    3. Entwicklung
    4. Neuer Adapter - Android TV & Fire TV Benachrichtigungen
      A Former User last edited by
      @stolly82
      seit V2.3.0, Host Docker V9.0.1, alles latest.
      2024-01-09 11:03:38.210  - info: host.iobroker "system.adapter.notificationforandroidtv.0" enabled
      2024-01-09 11:03:38.304  - info: host.iobroker instance system.adapter.notificationforandroidtv.0 started with pid 3609
      2024-01-09 11:03:39.597  - info: notificationforandroidtv.0 (3609) starting. Version 2.3.0 (non-npm: DNAngelX/ioBroker.notificationforandroidtv) in /opt/iobroker/node_modules/iobroker.notificationforandroidtv, node: v18.19.0, js-controller: 5.0.17
      2024-01-09 11:03:39.607  - error: notificationforandroidtv.0 (3609) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2024-01-09 11:03:39.611  - error: notificationforandroidtv.0 (3609) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2024-01-09 11:03:39.612  - error: notificationforandroidtv.0 (3609) unhandled promise rejection: Cannot read properties of undefined (reading 'error')
      2024-01-09 11:03:39.612  - error: notificationforandroidtv.0 (3609) TypeError: Cannot read properties of undefined (reading 'error')
          at Notificationforandroidtv.onReady (/opt/iobroker/node_modules/iobroker.notificationforandroidtv/main.js:338:22)
          at Notificationforandroidtv.emit (node:events:517:28)
          at Notificationforandroidtv._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9118:18)
          at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9097:26
      2024-01-09 11:03:39.612  - error: notificationforandroidtv.0 (3609) Cannot read properties of undefined (reading 'error')
      2024-01-09 11:03:39.608  - error: notificationforandroidtv.0 (3609) unhandled promise rejection: Cannot read properties of undefined (reading 'error')
      2024-01-09 11:03:39.610  - error: notificationforandroidtv.0 (3609) TypeError: Cannot read properties of undefined (reading 'error')
      2024-01-09 11:03:39.610  - error: notificationforandroidtv.0 (3609) Cannot read properties of undefined (reading 'error')
      2024-01-09 11:03:39.611  - info: notificationforandroidtv.0 (3609) registerNotification not processed because States database not connected
      2024-01-09 11:03:39.620  - info: notificationforandroidtv.0 (3609) terminating
      2024-01-09 11:03:39.621  - warn: notificationforandroidtv.0 (3609) Terminated (UNCAUGHT_EXCEPTION): Without reason
      stolly82 1 Reply Last reply Reply Quote 0
      • stolly82
        stolly82 @Guest last edited by
        @ilovegym
        Hmm, merkwürdig. Ich bekomme den im dev System und live nicht.
        Ich schaue noch mal
          A Former User @stolly82 last edited by A Former User
          @stolly82
          hab den Fehler gefunden, ich musste die Konfig neu anlegen, deshalb auch der Fehler im Log mit unexpected json ...
          Ich habe in der Konfig den Namen mit Leerzeichen versehen, also Fire TV Keller, da tritt der Fehler auf, wenn ich als Name FireTVKeller eintrage, geht alles...
          Edit:
          Zu frueh gefreut, hab alle 9 auf einmal angelegt, gleicher Fehler... ((
          Edit2:
          Also, ein FireTV angelegt, gespeichert, Adapter laeuft.
          Naechster Firetv in der Konfig angelegt, gespeichert, Adapter laeuft... so gehts.. beim neunten isser dann wieder abgestuerzt, hab ihn geloescht und nochmal angelegt (also den neunten FireTV), seitdem gehts...
          Denke, wenn du in der Konfig-Json suchst, biste richtig.. vielleicht kam das ja auch erst mit Admin 6.13.15..
          stolly82 1 Reply Last reply Reply Quote 1
          • wendy2702
            Geht mit dem Adapter und Notification for Android auch ein Live Stream einer Kamera?
              Lucky_ESA Developer Most Active @wendy2702 last edited by
              @wendy2702 sagte in Neuer Adapter - Android TV & Fire TV Benachrichtigungen:
              Dazu müsste noch die APP PiPup implementiert werden.
              Gruß//Lucky
              • wendy2702
                wendy2702 @Lucky_ESA last edited by
                @lucky_esa Ja,
                Mit Pipup und Blockly mache ich es aktuell.
                Dachte es würde hiermit auch schon gehen.
                  @lucky_esa Ja,
                  Ein Adapter wäre immer die bessere Lösung. Vielleicht implementiert @stolly82 PiPup noch.
                  Gruß//Lucky
                  • stolly82
                    stolly82 @Lucky_ESA last edited by
                    @lucky_esa
                    HMMMM, gar nicht mal so doof die Idee!
                    Schon mal, da die Configs ja schon alle da sind, sollte das nicht so schwer sein 😉
                    Ich schaue mal
                      Lucky_ESA Developer Most Active @stolly82 last edited by
                      @stolly82 sagte in Neuer Adapter - Android TV & Fire TV Benachrichtigungen:
                      @lucky_esa
                      Ich schaue mal
                      Hier wäre die API
                      readme.md
                      Gruß//Lucky
                      • stolly82
                        @ilovegym
                        Objekt payload hatte ich nicht geprüft, wenn "leer" dann war es kein JSON und somit ist der Adapter abgestürzt.
                        Ist behoben, bekomme den über das DEV Portal nur nicht in add to latest
                        • stolly82
                          @lucky_esa
                          Ich muss das App erstmal auf die FireTV's drauf bekommen.
                          Grusel 😖
                          So, the tutorial:
                          Installing PiPup
                          Download ADB drivers (Platform-Tools) for the device you’re using from here 138. On windows you just unzip the file, open terminal there and everything should work. People using linux - you know what to do.
                          Enable ADB and connect to the TV: follow this 166, it’s way better than what I can write.
                          Download Pipup from here 156 (app-debug.apk file). Put it in the directory with ADB drivers
                          In the terminal you have open run: adb sideload app-debug.apk (you must already be connected to TV, so don’t forget adb connect <IP> from the last step)
                          Grant needed permission with: adb shell appops set nl.rogro82.pipup SYSTEM_ALERT_WINDOW allow
                          Open the app on your TV, you can close it pretty much immediately, it just needs to run in the background
                          • BananaJoe
                            BananaJoe Most Active last edited by
                            Kann PiPup denn RSTP-Streams? Das wäre der Kamera Standard. Oder "nur" Video?
                            Das Issue dazu ist noch offen, https://github.com/rogro82/PiPup/issues/8
                            Ich habe nur einen gefunden der das Video vorher über WebRTC umwandelt/bereitstellt.
                            mvanhelmont created this issue in rogro82/PiPup
                            closed Please add support for RTSP #8
                            • BananaJoe
                              BananaJoe Most Active @BananaJoe last edited by BananaJoe
                              @bananajoe Nachtrag: Direkt das Bild von der Kamera zu holen klappt mit dem Adapter nicht (was aber wohl an der App auf Android liegen wird), ich hole es erst auf den ioBroker und stelle es dort bereit. Die App hat wohl nicht die gedult auf das Bild zu warten (Reolink Kameras)
                              • mcm1957
                                mcm1957 @stolly82 last edited by
                                @stolly82 said in Neuer Adapter - Android TV & Fire TV Benachrichtigungen:
                                @ilovegym
                                Du brauchst nur EINMAL ein "add to latest" auslösen. Dein PR existiert als https://github.com/ioBroker/ioBroker.repositories/pull/3189.
                                Das Review ist noch pending.
                                Neue Releases brauchen für das latest Repository KEINEN neuerlichen Aufruf via dev Protal. Sobald ein Adapter für Latest freigeschaltet ist wird er im latest Repositpory automatisch aktualisisert. Nur fürs stable Repo musst du später einen Reqeust per Release stellen (dazu gibts dann aber ggF Erinnerungen)
                                DNAngelX created this issue in ioBroker/ioBroker.repositories
                                closed Add notificationforandroidtv to latest #3189
                                • wendy2702
                                  @BananaJoe Ich nutze den http Stream aus Motioneye. RTSP direkt geht wohl nicht weil die auch im Browser nicht mehr gehen.
                                  • BananaJoe
                                    BananaJoe Most Active @wendy2702 last edited by
                                    @wendy2702 könnte ich bei mir auch machen (aus BlueIris). Hab dann aber irgendwann entschieden das ein Bild pro Sekunde auch reicht um zusehen wer da steht.
                                    Der Stream war immer eine ganz schöne Last ... und es hat lange gedauert bis das System erkannt hat das auf der anderen Seite gar keiner mehr zu hört und wieder runter geschaltet hat.
                                    • matthsc
                                      matthsc Developer @stolly82 last edited by
                                      Erledigt!
                                      Changelog
                                      2.3.0 (2024-01-08)
                                      • (DNAngel) extended payload possibility as message object
                                      Danke dir, funktioniert einwandfrei!
                                      • stolly82
                                        Ich hatte mich gestern dran gesetzt und PiPup eingearbeitet.
                                        El Question:
                                        hat schon mal jemand PiPup auf dem FireTV zum laufen gebracht?
                                        Ich habe es auf zwei FireTV 4k max installiert, das war es dann aber auch schon 😉
                                        App startet, ich kann via Postman Daten senden und bekomme 'ne 200 und die Response der Daten zurück, die ich gesendet habe.
                                        PopupProps(duration=30, position=TopLeft, backgroundColor=#ffffff, title=Your awesome title, titleSize=20.0, titleColor=#0066cc, message=What ever you want to say... do it here..., messageSize=14.0, messageColor=#000000, media=Image(uri=https://i.ebayimg.com/images/g/ZOkAAOSwgyZkfGxF/s-l1600.jpg, width=480))
                                        Auf dem FireTV passiert ziemlich genau,.... nichts.
                                        Dachte dann,..
                                        On Android TV (8.0+), when sideloading, you will need to set the permission for SYSTEM_ALERT_WINDOW manually (using adb) as there is no interface on Android TV to do this.
                                        To give the application the required permission to draw overlays you will need to run:
                                        Integrating
                                        würden helfen, aber nix.
                                        Wenn es schon mal jemand zum laufen gebacht hat, was fehlt bei mir?
                                        Muss adb shell appops set nl.rogro82.pipup SYSTEM_ALERT_WINDOW allow irgend eine response im Terminal ergeben?
                                        MyWay:
                                        Ich haben mir atvTools geladen, habe die PiPup apk geladen und auf den FireTV übertragen, installiert und geöffnet.
                                        In der Befehlskonsole von atvTools dann "adb shell appops set nl.rogro82.pipup SYSTEM_ALERT_WINDOW allow" eingegeben.
                                        Meines Verständnisses nach, hätte sich das popup öffnen müssen.
                                        Liebe Grüsse
                                        • stolly82
                                          stolly82 last edited by stolly82
                                          Ich habe PiPup jetzt komplett implementiert, auch wieder mit dem "payload" request etc.
                                          Laut response klappt es, wie gesagt, bei mir kommt auf dem TV nichts an.
                                          Ich mache selten Fehler im Software Development, deshalb würde ich die 3.0.1 dann direkt hochladen zum review.
                                          wendy2702 L 2 Replies Last reply Reply Quote 0
                                          • wendy2702
                                            wendy2702 @stolly82 last edited by
                                            @stolly82 ich kann das morgen mal testen wenn ich zu Hause bin.
                                            Mein Pipup funktioniert ja auf nem Philips Android TV.
                                            79
                                            9515
