    4. QNAP NAS Container ioBroker js-controller und node update
      HolgerCW @Glasfaser last edited by Homoran
      @glasfaser
      root@ioBroker:/opt/iobroker# iob list instances
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.ble.0                    : ble                   : ioBroker                                 -  enabled
      + system.adapter.daikin.0                 : daikin                : ioBroker                                 -  enabled
      + system.adapter.daikin.1                 : daikin                : ioBroker                                 -  enabled
      + system.adapter.daikin.2                 : daikin                : ioBroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
      + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
      + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
      + system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 -  enabled, port: 8080
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
      + system.adapter.samsung.0                : samsung               : ioBroker                                 -  enabled
      + system.adapter.samsung.1                : samsung               : ioBroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 192.168.0.60, run as: admin
      + system.adapter.tesla-motors.0           : tesla-motors          : ioBroker                                 -  enabled
      + system.adapter.vr200.0                  : vr200                 : ioBroker                                 -  enabled
      + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
      + instance is alive
        @glasfaser
        system.adapter.admin                   : admin          - v5.1.25
        system.adapter.ble                     : ble            - v0.12.0
        system.adapter.daikin                  : daikin         - v1.4.2
        system.adapter.discovery               : discovery      - v2.7.3
        system.adapter.fritzbox                : fritzbox       - v0.2.1
        system.adapter.fullybrowser            : fullybrowser   - v2.0.10
        system.adapter.hue                     : hue            - v3.7.1
        system.adapter.info                    : info           - v1.9.8
        system.adapter.lgtv-rs                 : lgtv-rs        - v0.1.1
        system.adapter.lgtv11                  : lgtv11         - v1.0.5
        system.adapter.mihome-vacuum           : mihome-vacuum  - v3.8.6
        system.adapter.ping                    : ping           - v1.5.0
        system.adapter.samsung                 : samsung        - v0.2.9
        system.adapter.shelly                  : shelly         - v4.0.7
        system.adapter.simple-api              : simple-api     - v2.6.1
        system.adapter.tesla-motors            : tesla-motors   - v1.3.2
        system.adapter.tr-064                  : tr-064         - v4.2.16
        system.adapter.vr200                   : vr200          - v1.1.0
        system.adapter.wled                    : wled           - v0.6.7
          @glasfaser WUsste nie wie ich da ran gehen soll. Habe dann immer wieder aufgegeben. Hoffe jetzt geht es mal vorran
          • Glasfaser
            Glasfaser @HolgerCW last edited by
            @holgercw sagte in QNAP NAS Container ioBroker js-controller und node update:
            Das ganze Problem was ich jetzt sehe , ist das du kein Backup hast mit dem Backitup Adapter !
            Oder wie machst du Backups !?
              @glasfaser Habe noch nie ein Backup gemacht. Soll ich den backitup adapter installieren auf dem iobroker. Bisher läuft ja auch leider alles, daher habe ich da ein wenig schiss. Ein Update des node und js wäre top wenn das einfach so ginge
              • Glasfaser
                dann hast du immer Glück gehabt !
                Ein Update des node
                lohnt sich nicht , der Container ist UhrAlt !
                Naja ..
                Erstmal ein Backup machen !
                Dann im alten Container den js-controller langsam hochziehen inkl Nodejs usw.
                Dann ein Backup ,
                dann einen neuen Container erstellen mit dem aktuelle Image dann dein Backup rein .
                  @glasfaser Alles klar. Nur wie mache ich ein Backup und wie mache ich danach die Updates. Bisher war das ja ohne Erfolg ?
                  • Glasfaser
                    @glasfaser sagte in QNAP NAS Container ioBroker js-controller und node update:
                      @glasfaser said in QNAP NAS Container ioBroker js-controller und node update:
                      Backitup
                      LEider keine Chance. Adapter nicht installierbar:1.jpg
                      Was nun ?
                        @glasfaser Ich konnte ja auch jetzt nicht in der Console iobroker update machen
                        Thomas Braun Homoran Glasfaser 4 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @HolgerCW last edited by Thomas Braun
                          @holgercw
                          iob stop
                          iob fix
                          iob nodejs-update
                          Dann schauen ob der backitup-Adapter installierbar ist.
                          Edith: Das ist ein Docker bei dir? Dann vergiss es, das geht da glaub ich nicht/anders.
                            Homoran Global Moderator Administrators @HolgerCW last edited by
                            warum nicht?
                            zeigen!
                            wenn man 7 Jahre nichts updated gibt es die alten Repos gar nicht mehr.
                            Hier trifft nach so langer Zeit wirklich zu:
                            kein Backup - kein Mitleid!
                            Du kannst noch versuchen nodejs hochzuziehen um den Controller und einige Adapter upzudaten.
                            Aber da wirst du auch ggf. am Betriebssystem scheitern.
                            Du darfst natürlich nicht versuchen die allerneuesten Versionen draufzuspielen.
                            • Glasfaser
                              Glasfaser @HolgerCW last edited by Glasfaser
                              @holgercw
                              Dann ziehen wir langsam hoch ...
                              Erstmal
                              pkill -u iobroker
                              sudo -H -u iobroker npm install iobroker.js-controller@4.0.24
                              Container danach neu starten .
                              Bei
                              nodejs: v10.18.1
                              @Thomas-Braun kannst du nacher helfen... um erstmal nur auf 16 zu kommen für den alten Container !
                              EDIT :
                              Mähhh .. ab 4.0.24
                              Nur die Node.js Version muss weiterhin mindestens 12.x sein, wie oben bereits ausgeführt.
                              also erst Node-js
                              Thomas Braun H 2 Replies Last reply Reply Quote 0
                                Thomas Braun Most Active @Glasfaser last edited by
                                Keine Ahnung. Ich kann nur apt... Geht das im Container?
                                • Glasfaser
                                  Glasfaser @Thomas Braun last edited by
                                  Ja , geht !
                                    @holgercw
                                    apt update
                                    apt policy nodejs
                                    sagt?
                                      @glasfaser ```
                                      root@ioBroker:/opt/iobroker# pkill -u iobroker
                                      root@ioBroker:/opt/iobroker# sudo -H -u iobroker npm install iobroker.js-controller@4.0.24
                                      npm ERR! code ENOTSUP
                                      npm ERR! notsup Unsupported engine for iobroker.js-controller@4.0.24: wanted: {"node":">=12.0.0"} (current: {"node":"10.18.1","npm":"6.13.4"})
                                      npm ERR! notsup Not compatible with your version of node/npm: iobroker.js-controller@4.0.24
                                      npm ERR! notsup Required: {"node":">=12.0.0"}
                                      npm ERR! notsup Actual: {"npm":"6.13.4","node":"10.18.1"}
                                      npm ERR! /opt/iobroker/.npm/_logs/2024-01-14T13_59_52_793Z-debug.log
                                        HolgerCW @Thomas Braun last edited by
                                        @thomas-braun sagte in QNAP NAS Container ioBroker js-controller und node update:
                                        apt policy nodejs
                                        root@ioBroker:/opt/iobroker# apt update
                                        Ign:1 http://security.debian.org/debian-security stretch/updates InRelease
                                        Fehl:2 http://security.debian.org/debian-security stretch/updates Release
                                          404  Not Found
                                        Ign:3 http://deb.debian.org/debian stretch InRelease
                                        Ign:4 http://deb.debian.org/debian stretch-updates InRelease
                                        Fehl:5 http://deb.debian.org/debian stretch Release
                                          404  Not Found
                                        Fehl:6 http://deb.debian.org/debian stretch-updates Release
                                          404  Not Found
                                        Holen:7 https://deb.nodesource.com/node_10.x stretch InRelease [4.585 B]
                                        Holen:8 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages [767 B]
                                        E: The repository 'http://security.debian.org/debian-security stretch/updates Release' does not have a Release file.
                                        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                                        N: See apt-secure(8) manpage for repository creation and user configuration details.
                                        E: The repository 'http://deb.debian.org/debian stretch Release' does not have a Release file.
                                        E: The repository 'http://deb.debian.org/debian stretch-updates Release' does not have a Release file.
                                        root@ioBroker:/opt/iobroker# apt policy nodejs
                                        nodejs:
                                          Installiert:           10.18.1-1nodesource1
                                          Installationskandidat: 10.24.1-1nodesource1
                                          Versionstabelle:
                                             10.24.1-1nodesource1 500
                                                500 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages
                                         *** 10.18.1-1nodesource1 100
                                                100 /var/lib/dpkg/status
                                          Habe beides durchgeführt. Siehe was die Console ausgespuckt hat in den letzten beiden Posts. Sorry, gestern konnte ich leider nicht mehr antworten.
                                          Gruss
                                          Holger
                                          • Glasfaser
                                            deshalb mein Edit dazu im oberen Beitrag , das erst Nodejs hochgezogen werden muß !!
                                            4278
