    4. QNAP NAS Container ioBroker js-controller und node update
      Thomas Braun Most Active @Glasfaser last edited by
      @glasfaser sagte in QNAP NAS Container ioBroker js-controller und node update:
      kannst du nacher helfen... um erstmal nur auf 16 zu kommen für den alten Container !
      Keine Ahnung. Ich kann nur apt... Geht das im Container?
      • Glasfaser
        Glasfaser @Thomas Braun last edited by
        Ja , geht !
          Thomas Braun Most Active @HolgerCW last edited by
          @holgercw
          apt update
          apt policy nodejs
          sagt?
            HolgerCW @Glasfaser last edited by
            @glasfaser ```
            root@ioBroker:/opt/iobroker# pkill -u iobroker
            root@ioBroker:/opt/iobroker# sudo -H -u iobroker npm install iobroker.js-controller@4.0.24
            npm ERR! code ENOTSUP
            npm ERR! notsup Unsupported engine for iobroker.js-controller@4.0.24: wanted: {"node":">=12.0.0"} (current: {"node":"10.18.1","npm":"6.13.4"})
            npm ERR! notsup Not compatible with your version of node/npm: iobroker.js-controller@4.0.24
            npm ERR! notsup Required: {"node":">=12.0.0"}
            npm ERR! notsup Actual: {"npm":"6.13.4","node":"10.18.1"}
            npm ERR! /opt/iobroker/.npm/_logs/2024-01-14T13_59_52_793Z-debug.log
              HolgerCW @Thomas Braun last edited by
              @thomas-braun sagte in QNAP NAS Container ioBroker js-controller und node update:
              apt policy nodejs
              root@ioBroker:/opt/iobroker# apt update
              Ign:1 http://security.debian.org/debian-security stretch/updates InRelease
              Fehl:2 http://security.debian.org/debian-security stretch/updates Release
                404  Not Found
              Ign:3 http://deb.debian.org/debian stretch InRelease
              Ign:4 http://deb.debian.org/debian stretch-updates InRelease
              Fehl:5 http://deb.debian.org/debian stretch Release
                404  Not Found
              Fehl:6 http://deb.debian.org/debian stretch-updates Release
                404  Not Found
              Holen:7 https://deb.nodesource.com/node_10.x stretch InRelease [4.585 B]
              Holen:8 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages [767 B]
              E: The repository 'http://security.debian.org/debian-security stretch/updates Release' does not have a Release file.
              N: Updating from such a repository can't be done securely, and is therefore disabled by default.
              N: See apt-secure(8) manpage for repository creation and user configuration details.
              E: The repository 'http://deb.debian.org/debian stretch Release' does not have a Release file.
              E: The repository 'http://deb.debian.org/debian stretch-updates Release' does not have a Release file.
              root@ioBroker:/opt/iobroker# apt policy nodejs
              nodejs:
                Installiert:           10.18.1-1nodesource1
                Installationskandidat: 10.24.1-1nodesource1
                Versionstabelle:
                   10.24.1-1nodesource1 500
                      500 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages
               *** 10.18.1-1nodesource1 100
                      100 /var/lib/dpkg/status
                Habe beides durchgeführt. Siehe was die Console ausgespuckt hat in den letzten beiden Posts. Sorry, gestern konnte ich leider nicht mehr antworten.
                Gruss
                Holger
                • Glasfaser
                  Glasfaser @HolgerCW last edited by Glasfaser
                  @holgercw sagte in QNAP NAS Container ioBroker js-controller und node update:
                  deshalb mein Edit dazu im oberen Beitrag , das erst Nodejs hochgezogen werden muß !!
                    HolgerCW @Glasfaser last edited by HolgerCW
                    @glasfaser OK, da übersehe ich dann hier ständig was. Wie ziehe ich das hoch ? Kannst mir den Code dazu posten ?
                    • Glasfaser
                      Ja , das sehe ich ..
                      lese doch bitte die Kommentare langsam durch , ich habe @Thomas-Braun um Hilfe gebeten !
                        HolgerCW @Glasfaser last edited by Homoran
                        @glasfaser Habe jetzt apt update gemacht und dann kommt das:
                          404  Not Found
                          404  Not Found
                          404  Not Found
                        nodejs:
                          Versionstabelle:
                        • Glasfaser
                          Bitte kein Doppelpost ... eine Ausgabe reicht oben !
                          Und Wichtig bitte keine Befehl quer ausführen ... !
                          Also warten !
                            @glasfaser UNd auch das mit iob nodejs-update. Dann kommt das:
                            root@ioBroker:/opt/iobroker# iob stop
                            iobroker controller daemon is not running
                            root@ioBroker:/opt/iobroker# iob fix
                            root@ioBroker:/opt/iobroker# iob nodejs-update
                            iobroker [command]
                            Commands:
                              iobroker setup                                               Setup ioBroker
                              iobroker start                                               Starts the js-controller
                              iobroker stop                                                stops the js-controller
                              iobroker restart                                             Restarts js-controller
                              iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                              iobroker info                                                Shows the host info
                              iobroker logs [<adapter>]                                    Monitor log
                              iobroker add <adapter> [desiredNumber]                       Add instance of adapter
                              iobroker install <adapter>                                   Installs a specified adapter
                              iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
                              iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                              iobroker del <adapter>                                       Remove adapter from system
                              iobroker del <adapter>.<instance>                            Remove adapter instance
                              iobroker update [<repositoryUrl>]                            Update repository and list adapters
                              iobroker upgrade                                             Upgrade management
                              iobroker upload                                              Upload management
                              iobroker object                                              Object management
                              iobroker state                                               State management
                              iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                              iobroker list <type> [<filter>]                              List all entries, like objects
                              iobroker chmod <mode> <file>                                 Change file rights
                              iobroker chown <user> <group> <file>                         Change file ownership
                              iobroker touch <file>                                        Touch file
                              iobroker rm <file>                                           Remove file
                              iobroker file                                                File management
                              iobroker user                                                User commands
                              iobroker group                                               group management
                              iobroker host <hostname>                                     Set host to given hostname
                              iobroker set <adapter>.<instance>                            Change settings of adapter config
                              iobroker license <license.file or license.text>              Update license by given file
                              iobroker cert                                                Certificate management
                              iobroker clean <yes>                                         Clears all objects and states
                              iobroker backup                                              Create backup
                              iobroker restore <backup name or path>                       Restore a specified backup
                              iobroker validate <backup name or path>                      Validate a specified backup
                              iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
                              iobroker repo [<name>]                                       Show repo information
                              iobroker uuid                                                Show uuid of the installation
                              iobroker unsetup                                             Reset license, installation secret and language
                              iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                              iobroker multihost                                           Multihost management
                              iobroker compact                                             compact group management
                              iobroker plugin                                              Plugin management
                              iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
                            Options:
                                  --help     Show help  [boolean]
                              -v, --version  Show version  [boolean]
                            • Glasfaser
                              Nochmal bitte Warten !
                              der Befehl funktioniert nicht in Docker !
                                @glasfaser Achso. Ich soll hier auf eine Antwort warten ? Ich danchte ich hätte was übersehen. Dann bin ich gespannt auf die Antwort.
                                • Glasfaser
                                  richtig ...er braucht diese zwei Ausgaben , dann gehts es weiter ... ( oder auch nicht ) !
                                  Das Problem ist , das du auf Nodejs 10 bist !
                                    @glasfaser Ok, die Ausgabe habe ich ja geliefert, richtig ? Dann warten wir mal ab.
                                      Thomas Braun Most Active @HolgerCW last edited by Thomas Braun
                                      @holgercw
                                      Alles steinalt und die Repos sind natürlich auch abgeräumt worden...
                                      Versuch mal in der Datei
                                      /etc/apt/sources.list.d/nodesource.list
                                      die 10 durch 16 zu ersetzen. Vielleicht lebt wenigstens das noch.
                                      Der ganze Mist kommt von dem tollen 'never tatsch a running süstem'. Der Schwachsinn funktioniert nicht.
                                      H maloross 2 Replies Last reply Reply Quote 0
                                        Kannst Du mir sage, wo ich den PFad finde:
                                          @holgercw
                                          Nein, kann ich nicht. Von Docker lass ich nämlich die Finger.
                                          • maloross
                                            maloross @Thomas Braun last edited by
                                            Das sollte über die Befehlskonsole funktionieren (Ansicht aus CS 3)
                                            4295
