    4. IOBroker reagiert nicht mehr | Shelly Adapter
      dike1982 @dike1982 last edited by dike1982
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi4
             Icon name: computer
                Kernel: Linux 6.1.0-rpi6-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       23:22:12 up 27 days, 13:28,  2 users,  load average: 1.71, 2.02, 2.14
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sat 2024-01-13 23:22:13 CET
                 Universal time: Sat 2024-01-13 22:22:13 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi4
      /home/pi4
      pi4 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            8.2G        2.4G        4.1G        1.2M        1.7G        5.7G
      Swap:           104M          0B        104M
      Total:          8.3G        2.4G        4.2G
               7811 M total memory
               2328 M used memory
               2296 M active memory
               1340 M inactive memory
               3947 M free memory
                138 M buffer memory
               1519 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     782M  1.2M  781M   1% /run
      /dev/mmcblk0p2 ext4       28G  4.3G   23G  17% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      [Sun Dec 17 09:53:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:92:1C:FA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3656f3dd-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun Dec 17 09:53:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Dec 17 09:53:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      730M    /var/
      265M    /var/log
      264M    /var/log/journal/7251727675ab4e198e92b6d62c980f75
      202M    /var/cache
      Archived and active journals take up 263.9M in the file system.
      /opt/iobroker/backups:
      112M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      322M    /opt/iobroker/iobroker-data/
      197M    /opt/iobroker/iobroker-data/files
      83M     /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      22M     /opt/iobroker/iobroker-data/states.jsonl
      21M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 500
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: chroma-js@^2.4.2, required by iobroker.javascript@7.1.6
      npm ERR! missing: moment-duration-format@^2.3.2, required by iobroker.javascript@7.1.6
      npm ERR! invalid: moment-timezone@0.5.43 /opt/iobroker/node_modules/moment-timezone
      npm ERR! invalid: moment@2.29.4 /opt/iobroker/node_modules/moment
      npm ERR! A complete log of this run can be found in: /home/pi4/.npm/_logs/2024-01-13T22_22_22_872Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   0
      Adapter State
       Cannot read system.config: undefined (OK when migrating or restoring)
      /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
              throw e;
      Error: Connection is closed.
          at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
          at Redis.scan (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
          at ScanStream._read (/opt/iobroker/node_modules/ioredis/built/ScanStream.js:36:41)
          at Readable.read (node:internal/streams/readable:539:12)
          at resume_ (node:internal/streams/readable:1040:12)
          at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
      Emitted 'error' event on ScanStream instance at:
          at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
          at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
          at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      Node.js v18.19.0
      + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi4                             -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi4                             -  enabled, port: 12010
      + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
              throw e;
          at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
          at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
          at Object.onceWrapper (node:events:632:26)
          at Socket.emit (node:events:517:28)
          at TCP.<anonymous> (node:net:350:12)
      Node.js v18.19.0
      Objects and States
      Objects:        15406
      States:         0
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 35
      *** Listening Ports ***
      tcp        0      0 192.168.115.89:2001     0.0.0.0:*               LISTEN      1001       4503948    221765/io.hm-rpc.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4296067    217537/iobroker.js-
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4297730    217537/iobroker.js-
      tcp        0      0 192.168.115.89:12010    0.0.0.0:*               LISTEN      1001       4504699    221776/io.hm-rpc.1
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15619      698/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4297753    217556/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       4297962    217807/io.web.0
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       4296212    217668/io.sonos.0
      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       4297506    217850/io.fullybrow
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15621      698/sshd: /usr/sbin
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       4297874    217705/io.chromecas
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15003      503/avahi-daemon: r
      udp        0      0 0.0.0.0:55119           0.0.0.0:*                           104        15005      503/avahi-daemon: r
      udp6       0      0 fe80::bea5:9acd:17c:546 :::*                                0          209584     594/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        15004      503/avahi-daemon: r
      udp6       0      0 :::48055                :::*                                104        15006      503/avahi-daemon: r
      2024-01-13 23:10:05.953  - info: host.raspberrypi4 instance system.adapter.dwd.0 started with pid 222444
      2024-01-13 23:10:17.966  - warn: dwd.0 (222444) slow connection to objects DB. Still waiting ...
      2024-01-13 23:10:24.376  - warn: dwd.0 (222444) slow connection to states DB. Still waiting ...
      2024-01-13 23:10:40.426  - info: dwd.0 (222444) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
      2024-01-13 23:10:47.858  - info: dwd.0 (222444) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-13 23:10:54.206  - info: host.raspberrypi4 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-01-13 23:10:59.765  - info: admin.0 (217556) <== Disconnect system.user.admin from ::ffff:192.168.115.81 admin
      2024-01-13 23:11:08.525  - info: admin.0 (217556) ==> Connected system.user.admin from ::ffff:192.168.115.81
      2024-01-13 23:11:57.002  - info: host.raspberrypi4 "system.adapter.weatherunderground.0" disabled
      2024-01-13 23:11:57.003  - info: host.raspberrypi4 stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
      2024-01-13 23:11:57.004  - info: host.raspberrypi4 stopInstance canceled schedule system.adapter.weatherunderground.0
      2024-01-13 23:15:06.099  - info: host.raspberrypi4 instance system.adapter.dwd.0 started with pid 222463
      2024-01-13 23:15:10.162  - info: host.raspberrypi4 instance system.adapter.daswetter.0 started with pid 222474
      2024-01-13 23:15:11.902  - info: dwd.0 (222463) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
      2024-01-13 23:15:17.906  - info: daswetter.0 (222474) starting. Version 3.1.12 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.19.0, js-controller: 5.0.17
      2024-01-13 23:15:17.991  - info: daswetter.0 (222474) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2024-01-13 23:15:20.205  - info: daswetter.0 (222474) cleaned everything up...
      2024-01-13 23:15:20.405  - info: host.raspberrypi4 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-01-13 23:15:20.852  - info: dwd.0 (222463) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-13 23:15:21.416  - info: host.raspberrypi4 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-01-13 23:20:00.371  - info: host.raspberrypi4 instance system.adapter.dwd.0 started with pid 222507
      2024-01-13 23:20:15.977  - warn: dwd.0 (222507) slow connection to states DB. Still waiting ...
      2024-01-13 23:20:22.341  - info: dwd.0 (222507) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
      2024-01-13 23:21:05.241  - info: dwd.0 (222507) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-13 23:21:05.858  - info: host.raspberrypi4 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              v.2023-10-10
             Icon name: computer
          Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               arm64
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     35
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
      Recommended versions are nodejs 18.19.0 and npm
      MEMORY:
      Mem:            8.2G        2.6G        4.0G        1.2M        1.8G        5.6G
      Swap:           104M          0B        104M
      Total:          8.3G        2.6G        4.1G
      Active iob-Instances:   19
      ioBroker Core:          js-controller           5.0.17
                              admin                   6.12.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                15406
      States:                 0
      Size of iob-Database:
      30M     /opt/iobroker/iobroker-data/objects.jsonl
      Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @dike1982 last edited by
        @dike1982
        echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
        sudo apt update
        iob stop
        sudo apt full-upgrade
        sudo reboot
        Wenn die Kiste wieder erreichbar ist schauen wir weiter.
          dike1982 @Thomas Braun last edited by
          @thomas-braun said in IOBroker reagiert nicht mehr | Shelly Adapter:
          echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref sudo apt update iob stop sudo apt full-upgrade sudo reboot
          Dank läuft!
            @dike1982
            Was läuft?
            Das full-upgrade? Das System? Inkl. iobroker?
              Das Upgrade!
                full-upgrade ist durch und bin wieder eingeloggt!
                  @dike1982
                  Dann schau dir jetzt noch Mal das
                  iob diag
                  an.
                  • Glasfaser
                    Glasfaser @dike1982 last edited by
                    @dike1982 sagte in IOBroker reagiert nicht mehr | Shelly Adapter:
                    Objects: 15406
                    States: 0
                    Adapter State
                    Kannst du nochmal
                    iob diag
                    zeigen , da dein States 0 waren !
                      iob diag
                      Hier das Ergebnis:
                      Shelly-Adapter ist aus auf Pause.
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                             Icon name: computer
                                Kernel: Linux 6.1.0-rpi7-rpi-v8
                          Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                       23:47:15 up 8 min,  2 users,  load average: 0.70, 0.69, 0.46
                      CPU threads: 4
                      Current issues:
                                     Local time: Sat 2024-01-13 23:47:15 CET
                                 Universal time: Sat 2024-01-13 22:47:15 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi4
                      /home/pi4
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            8.2G        1.6G        6.3G        1.2M        497M        6.6G
                      Swap:           104M          0B        104M
                      Total:          8.3G        1.6G        6.4G
                               7811 M total memory
                               1486 M used memory
                               1423 M active memory
                                299 M inactive memory
                               5969 M free memory
                                 40 M buffer memory
                                433 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/mmcblk0p2 ext4       28G  4.6G   22G  18% /
                      [Sat Jan 13 23:38:40 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:92:1C:FA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3656f3dd-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Sat Jan 13 23:38:42 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Sat Jan 13 23:38:44 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                      /var:
                      741M    /var/
                      273M    /var/log
                      272M    /var/log/journal/7251727675ab4e198e92b6d62c980f75
                      202M    /var/cache
                      Archived and active journals take up 271.9M in the file system.
                      338M    /opt/iobroker/iobroker-data/
                      33M     /opt/iobroker/iobroker-data/objects.jsonl
                      26M     /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                           18.19.0+dfsg-6~deb12u1 500
                       *** 18.19.0-1nodesource1 1001
                           18.18.2-1nodesource1 1001
                           18.18.1-1nodesource1 1001
                           18.18.0-1nodesource1 1001
                           18.17.1-1nodesource1 1001
                           18.17.0-1nodesource1 1001
                           18.16.1-1nodesource1 1001
                           18.16.0-1nodesource1 1001
                           18.15.0-1nodesource1 1001
                           18.14.2-1nodesource1 1001
                           18.14.1-1nodesource1 1001
                           18.14.0-1nodesource1 1001
                           18.13.0+dfsg1-1 500
                           18.13.0-1nodesource1 1001
                           18.12.0-1nodesource1 1001
                           18.11.0-1nodesource1 1001
                           18.10.0-1nodesource1 1001
                           18.9.1-1nodesource1 1001
                           18.9.0-1nodesource1 1001
                           18.8.0-1nodesource1 1001
                           18.7.0-1nodesource1 1001
                           18.6.0-1nodesource1 1001
                           18.5.0-1nodesource1 1001
                           18.4.0-1nodesource1 1001
                           18.3.0-1nodesource1 1001
                           18.2.0-1nodesource1 1001
                           18.1.0-1nodesource1 1001
                           18.0.0-1nodesource1 1001
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapter State
                      + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
                      + system.adapter.chromecast.0             : chromecast            : raspberrypi4                             -  enabled
                      + system.adapter.cloud.0                  : cloud                 : raspberrypi4                             -  enabled
                        system.adapter.daswetter.0              : daswetter             : raspberrypi4                             -  enabled
                      + system.adapter.device-watcher.0         : device-watcher        : raspberrypi4                             -  enabled
                        system.adapter.discovery.0              : discovery             : raspberrypi4                             - disabled
                        system.adapter.dwd.0                    : dwd                   : raspberrypi4                             -  enabled
                        system.adapter.flot.0                   : flot                  : raspberrypi4                             -  enabled
                      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi4                             -  enabled
                      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi4                             -  enabled
                      + system.adapter.hue-extended.0           : hue-extended          : raspberrypi4                             -  enabled
                        system.adapter.ical.0                   : ical                  : raspberrypi4                             -  enabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi4                             -  enabled
                      + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
                        system.adapter.lgtv.0                   : lgtv                  : raspberrypi4                             - disabled
                      + system.adapter.mercedesme.0             : mercedesme            : raspberrypi4                             -  enabled
                        system.adapter.net-tools.0              : net-tools             : raspberrypi4                             - disabled
                        system.adapter.openknx.0                : openknx               : raspberrypi4                             - disabled
                        system.adapter.openknx.1                : openknx               : raspberrypi4                             - disabled
                        system.adapter.ping.0                   : ping                  : raspberrypi4                             - disabled
                      + system.adapter.scenes.0                 : scenes                : raspberrypi4                             -  enabled
                        system.adapter.shelly.0                 : shelly                : raspberrypi4                             - disabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.sonos.0                  : sonos                 : raspberrypi4                             -  enabled
                      + system.adapter.tr-064.0                 : tr-064                : raspberrypi4                             -  enabled
                      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4                             -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             -  enabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi4                             -  enabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi4                             -  enabled
                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi4                             -  enabled
                        system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             -  enabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4                             -  enabled
                        system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
                        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4                             - disabled
                      + instance is alive
                      Used repository: stable
                      Adapter    "admin"        : 6.12.0   , installed 6.12.0
                      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                      Adapter    "daswetter"    : 3.1.12   , installed 3.1.12
                      Adapter    "device-watcher": 2.9.6   , installed 2.9.6
                      Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
                      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                      Controller "js-controller": 5.0.17   , installed 5.0.17
                      Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
                      Adapter    "mercedesme"   : 0.1.1    , installed 0.1.6
                      Adapter    "openknx"      : 0.6.3    , installed 0.6.3
                      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                      Adapter    "swiss-weather-api": 2.0.3, installed 2.0.3
                      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
                      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                      Adapter    "web"          : 6.1.10   , installed 6.1.10
                      Adapter    "ws"           : 2.5.8    , installed 2.5.8
                      Objects and States
                      Objects:        15847
                      States:         13319
                      Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                      Pending Updates: 0
                      tcp        0      0 192.168.115.89:12010    0.0.0.0:*               LISTEN      1001       15886      850/io.hm-rpc.1
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13103      658/iobroker.js-con
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13114      658/iobroker.js-con
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13057      683/sshd: /usr/sbin
                      tcp        0      0 192.168.115.89:2001     0.0.0.0:*               LISTEN      1001       14083      830/io.hm-rpc.0
                      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       17537      1029/io.fullybrowse
                      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16027      884/io.sonos.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17471      988/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14027      718/io.admin.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          13059      683/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       16101      939/io.chromecast.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15528      468/avahi-daemon: r
                      udp        0      0 0.0.0.0:59423           0.0.0.0:*                           104        15530      468/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                104        15529      468/avahi-daemon: r
                      udp6       0      0 :::42496                :::*                                104        15531      468/avahi-daemon: r
                      udp6       0      0 fe80::bea5:9acd:17c:546 :::*                                0          13984      515/NetworkManager
                      2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
                      2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=13 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705144977704
                      2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Room 13 = OG Spielzimmer is open or disabled, no vent warning set
                      2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=14 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705185983307
                      2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Room 14 = OG Wohnzimmer is open or disabled, no vent warning set
                      2024-01-13 23:46:25.243  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=15 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705185983768
                      2024-01-13 23:46:25.243  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Room 15 = Treppenhaus is open or disabled, no vent warning set
                      2024-01-13 23:46:25.243  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
                      2024-01-13 23:46:25.250  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithOpenDoorsList
                      2024-01-13 23:46:25.251  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenDoors: Keine Tür/en geöffnet
                      2024-01-13 23:46:25.251  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithTiltedDoorsList
                      2024-01-13 23:46:25.251  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithTiltedDoors: Keine Tür gekippt
                      2024-01-13 23:46:25.252  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithOpenWindowsList
                      2024-01-13 23:46:25.252  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenWindows: Alle Fenster sind geschlossen
                      2024-01-13 23:46:25.252  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithTiltedWindowsList
                      2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithTiltedWindows: Keine Fenster gekippt
                      2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: CreateOpenRoomsList()
                      2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenings:
                      2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
                      2024-01-13 23:47:48.717  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.115.81 javascript
                      2024-01-13 23:48:14.589  - info: web.0 (988) ==> Connected system.user.admin from ::ffff:192.168.115.81
                      2024-01-13 23:48:27.235  - info: web.0 (988) <== Disconnect system.user.admin from ::ffff:192.168.115.81 vis.0
                      2024-01-13 23:48:27.593  - info: web.0 (988) ==> Connected system.user.admin from ::ffff:192.168.115.81
                                              v.2023-10-10
                             Icon name: computer
                          Architecture: arm64
                      Kernel:                 aarch64
                      Userland:               arm64
                      User-ID:                1000
                      X-Server:               false
                      Pending OS-Updates:     0
                                              /usr/bin/npm            10.2.3
                                              /usr/bin/npx            10.2.3
                      Recommended versions are nodejs 18.19.0 and npm 10.2.3
                      MEMORY:
                      Mem:            8.2G        1.6G        5.9G        1.2M        831M        6.6G
                      Swap:           104M          0B        104M
                      Total:          8.3G        1.6G        6.0G
                                              admin                   6.12.0
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                15847
                      States:                 13319
                        @dike1982
                        Ich seh keine Unstimmigkeiten mehr in der Ausgabe.
                          Okay soll ich dann den Shelly-Adapter mal wieder anwerfen?
                            @dike1982
                            Ja. Und schau dir das Logfile dann dazu in Echtzeit an:
                            iob logs --watch
                              024-01-14 00:01:27.778  - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 2664
                              2024-01-14 00:01:27.466  - info: host.raspberrypi4 "system.adapter.shelly.0" enabled
                              2024-01-14 00:01:27.778  - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 2664
                              2024-01-14 00:01:31.946  - info: shelly.0 (2664) starting. Version 6.7.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.19.0, js-controller: 5.0.17
                              2024-01-14 00:01:40.337  - info: shelly.0 (2664) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
                              2024-01-14 00:01:41.130  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplusplugs-e465b860af58" connected!
                              2024-01-14 00:01:42.462  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-C8C9A325943E" connected!
                              2024-01-14 00:01:47.694  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204abaf8c" connected!
                              2024-01-14 00:01:48.225  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa80e8" connected!
                              2024-01-14 00:01:48.642  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684114" connected!
                              2024-01-14 00:01:51.090  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplusplugs / shellyplusplugs-e465b860af58 / shellyplusplugs#e465b860af58#1) (false)
                              2024-01-14 00:01:51.843  - error: shelly.0 (2664) [MQTT] Wrong MQTT authentification of client "shelly1pmmini-543204abcca8"
                              2024-01-14 00:01:52.038  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abcca8 / shelly1pmmini#543204abcca8#1) (false)
                              2024-01-14 00:01:56.147  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa1ae0" connected!
                              2024-01-14 00:01:57.690  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abaf8c / shelly1pmmini#543204abaf8c#1) (false)
                              2024-01-14 00:01:58.223  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa80e8 / shelly1pmmini#543204aa80e8#1) (false)
                              2024-01-14 00:01:58.474  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ab95d8" connected!
                              2024-01-14 00:01:58.637  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684114 / shellyplus2pm#a0a3b3684114#1) (false)
                              2024-01-14 00:01:59.963  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aaa1f4" connected!
                              2024-01-14 00:02:04.538  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-C8C9A325B2BE" connected!
                              2024-01-14 00:02:06.144  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa1ae0 / shelly1pmmini#543204aa1ae0#1) (false)
                              2024-01-14 00:02:06.889  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b8604d6c" connected!
                              2024-01-14 00:02:08.474  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ab95d8 / shelly1pmmini#543204ab95d8#1) (false)
                              2024-01-14 00:02:09.870  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aaa1f4 / shelly1pmmini#543204aaa1f4#1) (false)
                              2024-01-14 00:02:10.128  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b893c4d0" connected!
                              2024-01-14 00:02:11.893  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204adcc50" connected!
                              2024-01-14 00:02:13.197  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-08F9E047CD2F" connected!
                              2024-01-14 00:02:13.611  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa8d5c" connected!
                              2024-01-14 00:02:16.875  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b8604d6c / shellyplus2pm#e465b8604d6c#1) (false)
                              2024-01-14 00:02:19.387  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-C8C9A3258A34" connected!
                              2024-01-14 00:02:20.117  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b893c4d0 / shellyplus2pm#e465b893c4d0#1) (false)
                              2024-01-14 00:02:21.787  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-08F9E047CBED" connected!
                              2024-01-14 00:02:21.884  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204adcc50 / shelly1pmmini#543204adcc50#1) (false)
                              2024-01-14 00:02:22.044  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acaf70" connected!
                              2024-01-14 00:02:23.605  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa8d5c / shelly1pmmini#543204aa8d5c#1) (false)
                              2024-01-14 00:02:25.623  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684110" connected!
                              2024-01-14 00:02:30.652  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204addca8" connected!
                              2024-01-14 00:02:32.037  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acaf70 / shelly1pmmini#543204acaf70#1) (false)
                              2024-01-14 00:02:32.452  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acfe10" connected!
                              2024-01-14 00:02:32.600  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ad6264" connected!
                              2024-01-14 00:02:34.964  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acee28" connected!
                              2024-01-14 00:02:35.620  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684110 / shellyplus2pm#a0a3b3684110#1) (false)
                              2024-01-14 00:02:40.650  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204addca8 / shelly1pmmini#543204addca8#1) (false)
                              2024-01-14 00:02:42.452  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acfe10 / shelly1pmmini#543204acfe10#1) (false)
                              2024-01-14 00:02:42.593  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ad6264 / shelly1pmmini#543204ad6264#1) (false)
                              2024-01-14 00:02:44.952  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acee28 / shelly1pmmini#543204acee28#1) (false)
                              2024-01-14 00:02:47.436  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplusplugs-e465b860af58" connected!
                              2024-01-14 00:02:48.615  - error: shelly.0 (2664) [MQTT] Wrong MQTT authentification of client "shelly1pmmini-543204abcca8"
                              2024-01-14 00:02:48.643  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abcca8 / shelly1pmmini#543204abcca8#1) (false)
                              2024-01-14 00:02:54.764  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684114" connected!
                              2024-01-14 00:02:54.980  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa80e8" connected!
                              2024-01-14 00:02:55.029  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204abaf8c" connected!
                              2024-01-14 00:02:57.435  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplusplugs / shellyplusplugs-e465b860af58 / shellyplusplugs#e465b860af58#1) (false)
                              2024-01-14 00:03:02.463  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa1ae0" connected!
                              2024-01-14 00:03:04.357  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ab95d8" connected!
                              2024-01-14 00:03:04.755  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684114 / shellyplus2pm#a0a3b3684114#1) (false)
                              2024-01-14 00:03:04.970  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa80e8 / shelly1pmmini#543204aa80e8#1) (false)
                              2024-01-14 00:03:05.025  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abaf8c / shelly1pmmini#543204abaf8c#1) (false)
                              2024-01-14 00:03:08.301  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aaa1f4" connected!
                              2024-01-14 00:03:12.456  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa1ae0 / shelly1pmmini#543204aa1ae0#1) (false)
                              2024-01-14 00:03:13.863  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b8604d6c" connected!
                              2024-01-14 00:03:14.349  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ab95d8 / shelly1pmmini#543204ab95d8#1) (false)
                              2024-01-14 00:03:16.095  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b893c4d0" connected!
                              2024-01-14 00:03:16.551  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204adcc50" connected!
                              2024-01-14 00:03:18.298  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aaa1f4 / shelly1pmmini#543204aaa1f4#1) (false)
                              2024-01-14 00:03:20.921  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa8d5c" connected!
                              2024-01-14 00:03:23.854  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b8604d6c / shellyplus2pm#e465b8604d6c#1) (false)
                              2024-01-14 00:03:26.086  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b893c4d0 / shellyplus2pm#e465b893c4d0#1) (false)
                              2024-01-14 00:03:26.542  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204adcc50 / shelly1pmmini#543204adcc50#1) (false)
                              2024-01-14 00:03:30.430  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acaf70" connected!
                              2024-01-14 00:03:30.913  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa8d5c / shelly1pmmini#543204aa8d5c#1) (false)
                              2024-01-14 00:03:32.492  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684110" connected!
                              Sieht soweit Okay aus, bis auf die 2 error ?!
                                Ich kenne den shelly-Adapter nicht. Aber ich würde auch sagen, das ist soweit harmlos.
                                  jetzt bekomme ich aber wieder Probleme;#
                                  Cannot read compact mode by host "system.host.raspberrypi4": timeout
                                    Thomas Braun Most Active @dike1982 last edited by Thomas Braun
                                    @dike1982
                                    Haste den denn aktiv?
                                      Wen?
                                      2024-01-14 00:09:16.821  - warn: dwd.0 (2682) get state error: Connection is closed.
                                      2024-01-14 00:09:16.831  - warn: dwd.0 (2682) get state error: Connection is closed.
                                      2024-01-14 00:09:16.832  - warn: dwd.0 (2682) get state error: Connection is closed.
                                      2024-01-14 00:09:16.833  - warn: dwd.0 (2682) get state error: Connection is closed.
                                      2024-01-14 00:09:16.834  - warn: dwd.0 (2682) get state error: Connection is closed.
                                      2024-01-14 00:09:16.839  - warn: dwd.0 (2682) get state error: Connection is closed.
                                      2024-01-14 00:09:16.840  - warn: dwd.0 (2682) get state error: Connection is closed.
                                      2024-01-14 00:09:16.848  - warn: dwd.0 (2682) get state error: Connection is closed.
                                      2024-01-14 00:09:16.849  - warn: dwd.0 (2682) get state error: Connection is closed.
                                      2024-01-14 00:09:16.898  - warn: dwd.0 (2682) Can not read iobroker system configuration. Disable Rain Radar.
                                      2024-01-14 00:09:16.916  - error: dwd.0 (2682) Cannot find view "system" for search "state" : Connection is closed.
                                      2024-01-14 00:09:16.929  - error: dwd.0 (2682) Could not read existing states: Cannot find view "system"
                                      2024-01-14 00:09:16.959  - warn: dwd.0 (2682) get state error: Connection is closed.
                                      2024-01-14 00:09:16.960  - warn: dwd.0 (2682) get state error: Connection is closed.
                                      2024-01-14 00:09:16.676  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684110 / shellyplus2pm#a0a3b3684110#1) (false)
                                      2024-01-14 00:09:16.765  - info: dwd.0 (2682) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
                                      DWD macht auch Zicken
                                      D Thomas Braun 2 Replies Last reply Reply Quote 0
                                        @dike1982
                                        Und jetzt geht es los:
                                        2024-01-14 00:15:03.289  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                        2024-01-14 00:15:03.298  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                        2024-01-14 00:15:03.300  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                        2024-01-14 00:15:03.301  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                        2024-01-14 00:15:03.302  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                        2024-01-14 00:15:03.303  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                        2024-01-14 00:15:03.304  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                        2024-01-14 00:15:03.306  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                        2024-01-14 00:15:03.307  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                        2024-01-14 00:15:03.308  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                        2024-01-14 00:15:03.309  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                        2024-01-14 00:15:03.310  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                        2024-01-14 00:15:03.312  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                        2024-01-14 00:15:03.313  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                        2024-01-14 00:15:03.316  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                        2024-01-14 00:15:03.317  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                        2024-01-14 00:15:05.556  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplusplugs-e465b860af58" connected!
                                        2024-01-14 00:15:06.688  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                        2024-01-14 00:15:06.690  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                        2024-01-14 00:15:06.692  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                        2024-01-14 00:15:06.694  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                        2024-01-14 00:15:06.696  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                        2024-01-14 00:15:06.697  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                        2024-01-14 00:15:06.699  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                        2024-01-14 00:15:06.700  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                        2024-01-14 00:15:06.702  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                        2024-01-14 00:15:06.703  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                        2024-01-14 00:15:06.705  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                        2024-01-14 00:15:06.707  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                        2024-01-14 00:15:06.709  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                        2024-01-14 00:15:06.710  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                        2024-01-14 00:15:06.712  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                        2024-01-14 00:15:06.713  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                        2024-01-14 00:15:06.714  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                        2024-01-14 00:15:06.715  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                        2024-01-14 00:15:06.717  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                        2024-01-14 00:15:06.719  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                        2024-01-14 00:15:06.720  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                        2024-01-14 00:15:06.721  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                        2024-01-14 00:15:08.468  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684114" connected!
                                        2024-01-14 00:15:08.686  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                        2024-01-14 00:15:08.689  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                        2024-01-14 00:15:08.693  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                        2024-01-14 00:15:08.696  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                        2024-01-14 00:15:08.700  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                        2024-01-14 00:15:08.702  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                        2024-01-14 00:15:08.704  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                        2024-01-14 00:15:08.708  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                        2024-01-14 00:15:08.715  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                        2024-01-14 00:15:08.723  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                        2024-01-14 00:15:08.725  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                        2024-01-14 00:15:08.726  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                        2024-01-14 00:15:08.728  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                        2024-01-14 00:15:08.733  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                        2024-01-14 00:15:08.734  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                        2024-01-14 00:15:08.783  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                        2024-01-14 00:15:08.785  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                        2024-01-14 00:15:10.570  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acfe10 / shelly1pmmini#543204acfe10#1) (false)
                                        2024-01-14 00:15:10.964  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa80e8" connected!
                                        2024-01-14 00:15:11.182  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204abaf8c" connected!
                                        2024-01-14 00:15:11.847  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                        2024-01-14 00:15:11.860  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                        2024-01-14 00:15:11.861  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                        2024-01-14 00:15:11.861  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                        2024-01-14 00:15:11.862  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                        2024-01-14 00:15:11.863  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                        2024-01-14 00:15:11.864  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                        2024-01-14 00:15:11.865  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                        2024-01-14 00:15:11.866  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                        2024-01-14 00:15:11.867  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                        2024-01-14 00:15:11.868  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                        2024-01-14 00:15:11.869  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                        2024-01-14 00:15:11.870  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                        2024-01-14 00:15:11.871  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                        2024-01-14 00:15:11.872  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                        2024-01-14 00:15:12.043  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ab95d8" connected!
                                        2024-01-14 00:15:14.971  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                        2024-01-14 00:15:15.224  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                        2024-01-14 00:15:15.237  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                        2024-01-14 00:15:15.239  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                        2024-01-14 00:15:15.240  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                        2024-01-14 00:15:15.241  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                        2024-01-14 00:15:15.243  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                        2024-01-14 00:15:15.244  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                        2024-01-14 00:15:15.252  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                        2024-01-14 00:15:15.254  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                        2024-01-14 00:15:15.255  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                        2024-01-14 00:15:15.257  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                        2024-01-14 00:15:15.258  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                        2024-01-14 00:15:15.260  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                        2024-01-14 00:15:15.261  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                        2024-01-14 00:15:15.262  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                        2024-01-14 00:15:15.264  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                        2024-01-14 00:15:15.265  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                        2024-01-14 00:15:15.274  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                        2024-01-14 00:15:15.281  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                        2024-01-14 00:15:15.282  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                        2024-01-14 00:15:15.551  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplusplugs / shellyplusplugs-e465b860af58 / shellyplusplugs#e465b860af58#1) (false)
                                        2024-01-14 00:15:16.845  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b8604d6c" connected!
                                        2024-01-14 00:15:17.911  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                        2024-01-14 00:15:17.955  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                        2024-01-14 00:15:17.963  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                        2024-01-14 00:15:17.965  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                        2024-01-14 00:15:17.966  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                        2024-01-14 00:15:17.971  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                        2024-01-14 00:15:17.974  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                        2024-01-14 00:15:17.975  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                        2024-01-14 00:15:17.977  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                        2024-01-14 00:15:17.980  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                        2024-01-14 00:15:17.984  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                        2024-01-14 00:15:17.986  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                        2024-01-14 00:15:17.987  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                        2024-01-14 00:15:17.988  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                        2024-01-14 00:15:17.989  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                        2024-01-14 00:15:17.990  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                        2024-01-14 00:15:17.992  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                        2024-01-14 00:15:17.993  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                        2024-01-14 00:15:17.995  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                        2024-01-14 00:15:17.996  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                        2024-01-14 00:15:17.997  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                        2024-01-14 00:15:18.237  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                        2024-01-14 00:15:18.547  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684114 / shellyplus2pm#a0a3b3684114#1) (false)
                                        2024-01-14 00:15:20.960  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa80e8 / shelly1pmmini#543204aa80e8#1) (false)
                                        2024-01-14 00:15:21.354  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                        2024-01-14 00:15:21.360  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                        2024-01-14 00:15:21.361  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                        2024-01-14 00:15:21.362  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                        2024-01-14 00:15:21.363  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                        2024-01-14 00:15:21.365  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                        2024-01-14 00:15:21.366  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                        2024-01-14 00:15:21.367  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                        2024-01-14 00:15:21.368  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                        2024-01-14 00:15:21.370  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                        2024-01-14 00:15:21.371  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                        2024-01-14 00:15:21.371  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                        2024-01-14 00:15:21.372  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                        2024-01-14 00:15:21.373  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                        2024-01-14 00:15:21.374  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                        2024-01-14 00:15:21.376  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                        2024-01-14 00:15:21.377  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                        2024-01-14 00:15:21.543  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abaf8c / shelly1pmmini#543204abaf8c#1) (false)
                                        2024-01-14 00:15:22.041  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ab95d8 / shelly1pmmini#543204ab95d8#1) (false)
                                        2024-01-14 00:15:22.649  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aaa1f4" connected!
                                        2024-01-14 00:15:23.721  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b893c4d0" connected!
                                        2024-01-14 00:15:24.063  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                        2024-01-14 00:15:24.070  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                        2024-01-14 00:15:24.070  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                        2024-01-14 00:15:24.071  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                        2024-01-14 00:15:24.072  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                        2024-01-14 00:15:24.073  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                        2024-01-14 00:15:24.074  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                        2024-01-14 00:15:24.075  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                        2024-01-14 00:15:24.076  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                        2024-01-14 00:15:24.078  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                        2024-01-14 00:15:24.080  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                        2024-01-14 00:15:24.081  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                        2024-01-14 00:15:24.083  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                        2024-01-14 00:15:24.084  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                        2024-01-14 00:15:24.085  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                        2024-01-14 00:15:24.086  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                        2024-01-14 00:15:24.087  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                        2024-01-14 00:15:24.088  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                        2024-01-14 00:15:24.089  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                        2024-01-14 00:15:24.090  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                        2024-01-14 00:15:24.091  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                        2024-01-14 00:15:24.092  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                        2024-01-14 00:15:24.093  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                        2024-01-14 00:15:24.098  - error: shelly.0 (2664) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for  (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
                                        2024-01-14 00:15:24.099  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                        2024-01-14 00:15:24.100  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                        2024-01-14 00:15:24.521  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa1ae0" connected!
                                        2024-01-14 00:15:25.886  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa8d5c" connected!
                                        2024-01-14 00:15:26.836  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b8604d6c / shellyplus2pm#e465b8604d6c#1) (false)
                                        2024-01-14 00:15:26.901  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                        2024-01-14 00:15:26.911  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                        2024-01-14 00:15:26.914  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                        2024-01-14 00:15:26.917  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                        2024-01-14 00:15:26.918  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                        2024-01-14 00:15:26.924  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                        2024-01-14 00:15:26.925  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                        2024-01-14 00:15:26.928  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                        2024-01-14 00:15:26.929  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                        2024-01-14 00:15:26.932  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                        2024-01-14 00:15:26.933  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                        2024-01-14 00:15:26.935  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                        2024-01-14 00:15:26.937  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                        2024-01-14 00:15:26.938  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                        2024-01-14 00:15:26.941  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                        2024-01-14 00:15:26.942  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                        2024-01-14 00:15:26.943  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                        2024-01-14 00:15:26.948  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                        2024-01-14 00:15:26.951  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                        2024-01-14 00:15:26.954  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                        2024-01-14 00:15:26.956  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                        2024-01-14 00:15:26.958  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                        2024-01-14 00:15:26.961  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                        2024-01-14 00:15:26.965  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                        2024-01-14 00:15:26.967  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                        2024-01-14 00:15:28.173  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204adcc50" connected!
                                        2024-01-14 00:15:29.835  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                          @dike1982
                                          So ein Verhalten des Systems hatte ich mal kurz bevor mir eine SD-Karte verreckt ist.
                                            Okay, die ist aber einen Monat alt vielleicht.
                                            Und es lief bisher ohne Problem, bis ich die Shellys heute eingebunden habe!
                                            2325
