    4. IOBroker reagiert nicht mehr | Shelly Adapter
      dike1982 @dike1982 last edited by dike1982
      full-upgrade ist durch und bin wieder eingeloggt!
        Thomas Braun Most Active @dike1982 last edited by
        @dike1982
        Dann schau dir jetzt noch Mal das
        iob diag
        an.
        • Glasfaser
          Glasfaser @dike1982 last edited by
          @dike1982 sagte in IOBroker reagiert nicht mehr | Shelly Adapter:
          Objects: 15406
          States: 0
          Size of iob-Database:
          30M /opt/iobroker/iobroker-data/objects.jsonl
          22M /opt/iobroker/iobroker-data/states.jsonl
          Adapter State
          Cannot read system.config: undefined (OK when migrating or restoring)
          Kannst du nochmal
          iob diag
          zeigen , da dein States 0 waren !
            dike1982 @Thomas Braun last edited by
            @thomas-braun said in IOBroker reagiert nicht mehr | Shelly Adapter:
            iob diag
            Hier das Ergebnis:
            Shelly-Adapter ist aus auf Pause.
            Skript v.2023-10-10
            *** BASE SYSTEM ***
             Static hostname: raspberrypi4
                   Icon name: computer
                      Kernel: Linux 6.1.0-rpi7-rpi-v8
                Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.5
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : arm64
            Systemuptime and Load:
             23:47:15 up 8 min,  2 users,  load average: 0.70, 0.69, 0.46
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Sat 2024-01-13 23:47:15 CET
                       Universal time: Sat 2024-01-13 22:47:15 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi4
            /home/pi4
            pi4 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            8.2G        1.6G        6.3G        1.2M        497M        6.6G
            Swap:           104M          0B        104M
            Total:          8.3G        1.6G        6.4G
                     7811 M total memory
                     1486 M used memory
                     1423 M active memory
                      299 M inactive memory
                     5969 M free memory
                       40 M buffer memory
                      433 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            udev           devtmpfs  3.6G     0  3.6G   0% /dev
            tmpfs          tmpfs     782M  1.2M  781M   1% /run
            /dev/mmcblk0p2 ext4       28G  4.6G   22G  18% /
            tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
            /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
            tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
            [Sat Jan 13 23:38:40 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:92:1C:FA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3656f3dd-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Sat Jan 13 23:38:42 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sat Jan 13 23:38:44 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            TARGET           SOURCE         FSTYPE OPTIONS
            /                /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            741M    /var/
            273M    /var/log
            272M    /var/log/journal/7251727675ab4e198e92b6d62c980f75
            202M    /var/cache
            Archived and active journals take up 271.9M in the file system.
            /opt/iobroker/backups:
            112M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            338M    /opt/iobroker/iobroker-data/
            197M    /opt/iobroker/iobroker-data/files
            83M     /opt/iobroker/iobroker-data/backup-objects
            67M     /opt/iobroker/iobroker-data/files/javascript.admin
            48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
            33M     /opt/iobroker/iobroker-data/objects.jsonl
            26M     /opt/iobroker/iobroker-data/states.jsonl
            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
            8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
            8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
            USB-Devices by-id:
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.19.0
            /usr/bin/node           v18.19.0
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            /usr/bin/corepack       0.22.0
            nodejs:
              Installed: 18.19.0-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
                 18.19.0+dfsg-6~deb12u1 500
             *** 18.19.0-1nodesource1 1001
                    100 /var/lib/dpkg/status
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0+dfsg1-1 500
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.17
            admin:          6.12.0
            javascript:     7.1.6
            Adapters from github:   0
            Adapter State
            + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
            + system.adapter.chromecast.0             : chromecast            : raspberrypi4                             -  enabled
            + system.adapter.cloud.0                  : cloud                 : raspberrypi4                             -  enabled
              system.adapter.daswetter.0              : daswetter             : raspberrypi4                             -  enabled
            + system.adapter.device-watcher.0         : device-watcher        : raspberrypi4                             -  enabled
              system.adapter.discovery.0              : discovery             : raspberrypi4                             - disabled
              system.adapter.dwd.0                    : dwd                   : raspberrypi4                             -  enabled
              system.adapter.flot.0                   : flot                  : raspberrypi4                             -  enabled
            + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi4                             -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : raspberrypi4                             -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi4                             -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi4                             -  enabled, port: 12010
            + system.adapter.hue-extended.0           : hue-extended          : raspberrypi4                             -  enabled
              system.adapter.ical.0                   : ical                  : raspberrypi4                             -  enabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi4                             -  enabled
            + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
              system.adapter.lgtv.0                   : lgtv                  : raspberrypi4                             - disabled
            + system.adapter.mercedesme.0             : mercedesme            : raspberrypi4                             -  enabled
              system.adapter.net-tools.0              : net-tools             : raspberrypi4                             - disabled
              system.adapter.openknx.0                : openknx               : raspberrypi4                             - disabled
              system.adapter.openknx.1                : openknx               : raspberrypi4                             - disabled
              system.adapter.ping.0                   : ping                  : raspberrypi4                             - disabled
            + system.adapter.scenes.0                 : scenes                : raspberrypi4                             -  enabled
              system.adapter.shelly.0                 : shelly                : raspberrypi4                             - disabled, port: 1882, bind: 0.0.0.0
            + system.adapter.sonos.0                  : sonos                 : raspberrypi4                             -  enabled
            + system.adapter.tr-064.0                 : tr-064                : raspberrypi4                             -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4                             -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi4                             -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi4                             -  enabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi4                             -  enabled
              system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4                             -  enabled
              system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4                             - disabled
            + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.12.0   , installed 6.12.0
            Adapter    "backitup"     : 2.9.8    , installed 2.9.8
            Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
            Adapter    "daswetter"    : 3.1.12   , installed 3.1.12
            Adapter    "device-watcher": 2.9.6   , installed 2.9.6
            Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
            Controller "js-controller": 5.0.17   , installed 5.0.17
            Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
            Adapter    "mercedesme"   : 0.1.1    , installed 0.1.6
            Adapter    "openknx"      : 0.6.3    , installed 0.6.3
            Adapter    "shelly"       : 6.6.1    , installed 6.6.1
            Adapter    "sonos"        : 3.0.0    , installed 3.0.0
            Adapter    "swiss-weather-api": 2.0.3, installed 2.0.3
            Adapter    "trashschedule": 2.3.0    , installed 2.3.0
            Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
            Adapter    "weatherunderground": 3.6.0, installed 3.6.0
            Adapter    "web"          : 6.1.10   , installed 6.1.10
            Adapter    "ws"           : 2.5.8    , installed 2.5.8
            Objects and States
            Objects:        15847
            States:         13319
            Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
            Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 192.168.115.89:12010    0.0.0.0:*               LISTEN      1001       15886      850/io.hm-rpc.1
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13103      658/iobroker.js-con
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13114      658/iobroker.js-con
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13057      683/sshd: /usr/sbin
            tcp        0      0 192.168.115.89:2001     0.0.0.0:*               LISTEN      1001       14083      830/io.hm-rpc.0
            tcp6       0      0 :::3000                 :::*                    LISTEN      1001       17537      1029/io.fullybrowse
            tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16027      884/io.sonos.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17471      988/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14027      718/io.admin.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          13059      683/sshd: /usr/sbin
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       16101      939/io.chromecast.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15528      468/avahi-daemon: r
            udp        0      0 0.0.0.0:59423           0.0.0.0:*                           104        15530      468/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                104        15529      468/avahi-daemon: r
            udp6       0      0 :::42496                :::*                                104        15531      468/avahi-daemon: r
            udp6       0      0 fe80::bea5:9acd:17c:546 :::*                                0          13984      515/NetworkManager
            2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
            2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=13 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705144977704
            2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Room 13 = OG Spielzimmer is open or disabled, no vent warning set
            2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=14 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705185983307
            2024-01-13 23:46:25.242  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Room 14 = OG Wohnzimmer is open or disabled, no vent warning set
            2024-01-13 23:46:25.243  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching VentCheck x=15 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1705185983768
            2024-01-13 23:46:25.243  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Room 15 = Treppenhaus is open or disabled, no vent warning set
            2024-01-13 23:46:25.243  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
            2024-01-13 23:46:25.250  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithOpenDoorsList
            2024-01-13 23:46:25.251  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenDoors: Keine Tür/en geöffnet
            2024-01-13 23:46:25.251  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithTiltedDoorsList
            2024-01-13 23:46:25.251  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithTiltedDoors: Keine Tür gekippt
            2024-01-13 23:46:25.252  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithOpenWindowsList
            2024-01-13 23:46:25.252  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenWindows: Alle Fenster sind geschlossen
            2024-01-13 23:46:25.252  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithTiltedWindowsList
            2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithTiltedWindows: Keine Fenster gekippt
            2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: CreateOpenRoomsList()
            2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: RoomsWithOpenings:
            2024-01-13 23:46:25.253  - info: javascript.0 (787) script.js.common.Visu.Status_Fenster.Fenster: Reaching CreateRoomsWithVentWarnings
            2024-01-13 23:47:48.717  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.115.81 javascript
            2024-01-13 23:48:14.589  - info: web.0 (988) ==> Connected system.user.admin from ::ffff:192.168.115.81
            2024-01-13 23:48:27.235  - info: web.0 (988) <== Disconnect system.user.admin from ::ffff:192.168.115.81 vis.0
            2024-01-13 23:48:27.593  - info: web.0 (988) ==> Connected system.user.admin from ::ffff:192.168.115.81
                                    v.2023-10-10
                   Icon name: computer
                Architecture: arm64
            Installation:           native
            Kernel:                 aarch64
            Userland:               arm64
            Timezone:               Europe/Berlin (CET, +0100)
            User-ID:                1000
            X-Server:               false
            Pending OS-Updates:     0
            Pending iob updates:    0
            Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
            Recommended versions are nodejs 18.19.0 and npm 10.2.3
            MEMORY:
            Mem:            8.2G        1.6G        5.9G        1.2M        831M        6.6G
            Swap:           104M          0B        104M
            Total:          8.3G        1.6G        6.0G
            Active iob-Instances:   19
            ioBroker Core:          js-controller           5.0.17
                                    admin                   6.12.0
            Objects type: jsonl
            States  type: jsonl
            Objects:                15847
            States:                 13319
              @dike1982
              Ich seh keine Unstimmigkeiten mehr in der Ausgabe.
                Okay soll ich dann den Shelly-Adapter mal wieder anwerfen?
                  @dike1982
                  Ja. Und schau dir das Logfile dann dazu in Echtzeit an:
                  iob logs --watch
                    024-01-14 00:01:27.778  - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 2664
                    2024-01-14 00:01:27.466  - info: host.raspberrypi4 "system.adapter.shelly.0" enabled
                    2024-01-14 00:01:27.778  - info: host.raspberrypi4 instance system.adapter.shelly.0 started with pid 2664
                    2024-01-14 00:01:31.946  - info: shelly.0 (2664) starting. Version 6.7.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.19.0, js-controller: 5.0.17
                    2024-01-14 00:01:40.337  - info: shelly.0 (2664) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
                    2024-01-14 00:01:41.130  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplusplugs-e465b860af58" connected!
                    2024-01-14 00:01:42.462  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-C8C9A325943E" connected!
                    2024-01-14 00:01:47.694  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204abaf8c" connected!
                    2024-01-14 00:01:48.225  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa80e8" connected!
                    2024-01-14 00:01:48.642  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684114" connected!
                    2024-01-14 00:01:51.090  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplusplugs / shellyplusplugs-e465b860af58 / shellyplusplugs#e465b860af58#1) (false)
                    2024-01-14 00:01:51.843  - error: shelly.0 (2664) [MQTT] Wrong MQTT authentification of client "shelly1pmmini-543204abcca8"
                    2024-01-14 00:01:52.038  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abcca8 / shelly1pmmini#543204abcca8#1) (false)
                    2024-01-14 00:01:56.147  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa1ae0" connected!
                    2024-01-14 00:01:57.690  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abaf8c / shelly1pmmini#543204abaf8c#1) (false)
                    2024-01-14 00:01:58.223  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa80e8 / shelly1pmmini#543204aa80e8#1) (false)
                    2024-01-14 00:01:58.474  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ab95d8" connected!
                    2024-01-14 00:01:58.637  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684114 / shellyplus2pm#a0a3b3684114#1) (false)
                    2024-01-14 00:01:59.963  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aaa1f4" connected!
                    2024-01-14 00:02:04.538  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-C8C9A325B2BE" connected!
                    2024-01-14 00:02:06.144  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa1ae0 / shelly1pmmini#543204aa1ae0#1) (false)
                    2024-01-14 00:02:06.889  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b8604d6c" connected!
                    2024-01-14 00:02:08.474  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ab95d8 / shelly1pmmini#543204ab95d8#1) (false)
                    2024-01-14 00:02:09.870  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aaa1f4 / shelly1pmmini#543204aaa1f4#1) (false)
                    2024-01-14 00:02:10.128  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b893c4d0" connected!
                    2024-01-14 00:02:11.893  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204adcc50" connected!
                    2024-01-14 00:02:13.197  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-08F9E047CD2F" connected!
                    2024-01-14 00:02:13.611  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa8d5c" connected!
                    2024-01-14 00:02:16.875  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b8604d6c / shellyplus2pm#e465b8604d6c#1) (false)
                    2024-01-14 00:02:19.387  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-C8C9A3258A34" connected!
                    2024-01-14 00:02:20.117  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b893c4d0 / shellyplus2pm#e465b893c4d0#1) (false)
                    2024-01-14 00:02:21.787  - info: shelly.0 (2664) [MQTT] Device with client id "shellydimmer2-08F9E047CBED" connected!
                    2024-01-14 00:02:21.884  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204adcc50 / shelly1pmmini#543204adcc50#1) (false)
                    2024-01-14 00:02:22.044  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acaf70" connected!
                    2024-01-14 00:02:23.605  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa8d5c / shelly1pmmini#543204aa8d5c#1) (false)
                    2024-01-14 00:02:25.623  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684110" connected!
                    2024-01-14 00:02:30.652  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204addca8" connected!
                    2024-01-14 00:02:32.037  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acaf70 / shelly1pmmini#543204acaf70#1) (false)
                    2024-01-14 00:02:32.452  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acfe10" connected!
                    2024-01-14 00:02:32.600  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ad6264" connected!
                    2024-01-14 00:02:34.964  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acee28" connected!
                    2024-01-14 00:02:35.620  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684110 / shellyplus2pm#a0a3b3684110#1) (false)
                    2024-01-14 00:02:40.650  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204addca8 / shelly1pmmini#543204addca8#1) (false)
                    2024-01-14 00:02:42.452  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acfe10 / shelly1pmmini#543204acfe10#1) (false)
                    2024-01-14 00:02:42.593  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ad6264 / shelly1pmmini#543204ad6264#1) (false)
                    2024-01-14 00:02:44.952  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acee28 / shelly1pmmini#543204acee28#1) (false)
                    2024-01-14 00:02:47.436  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplusplugs-e465b860af58" connected!
                    2024-01-14 00:02:48.615  - error: shelly.0 (2664) [MQTT] Wrong MQTT authentification of client "shelly1pmmini-543204abcca8"
                    2024-01-14 00:02:48.643  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abcca8 / shelly1pmmini#543204abcca8#1) (false)
                    2024-01-14 00:02:54.764  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684114" connected!
                    2024-01-14 00:02:54.980  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa80e8" connected!
                    2024-01-14 00:02:55.029  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204abaf8c" connected!
                    2024-01-14 00:02:57.435  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplusplugs / shellyplusplugs-e465b860af58 / shellyplusplugs#e465b860af58#1) (false)
                    2024-01-14 00:03:02.463  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa1ae0" connected!
                    2024-01-14 00:03:04.357  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ab95d8" connected!
                    2024-01-14 00:03:04.755  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684114 / shellyplus2pm#a0a3b3684114#1) (false)
                    2024-01-14 00:03:04.970  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa80e8 / shelly1pmmini#543204aa80e8#1) (false)
                    2024-01-14 00:03:05.025  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abaf8c / shelly1pmmini#543204abaf8c#1) (false)
                    2024-01-14 00:03:08.301  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aaa1f4" connected!
                    2024-01-14 00:03:12.456  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa1ae0 / shelly1pmmini#543204aa1ae0#1) (false)
                    2024-01-14 00:03:13.863  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b8604d6c" connected!
                    2024-01-14 00:03:14.349  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ab95d8 / shelly1pmmini#543204ab95d8#1) (false)
                    2024-01-14 00:03:16.095  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b893c4d0" connected!
                    2024-01-14 00:03:16.551  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204adcc50" connected!
                    2024-01-14 00:03:18.298  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aaa1f4 / shelly1pmmini#543204aaa1f4#1) (false)
                    2024-01-14 00:03:20.921  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa8d5c" connected!
                    2024-01-14 00:03:23.854  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b8604d6c / shellyplus2pm#e465b8604d6c#1) (false)
                    2024-01-14 00:03:26.086  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b893c4d0 / shellyplus2pm#e465b893c4d0#1) (false)
                    2024-01-14 00:03:26.542  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204adcc50 / shelly1pmmini#543204adcc50#1) (false)
                    2024-01-14 00:03:30.430  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204acaf70" connected!
                    2024-01-14 00:03:30.913  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa8d5c / shelly1pmmini#543204aa8d5c#1) (false)
                    2024-01-14 00:03:32.492  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684110" connected!
                    Sieht soweit Okay aus, bis auf die 2 error ?!
                      Ich kenne den shelly-Adapter nicht. Aber ich würde auch sagen, das ist soweit harmlos.
                        jetzt bekomme ich aber wieder Probleme;#
                        Cannot read compact mode by host "system.host.raspberrypi4": timeout
                          Thomas Braun Most Active @dike1982 last edited by Thomas Braun
                          @dike1982
                          Haste den denn aktiv?
                            Wen?
                            2024-01-14 00:09:16.821  - warn: dwd.0 (2682) get state error: Connection is closed.
                            2024-01-14 00:09:16.831  - warn: dwd.0 (2682) get state error: Connection is closed.
                            2024-01-14 00:09:16.832  - warn: dwd.0 (2682) get state error: Connection is closed.
                            2024-01-14 00:09:16.833  - warn: dwd.0 (2682) get state error: Connection is closed.
                            2024-01-14 00:09:16.834  - warn: dwd.0 (2682) get state error: Connection is closed.
                            2024-01-14 00:09:16.839  - warn: dwd.0 (2682) get state error: Connection is closed.
                            2024-01-14 00:09:16.840  - warn: dwd.0 (2682) get state error: Connection is closed.
                            2024-01-14 00:09:16.848  - warn: dwd.0 (2682) get state error: Connection is closed.
                            2024-01-14 00:09:16.849  - warn: dwd.0 (2682) get state error: Connection is closed.
                            2024-01-14 00:09:16.898  - warn: dwd.0 (2682) Can not read iobroker system configuration. Disable Rain Radar.
                            2024-01-14 00:09:16.916  - error: dwd.0 (2682) Cannot find view "system" for search "state" : Connection is closed.
                            2024-01-14 00:09:16.929  - error: dwd.0 (2682) Could not read existing states: Cannot find view "system"
                            2024-01-14 00:09:16.959  - warn: dwd.0 (2682) get state error: Connection is closed.
                            2024-01-14 00:09:16.960  - warn: dwd.0 (2682) get state error: Connection is closed.
                            2024-01-14 00:09:16.676  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684110 / shellyplus2pm#a0a3b3684110#1) (false)
                            2024-01-14 00:09:16.765  - info: dwd.0 (2682) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
                            DWD macht auch Zicken
                            D Thomas Braun 2 Replies Last reply Reply Quote 0
                              @dike1982
                              Und jetzt geht es los:
                              2024-01-14 00:15:03.289  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                              2024-01-14 00:15:03.298  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                              2024-01-14 00:15:03.300  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                              2024-01-14 00:15:03.301  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                              2024-01-14 00:15:03.302  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                              2024-01-14 00:15:03.303  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                              2024-01-14 00:15:03.304  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                              2024-01-14 00:15:03.306  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                              2024-01-14 00:15:03.307  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                              2024-01-14 00:15:03.308  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                              2024-01-14 00:15:03.309  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                              2024-01-14 00:15:03.310  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                              2024-01-14 00:15:03.312  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                              2024-01-14 00:15:03.313  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                              2024-01-14 00:15:03.316  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                              2024-01-14 00:15:03.317  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                              2024-01-14 00:15:05.556  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplusplugs-e465b860af58" connected!
                              2024-01-14 00:15:06.688  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                              2024-01-14 00:15:06.690  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                              2024-01-14 00:15:06.692  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                              2024-01-14 00:15:06.694  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                              2024-01-14 00:15:06.696  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                              2024-01-14 00:15:06.697  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                              2024-01-14 00:15:06.699  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                              2024-01-14 00:15:06.700  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                              2024-01-14 00:15:06.702  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                              2024-01-14 00:15:06.703  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                              2024-01-14 00:15:06.705  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                              2024-01-14 00:15:06.707  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                              2024-01-14 00:15:06.709  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                              2024-01-14 00:15:06.710  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                              2024-01-14 00:15:06.712  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                              2024-01-14 00:15:06.713  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                              2024-01-14 00:15:06.714  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                              2024-01-14 00:15:06.715  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                              2024-01-14 00:15:06.717  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                              2024-01-14 00:15:06.719  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                              2024-01-14 00:15:06.720  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                              2024-01-14 00:15:06.721  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                              2024-01-14 00:15:08.468  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-a0a3b3684114" connected!
                              2024-01-14 00:15:08.686  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                              2024-01-14 00:15:08.689  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                              2024-01-14 00:15:08.693  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                              2024-01-14 00:15:08.696  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                              2024-01-14 00:15:08.700  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                              2024-01-14 00:15:08.702  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                              2024-01-14 00:15:08.704  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                              2024-01-14 00:15:08.708  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                              2024-01-14 00:15:08.715  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                              2024-01-14 00:15:08.723  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                              2024-01-14 00:15:08.725  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                              2024-01-14 00:15:08.726  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                              2024-01-14 00:15:08.728  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                              2024-01-14 00:15:08.733  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                              2024-01-14 00:15:08.734  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                              2024-01-14 00:15:08.783  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                              2024-01-14 00:15:08.785  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                              2024-01-14 00:15:10.570  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204acfe10 / shelly1pmmini#543204acfe10#1) (false)
                              2024-01-14 00:15:10.964  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa80e8" connected!
                              2024-01-14 00:15:11.182  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204abaf8c" connected!
                              2024-01-14 00:15:11.847  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                              2024-01-14 00:15:11.860  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                              2024-01-14 00:15:11.861  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                              2024-01-14 00:15:11.861  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                              2024-01-14 00:15:11.862  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                              2024-01-14 00:15:11.863  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                              2024-01-14 00:15:11.864  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                              2024-01-14 00:15:11.865  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                              2024-01-14 00:15:11.866  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                              2024-01-14 00:15:11.867  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                              2024-01-14 00:15:11.868  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                              2024-01-14 00:15:11.869  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                              2024-01-14 00:15:11.870  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                              2024-01-14 00:15:11.871  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                              2024-01-14 00:15:11.872  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                              2024-01-14 00:15:12.043  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204ab95d8" connected!
                              2024-01-14 00:15:14.971  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                              2024-01-14 00:15:15.224  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                              2024-01-14 00:15:15.237  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                              2024-01-14 00:15:15.239  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                              2024-01-14 00:15:15.240  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                              2024-01-14 00:15:15.241  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                              2024-01-14 00:15:15.243  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                              2024-01-14 00:15:15.244  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                              2024-01-14 00:15:15.252  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                              2024-01-14 00:15:15.254  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                              2024-01-14 00:15:15.255  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                              2024-01-14 00:15:15.257  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                              2024-01-14 00:15:15.258  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                              2024-01-14 00:15:15.260  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                              2024-01-14 00:15:15.261  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                              2024-01-14 00:15:15.262  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                              2024-01-14 00:15:15.264  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                              2024-01-14 00:15:15.265  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                              2024-01-14 00:15:15.274  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                              2024-01-14 00:15:15.281  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                              2024-01-14 00:15:15.282  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                              2024-01-14 00:15:15.551  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplusplugs / shellyplusplugs-e465b860af58 / shellyplusplugs#e465b860af58#1) (false)
                              2024-01-14 00:15:16.845  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b8604d6c" connected!
                              2024-01-14 00:15:17.911  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                              2024-01-14 00:15:17.955  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                              2024-01-14 00:15:17.963  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                              2024-01-14 00:15:17.965  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                              2024-01-14 00:15:17.966  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                              2024-01-14 00:15:17.971  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                              2024-01-14 00:15:17.974  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                              2024-01-14 00:15:17.975  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                              2024-01-14 00:15:17.977  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                              2024-01-14 00:15:17.980  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                              2024-01-14 00:15:17.984  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                              2024-01-14 00:15:17.986  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                              2024-01-14 00:15:17.987  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                              2024-01-14 00:15:17.988  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                              2024-01-14 00:15:17.989  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                              2024-01-14 00:15:17.990  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                              2024-01-14 00:15:17.992  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                              2024-01-14 00:15:17.993  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                              2024-01-14 00:15:17.995  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                              2024-01-14 00:15:17.996  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                              2024-01-14 00:15:17.997  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                              2024-01-14 00:15:18.237  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                              2024-01-14 00:15:18.547  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-a0a3b3684114 / shellyplus2pm#a0a3b3684114#1) (false)
                              2024-01-14 00:15:20.960  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204aa80e8 / shelly1pmmini#543204aa80e8#1) (false)
                              2024-01-14 00:15:21.354  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                              2024-01-14 00:15:21.360  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                              2024-01-14 00:15:21.361  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                              2024-01-14 00:15:21.362  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                              2024-01-14 00:15:21.363  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                              2024-01-14 00:15:21.365  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                              2024-01-14 00:15:21.366  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                              2024-01-14 00:15:21.367  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                              2024-01-14 00:15:21.368  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                              2024-01-14 00:15:21.370  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                              2024-01-14 00:15:21.371  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                              2024-01-14 00:15:21.371  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                              2024-01-14 00:15:21.372  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                              2024-01-14 00:15:21.373  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                              2024-01-14 00:15:21.374  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                              2024-01-14 00:15:21.376  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                              2024-01-14 00:15:21.377  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                              2024-01-14 00:15:21.543  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204abaf8c / shelly1pmmini#543204abaf8c#1) (false)
                              2024-01-14 00:15:22.041  - info: shelly.0 (2664) [MQTT] Client Close:  (shelly1pmmini / shelly1pmmini-543204ab95d8 / shelly1pmmini#543204ab95d8#1) (false)
                              2024-01-14 00:15:22.649  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aaa1f4" connected!
                              2024-01-14 00:15:23.721  - info: shelly.0 (2664) [MQTT] Device with client id "shellyplus2pm-e465b893c4d0" connected!
                              2024-01-14 00:15:24.063  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                              2024-01-14 00:15:24.070  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                              2024-01-14 00:15:24.070  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                              2024-01-14 00:15:24.071  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                              2024-01-14 00:15:24.072  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                              2024-01-14 00:15:24.073  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                              2024-01-14 00:15:24.074  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                              2024-01-14 00:15:24.075  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                              2024-01-14 00:15:24.076  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                              2024-01-14 00:15:24.078  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                              2024-01-14 00:15:24.080  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acee28"
                              2024-01-14 00:15:24.081  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                              2024-01-14 00:15:24.083  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                              2024-01-14 00:15:24.084  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                              2024-01-14 00:15:24.085  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                              2024-01-14 00:15:24.086  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                              2024-01-14 00:15:24.087  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                              2024-01-14 00:15:24.088  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                              2024-01-14 00:15:24.089  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                              2024-01-14 00:15:24.090  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                              2024-01-14 00:15:24.091  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                              2024-01-14 00:15:24.092  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                              2024-01-14 00:15:24.093  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acaf70"
                              2024-01-14 00:15:24.098  - error: shelly.0 (2664) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for  (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
                              2024-01-14 00:15:24.099  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                              2024-01-14 00:15:24.100  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa1ae0"
                              2024-01-14 00:15:24.521  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa1ae0" connected!
                              2024-01-14 00:15:25.886  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204aa8d5c" connected!
                              2024-01-14 00:15:26.836  - info: shelly.0 (2664) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-e465b8604d6c / shellyplus2pm#e465b8604d6c#1) (false)
                              2024-01-14 00:15:26.901  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684114"
                              2024-01-14 00:15:26.911  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b8604d6c"
                              2024-01-14 00:15:26.914  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                              2024-01-14 00:15:26.917  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa8d5c"
                              2024-01-14 00:15:26.918  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                              2024-01-14 00:15:26.924  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                              2024-01-14 00:15:26.925  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                              2024-01-14 00:15:26.928  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                              2024-01-14 00:15:26.929  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abaf8c"
                              2024-01-14 00:15:26.932  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                              2024-01-14 00:15:26.933  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                              2024-01-14 00:15:26.935  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                              2024-01-14 00:15:26.937  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                              2024-01-14 00:15:26.938  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aa80e8"
                              2024-01-14 00:15:26.941  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                              2024-01-14 00:15:26.942  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-e465b860af58"
                              2024-01-14 00:15:26.943  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-e465b893c4d0"
                              2024-01-14 00:15:26.948  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a0a3b3684110"
                              2024-01-14 00:15:26.951  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204addca8"
                              2024-01-14 00:15:26.954  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                              2024-01-14 00:15:26.956  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ad6264"
                              2024-01-14 00:15:26.958  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204ab95d8"
                              2024-01-14 00:15:26.961  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204acfe10"
                              2024-01-14 00:15:26.965  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204adcc50"
                              2024-01-14 00:15:26.967  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204abcca8"
                              2024-01-14 00:15:28.173  - info: shelly.0 (2664) [MQTT] Device with client id "shelly1pmmini-543204adcc50" connected!
                              2024-01-14 00:15:29.835  - error: shelly.0 (2664) [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                @dike1982
                                So ein Verhalten des Systems hatte ich mal kurz bevor mir eine SD-Karte verreckt ist.
                                  Okay, die ist aber einen Monat alt vielleicht.
                                  Und es lief bisher ohne Problem, bis ich die Shellys heute eingebunden habe!
                                    @dike1982
                                    Da kann ich dir nicht weiterhelfen, kenne den Adapter und die Hardware nicht.
                                      dike1982 @Thomas Braun last edited by dike1982
                                      Trotzdem schon mal danke!
                                      Hat sonst einer eine Idee??
                                        Ich brauch leider nochmal Hilfe.
                                        Ich hab mir gedacht ich lösche den shelly-Adapter und fang mit den Shellys von vorne an.
                                        Das Löschen hat recht lange gedauert.
                                        Jetzt habe ich wieder die Time-out Warnungen auf der Oberfläche und es lässt sich quasi nicht bedienen, bzw. alles sehr langsam!!
                                        2024-01-14 01:36:10.647  - info: host.raspberrypi4 instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2024-01-14 01:37:09.511  - info: host.raspberrypi4 iobroker del shelly.0
                                        2024-01-14 01:37:40.809  - info: host.raspberrypi4 iobroker Delete instance "shelly.0"
                                        2024-01-14 01:37:46.555  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1 instances of shelly.0
                                        2024-01-14 01:37:51.803  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 23 devices of shelly.0
                                        2024-01-14 01:37:55.733  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 159 channels of shelly.0
                                        2024-01-14 01:37:59.655  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1360 states of shelly.0
                                        2024-01-14 01:38:02.245  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 15 states of system.adapter.shelly.0
                                        2024-01-14 01:38:02.906  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1134 states (io.shelly.0.*) from states
                                        2024-01-14 01:38:04.894  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 6 states (system.adapter.shelly.0.*) from states
                                        2024-01-14 01:38:11.587  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 2 objects of shelly.0host.raspberrypi4 Deleting 1560 object(s). Be patient...
                                        2024-01-14 01:38:49.188  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 1400 objects left to be deleted.
                                        2024-01-14 01:39:59.624  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 1200 objects left to be deleted.
                                        2024-01-14 01:40:21.779  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 1000 objects left to be deleted.
                                        2024-01-14 01:41:30.214  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 800 objects left to be deleted.
                                        2024-01-14 01:41:35.629  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 600 objects left to be deleted.
                                        2024-01-14 01:41:50.581  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 400 objects left to be deleted.
                                        2024-01-14 01:44:28.905  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 200 objects left to be deleted.
                                        2024-01-14 01:46:34.239  - info: host.raspberrypi4 object deleted system.adapter.shelly.0
                                        2024-01-14 01:46:34.251  - info: host.raspberrypi4 iobroker host.raspberrypi4 Deleting 1140 state(s). Be patient...
                                        2024-01-14 01:47:44.091  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 1000 states left to be deleted.
                                        2024-01-14 01:48:17.714  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 800 states left to be deleted.
                                        2024-01-14 01:49:33.382  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 600 states left to be deleted.
                                        2024-01-14 01:49:37.528  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 400 states left to be deleted.
                                        2024-01-14 01:52:40.727  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 200 states left to be deleted.
                                        2024-01-14 01:53:11.244  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.115.81 admin
                                        2024-01-14 01:54:05.002  - info: admin.0 (718) failed connection to socket.io from ::ffff:192.168.115.81: Passport was not initialized
                                        2024-01-14 01:54:10.253  - info: admin.0 (718) failed connection to socket.io from ::ffff:192.168.115.81: Passport was not initialized
                                        2024-01-14 01:55:26.687  - info: host.raspberrypi4 instance system.adapter.ical.0 started with pid 2971
                                        2024-01-14 01:55:38.919  - warn: ical.0 (2971) slow connection to objects DB. Still waiting ...
                                        2024-01-14 01:56:04.379  - warn: ical.0 (2971) slow connection to states DB. Still waiting ...
                                        2024-01-14 01:56:48.432  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.115.81 admin
                                        2024-01-14 01:57:05.853  - info: admin.0 (718) failed connection to socket.io from ::ffff:192.168.115.81: Passport was not initialized
                                        2024-01-14 01:57:41.889  - info: ical.0 (2971) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                                        2024-01-14 01:57:44.516  - info: ical.0 (2971) processing URL: Müllkalender https://calendar.google.com/calendar/ical/3a2097d8a678bc40972b4f2df3a70416e549cabb23d727a3bddacc2001f63aa7%40group.calendar.google.com/private-f6d975016103767eb05b6b0c059afa62/basic.ics
                                        2024-01-14 01:58:13.682  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.115.81
                                        2024-01-14 01:58:19.894  - info: ical.0 (2971) Terminated (NO_ERROR): Without reason
                                        2024-01-14 01:58:21.662  - info: host.raspberrypi4 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                        2024-01-14 01:59:47.928  - info: host.raspberrypi4 iobroker exit 0
                                        2024-01-14 02:00:00.084  - info: host.raspberrypi4 instance system.adapter.ical.0 started with pid 2990
                                        2024-01-14 02:00:20.340  - info: ical.0 (2990) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                                        2024-01-14 02:00:33.511  - info: ical.0 (2990) processing URL: Müllkalender https://calendar.google.com/calendar/ical/3a2097d8a678bc40972b4f2df3a70416e549cabb23d727a3bddacc2001f63aa7%40group.calendar.google.com/private-f6d975016103767eb05b6b0c059afa62/basic.ics
                                        2024-01-14 02:01:08.408  - info: ical.0 (2990) Terminated (NO_ERROR): Without reason
                                        2024-01-14 02:01:09.834  - info: host.raspberrypi4 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                        2024-01-14 02:02:52.339  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.115.81 admin
                                        2024-01-14 02:03:06.659  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.115.81
                                          Hat sich erledigt.
                                          Ich hab nochmal ein full-upgrade gemacht.
                                          Jetzt läuft alles inkl. Shelly.
                                            @Thomas-Braun
                                            Leider ist das Thema nicht erledigt.
                                            Der Shellyadater legt mir immer noch das System lahm.
                                            Ich habe deswegen ein Issue auf Github aufgemacht, der ENtwickler meinte zu mir:
                                            "deine Objekt- und State-DB macht Probleme"
                                            Keine Ahnung was das bedeutet oder wie ich das fixe.
                                            Würde aber dazu passen, dass ich mit einem Skript auch Probleme habe bei welchem aus einem Fensterkontakt der STATE nicht richtig ausgelesen werden kann und das Skript deswegen Fehler bringt.
                                            Eine Idee wie ich das löse?
                                            2325
