[gelöst] js-adapter startet immer wieder neu
@fhainz sagte in js-controller startet immer wieder neu:
Ist ja im Beitrag dabei? Klick mal auf iob.txtach was!
und wie bekomme ich das am Handy auf? -
@homoran Ok, dann versuche ich es in mehreren Beiträgen aufzuteilen.
Teil 1
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: iobroker Icon name: computer-vm Chassis: vm Virtualization: oracle Operating System: Ubuntu 22.04.3 LTS Kernel: Linux 5.15.0-91-generic Architecture: x86-64 Hardware Vendor: innotek GmbH Hardware Model: VirtualBox model name : Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz Docker : false Virtualization : oracle Kernel : x86_64 Userland : amd64 Systemuptime and Load: 09:54:08 up 19 min, 2 users, load average: 0.65, 0.59, 0.42 CPU threads: 2 *** Time and Time Zones *** Local time: Mon 2024-01-15 09:54:08 UTC Universal time: Mon 2024-01-15 09:54:08 UTC RTC time: Mon 2024-01-15 09:54:09 Time zone: Etc/UTC (UTC, +0000) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** fabian /home/fabian fabian adm cdrom sudo dip plugdev lxd iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 7.9G 1.8G 5.2G 1.0M 1.0G 5.9G Swap: 0B 0B 0B Total: 7.9G 1.8G 5.2G 7938 M total memory 1755 M used memory 482 M active memory 2008 M inactive memory 5150 M free memory 118 M buffer memory 914 M swap cache 0 M total swap 0 M used swap 0 M free swap *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 794M 1.2M 793M 1% /run /dev/mapper/ubuntu--vg-ubuntu--lv ext4 18G 16G 1.4G 93% / tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock /dev/sda2 ext4 1.8G 252M 1.4G 16% /boot tmpfs tmpfs 794M 4.0K 794M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Mon Jan 15 09:34:19 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [Mon Jan 15 09:34:19 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none. [Mon Jan 15 09:34:20 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/ubuntu--vg-ubuntu--lv ext4 rw,relatime |-/snap/snapd/20671 /dev/loop0 squashfs ro,nodev,relatime,errors=continue |-/snap/snapd/20290 /dev/loop1 squashfs ro,nodev,relatime,errors=continue |-/snap/core20/2015 /dev/loop2 squashfs ro,nodev,relatime,errors=continue |-/snap/lxd/24322 /dev/loop4 squashfs ro,nodev,relatime,errors=continue |-/snap/core20/2105 /dev/loop3 squashfs ro,nodev,relatime,errors=continue `-/boot /dev/sda2 ext4 rw,relatime Files in neuralgic directories: /var: 8.6G /var/ 7.2G /var/lib 6.5G /var/lib/influxdb/engine/data 6.5G /var/lib/influxdb/engine 6.5G /var/lib/influxdb Archived and active journals take up 808.3M in the file system. /opt/iobroker/backups: 4.0K /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.1G /opt/iobroker/iobroker-data/ 650M /opt/iobroker/iobroker-data/files 200M /opt/iobroker/iobroker-data/history 190M /opt/iobroker/iobroker-data/backup-objects 166M /opt/iobroker/iobroker-data/files/vis-2 The five largest files in iobroker-data are: 27M /opt/iobroker/iobroker-data/states.jsonl 24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map 24M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map 23M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map 22M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03188557-if00-port0 /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A907AG4V-if00-port0 *** NodeJS-Installation *** /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.0-1nodesource1 Version table: *** 18.19.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 12.22.9~dfsg-1ubuntu3.3 500 500 http://at.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages 500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages 12.22.9~dfsg-1ubuntu3 500 500 http://at.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: npm ERR! code ELSPROBLEMS npm ERR! extraneous: @types/caseless@0.12.4 /opt/iobroker/node_modules/@types/caseless npm ERR! extraneous: @types/request@2.48.11 /opt/iobroker/node_modules/@types/request npm ERR! extraneous: @types/tough-cookie@4.0.4 /opt/iobroker/node_modules/@types/tough-cookie npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2 npm ERR! extraneous: typescript@5.2.2 /opt/iobroker/node_modules/typescript npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data npm ERR! extraneous: @aashutoshrathi/word-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@aashutoshrathi/word-wrap npm ERR! extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak npm ERR! extraneous: @alcalzone/release-script-core@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-core npm ERR! extraneous: @alcalzone/release-script-plugin-changelog@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-changelog npm ERR! extraneous: @alcalzone/release-script-plugin-exec@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-exec npm ERR! extraneous: @alcalzone/release-script-plugin-git@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-git npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker npm ERR! extraneous: @alcalzone/release-script-plugin-license@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-license npm ERR! extraneous: @alcalzone/release-script-plugin-package@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-package npm ERR! extraneous: @alcalzone/release-script-plugin-version@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-version npm ERR! extraneous: @alcalzone/release-script@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script npm ERR! extraneous: @eslint-community/eslint-utils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/eslint-utils npm ERR! extraneous: @eslint-community/regexpp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/regexpp npm ERR! extraneous: @eslint/eslintrc@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/eslintrc npm ERR! extraneous: @eslint/js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/js npm ERR! extraneous: @humanwhocodes/config-array@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/config-array npm ERR! extraneous: @humanwhocodes/module-importer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/module-importer npm ERR! extraneous: @humanwhocodes/object-schema@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/object-schema npm ERR! extraneous: @iobroker/dev-server@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server npm ERR! extraneous: @iobroker/testing@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/testing npm ERR! extraneous: @nodelib/fs.scandir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.scandir npm ERR! extraneous: @nodelib/fs.stat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat npm ERR! extraneous: @nodelib/fs.walk@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.walk npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/commons npm ERR! extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers npm ERR! extraneous: @sinonjs/samsam@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/samsam npm ERR! extraneous: @sinonjs/text-encoding@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/text-encoding npm ERR! extraneous: @socket.io/component-emitter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@socket.io/component-emitter npm ERR! extraneous: @types/cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cookie npm ERR! extraneous: @types/cors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cors npm ERR! extraneous: @types/expect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/expect npm ERR! extraneous: @types/http-proxy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/http-proxy npm ERR! extraneous: @types/iobroker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker npm ERR! invalid: @types/node@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node npm ERR! extraneous: @types/vinyl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/vinyl npm ERR! extraneous: @ungap/structured-clone@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@ungap/structured-clone npm ERR! extraneous: abbrev@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/abbrev npm ERR! extraneous: accepts@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/accepts npm ERR! extraneous: acorn-globals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals npm ERR! extraneous: acorn-jsx@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-jsx npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/alcalzone-shared npm ERR! extraneous: ansi-align@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-align npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-colors npm ERR! extraneous: ansi-gray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-gray npm ERR! extraneous: ansi-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-regex npm ERR! extraneous: ansi-styles@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-styles npm ERR! extraneous: ansi-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-wrap npm ERR! extraneous: anymatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch npm ERR! extraneous: append-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/append-buffer npm ERR! extraneous: archy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/archy npm ERR! extraneous: argparse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse npm ERR! extraneous: arr-diff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-diff npm ERR! extraneous: arr-filter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-filter npm ERR! extraneous: arr-flatten@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-flatten npm ERR! extraneous: arr-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-map npm ERR! extraneous: arr-union@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-union npm ERR! extraneous: array-each@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-each npm ERR! extraneous: array-flatten@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-flatten npm ERR! extraneous: array-initial@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial npm ERR! extraneous: array-last@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last npm ERR! extraneous: array-slice@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-slice npm ERR! extraneous: array-sort@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-sort npm ERR! extraneous: array-unique@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-unique npm ERR! extraneous: asn1@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1 npm ERR! extraneous: assert-plus@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus npm ERR! extraneous: assertion-error@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/assertion-error npm ERR! extraneous: assign-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/assign-symbols npm ERR! extraneous: astral-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/astral-regex npm ERR! extraneous: async-done@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-done npm ERR! extraneous: async-each-series@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each-series npm ERR! extraneous: async-each@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each npm ERR! extraneous: async-settle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-settle npm ERR! extraneous: async@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async npm ERR! extraneous: atob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/atob npm ERR! extraneous: aws-sign2@0.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2 npm ERR! extraneous: aws4@1.12.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4 npm ERR! invalid: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/axios npm ERR! extraneous: bach@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bach npm ERR! extraneous: balanced-match@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match npm ERR! extraneous: base@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base npm ERR! extraneous: base64id@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base64id npm ERR! extraneous: batch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/batch npm ERR! extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/binary-extensions npm ERR! extraneous: binaryextensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/binaryextensions npm ERR! extraneous: bindings@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bindings npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser npm ERR! extraneous: boxen@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/boxen npm ERR! extraneous: brace-expansion@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/braces npm ERR! extraneous: browser-request@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-request npm ERR! extraneous: browser-stdout@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-stdout npm ERR! extraneous: browser-sync-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-client npm ERR! extraneous: browser-sync-ui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-ui npm ERR! extraneous: browser-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync npm ERR! extraneous: bs-html-injector@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector npm ERR! extraneous: bs-recipes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-recipes npm ERR! extraneous: buffer-equal@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-equal npm ERR! extraneous: buffer-from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-from npm ERR! extraneous: bytes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bytes npm ERR! extraneous: cache-base@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cache-base npm ERR! extraneous: call-bind@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind npm ERR! extraneous: callsites@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/callsites npm ERR! extraneous: camelcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/camelcase npm ERR! extraneous: caseless@0.12.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless npm ERR! extraneous: chai-as-promised@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai-as-promised npm ERR! extraneous: chai@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai npm ERR! extraneous: chalk@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chalk npm ERR! extraneous: check-error@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/check-error npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar npm ERR! extraneous: class-utils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils npm ERR! extraneous: cli-boxes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cli-boxes npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cliui npm ERR! extraneous: clone-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-buffer npm ERR! extraneous: clone-stats@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-stats npm ERR! extraneous: clone@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone npm ERR! extraneous: cloneable-readable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cloneable-readable npm ERR! extraneous: code-point-at@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/code-point-at npm ERR! invalid: coffeescript@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript npm ERR! extraneous: collection-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-map npm ERR! extraneous: collection-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-visit npm ERR! extraneous: color-convert@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-convert npm ERR! extraneous: color-name@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-name npm ERR! extraneous: color-support@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-support npm ERR! extraneous: colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/colors npm ERR! extraneous: commander@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/commander npm ERR! extraneous: component-emitter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/component-emitter npm ERR! extraneous: concat-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map npm ERR! extraneous: concat-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-stream npm ERR! extraneous: connect-history-api-fallback@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect-history-api-fallback npm ERR! extraneous: connect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect npm ERR! extraneous: content-disposition@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition npm ERR! extraneous: content-type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-type npm ERR! extraneous: convert-source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/convert-source-map npm ERR! extraneous: cookie-signature@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie-signature npm ERR! extraneous: cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie npm ERR! extraneous: copy-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-descriptor npm ERR! extraneous: copy-props@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props npm ERR! extraneous: core-util-is@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is npm ERR! extraneous: cors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cors npm ERR! extraneous: cron-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser npm ERR! extraneous: cross-spawn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cross-spawn npm ERR! extraneous: cssom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssom npm ERR! extraneous: cssstyle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssstyle npm ERR! extraneous: d@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/d npm ERR! extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/debug npm ERR! extraneous: decamelize@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/decamelize npm ERR! extraneous: decode-uri-component@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component npm ERR! extraneous: deep-eql@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-eql npm ERR! extraneous: deep-is@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-is npm ERR! extraneous: default-compare@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-compare npm ERR! extraneous: default-resolution@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-resolution npm ERR! extraneous: define-data-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-data-property npm ERR! extraneous: define-properties@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-property npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/depd npm ERR! extraneous: destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/destroy npm ERR! extraneous: detect-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/detect-file npm ERR! extraneous: dev-ip@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dev-ip npm ERR! extraneous: diff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/diff npm ERR! extraneous: doctrine@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/doctrine npm ERR! extraneous: dom-compare-temp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-compare-temp npm ERR! extraneous: dom-serializer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer npm ERR! extraneous: domelementtype@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype npm ERR! extraneous: domhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler npm ERR! extraneous: domutils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils npm ERR! extraneous: duplexer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer npm ERR! extraneous: duplexify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexify npm ERR! extraneous: each-props@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props npm ERR! extraneous: easy-extender@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/easy-extender npm ERR! extraneous: eazy-logger@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eazy-logger npm ERR! extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn npm ERR! extraneous: ee-first@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ee-first npm ERR! extraneous: emoji-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/emoji-regex npm ERR! extraneous: encodeurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/encodeurl npm ERR! extraneous: end-of-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-client npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-parser npm ERR! extraneous: engine.io@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io npm ERR! extraneous: enquirer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/enquirer npm ERR! extraneous: entities@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/entities npm ERR! extraneous: error-ex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/error-ex npm ERR! extraneous: es5-ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es5-ext npm ERR! extraneous: es6-iterator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-iterator npm ERR! extraneous: es6-symbol@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-symbol npm ERR! extraneous: es6-weak-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-weak-map npm ERR! extraneous: escalade@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escalade npm ERR! extraneous: escape-html@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-html npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-string-regexp npm ERR! extraneous: escodegen@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen npm ERR! extraneous: eslint-scope@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-scope npm ERR! extraneous: eslint-visitor-keys@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-visitor-keys npm ERR! extraneous: eslint@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint npm ERR! extraneous: espree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/espree npm ERR! extraneous: esprima@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esprima npm ERR! extraneous: esquery@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esquery npm ERR! extraneous: esrecurse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esrecurse npm ERR! extraneous: estraverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/estraverse npm ERR! extraneous: esutils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esutils npm ERR! extraneous: etag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/etag npm ERR! extraneous: event-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/event-stream npm ERR! extraneous: eventemitter3@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eventemitter3 npm ERR! extraneous: execa@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/execa npm ERR! extraneous: expand-brackets@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets npm ERR! extraneous: expand-tilde@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-tilde npm ERR! extraneous: express@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express npm ERR! extraneous: ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend-shallow npm ERR! extraneous: extend@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend npm ERR! extraneous: extglob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob npm ERR! extraneous: extsprintf@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf npm ERR! extraneous: fancy-log@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fancy-log npm ERR! extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal npm ERR! extraneous: fast-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob npm ERR! extraneous: fast-json-stable-stringify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify npm ERR! extraneous: fast-levenshtein@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-levenshtein npm ERR! extraneous: fastq@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fastq npm ERR! extraneous: file-entry-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-entry-cache npm ERR! extraneous: file-uri-to-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-uri-to-path npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fill-range npm ERR! extraneous: finalhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler npm ERR! extraneous: find-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/find-up npm ERR! extraneous: findup-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync npm ERR! extraneous: fined@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined npm ERR! extraneous: flagged-respawn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flagged-respawn npm ERR! extraneous: flat-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat-cache npm ERR! extraneous: flat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat npm ERR! extraneous: flatted@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flatted npm ERR! extraneous: flush-write-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flush-write-stream npm ERR! extraneous: follow-redirects@1.15.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/follow-redirects npm ERR! extraneous: for-in@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-in npm ERR! extraneous: for-own@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-own npm ERR! extraneous: forever-agent@0.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent npm ERR! extraneous: forwarded@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/forwarded npm ERR! extraneous: fragment-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fragment-cache npm ERR! extraneous: fresh@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fresh npm ERR! extraneous: from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/from npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-extra npm ERR! extraneous: fs-mkdirp-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-mkdirp-stream npm ERR! extraneous: fs.realpath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs.realpath npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fsevents npm ERR! extraneous: function-bind@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind npm ERR! extraneous: get-caller-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-caller-file npm ERR! extraneous: get-func-name@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-func-name npm ERR! extraneous: get-intrinsic@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic npm ERR! extraneous: get-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-stream npm ERR! extraneous: get-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-value npm ERR! extraneous: getpass@0.1.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-parent npm ERR! extraneous: glob-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream npm ERR! extraneous: glob-watcher@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher npm ERR! extraneous: glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob npm ERR! extraneous: global-modules@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-modules npm ERR! extraneous: global-prefix@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix npm ERR! extraneous: globals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globals npm ERR! extraneous: globalyzer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globalyzer npm ERR! extraneous: globrex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globrex npm ERR! extraneous: glogg@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glogg npm ERR! extraneous: gopd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gopd npm ERR! extraneous: graceful-fs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs npm ERR! extraneous: graphemer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/graphemer npm ERR! extraneous: gulp-cli@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli npm ERR! extraneous: gulp-rename@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-rename npm ERR! extraneous: gulp-replace@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace npm ERR! extraneous: gulp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp npm ERR! extraneous: gulplog@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulplog npm ERR! extraneous: har-schema@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema npm ERR! extraneous: har-validator@5.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator npm ERR! extraneous: has-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-flag npm ERR! extraneous: has-property-descriptors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors npm ERR! extraneous: has-proto@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-proto npm ERR! extraneous: has-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols npm ERR! extraneous: has-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-value npm ERR! extraneous: has-values@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values npm ERR! extraneous: hasown@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/hasown npm ERR! extraneous: he@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/he npm ERR! extraneous: homedir-polyfill@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/homedir-polyfill npm ERR! extraneous: hosted-git-info@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/hosted-git-info npm ERR! extraneous: htmlparser2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2 npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-errors npm ERR! extraneous: http-proxy-middleware@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy-middleware npm ERR! extraneous: http-proxy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy npm ERR! extraneous: http-signature@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature npm ERR! extraneous: human-signals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/human-signals npm ERR! extraneous: iconv-lite@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/iconv-lite npm ERR! extraneous: ignore-by-default@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore-by-default npm ERR! extraneous: ignore@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore npm ERR! extraneous: immediate@3.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate npm ERR! extraneous: immutable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/immutable npm ERR! extraneous: import-fresh@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/import-fresh npm ERR! extraneous: imurmurhash@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/imurmurhash npm ERR! extraneous: inflight@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/inflight npm ERR! extraneous: inherits@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits npm ERR! extraneous: ini@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ini npm ERR! extraneous: interpret@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/interpret npm ERR! extraneous: invert-kv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/invert-kv npm ERR! extraneous: ipaddr.js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ipaddr.js npm ERR! extraneous: is-absolute@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-absolute npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor npm ERR! extraneous: is-arrayish@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-arrayish npm ERR! extraneous: is-binary-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-binary-path npm ERR! extraneous: is-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-buffer npm ERR! extraneous: is-core-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-core-module npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable npm ERR! extraneous: is-extglob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extglob npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-fullwidth-code-point npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-glob npm ERR! extraneous: is-negated-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-negated-glob npm ERR! extraneous: is-number-like@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number-like npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number npm ERR! extraneous: is-path-inside@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-path-inside npm ERR! extraneous: is-plain-obj@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-obj npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-object npm ERR! extraneous: is-relative@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-relative npm ERR! extraneous: is-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-stream npm ERR! extraneous: is-typedarray@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray npm ERR! extraneous: is-unc-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unc-path npm ERR! extraneous: is-unicode-supported@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unicode-supported npm ERR! extraneous: is-utf8@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-utf8 npm ERR! extraneous: is-valid-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-valid-glob npm ERR! extraneous: is-windows@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-windows npm ERR! extraneous: is-wsl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-wsl npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray npm ERR! extraneous: isexe@ npm ERR! A complete log of this run can be found in: /home/fabian/.npm/_logs/2024-01-15T09_54_11_756Z-debug-0.log
so geht es noch einige zeilen weiter...
nach dem npm ERR! ... kommt noch das:
*** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.17 admin: 6.12.0 javascript: 7.1.6 Adapters from github: 2 Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alexa2.0 : alexa2 : iobroker - disabled system.adapter.alias-manager.0 : alias-manager : iobroker - enabled system.adapter.awattar.0 : awattar : iobroker - enabled + system.adapter.backitup.0 : backitup : iobroker - enabled system.adapter.discovery.0 : discovery : iobroker - disabled system.adapter.fronius-solarweb.0 : fronius-solarweb : iobroker - disabled + system.adapter.fronius.0 : fronius : iobroker - enabled + system.adapter.govee-local.0 : govee-local : iobroker - enabled system.adapter.govee.0 : govee : iobroker - disabled system.adapter.history.0 : history : iobroker - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - enabled + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 system.adapter.jarvis.0 : jarvis : iobroker - disabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.javascript.0 : javascript : iobroker - enabled system.adapter.linkeddevices.0 : linkeddevices : iobroker - disabled system.adapter.lovelace.0 : lovelace : iobroker - disabled, port: 8091, bind: 0.0.0.0, run as: admin system.adapter.mobile.0 : mobile : iobroker - disabled + system.adapter.modbus.0 : modbus : iobroker - enabled + system.adapter.modbus.1 : modbus : iobroker - enabled + system.adapter.modbus.2 : modbus : iobroker - enabled + system.adapter.modbus.3 : modbus : iobroker - enabled + system.adapter.mqtt-client.0 : mqtt-client : iobroker - enabled, port: 1884 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1884, bind: 0.0.0.0 system.adapter.net-tools.0 : net-tools : iobroker - disabled + system.adapter.notification-manager.0 : notification-manager : iobroker - enabled + system.adapter.owfs.0 : owfs : iobroker - enabled, port: 4304 system.adapter.ping.0 : ping : iobroker - disabled system.adapter.pvforecast.0 : pvforecast : iobroker - disabled system.adapter.roborock.0 : roborock : iobroker - disabled + system.adapter.s7.0 : s7 : iobroker - enabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.socketio.0 : socketio : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin system.adapter.sonoff.0 : sonoff : iobroker - disabled, port: 1887, bind: 0.0.0.0 + system.adapter.statistics.0 : statistics : iobroker - enabled + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 system.adapter.vis-2-widgets-energy.0 : vis-2-widgets-energy : iobroker - enabled system.adapter.vis-2-widgets-gauges.0 : vis-2-widgets-gauges : iobroker - enabled system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker - enabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker - enabled system.adapter.vis-2.0 : vis-2 : iobroker - disabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : iobroker - enabled system.adapter.vis.0 : vis : iobroker - disabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyUSB1 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.mqtt-client.0 : mqtt-client : iobroker - enabled, port: 1884 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.owfs.0 : owfs : iobroker - enabled, port: 4304 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.socketio.0 : socketio : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyUSB1 ioBroker-Repositories List is empty Installed ioBroker-Instances Error: Object "system.repositories" not found Objects and States Please stand by - This may take a while Objects: 11044 States: 8689 *** OS-Repositories and Updates *** Hit:1 http://at.archive.ubuntu.com/ubuntu jammy InRelease Hit:2 http://at.archive.ubuntu.com/ubuntu jammy-updates InRelease Hit:3 http://at.archive.ubuntu.com/ubuntu jammy-backports InRelease Hit:4 https://repos.influxdata.com/debian stable InRelease Hit:5 http://security.ubuntu.com/ubuntu jammy-security InRelease Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 102 21829 660/systemd-resolve tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 20100 734/sshd: /usr/sbin tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 15796 1/init tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 22586 799/iobroker.js-con tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 22433 799/iobroker.js-con tcp6 0 0 :::8081 :::* LISTEN 1001 22666 953/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 24575 1229/io.web.0 tcp6 0 0 :::8084 :::* LISTEN 1001 25139 1274/io.socketio.0 tcp6 0 0 :::8086 :::* LISTEN 998 22198 702/influxd tcp6 0 0 :::22 :::* LISTEN 0 20114 734/sshd: /usr/sbin tcp6 0 0 :::111 :::* LISTEN 0 15798 1/init udp 0 0 0.0.0.0:45390 0.0.0.0:* 1001 25163 1259/io.govee-local udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 24122 1101/io.shelly.0 udp 0 0 0.0.0.0:4002 0.0.0.0:* 1001 25009 1259/io.govee-local udp 0 0 127.0.0.53:53 0.0.0.0:* 102 21828 660/systemd-resolve udp 0 0 10.0.100.233:68 0.0.0.0:* 101 19831 658/systemd-network udp 0 0 0.0.0.0:111 0.0.0.0:* 0 15797 1/init udp6 0 0 :::111 :::* 0 15799 1/init *** Log File - Last 25 Lines *** 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: at node:internal/main/run_main_module:28:49 { 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: } 2024-01-15 09:54:18.186 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0 2024-01-15 09:54:18.187 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2024-01-15 09:54:18.187 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
iob diag has finished.
Press any key for a summary
@fhainz hast du an den Skripten etwas verändert?
der Adapter wird beendet, und ein modulcron-parser
angemeckert.
Hast du das zusätzlich installiert?startet wirklich der controller neu?
javascript
Installier den Adapter
javascript
nochmal. -
Nein, wie gsagt, bin heute morgen auf und nichts ging mehr. Hab gestern nur an der vis-2 gebastelt. Hab auch alle Skripte, sowie den vis und den vis-2 adapter deaktiviert.
Nein, cron-parser hab ich nicht (bewusst) installiert.
Ja, der Javascript Adapter startet immer wieder, mit den unterstehenden Meldungen, neu.host.iobroker 2024-01-15 11:26:36.598 info Restart adapter system.adapter.javascript.0 because enabled host.iobroker 2024-01-15 11:26:36.598 error instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: Node.js v18.19.0 host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: } host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: at node:internal/main/run_main_module:28:49 { host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:26:36.598 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: at parse (<anonymous>) host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: ^ host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: throw error; host.iobroker 2024-01-15 11:26:36.597 error Caught by controller[0]: node:internal/modules/package_json_reader:92 host.iobroker 2024-01-15 11:26:36.354 info instance system.adapter.javascript.0 started with pid 6146 host.iobroker 2024-01-15 11:26:06.287 info Restart adapter system.adapter.javascript.0 because enabled host.iobroker 2024-01-15 11:26:06.287 error instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker 2024-01-15 11:26:06.287 error Caught by controller[0]: Node.js v18.19.0 host.iobroker 2024-01-15 11:26:06.287 error Caught by controller[0]: } host.iobroker 2024-01-15 11:26:06.287 error Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' host.iobroker 2024-01-15 11:26:06.287 error Caught by controller[0]: at node:internal/main/run_main_module:28:49 { host.iobroker 2024-01-15 11:26:06.287 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) host.iobroker 2024-01-15 11:26:06.287 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:26:06.287 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:26:06.287 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:26:06.287 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: at parse (<anonymous>) host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: ^ host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: throw error; host.iobroker 2024-01-15 11:26:06.286 error Caught by controller[0]: node:internal/modules/package_json_reader:92 host.iobroker 2024-01-15 11:26:06.078 info instance system.adapter.javascript.0 started with pid 6139 host.iobroker 2024-01-15 11:25:35.947 info Restart adapter system.adapter.javascript.0 because enabled host.iobroker 2024-01-15 11:25:35.947 error instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker 2024-01-15 11:25:35.947 error Caught by controller[0]: Node.js v18.19.0 host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: } host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at node:internal/main/run_main_module:28:49 { host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16) host.iobroker 2024-01-15 11:25:35.946 error Caught by controller[0]: at parse (<anonymous>) host.iobroker 2024-01-15 11:25:35.945 error Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input host.iobroker 2024-01-15 11:25:35.945 error Caught by controller[0]: ^ host.iobroker 2024-01-15 11:25:35.945 error Caught by controller[0]: throw error; host.iobroker 2024-01-15 11:25:35.945 error Caught by controller[0]: node:internal/modules/package_json_reader:92 host.iobroker 2024-01-15 11:25:35.749 info instance system.adapter.javascript.0 started with pid 6132 host.iobroker 2024-01-15 11:25:05.702 info Restart adapter system.adapter.javascript.0 because enabled host.iobroker 2024-01-15 11:25:05.702 error instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker 2024-01-15 11:25:05.702 error Caught by controller[0]: Node.js v18.19.0 host.iobroker 2024-01-15 11:25:05.702 error Caught by controller[0]: } host.iobroker 2024-01-15 11:25:05.702 error Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' host.iobroker 2024-01-15 11:25:05.702 error Caught by controller[0]: at node:internal/main/run_main_module:28:49 { host.iobroker 2024-01-15 11:25:05.702 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) host.iobroker 2024-01-15 11:25:05.702 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:25:05.702 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:25:05.702 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:25:05.702 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:25:05.702 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) host.iobroker 2024-01-15 11:25:05.702 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:25:05.702 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:25:05.702 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:25:05.702 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:25:05.701 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:25:05.701 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:25:05.701 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) host.iobroker 2024-01-15 11:25:05.701 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:25:05.701 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:25:05.701 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:25:05.701 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:25:05.701 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:25:05.701 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:25:05.701 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18) host.iobroker 2024-01-15 11:25:05.701 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:25:05.701 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:25:05.699 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27) host.iobroker 2024-01-15 11:25:05.699 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27) host.iobroker 2024-01-15 11:25:05.699 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31) host.iobroker 2024-01-15 11:25:05.699 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15) host.iobroker 2024-01-15 11:25:05.699 error Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10) host.iobroker 2024-01-15 11:25:05.699 error Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16) host.iobroker 2024-01-15 11:25:05.699 error Caught by controller[0]: at parse (<anonymous>) host.iobroker 2024-01-15 11:25:05.699 error Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input host.iobroker 2024-01-15 11:25:05.698 error Caught by controller[0]: ^ host.iobroker 2024-01-15 11:25:05.698 error Caught by controller[0]: throw error; host.iobroker 2024-01-15 11:25:05.698 error Caught by controller[0]: node:internal/modules/package_json_reader:92 host.iobroker 2024-01-15 11:25:05.466 info instance system.adapter.javascript.0 started with pid 6125 host.iobroker 2024-01-15 11:24:35.396 info Restart adapter system.adapter.javascript.0 because enabled host.iobroker 2024-01-15 11:24:35.396 error instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: Node.js v18.19.0 host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: } host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at node:internal/main/run_main_module:28:49 { host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:24:35.396 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18) host.iobroker 2024-01-15 11:24:35.395 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:24:35.395 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:24:35.395 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27) host.iobroker 2024-01-15 11:24:35.395 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27) host.iobroker 2024-01-15 11:24:35.395 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31) host.iobroker 2024-01-15 11:24:35.395 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15) host.iobroker 2024-01-15 11:24:35.395 error Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10) host.iobroker 2024-01-15 11:24:35.395 error Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16) host.iobroker 2024-01-15 11:24:35.395 error Caught by controller[0]: at parse (<anonymous>) host.iobroker 2024-01-15 11:24:35.395 error Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input host.iobroker 2024-01-15 11:24:35.395 error Caught by controller[0]: ^ host.iobroker 2024-01-15 11:24:35.395 error Caught by controller[0]: throw error; host.iobroker 2024-01-15 11:24:35.395 error Caught by controller[0]: node:internal/modules/package_json_reader:92 host.iobroker 2024-01-15 11:24:35.161 info instance system.adapter.javascript.0 started with pid 6115 host.iobroker 2024-01-15 11:24:05.122 info Restart adapter system.adapter.javascript.0 because enabled host.iobroker 2024-01-15 11:24:05.122 error instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker 2024-01-15 11:24:05.122 error Caught by controller[0]: Node.js v18.19.0 host.iobroker 2024-01-15 11:24:05.122 error Caught by controller[0]: } host.iobroker 2024-01-15 11:24:05.122 error Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' host.iobroker 2024-01-15 11:24:05.122 error Caught by controller[0]: at node:internal/main/run_main_module:28:49 { host.iobroker 2024-01-15 11:24:05.122 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) host.iobroker 2024-01-15 11:24:05.122 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:24:05.122 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:24:05.122 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:24:05.122 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:24:05.122 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) host.iobroker 2024-01-15 11:24:05.122 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:24:05.122 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: at parse (<anonymous>) host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: ^ host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: throw error; host.iobroker 2024-01-15 11:24:05.121 error Caught by controller[0]: node:internal/modules/package_json_reader:92 host.iobroker 2024-01-15 11:24:04.869 info instance system.adapter.javascript.0 started with pid 6107 host.iobroker 2024-01-15 11:23:34.777 info Restart adapter system.adapter.javascript.0 because enabled host.iobroker 2024-01-15 11:23:34.777 error instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker 2024-01-15 11:23:34.777 error Caught by controller[0]: Node.js v18.19.0 host.iobroker 2024-01-15 11:23:34.777 error Caught by controller[0]: } host.iobroker 2024-01-15 11:23:34.777 error Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' host.iobroker 2024-01-15 11:23:34.777 error Caught by controller[0]: at node:internal/main/run_main_module:28:49 { host.iobroker 2024-01-15 11:23:34.777 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) host.iobroker 2024-01-15 11:23:34.777 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:23:34.777 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:23:34.777 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:23:34.777 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:23:34.777 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) host.iobroker 2024-01-15 11:23:34.777 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:23:34.777 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:23:34.777 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:23:34.777 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: at parse (<anonymous>) host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: ^ host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: throw error; host.iobroker 2024-01-15 11:23:34.776 error Caught by controller[0]: node:internal/modules/package_json_reader:92 host.iobroker 2024-01-15 11:23:34.567 info instance system.adapter.javascript.0 started with pid 6100 host.iobroker 2024-01-15 11:23:04.513 info Restart adapter system.adapter.javascript.0 because enabled host.iobroker 2024-01-15 11:23:04.513 error instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker 2024-01-15 11:23:04.513 error Caught by controller[0]: Node.js v18.19.0 host.iobroker 2024-01-15 11:23:04.513 error Caught by controller[0]: } host.iobroker 2024-01-15 11:23:04.513 error Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' host.iobroker 2024-01-15 11:23:04.513 error Caught by controller[0]: at node:internal/main/run_main_module:28:49 { host.iobroker 2024-01-15 11:23:04.513 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) host.iobroker 2024-01-15 11:23:04.513 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:23:04.513 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:23:04.513 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:23:04.513 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:23:04.513 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: at parse (<anonymous>) host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: ^ host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: throw error; host.iobroker 2024-01-15 11:23:04.512 error Caught by controller[0]: node:internal/modules/package_json_reader:92 host.iobroker 2024-01-15 11:23:04.268 info instance system.adapter.javascript.0 started with pid 6086 host.iobroker 2024-01-15 11:22:34.229 info Restart adapter system.adapter.javascript.0 because enabled host.iobroker 2024-01-15 11:22:34.229 error instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker 2024-01-15 11:22:34.229 error Caught by controller[0]: Node.js v18.19.0 host.iobroker 2024-01-15 11:22:34.229 error Caught by controller[0]: } host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at node:internal/main/run_main_module:28:49 { host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:22:34.228 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:22:34.227 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18) host.iobroker 2024-01-15 11:22:34.227 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:22:34.227 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:22:34.227 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27) host.iobroker 2024-01-15 11:22:34.227 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27) host.iobroker 2024-01-15 11:22:34.227 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31) host.iobroker 2024-01-15 11:22:34.227 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15) host.iobroker 2024-01-15 11:22:34.227 error Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10) host.iobroker 2024-01-15 11:22:34.227 error Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16) host.iobroker 2024-01-15 11:22:34.227 error Caught by controller[0]: at parse (<anonymous>) host.iobroker 2024-01-15 11:22:34.227 error Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input host.iobroker 2024-01-15 11:22:34.227 error Caught by controller[0]: ^ host.iobroker 2024-01-15 11:22:34.227 error Caught by controller[0]: throw error; host.iobroker 2024-01-15 11:22:34.227 error Caught by controller[0]: node:internal/modules/package_json_reader:92 host.iobroker 2024-01-15 11:22:34.022 info instance system.adapter.javascript.0 started with pid 5942 host.iobroker 2024-01-15 11:22:03.982 info Restart adapter system.adapter.javascript.0 because enabled host.iobroker 2024-01-15 11:22:03.982 error instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker 2024-01-15 11:22:03.982 error Caught by controller[0]: Node.js v18.19.0 host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: } host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at node:internal/main/run_main_module:28:49 { host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15) host.iobroker 2024-01-15 11:22:03.981 error Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10) host.iobroker 2024-01-15 11:22:03.980 error Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16) host.iobroker 2024-01-15 11:22:03.980 error Caught by controller[0]: at parse (<anonymous>) host.iobroker 2024-01-15 11:22:03.980 error Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input host.iobroker 2024-01-15 11:22:03.980 error Caught by controller[0]: ^ host.iobroker 2024-01-15 11:22:03.980 error Caught by controller[0]: throw error; host.iobroker 2024-01-15 11:22:03.980 error Caught by controller[0]: node:internal/modules/package_json_reader:92 host.iobroker 2024-01-15 11:22:03.711 info instance system.adapter.javascript.0 started with pid 5935 host.iobroker 2024-01-15 11:21:33.652 info Restart adapter system.adapter.javascript.0 because enabled host.iobroker 2024-01-15 11:21:33.652 error instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker 2024-01-15 11:21:33.652 error Caught by controller[0]: Node.js v18.19.0 host.iobroker 2024-01-15 11:21:33.652 error Caught by controller[0]: } host.iobroker 2024-01-15 11:21:33.652 error Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' host.iobroker 2024-01-15 11:21:33.652 error Caught by controller[0]: at node:internal/main/run_main_module:28:49 { host.iobroker 2024-01-15 11:21:33.652 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) host.iobroker 2024-01-15 11:21:33.652 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:21:33.652 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: at parse (<anonymous>) host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input host.iobroker 2024-01-15 11:21:33.651 error Caught by controller[0]: ^ host.iobroker 2024-01-15 11:21:33.650 error Caught by controller[0]: throw error; host.iobroker 2024-01-15 11:21:33.650 error Caught by controller[0]: node:internal/modules/package_json_reader:92 host.iobroker 2024-01-15 11:21:33.431 info instance system.adapter.javascript.0 started with pid 5928 host.iobroker 2024-01-15 11:21:03.380 info Restart adapter system.adapter.javascript.0 because enabled host.iobroker 2024-01-15 11:21:03.380 error instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[1]: Node.js v18.19.0 host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: } host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at node:internal/main/run_main_module:28:49 { host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:21:03.380 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27) host.iobroker 2024-01-15 11:21:03.379 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27) host.iobroker 2024-01-15 11:21:03.379 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31) host.iobroker 2024-01-15 11:21:03.379 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15) host.iobroker 2024-01-15 11:21:03.379 error Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10) host.iobroker 2024-01-15 11:21:03.379 error Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16) host.iobroker 2024-01-15 11:21:03.379 error Caught by controller[0]: at parse (<anonymous>) host.iobroker 2024-01-15 11:21:03.379 error Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input host.iobroker 2024-01-15 11:21:03.379 error Caught by controller[0]: ^ host.iobroker 2024-01-15 11:21:03.379 error Caught by controller[0]: throw error; host.iobroker 2024-01-15 11:21:03.379 error Caught by controller[0]: node:internal/modules/package_json_reader:92 host.iobroker 2024-01-15 11:21:03.174 info instance system.adapter.javascript.0 started with pid 5921
Die Uhrzeit passt nun plötzlich wieder.
In den Repository-Einstellungen verschwinden nach dem Speichern beide Einträge wieder. -
Hab ich getan. Leider keine Änderung.
host.iobroker 2024-01-15 11:30:38.294 info Restart adapter system.adapter.javascript.0 because enabled host.iobroker 2024-01-15 11:30:38.294 error instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: Node.js v18.19.0 host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: } host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at node:internal/main/run_main_module:28:49 { host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31) host.iobroker 2024-01-15 11:30:38.294 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15) host.iobroker 2024-01-15 11:30:38.293 error Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10) host.iobroker 2024-01-15 11:30:38.293 error Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16) host.iobroker 2024-01-15 11:30:38.293 error Caught by controller[0]: at parse (<anonymous>) host.iobroker 2024-01-15 11:30:38.293 error Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input host.iobroker 2024-01-15 11:30:38.293 error Caught by controller[0]: ^ host.iobroker 2024-01-15 11:30:38.293 error Caught by controller[0]: throw error; host.iobroker 2024-01-15 11:30:38.293 error Caught by controller[0]: node:internal/modules/package_json_reader:92 host.iobroker 2024-01-15 11:30:38.058 info instance system.adapter.javascript.0 started with pid 6221 host.iobroker 2024-01-15 11:30:36.470 error cannot call visUtils: Not exists
@fhainz sagte in js-controller startet immer wieder neu:
Ja, der Javascript Adapter startet immer wieder,
aber laut Threadtitel der js-controller!!
und danach suche ich die ganze Zeit -
Hab auch alle Skripte, sowie den vis und den vis-2 adapter deaktiviert.
auch den Javascript Adapter?
Entschuldigung.. Wusste nicht das es einen Unterscheid gibt. Hab die formulierung anscheinend aus dieser Fehlermeldung übernommen.
Da steht auch JS_CONTROLLER
Nein, der ist aktiv und Rot markiert. -
der js-controller ist das Herzstück von iobroker und regelt alles
deswegen stoppt der controller auch den javascript-Adapter, weil der anscheinend ein Problem hat.
Nein, der ist aktiv und Rot markiert.dann stop ihn
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: iobroker Icon name: computer-vm Chassis: vm Virtualization: oracle Operating System: Ubuntu 22.04.3 LTS Kernel: Linux 5.15.0-91-generic Architecture: x86-64 Hardware Vendor: innotek GmbH Hardware Model: VirtualBox model name : Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz Docker : false Virtualization : oracle Kernel : x86_64 Userland : amd64 Systemuptime and Load: 10:36:59 up 1:02, 2 users, load average: 1.68, 1.01, 0.68 CPU threads: 2 *** Time and Time Zones *** Local time: Mon 2024-01-15 10:36:59 UTC Universal time: Mon 2024-01-15 10:36:59 UTC RTC time: Mon 2024-01-15 10:36:59 Time zone: Etc/UTC (UTC, +0000) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** fabian /home/fabian fabian adm cdrom sudo dip plugdev lxd iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 7.9G 1.9G 5.0G 1.0M 1.1G 5.8G Swap: 0B 0B 0B Total: 7.9G 1.9G 5.0G 7938 M total memory 1913 M used memory 511 M active memory 2158 M inactive memory 4957 M free memory 145 M buffer memory 921 M swap cache 0 M total swap 0 M used swap 0 M free swap *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 794M 1.2M 793M 1% /run /dev/mapper/ubuntu--vg-ubuntu--lv ext4 18G 16G 1.4G 93% / tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock /dev/sda2 ext4 1.8G 252M 1.4G 16% /boot tmpfs tmpfs 794M 4.0K 794M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Mon Jan 15 09:34:19 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [Mon Jan 15 09:34:19 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none. [Mon Jan 15 09:34:20 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/ubuntu--vg-ubuntu--lv ext4 rw,relatime |-/snap/snapd/20671 /dev/loop0 squashfs ro,nodev,relatime,errors=continue |-/snap/snapd/20290 /dev/loop1 squashfs ro,nodev,relatime,errors=continue |-/snap/core20/2015 /dev/loop2 squashfs ro,nodev,relatime,errors=continue |-/snap/lxd/24322 /dev/loop4 squashfs ro,nodev,relatime,errors=continue |-/snap/core20/2105 /dev/loop3 squashfs ro,nodev,relatime,errors=continue `-/boot /dev/sda2 ext4 rw,relatime Files in neuralgic directories: /var: 8.6G /var/ 7.2G /var/lib 6.5G /var/lib/influxdb/engine/data 6.5G /var/lib/influxdb/engine 6.5G /var/lib/influxdb Archived and active journals take up 816.3M in the file system. /opt/iobroker/backups: 4.0K /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.1G /opt/iobroker/iobroker-data/ 650M /opt/iobroker/iobroker-data/files 200M /opt/iobroker/iobroker-data/history 190M /opt/iobroker/iobroker-data/backup-objects 166M /opt/iobroker/iobroker-data/files/vis-2 The five largest files in iobroker-data are: 24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map 24M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map 23M /opt/iobroker/iobroker-data/states.jsonl 23M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map 22M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03188557-if00-port0 /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A907AG4V-if00-port0 *** NodeJS-Installation *** /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.0-1nodesource1 Version table: *** 18.19.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 500 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 12.22.9~dfsg-1ubuntu3.3 500 500 http://at.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages 500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages 12.22.9~dfsg-1ubuntu3 500 500 http://at.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages Temp directories causing npm8 problem: 0 No problems detected
Anschließend kommen hunderte Zeilen ala
Errors in npm tree: npm ERR! code ELSPROBLEMS npm ERR! extraneous: @types/caseless@0.12.4 /opt/iobroker/node_modules/@types/caseless npm ERR! extraneous: @types/request@2.48.11 /opt/iobroker/node_modules/@types/request npm ERR! extraneous: @types/tough-cookie@4.0.4 /opt/iobroker/node_modules/@types/tough-cookie
Dann geht es wieder mit:
*** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.17 admin: 6.12.0 javascript: 7.1.6 Adapters from github: 2 Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alexa2.0 : alexa2 : iobroker - disabled system.adapter.alias-manager.0 : alias-manager : iobroker - enabled system.adapter.awattar.0 : awattar : iobroker - enabled + system.adapter.backitup.0 : backitup : iobroker - enabled system.adapter.discovery.0 : discovery : iobroker - disabled system.adapter.fronius-solarweb.0 : fronius-solarweb : iobroker - disabled + system.adapter.fronius.0 : fronius : iobroker - enabled + system.adapter.govee-local.0 : govee-local : iobroker - enabled system.adapter.govee.0 : govee : iobroker - disabled system.adapter.history.0 : history : iobroker - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - enabled + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 system.adapter.jarvis.0 : jarvis : iobroker - disabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.javascript.0 : javascript : iobroker - enabled system.adapter.linkeddevices.0 : linkeddevices : iobroker - disabled system.adapter.lovelace.0 : lovelace : iobroker - disabled, port: 8091, bind: 0.0.0.0, run as: admin system.adapter.mobile.0 : mobile : iobroker - disabled + system.adapter.modbus.0 : modbus : iobroker - enabled + system.adapter.modbus.1 : modbus : iobroker - enabled + system.adapter.modbus.2 : modbus : iobroker - enabled + system.adapter.modbus.3 : modbus : iobroker - enabled + system.adapter.mqtt-client.0 : mqtt-client : iobroker - enabled, port: 1884 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1884, bind: 0.0.0.0 system.adapter.net-tools.0 : net-tools : iobroker - disabled + system.adapter.notification-manager.0 : notification-manager : iobroker - enabled + system.adapter.owfs.0 : owfs : iobroker - enabled, port: 4304 system.adapter.ping.0 : ping : iobroker - disabled system.adapter.pvforecast.0 : pvforecast : iobroker - disabled system.adapter.roborock.0 : roborock : iobroker - disabled + system.adapter.s7.0 : s7 : iobroker - enabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.socketio.0 : socketio : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin system.adapter.sonoff.0 : sonoff : iobroker - disabled, port: 1887, bind: 0.0.0.0 + system.adapter.statistics.0 : statistics : iobroker - enabled + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 system.adapter.vis-2-widgets-energy.0 : vis-2-widgets-energy : iobroker - enabled system.adapter.vis-2-widgets-gauges.0 : vis-2-widgets-gauges : iobroker - enabled system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker - enabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker - enabled system.adapter.vis-2.0 : vis-2 : iobroker - disabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : iobroker - enabled system.adapter.vis.0 : vis : iobroker - disabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyUSB1 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086 + system.adapter.mqtt-client.0 : mqtt-client : iobroker - enabled, port: 1884 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.owfs.0 : owfs : iobroker - enabled, port: 4304 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.socketio.0 : socketio : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyUSB1 ioBroker-Repositories List is empty Installed ioBroker-Instances Error: Object "system.repositories" not found Objects and States Please stand by - This may take a while Objects: 10841 States: 8517 *** OS-Repositories and Updates *** Hit:1 http://at.archive.ubuntu.com/ubuntu jammy InRelease Hit:2 http://security.ubuntu.com/ubuntu jammy-security InRelease Hit:3 http://at.archive.ubuntu.com/ubuntu jammy-updates InRelease Hit:4 http://at.archive.ubuntu.com/ubuntu jammy-backports InRelease Hit:5 https://repos.influxdata.com/debian stable InRelease Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 102 21829 660/systemd-resolve tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 20100 734/sshd: /usr/sbin tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 15796 1/init tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 22586 799/iobroker.js-con tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 22433 799/iobroker.js-con tcp6 0 0 :::8081 :::* LISTEN 1001 22666 953/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 24575 1229/io.web.0 tcp6 0 0 :::8084 :::* LISTEN 1001 25139 1274/io.socketio.0 tcp6 0 0 :::8086 :::* LISTEN 998 22198 702/influxd tcp6 0 0 :::22 :::* LISTEN 0 20114 734/sshd: /usr/sbin tcp6 0 0 :::111 :::* LISTEN 0 15798 1/init udp 0 0 0.0.0.0:45390 0.0.0.0:* 1001 25163 1259/io.govee-local udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 24122 1101/io.shelly.0 udp 0 0 0.0.0.0:4002 0.0.0.0:* 1001 25009 1259/io.govee-local udp 0 0 127.0.0.53:53 0.0.0.0:* 102 21828 660/systemd-resolve udp 0 0 10.0.100.233:68 0.0.0.0:* 101 19831 658/systemd-network udp 0 0 0.0.0.0:111 0.0.0.0:* 0 15797 1/init udp6 0 0 :::111 :::* 0 15799 1/init *** Log File - Last 25 Lines *** 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: at node:internal/main/run_main_module:28:49 { 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json' 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[0]: } 2024-01-15 10:37:33.662 - error: host.iobroker Caught by controller[1]: Node.js v18.19.0 2024-01-15 10:37:33.662 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2024-01-15 10:37:33.662 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
======================= SUMMARY ======================= v.2023-10-10 Static hostname: iobroker Icon name: computer-vm Chassis: vm Virtualization: oracle Operating System: Ubuntu 22.04.3 LTS Kernel: Linux 5.15.0-91-generic Architecture: x86-64 Hardware Vendor: innotek GmbH Hardware Model: VirtualBox Installation: oracle Kernel: x86_64 Userland: amd64 Timezone: Etc/UTC (UTC, +0000) User-ID: 1000 X-Server: false Boot Target: graphical.target Pending OS-Updates: 0 Error: Object "system.repositories" not found Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 Recommended versions are nodejs 18.19.0 and npm 10.2.3 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 7.9G 1.9G 4.9G 1.0M 1.1G 5.7G Swap: 0B 0B 0B Total: 7.9G 1.9G 4.9G Active iob-Instances: 21 List is empty ioBroker Core: js-controller 5.0.17 admin 6.12.0 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 10841 States: 8517 Size of iob-Database: 13M /opt/iobroker/iobroker-data/objects.jsonl 24M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ====================
Hab ich getan
wie genau durchgeführt?
wo ist der Konsolenoutput dazu?
waren da H7nweise? -
Ich hab in den Instanzen den JS-Adapter ausgeklappt und auf das Müll Symbol geklickt. Anschließend unter Adapter den JS-Adapter gesucht und nochmals installiert.
Kein Konsolen-Output, Keine Hinweise.
dann hast du nur die Instanz entfernt und wieder angekegt, aber nicht den Adapter neu installiert!
Eigenartig finde ich auch diese Meldungen.
iobroker 2024-01-15 11:44:51.083 error cannot call visUtils: Not exists host.iobroker 2024-01-15 10:44:45.734 error cannot call visUtils: Not exists
Mal passt die Zeit, mal nicht. vis Adapter sind deaktiviert.
sudo timedatectl set-timezone Europe/Berlin sudo systemctl set-default multi-user.target iob update
Edit: Kommando korrigiert.
Ich denke ich hab den Adapter jetzt gelöscht. Klick auf das Müll-Zeichen in Adapter.Vermutlich weil meine Repositories leer sind kann ich keine Adapter neu installieren? Habs schon mehrfach händisch eingetragen bzw auf "Repositories auf Standart herstellen" geklickt. Nach dem speichern ist die Liste immer wieder leer.
