    4. QNAP NAS Container ioBroker js-controller und node update
      HolgerCW @Glasfaser last edited by
      @glasfaser ```
      root@ioBroker:/opt/iobroker# pkill -u iobroker
      root@ioBroker:/opt/iobroker# sudo -H -u iobroker npm install iobroker.js-controller@4.0.24
      npm ERR! code ENOTSUP
      npm ERR! notsup Unsupported engine for iobroker.js-controller@4.0.24: wanted: {"node":">=12.0.0"} (current: {"node":"10.18.1","npm":"6.13.4"})
      npm ERR! notsup Not compatible with your version of node/npm: iobroker.js-controller@4.0.24
      npm ERR! notsup Required: {"node":">=12.0.0"}
      npm ERR! notsup Actual: {"npm":"6.13.4","node":"10.18.1"}
      npm ERR! /opt/iobroker/.npm/_logs/2024-01-14T13_59_52_793Z-debug.log
        HolgerCW @Thomas Braun last edited by
        @thomas-braun sagte in QNAP NAS Container ioBroker js-controller und node update:
        apt policy nodejs
        root@ioBroker:/opt/iobroker# apt update
        Ign:1 http://security.debian.org/debian-security stretch/updates InRelease
        Fehl:2 http://security.debian.org/debian-security stretch/updates Release
          404  Not Found
        Ign:3 http://deb.debian.org/debian stretch InRelease
        Ign:4 http://deb.debian.org/debian stretch-updates InRelease
        Fehl:5 http://deb.debian.org/debian stretch Release
          404  Not Found
        Fehl:6 http://deb.debian.org/debian stretch-updates Release
          404  Not Found
        Holen:7 https://deb.nodesource.com/node_10.x stretch InRelease [4.585 B]
        Holen:8 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages [767 B]
        E: The repository 'http://security.debian.org/debian-security stretch/updates Release' does not have a Release file.
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
        E: The repository 'http://deb.debian.org/debian stretch Release' does not have a Release file.
        E: The repository 'http://deb.debian.org/debian stretch-updates Release' does not have a Release file.
        root@ioBroker:/opt/iobroker# apt policy nodejs
        nodejs:
          Installiert:           10.18.1-1nodesource1
          Installationskandidat: 10.24.1-1nodesource1
          Versionstabelle:
             10.24.1-1nodesource1 500
                500 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages
         *** 10.18.1-1nodesource1 100
                100 /var/lib/dpkg/status
          Habe beides durchgeführt. Siehe was die Console ausgespuckt hat in den letzten beiden Posts. Sorry, gestern konnte ich leider nicht mehr antworten.
          Gruss
          Holger
          • Glasfaser
            Glasfaser @HolgerCW last edited by Glasfaser
            @holgercw sagte in QNAP NAS Container ioBroker js-controller und node update:
            deshalb mein Edit dazu im oberen Beitrag , das erst Nodejs hochgezogen werden muß !!
              HolgerCW @Glasfaser last edited by HolgerCW
              @glasfaser OK, da übersehe ich dann hier ständig was. Wie ziehe ich das hoch ? Kannst mir den Code dazu posten ?
              • Glasfaser
                Ja , das sehe ich ..
                lese doch bitte die Kommentare langsam durch , ich habe @Thomas-Braun um Hilfe gebeten !
                  HolgerCW @Glasfaser last edited by Homoran
                  @glasfaser Habe jetzt apt update gemacht und dann kommt das:
                    404  Not Found
                    404  Not Found
                    404  Not Found
                  nodejs:
                    Versionstabelle:
                  • Glasfaser
                    Bitte kein Doppelpost ... eine Ausgabe reicht oben !
                    Und Wichtig bitte keine Befehl quer ausführen ... !
                    Also warten !
                      @glasfaser UNd auch das mit iob nodejs-update. Dann kommt das:
                      root@ioBroker:/opt/iobroker# iob stop
                      iobroker controller daemon is not running
                      root@ioBroker:/opt/iobroker# iob fix
                      root@ioBroker:/opt/iobroker# iob nodejs-update
                      iobroker [command]
                      Commands:
                        iobroker setup                                               Setup ioBroker
                        iobroker start                                               Starts the js-controller
                        iobroker stop                                                stops the js-controller
                        iobroker restart                                             Restarts js-controller
                        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                        iobroker info                                                Shows the host info
                        iobroker logs [<adapter>]                                    Monitor log
                        iobroker add <adapter> [desiredNumber]                       Add instance of adapter
                        iobroker install <adapter>                                   Installs a specified adapter
                        iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
                        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                        iobroker del <adapter>                                       Remove adapter from system
                        iobroker del <adapter>.<instance>                            Remove adapter instance
                        iobroker update [<repositoryUrl>]                            Update repository and list adapters
                        iobroker upgrade                                             Upgrade management
                        iobroker upload                                              Upload management
                        iobroker object                                              Object management
                        iobroker state                                               State management
                        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                        iobroker list <type> [<filter>]                              List all entries, like objects
                        iobroker chmod <mode> <file>                                 Change file rights
                        iobroker chown <user> <group> <file>                         Change file ownership
                        iobroker touch <file>                                        Touch file
                        iobroker rm <file>                                           Remove file
                        iobroker file                                                File management
                        iobroker user                                                User commands
                        iobroker group                                               group management
                        iobroker host <hostname>                                     Set host to given hostname
                        iobroker set <adapter>.<instance>                            Change settings of adapter config
                        iobroker license <license.file or license.text>              Update license by given file
                        iobroker cert                                                Certificate management
                        iobroker clean <yes>                                         Clears all objects and states
                        iobroker backup                                              Create backup
                        iobroker restore <backup name or path>                       Restore a specified backup
                        iobroker validate <backup name or path>                      Validate a specified backup
                        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
                        iobroker repo [<name>]                                       Show repo information
                        iobroker uuid                                                Show uuid of the installation
                        iobroker unsetup                                             Reset license, installation secret and language
                        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                        iobroker multihost                                           Multihost management
                        iobroker compact                                             compact group management
                        iobroker plugin                                              Plugin management
                        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
                      Options:
                            --help     Show help  [boolean]
                        -v, --version  Show version  [boolean]
                      • Glasfaser
                        Nochmal bitte Warten !
                        der Befehl funktioniert nicht in Docker !
                          @glasfaser Achso. Ich soll hier auf eine Antwort warten ? Ich danchte ich hätte was übersehen. Dann bin ich gespannt auf die Antwort.
                          • Glasfaser
                            richtig ...er braucht diese zwei Ausgaben , dann gehts es weiter ... ( oder auch nicht ) !
                            Das Problem ist , das du auf Nodejs 10 bist !
                              @glasfaser Ok, die Ausgabe habe ich ja geliefert, richtig ? Dann warten wir mal ab.
                                Thomas Braun Most Active @HolgerCW last edited by Thomas Braun
                                @holgercw
                                Alles steinalt und die Repos sind natürlich auch abgeräumt worden...
                                Versuch mal in der Datei
                                /etc/apt/sources.list.d/nodesource.list
                                die 10 durch 16 zu ersetzen. Vielleicht lebt wenigstens das noch.
                                Der ganze Mist kommt von dem tollen 'never tatsch a running süstem'. Der Schwachsinn funktioniert nicht.
                                H maloross 2 Replies Last reply Reply Quote 0
                                  Kannst Du mir sage, wo ich den PFad finde:
                                    @holgercw
                                    Nein, kann ich nicht. Von Docker lass ich nämlich die Finger.
                                    • maloross
                                      maloross @Thomas Braun last edited by
                                      Das sollte über die Befehlskonsole funktionieren (Ansicht aus CS 3)
                                        HolgerCW @maloross last edited by
                                        @maloross Das habe ich gemacht und es klappt. Und nun ?
                                          HolgerCW @Thomas Braun last edited by HolgerCW
                                          @thomas-braun Habe da was gefunden. Ich glaube das ist der Pfad von Docker. Nun müsste ich noch geführt werden:
                                          Vielleicht auch hier: S:\container-station-data\lib\docker\overlay2\l\UJDMZLQINEDIUXDWCN6JCCNOKX\opt\iobroker\node_modules ???
                                          maloross 1 Reply Last reply Reply Quote 0
                                          • maloross
                                            maloross @HolgerCW last edited by
                                            @holgercw vorweg: ich verfüge auch nur über Grundlagen-Kenntnisse sowohl QNAP als auch Container-Station.
                                            Wenn du auf der QNAP den Texteditor installiert hast, kannst du dich zu der oben genannten Datei durchhangeln und diese mit dem Texteditor bearbeiten. Ich selbst ändere solche Dinge meist über die Konsole.
                                            4278
