    4. QNAP NAS Container ioBroker js-controller und node update
      Thomas Braun Most Active @HolgerCW last edited by
      @holgercw
      apt update
      apt policy nodejs
      sagt?
        HolgerCW @Glasfaser last edited by
        @glasfaser ```
        root@ioBroker:/opt/iobroker# pkill -u iobroker
        root@ioBroker:/opt/iobroker# sudo -H -u iobroker npm install iobroker.js-controller@4.0.24
        npm ERR! code ENOTSUP
        npm ERR! notsup Unsupported engine for iobroker.js-controller@4.0.24: wanted: {"node":">=12.0.0"} (current: {"node":"10.18.1","npm":"6.13.4"})
        npm ERR! notsup Not compatible with your version of node/npm: iobroker.js-controller@4.0.24
        npm ERR! notsup Required: {"node":">=12.0.0"}
        npm ERR! notsup Actual: {"npm":"6.13.4","node":"10.18.1"}
        npm ERR! /opt/iobroker/.npm/_logs/2024-01-14T13_59_52_793Z-debug.log
          HolgerCW @Thomas Braun last edited by
          @thomas-braun sagte in QNAP NAS Container ioBroker js-controller und node update:
          apt policy nodejs
          root@ioBroker:/opt/iobroker# apt update
          Ign:1 http://security.debian.org/debian-security stretch/updates InRelease
          Fehl:2 http://security.debian.org/debian-security stretch/updates Release
            404  Not Found
          Ign:3 http://deb.debian.org/debian stretch InRelease
          Ign:4 http://deb.debian.org/debian stretch-updates InRelease
          Fehl:5 http://deb.debian.org/debian stretch Release
            404  Not Found
          Fehl:6 http://deb.debian.org/debian stretch-updates Release
            404  Not Found
          Holen:7 https://deb.nodesource.com/node_10.x stretch InRelease [4.585 B]
          Holen:8 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages [767 B]
          E: The repository 'http://security.debian.org/debian-security stretch/updates Release' does not have a Release file.
          N: Updating from such a repository can't be done securely, and is therefore disabled by default.
          N: See apt-secure(8) manpage for repository creation and user configuration details.
          E: The repository 'http://deb.debian.org/debian stretch Release' does not have a Release file.
          E: The repository 'http://deb.debian.org/debian stretch-updates Release' does not have a Release file.
          root@ioBroker:/opt/iobroker# apt policy nodejs
          nodejs:
            Installiert:           10.18.1-1nodesource1
            Installationskandidat: 10.24.1-1nodesource1
            Versionstabelle:
               10.24.1-1nodesource1 500
                  500 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages
           *** 10.18.1-1nodesource1 100
                  100 /var/lib/dpkg/status
            Habe beides durchgeführt. Siehe was die Console ausgespuckt hat in den letzten beiden Posts. Sorry, gestern konnte ich leider nicht mehr antworten.
            Gruss
            Holger
            • Glasfaser
              Glasfaser @HolgerCW last edited by Glasfaser
              @holgercw sagte in QNAP NAS Container ioBroker js-controller und node update:
              deshalb mein Edit dazu im oberen Beitrag , das erst Nodejs hochgezogen werden muß !!
                HolgerCW @Glasfaser last edited by HolgerCW
                @glasfaser OK, da übersehe ich dann hier ständig was. Wie ziehe ich das hoch ? Kannst mir den Code dazu posten ?
                • Glasfaser
                  Ja , das sehe ich ..
                  lese doch bitte die Kommentare langsam durch , ich habe @Thomas-Braun um Hilfe gebeten !
                    HolgerCW @Glasfaser last edited by Homoran
                    @glasfaser Habe jetzt apt update gemacht und dann kommt das:
                      404  Not Found
                      404  Not Found
                      404  Not Found
                    nodejs:
                      Versionstabelle:
                    • Glasfaser
                      Bitte kein Doppelpost ... eine Ausgabe reicht oben !
                      Und Wichtig bitte keine Befehl quer ausführen ... !
                      Also warten !
                        @glasfaser UNd auch das mit iob nodejs-update. Dann kommt das:
                        root@ioBroker:/opt/iobroker# iob stop
                        iobroker controller daemon is not running
                        root@ioBroker:/opt/iobroker# iob fix
                        root@ioBroker:/opt/iobroker# iob nodejs-update
                        iobroker [command]
                        Commands:
                          iobroker setup                                               Setup ioBroker
                          iobroker start                                               Starts the js-controller
                          iobroker stop                                                stops the js-controller
                          iobroker restart                                             Restarts js-controller
                          iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                          iobroker info                                                Shows the host info
                          iobroker logs [<adapter>]                                    Monitor log
                          iobroker add <adapter> [desiredNumber]                       Add instance of adapter
                          iobroker install <adapter>                                   Installs a specified adapter
                          iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
                          iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                          iobroker del <adapter>                                       Remove adapter from system
                          iobroker del <adapter>.<instance>                            Remove adapter instance
                          iobroker update [<repositoryUrl>]                            Update repository and list adapters
                          iobroker upgrade                                             Upgrade management
                          iobroker upload                                              Upload management
                          iobroker object                                              Object management
                          iobroker state                                               State management
                          iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                          iobroker list <type> [<filter>]                              List all entries, like objects
                          iobroker chmod <mode> <file>                                 Change file rights
                          iobroker chown <user> <group> <file>                         Change file ownership
                          iobroker touch <file>                                        Touch file
                          iobroker rm <file>                                           Remove file
                          iobroker file                                                File management
                          iobroker user                                                User commands
                          iobroker group                                               group management
                          iobroker host <hostname>                                     Set host to given hostname
                          iobroker set <adapter>.<instance>                            Change settings of adapter config
                          iobroker license <license.file or license.text>              Update license by given file
                          iobroker cert                                                Certificate management
                          iobroker clean <yes>                                         Clears all objects and states
                          iobroker backup                                              Create backup
                          iobroker restore <backup name or path>                       Restore a specified backup
                          iobroker validate <backup name or path>                      Validate a specified backup
                          iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
                          iobroker repo [<name>]                                       Show repo information
                          iobroker uuid                                                Show uuid of the installation
                          iobroker unsetup                                             Reset license, installation secret and language
                          iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                          iobroker multihost                                           Multihost management
                          iobroker compact                                             compact group management
                          iobroker plugin                                              Plugin management
                          iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
                        Options:
                              --help     Show help  [boolean]
                          -v, --version  Show version  [boolean]
                        • Glasfaser
                          Nochmal bitte Warten !
                          der Befehl funktioniert nicht in Docker !
                            @glasfaser Achso. Ich soll hier auf eine Antwort warten ? Ich danchte ich hätte was übersehen. Dann bin ich gespannt auf die Antwort.
                            • Glasfaser
                              richtig ...er braucht diese zwei Ausgaben , dann gehts es weiter ... ( oder auch nicht ) !
                              Das Problem ist , das du auf Nodejs 10 bist !
                                @glasfaser Ok, die Ausgabe habe ich ja geliefert, richtig ? Dann warten wir mal ab.
                                  Thomas Braun Most Active @HolgerCW last edited by Thomas Braun
                                  @holgercw
                                  Alles steinalt und die Repos sind natürlich auch abgeräumt worden...
                                  Versuch mal in der Datei
                                  /etc/apt/sources.list.d/nodesource.list
                                  die 10 durch 16 zu ersetzen. Vielleicht lebt wenigstens das noch.
                                  Der ganze Mist kommt von dem tollen 'never tatsch a running süstem'. Der Schwachsinn funktioniert nicht.
                                  H maloross 2 Replies Last reply Reply Quote 0
                                    Kannst Du mir sage, wo ich den PFad finde:
                                      @holgercw
                                      Nein, kann ich nicht. Von Docker lass ich nämlich die Finger.
                                      • maloross
                                        maloross @Thomas Braun last edited by
                                        Das sollte über die Befehlskonsole funktionieren (Ansicht aus CS 3)
                                          HolgerCW @maloross last edited by
                                          @maloross Das habe ich gemacht und es klappt. Und nun ?
                                            HolgerCW @Thomas Braun last edited by HolgerCW
                                            @thomas-braun Habe da was gefunden. Ich glaube das ist der Pfad von Docker. Nun müsste ich noch geführt werden:
                                            Vielleicht auch hier: S:\container-station-data\lib\docker\overlay2\l\UJDMZLQINEDIUXDWCN6JCCNOKX\opt\iobroker\node_modules ???
                                            maloross 1 Reply Last reply Reply Quote 0
                                            4278
