    4. QNAP NAS Container ioBroker js-controller und node update
    • Glasfaser
      Glasfaser @HolgerCW last edited by
      @holgercw sagte in QNAP NAS Container ioBroker js-controller und node update:
      Was gebe ich da ein ?
      War doch schon richtig ... mit bash
      • Glasfaser
        @holgercw
        ich habe so eine Vorahnung, das wieder No connection kommt ,
        dann diese Ausgabe hier posten :
        type -P nodejs && nodejs -v && type -P node && node -v && type -P npm && npm -v && type -P npx && npx -v && apt policy nodejs && ls -lh /opt/iobroker/iobroker-data/&& iob version
          HolgerCW @Glasfaser last edited by
          @glasfaser HIer nun die Ausgabe
          H Glasfaser 2 Replies Last reply Reply Quote 0
            HolgerCW @HolgerCW last edited by Homoran
            @holgercw
            root@ioBroker:/opt/iobroker# iob diag
            iobroker [command]
            Commands:
              iobroker setup                                               Setup ioBroker
              iobroker start                                               Starts the js-controller
              iobroker stop                                                stops the js-controller
              iobroker restart                                             Restarts js-controller
              iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
              iobroker info                                                Shows the host info
              iobroker logs [<adapter>]                                    Monitor log
              iobroker add <adapter> [desiredNumber]                       Add instance of adapter
              iobroker install <adapter>                                   Installs a specified adapter
              iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
              iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
              iobroker del <adapter>                                       Remove adapter from system
              iobroker del <adapter>.<instance>                            Remove adapter instance
              iobroker update [<repositoryUrl>]                            Update repository and list adapters
              iobroker upgrade                                             Upgrade management
              iobroker upload                                              Upload management
              iobroker object                                              Object management
              iobroker state                                               State management
              iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
              iobroker list <type> [<filter>]                              List all entries, like objects
              iobroker chmod <mode> <file>                                 Change file rights
              iobroker chown <user> <group> <file>                         Change file ownership
              iobroker touch <file>                                        Touch file
              iobroker rm <file>                                           Remove file
              iobroker file                                                File management
              iobroker user                                                User commands
              iobroker group                                               group management
              iobroker host <hostname>                                     Set host to given hostname
              iobroker set <adapter>.<instance>                            Change settings of adapter config
              iobroker license <license.file or license.text>              Update license by given file
              iobroker cert                                                Certificate management
              iobroker clean <yes>                                         Clears all objects and states
              iobroker backup                                              Create backup
              iobroker restore <backup name or path>                       Restore a specified backup
              iobroker validate <backup name or path>                      Validate a specified backup
              iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
              iobroker repo [<name>]                                       Show repo information
              iobroker uuid                                                Show uuid of the installation
              iobroker unsetup                                             Reset license, installation secret and language
              iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
              iobroker multihost                                           Multihost management
              iobroker compact                                             compact group management
              iobroker plugin                                              Plugin management
              iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
            Options:
                  --help     Show help  [boolean]
              -v, --version  Show version  [boolean]
            • Glasfaser
              @holgercw
              Was machst du !
              Zuerst :
              @glasfaser sagte in QNAP NAS Container ioBroker js-controller und node update:
              Wenn ich dort was eingebe und enter drücke passiert nichts:
              Habe kein Qnap ... aber da bist du falsch , du hast da ein Button Terminal ...
              Aber im Grunde um dir zu helfen , brauchen wir keine Briefmarke , sondern ein richtige Ausgabe deines Systems :
              dazu dann einmal
              pkill -u iobroker
              iob fix
              danach den Container neu starten ,
              dann
              die Full Ausgabe von
              iob diag
              hier in Code-Tags </> posten
              sonst das :
              @holgercw
                @glasfaser Habe nun den Code eingegeben:
                root@ioBroker:/opt/iobroker# type -P nodejs && nodejs -v && type -P node && node -v && type -P npm && npm -v && type -P npx && npx -v && apt policy nodejs && ls -lh /opt/iobroker/iobroker-data/&& iob version
                /usr/bin/nodejs
                v10.18.1
                /usr/bin/node
                v10.18.1
                /usr/bin/npm
                6.13.4
                /usr/bin/npx
                6.13.4
                nodejs:
                  Installiert:           10.18.1-1nodesource1
                  Installationskandidat: 10.18.1-1nodesource1
                  Versionstabelle:
                 *** 10.18.1-1nodesource1 100
                        100 /var/lib/dpkg/status
                insgesamt 15M
                drwxrwxr-x 1 iobroker iobroker  12K Jan 13 18:09 backup-objects
                drwxrwxr-x 1 iobroker iobroker 4,0K Jan 13 16:19 files
                -rw-rwxr-- 1 iobroker iobroker 4,3K Jun  7  2021 iobroker.json
                -rw-r--r-- 1 iobroker iobroker    3 Jan 13 17:57 notifications.json
                -rw-r--r-- 1 iobroker iobroker 6,4M Jan 13 18:15 objects.json
                -rw-r--r-- 1 iobroker iobroker 6,4M Jan 13 18:15 objects.json.bak
                -rw-r--r-- 1 iobroker iobroker 847K Jan 13 18:21 states.json
                -rw-r--r-- 1 iobroker iobroker 847K Jan 13 18:20 states.json.bak
                3.2.16
                  HolgerCW @HolgerCW last edited by HolgerCW
                  Wusste eben nicht ob ich zwischen iob fix und iob diag in dem neuen Fenster bleiben soll bis er neu gestartet ist. Bin mit der Materie komplet nicht vertraut. Kannst Du mit den Daten nun was anfangen ?
                  Vielleicht gibt es ja auch eine Möglichkeit das Image komplett neu zu installieren (Vorher backup und so) aber ohne das dann das Smarthome neu eingerichtet werden muss
                  • Glasfaser
                    Glasfaser @HolgerCW last edited by Glasfaser
                    Ja ... , erstmal !
                    Wie schon auf der Briefmarke zu erkennen , ist dein ioBroker / Container Stein Alt ... also nie gepflegt worden .
                    Zeige mal :
                    iob list instances
                    iob list adapters
                    H 3 Replies Last reply Reply Quote 0
                      HolgerCW @Glasfaser last edited by Homoran
                      @glasfaser
                      root@ioBroker:/opt/iobroker# iob list instances
                      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.ble.0                    : ble                   : ioBroker                                 -  enabled
                      + system.adapter.daikin.0                 : daikin                : ioBroker                                 -  enabled
                      + system.adapter.daikin.1                 : daikin                : ioBroker                                 -  enabled
                      + system.adapter.daikin.2                 : daikin                : ioBroker                                 -  enabled
                      + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                      + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
                      + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
                      + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                      + system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 -  enabled, port: 8080
                      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                      + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                      + system.adapter.samsung.0                : samsung               : ioBroker                                 -  enabled
                      + system.adapter.samsung.1                : samsung               : ioBroker                                 -  enabled
                      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 192.168.0.60, run as: admin
                      + system.adapter.tesla-motors.0           : tesla-motors          : ioBroker                                 -  enabled
                      + system.adapter.vr200.0                  : vr200                 : ioBroker                                 -  enabled
                      + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
                      + instance is alive
                        @glasfaser
                        system.adapter.admin                   : admin          - v5.1.25
                        system.adapter.ble                     : ble            - v0.12.0
                        system.adapter.daikin                  : daikin         - v1.4.2
                        system.adapter.discovery               : discovery      - v2.7.3
                        system.adapter.fritzbox                : fritzbox       - v0.2.1
                        system.adapter.fullybrowser            : fullybrowser   - v2.0.10
                        system.adapter.hue                     : hue            - v3.7.1
                        system.adapter.info                    : info           - v1.9.8
                        system.adapter.lgtv-rs                 : lgtv-rs        - v0.1.1
                        system.adapter.lgtv11                  : lgtv11         - v1.0.5
                        system.adapter.mihome-vacuum           : mihome-vacuum  - v3.8.6
                        system.adapter.ping                    : ping           - v1.5.0
                        system.adapter.samsung                 : samsung        - v0.2.9
                        system.adapter.shelly                  : shelly         - v4.0.7
                        system.adapter.simple-api              : simple-api     - v2.6.1
                        system.adapter.tesla-motors            : tesla-motors   - v1.3.2
                        system.adapter.tr-064                  : tr-064         - v4.2.16
                        system.adapter.vr200                   : vr200          - v1.1.0
                        system.adapter.wled                    : wled           - v0.6.7
                          @glasfaser WUsste nie wie ich da ran gehen soll. Habe dann immer wieder aufgegeben. Hoffe jetzt geht es mal vorran
                          • Glasfaser
                            Das ganze Problem was ich jetzt sehe , ist das du kein Backup hast mit dem Backitup Adapter !
                            Oder wie machst du Backups !?
                              @glasfaser Habe noch nie ein Backup gemacht. Soll ich den backitup adapter installieren auf dem iobroker. Bisher läuft ja auch leider alles, daher habe ich da ein wenig schiss. Ein Update des node und js wäre top wenn das einfach so ginge
                              • Glasfaser
                                dann hast du immer Glück gehabt !
                                Ein Update des node
                                lohnt sich nicht , der Container ist UhrAlt !
                                Naja ..
                                Erstmal ein Backup machen !
                                Dann im alten Container den js-controller langsam hochziehen inkl Nodejs usw.
                                Dann ein Backup ,
                                dann einen neuen Container erstellen mit dem aktuelle Image dann dein Backup rein .
                                  @glasfaser Alles klar. Nur wie mache ich ein Backup und wie mache ich danach die Updates. Bisher war das ja ohne Erfolg ?
                                  • Glasfaser
                                      @glasfaser said in QNAP NAS Container ioBroker js-controller und node update:
                                      Backitup
                                      LEider keine Chance. Adapter nicht installierbar:1.jpg
                                      Was nun ?
                                        @glasfaser Ich konnte ja auch jetzt nicht in der Console iobroker update machen
                                        Thomas Braun Homoran Glasfaser 4 Replies Last reply Reply Quote 0
                                          Thomas Braun Most Active @HolgerCW last edited by Thomas Braun
                                          @holgercw
                                          iob stop
                                          iob fix
                                          iob nodejs-update
                                          Dann schauen ob der backitup-Adapter installierbar ist.
                                          Edith: Das ist ein Docker bei dir? Dann vergiss es, das geht da glaub ich nicht/anders.
                                            Homoran Global Moderator Administrators @HolgerCW last edited by
                                            warum nicht?
                                            zeigen!
                                            wenn man 7 Jahre nichts updated gibt es die alten Repos gar nicht mehr.
                                            Hier trifft nach so langer Zeit wirklich zu:
                                            kein Backup - kein Mitleid!
                                            Du kannst noch versuchen nodejs hochzuziehen um den Controller und einige Adapter upzudaten.
                                            Aber da wirst du auch ggf. am Betriebssystem scheitern.
                                            Du darfst natürlich nicht versuchen die allerneuesten Versionen draufzuspielen.
                                            4278
