    4. Test Adapter PSA v0.0.x Peugeot Opel Citroen
      wolkenschaufler last edited by
      Hallo Zusammen,
      Ich hätte die Integration auch gerne benutzt, allerdings kommt bei meinem e-208 folgende Fehlermeldung:
      2023-04-08 13:30:07.423 - error: psa.0 (204181) AxiosError: Request failed with status code 400
      2023-04-08 13:30:07.424 - error: psa.0 (204181) Login failed
      2023-04-08 13:30:07.424 - error: psa.0 (204181) {"error":"invalid_grant","error_description":"The provided access grant is invalid, expired, or revoked."}
      2023-04-08 13:30:07.425 - error: psa.0 (204181) Login failed
      2023-04-08 13:30:07.614 - warn: psa.0 (204181) {"returnCode":"AUTHENTICATION_FAILED"}
      2023-04-08 13:30:07.615 - warn: psa.0 (204181) No Token received for old api
      2023-04-08 13:30:07.999 - warn: psa.0 (204181) {"returnCode":"AUTHENTICATION_FAILED"}
      2023-04-08 13:30:07.999 - warn: psa.0 (204181) No Token received for old api
      Ist das etwas bekannt?
        Fenrir last edited by
        habe auch seit heute die Meldung:
        psa.0
        	2023-04-18 16:39:55.879	warn	{"code":"495","message":"Invalid or expired client certificate"}
        psa.0
        	2023-04-18 16:39:55.878	warn	receive new api failed
        psa.0
        	2023-04-18 16:39:55.878	warn	AxiosError: Request failed with status code 495
        psa.0
        	2023-04-18 16:39:55.827	warn	OldAPI Login failed, only relevant for non eletric cars
        psa.0
        	2023-04-18 16:39:55.827	warn	{"code":"495","message":"Invalid or expired client certificate"}
        psa.0
        	2023-04-18 16:39:55.827	warn	receive old api failed
        psa.0
        	2023-04-18 16:39:55.827	warn	AxiosError: Request failed with status code 495
        psa.0
        	2023-04-18 16:39:55.742	info	Login successful
        psa.0
        	2023-04-18 16:39:55.050	info	starting. Version 0.0.11 (non-npm: TA2k/ioBroker.psa#f4ab91d11df215aa59eb70a064fdf9eaba7c0af4) in /opt/iobroker/node_modules/iobroker.psa, node: v16.19.1, js-controller: 4.0.24
          roughestboy last edited by
          Ich hatte bisher den psa Adapter am laufen (mit einem e 208), zumindest gabs bisher verlässliche updates zum Km-Stand und zum Batterieladestand, die ich beide in VIS angezeigt habe. Seit heute morgen geht da gar nichts mehr, auch nicht in der Handy-App. Vielleicht weiß ja ein Insider, was da los ist ?
          Protokoll:
          psa.0
          2023-08-03 21:52:42.664 warn OldAPI Login failed, only relevant for non eletric cars
          psa.0
          2023-08-03 21:52:42.664 warn {"code":"495","message":"Invalid or expired client certificate"}
          psa.0
          2023-08-03 21:52:42.663 warn receive old api failed
          psa.0
          2023-08-03 21:52:42.662 warn AxiosError: Request failed with status code 495
          psa.0
          2023-08-03 21:52:42.646 warn {"code":"495","message":"Invalid or expired client certificate"}
          psa.0
          2023-08-03 21:52:42.645 warn receive new api failed
          psa.0
          2023-08-03 21:52:42.644 warn AxiosError: Request failed with status code 495
          psa.0
          2023-08-03 21:52:42.466 info Login successful
          psa.0
          2023-08-03 21:52:41.809 info starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.psa, node: v16.20.1, js-controller: 5.0.8
          psa.0
          2023-08-03 21:52:36.774 info terminating
          psa.0
          2023-08-03 21:52:36.267 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          psa.0
          2023-08-03 21:52:36.264 info terminating
          psa.0
          2023-08-03 21:52:36.261 info Got terminate signal TERMINATE_YOURSELF
          • RaspiUser
            RaspiUser last edited by
            @tombox
            ... seit ca. 17 Uhr dieser Log-Eintrag bei einem Corsa-e:
            2024-01-10 20:45:50.282 - error: psa.0 (6275) AxiosError: Request failed with status code 400
            2024-01-10 20:45:50.284 - error: psa.0 (6275) Login failed
            2024-01-10 20:45:50.285 - error: psa.0 (6275) {"error_description":"Internal Server Error","error":"server_error"}
            2024-01-10 20:45:50.286 - error: psa.0 (6275) Login failed
            Ein PSA-Opel-Server-Problem und einfach abwarten oder der Adapter ?
              hier das selbe, gestern ging der Adapter noch.
              psa.0
              	2024-01-11 19:25:39.833	error	Get device status failed
              psa.0
              	2024-01-11 19:25:39.833	error	Refreshtoken failed
              psa.0
              psa.0
              	2024-01-11 19:25:39.832	error	Error: read ECONNRESET
              psa.0
              	2024-01-11 19:10:39.744	error	Get device status failed
              psa.0
              	2024-01-11 19:10:39.744	error	Refreshtoken failed
              psa.0
              psa.0
              	2024-01-11 19:10:39.744	error	Error: read ECONNRESET
              • RaspiUser
                RaspiUser last edited by RaspiUser
                ... ist wohl ein OPEL Problem ...
                EDIT:
                ... und das ist die Antwort seitens OPEL nach 3 Tagen ...:
                vielen Dank für Ihre E-Mail.
                Wir freuen uns, dass Sie sich für ein Fahrzeug aus unserem Hause entschieden haben und
                bedanken uns für das damit ausgesprochene Vertrauen.
                Wir bedanken uns bei Ihnen, dass Sie sich die Mühe gemacht haben, Ihre Kritik an uns zu richten.
                Dies zeigt uns, dass Sie sich intensiv mit unseren Fahrzeugen auseinander setzen und sich Gedanken darüber machen,
                ob und wo Verbesserungspotential besteht.
                Derartige Rückmeldungen sind für uns wichtig, denn sie zeigen uns, wie wir noch individueller auf die Wünsche
                unserer Kunden eingehen können.
                Selbstverständlich sind wir laufend um Innovationen bemüht.
                Ihre Anmerkungen haben wir zur Kenntnis genommen und bereits an zuständigen Fachabteilung weitergeleitet.
                Wir bedanken uns, dass Sie sich an den Opel Kundenservice gewendet haben.
                Chris_Carryflag A 2 Replies Last reply Reply Quote 0
                • Chris_Carryflag
                  Chris_Carryflag @RaspiUser last edited by
                  @raspiuser
                  Na klasse. Eine typische Textbausteinantwort vom Kundenservice.
                  Na dann muss ich wohl noch ein paar Tage den SOC vom Fahrzeug manuell in die Ladesteuerung im iobroker eintragen, um das Laden bei 80% zu beenden. seufz
                  Aber vielen Dank, dass du uns hier mit der Antwort auf dem Laufenden hältst!
                    ausmaus @RaspiUser last edited by
                    @raspiuser said in Test Adapter PSA v0.0.x Peugeot Opel Citroen:
                    EDIT:
                    Ist nun unter https://my.opel.com/de/de wieder erreichbar
                    RaspiUser 1 Reply Last reply Reply Quote 0
                    • RaspiUser
                      RaspiUser @ausmaus last edited by RaspiUser
                      @ausmaus sagte in Test Adapter PSA v0.0.x Peugeot Opel Citroen:
                      ... stimmt ... und mein Konto gibt es (scheinbar) nicht mehr ... bei Dir auch, nehme ich an ?!
                      Edit:
                      ... ich habe nun ein neues Kto. angelegt, Mailadresse beibehalten, neues Passwort.
                      Unser Corsa war, ohne ihn neu einzugeben (?), bereits im Kto. vorhanden ...
                      Im Adapter habe ich die neuen Daten eingegeben ... er bleibt aber gelb
                      Hier der Log ...
                      psa.0
                      	2024-01-16 12:12:31.012	warn	OldAPI Login failed, only relevant for non eletric cars
                      psa.0
                      	2024-01-16 12:12:31.011	warn	receive old api failed
                      psa.0
                      	2024-01-16 12:12:31.011	warn	Error: unsupported
                      psa.0
                      	2024-01-16 12:12:31.003	warn	receive new api failed
                      psa.0
                      	2024-01-16 12:12:31.002	warn	Error: unsupported
                      psa.0
                      	2024-01-16 12:12:30.613	error	Login failed
                      psa.0
                      	2024-01-16 12:12:30.613	error	{"error_description":"Internal Server Error","error":"server_error"}
                      psa.0
                      	2024-01-16 12:12:30.612	error	Login failed
                      psa.0
                      	2024-01-16 12:12:30.612	error	AxiosError: Request failed with status code 400
                      psa.0
                      	2024-01-16 12:12:30.272	info	starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.psa, node: v18.19.0, js-controller: 5.0.17
                      psa.0
                      	2024-01-16 12:12:26.430	info	terminating
                      psa.0
                      	2024-01-16 12:12:25.928	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      psa.0
                      	2024-01-16 12:12:25.927	info	terminating
                      psa.0
                      	2024-01-16 12:12:25.926	info	Got terminate signal TERMINATE_YOURSELF
                      @tombox
                      Deine Meinung ?
                      Edit:
                      ... noch ein Hinweis / Erkenntnis ...
                      Ich habe alle Objekte gelöscht und den Adapter neu gestartet ... das war die Antwort ...
                      6f658388-61e5-48b6-93ab-d290a2dc9674-grafik.png `
                      Chris_Carryflag 1 Reply Last reply Reply Quote 0
                      • Chris_Carryflag
                        @raspiuser
                        Mein Opel-Konto ist zwar noch vorhanden (ich konnte mich mit den alten Zugangsdaten einloggen). Beim Neustart des PSA-Adapters im iobroker kommt jedoch auch die Fehlermeldung "Internal Server Error" und der Adapter bekommt weiterhin keine Verbindung.
                        • RaspiUser
                          ... ich nehme mal an, dass es (noch?) keine Lösung gibt ?
                            Ich vermute, dass der Stellantis Konzern oder auch Peugeot an ihrer Server- und Datenstruktur arbeiten und das ggf. das Problem ist. Nur so ein Gedanke. Ich hatte die mal angeschrieben, weil ich die MyPeugeot-App nicht gerade gelungen finde. Ein Problem z.B., dass die Zusammenfassungen zu den Fahrten bis vor Monaten/Wochen nur unregelmäßig in die App übertragen wurden. Mittlerweile kommen die nahezu immer sofort, wenn ich meinen e208 abstelle. Ich werde auch über die App immer wieder mal abgefragt, ob ich sie gut finde oder nicht, und kann dann meine Verbesserungsvorschläge zurückschreiben. Und ich kriege auch regelmäßig Hinweise auf Navigations-Updates, die ich auf einen USB-Stick kopiere und am Auto einspiele. Es ist also definitiv was los im digitalen Service.
                            • RaspiUser
                              RaspiUser @roughestboy last edited by
                              @roughestboy sagte in Test Adapter PSA v0.0.x Peugeot Opel Citroen:
                              ... aber nicht im OPEL Universum ... Ich habe dort nach dem Corsa-e Kauf mal Fragen bzw. Anmerkungen zur (absolut unterirdischen) App platziert. Die Antworten waren Standard-Text-Bausteine, die Hotline ist eher dazu da, die Kunden zu beruhigen und nicht um Lösungen voran zutreiben.
                              Das die App z.B. kein SoC-Ziel-laden zuläßt ist unbegreiflich ...
                              Um so wichtiger, dass dieser Adapter (bald) wieder funktioniert !!!
                                roughestboy @RaspiUser last edited by
                                @raspiuser Also ein SOC Ziel hat die Peugeot App auch nicht.
                                • hg6806
                                  hg6806 Most Active last edited by
                                  Peugeot hatte wohl an der API gebastelt. Man muss auch nun ein Passwort mit Sonderzeichen verwenden. Das hatte ich in der iOS App eingerichtet, jedoch geht nun der PSA Adapter nicht mehr. Neues PW natürlich auch eingetragen.
                                  Das seltsame an der App ist auch, dass, wenn man ausgeloggt ist, das 1.Mal Einloggen gar nicht funktioniert, so als wenn man das PW falsch eingegeben hätte. Und es verlangt diesen Sicherheitscode, den man im Adapter auch nicht eintragen kann.
                                  Geht bei euch noch der PSA Adapter? Welches Fahrzeug?
                                  Ich habe einen Peugeot e-208.
                                  C G 2 Replies Last reply Reply Quote 0
                                    claus1968 @hg6806 last edited by
                                    @hg6806
                                    Ich habe einen Opel Corsa e und er kommuniziert auch nicht mehr mit dem Adapter 😞
                                    • U
                                      Uwe96 last edited by
                                      EVCC geht auch seit ein paar Tagen mit Opel nicht mehr. Hoffe das wird schnell gefixt
                                        GER55 0 @hg6806 last edited by
                                        habe das gleiche Problem beim Peugeot 3008 Hyprid
                                        • hg6806
                                          hg6806 Most Active last edited by hg6806
                                          Das Ganze muss wohl bei Stellantis neu requested werden.
                                          https://github.com/Stellantis/stellantis.github.io/issues/128
                                          Hier für OpenWB.
                                          Ich weiß jetzt nicht ob das für den ioBroker explizit extra beantragt werden muss.
                                          flobz created this issue in Stellantis/stellantis.github.io
                                          open B2C API access #128
                                          • hollywoot
                                            hollywoot last edited by hollywoot
                                            Reicht ja eigentlich, dass die (Peugeot-)App nahezu unbrauchbar ist...
                                            Hoffentlich gibt's demnächst wieder eine offene API.
                                            citroen corsa corsa-e e208 opel peugeot psa
                                            44
                                            334
                                            47914
