter.trashschedule.1          : trashschedule         : iobroker                                 -  enabled
                  system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
                  system.adapter.unifi-protect.0          : unifi-protect         : iobroker                                 -  enabled
                  system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                  system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                  system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                  system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                  system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
                  system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                + instance is alive
                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                ioBroker-Repositories
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 6.12.0   , installed 6.12.0
                Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                Adapter    "awattar"      : 1.0.6    , installed 1.0.6
                Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
                Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
                Adapter    "email"        : 1.2.1    , installed 1.2.1
                Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
                Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                Adapter    "followthesun" : 0.5.0    , installed 0.5.0
                Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.2  [Updatable]
                Adapter    "fuelpricemonitor": 0.4.0 , installed 0.4.0
                Adapter    "harmony"      : 1.3.0    , installed 1.3.0
                Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
                Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
                Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                Controller "js-controller": 5.0.17   , installed 5.0.12 [Updatable]
                Adapter    "logparser"    : 2.2.1    , installed 2.2.0  [Updatable]
                Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                Adapter    "parser"       : 2.0.7    , installed 2.0.7
                Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                Adapter    "pvforecast"   : 2.9.1    , installed 2.9.0  [Updatable]
                Adapter    "roomba"       : 1.2.2    , installed 1.2.2
                Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                Adapter    "tado"         : 0.5.1    , installed 0.4.12 [Updatable]
                Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
                Adapter    "unifi"        : 0.6.7    , installed 0.6.7
                Adapter    "vis-icontwo"  : 1.3.0    , installed 1.0.0  [Updatable]
                Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                Adapter    "vw-connect"   : 0.0.67   , installed 0.5.1
                Adapter    "web"          : 6.1.10   , installed 6.1.10
                Adapter    "ws"           : 2.5.8    , installed 2.5.8
                Objects and States
                Objects:        26635
                States:         22792
                Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                Hit:3 http://security.debian.org bookworm-security InRelease
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          165612264  307/master
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          165607810  1/init
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       165597793  147/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       165597786  147/iobroker.js-con
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       165621427  859/io.mqtt.0
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       165615581  959/io.shelly.1
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          165612265  307/master
                tcp6       0      0 :::3500                 :::*                    LISTEN      1001       165597982  986/io.sonos.0
                tcp6       0      0 :::111                  :::*                    LISTEN      0          165607812  1/init
                tcp6       0      0 :::22                   :::*                    LISTEN      0          165614151  1/init
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       165614262  329/io.admin.1
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          165615976  90/dhclient
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          165607811  1/init
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       165620241  908/io.shelly.0
                udp6       0      0 :::111                  :::*                                0          165607813  1/init
                2024-01-12 19:20:20.257  - info: shelly.1 (959) starting. Version 6.6.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.19.0, js-controller: 5.0.12
                2024-01-12 19:20:20.400  - info: shelly.1 (959) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
                2024-01-12 19:20:20.682  - info: shelly.0 (908) [CoAP] Device 192.168.98.26 (shellygas / shellygas-10521CF345C0 / SHGS-1#10521CF345C0#1) connected! Polltime set to 3600 sec.
                2024-01-12 19:20:21.784  - info: shelly.0 (908) [CoAP] Device 192.168.98.21 (shellyplug-s / shellyplug-s-C70598 / SHPLG-S#C70598#1) connected! Polltime set to 15 sec.
                2024-01-12 19:20:22.109  - info: shelly.0 (908) [CoAP] Device 192.168.99.45 (shellyswitch25 / shellyswitch25-BCDDC277B11B / SHSW-25#BCDDC277B11B#1) connected! Polltime set to 15 sec.
                2024-01-12 19:20:22.445  - info: shelly.0 (908) [CoAP] Device 192.168.98.24 (shelly1pm / shelly1pm-E09806A9E0B6 / SHSW-PM#E09806A9E0B6#1) connected! Polltime set to 15 sec.
                2024-01-12 19:20:22.490  - info: shelly.0 (908) [CoAP] Device 192.168.99.21 (shelly1pm / shelly1pm-68C63AFAE21E / SHSW-PM#68C63AFAE21E#1) connected! Polltime set to 15 sec.
                2024-01-12 19:20:23.224  - info: host.iobroker instance system.adapter.sonos.0 started with pid 986
                2024-01-12 19:20:23.725  - info: sonos.0 (986) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.19.0, js-controller: 5.0.12
                2024-01-12 19:20:23.793  - info: shelly.0 (908) [CoAP] Device 192.168.99.22 (shelly1 / shelly1-C45BBE775B7A / SHSW-1#C45BBE775B7A#1) connected! Polltime set to 15 sec.
                2024-01-12 19:20:24.652  - warn: sonos.0 (986) State "sonos.0.root.192_168_99_32.favorites_list_html" has no existing object, this might lead to an error in future versions
                2024-01-12 19:20:24.652  - info: shelly.0 (908) [CoAP] Device 192.168.99.41 (shellyplug-s / shellyplug-s-B5085F / SHPLG-S#B5085F#1) connected! Polltime set to 15 sec.
                2024-01-12 19:20:24.652  - warn: sonos.0 (986) State "sonos.0.root.192_168_99_47.favorites_list_html" has no existing object, this might lead to an error in future versions
                2024-01-12 19:20:24.653  - warn: sonos.0 (986) State "sonos.0.root.192_168_99_47.favorites_list_html" has no existing object, this might lead to an error in future versions
                2024-01-12 19:20:24.756  - info: shelly.0 (908) [CoAP] Device 192.168.98.30 (shellyplug-s / shellyplug-s-C38343 / SHPLG-S#C38343#1) connected! Polltime set to 15 sec.
                2024-01-12 19:20:25.400  - info: shelly.0 (908) [CoAP] Device 192.168.98.27 (shelly1pm / shelly1pm-E09806A9E311 / SHSW-PM#E09806A9E311#1) connected! Polltime set to 15 sec.
                2024-01-12 19:20:26.407  - info: shelly.0 (908) [CoAP] Device 192.168.99.17 (shelly1 / shelly1-C49979 / SHSW-1#C49979#1) connected! Polltime set to 15 sec.
                2024-01-12 19:20:26.697  - info: shelly.0 (908) [CoAP] Device 192.168.99.30 (shelly1 / shelly1-B8E736 / SHSW-1#B8E736#1) connected! Polltime set to 15 sec.
                2024-01-12 19:20:26.716  - info: shelly.0 (908) [CoAP] Device 192.168.99.40 (shellyswitch25 / shellyswitch25-E098068D445E / SHSW-25#E098068D445E#1) connected! Polltime set to 15 sec.
                2024-01-12 19:20:26.791  - info: shelly.0 (908) [CoAP] Device 192.168.99.35 (shellyswitch25 / shellyswitch25-C45BBE6AB3A2 / SHSW-25#C45BBE6AB3A2#1) connected! Polltime set to 15 sec.
                2024-01-12 19:20:27.221  - info: host.iobroker instance scheduled system.adapter.tvspielfilm.0 */5 * * * *
                2024-01-12 19:20:27.228  - info: host.iobroker instance system.adapter.tvspielfilm.0 started with pid 1571
                2024-01-12 19:20:27.781  - info: shelly.0 (908) [CoAP] Device 192.168.98.214 (shellyplug-s / shellyplug-s-083A8DC3528C / SHPLG-S#083A8DC3528C#1) connected! Polltime set to 15 sec.
                2024-01-12 19:20:27.820  - info: tvspielfilm.0 (1571) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.19.0, js-controller: 5.0.12
                scheint wieder alles normal zu laufen.
                habe aber meines Wissens nichts angegriffen außer eben ein upgrade in linux.
                aber danke für die Hilfe, bist ein Schatz.
                  Für die Zukunft: NIE als root, NIE npm manuell anpacken.
                  Hintergründe zu deinem 'Problem':
                  https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
                  • maximal1981
                    @thomas-braun ich habe npm seit der Einrichtung nicht mehr angefasst.
                    war das letzte mal auf der cli für ein apt upgrade. Hatte aber hier noch nie Probleme mit npm.
                      Das kam durch das Update von debian.
                      ist ein Kollateralschaden.
                      und was war das
                      • maximal1981
                        maximal1981 @Homoran last edited by
                        @homoran das schlug mir die Adapterinstallation vor, da ging aber schon nichts mehr.
                        aber vermutlich wie du als erstes schreibst, kommt es von dem Update vom OS.
                        Aber das hatte ich nie, soll das jetzt nicht umgesetzt werden?
                          @maximal1981
                          Im weiteren:
                          sudo systemctl set-default multi-host.target
                          sudo useradd -a -G adm maximal1981
                          Und schaufel die diversen Adapter-Updates auf die Kiste.
                            klar, npm war ja weg, wie gerade erklärt
                              Doch, du sollst natürlich weiterhin Updates fahren. Allerdings war bei dir das nodesource-Repository noch nicht auf die aktuellste Version mit dem richtigen Pinning umgestellt. Weswegen dir der Paketmanager die aktuellste Version von nodejs eingespielt hat, die aber nicht zum ioBroker passt.
                              Das ist aber jetzt alles wieder richtig, kannst also nun wieder wie gewohnt deine Updates einspielen.
                              1.3k
                              1141
