    4. Panasonic Wärmepumpenmanager, Script / Ideen gesucht
      ticaki Developer @sonny last edited by
      @sonny
      siehe eedit
        sonny @ticaki last edited by
        @ticaki
        hab das "log (result.data)" im Code hinzugefügt an entsprechender Stelle:
        Log selber meldet mir dabei "undefined"
          ticaki Developer @sonny last edited by ticaki
          @sonny
          Sry och ne... hab beim Entfernen der Auskommentierung nach dem Test auch das await gelöscht. moment edit kommt gleich
          const ip = '192.168.8.165';
          const prefix = '0_userdata.0.test'; // wird erstellt oder erweitert bei jedem durchlauf
          const channelName = 'My great channel';
          const axios = require('axios');
          const { HTMLToJSON } = require('html-to-json-parser');
          let values: any = {};
          async function main() {
              const result = await axios(`http://${ip}`);
              if ( result && result.data) {
                  for (const r of db) {
                      const match = result.data.match(r);
                      if (match && Array.isArray(match) && match.length >= 1) {
                          log(`http://${ip}/${match[0]}`)
                          const response = await axios(`http://${ip}/${match[0]}`);
                          const body = response.data.replace(/\n/gm, '').match(/<body>.*?<\/body>/gm)[0]
                          let data
                          try {
                              data = await HTMLToJSON(body, false);
                          } catch (e) {
                              log(e)
                          if (data && data.type == 'body') {
                              let d = data.content;
                              let c = 0;
                              while (c < d.length) {
                                  const v = d[c++];
                                  if (v.type === 'div') {
                                      for (const i of v.content) {
                                          if (i.attributes && i.attributes.class == 'dp') {
                                              for (const b of i.content) {
                                                  if (b.type) {
                                                      let val = b.content.join(' ').match(/ [0-9\.,]+/);
                                                      let end = '';
                                                      if (!val || isNaN(val.join(''))) val = b.content.join(' ');
                                                      else {
                                                          end = '_' + b.content.join(' ').replace(val, '');
                                                          val = parseFloat(val[0]);
                                                      values[(b.attributes.href + end).replace(/^.*?sessionid\=[0-9A-Z]+\&id\=/, '').replace(/[^_\-/:!#$%&()+=@^{}|~\p{Ll}\p{Lu}\p{Nd}]+/gu, '_')] = val;
              for (const id in values) {
                  const val = values[id];
                  await extendObjectAsync(`${prefix}`,{type: 'channel', common:{name: channelName}});
                  if (!existsState(`${prefix}.${id}`)) await createStateAsync(`${prefix}.${id}`, val, {name: 'no description', role: typeof val === 'string' ? 'text' : 'value', type: typeof val, read: true, write: false})
                  await setStateAsync(`${prefix}.${id}`, val, true);
          const db: RegExp[] = [
              /v107000\.rsp\?sessionid=[0-9A-Z]+/,
              /v21\.rsp\?sessionid=[0-9A-Z]+/,
              /v50\.rsp\?sessionid=[0-9A-Z]+/
          main();
            @ticaki
            Bitteschön :
            script.js.Statische_Scripte.Wärmepumpe: http://192.168.8.165/v107000.rsp?sessionid=5A5B0295
            Eine am Deckel krieg ich aber auch :
              @sonny
              Funktioniert die url in deinem browser?
                @ticaki
                Ja, was mich wundert (Mein Computer hat ne andere IP Adresse in meinem Netzwerk als der Iobroker Raspberry, ich müsste normalerweise vom Pumpenmanager nen Tritt in den Hintern bekommen oder eine neue Session ID)
                Scheint aber zu funktionieren Siehe:
                  @sonny
                  Ich füge mal unterschämt viele Debuglog einträge hinzu - 5-10 Minuten
                    @ticaki
                    Ich stell 2 Kaffee in den Raum hier inzwischen !
                      @sonny
                      Hab den schedule eingebaut, dauert bis zur vollen Minute bevor es durchläuft.
                      brauche 3 Logeinträge vor dem Fehler.
                      const interval = '* * * * *';
                      const DEBUG = true
                              logDebug(`Get data from http://${ip}`);
                              logDebug(``);
                                      if (response && response.data) {
                                          logDebug(`Get data from http://${ip}/${match[0]}`);
                                          let data
                                          try {
                                          } catch (e) {
                                              log(e)
                                              logDebug(`Parse data ok, found body`);
                                              for (const c in d) {
                                                  const v = d[c];
                                                      logDebug(`div found`);
                                                              logDebug(`class db found`);
        if (b.type) {
        logDebug(`type ${b.type} found`);
        let end = '';
        logDebug(val);
        else {
        val = parseFloat(val.join(''));
                                          } else logDebug(`${data ? 'Parse data ok' : 'Parse data failed!'}, ${data.type == 'body' ? 'body found' : 'body not found'}`);
                                      } else logDebug(`Don't get data from http://${ip}/${match[0]}`);
                          } else logDebug(`Don't get data from http://${ip}`);
                      function logDebug(l: string): void {
                          if (DEBUG) log(l);
                      schedule(interval, main);
                        sonny @ticaki last edited by sonny
                        @ticaki
                        Das kommt raus dabei ...
                        Hab 4 Durchläufe durch, Session ID ändert sich brav mit (Einmal pro Minute geht sich aus, mehr wie 3 Sitzungen, wo ich nicht wusste wann er die letzte "vergisst" mag er nicht)
                        Also soweit:
                        script.js.Statische_Scripte.Wärmepumpe: Get data from http://192.168.8.165/v107000.rsp?sessionid=0417D206
                        klappt es
                          @sonny
                          Ja ich weiß wo der Fehler liegt, aber muß rumprobieren wie ich ihn behebe. die Regex kommt mit den Zeilenumbrüchen nicht klar und das entfernen sebiger hat scheinbar nicht geholfen.
                          const DEBUG = true
                                  logDebug(``);
                                              let body = response.data.replace(/\n/gm, '').match(/<body>.*?<\/body>/gms)
                                              if (body || Array.isArray(body) ) {
                                                  body = body[0];
                                              if (!body) {
                                                  log('Regex: Body not found', 'error');
                                                  continue;
                                              let data
                                              try {
                                              } catch (e) {
                                                  log(e)
                                                      const v = d[c];
        if (b.type) {
        let end = '';
        logDebug(val);
        else {
                              if (DEBUG) log(l);
                          Jetzt gibts nicht mehr den großen Fehler sondern nur noch welche die zeigen das die Regex noch immer nicht funktioniert.
                            @ticaki
                            Ich kann dir hier vielleicht helfen: fängst du mit Python etwas an ?
                            Es gibt jemanden aus dem Haustechnikdialog , der das mit Python geschafft hat, vermutlich eh auf gleichem Weg wie du hier:
                            Ich füg hier ein Codebeispiel ein- Eigentum "Ladyshave" aus dem Haustechnikforum. (Ist öffentlich , ich hoffe man hat nichts dagegen wenn ich mir den für Demonstrationszwecke ausborge)
                            [code]
                            # Script zum Auslesen des HPM Waermepumpenmanagers #
                            # getestete Firmware H1.1.20 vom 22.01.2015 #
                            # programmed by ladyshave ;-) #
                            # V1.0 vom 14.03.2016 #
                            import requests
                            #ip-Adresse des HPM
                            website="http://192.168.101.10"
                            #Auslesen der Daten und Aufbereiten
                            t = requests.get(website)
                            url = t.url
                            print (url)
                            #holen der SessionID für die Sitzung
                            sessionid = url[39:47]
                            print (sessionid)
                            #URLs mit SessionID basteln:
                            url_wp= "http://192.168.101.10/v21.rsp?sessionid=" + sessionid
                            url_bw= "http://192.168.101.10/v107000.rsp?sessionid=" + sessionid
                            url_pu= "http://192.168.101.10/v100100.rsp?sessionid=" + sessionid
                            url_hk1= "http://192.168.101.10/v30.rsp?sessionid=" + sessionid
                            url_hk2= "http://192.168.101.10/v3.rsp?sessionid=" + sessionid
                            #Daten der Seiten abholen
                            daten_wp = requests.get(url_wp)
                            daten_bw = requests.get(url_bw)
                            daten_pu = requests.get(url_pu)
                            daten_hk1 = requests.get(url_hk1)
                            daten_hk2 = requests.get(url_hk2)
                            #Test Augabe der Website als Text
                            #print (daten_wp.text)
                            #print (daten_bw.text)
                            #print (daten_pu.text)
                            #print (daten_hk1.text)
                            #print (daten_hk2.text)
                            #Funktion zum Auslesen der Daten aus der Seite
                            def daten_lesen(text, suchstring, bezeichnung):
                            index = text.find(suchstring) #Anfangsindex im String suchen
                            indexend = text.find("</a>", index) #Endindex im String suchen
                            #print (index)
                            #print (indexend)
                            if index == -1:
                            return -1
                            index = index + 14 #Index nach ID setzen
                            i=0
                            rueckgabe=""
                            laenge = indexend-index #laenge des Index berechnen
                            while i != laenge: #Schleife ueber laenge
                            # falls Zahl im Namen wird dies mit isalpaha() ausgeblendet
                            # ansonsten Zahl oder "." oder "-"schreiben
                            if text[index + i-1].isalpha() == False and (text[index + i].isdigit() == True or text[index + i] == "." or text[index + i] == "-"):
                            rueckgabe = rueckgabe + text[index + i]
                            i = i + 1 #naechter bitte
                            return (bezeichnung + ":" + rueckgabe) #Rueckgabe des Textes
                            #id=126:6.6.22">Freq 0</a>
                            #id=110:6.6.5">SollwertBW 2 °C
                            #id=109:6.6.4">SollwertHK 2 °C</a>
                            #Vorlauf id=111:6.6.6"> 29 °C</a>
                            #Ruecklauf id=112:6.6.7"> 29 °C</a>
                            print (daten_lesen (daten_wp.text, "id=126:6.6.22", "WP_Freq"))
                            print (daten_lesen (daten_wp.text, "id=110:6.6.5", "WP_SollBW"))
                            print (daten_lesen (daten_wp.text, "id=109:6.6.4", "WP_SollHK"))
                            print (daten_lesen (daten_wp.text, "id=111:6.6.6", "WP_Vorl"))
                            print (daten_lesen (daten_wp.text, "id=112:6.6.7", "WP_Rueckl"))
                            #Pufferdaten auslesen:
                            #Istwert id=61:6.5.5"> 32.0 °C</a>
                            #Sollwert id=59:6.5.3">SW-Zone1 32.4 °C</a>
                            print (daten_lesen (daten_pu.text, "id=61:6.5.5", "PU_Istwert"))
                            print (daten_lesen (daten_pu.text, "id=59:6.5.3", "PU_Sollwert"))
                            #Brauchwasser:
                            #Istwertid=38:6.4.8"> 42.0 °C</a>
                            #Sollwertid=37:6.4.7">SW-Spei 45.0 °C</a>
                            print (daten_lesen (daten_bw.text, "id=38:6.4.8", "BW_Istwert"))
                            print (daten_lesen (daten_bw.text, "id=37:6.4.7", "BW_Sollwert"))
                            #HK1
                            #Istwert id=13:6.2.12"> 22.7 °C</a>
                            #Sollwert id=12:6.2.11">SW-Vorl 30.9 °C</a>
                            #Ausstemp id=9:6.2.8"> 2.0 °C</a>
                            print (daten_lesen (daten_hk1.text, "id=13:6.2.12", "HK1_Istwert"))
                            print (daten_lesen (daten_hk1.text, "id=12:6.2.11", "HK1_Sollwert"))
                            print (daten_lesen (daten_hk1.text, "id=9:6.2.8", "HK1_Aussen"))
                            #HK2
                            #Istwert id=27:6.3.12"> 30.7 °C</a>
                            #Sollwert id=26:6.3.11">SW-Vorl 31.0 °C</a>
                            print (daten_lesen (daten_hk2.text, "id=27:6.3.12", "HK2_Istwert"))
                            print (daten_lesen (daten_hk2.text, "id=26:6.3.11", "HK2_Sollwert"))
                            [/code]
                            und hier ein Forumsbeitrag, sehr versprechend, mit selbigem Projekt: Da gabs ne Lösung dazu (aus der ich natürlich absolut nicht schlau werd)
                            https://www.loxforum.com/forum/german/software-konfiguration-programm-und-visualisierung/35354-web-interface-einer-panasonic-lwp-mit-hpm-über-virtuelle-http-eingänge-einlesen
                            Die Infos hab ich in vergangenheit zusammengekrazt, es war alles was ich finden konnte darüber
                            LG und danke derweil für alles !
                              @sonny
                              Erstmal kann ich python nicht leiden und die Arbeit mache ich mir für einen Adapter und dann bis du das Opfer 😄
                              bitte probiere noch meinen Code aus ich will das mit der RegEx noch probieren (vorheriger Beitrag) wenn nicht klappt mache ich es auf dem langweiliigen weg.
                              EDIT: gehts?
                                @ticaki
                                Moment ich hab das Script gerade gestartet, der Ordner wurde erstellt.
                                Ich gleich das eben ab und "suche" nach fehler 🙂 Das Log wird halt überfüllt, das unmengen "gefunden" wurde .aber Infos, keine Fehler.
                                Opfer immer gern, für die Entwicklung sowieso. Soll ja jedem helfen.
                                  @sonny
                                  Dann mache DEBUG=false Dann hält es die klappe 🙂
                                  Wenn du einen Adapter haben möchtest trage bitte sorgfällig englische Bezeichnungen in das Namenfeld der Objekte ein. (stift rechts klicken) Wenn du das hast exportiere den ganze Ordner und stelle ihn hier ein.
                                    @ticaki
                                    Du ich glaub das funktioniert !!!
                                    So z.b ?
                                    Für mich extra brauchst keinen machen. Ich glaub auch nicht, das den jemals jemand braucht- Das Script sollte reichen.
                                    Wenn du allerdings willst, mach ich das gern. (Bin eigentlich eh grad dabei, was ich weiß geb ich einen Namen)
                                    Ich tests mal kommende Tage auf Herz und Nieren. Sieht MOMENTAN aber alles wunderbar aus hey !
                                      @sonny
                                      und wenn alles geht kannst du das
                                      auskommentieren:
                                      //log(`http://${ip}/${match[0]}`)
                                        @sonny sagte in Panasonic Wärmepumpenmanager, Script / Ideen gesucht:
                                        Ist dein Gerät hier dabei, oder mit denen kompatibel?
                                        https://github.com/search?q=repo%3AioBroker%2FAdapterRequests+Panasonic&type=issues
                                          @ticaki
                                          Moment ich brauch ein bissl ich schau mir das an, ob diese Wärmepumpe vom Pumpenmanager Unterstützt wird.
                                          Ich kann dir, vorrausgesetzt man HAT diesen Pumpenmanager und entsprechendes Adapterkabel von Panasonic , die Liste der unterstützten Geräte hier posten....
                                          Für Google: Das Geräte heißt: Panasonic PAW-HPM oder PAW-HPM1 (Das sich Leute hierher verlaufen)
                                          Alle anderen Requests, Seitens Wärmepumpen: sind beim Projekt: HEISHAMON besser aufgehoben.
                                          Was der HPM kann, kann Heishamon nicht und umgekehrt .
                                          Wir handeln hier die Generationen ab, die Heishamon NICHT kann (und vermutlich auch nie können wird- Anderes Kommunikationsprotokoll) - Aber auch älter sind, aber von den Kübeln sind noch genug im Umlauf.
                                          Ich hatte Heishamon an meiner Probiert, keine Chance, daher den HPM gekauft. Es sind immer mal wieder auf Ebay Kleinanzeigen, welche zu gutem Kurs zu bekommen.
                                          Ich geb hier alles mal einen Namen, mach meine Datenbank fertig- und werd kommende Tage schaun ob alles passt (Ich nehm aber an ja, würde ja jetzt schon Probleme geben denk ich).
                                          Nächste Woche möcht ich mich noch wegen paar Kisten Bier oder was auch immer du gerne hättest, was ich dir schuldig bin, unterhalten 🙂 - Ich sag in jedem Fall : Tausend dank derweil !- Ich meld mich hier sollte es Probleme geben, und in jedem Fall Dienstag/Mittwoch und sorge für ein selbstverständliches entgegenkommen meinerseits .
                                          LG
                                            sonny @sonny last edited by sonny
                                            @ticaki
                                            Einen Schönheitsfehler hab ich bisher gefunden (Sonst scheint das wirklich bisher ohne Probleme zu laufen !).
                                            Sonderzeichen. Aussentemperatur wird mir als : "-1.1 �C"
                                            angezeigt und gespeichert. Was Grad Celsius " °C" sein soll nehm ich an.
                                            statt eines "ö" wird als "�" dargestellt (Störung z.b) , vermutlich Zeichensatzproblem ?
                                            Hab eben gesehen, das bei deinem Screenshot von den States, das "ö" zumindest richtig dargestellt wird. Komisch, hab ich hier Blödsinn bei mir beinander ?
                                            6320
