    3. Einsteigerfragen
    4. Installation
    5. kann keinen Adapter mehr updaten
      Homoran Global Moderator Administrators @maximal1981 last edited by
      @maximal1981 ist das vollständig?
      wieso sehe ich die Eingabezeilen nie?
        Thomas Braun Most Active @maximal1981 last edited by Thomas Braun
        @maximal1981
        apt policy nodejs
        sudo apt install nodejs=18.19.0-1nodesource1
        maximal1981 1 Reply Last reply Reply Quote 0
        • maximal1981
          maximal1981 @Thomas Braun last edited by maximal1981
          @thomas-braun weil ich dann auch nicht mehr sehe. Das ist was ich nach den aufrufen bekomme.
          ioBroker nodejs updater 2023-10-13
          You requested to intall latest version from nodejs v18 tree.
          Your current setup is:
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          /usr/bin/corepack       0.22.0
          We found these nodejs versions available for installation:
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org bookworm-security/main amd64 Packages
           *** 18.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0+dfsg1-1 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          Nothing to do - Your installation is using the correct paths.
          You are running nodejs v18.19.0. Do you want to install latest version from nodejs v.18 tree?
          Press <y> to continue or any other key to quit
          Trying to update your installation now. Please be patient.
          Virtualization: lxc
          Waiting for ioBroker to shut down - Give me a minute...
          *** These repos are active on your system:
          Hit:1 http://security.debian.org bookworm-security InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Reading package lists... Done
          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
          Package: nodejs
          Pin: origin deb.nodesource.com
          Pin-Priority: 1001
          *** These repos are active after the adjustments:
          Hit:2 http://security.debian.org bookworm-security InRelease
          Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
          Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [6634 B]
          Fetched 18.8 kB in 0s (50.6 kB/s)
          Installing the recommended nodejs version now!
          Installing the recommended nodejs version!
          *** You need to manually restart your container/virtual machine now! ***
          We tried our best to update or fix your nodejs. Please run 'iob diag' again to verify.
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
                    Kernel: Linux 6.2.16-3-pve
              Architecture: x86-64
          model name      : AMD Ryzen 5 5600U with Radeon Graphics
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
           19:20:05 up 0 min,  2 users,  load average: 1.36, 1.07, 1.02
          CPU threads: 12
          *** Time and Time Zones ***
                         Local time: Fri 2024-01-12 19:20:05 CET
                     Universal time: Fri 2024-01-12 18:20:05 UTC
                           RTC time: n/a
                          Time zone: Europe/Vienna (CET, +0100)
                        NTP service: inactive
                    RTC in local TZ: no
          *** User and Groups ***
          maximal1981
          /home/maximal1981
          maximal1981 sudo users iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:            6.4G        1.1G        5.0G        118K        298M        5.3G
          Swap:           1.1G          0B        1.1G
          Total:          7.5G        1.1G        6.1G
                   6144 M total memory
                   1071 M used memory
                    123 M active memory
                   1172 M inactive memory
                   4787 M free memory
                      0 M buffer memory
                    284 M swap cache
                   1024 M total swap
                      0 M used swap
                   1024 M free swap
          *** FAILED SERVICES ***
            UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** FILESYSTEM ***
          Filesystem                       Type      Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--101--disk--0 ext4      7.8G  5.0G  2.4G  68% /
          none                             tmpfs     492K  4.0K  488K   1% /dev
          udev                             devtmpfs  7.5G     0  7.5G   0% /dev/tty
          tmpfs                            tmpfs     7.6G     0  7.6G   0% /dev/shm
          tmpfs                            tmpfs     3.1G  112K  3.1G   1% /run
          tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
          dmesg: read kernel buffer failed: Operation not permitted
          TARGET SOURCE                           FSTYPE OPTIONS
          /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
          /var:
          862M    /var/
          470M    /var/log
          469M    /var/log/journal/fdf5cd495bb345a58900f9d60cd51d5c
          246M    /var/cache
          Archived and active journals take up 10.9M in the file system.
          /opt/iobroker/backups:
          453M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          548M    /opt/iobroker/iobroker-data/
          342M    /opt/iobroker/iobroker-data/files
          136M    /opt/iobroker/iobroker-data/backup-objects
          78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
          67M     /opt/iobroker/iobroker-data/files/javascript.admin
          39M     /opt/iobroker/iobroker-data/states.jsonl
          30M     /opt/iobroker/iobroker-data/objects.jsonl
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
          21M     /opt/iobroker/iobroker-data/files/0_userdata.0/iobroker_2023_09_02-14_14_06_backupiobroker.tar.gz
          9.2M    /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.12
          admin:          6.12.0
          javascript:     7.1.6
          Adapters from github:   4
          Adapter State
          + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
            system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
            system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
            system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
            system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 - disabled
          + system.adapter.daikin.0                 : daikin                : iobroker                                 -  enabled
          + system.adapter.daikin.1                 : daikin                : iobroker                                 -  enabled
          + system.adapter.daikin.2                 : daikin                : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
            system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
            system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
            system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
            system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
            system.adapter.fakeroku.0               : fakeroku              : iobroker                                 - disabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
            system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
            system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : iobroker                                 -  enabled
            system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
            system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : iobroker                                 -  enabled
            system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
            system.adapter.iceroad.0                : iceroad               : iobroker                                 -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
            system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
            system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
            system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
            system.adapter.roomba.0                 : roomba                : iobroker                                 -  enabled
            system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
            system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
            system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
            system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            system.adapter.trashschedule.1          : trashschedule         : iobroker                                 -  enabled
            system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
            system.adapter.unifi-protect.0          : unifi-protect         : iobroker                                 -  enabled
            system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
            system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
            system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
            system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + instance is alive
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.12.0   , installed 6.12.0
          Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
          Adapter    "awattar"      : 1.0.6    , installed 1.0.6
          Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "daikin"       : 1.4.2    , installed 1.4.2
          Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
          Adapter    "email"        : 1.2.1    , installed 1.2.1
          Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
          Adapter    "followthesun" : 0.5.0    , installed 0.5.0
          Adapter    "fronius"      : 2.0.2    , installed 2.0.2
          Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.2  [Updatable]
          Adapter    "fuelpricemonitor": 0.4.0 , installed 0.4.0
          Adapter    "harmony"      : 1.3.0    , installed 1.3.0
          Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
          Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.12 [Updatable]
          Adapter    "logparser"    : 2.2.1    , installed 2.2.0  [Updatable]
          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "parser"       : 2.0.7    , installed 2.0.7
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "pvforecast"   : 2.9.1    , installed 2.9.0  [Updatable]
          Adapter    "roomba"       : 1.2.2    , installed 1.2.2
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "tado"         : 0.5.1    , installed 0.4.12 [Updatable]
          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
          Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
          Adapter    "unifi"        : 0.6.7    , installed 0.6.7
          Adapter    "vis-icontwo"  : 1.3.0    , installed 1.0.0  [Updatable]
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vw-connect"   : 0.0.67   , installed 0.5.1
          Adapter    "web"          : 6.1.10   , installed 6.1.10
          Adapter    "ws"           : 2.5.8    , installed 2.5.8
          Objects and States
          Objects:        26635
          States:         22792
          Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
          Hit:3 http://security.debian.org bookworm-security InRelease
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          165612264  307/master
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          165607810  1/init
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       165597793  147/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       165597786  147/iobroker.js-con
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       165621427  859/io.mqtt.0
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       165615581  959/io.shelly.1
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          165612265  307/master
          tcp6       0      0 :::3500                 :::*                    LISTEN      1001       165597982  986/io.sonos.0
          tcp6       0      0 :::111                  :::*                    LISTEN      0          165607812  1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          165614151  1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       165614262  329/io.admin.1
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          165615976  90/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          165607811  1/init
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       165620241  908/io.shelly.0
          udp6       0      0 :::111                  :::*                                0          165607813  1/init
          2024-01-12 19:20:20.257  - info: shelly.1 (959) starting. Version 6.6.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.19.0, js-controller: 5.0.12
          2024-01-12 19:20:20.400  - info: shelly.1 (959) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
          2024-01-12 19:20:20.682  - info: shelly.0 (908) [CoAP] Device 192.168.98.26 (shellygas / shellygas-10521CF345C0 / SHGS-1#10521CF345C0#1) connected! Polltime set to 3600 sec.
          2024-01-12 19:20:21.784  - info: shelly.0 (908) [CoAP] Device 192.168.98.21 (shellyplug-s / shellyplug-s-C70598 / SHPLG-S#C70598#1) connected! Polltime set to 15 sec.
          2024-01-12 19:20:22.109  - info: shelly.0 (908) [CoAP] Device 192.168.99.45 (shellyswitch25 / shellyswitch25-BCDDC277B11B / SHSW-25#BCDDC277B11B#1) connected! Polltime set to 15 sec.
          2024-01-12 19:20:22.445  - info: shelly.0 (908) [CoAP] Device 192.168.98.24 (shelly1pm / shelly1pm-E09806A9E0B6 / SHSW-PM#E09806A9E0B6#1) connected! Polltime set to 15 sec.
          2024-01-12 19:20:22.490  - info: shelly.0 (908) [CoAP] Device 192.168.99.21 (shelly1pm / shelly1pm-68C63AFAE21E / SHSW-PM#68C63AFAE21E#1) connected! Polltime set to 15 sec.
          2024-01-12 19:20:23.224  - info: host.iobroker instance system.adapter.sonos.0 started with pid 986
          2024-01-12 19:20:23.725  - info: sonos.0 (986) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.19.0, js-controller: 5.0.12
          2024-01-12 19:20:23.793  - info: shelly.0 (908) [CoAP] Device 192.168.99.22 (shelly1 / shelly1-C45BBE775B7A / SHSW-1#C45BBE775B7A#1) connected! Polltime set to 15 sec.
          2024-01-12 19:20:24.652  - warn: sonos.0 (986) State "sonos.0.root.192_168_99_32.favorites_list_html" has no existing object, this might lead to an error in future versions
          2024-01-12 19:20:24.652  - info: shelly.0 (908) [CoAP] Device 192.168.99.41 (shellyplug-s / shellyplug-s-B5085F / SHPLG-S#B5085F#1) connected! Polltime set to 15 sec.
          2024-01-12 19:20:24.652  - warn: sonos.0 (986) State "sonos.0.root.192_168_99_47.favorites_list_html" has no existing object, this might lead to an error in future versions
          2024-01-12 19:20:24.653  - warn: sonos.0 (986) State "sonos.0.root.192_168_99_47.favorites_list_html" has no existing object, this might lead to an error in future versions
          2024-01-12 19:20:24.756  - info: shelly.0 (908) [CoAP] Device 192.168.98.30 (shellyplug-s / shellyplug-s-C38343 / SHPLG-S#C38343#1) connected! Polltime set to 15 sec.
          2024-01-12 19:20:25.400  - info: shelly.0 (908) [CoAP] Device 192.168.98.27 (shelly1pm / shelly1pm-E09806A9E311 / SHSW-PM#E09806A9E311#1) connected! Polltime set to 15 sec.
          2024-01-12 19:20:26.407  - info: shelly.0 (908) [CoAP] Device 192.168.99.17 (shelly1 / shelly1-C49979 / SHSW-1#C49979#1) connected! Polltime set to 15 sec.
          2024-01-12 19:20:26.697  - info: shelly.0 (908) [CoAP] Device 192.168.99.30 (shelly1 / shelly1-B8E736 / SHSW-1#B8E736#1) connected! Polltime set to 15 sec.
          2024-01-12 19:20:26.716  - info: shelly.0 (908) [CoAP] Device 192.168.99.40 (shellyswitch25 / shellyswitch25-E098068D445E / SHSW-25#E098068D445E#1) connected! Polltime set to 15 sec.
          2024-01-12 19:20:26.791  - info: shelly.0 (908) [CoAP] Device 192.168.99.35 (shellyswitch25 / shellyswitch25-C45BBE6AB3A2 / SHSW-25#C45BBE6AB3A2#1) connected! Polltime set to 15 sec.
          2024-01-12 19:20:27.221  - info: host.iobroker instance scheduled system.adapter.tvspielfilm.0 */5 * * * *
          2024-01-12 19:20:27.228  - info: host.iobroker instance system.adapter.tvspielfilm.0 started with pid 1571
          2024-01-12 19:20:27.781  - info: shelly.0 (908) [CoAP] Device 192.168.98.214 (shellyplug-s / shellyplug-s-083A8DC3528C / SHPLG-S#083A8DC3528C#1) connected! Polltime set to 15 sec.
          2024-01-12 19:20:27.820  - info: tvspielfilm.0 (1571) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.19.0, js-controller: 5.0.12
          scheint wieder alles normal zu laufen.
          habe aber meines Wissens nichts angegriffen außer eben ein upgrade in linux.
          aber danke für die Hilfe, bist ein Schatz.
            @maximal1981 sagte in kann keinen Adapter mehr updaten:
            Für die Zukunft: NIE als root, NIE npm manuell anpacken.
            Hintergründe zu deinem 'Problem':
            https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
            • maximal1981
              @thomas-braun ich habe npm seit der Einrichtung nicht mehr angefasst.
              war das letzte mal auf der cli für ein apt upgrade. Hatte aber hier noch nie Probleme mit npm.
                Das kam durch das Update von debian.
                ist ein Kollateralschaden.
                und was war das
                npm install -g npm@8
                • maximal1981
                  maximal1981 @Homoran last edited by
                  @homoran das schlug mir die Adapterinstallation vor, da ging aber schon nichts mehr.
                  aber vermutlich wie du als erstes schreibst, kommt es von dem Update vom OS.
                  Aber das hatte ich nie, soll das jetzt nicht umgesetzt werden?
                    @maximal1981
                    Im weiteren:
                    Boot Target: graphical.target
                    sudo systemctl set-default multi-host.target
                    sudo useradd -a -G adm maximal1981
                    Und schaufel die diversen Adapter-Updates auf die Kiste.
                      klar, npm war ja weg, wie gerade erklärt
                        Doch, du sollst natürlich weiterhin Updates fahren. Allerdings war bei dir das nodesource-Repository noch nicht auf die aktuellste Version mit dem richtigen Pinning umgestellt. Weswegen dir der Paketmanager die aktuellste Version von nodejs eingespielt hat, die aber nicht zum ioBroker passt.
                        Das ist aber jetzt alles wieder richtig, kannst also nun wieder wie gewohnt deine Updates einspielen.
                        1.2k
                        1141
