    4. IOBroker reagiert nicht mehr | Shelly Adapter
      Thomas Braun Most Active @dike1982 last edited by
      @dike1982
      iob diag
      sagt?
        dike1982 @Thomas Braun last edited by
        Da musst du mir jetzt helfen.
        Ich kann den iobroker ganz gut bediene, bin aber im Linux einen absolute Pfeife!
        Auf das System verbinden und den Befehl eingeben?
          dike1982 @dike1982 last edited by
          @dike1982
          /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                 throw e;
          Error: Connection is closed.
             at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
             at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
             at Object.onceWrapper (node:events:632:26)
             at Socket.emit (node:events:517:28)
             at TCP.<anonymous> (node:net:350:12)
          Emitted 'error' event on ScanStream instance at:
             at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
             at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
             at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
             at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
          Node.js v18.19.0
          D 1 Reply Last reply Reply Quote -1
            dike1982 @dike1982 last edited by dike1982
            Skript v.2023-10-10
            *** BASE SYSTEM ***
             Static hostname: raspberrypi4
                   Icon name: computer
                      Kernel: Linux 6.1.0-rpi6-rpi-v8
                Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.5
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : arm64
            Systemuptime and Load:
             23:22:12 up 27 days, 13:28,  2 users,  load average: 1.71, 2.02, 2.14
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Sat 2024-01-13 23:22:13 CET
                       Universal time: Sat 2024-01-13 22:22:13 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi4
            /home/pi4
            pi4 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            8.2G        2.4G        4.1G        1.2M        1.7G        5.7G
            Swap:           104M          0B        104M
            Total:          8.3G        2.4G        4.2G
                     7811 M total memory
                     2328 M used memory
                     2296 M active memory
                     1340 M inactive memory
                     3947 M free memory
                      138 M buffer memory
                     1519 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            udev           devtmpfs  3.6G     0  3.6G   0% /dev
            tmpfs          tmpfs     782M  1.2M  781M   1% /run
            /dev/mmcblk0p2 ext4       28G  4.3G   23G  17% /
            tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
            /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
            tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
            [Sun Dec 17 09:53:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:92:1C:FA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3656f3dd-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Sun Dec 17 09:53:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sun Dec 17 09:53:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            TARGET           SOURCE         FSTYPE OPTIONS
            /                /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            730M    /var/
            265M    /var/log
            264M    /var/log/journal/7251727675ab4e198e92b6d62c980f75
            202M    /var/cache
            Archived and active journals take up 263.9M in the file system.
            /opt/iobroker/backups:
            112M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            322M    /opt/iobroker/iobroker-data/
            197M    /opt/iobroker/iobroker-data/files
            83M     /opt/iobroker/iobroker-data/backup-objects
            67M     /opt/iobroker/iobroker-data/files/javascript.admin
            48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
            22M     /opt/iobroker/iobroker-data/states.jsonl
            21M     /opt/iobroker/iobroker-data/objects.jsonl
            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
            8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
            8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
            USB-Devices by-id:
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.19.0
            /usr/bin/node           v18.19.0
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            /usr/bin/corepack       0.22.0
            nodejs:
              Installed: 18.19.0-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
             *** 18.19.0-1nodesource1 500
                    100 /var/lib/dpkg/status
                 18.18.2-1nodesource1 500
                 18.18.1-1nodesource1 500
                 18.18.0-1nodesource1 500
                 18.17.1-1nodesource1 500
                 18.17.0-1nodesource1 500
                 18.16.1-1nodesource1 500
                 18.16.0-1nodesource1 500
                 18.15.0-1nodesource1 500
                 18.14.2-1nodesource1 500
                 18.14.1-1nodesource1 500
                 18.14.0-1nodesource1 500
                 18.13.0+dfsg1-1 500
                 18.13.0-1nodesource1 500
                 18.12.0-1nodesource1 500
                 18.11.0-1nodesource1 500
                 18.10.0-1nodesource1 500
                 18.9.1-1nodesource1 500
                 18.9.0-1nodesource1 500
                 18.8.0-1nodesource1 500
                 18.7.0-1nodesource1 500
                 18.6.0-1nodesource1 500
                 18.5.0-1nodesource1 500
                 18.4.0-1nodesource1 500
                 18.3.0-1nodesource1 500
                 18.2.0-1nodesource1 500
                 18.1.0-1nodesource1 500
                 18.0.0-1nodesource1 500
            No problems detected
            Errors in npm tree:
            npm ERR! code ELSPROBLEMS
            npm ERR! missing: chroma-js@^2.4.2, required by iobroker.javascript@7.1.6
            npm ERR! missing: moment-duration-format@^2.3.2, required by iobroker.javascript@7.1.6
            npm ERR! invalid: moment-timezone@0.5.43 /opt/iobroker/node_modules/moment-timezone
            npm ERR! invalid: moment@2.29.4 /opt/iobroker/node_modules/moment
            npm ERR! A complete log of this run can be found in: /home/pi4/.npm/_logs/2024-01-13T22_22_22_872Z-debug-0.log
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.17
            admin:          6.12.0
            javascript:     7.1.6
            Adapters from github:   0
            Adapter State
             Cannot read system.config: undefined (OK when migrating or restoring)
                    throw e;
                at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                at Redis.scan (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                at ScanStream._read (/opt/iobroker/node_modules/ioredis/built/ScanStream.js:36:41)
                at Readable.read (node:internal/streams/readable:539:12)
                at resume_ (node:internal/streams/readable:1040:12)
                at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
            Node.js v18.19.0
            + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi4                             -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi4                             -  enabled, port: 12010
            + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
                    throw e;
            Node.js v18.19.0
            Objects and States
            Objects:        15406
            States:         0
            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
            Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 35
            *** Listening Ports ***
            tcp        0      0 192.168.115.89:2001     0.0.0.0:*               LISTEN      1001       4503948    221765/io.hm-rpc.0
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4296067    217537/iobroker.js-
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4297730    217537/iobroker.js-
            tcp        0      0 192.168.115.89:12010    0.0.0.0:*               LISTEN      1001       4504699    221776/io.hm-rpc.1
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15619      698/sshd: /usr/sbin
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4297753    217556/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       4297962    217807/io.web.0
            tcp6       0      0 :::3500                 :::*                    LISTEN      1001       4296212    217668/io.sonos.0
            tcp6       0      0 :::3000                 :::*                    LISTEN      1001       4297506    217850/io.fullybrow
            tcp6       0      0 :::22                   :::*                    LISTEN      0          15621      698/sshd: /usr/sbin
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       4297874    217705/io.chromecas
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15003      503/avahi-daemon: r
            udp        0      0 0.0.0.0:55119           0.0.0.0:*                           104        15005      503/avahi-daemon: r
            udp6       0      0 fe80::bea5:9acd:17c:546 :::*                                0          209584     594/NetworkManager
            udp6       0      0 :::5353                 :::*                                104        15004      503/avahi-daemon: r
            udp6       0      0 :::48055                :::*                                104        15006      503/avahi-daemon: r
            2024-01-13 23:10:05.953  - info: host.raspberrypi4 instance system.adapter.dwd.0 started with pid 222444
            2024-01-13 23:10:17.966  - warn: dwd.0 (222444) slow connection to objects DB. Still waiting ...
            2024-01-13 23:10:24.376  - warn: dwd.0 (222444) slow connection to states DB. Still waiting ...
            2024-01-13 23:10:40.426  - info: dwd.0 (222444) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
            2024-01-13 23:10:47.858  - info: dwd.0 (222444) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-01-13 23:10:54.206  - info: host.raspberrypi4 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-01-13 23:10:59.765  - info: admin.0 (217556) <== Disconnect system.user.admin from ::ffff:192.168.115.81 admin
            2024-01-13 23:11:08.525  - info: admin.0 (217556) ==> Connected system.user.admin from ::ffff:192.168.115.81
            2024-01-13 23:11:57.002  - info: host.raspberrypi4 "system.adapter.weatherunderground.0" disabled
            2024-01-13 23:11:57.003  - info: host.raspberrypi4 stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
            2024-01-13 23:11:57.004  - info: host.raspberrypi4 stopInstance canceled schedule system.adapter.weatherunderground.0
            2024-01-13 23:15:06.099  - info: host.raspberrypi4 instance system.adapter.dwd.0 started with pid 222463
            2024-01-13 23:15:10.162  - info: host.raspberrypi4 instance system.adapter.daswetter.0 started with pid 222474
            2024-01-13 23:15:11.902  - info: dwd.0 (222463) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
            2024-01-13 23:15:17.906  - info: daswetter.0 (222474) starting. Version 3.1.12 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.19.0, js-controller: 5.0.17
            2024-01-13 23:15:17.991  - info: daswetter.0 (222474) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-01-13 23:15:20.205  - info: daswetter.0 (222474) cleaned everything up...
            2024-01-13 23:15:20.405  - info: host.raspberrypi4 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-01-13 23:15:20.852  - info: dwd.0 (222463) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-01-13 23:15:21.416  - info: host.raspberrypi4 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-01-13 23:20:00.371  - info: host.raspberrypi4 instance system.adapter.dwd.0 started with pid 222507
            2024-01-13 23:20:15.977  - warn: dwd.0 (222507) slow connection to states DB. Still waiting ...
            2024-01-13 23:20:22.341  - info: dwd.0 (222507) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
            2024-01-13 23:21:05.241  - info: dwd.0 (222507) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-01-13 23:21:05.858  - info: host.raspberrypi4 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    v.2023-10-10
                   Icon name: computer
                Architecture: arm64
            Installation:           native
            Kernel:                 aarch64
            Userland:               arm64
            Timezone:               Europe/Berlin (CET, +0100)
            User-ID:                1000
            X-Server:               false
            Pending OS-Updates:     35
            Pending iob updates:    0
            Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
            Recommended versions are nodejs 18.19.0 and npm
            MEMORY:
            Mem:            8.2G        2.6G        4.0G        1.2M        1.8G        5.6G
            Swap:           104M          0B        104M
            Total:          8.3G        2.6G        4.1G
            Active iob-Instances:   19
            ioBroker Core:          js-controller           5.0.17
                                    admin                   6.12.0
            Objects type: jsonl
            States  type: jsonl
            Objects:                15406
            States:                 0
            Size of iob-Database:
            30M     /opt/iobroker/iobroker-data/objects.jsonl
            Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
              @dike1982
              echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
              sudo apt update
              iob stop
              sudo apt full-upgrade
              sudo reboot
              Wenn die Kiste wieder erreichbar ist schauen wir weiter.
                @thomas-braun said in IOBroker reagiert nicht mehr | Shelly Adapter:
                echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref sudo apt update iob stop sudo apt full-upgrade sudo reboot
                Dank läuft!
                  @dike1982
                  Was läuft?
                  Das full-upgrade? Das System? Inkl. iobroker?
                    Das Upgrade!
                      full-upgrade ist durch und bin wieder eingeloggt!
                        @dike1982
                        Dann schau dir jetzt noch Mal das
                        iob diag
                        an.
                        • Glasfaser
                          Glasfaser @dike1982 last edited by
                          @dike1982 sagte in IOBroker reagiert nicht mehr | Shelly Adapter:
                          Objects: 15406
                          States: 0
                          Adapter State
                          Kannst du nochmal
                          iob diag
                          zeigen , da dein States 0 waren !
                            iob diag
                            Hier das Ergebnis:
                            Shelly-Adapter ist aus auf Pause.
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                      Kernel: Linux 6.1.0-rpi7-rpi-v8
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                             23:47:15 up 8 min,  2 users,  load average: 0.70, 0.69, 0.46
                            CPU threads: 4
                            Current issues:
                                           Local time: Sat 2024-01-13 23:47:15 CET
                                       Universal time: Sat 2024-01-13 22:47:15 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi4
                            /home/pi4
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            8.2G        1.6G        6.3G        1.2M        497M        6.6G
                            Swap:           104M          0B        104M
                            Total:          8.3G        1.6G        6.4G
                                     7811 M total memory
                                     1486 M used memory
                                     1423 M active memory
                                      299 M inactive memory
                                     5969 M free memory
                                       40 M buffer memory
                                      433 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /dev/mmcblk0p2 ext4       28G  4.6G   22G  18% /
                            [Sat Jan 13 23:38:40 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:92:1C:FA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3656f3dd-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Sat Jan 13 23:38:42 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Sat Jan 13 23:38:44 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                            /var:
                            741M    /var/
                            273M    /var/log
                            272M    /var/log/journal/7251727675ab4e198e92b6d62c980f75
                            202M    /var/cache
                            Archived and active journals take up 271.9M in the file system.
                            338M    /opt/iobroker/iobroker-data/
                            33M     /opt/iobroker/iobroker-data/objects.jsonl
                            26M     /opt/iobroker/iobroker-data/states.jsonl
                            USB-Devices by-id:
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            nodejs:
                              Version table:
                                 18.19.0+dfsg-6~deb12u1 500
                             *** 18.19.0-1nodesource1 1001
                                 18.18.2-1nodesource1 1001
                                 18.18.1-1nodesource1 1001
                                 18.18.0-1nodesource1 1001
                                 18.17.1-1nodesource1 1001
                                 18.17.0-1nodesource1 1001
                                 18.16.1-1nodesource1 1001
                                 18.16.0-1nodesource1 1001
                                 18.15.0-1nodesource1 1001
                                 18.14.2-1nodesource1 1001
                                 18.14.1-1nodesource1 1001
                                 18.14.0-1nodesource1 1001
                                 18.13.0+dfsg1-1 500
                                 18.13.0-1nodesource1 1001
                                 18.12.0-1nodesource1 1001
                                 18.11.0-1nodesource1 1001
                                 18.10.0-1nodesource1 1001
                                 18.9.1-1nodesource1 1001
                                 18.9.0-1nodesource1 1001
                                 18.8.0-1nodesource1 1001
                                 18.7.0-1nodesource1 1001
                                 18.6.0-1nodesource1 1001
                                 18.5.0-1nodesource1 1001
                                 18.4.0-1nodesource1 1001
                                 18.3.0-1nodesource1 1001
                                 18.2.0-1nodesource1 1001
                                 18.1.0-1nodesource1 1001
                                 18.0.0-1nodesource1 1001
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.12.0
                            javascript:     7.1.6
                            Adapter State
                            + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
                            + system.adapter.chromecast.0             : chromecast            : raspberrypi4                             -  enabled
                            + system.adapter.cloud.0                  : cloud                 : raspberrypi4                             -  enabled
                              system.adapter.daswetter.0              : daswetter             : raspberrypi4                             -  enabled
                            + system.adapter.device-watcher.0         : device-watcher        : raspberrypi4                             -  enabled
                              system.adapter.discovery.0              : discovery             : raspberrypi4                             - disabled
                              system.adapter.dwd.0                    : dwd                   : raspberrypi4                             -  enabled
                              system.adapter.flot.0                   : flot                  : raspberrypi4                             -  enabled
                            + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi4                             -  enabled
                            + system.adapter.hm-rega.0                : hm-rega               : raspberrypi4                             -  enabled
                            + system.adapter.hue-extended.0           : hue-extended          : raspberrypi4                             -  enabled
                              system.adapter.ical.0                   : ical                  : raspberrypi4                             -  enabled
                              system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi4                             -  enabled
                            + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
                              system.adapter.lgtv.0                   : lgtv                  : raspberrypi4                             - disabled
                            + system.adapter.mercedesme.0             : mercedesme            : raspberrypi4                             -  enabled
                              system.adapter.net-tools.0              : net-tools             : raspberrypi4                             - disabled
                              system.adapter.openknx.0                : openknx               : raspberrypi4                             - disabled
                              system.adapter.openknx.1                : openknx               : raspberrypi4                             - disabled
                              system.adapter.ping.0                   : ping                  : raspberrypi4                             - disabled
                            + system.adapter.scenes.0                 : scenes                : raspberrypi4                             -  enabled
                              system.adapter.shelly.0                 : shelly                : raspberrypi4                             - disabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.sonos.0                  : sonos                 : raspberrypi4                             -  enabled
                            + system.adapter.tr-064.0                 : tr-064                : raspberrypi4                             -  enabled
                            + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4                             -  enabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             -  enabled
                              system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi4                             -  enabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi4                             -  enabled
                              system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi4                             -  enabled
                              system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             -  enabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4                             -  enabled
                              system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
                              system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4                             - disabled
                            + instance is alive
                            Used repository: stable
                            Adapter    "admin"        : 6.12.0   , installed 6.12.0
                            Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                            Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                            Adapter    "daswetter"    : 3.1.12   , installed 3.1.12
                            Adapter    "device-watcher": 2.9.6   , installed 2.9.6
                            Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
                            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                            Controller "js-controller": 5.0.17   , installed 5.0.17
                            Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
                            Adapter    "mercedesme"   : 0.1.1    , installed 0.1.6
                            Adapter    "openknx"      : 0.6.3    , installed 0.6.3
                            Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                            Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                            Adapter    "swiss-weather-api": 2.0.3, installed 2.0.3
                            Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                            Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
                            Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                            Adapter    "web"          : 6.1.10   , installed 6.1.10
                            Adapter    "ws"           : 2.5.8    , installed 2.5.8
                            Objects and States
                            Objects:        15847
                            States:         13319
                            Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                            Pending Updates: 0
                            tcp        0      0 192.168.115.89:12010    0.0.0.0:*               LISTEN      1001       15886      850/io.hm-rpc.1
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13103      658/iobroker.js-con
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13114      658/iobroker.js-con
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13057      683/sshd: /usr/sbin
                            tcp        0      0 192.168.115.89:2001     0.0.0.0:*               LISTEN      1001       14083      830/io.hm-rpc.0
                            tcp6       0      0 :::3000                 :::*                    LISTEN      1001       17537      1029/io.fullybrowse
                            tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16027      884/io.sonos.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17471      988/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14027      718/io.admin.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          13059      683/sshd: /usr/sbin
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       16101      939/io.chromecast.0
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15528      468/avahi-daemon: r
                            udp        0      0 0.0.0.0:59423           0.0.0.0:*                           104        15530      468/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                104        15529      468/avahi-daemon: r
                            udp6       0      0 :::42496                :::*                                104        15531      468/avahi-daemon: r
                            udp6       0      0 fe80::bea5:9acd:17c:546 :::*                                0          13984      515/NetworkManager
                            2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
                            2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=13 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705144977704
                            2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Room 13 = OG Spielzimmer is open or disabled, no vent warning set
                            2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=14 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705185983307
                            2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Room 14 = OG Wohnzimmer is open or disabled, no vent warning set
                            2024-01-13 23:46:25.243  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=15 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705185983768
                            2024-01-13 23:46:25.243  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Room 15 = Treppenhaus is open or disabled, no vent warning set
                            2024-01-13 23:46:25.243  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
                            2024-01-13 23:46:25.250  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithOpenDoorsList
                            2024-01-13 23:46:25.251  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenDoors: Keine Tür/en geöffnet
                            2024-01-13 23:46:25.251  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithTiltedDoorsList
                            2024-01-13 23:46:25.251  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithTiltedDoors: Keine Tür gekippt
                            2024-01-13 23:46:25.252  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithOpenWindowsList
                            2024-01-13 23:46:25.252  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenWindows: Alle Fenster sind geschlossen
                            2024-01-13 23:46:25.252  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithTiltedWindowsList
                            2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithTiltedWindows: Keine Fenster gekippt
                            2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: CreateOpenRoomsList()
                            2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenings:
                            2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
                            2024-01-13 23:47:48.717  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.115.81 javascript
                            2024-01-13 23:48:14.589  - info: web.0 (988) ==> Connected system.user.admin from ::ffff:192.168.115.81
                            2024-01-13 23:48:27.235  - info: web.0 (988) <== Disconnect system.user.admin from ::ffff:192.168.115.81 vis.0
                            2024-01-13 23:48:27.593  - info: web.0 (988) ==> Connected system.user.admin from ::ffff:192.168.115.81
                                                    v.2023-10-10
                                   Icon name: computer
                                Architecture: arm64
                            Kernel:                 aarch64
                            Userland:               arm64
                            User-ID:                1000
                            X-Server:               false
                            Pending OS-Updates:     0
                                                    /usr/bin/npm            10.2.3
                                                    /usr/bin/npx            10.2.3
                            Recommended versions are nodejs 18.19.0 and npm 10.2.3
                            MEMORY:
                            Mem:            8.2G        1.6G        5.9G        1.2M        831M        6.6G
                            Swap:           104M          0B        104M
                            Total:          8.3G        1.6G        6.0G
                                                    admin                   6.12.0
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                15847
                            States:                 13319
                              @dike1982
                              Ich seh keine Unstimmigkeiten mehr in der Ausgabe.
                                Okay soll ich dann den Shelly-Adapter mal wieder anwerfen?
                                  @dike1982
                                  Ja. Und schau dir das Logfile dann dazu in Echtzeit an:
                                  iob logs --watch
                                    024-01-14 00:01:27.778  - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 2664
                                    2024-01-14 00:01:27.466  - info: host.raspberrypi4 "system.adapter.shelly.0" enabled
                                    2024-01-14 00:01:27.778  - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 2664
                                    2024-01-14 00:01:31.946  - info: shelly.0 (2664) starting. Version 6.7.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.19.0, js-controller: 5.0.17
                                    2024-01-14 00:01:40.337  - info: shelly.0 (2664) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
                                    2024-01-14 00:01:41.130  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplusplugs-e465b860af58" connected!
                                    2024-01-14 00:01:42.462  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-C8C9A325943E" connected!
                                    2024-01-14 00:01:47.694  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204abaf8c" connected!
                                    2024-01-14 00:01:48.225  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa80e8" connected!
                                    2024-01-14 00:01:48.642  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684114" connected!
                                    2024-01-14 00:01:51.090  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplusplugs / shellyplusplugs-e465b860af58 / shellyplusplugs#e465b860af58#1) (false)
                                    2024-01-14 00:01:51.843  - error: shelly.0 (2664) [MQTT] Wrong MQTT authentification of client "shelly1pmmini-543204abcca8"
                                    2024-01-14 00:01:52.038  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abcca8 / shelly1pmmini#543204abcca8#1) (false)
                                    2024-01-14 00:01:56.147  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa1ae0" connected!
                                    2024-01-14 00:01:57.690  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abaf8c / shelly1pmmini#543204abaf8c#1) (false)
                                    2024-01-14 00:01:58.223  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa80e8 / shelly1pmmini#543204aa80e8#1) (false)
                                    2024-01-14 00:01:58.474  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ab95d8" connected!
                                    2024-01-14 00:01:58.637  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684114 / shellyplus2pm#a0a3b3684114#1) (false)
                                    2024-01-14 00:01:59.963  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aaa1f4" connected!
                                    2024-01-14 00:02:04.538  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-C8C9A325B2BE" connected!
                                    2024-01-14 00:02:06.144  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa1ae0 / shelly1pmmini#543204aa1ae0#1) (false)
                                    2024-01-14 00:02:06.889  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b8604d6c" connected!
                                    2024-01-14 00:02:08.474  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ab95d8 / shelly1pmmini#543204ab95d8#1) (false)
                                    2024-01-14 00:02:09.870  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aaa1f4 / shelly1pmmini#543204aaa1f4#1) (false)
                                    2024-01-14 00:02:10.128  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b893c4d0" connected!
                                    2024-01-14 00:02:11.893  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204adcc50" connected!
                                    2024-01-14 00:02:13.197  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-08F9E047CD2F" connected!
                                    2024-01-14 00:02:13.611  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa8d5c" connected!
                                    2024-01-14 00:02:16.875  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b8604d6c / shellyplus2pm#e465b8604d6c#1) (false)
                                    2024-01-14 00:02:19.387  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-C8C9A3258A34" connected!
                                    2024-01-14 00:02:20.117  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b893c4d0 / shellyplus2pm#e465b893c4d0#1) (false)
                                    2024-01-14 00:02:21.787  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-08F9E047CBED" connected!
                                    2024-01-14 00:02:21.884  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204adcc50 / shelly1pmmini#543204adcc50#1) (false)
                                    2024-01-14 00:02:22.044  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acaf70" connected!
                                    2024-01-14 00:02:23.605  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa8d5c / shelly1pmmini#543204aa8d5c#1) (false)
                                    2024-01-14 00:02:25.623  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684110" connected!
                                    2024-01-14 00:02:30.652  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204addca8" connected!
                                    2024-01-14 00:02:32.037  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acaf70 / shelly1pmmini#543204acaf70#1) (false)
                                    2024-01-14 00:02:32.452  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acfe10" connected!
                                    2024-01-14 00:02:32.600  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ad6264" connected!
                                    2024-01-14 00:02:34.964  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acee28" connected!
                                    2024-01-14 00:02:35.620  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684110 / shellyplus2pm#a0a3b3684110#1) (false)
                                    2024-01-14 00:02:40.650  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204addca8 / shelly1pmmini#543204addca8#1) (false)
                                    2024-01-14 00:02:42.452  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acfe10 / shelly1pmmini#543204acfe10#1) (false)
                                    2024-01-14 00:02:42.593  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ad6264 / shelly1pmmini#543204ad6264#1) (false)
                                    2024-01-14 00:02:44.952  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acee28 / shelly1pmmini#543204acee28#1) (false)
                                    2024-01-14 00:02:47.436  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplusplugs-e465b860af58" connected!
                                    2024-01-14 00:02:48.615  - error: shelly.0 (2664) [MQTT] Wrong MQTT authentification of client "shelly1pmmini-543204abcca8"
                                    2024-01-14 00:02:48.643  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abcca8 / shelly1pmmini#543204abcca8#1) (false)
                                    2024-01-14 00:02:54.764  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684114" connected!
                                    2024-01-14 00:02:54.980  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa80e8" connected!
                                    2024-01-14 00:02:55.029  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204abaf8c" connected!
                                    2024-01-14 00:02:57.435  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplusplugs / shellyplusplugs-e465b860af58 / shellyplusplugs#e465b860af58#1) (false)
                                    2024-01-14 00:03:02.463  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa1ae0" connected!
                                    2024-01-14 00:03:04.357  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ab95d8" connected!
                                    2024-01-14 00:03:04.755  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684114 / shellyplus2pm#a0a3b3684114#1) (false)
                                    2024-01-14 00:03:04.970  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa80e8 / shelly1pmmini#543204aa80e8#1) (false)
                                    2024-01-14 00:03:05.025  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abaf8c / shelly1pmmini#543204abaf8c#1) (false)
                                    2024-01-14 00:03:08.301  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aaa1f4" connected!
                                    2024-01-14 00:03:12.456  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa1ae0 / shelly1pmmini#543204aa1ae0#1) (false)
                                    2024-01-14 00:03:13.863  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b8604d6c" connected!
                                    2024-01-14 00:03:14.349  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ab95d8 / shelly1pmmini#543204ab95d8#1) (false)
                                    2024-01-14 00:03:16.095  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b893c4d0" connected!
                                    2024-01-14 00:03:16.551  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204adcc50" connected!
                                    2024-01-14 00:03:18.298  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aaa1f4 / shelly1pmmini#543204aaa1f4#1) (false)
                                    2024-01-14 00:03:20.921  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa8d5c" connected!
                                    2024-01-14 00:03:23.854  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b8604d6c / shellyplus2pm#e465b8604d6c#1) (false)
                                    2024-01-14 00:03:26.086  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b893c4d0 / shellyplus2pm#e465b893c4d0#1) (false)
                                    2024-01-14 00:03:26.542  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204adcc50 / shelly1pmmini#543204adcc50#1) (false)
                                    2024-01-14 00:03:30.430  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acaf70" connected!
                                    2024-01-14 00:03:30.913  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa8d5c / shelly1pmmini#543204aa8d5c#1) (false)
                                    2024-01-14 00:03:32.492  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684110" connected!
                                    Sieht soweit Okay aus, bis auf die 2 error ?!
                                      Ich kenne den shelly-Adapter nicht. Aber ich würde auch sagen, das ist soweit harmlos.
                                        jetzt bekomme ich aber wieder Probleme;#
                                        Cannot read compact mode by host "system.host.raspberrypi4": timeout
                                          Thomas Braun Most Active @dike1982 last edited by Thomas Braun
                                          @dike1982
                                          Haste den denn aktiv?
                                            Wen?
                                            2024-01-14 00:09:16.821  - warn: dwd.0 (2682) get state error: Connection is closed.
                                            2024-01-14 00:09:16.831  - warn: dwd.0 (2682) get state error: Connection is closed.
                                            2024-01-14 00:09:16.832  - warn: dwd.0 (2682) get state error: Connection is closed.
                                            2024-01-14 00:09:16.833  - warn: dwd.0 (2682) get state error: Connection is closed.
                                            2024-01-14 00:09:16.834  - warn: dwd.0 (2682) get state error: Connection is closed.
                                            2024-01-14 00:09:16.839  - warn: dwd.0 (2682) get state error: Connection is closed.
                                            2024-01-14 00:09:16.840  - warn: dwd.0 (2682) get state error: Connection is closed.
                                            2024-01-14 00:09:16.848  - warn: dwd.0 (2682) get state error: Connection is closed.
                                            2024-01-14 00:09:16.849  - warn: dwd.0 (2682) get state error: Connection is closed.
                                            2024-01-14 00:09:16.898  - warn: dwd.0 (2682) Can not read iobroker system configuration. Disable Rain Radar.
                                            2024-01-14 00:09:16.916  - error: dwd.0 (2682) Cannot find view "system" for search "state" : Connection is closed.
                                            2024-01-14 00:09:16.929  - error: dwd.0 (2682) Could not read existing states: Cannot find view "system"
                                            2024-01-14 00:09:16.959  - warn: dwd.0 (2682) get state error: Connection is closed.
                                            2024-01-14 00:09:16.960  - warn: dwd.0 (2682) get state error: Connection is closed.
                                            2024-01-14 00:09:16.676  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684110 / shellyplus2pm#a0a3b3684110#1) (false)
                                            2024-01-14 00:09:16.765  - info: dwd.0 (2682) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
                                            DWD macht auch Zicken
                                            D Thomas Braun 2 Replies Last reply Reply Quote 0
                                            2325
