    4. [Aufruf] TP-Link HS100 HS110 Adapter Testen
      @tomtom:
      Hallo arteck,
      habe die Version 0.0.21 installiert - Herzlichen Dank dafür - leider startet der Adpater nicht.
      Die vorher installierte Version 0.0.18 lief.
      host.ioBroker-RasPi 2017-12-03 20:07:30.058 info Do not restart adapter system.adapter.hs100.0 because disabled or deleted
      host.ioBroker-RasPi 2017-12-03 20:07:30.057 error instance system.adapter.hs100.0 terminated with code 3 (Adapter disabled or invalid config)
      host.ioBroker-RasPi 2017-12-03 20:07:30.057 error Caught by controller[0]: at Function.Module._load (module.js:438:3) code: 'MODULE_NOT_FOUND' }
      host.ioBroker-RasPi 2017-12-03 20:07:30.056 error Caught by controller[0]: at tryModuleLoad (module.js:446:12)
      host.ioBroker-RasPi 2017-12-03 20:07:30.056 error Caught by controller[0]: at Module.load (module.js:487:32)
      host.ioBroker-RasPi 2017-12-03 20:07:30.056 error Caught by controller[0]: at Object.Module._extensions..js (module.js:579:10)
      host.ioBroker-RasPi 2017-12-03 20:07:30.055 error Caught by controller[0]: at Module._compile (module.js:570:32)
      host.ioBroker-RasPi 2017-12-03 20:07:30.053 error Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api/lib/client.js:3:18)
      host.ioBroker-RasPi 2017-12-03 20:07:30.052 error Caught by controller[0]: at require (internal/module.js:20:19)
      host.ioBroker-RasPi 2017-12-03 20:07:30.050 error Caught by controller[0]: at Module.require (module.js:497:17)
      host.ioBroker-RasPi 2017-12-03 20:07:30.049 error Caught by controller[0]: at Function.Module._load (module.js:417:25)
      host.ioBroker-RasPi 2017-12-03 20:07:30.047 error Caught by controller[0]: at Function.Module._resolveFilename (module.js:469:15)
      host.ioBroker-RasPi 2017-12-03 20:07:30.045 error Caught by controller[0]: { Error: Cannot find module 'babel-runtime/core-js/json/stringify'
      hs100.0 2017-12-03 20:07:29.966 error adapter disabled
      host.ioBroker-RasPi 2017-12-03 20:07:06.090 info object change system.adapter.hs100.0
      host.ioBroker-RasPi 2017-12-03 20:06:57.987 info Restart adapter system.adapter.hs100.0 because enabled
      host.ioBroker-RasPi 2017-12-03 20:06:57.987 error instance system.adapter.hs100.0 terminated with code 0 (OK)
      Caught 2017-12-03 20:06:57.987 error by controller[0]: at Function.Module._load (module.js:438:3) code: 'MODULE_NOT_FOUND' }
      Caught 2017-12-03 20:06:57.986 error by controller[0]: at tryModuleLoad (module.js:446:12)
      Caught 2017-12-03 20:06:57.986 error by controller[0]: at Module.load (module.js:487:32)
      Caught 2017-12-03 20:06:57.986 error by controller[0]: at Object.Module._extensions..js (module.js:579:10)
      Caught 2017-12-03 20:06:57.982 error by controller[0]: at Module._compile (module.js:570:32)
      Caught 2017-12-03 20:06:57.981 error by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api/lib/client.js:3:18)
      Caught 2017-12-03 20:06:57.981 error by controller[0]: at require (internal/module.js:20:19)
      Caught 2017-12-03 20:06:57.981 error by controller[0]: at Module.require (module.js:497:17)
      Caught 2017-12-03 20:06:57.980 error by controller[0]: at Function.Module._load (module.js:417:25)
      Caught 2017-12-03 20:06:57.980 error by controller[0]: at Function.Module._resolveFilename (module.js:469:15)
      Caught 2017-12-03 20:06:57.979 error by controller[0]: { Error: Cannot find module 'babel-runtime/core-js/json/stringify'
      hs100.0 2017-12-03 20:06:57.938 info terminating
      hs100.0 2017-12-03 20:06:57.758 info starting. Version 0.0.21 in /opt/iobroker/node_modules/iobroker.hs100, node: v6.10.0
      hs100.0 2017-12-03 20:06:57.701 info States connected to redis: 127.0.0.1:6379
      hs100.0 2017-12-03 20:06:57.433 error at Function.Module._load (module.js:438:3)
      hs100.0 2017-12-03 20:06:57.433 error at tryModuleLoad (module.js:446:12)
      hs100.0 2017-12-03 20:06:57.433 error at Module.load (module.js:487:32)
      hs100.0 2017-12-03 20:06:57.433 error at Object.Module._extensions..js (module.js:579:10)
      hs100.0 2017-12-03 20:06:57.433 error at Module._compile (module.js:570:32)
      hs100.0 2017-12-03 20:06:57.433 error at Object. (/opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api/lib/client.js:3:18)
      hs100.0 2017-12-03 20:06:57.433 error at require (internal/module.js:20:19)
      hs100.0 2017-12-03 20:06:57.433 error at Module.require (module.js:497:17)
      hs100.0 2017-12-03 20:06:57.433 error at Function.Module._load (module.js:417:25)
      hs100.0 2017-12-03 20:06:57.433 error at Function.Module._resolveFilename (module.js:469:15)
      hs100.0 2017-12-03 20:06:57.433 error Error: Cannot find module 'babel-runtime/core-js/json/stringify'
      hs100.0 2017-12-03 20:06:57.418 error uncaught exception: Cannot find module 'babel-runtime/core-js/json/stringify'
      host.ioBroker-RasPi 2017-12-03 20:06:56.080 info instance system.adapter.hs100.0 started with pid 10170
      host.ioBroker-RasPi 2017-12-03 20:06:56.007 info object change system.adapter.hs100.0
      LG
      Thomas `
      ok schmal bitte nach ob du unter /opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api/node_modules babel-runtime findest
      es scheint als ob irgendwas nicht mit installiert wurde
        @mamoel:
        Die Installation lief bei mir problemlos und der Adapter startet auch ohne Fehler im Log. Aber nach wie vor wird der Status nicht aktualisiert. `
        stoppe den adapter
        lösche unter objekte hs100.0
        starte den adapter.. die objekte sollten jetzt neu erzeugt worden sein..
          mamoel last edited by
          Vielen Dank. Ich kann bestätigen, dass es jetzt funktioniert.
          • cvidal
            @arteck:
            neue Version verfügbar 0.0.21 basierend auf https://github.com/plasticrake/tplink-smarthome-api
            allerdings habe ich ein Problem mit dem Powermanagement von HS110.. Bekomme die Verbrauchsdaten nicht ausgelesen..
            Polling sollte jetzt klappen `
            Ja Rückmeldung funtioniert jetzt, Danke für deine Mühe
            Ich werde aber erst mal zu 0.0.18 zurückkehren denn das Powermanagment nutze ich gerade in der Vis.App.
            Könntest du mir vielleicht sagen warum die Verbrauchsdaten im Broker anderes als in der Kasa App sind bzw. bin ich der einzige mit dem Problem?
            Gruß Christian
              tomtom last edited by
              Hallo arteck,
              unter /opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api# ls
              befindet sich nur:
              CHANGELOG.md lib LICENSE package.json README.md
              Der Ordner node_modules ist nicht vorhanden.
              Ich habe den Adapter 0.0.21 über den 0.0.18, wie folgt manuell installiert:
              cd /opt/iobroker
              iobroker stop
              npm install iobroker.hs100@0.0.21 –production
              iobroker upload hs100
              iobroker start
              LG
              Thomas
              • Dolomiti
                Dolomiti last edited by
                Hallo arteck,
                ich hatte auch eine Menge Fehlermeldungen
                host.raspi3	2017-12-04 20:41:24.027	error	instance system.adapter.hs100.0 terminated with code 1 ()
                Caught	2017-12-04 20:41:24.027	error	by controller[0]: at node.js:1043:3
                Caught	2017-12-04 20:41:24.026	error	by controller[0]: at startup (node.js:140:18)
                Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Function.Module.runMain (module.js:441:10)
                Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Function.Module._load (module.js:300:12)
                Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Module.load (module.js:343:32)
                Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Object.Module._extensions..js (module.js:416:10)
                Caught	2017-12-04 20:41:24.026	error	by controller[0]: at Module._compile (module.js:373:25)
                Caught	2017-12-04 20:41:24.025	error	by controller[0]: at exports.runInThisContext (vm.js:53:16)
                Caught	2017-12-04 20:41:24.025	error	by controller[0]: SyntaxError: Unexpected token {
                Caught	2017-12-04 20:41:24.025	error	by controller[0]: ^
                Caught	2017-12-04 20:41:24.024	error	by controller[0]: const { Client } = require('./lib/tplink-smarthome-api/lib/index');
                Caught	2017-12-04 20:41:24.024	error	by controller[0]: /opt/iobroker/node_modules/iobroker.hs100/main.js:14
                Unter /opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api/node_modules babel-runtime habe ich die Verzeichnisse
                core-js
                helpers
                regenerator
                und noch 4 Dateien
                Bin momentan zurück auf 0.0.18, die einwandfrei läuft. Der Trockner wird momentan geloggt. 🙂
                Dolomiti
                  schon komisch .bei euch beiden.. es ist als ob nicht alles von GIT gezogen wurde..
                  so die hs110 liefert jetzt auch daten.. version 0.22
                  und die restlichen tp-link derivate sollten auch laufen.. (so hoffe ich :oops: )
                    Gerni last edited by
                    ich hatte auch das Problem, dass der State nicht übergeben wurde, entsprechendes UpDate steht ja zur Verfügung.
                    Also Adapter gestoppt, Unter Objekte HS100 alles gelöscht, UpDate gemacht -> Adapter startet
                    Adapter komplett deinstalliert und wieder installiert -> Adapter startet nicht.
                    Ideen?
                    • AlCalzone
                      Ist da nicht-transpilierter Code auf NPM gelandet? Die Syntax ist relativ neu und wird aktuell nur von Babel/TypeScript unterstützt, evtl auch Node 8+
                        @AlCalzone:
                        Ist da nicht-transpilierter Code auf NPM gelandet? Die Syntax ist relativ neu und wird aktuell nur von Babel/TypeScript unterstützt, evtl auch Node 8+ `
                        ich hab node 6.12 .. auf dem Pi und 6 nochwas auf dem Win Entwickler System
                        ich check mal ob auf NPM alles gelandet ist .. da kann das Problem sein
                        installier es bitte nur vom GIT..
                        über admin
                        • AlCalzone
                          Node 8 war geraten, aber Node 4 kann es definitiv nicht und davon sind hier noch einige im Umlauf.
                          Lässt sich aber relativ einfach fixen:
                          const Client = require('./lib/tplink-smarthome-api/lib/index').Client;
                            @AlCalzone:
                            ok… ich check das mal
                            wobei mit node 4 läuft der adapter nicht
                              also ich habe die Version 6.10.0 im Einsatz:
                              Was ist mit
                              -installier es bitte nur vom GIT..
                              -über admin
                              gemeint?
                              cd /opt/iobroker
                              npm install https://github.com/arteck/ioBroker.hs10 … ll/master/
                              LG
                              Thomas
                              • AlCalzone
                                @tomtom:
                                -über admin
                                gemeint? `
                                => ioBroker Admin öffnen
                                => Auf das GitHub-Icon klicken
                                => hs110 aus der Liste auswählen
                                => OK
                                • Dolomiti
                                  Ich Vollpfosten 🙂
                                  Man sollte den Adapter auch auf dem richtigen Slave-Raspi mit Node 6 installieren und nicht auf dem Master-Raspi mit Node 4.
                                  Jetzt klappt´s.
                                  Dolomiti
                                  P.S. Bei mir lief 0.0.18 auch unter Node 4.8
                                  • cvidal
                                    So 0.0.22 Läuft Instaliert habe ich über Admin Octocat Symbol siehe Bild…
                                    Läuft erstmal soweit sehr gut der Adapter, danke dafür.
                                    Einzig der Datenpunkt Total gibt mir immer noch Rätsel auf, was soll der überhaupt ausgeben? Verbrauch Heute, Vergangene 7 Tage oder Vergangene 30 Tage kann das nicht sein denn die Kasa App zeigt einen völlig anderen Wert an…
                                    Gruß Christian
                                      Auch die 0.0.22 läuft bei mir fehlerfrei. Aber auch bei dieser Version musste ich unter "Objects" den HS100-Knoten löschen. Sonst wird der "state" nicht aktualisiert.
                                        freut mich dass es läuft…
                                        wobei ich probleme mit dem npm Paket habe
                                        also bitte erstmal vom Git installieren
                                        @AlCalzone:
                                        => OK `
                                        • X
                                          xelarep last edited by
                                          hab heute auch ne HS110 bekommen. Leider klappts bei mir nicht: Hatte erst händisch versucht per````
                                          sudo npm install iobroker.hs100
                                          Es wurde v0.0.23 installiert, ich seh in der Admin Oberfläche einen Adapter und kann eine Instanz hs100.0 anlegen und konfigurieren. Sie stoppt aber sofort wieder, und wirft folgende Fehler ins log.
                                          host.morbo 2017-12-06 15:02:55.522 info Restart adapter system.adapter.hs100.0 because enabled
                                          host.morbo 2017-12-06 15:02:55.521 error instance system.adapter.hs100.0 terminated with code 0 (OK)
                                          hs100.0 2017-12-06 15:02:55.503 info terminating
                                          hs100.0 2017-12-06 15:02:55.296 info starting. Version 0.0.23 in /opt/iobroker/node_modules/iobroker.hs100, node: v6.11.2
                                          hs100.0 2017-12-06 15:02:54.994 error at Function.Module._load (module.js:438:3)
                                          hs100.0 2017-12-06 15:02:54.994 error at tryModuleLoad (module.js:446:12)
                                          hs100.0 2017-12-06 15:02:54.994 error at Module.load (module.js:487:32)
                                          hs100.0 2017-12-06 15:02:54.994 error at Object.Module._extensions..js (module.js:579:10)
                                          hs100.0 2017-12-06 15:02:54.994 error at Module._compile (module.js:570:32)
                                          hs100.0 2017-12-06 15:02:54.994 error at Object. (/opt/iobroker/node_modules/iobroker.hs100/lib/tplink-smarthome-api/lib/client.js:3:18)
                                          hs100.0 2017-12-06 15:02:54.994 error at require (internal/module.js:20:19)
                                          hs100.0 2017-12-06 15:02:54.994 error at Module.require (module.js:497:17)
                                          hs100.0 2017-12-06 15:02:54.994 error at Function.Module._load (module.js:417:25)
                                          hs100.0 2017-12-06 15:02:54.994 error at Function.Module._resolveFilename (module.js:469:15)
                                          hs100.0 2017-12-06 15:02:54.994 error Error: Cannot find module 'babel-runtime/core-js/json/stringify'
                                          hs100.0 2017-12-06 15:02:54.979 error uncaught exception: Cannot find module 'babel-runtime/core-js/json/stringify'
                                          Node ist 6.11.2 auf einem RPi3
                                          Wenn ich per Github installieren möchte bekomme ich keine hs100 angeboten?
                                          Was mach ich falsch?
                                          Alexander
                                          [edit] ich hab noch etwas rumgespielt: wenn ich einmal händisch per Terminal installiert habe, kann ich per GitHub drüberinstallieren (dann kommt eine hs100 in der Github Liste), und dann wird auch eine lauffähige Instanz und ein Objekt erzeugt, die ich benutzen kann?!
                                            link eintragen https://github.com/arteck/ioBroker.hs100
                                            dann weiter mit
                                            => OK
                                            31.7k
                                            79.8k
                                            215
                                            43192
