[gelöst] Javascript Adapter stürzt ab
Systemdata Bitte Ausfüllen Hardwaresystem: Mitac PC Arbeitsspeicher: 8GB Festplattenart: SSD Betriebssystem: Ubuntu Node-Version: 19.9.0 Nodejs-Version: command not found NPM-Version: 9.6.3 Installationsart: Skript ich habe seit 3 Tagen das Problem das mein Javascript Adapter in unregelmäßigen Abständen abstürzt.
Hier der Log dazu:2024-01-15 21:07:00.119 - info: host.iobroker instance system.adapter.openweathermap.0 started with pid 253355 2024-01-15 21:07:05.103 - info: openweathermap.0 (253355) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v19.9.0, js-controller: 5.0.17 2024-01-15 21:07:24.977 - info: openweathermap.0 (253355) Terminated (NO_ERROR): Without reason 2024-01-15 21:07:25.513 - info: host.iobroker instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR) 2024-01-15 21:09:17.519 - error: host.iobroker Caught by controller[0]: <--- Last few GCs ---> 2024-01-15 21:09:17.520 - error: host.iobroker Caught by controller[0]: [241690:0x6791ae0] 8052324 ms: Scavenge 2042.5 (2081.4) -> 2042.0 (2081.9) MB, 15.4 / 0.0 ms (average mu = 0.182, current mu = 0.201) allocation failure; 2024-01-15 21:09:17.520 - error: host.iobroker Caught by controller[0]: [241690:0x6791ae0] 8052350 ms: Scavenge 2043.1 (2081.9) -> 2042.7 (2082.9) MB, 18.4 / 0.0 ms (average mu = 0.182, current mu = 0.201) allocation failure; 2024-01-15 21:09:17.520 - error: host.iobroker Caught by controller[0]: [241690:0x6791ae0] 8052376 ms: Scavenge 2043.9 (2082.9) -> 2043.4 (2087.4) MB, 16.4 / 0.0 ms (average mu = 0.182, current mu = 0.201) allocation failure; 2024-01-15 21:09:17.520 - error: host.iobroker Caught by controller[0]: <--- JS stacktrace ---> 2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory 2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[1]: 1: 0xbf9890 node::Abort() [io.javascript.0] 2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[2]: 2: 0xaf6859 [io.javascript.0] 2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[3]: 3: 0xddaf80 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [io.javascript.0] 2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[4]: 4: 0xddb336 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [io.javascript.0] 2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[5]: 5: 0xfd9db5 [io.javascript.0] 2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[6]: 6: 0xfda366 v8::internal::Heap::RecomputeLimits(v8::internal::GarbageCollector) [io.javascript.0] 2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[7]: 7: 0xfec656 [io.javascript.0] 2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[8]: 8: 0xfed295 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0] 2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[9]: 9: 0xfef978 v8::internal::Heap::HandleGCRequest() [io.javascript.0] 2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[10]: 10: 0xf69be7 v8::internal::StackGuard::HandleInterrupts() [io.javascript.0] 2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[11]: 11: 0x13bd365 v8::internal::Runtime_StackGuard(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0] 2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[12]: 12: 0x18443f9 [io.javascript.0] 2024-01-15 21:09:17.522 - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGABRT 2024-01-15 21:09:17.522 - info: host.iobroker instance system.adapter.javascript.0 terminated with code null () 2024-01-15 21:09:17.523 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled 2024-01-15 21:09:47.865 - info: host.iobroker instance system.adapter.javascript.0 started with pid 253608 2024-01-15 21:09:52.402 - info: javascript.0 (253608) starting. Version 7.1.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v19.9.0, js-controller: 5.0.17 2024-01-15 21:09:55.489 - info: javascript.0 (253608) requesting all states 2024-01-15 21:09:55.492 - info: javascript.0 (253608) requesting all objects 2024-01-15 21:10:01.666 - info: javascript.0 (253608) received all objects 2024-01-15 21:10:03.022 - info: javascript.0 (253608) received all states 2024-01-15 21:10:03.796 - info: javascript.0 (253608) Start javascript script.js.2021-04-09-scripts.Abfragen.Garagentor_Auf_Fährt_Zu
es wurden keine neuen Scripte erstellt oder geändert.
System läuft auf einem Proxmox Container unter Ubuntu.@iobroker:~# npm -v 9.6.3 @iobroker:~# node -v v19.9.0 @iobroker:~# nodejs -v -bash: nodejs: command not found @iobroker:~# iob status iobroker is running on this host. Objects type: jsonl States type: jsonl
Danke im voraus und viele Grüße
@blue231181 sagte in Javascript Adapter stürzt ab:
Was sagt
iob diag
Für die nodejs und npm version wirst du gleich auf die Finger bekommen
Zieh das erstmal gerade. Wie ist das nodejs auf das System gekommen? Wahrscheinlich nicht über apt?!
@haus-automatisierung sagte in Javascript Adapter stürzt ab:
3 ... 2 ... 1
NICHT als root herumhampeln. (Auch wenn du den verschämt löschst sieht man das noch...)
Als USER!:
iob nodejs-update 18
@Codierknecht
@haus-automatisierung (wow ich glaubs nicht mein persönlicher youtube Held, danke für all die genialen Videos und super Erklärungen)
@Homoran
euch allen Danke erstmal das ihr hier im Forum so aktiv seid und es zu dem macht was ioBroker ausmacht@Codierknecht ich habe einen neuen Benutzer angelegt. @Thomas-Braun hat recht ich habe es zu meiner Schande schön verstecken wollen. Nun mit dem neuen Benutzer kommt folgende Meldung:
Sorry, user blue2311 is not allowed to execute '/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh' as iobroker on iobroker.local.
Also habe ich das folgende durchgelesen: ioBroker Forum diag-skript was ich feststellen musste, von @Thomas-Braun entwickelt wurde. Hier hat Thomas wohl auch die LXC Container (Proxmox) mit auslesen können.
Nun habe ich mal meine Version überprüft und folgendes ist heraus gekommen:blue2311@iobroker:~$ cat /etc/*release PRETTY_NAME="Debian GNU/Linux 11 (bullseye)" NAME="Debian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/"
Also muss ich zu meiner weiteren Schande gestehen das es kein Ubuntu System ist, sondern ein Bullseye 11 Debian.
@haus-automatisierung "Für die nodejs und npm version wirst du gleich auf die Finger bekommenZieh das erstmal gerade. Wie ist das nodejs auf das System gekommen? Wahrscheinlich nicht über apt?!" mit "apt-get" konnte ich diverse updates fahren..
"Für die nodejs und npm version wirst du gleich auf die Finger bekommen" bitte nicht. Ich bin kein entwickler, hab auch niemals Informatiker gelernt aber mir macht es als Hobby Spass und ich bin unendlich dankbar hier im Forum immer wieder auf so nette und hilfsbereite Menschen zu treffen. Also nicht hauen
und zu guter letzt @Thomas-Braun:
blue2311@iobroker:~$ iob nodejs-update 18 [sudo] password for blue2311: Sorry, user blue2311 is not allowed to execute '/usr/bin/curl -sLf https://iobroker.net/node-update.sh --output /home/iobroker/.nodejs-update.sh' as iobroker on iobroker.local.
blue2311
Dann ist der user nicht in den rudimentärsten Gruppen drin.
Als dieser User:
groups
das gilt hier für >90% der User.
aber node v19 kommt dann üblicherweise nicht bei raus
das ist das Problem wenn nicht von Anfang an mit dem User gearbeitet wird, dann hat er nicht automatisch die notwendigen Rechte und/oder die Nutzung von Root hat gewisse Rechte verbogen, dass der Systemuser iobroker und dein neuer User da nicht dran dürfen.
Erschwerend kommt dein Konstrukt mit Container dazu, wo wiederum zusätzlich Dinge richtig eingestellt sein müssen
In der Doku steht auch drin, wie man im Container einen user anlegt:
https://www.iobroker.net/#de/documentation/install/proxmox.md
@thomas-braun @Homoran also wäre eine Neuinstallation mit einspielen des Backups am sinnvollsten wenn so viel schief liegt?
Das musst du selber entscheiden.
@thomas-braun ja ich versuchs mit Neuinstallation bevor ich das krumme System anpasse
Danke an alle
@blue231181 sagte in [gelöst] Javascript Adapter stürzt ab:
Gern, dort habe ich übrigens auch gezeigt wie man einen neuen Benutzer im LXC anlegt usw.
muss hier leider wieder öffnen.
Habe nach bestem Wissen und gewissen mein System gerade gezogen
Leider stürzt der Javascript Adapter weiterhin ab.
Hier der Auszug vom Iob Diag======== Start marking the full check here ========= Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: iobroker Icon name: computer-container Chassis: container Virtualization: lxc Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 5.15.131-2-pve Architecture: x86-64 model name : Intel(R) Celeron(R) CPU J1900 @ 1.99GHz Docker : false Virtualization : lxc Kernel : x86_64 Userland : amd64 Systemuptime and Load: 05:45:53 up 21:39, 1 user, load average: 1.82, 1.66, 1.35 CPU threads: 4 *** Time and Time Zones *** Local time: Thu 2024-01-18 05:45:53 CET Universal time: Thu 2024-01-18 04:45:53 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: inactive RTC in local TZ: no *** User and Groups *** blue2311 /home/blue2311 blue2311 sudo *** X-Server-Setup *** X-Server: false Desktop: Terminal: Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 7.8G 3.7G 3.5G 0.0K 592M 4.1G Swap: 0B 0B 0B Total: 7.8G 3.7G 3.5G 7822 M total memory 3689 M used memory 167 M active memory 3918 M inactive memory 3541 M free memory 0 M buffer memory 592 M swap cache 0 M total swap 0 M used swap 0 M free swap *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System * sys-kernel-config.mount loaded failed failed Kernel Configuration File System * systemd-journald-audit.socket loaded failed failed Journal Audit Socket LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 3 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/mapper/pve-vm--100--disk--0 ext4 42G 11G 29G 27% / none tmpfs 492K 4.0K 488K 1% /dev /dev/mapper/pve-root ext4 29G 20G 7.7G 73% /dev/ttyACM0 udev devtmpfs 3.8G 0 3.8G 0% /dev/tty tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 1.6G 104K 1.6G 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock Messages concerning ext4 filesystem in dmesg: dmesg: read kernel buffer failed: Operation not permitted Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/pve-vm--100--disk--0 ext4 rw,relatime,stripe=16 `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/189/devices/ttyACM0] ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 3.2G /var/ 2.6G /var/log/journal/4b4c08ea54a04d2e89ddb21f3e8976ed 2.6G /var/log/journal 2.6G /var/log 466M /var/cache Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 8.0M in the file system. /opt/iobroker/backups: 521M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 2.3G /opt/iobroker/iobroker-data/ 1.1G /opt/iobroker/iobroker-data/history 706M /opt/iobroker/iobroker-data/files 299M /opt/iobroker/iobroker-data/backup-objects 142M /opt/iobroker/iobroker-data/files/vis.0 The five largest files in iobroker-data are: 70M /opt/iobroker/iobroker-data/objects.jsonl 65M /opt/iobroker/iobroker-data/states.jsonl 41M /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map 40M /opt/iobroker/iobroker-data/objects.json.migrated 40M /opt/iobroker/iobroker-data/objects.json.bak.migrated USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2410075-if00 *** NodeJS-Installation *** /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.0-1nodesource1 Version table: *** 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 12.22.12~dfsg-1~deb11u4 500 500 http://ftp.debian.org/debian bullseye/main amd64 Packages 500 http://security.debian.org bullseye-security/main amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.17 admin: 6.12.0 javascript: 7.1.6 Adapters from github: 4 Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.admin.1 : admin : iobroker - disabled, port: 8083, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.1 : alexa2 : iobroker - enabled system.adapter.alias-manager.0 : alias-manager : iobroker - disabled + system.adapter.backitup.0 : backitup : iobroker - enabled + system.adapter.cloud.0 : cloud : iobroker - enabled system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker - disabled + system.adapter.countdown.0 : countdown : iobroker - enabled system.adapter.daswetter.0 : daswetter : iobroker - enabled + system.adapter.device-reminder.0 : device-reminder : iobroker - enabled system.adapter.devices.0 : devices : iobroker - disabled + system.adapter.discovery.0 : discovery : iobroker - enabled system.adapter.dwd.0 : dwd : iobroker - enabled system.adapter.email.0 : email : iobroker - disabled system.adapter.eusec.0 : eusec : iobroker - disabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : iobroker - enabled system.adapter.flot.0 : flot : iobroker - disabled system.adapter.fritzbox.0 : fritzbox : iobroker - disabled system.adapter.fullybrowser.0 : fullybrowser : iobroker - disabled system.adapter.heizoel.0 : heizoel : iobroker - disabled + system.adapter.history.0 : history : iobroker - enabled + system.adapter.hmip.0 : hmip : iobroker - enabled system.adapter.ical.0 : ical : iobroker - enabled system.adapter.ical.1 : ical : iobroker - enabled system.adapter.icons-fatcow-hosting.0 : icons-fatcow-hosting : iobroker - disabled system.adapter.icons-material-png.0 : icons-material-png : iobroker - disabled system.adapter.icons-material-svg.0 : icons-material-svg : iobroker - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker - disabled + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086 + system.adapter.info.0 : info : iobroker - enabled + system.adapter.iot.0 : iot : iobroker - enabled + system.adapter.javascript.0 : javascript : iobroker - enabled system.adapter.kodi.0 : kodi : iobroker - disabled, port: 8080 system.adapter.lgtv.0 : lgtv : iobroker - disabled system.adapter.linux-control.0 : linux-control : iobroker - disabled + system.adapter.logparser.0 : logparser : iobroker - enabled + system.adapter.net-tools.0 : net-tools : iobroker - enabled + system.adapter.nut.0 : nut : iobroker - enabled + system.adapter.octoprint.0 : octoprint : iobroker - enabled system.adapter.openweathermap.0 : openweathermap : iobroker - enabled + system.adapter.ping.0 : ping : iobroker - enabled + system.adapter.pollenflug.0 : pollenflug : iobroker - enabled + system.adapter.proxmox.0 : proxmox : iobroker - enabled, port: 8006 + system.adapter.proxmox.1 : proxmox : iobroker - enabled, port: 8006 + system.adapter.pvforecast.0 : pvforecast : iobroker - enabled system.adapter.rpi2.0 : rpi2 : iobroker - disabled + system.adapter.scenes.0 : scenes : iobroker - enabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 7770, bind: 0.0.0.0, run as: admin system.adapter.snmp.0 : snmp : iobroker - disabled + system.adapter.socketio.0 : socketio : iobroker - enabled, port: 7769, bind: 0.0.0.0, run as: admin system.adapter.solarmanpv.0 : solarmanpv : iobroker - enabled + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.tr-064.0 : tr-064 : iobroker - enabled system.adapter.tr-064.1 : tr-064 : iobroker - disabled + system.adapter.trashschedule.0 : trashschedule : iobroker - enabled + system.adapter.tuya.0 : tuya : iobroker - enabled system.adapter.tvspielfilm.0 : tvspielfilm : iobroker - disabled + system.adapter.upnp.0 : upnp : iobroker - enabled system.adapter.vis-bars.0 : vis-bars : iobroker - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : iobroker - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - disabled system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker - disabled system.adapter.vis-justgage.0 : vis-justgage : iobroker - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : iobroker - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker - disabled system.adapter.vis-metro.0 : vis-metro : iobroker - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - disabled system.adapter.vis.0 : vis : iobroker - enabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker - disabled system.adapter.windows-control.0 : windows-control : iobroker - disabled + system.adapter.wled.0 : wled : iobroker - enabled system.adapter.worx.0 : worx : iobroker - disabled + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyACM0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086 + system.adapter.proxmox.0 : proxmox : iobroker - enabled, port: 8006 + system.adapter.proxmox.1 : proxmox : iobroker - enabled, port: 8006 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 7770, bind: 0.0.0.0, run as: admin + system.adapter.socketio.0 : socketio : iobroker - enabled, port: 7769, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyACM0 ioBroker-Repositories New : http://iobroker.live/repo/sources-dist.json stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.12.0 , installed 6.12.0 Adapter "alexa2" : 3.26.3 , installed 3.26.3 Adapter "alias-manager": 1.2.6 , installed 1.2.6 Adapter "backitup" : 2.9.8 , installed 2.9.8 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "coronavirus-statistics": 0.9.0, installed 0.8.8-0 [Updatable] Adapter "countdown" : 2.2.0 , installed 2.2.0 Adapter "daswetter" : 3.1.12 , installed 3.1.12 Adapter "device-reminder": 3.0.0 , installed 3.0.0 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "email" : 1.2.1 , installed 1.2.1 Adapter "eusec" : 1.2.1 , installed 1.2.1 Adapter "fb-checkpresence": 1.2.2 , installed 1.2.2 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzbox" : 0.5.0 , installed 0.5.0 Adapter "fullybrowser" : 3.0.9 , installed 2.0.4 [Updatable] Adapter "heizoel" : 1.0.3 , installed 1.0.3 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hmip" : 1.21.0 , installed 1.21.0 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-fatcow-hosting": 0.1.0, installed 0.1.0 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "influxdb" : 3.2.0 , installed 3.2.0 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "iot" : 2.0.11 , installed 2.0.11 Adapter "javascript" : 7.1.6 , installed 7.1.6 Controller "js-controller": 5.0.17 , installed 5.0.17 Adapter "kodi" : 3.0.0 , installed 3.0.0 Adapter "lgtv" : 2.1.2 , installed 2.1.2 Adapter "linux-control": 1.1.5 , installed 1.1.5 Adapter "logparser" : 2.2.1 , installed 2.2.1 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "nut" : 1.6.0 , installed 1.6.0 Adapter "octoprint" : 5.1.0 , installed 5.1.0 Adapter "openweathermap": 0.4.5 , installed 0.4.5 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "proxmox" : 2.2.2 , installed 2.2.2 Adapter "pvforecast" : 2.9.1 , installed 2.9.1 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 6.6.1 , installed 6.6.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "snmp" : 3.1.0 , installed 2.4.11 [Updatable] Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "solarmanpv" : 0.5.1 , installed 0.5.1 Adapter "sonoff" : 3.0.3 , installed 2.5.3 [Updatable] Adapter "tankerkoenig" : 3.3.7 , installed 2.1.1 [Updatable] Adapter "telegram" : 3.0.1 , installed 3.0.1 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "trashschedule": 2.3.0 , installed 2.3.0 Adapter "tuya" : 3.15.0 , installed 3.6.5 [Updatable] Adapter "tvspielfilm" : 2.0.5 , installed 2.0.4 [Updatable] Adapter "unifi" : 0.6.7 , installed 0.6.6 [Updatable] Adapter "upnp" : 1.0.21 , installed 1.0.21 Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 1.3.0 , installed 1.3.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-justgage" : 2.1.0 , installed 2.1.0 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 6.1.10 , installed 6.1.10 Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3 Adapter "windows-control": 0.1.5 , installed 0.1.5 Adapter "wled" : 0.7.2 , installed 0.7.2 Adapter "worx" : 2.3.4 , installed 2.1.3 [Updatable] Adapter "ws" : 2.5.8 , installed 2.5.8 Adapter "zigbee" : 1.9.7 , installed 1.8.24 [Updatable] Objects and States Please stand by - This may take a while Objects: 32363 States: 26941 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org bullseye-security InRelease Hit:2 http://ftp.debian.org/debian bullseye InRelease Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1000 46666067 120/iobroker.js-con tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1000 46666075 120/iobroker.js-con tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 0 46667947 289/master tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 104 46666916 108/systemd-resolve tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 46665812 1/init tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1000 47647964 30207/io.sonoff.0 tcp 0 0 0.0.0.0:5355 0.0.0.0:* LISTEN 104 46666910 108/systemd-resolve tcp6 0 0 ::1:25 :::* LISTEN 0 46667948 289/master tcp6 0 0 :::8082 :::* LISTEN 1000 46677868 1462/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1000 46666242 307/io.admin.0 tcp6 0 0 :::8000 :::* LISTEN 1000 46683978 1398/io.upnp.0 tcp6 0 0 :::7770 :::* LISTEN 1000 46676821 1261/io.simple-api. tcp6 0 0 :::7769 :::* LISTEN 1000 46676885 1284/io.socketio.0 tcp6 0 0 :::22 :::* LISTEN 0 46665611 1/init tcp6 0 0 :::111 :::* LISTEN 0 46665814 1/init tcp6 0 0 :::5355 :::* LISTEN 104 46666913 108/systemd-resolve udp 0 0 0.0.0.0:5353 0.0.0.0:* 1000 46678967 1473/io.wled.0 udp 0 0 192.168.178.100:5353 0.0.0.0:* 1000 46671958 548/io.tr-064.0 udp 0 0 0.0.0.0:5355 0.0.0.0:* 104 46666909 108/systemd-resolve udp 0 0 0.0.0.0:5683 0.0.0.0:* 1000 46972090 8939/io.shelly.0 udp 0 0 0.0.0.0:54955 0.0.0.0:* 1000 46678822 1398/io.upnp.0 udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 46677926 1398/io.upnp.0 udp 0 0 0.0.0.0:6666 0.0.0.0:* 1000 46670144 565/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1000 46670145 565/io.tuya.0 udp 0 0 127.0.0.53:53 0.0.0.0:* 104 46666915 108/systemd-resolve udp 0 0 0.0.0.0:111 0.0.0.0:* 0 46665813 1/init udp6 0 0 :::5355 :::* 104 46666912 108/systemd-resolve udp6 0 0 :::111 :::* 0 46665815 1/init *** Log File - Last 25 Lines *** 2024-01-18 05:42:06.483 - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634911.225508433.HWv1" has to be type "string" but received type "number" 2024-01-18 05:42:06.851 - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634911.225508433.NOP" has to be type "number" but received type "string" 2024-01-18 05:42:08.285 - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634926.225510526.DEV_TYP1" has to be type "number" but received type "string" 2024-01-18 05:42:08.365 - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634926.225510526.COMM_PTC_v1" has to be type "string" but received type "number" 2024-01-18 05:42:08.419 - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634926.225510526.HWv1" has to be type "string" but received type "number" 2024-01-18 05:42:08.856 - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634926.225510526.NOP" has to be type "number" but received type "string" 2024-01-18 05:42:10.733 - error: zigbee.0 (583) Send command to 0xc4988600000060aa failed with no error code (no response received (161) 2024-01-18 05:42:10.808 - info: solarmanpv.0 (120094) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule 2024-01-18 05:42:11.349 - info: host.iobroker instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2024-01-18 05:45:00.070 - info: host.iobroker instance system.adapter.ical.1 started with pid 120404 2024-01-18 05:45:00.202 - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Durchgang Zähler LUX : 10 2024-01-18 05:45:00.202 - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Aktuelle LUX = 0 2024-01-18 05:45:00.204 - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Aussenlichtstaerke Mittelwert = 0 2024-01-18 05:45:00.205 - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Zahlen aufsteigend sortiert: 0,0,0,0,0,0,0,0,0,0 2024-01-18 05:45:00.206 - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Auswahl der Liste 7-9 : 0,0,0,0,0,0 2024-01-18 05:45:00.206 - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: errechneter Mittelwert: 0 2024-01-18 05:45:03.942 - info: ical.1 (120404) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17 2024-01-18 05:45:12.852 - info: ical.1 (120404) Terminated (NO_ERROR): Without reason 2024-01-18 05:45:13.399 - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
iob diag has finished.
Press any key for a summary
======================= SUMMARY ======================= v.2023-10-10 Static hostname: iobroker Icon name: computer-container Chassis: container Virtualization: lxc Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 5.15.131-2-pve Architecture: x86-64 Installation: lxc Kernel: x86_64 Userland: amd64 Timezone: Europe/Berlin (CET, +0100) User-ID: 1001 X-Server: false Boot Target: graphical.target Pending OS-Updates: 0 Pending iob updates: 10 Nodejs-Installation: /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 Recommended versions are nodejs 18.19.0 and npm 10.2.3 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 7.8G 3.8G 3.3G 0.0K 703M 4.0G Swap: 0B 0B 0B Total: 7.8G 3.8G 3.3G Active iob-Instances: 40 Active repo(s): stable ioBroker Core: js-controller 5.0.17 admin 6.12.0 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.admin.1 : admin : iobroker - disabled, port: 8083, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 32363 States: 26941 Size of iob-Database: 81M /opt/iobroker/iobroker-data/objects.jsonl 40M /opt/iobroker/iobroker-data/objects.json.migrated 40M /opt/iobroker/iobroker-data/objects.json.bak.migrated 9.5M /opt/iobroker/iobroker-data/states.json.migrated 9.5M /opt/iobroker/iobroker-data/states.json.bak.migrated 9.4M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ====================
Hier der Auszug aus den Logs:
2024-01-17 22:12:07.737 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634911.225508433.DEV_TYP1" has to be type "number" but received type "string" 2024-01-17 22:12:07.819 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634911.225508433.COMM_PTC_v1" has to be type "string" but received type "number" 2024-01-17 22:12:07.873 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634911.225508433.HWv1" has to be type "string" but received type "number" 2024-01-17 22:12:08.290 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634911.225508433.NOP" has to be type "number" but received type "string" 2024-01-17 22:12:09.634 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634926.225510526.DEV_TYP1" has to be type "number" but received type "string" 2024-01-17 22:12:09.721 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634926.225510526.COMM_PTC_v1" has to be type "string" but received type "number" 2024-01-17 22:12:09.774 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634926.225510526.HWv1" has to be type "string" but received type "number" 2024-01-17 22:12:10.226 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634926.225510526.NOP" has to be type "number" but received type "string" 2024-01-17 22:12:11.201 - info: solarmanpv.0 (79070) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule 2024-01-17 22:12:11.740 - info: host.iobroker instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2024-01-17 22:14:19.619 - error: host.iobroker Caught by controller[0]: <--- Last few GCs ---> 2024-01-17 22:14:19.619 - error: host.iobroker Caught by controller[0]: [64004:0x6cde870] 9870984 ms: Scavenge 2044.5 (2084.6) -> 2044.0 (2085.4) MB, 14.7 / 0.0 ms (average mu = 0.183, current mu = 0.193) allocation failure; 2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: <--- JS stacktrace ---> 2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory 2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: 1: 0xb95b60 node::Abort() [io.javascript.0] 2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: 2: 0xa9a7f8 [io.javascript.0] 2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0] 2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0] 2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[0]: 5: 0xf4cba5 [io.javascript.0] 2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[0]: 6: 0xf4daa8 v8::internal::Heap::RecomputeLimits(v8::internal::GarbageCollector) [io.javascript.0] 2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[1]: 7: 0xf5dfb3 [io.javascript.0] 2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[1]: 8: 0xf5ee28 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0] 2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[1]: 9: 0xf3978e v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0] 2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[2]: 10: 0xf3ab57 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0] 2024-01-17 22:14:19.622 - error: host.iobroker Caught by controller[2]: 11: 0xf1bd2a v8::internal::Factory::NewFillerObject(int, v8::internal::AllocationAlignment, v8::internal::AllocationType, v8::internal::AllocationOrigin) [io.javascript.0] 2024-01-17 22:14:19.622 - error: host.iobroker Caught by controller[2]: 12: 0x12e114f v8::internal::Runtime_AllocateInYoungGeneration(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0] 2024-01-17 22:14:19.622 - error: host.iobroker Caught by controller[3]: 13: 0x170deb9 [io.javascript.0] 2024-01-17 22:14:19.622 - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGABRT 2024-01-17 22:14:19.623 - info: host.iobroker instance system.adapter.javascript.0 terminated with code null () 2024-01-17 22:14:19.623 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
2024-01-17 19:24:00.046 - info: host.iobroker instance system.adapter.solarmanpv.0 started with pid 63515 2024-01-17 19:24:03.269 - info: solarmanpv.0 (63515) starting. Version 0.5.1 (non-npm: raschy/ioBroker.solarmanpv) in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v18.19.0, js-controller: 5.0.17 2024-01-17 19:24:08.390 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634911.225508433.DEV_TYP1" has to be type "number" but received type "string" 2024-01-17 19:24:08.475 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634911.225508433.COMM_PTC_v1" has to be type "string" but received type "number" 2024-01-17 19:24:08.531 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634911.225508433.HWv1" has to be type "string" but received type "number" 2024-01-17 19:24:08.934 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634911.225508433.NOP" has to be type "number" but received type "string" 2024-01-17 19:24:10.435 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634926.225510526.DEV_TYP1" has to be type "number" but received type "string" 2024-01-17 19:24:10.507 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634926.225510526.COMM_PTC_v1" has to be type "string" but received type "number" 2024-01-17 19:24:10.562 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634926.225510526.HWv1" has to be type "string" but received type "number" 2024-01-17 19:24:10.973 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634926.225510526.NOP" has to be type "number" but received type "string" 2024-01-17 19:24:12.062 - info: solarmanpv.0 (63515) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule 2024-01-17 19:24:12.644 - info: host.iobroker instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2024-01-17 19:25:00.192 - info: javascript.0 (51920) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Durchgang Zähler LUX : 7 2024-01-17 19:25:00.194 - info: javascript.0 (51920) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Aktuelle LUX = 0 2024-01-17 19:25:00.194 - info: javascript.0 (51920) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Aussenlichtstaerke Mittelwert = 0 2024-01-17 19:29:07.194 - error: host.iobroker Caught by controller[0]: <--- Last few GCs ---> 2024-01-17 19:29:07.195 - error: host.iobroker Caught by controller[0]: [51920:0x717f870] 8062565 ms: Scavenge 2044.2 (2084.9) -> 2043.7 (2089.4) MB, 16.4 / 0.0 ms (average mu = 0.179, current mu = 0.167) allocation failure; 2024-01-17 19:29:07.195 - error: host.iobroker Caught by controller[0]: [51920:0x717f870] 8068108 ms: Mark-sweep (reduce) 2045.7 (2089.4) -> 2044.7 (2084.1) MB, 4609.8 / 0.0 ms (+ 97.8 ms in 31 steps since start of marking, biggest step 5.9 ms, walltime since start of marking 4746 ms) (average mu = 0.172, current mu = 0.164 2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[1]: <--- JS stacktrace ---> 2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[2]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory 2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[3]: 1: 0xb95b60 node::Abort() [io.javascript.0] 2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[4]: 2: 0xa9a7f8 [io.javascript.0] 2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[5]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0] 2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[6]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0] 2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[7]: 5: 0xf4cba5 [io.javascript.0] 2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[8]: 6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0] 2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[9]: 7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [io.javascript.0] 2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[10]: 8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [io.javascript.0] 2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[11]: 9: 0x12e0bcf v8::internal::Runtime_StackGuardWithGap(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0] 2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[12]: 10: 0x170deb9 [io.javascript.0] 2024-01-17 19:29:07.197 - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGABRT 2024-01-17 19:29:07.198 - info: host.iobroker instance system.adapter.javascript.0 terminated with code null () 2024-01-17 19:29:07.198 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled 2024-01-17 19:29:37.457 - info: host.iobroker instance system.adapter.javascript.0 started with pid 64004
@blue231181
1.) Entferne die privaten Daten aus dem Log!
2.) Was passiert, wenn Du alle Scripte mal stoppst? Bleibt der Adapter am Leben? -
@codierknecht private daten...? meine IP Adresse?
Stimmt das könnte ich versuchen. Alle Skripte beenden, und nach und nach wieder starten. Das wird ein längerer Akt weil der Fehler nur alle 3 Stunden auftritt, aber ich versuche es
Danke -
Nein - Die Kalender-ID's
In der Langfassung von diag.weil der Fehler nur alle 3 Stunden auftritt
Und was passiert alle 3 Stunden?
Läuft der vielleicht in genau diesem Intervall?
Keine Ahnung ob das auch hier zutreffen könnte - einen Zusammenhang mit 3h Intervall sehe ich da nicht - aber hier ging es um einen Crash des Javascript Adapters bei eine zu größen Anzahl von States (70.000 Alarmstates des unifi Adapters)
@codierknecht Danke für den Hinweis
Was euch alles auffälltAlso der Solarmanpv läuft alle 8 Min.
3 stunden Intervall ist mir nichts bekannt. Ich habe alle Scripte nun mal deaktiviert und teste mich durch.
@mcm57 den Adapter habe ich schon deaktiviert und die zugehörigen States gelöscht, ja damit hatte ich auch Probleme und massiv viele States die er mir angelegt hat
