    3. Einsteigerfragen
    4. [gelöst] js-adapter startet immer wieder neu
    • fhainz
      fhainz @Thomas Braun last edited by
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: oracle
      Operating System: Ubuntu 22.04.3 LTS
                Kernel: Linux 5.15.0-91-generic
          Architecture: x86-64
       Hardware Vendor: innotek GmbH
        Hardware Model: VirtualBox
      model name	: Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz
      Docker          : false
      Virtualization  : oracle
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       10:36:59 up  1:02,  2 users,  load average: 1.68, 1.01, 0.68
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Mon 2024-01-15 10:36:59 UTC
                 Universal time: Mon 2024-01-15 10:36:59 UTC
                       RTC time: Mon 2024-01-15 10:36:59
                      Time zone: Etc/UTC (UTC, +0000)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      fabian
      /home/fabian
      fabian adm cdrom sudo dip plugdev lxd iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:            7.9G        1.9G        5.0G        1.0M        1.1G        5.8G
      Swap:             0B          0B          0B
      Total:          7.9G        1.9G        5.0G
               7938 M total memory
               1913 M used memory
                511 M active memory
               2158 M inactive memory
               4957 M free memory
                145 M buffer memory
                921 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                        Type   Size  Used Avail Use% Mounted on
      tmpfs                             tmpfs  794M  1.2M  793M   1% /run
      /dev/mapper/ubuntu--vg-ubuntu--lv ext4    18G   16G  1.4G  93% /
      tmpfs                             tmpfs  3.9G     0  3.9G   0% /dev/shm
      tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
      /dev/sda2                         ext4   1.8G  252M  1.4G  16% /boot
      tmpfs                             tmpfs  794M  4.0K  794M   1% /run/user/1000
      [Mon Jan 15 09:34:19 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Mon Jan 15 09:34:19 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
      [Mon Jan 15 09:34:20 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      TARGET              SOURCE                            FSTYPE   OPTIONS
      /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
      |-/snap/snapd/20671 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/snapd/20290 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/core20/2015 /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/lxd/24322   /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/core20/2105 /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
      `-/boot             /dev/sda2                         ext4     rw,relatime
      /var:
      8.6G	/var/
      7.2G	/var/lib
      6.5G	/var/lib/influxdb/engine/data
      Archived and active journals take up 816.3M in the file system.
      /opt/iobroker/backups:
      4.0K	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G	/opt/iobroker/iobroker-data/
      650M	/opt/iobroker/iobroker-data/files
      200M	/opt/iobroker/iobroker-data/history
      190M	/opt/iobroker/iobroker-data/backup-objects
      166M	/opt/iobroker/iobroker-data/files/vis-2
      24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      23M	/opt/iobroker/iobroker-data/states.jsonl
      23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
      22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03188557-if00-port0
      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A907AG4V-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.19.0
      /usr/bin/node 		v18.19.0
      /usr/bin/npm 		10.2.3
      /usr/bin/npx 		10.2.3
      /usr/bin/corepack 	0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
           12.22.9~dfsg-1ubuntu3.3 500
              500 http://at.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
              500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://at.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Anschließend kommen hunderte Zeilen ala
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @types/caseless@0.12.4 /opt/iobroker/node_modules/@types/caseless
      npm ERR! extraneous: @types/request@2.48.11 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: @types/tough-cookie@4.0.4 /opt/iobroker/node_modules/@types/tough-cookie
      Dann geht es wieder mit:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	5.0.17
      admin: 		6.12.0
      javascript: 	7.1.6
      Adapters from github: 	2
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
        system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
        system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled
      + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
      + system.adapter.govee-local.0            : govee-local           : iobroker                                 -  enabled
        system.adapter.govee.0                  : govee                 : iobroker                                 - disabled
        system.adapter.history.0                : history               : iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 - disabled
        system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
        system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.3                 : modbus                : iobroker                                 -  enabled
      + system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 -  enabled, port: 1884
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
        system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
      + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
      + system.adapter.owfs.0                   : owfs                  : iobroker                                 -  enabled, port: 4304
        system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
        system.adapter.pvforecast.0             : pvforecast            : iobroker                                 - disabled
        system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
      + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.sonoff.0                 : sonoff                : iobroker                                 - disabled, port: 1887, bind: 0.0.0.0
      + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
        system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB1
      + instance is alive
      ioBroker-Repositories
      List is empty
      Installed ioBroker-Instances
      Error: Object "system.repositories" not found
      Objects and States
      Objects: 	10841
      States: 	8517
      Hit:1 http://at.archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://security.ubuntu.com/ubuntu jammy-security InRelease
      Hit:3 http://at.archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:4 http://at.archive.ubuntu.com/ubuntu jammy-backports InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        21829      660/systemd-resolve
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20100      734/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15796      1/init
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       22586      799/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       22433      799/iobroker.js-con
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22666      953/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       24575      1229/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       25139      1274/io.socketio.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      998        22198      702/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          20114      734/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          15798      1/init
      udp        0      0 0.0.0.0:45390           0.0.0.0:*                           1001       25163      1259/io.govee-local
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24122      1101/io.shelly.0
      udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1001       25009      1259/io.govee-local
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        21828      660/systemd-resolve
      udp        0      0 10.0.100.233:68         0.0.0.0:*                           101        19831      658/systemd-network
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15797      1/init
      udp6       0      0 :::111                  :::*                                0          15799      1/init
      2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
      2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
      2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
      2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49 {
      2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
      2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]: }
      2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[1]: Node.js v18.19.0
      2024-01-15 10:37:33.662  - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-15 10:37:33.662  - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
      			v.2023-10-10
               Chassis: vm
      Installation: 		oracle
      Kernel: 		x86_64
      Userland: 		amd64
      Timezone: 		Etc/UTC (UTC, +0000)
      User-ID: 		1000
      X-Server: 		false
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
      			/usr/bin/npm 		10.2.3
      			/usr/bin/npx 		10.2.3
      Recommended versions are nodejs 18.19.0 and npm 10.2.3
      MEMORY:
      Mem:            7.9G        1.9G        4.9G        1.0M        1.1G        5.7G
      Swap:             0B          0B          0B
      Total:          7.9G        1.9G        4.9G
      Active iob-Instances: 	21
      List is empty
      ioBroker Core: 		js-controller 		5.0.17
      			admin 			6.12.0
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Objects: 		10841
      States: 		8517
      Size of iob-Database:
      13M	/opt/iobroker/iobroker-data/objects.jsonl
      24M	/opt/iobroker/iobroker-data/states.jsonl
        @fhainz sagte in js-controller startet immer wieder neu:
        Hab ich getan
        wie genau durchgeführt?
        wo ist der Konsolenoutput dazu?
        waren da H7nweise?
        fhainz 1 Reply Last reply Reply Quote 0
        • fhainz
          fhainz @Homoran last edited by
          Ich hab in den Instanzen den JS-Adapter ausgeklappt und auf das Müll Symbol geklickt. Anschließend unter Adapter den JS-Adapter gesucht und nochmals installiert.
          Kein Konsolen-Output, Keine Hinweise.
            Homoran Global Moderator Administrators @fhainz last edited by
            dann hast du nur die Instanz entfernt und wieder angekegt, aber nicht den Adapter neu installiert!
            • fhainz
              Eigenartig finde ich auch diese Meldungen.
              iobroker
              2024-01-15 11:44:51.083	error	cannot call visUtils: Not exists
              host.iobroker
              2024-01-15 10:44:45.734	error	cannot call visUtils: Not exists
              Mal passt die Zeit, mal nicht. vis Adapter sind deaktiviert.
                Thomas Braun Most Active @fhainz last edited by Thomas Braun
                @fhainz
                sudo timedatectl set-timezone Europe/Berlin
                sudo systemctl set-default multi-user.target
                iob update
                Edit: Kommando korrigiert.
                • fhainz
                  Ich denke ich hab den Adapter jetzt gelöscht. Klick auf das Müll-Zeichen in Adapter.
                  Vermutlich weil meine Repositories leer sind kann ich keine Adapter neu installieren? Habs schon mehrfach händisch eingetragen bzw auf "Repositories auf Standart herstellen" geklickt. Nach dem speichern ist die Liste immer wieder leer.
                    @fhainz
                    iob repo list
                      gezeigt hast du das aber auch noch nicht
                      bitte unbedingt lesen und beachten
                      Den Threadtitel bitte korrigieren!
                      • fhainz
                        fabian@iobroker:~$ sudo systemctl set-default multihost.target
                        Failed to set default target: Unit file multihost.target does not exist.
                        fabian@iobroker:~$ iob update
                          @fhainz
                          Mein Fehler.
                          • fhainz
                            fhainz @Thomas Braun last edited by fhainz
                            Hab ich gemacht.
                            fabian@iobroker:~$ iob repo list
                            List is empty
                            Leer und lassen sich im Admin unter Systemeinstellungen/Repositories auch nicht neu anlegen. Nach dem Speichern sind sie wieder weg.
                              @fhainz
                              iob repo add beta http://download.iobroker.net/sources-dist-latest.json
                              iob repo add stable http://download.iobroker.net/sources-dist.json
                              iob repo set stable
                              iob repo list
                              • fhainz
                                fhainz @Thomas Braun last edited by Homoran
                                @thomas-braun:
                                List is empty
                                fabian@iobroker:~$ iob repo add beta http://download.iobroker.net/sources-dist-latest.json
                                Cannot add repository location: Repository "beta" yet exists: http://download.iobroker.net/sources-dist-latest.json
                                fabian@iobroker:~$ iob repo add stable http://download.iobroker.net/sources-dist.json
                                Cannot add repository location: Repository "stable" yet exists: http://download.iobroker.net/sources-dist.json
                                fabian@iobroker:~$ iob repo set stable
                                Repository "stable" set as active.
                                List is empty
                                List is empty
                                Wird leider nicht übernommen.
                                • fhainz
                                  Ich habe jetzt noch den fix Befehl versucht.
                                  fabian@iobroker:~$ iob stop
                                  fabian@iobroker:~$ iob fix
                                  Your installation was fixed successfully
                                  fabian@iobroker:~$ iob start
                                  Problem besteht weiterhin. Repositories sind leer, ein neues Hinzufügen funktioniert aber auch nicht.
                                  List is empty
                                    @fhainz
                                    Keine Ahnung was da bei dir warum klemmt.
                                    • fhainz
                                      Ok, danke für deine Hilfe. Dann hoffe ich auf @Homoran, vielleicht hat er noch eine idee.
                                        @fhainz sagte in js-adapter startet immer wieder neu:
                                        keine Ahnung.
                                        hatte es einen Stromausfall gegeben?
                                        Dann könnte dein Dateisystem einen Schuss abbekommen haben.
                                        • fhainz
                                          Ich habe jetzt den Befehl
                                          iob setup first
                                          aus diesem Beitrag versucht: https://forum.iobroker.net/topic/67296/repositories-liste-ist-leer-und-kein-adapter-angezeigt/19?_=1705321064399
                                          Die Repositories sind jetzt wieder da. Somit war es auch wieder möglich den JS-Adapter neu zu installieren. Anschließend habe ich alle Skripte gestartet und bisher läuft es wieder soweit.
                                          • fhainz
                                            Nein, Stromausfall gab es keinen. Das System hängt zur Sicherheit auch noch an einer USV.
                                            2312
