    4. IOBroker reagiert nicht mehr | Shelly Adapter
      dike1982 @Thomas Braun last edited by
      Das Upgrade!
        dike1982 @dike1982 last edited by dike1982
        full-upgrade ist durch und bin wieder eingeloggt!
          Thomas Braun Most Active @dike1982 last edited by
          @dike1982
          Dann schau dir jetzt noch Mal das
          iob diag
          an.
          • Glasfaser
            Glasfaser @dike1982 last edited by
            @dike1982 sagte in IOBroker reagiert nicht mehr | Shelly Adapter:
            Objects: 15406
            States: 0
            Size of iob-Database:
            30M /opt/iobroker/iobroker-data/objects.jsonl
            22M /opt/iobroker/iobroker-data/states.jsonl
            Adapter State
            Cannot read system.config: undefined (OK when migrating or restoring)
            Kannst du nochmal
            iob diag
            zeigen , da dein States 0 waren !
              @thomas-braun said in IOBroker reagiert nicht mehr | Shelly Adapter:
              iob diag
              Hier das Ergebnis:
              Shelly-Adapter ist aus auf Pause.
              Skript v.2023-10-10
              *** BASE SYSTEM ***
               Static hostname: raspberrypi4
                     Icon name: computer
                        Kernel: Linux 6.1.0-rpi7-rpi-v8
                  Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.5
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : arm64
              Systemuptime and Load:
               23:47:15 up 8 min,  2 users,  load average: 0.70, 0.69, 0.46
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Sat 2024-01-13 23:47:15 CET
                         Universal time: Sat 2024-01-13 22:47:15 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi4
              /home/pi4
              pi4 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            8.2G        1.6G        6.3G        1.2M        497M        6.6G
              Swap:           104M          0B        104M
              Total:          8.3G        1.6G        6.4G
                       7811 M total memory
                       1486 M used memory
                       1423 M active memory
                        299 M inactive memory
                       5969 M free memory
                         40 M buffer memory
                        433 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              udev           devtmpfs  3.6G     0  3.6G   0% /dev
              tmpfs          tmpfs     782M  1.2M  781M   1% /run
              /dev/mmcblk0p2 ext4       28G  4.6G   22G  18% /
              tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
              /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
              tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
              [Sat Jan 13 23:38:40 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:92:1C:FA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3656f3dd-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Sat Jan 13 23:38:42 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Sat Jan 13 23:38:44 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              TARGET           SOURCE         FSTYPE OPTIONS
              /                /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              741M    /var/
              273M    /var/log
              272M    /var/log/journal/7251727675ab4e198e92b6d62c980f75
              202M    /var/cache
              Archived and active journals take up 271.9M in the file system.
              /opt/iobroker/backups:
              112M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              338M    /opt/iobroker/iobroker-data/
              197M    /opt/iobroker/iobroker-data/files
              83M     /opt/iobroker/iobroker-data/backup-objects
              67M     /opt/iobroker/iobroker-data/files/javascript.admin
              48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
              33M     /opt/iobroker/iobroker-data/objects.jsonl
              26M     /opt/iobroker/iobroker-data/states.jsonl
              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
              8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
              8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
              USB-Devices by-id:
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.19.0
              /usr/bin/node           v18.19.0
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              /usr/bin/corepack       0.22.0
              nodejs:
                Installed: 18.19.0-1nodesource1
                Candidate: 18.19.0-1nodesource1
                Version table:
                   18.19.0+dfsg-6~deb12u1 500
               *** 18.19.0-1nodesource1 1001
                      100 /var/lib/dpkg/status
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0+dfsg1-1 500
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.17
              admin:          6.12.0
              javascript:     7.1.6
              Adapters from github:   0
              Adapter State
              + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
              + system.adapter.chromecast.0             : chromecast            : raspberrypi4                             -  enabled
              + system.adapter.cloud.0                  : cloud                 : raspberrypi4                             -  enabled
                system.adapter.daswetter.0              : daswetter             : raspberrypi4                             -  enabled
              + system.adapter.device-watcher.0         : device-watcher        : raspberrypi4                             -  enabled
                system.adapter.discovery.0              : discovery             : raspberrypi4                             - disabled
                system.adapter.dwd.0                    : dwd                   : raspberrypi4                             -  enabled
                system.adapter.flot.0                   : flot                  : raspberrypi4                             -  enabled
              + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi4                             -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : raspberrypi4                             -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi4                             -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi4                             -  enabled, port: 12010
              + system.adapter.hue-extended.0           : hue-extended          : raspberrypi4                             -  enabled
                system.adapter.ical.0                   : ical                  : raspberrypi4                             -  enabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi4                             -  enabled
              + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
                system.adapter.lgtv.0                   : lgtv                  : raspberrypi4                             - disabled
              + system.adapter.mercedesme.0             : mercedesme            : raspberrypi4                             -  enabled
                system.adapter.net-tools.0              : net-tools             : raspberrypi4                             - disabled
                system.adapter.openknx.0                : openknx               : raspberrypi4                             - disabled
                system.adapter.openknx.1                : openknx               : raspberrypi4                             - disabled
                system.adapter.ping.0                   : ping                  : raspberrypi4                             - disabled
              + system.adapter.scenes.0                 : scenes                : raspberrypi4                             -  enabled
                system.adapter.shelly.0                 : shelly                : raspberrypi4                             - disabled, port: 1882, bind: 0.0.0.0
              + system.adapter.sonos.0                  : sonos                 : raspberrypi4                             -  enabled
              + system.adapter.tr-064.0                 : tr-064                : raspberrypi4                             -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4                             -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             -  enabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi4                             -  enabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi4                             -  enabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi4                             -  enabled
                system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4                             -  enabled
                system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
                system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4                             - disabled
              + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "backitup"     : 2.9.8    , installed 2.9.8
              Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
              Adapter    "daswetter"    : 3.1.12   , installed 3.1.12
              Adapter    "device-watcher": 2.9.6   , installed 2.9.6
              Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
              Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
              Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
              Controller "js-controller": 5.0.17   , installed 5.0.17
              Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
              Adapter    "mercedesme"   : 0.1.1    , installed 0.1.6
              Adapter    "openknx"      : 0.6.3    , installed 0.6.3
              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
              Adapter    "sonos"        : 3.0.0    , installed 3.0.0
              Adapter    "swiss-weather-api": 2.0.3, installed 2.0.3
              Adapter    "trashschedule": 2.3.0    , installed 2.3.0
              Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
              Adapter    "weatherunderground": 3.6.0, installed 3.6.0
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Objects and States
              Objects:        15847
              States:         13319
              Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 192.168.115.89:12010    0.0.0.0:*               LISTEN      1001       15886      850/io.hm-rpc.1
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13103      658/iobroker.js-con
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13114      658/iobroker.js-con
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13057      683/sshd: /usr/sbin
              tcp        0      0 192.168.115.89:2001     0.0.0.0:*               LISTEN      1001       14083      830/io.hm-rpc.0
              tcp6       0      0 :::3000                 :::*                    LISTEN      1001       17537      1029/io.fullybrowse
              tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16027      884/io.sonos.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17471      988/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14027      718/io.admin.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          13059      683/sshd: /usr/sbin
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       16101      939/io.chromecast.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15528      468/avahi-daemon: r
              udp        0      0 0.0.0.0:59423           0.0.0.0:*                           104        15530      468/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                104        15529      468/avahi-daemon: r
              udp6       0      0 :::42496                :::*                                104        15531      468/avahi-daemon: r
              udp6       0      0 fe80::bea5:9acd:17c:546 :::*                                0          13984      515/NetworkManager
              2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
              2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=13 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705144977704
              2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Room 13 = OG Spielzimmer is open or disabled, no vent warning set
              2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=14 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705185983307
              2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Room 14 = OG Wohnzimmer is open or disabled, no vent warning set
              2024-01-13 23:46:25.243  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=15 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705185983768
              2024-01-13 23:46:25.243  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Room 15 = Treppenhaus is open or disabled, no vent warning set
              2024-01-13 23:46:25.243  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
              2024-01-13 23:46:25.250  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithOpenDoorsList
              2024-01-13 23:46:25.251  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenDoors: Keine Tür/en geöffnet
              2024-01-13 23:46:25.251  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithTiltedDoorsList
              2024-01-13 23:46:25.251  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithTiltedDoors: Keine Tür gekippt
              2024-01-13 23:46:25.252  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithOpenWindowsList
              2024-01-13 23:46:25.252  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenWindows: Alle Fenster sind geschlossen
              2024-01-13 23:46:25.252  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithTiltedWindowsList
              2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithTiltedWindows: Keine Fenster gekippt
              2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: CreateOpenRoomsList()
              2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenings:
              2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
              2024-01-13 23:47:48.717  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.115.81 javascript
              2024-01-13 23:48:14.589  - info: web.0 (988) ==> Connected system.user.admin from ::ffff:192.168.115.81
              2024-01-13 23:48:27.235  - info: web.0 (988) <== Disconnect system.user.admin from ::ffff:192.168.115.81 vis.0
              2024-01-13 23:48:27.593  - info: web.0 (988) ==> Connected system.user.admin from ::ffff:192.168.115.81
                                      v.2023-10-10
                     Icon name: computer
                  Architecture: arm64
              Installation:           native
              Kernel:                 aarch64
              Userland:               arm64
              Timezone:               Europe/Berlin (CET, +0100)
              User-ID:                1000
              X-Server:               false
              Pending OS-Updates:     0
              Pending iob updates:    0
              Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                      /usr/bin/npm            10.2.3
                                      /usr/bin/npx            10.2.3
              Recommended versions are nodejs 18.19.0 and npm 10.2.3
              MEMORY:
              Mem:            8.2G        1.6G        5.9G        1.2M        831M        6.6G
              Swap:           104M          0B        104M
              Total:          8.3G        1.6G        6.0G
              Active iob-Instances:   19
              ioBroker Core:          js-controller           5.0.17
                                      admin                   6.12.0
              Objects type: jsonl
              States  type: jsonl
              Objects:                15847
              States:                 13319
                @dike1982
                Ich seh keine Unstimmigkeiten mehr in der Ausgabe.
                  Okay soll ich dann den Shelly-Adapter mal wieder anwerfen?
                    @dike1982
                    Ja. Und schau dir das Logfile dann dazu in Echtzeit an:
                    iob logs --watch
                      024-01-14 00:01:27.778  - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 2664
                      2024-01-14 00:01:27.466  - info: host.raspberrypi4 "system.adapter.shelly.0" enabled
                      2024-01-14 00:01:27.778  - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 2664
                      2024-01-14 00:01:31.946  - info: shelly.0 (2664) starting. Version 6.7.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.19.0, js-controller: 5.0.17
                      2024-01-14 00:01:40.337  - info: shelly.0 (2664) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
                      2024-01-14 00:01:41.130  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplusplugs-e465b860af58" connected!
                      2024-01-14 00:01:42.462  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-C8C9A325943E" connected!
                      2024-01-14 00:01:47.694  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204abaf8c" connected!
                      2024-01-14 00:01:48.225  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa80e8" connected!
                      2024-01-14 00:01:48.642  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684114" connected!
                      2024-01-14 00:01:51.090  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplusplugs / shellyplusplugs-e465b860af58 / shellyplusplugs#e465b860af58#1) (false)
                      2024-01-14 00:01:51.843  - error: shelly.0 (2664) [MQTT] Wrong MQTT authentification of client "shelly1pmmini-543204abcca8"
                      2024-01-14 00:01:52.038  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abcca8 / shelly1pmmini#543204abcca8#1) (false)
                      2024-01-14 00:01:56.147  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa1ae0" connected!
                      2024-01-14 00:01:57.690  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abaf8c / shelly1pmmini#543204abaf8c#1) (false)
                      2024-01-14 00:01:58.223  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa80e8 / shelly1pmmini#543204aa80e8#1) (false)
                      2024-01-14 00:01:58.474  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ab95d8" connected!
                      2024-01-14 00:01:58.637  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684114 / shellyplus2pm#a0a3b3684114#1) (false)
                      2024-01-14 00:01:59.963  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aaa1f4" connected!
                      2024-01-14 00:02:04.538  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-C8C9A325B2BE" connected!
                      2024-01-14 00:02:06.144  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa1ae0 / shelly1pmmini#543204aa1ae0#1) (false)
                      2024-01-14 00:02:06.889  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b8604d6c" connected!
                      2024-01-14 00:02:08.474  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ab95d8 / shelly1pmmini#543204ab95d8#1) (false)
                      2024-01-14 00:02:09.870  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aaa1f4 / shelly1pmmini#543204aaa1f4#1) (false)
                      2024-01-14 00:02:10.128  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b893c4d0" connected!
                      2024-01-14 00:02:11.893  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204adcc50" connected!
                      2024-01-14 00:02:13.197  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-08F9E047CD2F" connected!
                      2024-01-14 00:02:13.611  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa8d5c" connected!
                      2024-01-14 00:02:16.875  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b8604d6c / shellyplus2pm#e465b8604d6c#1) (false)
                      2024-01-14 00:02:19.387  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-C8C9A3258A34" connected!
                      2024-01-14 00:02:20.117  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b893c4d0 / shellyplus2pm#e465b893c4d0#1) (false)
                      2024-01-14 00:02:21.787  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-08F9E047CBED" connected!
                      2024-01-14 00:02:21.884  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204adcc50 / shelly1pmmini#543204adcc50#1) (false)
                      2024-01-14 00:02:22.044  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acaf70" connected!
                      2024-01-14 00:02:23.605  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa8d5c / shelly1pmmini#543204aa8d5c#1) (false)
                      2024-01-14 00:02:25.623  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684110" connected!
                      2024-01-14 00:02:30.652  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204addca8" connected!
                      2024-01-14 00:02:32.037  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acaf70 / shelly1pmmini#543204acaf70#1) (false)
                      2024-01-14 00:02:32.452  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acfe10" connected!
                      2024-01-14 00:02:32.600  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ad6264" connected!
                      2024-01-14 00:02:34.964  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acee28" connected!
                      2024-01-14 00:02:35.620  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684110 / shellyplus2pm#a0a3b3684110#1) (false)
                      2024-01-14 00:02:40.650  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204addca8 / shelly1pmmini#543204addca8#1) (false)
                      2024-01-14 00:02:42.452  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acfe10 / shelly1pmmini#543204acfe10#1) (false)
                      2024-01-14 00:02:42.593  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ad6264 / shelly1pmmini#543204ad6264#1) (false)
                      2024-01-14 00:02:44.952  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acee28 / shelly1pmmini#543204acee28#1) (false)
                      2024-01-14 00:02:47.436  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplusplugs-e465b860af58" connected!
                      2024-01-14 00:02:48.615  - error: shelly.0 (2664) [MQTT] Wrong MQTT authentification of client "shelly1pmmini-543204abcca8"
                      2024-01-14 00:02:48.643  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abcca8 / shelly1pmmini#543204abcca8#1) (false)
                      2024-01-14 00:02:54.764  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684114" connected!
                      2024-01-14 00:02:54.980  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa80e8" connected!
                      2024-01-14 00:02:55.029  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204abaf8c" connected!
                      2024-01-14 00:02:57.435  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplusplugs / shellyplusplugs-e465b860af58 / shellyplusplugs#e465b860af58#1) (false)
                      2024-01-14 00:03:02.463  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa1ae0" connected!
                      2024-01-14 00:03:04.357  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ab95d8" connected!
                      2024-01-14 00:03:04.755  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684114 / shellyplus2pm#a0a3b3684114#1) (false)
                      2024-01-14 00:03:04.970  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa80e8 / shelly1pmmini#543204aa80e8#1) (false)
                      2024-01-14 00:03:05.025  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abaf8c / shelly1pmmini#543204abaf8c#1) (false)
                      2024-01-14 00:03:08.301  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aaa1f4" connected!
                      2024-01-14 00:03:12.456  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa1ae0 / shelly1pmmini#543204aa1ae0#1) (false)
                      2024-01-14 00:03:13.863  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b8604d6c" connected!
                      2024-01-14 00:03:14.349  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ab95d8 / shelly1pmmini#543204ab95d8#1) (false)
                      2024-01-14 00:03:16.095  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b893c4d0" connected!
                      2024-01-14 00:03:16.551  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204adcc50" connected!
                      2024-01-14 00:03:18.298  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aaa1f4 / shelly1pmmini#543204aaa1f4#1) (false)
                      2024-01-14 00:03:20.921  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa8d5c" connected!
                      2024-01-14 00:03:23.854  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b8604d6c / shellyplus2pm#e465b8604d6c#1) (false)
                      2024-01-14 00:03:26.086  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b893c4d0 / shellyplus2pm#e465b893c4d0#1) (false)
                      2024-01-14 00:03:26.542  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204adcc50 / shelly1pmmini#543204adcc50#1) (false)
                      2024-01-14 00:03:30.430  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acaf70" connected!
                      2024-01-14 00:03:30.913  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa8d5c / shelly1pmmini#543204aa8d5c#1) (false)
                      2024-01-14 00:03:32.492  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684110" connected!
                      Sieht soweit Okay aus, bis auf die 2 error ?!
                        Ich kenne den shelly-Adapter nicht. Aber ich würde auch sagen, das ist soweit harmlos.
                          jetzt bekomme ich aber wieder Probleme;#
                          Cannot read compact mode by host "system.host.raspberrypi4": timeout
                            Thomas Braun Most Active @dike1982 last edited by Thomas Braun
                            @dike1982
                            Haste den denn aktiv?
                              Wen?
                              2024-01-14 00:09:16.821  - warn: dwd.0 (2682) get state error: Connection is closed.
                              2024-01-14 00:09:16.831  - warn: dwd.0 (2682) get state error: Connection is closed.
                              2024-01-14 00:09:16.832  - warn: dwd.0 (2682) get state error: Connection is closed.
                              2024-01-14 00:09:16.833  - warn: dwd.0 (2682) get state error: Connection is closed.
                              2024-01-14 00:09:16.834  - warn: dwd.0 (2682) get state error: Connection is closed.
                              2024-01-14 00:09:16.839  - warn: dwd.0 (2682) get state error: Connection is closed.
                              2024-01-14 00:09:16.840  - warn: dwd.0 (2682) get state error: Connection is closed.
                              2024-01-14 00:09:16.848  - warn: dwd.0 (2682) get state error: Connection is closed.
                              2024-01-14 00:09:16.849  - warn: dwd.0 (2682) get state error: Connection is closed.
                              2024-01-14 00:09:16.898  - warn: dwd.0 (2682) Can not read iobroker system configuration. Disable Rain Radar.
                              2024-01-14 00:09:16.916  - error: dwd.0 (2682) Cannot find view "system" for search "state" : Connection is closed.
                              2024-01-14 00:09:16.929  - error: dwd.0 (2682) Could not read existing states: Cannot find view "system"
                              2024-01-14 00:09:16.959  - warn: dwd.0 (2682) get state error: Connection is closed.
                              2024-01-14 00:09:16.960  - warn: dwd.0 (2682) get state error: Connection is closed.
                              2024-01-14 00:09:16.676  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684110 / shellyplus2pm#a0a3b3684110#1) (false)
                              2024-01-14 00:09:16.765  - info: dwd.0 (2682) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
                              DWD macht auch Zicken
                              D Thomas Braun 2 Replies Last reply Reply Quote 0
                                @dike1982
                                Und jetzt geht es los:
                                2024-01-14 00:15:03.289  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                2024-01-14 00:15:03.298  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                2024-01-14 00:15:03.300  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                2024-01-14 00:15:03.301  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                2024-01-14 00:15:03.302  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                2024-01-14 00:15:03.303  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                2024-01-14 00:15:03.304  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                2024-01-14 00:15:03.306  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                2024-01-14 00:15:03.307  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                2024-01-14 00:15:03.308  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                2024-01-14 00:15:03.309  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                2024-01-14 00:15:03.310  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                2024-01-14 00:15:03.312  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                2024-01-14 00:15:03.313  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                2024-01-14 00:15:03.316  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                2024-01-14 00:15:03.317  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                2024-01-14 00:15:05.556  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplusplugs-e465b860af58" connected!
                                2024-01-14 00:15:06.688  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                2024-01-14 00:15:06.690  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                2024-01-14 00:15:06.692  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                2024-01-14 00:15:06.694  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                2024-01-14 00:15:06.696  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                2024-01-14 00:15:06.697  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                2024-01-14 00:15:06.699  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                2024-01-14 00:15:06.700  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                2024-01-14 00:15:06.702  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                2024-01-14 00:15:06.703  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                2024-01-14 00:15:06.705  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                2024-01-14 00:15:06.707  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                2024-01-14 00:15:06.709  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                2024-01-14 00:15:06.710  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                2024-01-14 00:15:06.712  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                2024-01-14 00:15:06.713  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                2024-01-14 00:15:06.714  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                2024-01-14 00:15:06.715  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                2024-01-14 00:15:06.717  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                2024-01-14 00:15:06.719  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                2024-01-14 00:15:06.720  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                2024-01-14 00:15:06.721  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                2024-01-14 00:15:08.468  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684114" connected!
                                2024-01-14 00:15:08.686  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                2024-01-14 00:15:08.689  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                2024-01-14 00:15:08.693  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                2024-01-14 00:15:08.696  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                2024-01-14 00:15:08.700  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                2024-01-14 00:15:08.702  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                2024-01-14 00:15:08.704  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                2024-01-14 00:15:08.708  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                2024-01-14 00:15:08.715  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                2024-01-14 00:15:08.723  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                2024-01-14 00:15:08.725  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                2024-01-14 00:15:08.726  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                2024-01-14 00:15:08.728  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                2024-01-14 00:15:08.733  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                2024-01-14 00:15:08.734  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                2024-01-14 00:15:08.783  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                2024-01-14 00:15:08.785  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                2024-01-14 00:15:10.570  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acfe10 / shelly1pmmini#543204acfe10#1) (false)
                                2024-01-14 00:15:10.964  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa80e8" connected!
                                2024-01-14 00:15:11.182  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204abaf8c" connected!
                                2024-01-14 00:15:11.847  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                2024-01-14 00:15:11.860  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                2024-01-14 00:15:11.861  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                2024-01-14 00:15:11.861  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                2024-01-14 00:15:11.862  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                2024-01-14 00:15:11.863  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                2024-01-14 00:15:11.864  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                2024-01-14 00:15:11.865  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                2024-01-14 00:15:11.866  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                2024-01-14 00:15:11.867  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                2024-01-14 00:15:11.868  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                2024-01-14 00:15:11.869  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                2024-01-14 00:15:11.870  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                2024-01-14 00:15:11.871  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                2024-01-14 00:15:11.872  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                2024-01-14 00:15:12.043  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ab95d8" connected!
                                2024-01-14 00:15:14.971  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                2024-01-14 00:15:15.224  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                2024-01-14 00:15:15.237  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                2024-01-14 00:15:15.239  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                2024-01-14 00:15:15.240  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                2024-01-14 00:15:15.241  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                2024-01-14 00:15:15.243  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                2024-01-14 00:15:15.244  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                2024-01-14 00:15:15.252  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                2024-01-14 00:15:15.254  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                2024-01-14 00:15:15.255  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                2024-01-14 00:15:15.257  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                2024-01-14 00:15:15.258  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                2024-01-14 00:15:15.260  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                2024-01-14 00:15:15.261  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                2024-01-14 00:15:15.262  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                2024-01-14 00:15:15.264  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                2024-01-14 00:15:15.265  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                2024-01-14 00:15:15.274  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                2024-01-14 00:15:15.281  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                2024-01-14 00:15:15.282  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                2024-01-14 00:15:15.551  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplusplugs / shellyplusplugs-e465b860af58 / shellyplusplugs#e465b860af58#1) (false)
                                2024-01-14 00:15:16.845  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b8604d6c" connected!
                                2024-01-14 00:15:17.911  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                2024-01-14 00:15:17.955  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                2024-01-14 00:15:17.963  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                2024-01-14 00:15:17.965  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                2024-01-14 00:15:17.966  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                2024-01-14 00:15:17.971  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                2024-01-14 00:15:17.974  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                2024-01-14 00:15:17.975  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                2024-01-14 00:15:17.977  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                2024-01-14 00:15:17.980  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                2024-01-14 00:15:17.984  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                2024-01-14 00:15:17.986  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                2024-01-14 00:15:17.987  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                2024-01-14 00:15:17.988  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                2024-01-14 00:15:17.989  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                2024-01-14 00:15:17.990  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                2024-01-14 00:15:17.992  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                2024-01-14 00:15:17.993  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                2024-01-14 00:15:17.995  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                2024-01-14 00:15:17.996  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                2024-01-14 00:15:17.997  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                2024-01-14 00:15:18.237  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                2024-01-14 00:15:18.547  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684114 / shellyplus2pm#a0a3b3684114#1) (false)
                                2024-01-14 00:15:20.960  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa80e8 / shelly1pmmini#543204aa80e8#1) (false)
                                2024-01-14 00:15:21.354  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                2024-01-14 00:15:21.360  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                2024-01-14 00:15:21.361  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                2024-01-14 00:15:21.362  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                2024-01-14 00:15:21.363  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                2024-01-14 00:15:21.365  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                2024-01-14 00:15:21.366  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                2024-01-14 00:15:21.367  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                2024-01-14 00:15:21.368  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                2024-01-14 00:15:21.370  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                2024-01-14 00:15:21.371  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                2024-01-14 00:15:21.371  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                2024-01-14 00:15:21.372  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                2024-01-14 00:15:21.373  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                2024-01-14 00:15:21.374  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                2024-01-14 00:15:21.376  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                2024-01-14 00:15:21.377  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                2024-01-14 00:15:21.543  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abaf8c / shelly1pmmini#543204abaf8c#1) (false)
                                2024-01-14 00:15:22.041  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ab95d8 / shelly1pmmini#543204ab95d8#1) (false)
                                2024-01-14 00:15:22.649  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aaa1f4" connected!
                                2024-01-14 00:15:23.721  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b893c4d0" connected!
                                2024-01-14 00:15:24.063  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                2024-01-14 00:15:24.070  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                2024-01-14 00:15:24.070  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                2024-01-14 00:15:24.071  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                2024-01-14 00:15:24.072  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                2024-01-14 00:15:24.073  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                2024-01-14 00:15:24.074  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                2024-01-14 00:15:24.075  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                2024-01-14 00:15:24.076  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                2024-01-14 00:15:24.078  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                2024-01-14 00:15:24.080  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                                2024-01-14 00:15:24.081  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                2024-01-14 00:15:24.083  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                2024-01-14 00:15:24.084  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                2024-01-14 00:15:24.085  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                2024-01-14 00:15:24.086  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                2024-01-14 00:15:24.087  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                2024-01-14 00:15:24.088  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                2024-01-14 00:15:24.089  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                2024-01-14 00:15:24.090  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                2024-01-14 00:15:24.091  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                2024-01-14 00:15:24.092  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                2024-01-14 00:15:24.093  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                                2024-01-14 00:15:24.098  - error: shelly.0 (2664) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for  (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
                                2024-01-14 00:15:24.099  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                2024-01-14 00:15:24.100  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                                2024-01-14 00:15:24.521  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa1ae0" connected!
                                2024-01-14 00:15:25.886  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa8d5c" connected!
                                2024-01-14 00:15:26.836  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b8604d6c / shellyplus2pm#e465b8604d6c#1) (false)
                                2024-01-14 00:15:26.901  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                                2024-01-14 00:15:26.911  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                                2024-01-14 00:15:26.914  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                2024-01-14 00:15:26.917  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                                2024-01-14 00:15:26.918  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                2024-01-14 00:15:26.924  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                2024-01-14 00:15:26.925  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                2024-01-14 00:15:26.928  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                2024-01-14 00:15:26.929  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                                2024-01-14 00:15:26.932  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                2024-01-14 00:15:26.933  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                2024-01-14 00:15:26.935  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                2024-01-14 00:15:26.937  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                2024-01-14 00:15:26.938  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                                2024-01-14 00:15:26.941  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                2024-01-14 00:15:26.942  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                                2024-01-14 00:15:26.943  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                                2024-01-14 00:15:26.948  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                                2024-01-14 00:15:26.951  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                                2024-01-14 00:15:26.954  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                2024-01-14 00:15:26.956  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                                2024-01-14 00:15:26.958  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                                2024-01-14 00:15:26.961  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                                2024-01-14 00:15:26.965  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                                2024-01-14 00:15:26.967  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                                2024-01-14 00:15:28.173  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204adcc50" connected!
                                2024-01-14 00:15:29.835  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                  @dike1982
                                  So ein Verhalten des Systems hatte ich mal kurz bevor mir eine SD-Karte verreckt ist.
                                    Okay, die ist aber einen Monat alt vielleicht.
                                    Und es lief bisher ohne Problem, bis ich die Shellys heute eingebunden habe!
                                      @dike1982
                                      Da kann ich dir nicht weiterhelfen, kenne den Adapter und die Hardware nicht.
                                        dike1982 @Thomas Braun last edited by dike1982
                                        Trotzdem schon mal danke!
                                        Hat sonst einer eine Idee??
                                          Ich brauch leider nochmal Hilfe.
                                          Ich hab mir gedacht ich lösche den shelly-Adapter und fang mit den Shellys von vorne an.
                                          Das Löschen hat recht lange gedauert.
                                          Jetzt habe ich wieder die Time-out Warnungen auf der Oberfläche und es lässt sich quasi nicht bedienen, bzw. alles sehr langsam!!
                                          2024-01-14 01:36:10.647  - info: host.raspberrypi4 instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2024-01-14 01:37:09.511  - info: host.raspberrypi4 iobroker del shelly.0
                                          2024-01-14 01:37:40.809  - info: host.raspberrypi4 iobroker Delete instance "shelly.0"
                                          2024-01-14 01:37:46.555  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1 instances of shelly.0
                                          2024-01-14 01:37:51.803  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 23 devices of shelly.0
                                          2024-01-14 01:37:55.733  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 159 channels of shelly.0
                                          2024-01-14 01:37:59.655  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1360 states of shelly.0
                                          2024-01-14 01:38:02.245  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 15 states of system.adapter.shelly.0
                                          2024-01-14 01:38:02.906  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1134 states (io.shelly.0.*) from states
                                          2024-01-14 01:38:04.894  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 6 states (system.adapter.shelly.0.*) from states
                                          2024-01-14 01:38:11.587  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 2 objects of shelly.0host.raspberrypi4 Deleting 1560 object(s). Be patient...
                                          2024-01-14 01:38:49.188  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 1400 objects left to be deleted.
                                          2024-01-14 01:39:59.624  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 1200 objects left to be deleted.
                                          2024-01-14 01:40:21.779  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 1000 objects left to be deleted.
                                          2024-01-14 01:41:30.214  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 800 objects left to be deleted.
                                          2024-01-14 01:41:35.629  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 600 objects left to be deleted.
                                          2024-01-14 01:41:50.581  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 400 objects left to be deleted.
                                          2024-01-14 01:44:28.905  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 200 objects left to be deleted.
                                          2024-01-14 01:46:34.239  - info: host.raspberrypi4 object deleted system.adapter.shelly.0
                                          2024-01-14 01:46:34.251  - info: host.raspberrypi4 iobroker host.raspberrypi4 Deleting 1140 state(s). Be patient...
                                          2024-01-14 01:47:44.091  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 1000 states left to be deleted.
                                          2024-01-14 01:48:17.714  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 800 states left to be deleted.
                                          2024-01-14 01:49:33.382  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 600 states left to be deleted.
                                          2024-01-14 01:49:37.528  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 400 states left to be deleted.
                                          2024-01-14 01:52:40.727  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 200 states left to be deleted.
                                          2024-01-14 01:53:11.244  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.115.81 admin
                                          2024-01-14 01:54:05.002  - info: admin.0 (718) failed connection to socket.io from ::ffff:192.168.115.81: Passport was not initialized
                                          2024-01-14 01:54:10.253  - info: admin.0 (718) failed connection to socket.io from ::ffff:192.168.115.81: Passport was not initialized
                                          2024-01-14 01:55:26.687  - info: host.raspberrypi4 instance system.adapter.ical.0 started with pid 2971
                                          2024-01-14 01:55:38.919  - warn: ical.0 (2971) slow connection to objects DB. Still waiting ...
                                          2024-01-14 01:56:04.379  - warn: ical.0 (2971) slow connection to states DB. Still waiting ...
                                          2024-01-14 01:56:48.432  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.115.81 admin
                                          2024-01-14 01:57:05.853  - info: admin.0 (718) failed connection to socket.io from ::ffff:192.168.115.81: Passport was not initialized
                                          2024-01-14 01:57:41.889  - info: ical.0 (2971) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                                          2024-01-14 01:57:44.516  - info: ical.0 (2971) processing URL: Müllkalender https://calendar.google.com/calendar/ical/3a2097d8a678bc40972b4f2df3a70416e549cabb23d727a3bddacc2001f63aa7%40group.calendar.google.com/private-f6d975016103767eb05b6b0c059afa62/basic.ics
                                          2024-01-14 01:58:13.682  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.115.81
                                          2024-01-14 01:58:19.894  - info: ical.0 (2971) Terminated (NO_ERROR): Without reason
                                          2024-01-14 01:58:21.662  - info: host.raspberrypi4 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                          2024-01-14 01:59:47.928  - info: host.raspberrypi4 iobroker exit 0
                                          2024-01-14 02:00:00.084  - info: host.raspberrypi4 instance system.adapter.ical.0 started with pid 2990
                                          2024-01-14 02:00:20.340  - info: ical.0 (2990) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                                          2024-01-14 02:00:33.511  - info: ical.0 (2990) processing URL: Müllkalender https://calendar.google.com/calendar/ical/3a2097d8a678bc40972b4f2df3a70416e549cabb23d727a3bddacc2001f63aa7%40group.calendar.google.com/private-f6d975016103767eb05b6b0c059afa62/basic.ics
                                          2024-01-14 02:01:08.408  - info: ical.0 (2990) Terminated (NO_ERROR): Without reason
                                          2024-01-14 02:01:09.834  - info: host.raspberrypi4 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                          2024-01-14 02:02:52.339  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.115.81 admin
                                          2024-01-14 02:03:06.659  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.115.81
                                            Hat sich erledigt.
                                            Ich hab nochmal ein full-upgrade gemacht.
                                            Jetzt läuft alles inkl. Shelly.
                                            2325
