    • eierfeile
      eierfeile @ticaki last edited by
      @ticaki ich nutze TypeScript v4.3.1.1
      • eierfeile
        eierfeile @Armilar last edited by
        @armilar
        • Nicht das ich wüsste. Wie kann ich das prüfen?
        • Hab das entsprechende Blockly eigentlich deaktiviert. Falls trotzdem irgendwas das Relais ansteuert, hätte ich ein Hinweis in der Console erwartet. Oder is das falsch?
        • Nein, sagt mir ebenfalls nichts.
        08:22:26.173 CMD: status0
        08:22:26.219 MQT: Thermostate/stat/nspanel_FA4E78/STATUS0 = {"Status":{"Module":0,"DeviceName":"Tasmota","FriendlyName":["Tasmota",""],"Topic":"nspanel_FA4E78","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin","RestartReason":"Software reset CPU","Uptime":"0T13:07:41","StartupUTC":"2024-01-12T18:14:45","Sleep":0,"CfgHolder":4617,"BootCount":37,"BCResetTime":"2023-04-07T08:56:11","SaveCount":844},"StatusFWR":{"Version":"13.3.0(nspanel)","BuildDateTime":"2023-12-12T14:31:39","Core":"2_0_14","SDK":"4.4.6.231122","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.0","CR":"456/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["Fritz!repeater",""],"TelePeriod":10,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00800080","00006000","00004000","00000000"]},"StatusMEM":{"ProgramSize":1888,"Free":863,"Heap":131,"StackLowMark":4,"PsrMax":0,"PsrFree":0,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":"DIO","Features":["0809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80B1","00000000"],"Drivers":"1,2,3,4,5,7,8,9,10,11,12,14,16,17,20,21,24,26,27,29,34,35,38,50,52,59,60,62,63,66,67,68,82,86,87,88","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82"},"StatusNET":{"Hostname":"nspanel-FA4E78-3704","IPAddress":"192.168.188.96","Gateway":"192.168.188.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.188.1","DNSServer2":"2a02:6d40:36e7:9701:464e:6dff:feb7:9eee","Mac":"C0:49:EF:FA:4E:78","IP6Global":"2a02:6d40:36e7:9701:c249:efff:fefa:4e78","IP6Local":"fe80::c249:efff:fefa:4e78%st2","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.188.1","DNSServer2":"2a02:6d40:36e7:9701:464e:6dff:feb7:9eee","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":17.0},"StatusMQT":{"MqttHost":"192.168.188.222","MqttPort":1883,"MqttClientMask":"ThermostatKueche","MqttClient":"ThermostatKueche","MqttUser":"mqtt","MqttCount":2,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2024-01-13T07:22:26","Local":"2024-01-13T08:22:26","StartDST":"2024-03-31T02:00:00","EndDST":"2024-10-27T03:00:00","Timezone":"+01:00","Sunrise":"08:40","Sunset":"17:17"},"StatusSNS":{"Time":"2024-01-13T08:22:26","ANALOG":{"Temperature1":20.6},"TempUnit":"C"},"StatusSTS":{"Time":"2024-01-13T08:22:26","Uptime":"0T13:07:41","UptimeSec":47261,"Heap":129,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":16,"Objects":218},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Fritz!repeater","BSSId":"2C:91:AB:E1:FE:EA","Channel":6,"Mode":"11n","RSSI":80,"Signal":-60,"LinkCount":1,"Downtime":"0T00:00:05"}}}
        08:22:29.190 MQT: Thermostate/stat/nspanel_FA4E78/RESULT = {"CustomSend":"Done"}
        08:22:29.246 MQT: Thermostate/stat/nspanel_FA4E78/RESULT = {"CustomSend":"Done"}
        08:22:35.848 MQT: Thermostate/tele/nspanel_FA4E78/STATE = {"Time":"2024-01-13T08:22:35","Uptime":"0T13:07:50","UptimeSec":47270,"Heap":126,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":16,"Objects":218},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Fritz!repeater","BSSId":"2C:91:AB:E1:FE:EA","Channel":6,"Mode":"11n","RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:05"}}
        08:22:35.865 MQT: Thermostate/tele/nspanel_FA4E78/SENSOR = {"Time":"2024-01-13T08:22:35","ANALOG":{"Temperature1":20.5},"TempUnit":"C"}
        08:22:45.846 MQT: Thermostate/tele/nspanel_FA4E78/STATE = {"Time":"2024-01-13T08:22:45","Uptime":"0T13:08:00","UptimeSec":47280,"Heap":133,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":16,"Objects":218},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Fritz!repeater","BSSId":"2C:91:AB:E1:FE:EA","Channel":6,"Mode":"11n","RSSI":80,"Signal":-60,"LinkCount":1,"Downtime":"0T00:00:05"}}
        08:22:45.862 MQT: Thermostate/tele/nspanel_FA4E78/SENSOR = {"Time":"2024-01-13T08:22:45","ANALOG":{"Temperature1":20.5},"TempUnit":"C"}
        08:22:55.846 MQT: Thermostate/tele/nspanel_FA4E78/STATE = {"Time":"2024-01-13T08:22:55","Uptime":"0T13:08:10","UptimeSec":47290,"Heap":133,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":16,"Objects":218},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Fritz!repeater","BSSId":"2C:91:AB:E1:FE:EA","Channel":6,"Mode":"11n","RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:05"}}
        08:22:55.866 MQT: Thermostate/tele/nspanel_FA4E78/SENSOR = {"Time":"2024-01-13T08:22:55","ANALOG":{"Temperature1":20.5},"TempUnit":"C"}
        08:22:59.183 MQT: Thermostate/stat/nspanel_FA4E78/RESULT = {"CustomSend":"Done"}
        08:22:59.295 MQT: Thermostate/stat/nspanel_FA4E78/RESULT = {"CustomSend":"Done"}
        08:22:59.356 MQT: Thermostate/stat/nspanel_FA4E78/RESULT = {"CustomSend":"Done"}
        08:23:05.848 MQT: Thermostate/tele/nspanel_FA4E78/STATE = {"Time":"2024-01-13T08:23:05","Uptime":"0T13:08:20","UptimeSec":47300,"Heap":126,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":16,"Objects":218},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Fritz!repeater","BSSId":"2C:91:AB:E1:FE:EA","Channel":6,"Mode":"11n","RSSI":80,"Signal":-60,"LinkCount":1,"Downtime":"0T00:00:05"}}
        08:23:05.866 MQT: Thermostate/tele/nspanel_FA4E78/SENSOR = {"Time":"2024-01-13T08:23:05","ANALOG":{"Temperature1":20.5},"TempUnit":"C"}
        08:23:15.847 MQT: Thermostate/tele/nspanel_FA4E78/STATE = {"Time":"2024-01-13T08:23:15","Uptime":"0T13:08:30","UptimeSec":47310,"Heap":134,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":16,"Objects":218},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Fritz!repeater","BSSId":"2C:91:AB:E1:FE:EA","Channel":6,"Mode":"11n","RSSI":80,"Signal":-60,"LinkCount":1,"Downtime":"0T00:00:05"}}
        08:23:15.859 MQT: Thermostate/tele/nspanel_FA4E78/SENSOR = {"Time":"2024-01-13T08:23:15","ANALOG":{"Temperature1":20.5},"TempUnit":"C"}
        08:25:12.863 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 41, Pld -99, Data 'statusUpdate~梅20.5°~64332~~17299~~~'
        08:25:12.897 NXP: payload sent = bytes('55BB29007374617475735570646174657EEFA98432302E35C2B07E3634333332...')
        08:25:12.903 MQT: Thermostate/stat/nspanel_FA4E78/RESULT = {"CustomSend":"Done"}
        08:25:13.104 HTP: Command
        08:25:13.111 SRC: WebCommand from 0.0.0.0
        08:25:13.113 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 4, Pld 1, Data 'true'
        08:25:13.125 MQT: Thermostate/stat/nspanel_FA4E78/RESULT = {"POWER1":"ON"}
        08:25:13.128 MQT: Thermostate/stat/nspanel_FA4E78/POWER1 = ON
        08:25:13.719 CFG: Saved, Count 846, Bytes 4096
        08:25:15.847 MQT: Thermostate/tele/nspanel_FA4E78/STATE = {"Time":"2024-01-13T08:25:15","Uptime":"0T13:10:30","UptimeSec":47430,"Heap":129,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":16,"Objects":218},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Fritz!repeater","BSSId":"2C:91:AB:E1:FE:EA","Channel":6,"Mode":"11n","RSSI":78,"Signal":-61,"LinkCount":1,"Downtime":"0T00:00:05"}}
        08:25:15.858 MQT: Thermostate/tele/nspanel_FA4E78/SENSOR = {"Time":"2024-01-13T08:25:15","ANALOG":{"Temperature1":20.5},"TempUnit":"C"}
        08:25:25.848 MQT: Thermostate/tele/nspanel_FA4E78/STATE = {"Time":"2024-01-13T08:25:25","Uptime":"0T13:10:40","UptimeSec":47440,"Heap":134,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":16,"Objects":218},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Fritz!repeater","BSSId":"2C:91:AB:E1:FE:EA","Channel":6,"Mode":"11n","RSSI":80,"Signal":-60,"LinkCount":1,"Downtime":"0T00:00:05"}}
        08:25:25.863 MQT: Thermostate/tele/nspanel_FA4E78/SENSOR = {"Time":"2024-01-13T08:25:25","ANALOG":{"Temperature1":20.6},"TempUnit":"C"}
        08:25:25.953 HTP: Command
        08:25:25.959 SRC: WebCommand from 0.0.0.0
        08:25:25.961 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 5, Pld 0, Data 'false'
        08:25:25.974 MQT: Thermostate/stat/nspanel_FA4E78/RESULT = {"POWER1":"OFF"}
        08:25:25.980 MQT: Thermostate/stat/nspanel_FA4E78/POWER1 = OFF
        08:25:26.041 SRC: MQTT
        und hier das Blockly
        v7.1.6
        BlocklyJavascriptTypeScriptRules
        Skript läuft nicht
        08:27:26.697	info	javascript.0 (243) Stop script script.js.NSPanels.cardTherm
        Ausgewählte Blöcke exportieren
          <block type="on_ext" id="f5Bid}p|/9GT(RD6+VvN" x="12" y="63">
            <value name="OID0">
              <shadow type="field_oid" id="`r{2K%U)7zl).bayEI~^">
                <field name="oid">alias.0.NSPanel.1.Sensor.ANALOG.Temperature.ACTUAL</field>
              <block type="field_oid" id="U:J`M6C4H1J{*Q~bTz3y">
                <field name="oid">alias.0.NSPanels.Thermostat_Kueche.ACTUAL</field>
              <block type="controls_if" id="X2LSI}+Zi#M|IV$#WL@)">
                  <block type="logic_compare" id="M_JR1J!hC6l{=7#)}t;o">
                    <field name="OP">LT</field>
                      <block type="math_arithmetic" id="SSzhQfC0#lj$jKI`rAL2">
                        <field name="OP">ADD</field>
                          <shadow type="math_number" id="Cnu[3+X8C-i4aI$f[LLZ">
                            <field name="NUM">1</field>
                          <block type="get_value" id="s.Y#A[ZI%3V6pQ|$D~2(">
                            <field name="OID">alias.0.NSPanels.Thermostat_Kueche.SET</field>
                          <shadow type="math_number" id=";4Bs+8_Bf_~s5BGTL2Zm">
                          <block type="math_number" id="FW,V;B.:ZT`12]|[R69}">
                      <block type="get_value" id="9FRly,]ESm(#7Ahr9$Oq">
                        <field name="OID">alias.0.NSPanels.Thermostat_Kueche.ACTUAL</field>
                  <block type="control" id="ZBrHe-!=-7{XHEgZ[kKP">
                    <field name="OID">alias.0.NSPanels.Thermostat_Kueche.POWER</field>
                      <block type="logic_boolean" id="$!/V_Bz[$]FKapjGf7j#">
                <statement name="ELSE">
                  <block type="control" id="7O!kH0aC)ojZQ27T:i~3">
                      <block type="logic_boolean" id="^]R@F(rwWETa1P_SMi:W">
            <value name="OID0">
        eierfeile 1 Reply Last reply Reply Quote 0
        • eierfeile
          eierfeile @eierfeile last edited by
          @eierfeile hm, hab gerade gesehen, dass das Blockly wieder aktiv war. Hab es deaktiviert, jetzt schaltet es sich zumindest nicht mehr von alleine aus. Gestern ist das aber trotz deaktviertem Blockly passiert. Hm muss mir das heute abend nochmal anschauen. Muss jetzt leider los.
          • Armilar
            Armilar Most Active Forum Testing @eierfeile last edited by Armilar
            @eierfeile
            Status0 ist okay... ggfs. mal:
            • die TelePeriod von 10 nach z.B. 60 erhöhen
            • die ESP-Temp mit SetOption146 1 aktivieren
            • ggfs. (Tasmota) Friendly Name 2 ebenfalls setzen
            Das Blockly kann ich nicht importieren. Kommt bei mir:
            Ggfs mal als Bild senden... und/oder den JS-Code hier posten... c2d62bc8-8124-40be-8a04-0f0ed3f3b8bd-image.png
            Wenn es sporadisch ist, dann bitte den ioBroker einmal durchstarten. Scripte können auch mal im Hintergrund weiterlaufen, obwohl alles korrekt angezeigt wird.
            Auch mal prüfen, ob ein ggfs. weiteres Script einen Trigger auf das Relais hat.
            Ja ist falsch. Das Log füllt sich ja nur, wenn du den Debug Baustein im Blockly verwendest oder im NSPanelTs.ts Debug = true einstellst. Da das aber ein separater Trigger auf einem Datenpunkt (also eine Schnittstelle) im NSPanel-Verzeichnis ist, wird der nur protokollieren, dass der Trigger ausgelöst hat, aber nicht, welches Blockly das verursacht hat...
            in dem du PulseTime in der Tasmota Konsole eingibst:
            12:00:02.443 CMD: PulseTime
            12:00:02.456 MQT: SmartHome/NSPanel_1/stat/RESULT = {"PulseTime":{"Set":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"Remaining":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]}}
              ticaki @Armilar last edited by
              @armilar
              Das Debug im Skript wird von dem Debug im Datenpunkt überschrieben.
                Kugelblitz last edited by
                auch wenn es nicht ganz zu eurer Diskussion passt, möchte ich doch an dieser Stelle mal fragen wie man Lovelace UI wieder deinstalliert bekommt.
                Ich habe viel damit experimentiert, kam aber auch aufgrund fehlender Zeit zu keinem zufriedenstellenden Ergebnis. Jetzt möchte ich das NS Panel gerne erst mal wieder nur mit Tasmota, ohne Lovelace UI betreiben. Wie komme ich da wieder hin?
                Und wenn ich schon dabei bin zu fragen, je nachdem würde ich das Panel auch wieder verkaufen wollen, gibt es eine Möglichkeit die Sonoff Stock FW wieder drauf zu flashen bzw wo bekomme ich die her ohne ein Backup?
                Danke für eure Hilfe.
                  eMd @Kugelblitz last edited by
                  @kugelblitz Ist das panel weiß? Vielleicht kauft das hier auch jemand ab und freut sich das es nicht stock ist 😉
                    Kugelblitz @eMd last edited by
                    @emd Nein, es ist schwarz.
                    Armilar 1 Reply Last reply Reply Quote 1
                    • Armilar
                      Armilar Most Active Forum Testing @Kugelblitz last edited by
                      Update v4.3.3.36
                      Wenn aktuelle Version ab v4.3.3.30, dann unteren Teil des NSPanelTs.ts ab:
                      // ________________ DE: Ab hier keine Konfiguration mehr _______________
                      austauschen
                      https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs.ts
                      Wenn aktuelle Version bis v4.3.3.29, dann Updateaneitung befolgen:
                      https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Starthilfe-FAQ#hilfe-bei-update--upgrade
                      VG
                      @ticaki , @TT-Tom & @Armilar 😊
                      • theknut
                        theknut last edited by
                        ich kann bei mir reproduzierbar das Panel aufhängen indem ich folgendes mache:
                        setState(panelId + ".popupNotify.popupNotifyHeading", '');
                        setState(panelId + ".popupNotify.popupNotifyText", '');
                        Äußern tut sich das bei mir insofern, dass ich nach dem Bestätigen ein Clear von Heading und Text mache, weil ich das dann wieder schön aufgeräumt haben will^^
                        Getestet mit V4.3.3.30
                        • Armilar
                          Armilar Most Active Forum Testing @theknut last edited by Armilar
                          @theknut
                          hehe 😉 - der Leerzeichen Monk
                          Dann weiß du ja auch, dass du in den popupNotifyText kein '' bis zur nächsten Erweiterung schreiben solltest.
                          Oder halt nochmal "OK" drücken. Das Icon und den Button könntest du ja auch noch löschen 😁
                          Können da eine Erweiterung einbauen, dass wenn Heading und Text leer sind, kein Popup initiiert wird.
                          Armilar 1 Reply Last reply Reply Quote 2
                          • Armilar
                            Armilar Most Active Forum Testing @Armilar last edited by Armilar
                            @theknut
                            Kannst die v4.3.3.37 Version aus dem DEV nutzen:
                            https://github.com/joBr99/nspanel-lovelace-ui/blob/e94c711f123c3f0ecfed075f3bd9143df61c6890/ioBroker/DEV/NSPanelTs.ts
                            Damit kannst du die Texte aus dem popupNotify wieder bereinigen 😊
                            Ist dann in den kommenden Versionen ebenfalls enthalten...
                            theknut 1 Reply Last reply Reply Quote 1
                            • theknut
                              theknut @Armilar last edited by
                              @armilar Passt, ich danke dir!
                              • Marko1974
                                Marko1974 @ompi last edited by Marko1974
                                @ompi @TT-Tom
                                Also ich komme mit dem Abfallkalender nicht weiter.
                                Hab alles den in google als separaten Kalender.
                                Dann folgende Settings im trashschedule
                                Habe dann das bereitgestellte Blockly genommen, welches die Datenpunkte in userdata0 und die alias anlegt
                                und auch dieses probiert.
                                Hier kommts dann zu dem ersten Fehler. Da gehts es wahrscheinlich aber auch nur um Color, oder?
                                javascript.0
                                	2024-01-15 22:22:58.748	info	State value to set for "0_userdata.0.Abfallkalender.4.color" has to be type "number" but received type "object"
                                javascript.0
                                	2024-01-15 22:22:58.748	info	State value to set for "0_userdata.0.Abfallkalender.3.color" has to be type "number" but received type "object"
                                javascript.0
                                	2024-01-15 22:22:58.747	info	State value to set for "0_userdata.0.Abfallkalender.2.color" has to be type "number" but received type "object"
                                javascript.0
                                	2024-01-15 22:22:58.746	info	State value to set for "0_userdata.0.Abfallkalender.1.color" has to be type "number" but received type "object"
                                javascript.0
                                	2024-01-15 22:22:58.739	info	script.js.common.Abfallkalender: Daten vom ical Adapter werden ausgewertet
                                javascript.0
                                	2024-01-15 22:22:58.738	info	script.js.common.Abfallkalender: Daten vom ical Adapter werden ausgewertet
                                javascript.0
                                javascript.0
                                javascript.0
                                	2024-01-15 22:22:58.737	info	script.js.common.Abfallkalender: Daten vom ical Adapter werden ausgewertet
                                Des weiteren setzt er die dann als alias auch falsch.
                                • BananaJoe
                                  gelöscht - Thema verfehlt
                                    TT-Tom @Marko1974 last edited by TT-Tom
                                    @marko1974
                                    du kannst das Script aus meinem Github nehmen. Es legt dir alle Datenpunkte in 0_userdata und alias an und greift die Daten von iCal Adapter ab.
                                    Mit dem "Debug-Modus" bekommst du vom Script mehr informationen zu den Fehlern bei den Daten. Einfach die Konstante "debug" im Script auf true setzen.
                                    const debug= true;
                                    Der link zu meinem Github
                                    PS: das Blockly muss ich mal prüfen.
                                    Marko1974 1 Reply Last reply Reply Quote 0
                                    • Marko1974
                                      Marko1974 @TT-Tom last edited by
                                      @tt-tom Hi! Es ist ja sogar Dein Script 🙂 ...da haut er mit bei color immer das Ack:false rein
                                        @marko1974
                                        das Blockly ist nicht vom mir. Hast du das Script von Github neu aufgesetzt.
                                        • Marko1974
                                          @tt-tom ja ich habe nun NUR Dein script genommen
                                            @marko1974
                                            okay dann setze bitte im Script mal debug auf true.
                                            zeige mal den Config vom Script.
                                            lovelace ui nspanel sonoff
                                            271
                                            7725
                                            6651539
