    4. IOBroker reagiert nicht mehr | Shelly Adapter
      dike1982 @Thomas Braun last edited by dike1982
      Trotzdem schon mal danke!
      Hat sonst einer eine Idee??
        Ich brauch leider nochmal Hilfe.
        Ich hab mir gedacht ich lösche den shelly-Adapter und fang mit den Shellys von vorne an.
        Das Löschen hat recht lange gedauert.
        Jetzt habe ich wieder die Time-out Warnungen auf der Oberfläche und es lässt sich quasi nicht bedienen, bzw. alles sehr langsam!!
        2024-01-14 01:36:10.647  - info: host.raspberrypi4 instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-01-14 01:37:09.511  - info: host.raspberrypi4 iobroker del shelly.0
        2024-01-14 01:37:40.809  - info: host.raspberrypi4 iobroker Delete instance "shelly.0"
        2024-01-14 01:37:46.555  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1 instances of shelly.0
        2024-01-14 01:37:51.803  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 23 devices of shelly.0
        2024-01-14 01:37:55.733  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 159 channels of shelly.0
        2024-01-14 01:37:59.655  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1360 states of shelly.0
        2024-01-14 01:38:02.245  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 15 states of system.adapter.shelly.0
        2024-01-14 01:38:02.906  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 1134 states (io.shelly.0.*) from states
        2024-01-14 01:38:04.894  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 6 states (system.adapter.shelly.0.*) from states
        2024-01-14 01:38:11.587  - info: host.raspberrypi4 iobroker host.raspberrypi4 Counted 2 objects of shelly.0host.raspberrypi4 Deleting 1560 object(s). Be patient...
        2024-01-14 01:38:49.188  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 1400 objects left to be deleted.
        2024-01-14 01:39:59.624  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 1200 objects left to be deleted.
        2024-01-14 01:40:21.779  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 1000 objects left to be deleted.
        2024-01-14 01:41:30.214  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 800 objects left to be deleted.
        2024-01-14 01:41:35.629  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 600 objects left to be deleted.
        2024-01-14 01:41:50.581  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 400 objects left to be deleted.
        2024-01-14 01:44:28.905  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 200 objects left to be deleted.
        2024-01-14 01:46:34.239  - info: host.raspberrypi4 object deleted system.adapter.shelly.0
        2024-01-14 01:46:34.251  - info: host.raspberrypi4 iobroker host.raspberrypi4 Deleting 1140 state(s). Be patient...
        2024-01-14 01:47:44.091  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 1000 states left to be deleted.
        2024-01-14 01:48:17.714  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 800 states left to be deleted.
        2024-01-14 01:49:33.382  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 600 states left to be deleted.
        2024-01-14 01:49:37.528  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 400 states left to be deleted.
        2024-01-14 01:52:40.727  - info: host.raspberrypi4 iobroker host.raspberrypi4: Only 200 states left to be deleted.
        2024-01-14 01:53:11.244  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.115.81 admin
        2024-01-14 01:54:05.002  - info: admin.0 (718) failed connection to socket.io from ::ffff:192.168.115.81: Passport was not initialized
        2024-01-14 01:54:10.253  - info: admin.0 (718) failed connection to socket.io from ::ffff:192.168.115.81: Passport was not initialized
        2024-01-14 01:55:26.687  - info: host.raspberrypi4 instance system.adapter.ical.0 started with pid 2971
        2024-01-14 01:55:38.919  - warn: ical.0 (2971) slow connection to objects DB. Still waiting ...
        2024-01-14 01:56:04.379  - warn: ical.0 (2971) slow connection to states DB. Still waiting ...
        2024-01-14 01:56:48.432  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.115.81 admin
        2024-01-14 01:57:05.853  - info: admin.0 (718) failed connection to socket.io from ::ffff:192.168.115.81: Passport was not initialized
        2024-01-14 01:57:41.889  - info: ical.0 (2971) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
        2024-01-14 01:57:44.516  - info: ical.0 (2971) processing URL: Müllkalender https://calendar.google.com/calendar/ical/3a2097d8a678bc40972b4f2df3a70416e549cabb23d727a3bddacc2001f63aa7%40group.calendar.google.com/private-f6d975016103767eb05b6b0c059afa62/basic.ics
        2024-01-14 01:58:13.682  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.115.81
        2024-01-14 01:58:19.894  - info: ical.0 (2971) Terminated (NO_ERROR): Without reason
        2024-01-14 01:58:21.662  - info: host.raspberrypi4 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2024-01-14 01:59:47.928  - info: host.raspberrypi4 iobroker exit 0
        2024-01-14 02:00:00.084  - info: host.raspberrypi4 instance system.adapter.ical.0 started with pid 2990
        2024-01-14 02:00:20.340  - info: ical.0 (2990) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
        2024-01-14 02:00:33.511  - info: ical.0 (2990) processing URL: Müllkalender https://calendar.google.com/calendar/ical/3a2097d8a678bc40972b4f2df3a70416e549cabb23d727a3bddacc2001f63aa7%40group.calendar.google.com/private-f6d975016103767eb05b6b0c059afa62/basic.ics
        2024-01-14 02:01:08.408  - info: ical.0 (2990) Terminated (NO_ERROR): Without reason
        2024-01-14 02:01:09.834  - info: host.raspberrypi4 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2024-01-14 02:02:52.339  - info: admin.0 (718) <== Disconnect system.user.admin from ::ffff:192.168.115.81 admin
        2024-01-14 02:03:06.659  - info: admin.0 (718) ==> Connected system.user.admin from ::ffff:192.168.115.81
          dike1982 @dike1982 last edited by
          Hat sich erledigt.
          Ich hab nochmal ein full-upgrade gemacht.
          Jetzt läuft alles inkl. Shelly.
            @Thomas-Braun
            Leider ist das Thema nicht erledigt.
            Der Shellyadater legt mir immer noch das System lahm.
            Ich habe deswegen ein Issue auf Github aufgemacht, der ENtwickler meinte zu mir:
            "deine Objekt- und State-DB macht Probleme"
            Keine Ahnung was das bedeutet oder wie ich das fixe.
            Würde aber dazu passen, dass ich mit einem Skript auch Probleme habe bei welchem aus einem Fensterkontakt der STATE nicht richtig ausgelesen werden kann und das Skript deswegen Fehler bringt.
            Eine Idee wie ich das löse?
              bommel_030 @dike1982 last edited by
              @dike1982
              Schuss ins Blaue... Du hast den Device-Watcher Adapter installiert. Deaktivier den Mal... Reboot tut gut... Und dann Mal weiter beobachten. Hab die Kausalkette noch nicht durchblickt, hatte es aber schon 4-5x erfolgreich als Lösung...
                dike1982 @bommel_030 last edited by
                @bommel_030
                Device-Watcher ist tatsächlich installiert, aber gestoppt.
                Ich hau den mal runter und mach einen reboot.
                Wie kann ich feststellen ob die Objekt- und State-DB sauber läuft?
                  @dike1982
                  Oben im diag hatte ich nur gesehen dass der noch aktiv war. Ich habe noch keine Zeit gehabt das genauer zu untersuchen, daher nur Vermutung:
                  Der Shelly Adapter gibt (nach einem mir nicht ersichtlichen Schema) diese MQTT Fehlermeldungen raus. Darauf reagiert der device-watcher, darauf reagiert Shelly und darauf wieder der device-watcher und das erzeugt eine Schleife die mein System von üblicherweise 0,3 auf > 4 katapultiert hat.
                  Nach deaktivieren von device-watcher wieder 0,3. Ob dir die Überlast dein Dateisystem zerstört hat und wie das zu reparieren geht kann ich dir leider nicht beantworten.
                  D 3 Replies Last reply Reply Quote 0
                    @bommel_030
                    Alles klar ich schau mal wenn ich daheim bin!
                      @bommel_030
                      was meinst du mit 0,3 und 4?
                        dike1982 @bommel_030 last edited by dike1982
                        @bommel_030
                        Könnte sein, dass das was gebracht hat.
                        Ich habe den Device-Watscher gelöscht und ein fullupgrade auf Kommandoebene gemacht.
                        Habe dann 7 von 24 Shellys wieder das MQTT aktiviert und den Shellyadapter gestartet.
                        Log ist ruhig. Lässt sich alles bedienen.
                        Host bei 9 % CPU.
                        Ich warte mal noch ein paar stunden und nehme dann die restlichen Shelly auch wieder dazu!
                          @dike1982
                          Meinte den Load average. Ganz grob, bei allem größer 1 muss irgendein Prozeß warten weil RAM, CPU etc. Ausgelastet sind.
                            @bommel_030
                            Nochmal blöde Frage:
                            Wo sehe ich den?
                            Sorry bin Anfänger!
                              @dike1982
                              Viele Wege führen nach Rom...
                              Ich nehm die Konsole und schau in htop nach.
                              Je nach Betriebssystem ist das ggf. Nicht vorhanden, lässt sich aber einfach nachinstallieren oder in der Konsole top statt htop. Ist ne abgespeckte Version und eigentlich überall vorhanden.
                                @bommel_030
                                Danke.
                                htop klappt.
                                habe zischen 0,20 und 0,4
                                  Also bis jetzt läuft es stabil.
                                  Vielen Dank.
                                  Aber was mach ich jetzt mit dem Device-Watcher?
                                  • haus-automatisierung
                                    haus-automatisierung Developer Most Active @dike1982 last edited by
                                    @dike1982 sagte in IOBroker reagiert nicht mehr | Shelly Adapter:
                                    [MQTT] Unable to get mqttprefix of client with id "shelly1pmmini-543204aaa1f4"
                                    Das ist leider ein Problem mit der aktuellsten Firmware auf den Shellies. Ich konnte das bisher nur leider nicht reproduzieren.
                                    Ein paar deiner Shellies haben aber die falschen Zugangsdaten hinterlegt:
                                    [MQTT] Wrong MQTT authentification of client "shelly1pmmini-543204abcca8"
                                      dike1982 @haus-automatisierung last edited by
                                      Danke für die Info.
                                      Die falschen Zugangsdaten habe ich behoben. Ich bekomme jetzt keine Fehler mehr im Log, habe aber den Device-Wacher nach wie vor aus! Was etwas blöd ist!
                                      2325
