Start aus Backup *gelöst*
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.103-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Kernel : armv7l Userland : armhf Systemuptime and Load: 16:40:22 up 1:46, 1 user, load average: 2.58, 1.95, 1.55 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Sun 2024-01-14 16:40:25 CET Universal time: Sun 2024-01-14 15:40:25 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 7.9G 353M 6.7G 8.0M 812M 7.3G Swap: 99M 0B 99M Total: 8.0G 353M 6.8G 7898 M total memory 352 M used memory 517 M active memory 445 M inactive memory 6732 M free memory 239 M buffer memory 573 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** 0 loaded units listed. Pass --all to see loaded but inactive units, too. To show all installed unit files use 'systemctl list-unit-files'. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 14G 14G 50% / devtmpfs devtmpfs 3.7G 0 3.7G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 3.9G 8.5M 3.9G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 790M 0 790M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sun Jan 14 14:53:45 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [Sun Jan 14 14:53:46 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [Sun Jan 14 14:53:46 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Sun Jan 14 14:53:48 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700 `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 404M /var/ 118M /var/lib 102M /var/cache 90M /var/cache/apt 82M /var/log Archived and active journals take up 8.0M in the file system. /opt/iobroker/backups: 68M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 595M /opt/iobroker/iobroker-data/ 313M /opt/iobroker/iobroker-data/files 144M /opt/iobroker/iobroker-data/backup-objects 94M /opt/iobroker/iobroker-data/sonosCache 67M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map 15M /opt/iobroker/iobroker-data/objects.jsonl 12M /opt/iobroker/iobroker-data/objects.json.migrated USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00 *** NodeJS-Installation *** /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.0-1nodesource1 Version table: *** 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 10.24.0~dfsg-1~deb10u3 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: npm ERR! code ELSPROBLEMS npm ERR! extraneous: @iobroker/socket-classes@1.4.6 /opt/iobroker/node_modules/@iobroker/socket-classes npm ERR! extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver npm ERR! extraneous: @iobroker/ws-server@2.1.2 /opt/iobroker/node_modules/@iobroker/ws-server npm ERR! extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise npm ERR! extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64 npm ERR! extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen npm ERR! extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter npm ERR! extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch npm ERR! extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float npm ERR! extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire npm ERR! extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path npm ERR! extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool npm ERR! extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8 npm ERR! extraneous: @types/long@4.0.2 /opt/iobroker/node_modules/@types/long npm ERR! extraneous: ajv@8.12.0 /opt/iobroker/node_modules/ajv npm ERR! extraneous: archiver-utils@4.0.1 /opt/iobroker/node_modules/archiver-utils npm ERR! extraneous: archiver@6.0.1 /opt/iobroker/node_modules/archiver npm ERR! extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser npm ERR! extraneous: compress-commons@5.0.1 /opt/iobroker/node_modules/compress-commons npm ERR! extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible npm ERR! extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression npm ERR! extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash npm ERR! extraneous: cookie-parser@1.4.6 /opt/iobroker/node_modules/cookie-parser npm ERR! extraneous: cookie@0.4.1 /opt/iobroker/node_modules/cookie npm ERR! extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32 npm ERR! extraneous: crc32-stream@5.0.0 /opt/iobroker/node_modules/crc32-stream npm ERR! extraneous: express-fileupload@1.4.3 /opt/iobroker/node_modules/express-fileupload npm ERR! extraneous: express-session@1.17.3 /opt/iobroker/node_modules/express-session npm ERR! invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin npm ERR! extraneous: iobroker.sonoff@3.0.3 /opt/iobroker/node_modules/iobroker.sonoff npm ERR! extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse npm ERR! extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5 npm ERR! extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream npm ERR! extraneous: long@4.0.0 /opt/iobroker/node_modules/long npm ERR! extraneous: mime@3.0.0 /opt/iobroker/node_modules/mime npm ERR! extraneous: on-headers@1.0.2 /opt/iobroker/node_modules/on-headers npm ERR! extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local npm ERR! extraneous: passport-strategy@1.0.0 /opt/iobroker/node_modules/passport-strategy npm ERR! extraneous: passport@0.6.0 /opt/iobroker/node_modules/passport npm ERR! extraneous: pause@0.0.1 /opt/iobroker/node_modules/pause npm ERR! extraneous: random-bytes@1.0.0 /opt/iobroker/node_modules/random-bytes npm ERR! extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body npm ERR! extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob npm ERR! extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string npm ERR! extraneous: uid-safe@2.1.5 /opt/iobroker/node_modules/uid-safe npm ERR! extraneous: zip-stream@5.0.1 /opt/iobroker/node_modules/zip-stream npm ERR! extraneous: bytes@3.0.0 /opt/iobroker/node_modules/compression/node_modules/bytes npm ERR! extraneous: cookie@0.4.2 /opt/iobroker/node_modules/express-session/node_modules/cookie npm ERR! extraneous: safe-buffer@5.2.1 /opt/iobroker/node_modules/express-session/node_modules/safe-buffer npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/iobroker.admin/node_modules/semver npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/lazystream/node_modules/readable-stream npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/lazystream/node_modules/string_decoder npm ERR! invalid: string_decoder@1.3.0 /opt/iobroker/node_modules/string_decoder npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents npm ERR! invalid: ms@2.0.0 /opt/iobroker/node_modules/ms npm ERR! invalid: protobufjs@ /opt/iobroker/node_modules/protobufjs npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-14T15_40_34_077Z-debug-0.log *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.17 admin: "admin" not found javascript: 7.1.6 npm ERR! code ELSPROBLEMS npm ERR! extraneous: @iobroker/socket-classes@1.4.6 /opt/iobroker/node_modules/@iobroker/socket-classes npm ERR! extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver npm ERR! extraneous: @iobroker/ws-server@2.1.2 /opt/iobroker/node_modules/@iobroker/ws-server npm ERR! extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise npm ERR! extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64 npm ERR! extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen npm ERR! extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter npm ERR! extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch npm ERR! extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float npm ERR! extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire npm ERR! extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path npm ERR! extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool npm ERR! extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8 npm ERR! extraneous: @types/long@4.0.2 /opt/iobroker/node_modules/@types/long npm ERR! extraneous: ajv@8.12.0 /opt/iobroker/node_modules/ajv npm ERR! extraneous: archiver-utils@4.0.1 /opt/iobroker/node_modules/archiver-utils npm ERR! extraneous: archiver@6.0.1 /opt/iobroker/node_modules/archiver npm ERR! extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser npm ERR! extraneous: compress-commons@5.0.1 /opt/iobroker/node_modules/compress-commons npm ERR! extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible npm ERR! extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression npm ERR! extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash npm ERR! extraneous: cookie-parser@1.4.6 /opt/iobroker/node_modules/cookie-parser npm ERR! extraneous: cookie@0.4.1 /opt/iobroker/node_modules/cookie npm ERR! extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32 npm ERR! extraneous: crc32-stream@5.0.0 /opt/iobroker/node_modules/crc32-stream npm ERR! extraneous: express-fileupload@1.4.3 /opt/iobroker/node_modules/express-fileupload npm ERR! extraneous: express-session@1.17.3 /opt/iobroker/node_modules/express-session npm ERR! invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin npm ERR! extraneous: iobroker.sonoff@3.0.3 /opt/iobroker/node_modules/iobroker.sonoff npm ERR! extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse npm ERR! extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5 npm ERR! extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream npm ERR! extraneous: long@4.0.0 /opt/iobroker/node_modules/long npm ERR! extraneous: mime@3.0.0 /opt/iobroker/node_modules/mime npm ERR! extraneous: on-headers@1.0.2 /opt/iobroker/node_modules/on-headers npm ERR! extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local npm ERR! extraneous: passport-strategy@1.0.0 /opt/iobroker/node_modules/passport-strategy npm ERR! extraneous: passport@0.6.0 /opt/iobroker/node_modules/passport npm ERR! extraneous: pause@0.0.1 /opt/iobroker/node_modules/pause npm ERR! extraneous: random-bytes@1.0.0 /opt/iobroker/node_modules/random-bytes npm ERR! extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body npm ERR! extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob npm ERR! extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string npm ERR! extraneous: uid-safe@2.1.5 /opt/iobroker/node_modules/uid-safe npm ERR! extraneous: zip-stream@5.0.1 /opt/iobroker/node_modules/zip-stream npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-14T15_40_54_148Z-debug-0.log Adapters from github: 0 Adapter State system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alexa2.0 : alexa2 : raspberrypi - disabled system.adapter.alias-manager.0 : alias-manager : raspberrypi - disabled system.adapter.awtrix-light.0 : awtrix-light : raspberrypi - disabled + system.adapter.backitup.0 : backitup : raspberrypi - enabled system.adapter.ble.0 : ble : raspberrypi - disabled system.adapter.chromecast.0 : chromecast : raspberrypi - disabled system.adapter.daswetter.0 : daswetter : raspberrypi - disabled system.adapter.devices.0 : devices : raspberrypi - disabled system.adapter.discovery.0 : discovery : raspberrypi - disabled system.adapter.dwd.0 : dwd : raspberrypi - disabled system.adapter.fullybrowser.0 : fullybrowser : raspberrypi - disabled system.adapter.govee.0 : govee : raspberrypi - disabled system.adapter.gruenbeck.0 : gruenbeck : raspberrypi - disabled system.adapter.history.0 : history : raspberrypi - disabled system.adapter.hue.0 : hue : raspberrypi - disabled, port: 443 system.adapter.ical.0 : ical : raspberrypi - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : raspberrypi - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspberrypi - disabled system.adapter.info.0 : info : raspberrypi - disabled system.adapter.iot.0 : iot : raspberrypi - disabled system.adapter.javascript.0 : javascript : raspberrypi - disabled system.adapter.meross.0 : meross : raspberrypi - disabled system.adapter.mielecloudservice.0 : mielecloudservice : raspberrypi - disabled system.adapter.musiccast.0 : musiccast : raspberrypi - disabled system.adapter.net-tools.0 : net-tools : raspberrypi - disabled system.adapter.netatmo.0 : netatmo : raspberrypi - disabled system.adapter.philips-air.0 : philips-air : raspberrypi - disabled system.adapter.philips-air.1 : philips-air : raspberrypi - disabled system.adapter.ping.0 : ping : raspberrypi - disabled system.adapter.pollenflug.0 : pollenflug : raspberrypi - disabled system.adapter.scenes.0 : scenes : raspberrypi - disabled system.adapter.shelly.0 : shelly : raspberrypi - disabled, port: 1882, bind: 0.0.0.0 system.adapter.shuttercontrol.0 : shuttercontrol : raspberrypi - disabled system.adapter.smartcontrol.0 : smartcontrol : raspberrypi - disabled system.adapter.sonoff.0 : sonoff : raspberrypi - disabled, port: 1883, bind: 0.0.0.0 system.adapter.sonos.0 : sonos : raspberrypi - disabled system.adapter.trashschedule.0 : trashschedule : raspberrypi - disabled system.adapter.tuya.0 : tuya : raspberrypi - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : raspberrypi - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - disabled system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi - disabled system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : raspberrypi - disabled system.adapter.vis-metro.0 : vis-metro : raspberrypi - disabled system.adapter.vis-players.0 : vis-players : raspberrypi - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - disabled system.adapter.vis.0 : vis : raspberrypi - disabled system.adapter.weatherunderground.0 : weatherunderground : raspberrypi - disabled system.adapter.web.0 : web : raspberrypi - disabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.zigbee.0 : zigbee : raspberrypi - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00 + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/../node_modules/iobroker.admin/io-package.json: /opt/iobroker/node_modules/iobroker.admin/io-package.json: Unexpected end of JSON input Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/../node_modules/iobroker.admin/io-package.json: /opt/iobroker/node_modules/iobroker.admin/io-package.json: Unexpected end of JSON input Adapter "alexa2" : 3.26.3 , installed 3.26.3 Adapter "alias-manager": 1.2.6 , installed 1.2.6 Adapter "backitup" : 2.9.8 , installed 2.9.8 Adapter "chromecast" : 3.0.3 , installed 3.0.3 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hue" : 3.10.1 , installed 3.10.1 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-mfd-png": 1.2.1 , installed 1.1.0 [Updatable] Adapter "icons-mfd-svg": 1.2.0 , installed 1.1.0 [Updatable] Adapter "javascript" : 7.1.6 , installed 7.1.6 Controller "js-controller": 5.0.17 , installed 5.0.17 Adapter "meross" : 1.17.0 , installed 1.16.1 [Updatable] Adapter "mielecloudservice": 6.5.4, installed 6.5.4 Adapter "netatmo" : 3.1.0 , installed 3.1.0 Adapter "philips-air" : 1.0.3 , installed 1.0.3 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 6.6.1 , installed 6.6.1 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "sonos" : 3.0.0 , installed 3.0.0 Adapter "vis-icontwo" : 1.3.0 , installed 1.0.0 [Updatable] Adapter "weatherunderground": 3.6.0, installed 3.6.0 Adapter "zigbee" : 1.9.7 , installed 1.8.24 [Updatable] Objects and States Please stand by - This may take a while Objects: 11186 States: 8901 *** OS-Repositories and Updates *** Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:2 http://archive.raspberrypi.org/debian buster InRelease Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 16886 641/sshd tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 14852 365/cupsd tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 45899 9623/iobroker.js-co tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 45892 9623/iobroker.js-co tcp6 0 0 :::22 :::* LISTEN 0 16888 641/sshd tcp6 0 0 ::1:631 :::* LISTEN 0 14851 365/cupsd udp 0 0 0.0.0.0:68 0.0.0.0:* 0 17522 631/dhcpcd udp 0 0 0.0.0.0:631 0.0.0.0:* 0 16544 484/cups-browsed udp 0 0 0.0.0.0:42683 0.0.0.0:* 108 16161 372/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 16159 372/avahi-daemon: r udp6 0 0 :::41952 :::* 108 16162 372/avahi-daemon: r udp6 0 0 :::546 :::* 0 16570 631/dhcpcd udp6 0 0 :::5353 :::* 108 16160 372/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-01-14 16:40:45.597 - error: host.raspberrypi Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:122:24) 2024-01-14 16:40:45.597 - error: host.raspberrypi Caught by controller[0]: at node:internal/main/run_main_module:28:49 { 2024-01-14 16:40:45.598 - error: host.raspberrypi Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.admin/package.json' 2024-01-14 16:40:45.598 - error: host.raspberrypi Caught by controller[0]: } 2024-01-14 16:40:45.599 - error: host.raspberrypi Caught by controller[1]: Node.js v18.19.0 2024-01-14 16:40:45.599 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2024-01-14 16:40:45.600 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled 2024-01-14 16:41:15.734 - error: host.raspberrypi startInstance admin.0: Cannot read and parse "/opt/iobroker/node_modules/iobroker.admin/package.json" 2024-01-14 16:41:15.749 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 10027 2024-01-14 16:41:16.203 - error: host.raspberrypi Caught by controller[0]: node:internal/modules/package_json_reader:92 2024-01-14 16:41:16.204 - error: host.raspberrypi Caught by controller[0]: throw error; 2024-01-14 16:41:16.205 - error: host.raspberrypi Caught by controller[0]: ^ 2024-01-14 16:41:16.205 - error: host.raspberrypi Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.admin/package.json: Unexpected end of JSON input 2024-01-14 16:41:16.205 - error: host.raspberrypi Caught by controller[0]: at parse (<anonymous>) 2024-01-14 16:41:16.206 - error: host.raspberrypi Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16) 2024-01-14 16:41:16.206 - error: host.raspberrypi Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10) 2024-01-14 16:41:16.206 - error: host.raspberrypi Caught by controller[0]: at readPackageScope (node:internal/modules/package_json_reader:157:19) 2024-01-14 16:41:16.207 - error: host.raspberrypi Caught by controller[0]: at shouldUseESMLoader (node:internal/modules/run_main:77:15) 2024-01-14 16:41:16.207 - error: host.raspberrypi Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:122:24) 2024-01-14 16:41:16.208 - error: host.raspberrypi Caught by controller[0]: at node:internal/main/run_main_module:28:49 { 2024-01-14 16:41:16.208 - error: host.raspberrypi Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.admin/package.json' 2024-01-14 16:41:16.208 - error: host.raspberrypi Caught by controller[0]: } 2024-01-14 16:41:16.209 - error: host.raspberrypi Caught by controller[0]: Node.js v18.19.0 2024-01-14 16:41:16.209 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2024-01-14 16:41:16.209 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
Mhhhh... werde das dann wohl mal machen müssen...wobei es ja vorher lief... -
@gluecksmann sagte in Start aus Backup:
das heisst nichts.
jetzt ist jetzt.@gluecksmann sagte in Start aus Backup:
nachdem ich heute Vomittag ein Backup über den Backitup Adapter eingespielt habe
wie alt?
welche Grundkonfiguration in dem Backup?
welche jetzt? -
Es läuft immer vorher, bis es eben nicht mehr läuft.
Ich vermute du hast den Back-up-Prozess unterbrochen. Das kann geraume Zeit dauern. -
na da hoffe ich das das Backup nachts "gut" ist.... Suche jetzt mal eine neue Speicherkarte...
Hat jetzt scheinbar geklappt...bin aber das Problem mit Zigbee nicht losgeworden...
2024-01-14 20:12:42.572 - error: zigbee.0 (14059) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
was denn nun schon wieder? Ist doch alles neu und frisch...
Vielleicht gerade deswegen.
wie ist die Konfiguration von der Instanz?
Schau in das LogFile rein und guck was der Adapter da zu melden hat.
Ein CC2531 ist allerdings auch mittlerweile veraltet. Würde ich eh austauschen.
was austauschen? Geht es um den Zigbee Stick? Da hatte ich nach Empfehlungen gefragt..bekam aber keine für mich als DAU User verwertbaren Antworten..
@gluecksmann dein /dev/by-id in der Konfiguration scheint bei der list of ports nicht dabei zu sein.
Du solltest aber doch inzwischen wissen dass logs als Text in code-tags gepostet werden
Ja.
Nimm einen aus dieser Liste:
https://www.zigbee2mqtt.io/guide/adapters/#recommended -
@thomas-braun sagte in Start aus Backup:
iob logs --watch
2024-01-14 20:21:59.992 - error: zigbee.0 (14059) getGroups: caught error: Type Error: Cannot read properties of undefined (reading 'getGroups')
Den ganzen Neustart des Adapters anschauen. Da steht deutlich mehr drin.
Komisch...jetzt funktioniert es... gehe ich Recht in der Annahme, das ich bei einem neuem Zigbee Stick alles neu anlernen muß?
Gibt es da Quellen die man nicht nutzen sollte? Wenn ich mit den Sonoff Stock anschauen kostet der bei Amazon das doppelte wie bei Ali ...
