    4. Test ViessmannAPI v2.0.0
      m4rgott @mading last edited by m4rgott
      @mading
      Gab es hierzu inzwischen eine Lösung?
      Ich versuche gerade ein Blockly zu schreiben, das die Zirkulationspumpe steuert.
      Bei Anwesenheit "an", bei Abwesenheit "aus"
      Die Anwesenheit hole ich mir über ein Script, dass auch anderweitig schon funktioniert.
      Blockly sieht wie folgt aus:
        <block type="on" id="Ew~n++NGs7J:Ar#*Uqbr" x="463" y="188">
          <field name="OID">0_userdata.0.JemandZuHause</field>
            <block type="controls_if" id="yPYg)lUZJYm0;W=3KFRz">
                <block type="logic_compare" id="6:2aE-_cRkp|wIbHx)VK">
                  <field name="OP">GTE</field>
                    <block type="on_source" id="zXsr1Gk{1GzZnI)[keau">
                      <field name="ATTR">id</field>
                    <block type="on_source" id="S^sj=Iwb{i;*sC=Y2sCu">
                      <field name="ATTR">oldState.val</field>
                <block type="debug" id="{uPj$*.M*$xKd%,gfu%7">
                  <value name="TEXT">
                    <shadow type="text" id="LCkx7hMwuj0FZi{.YkK1">
                      <field name="TEXT">Schreibe: Warmwasserzirkulation Anwesenheit</field>
                    <block type="control" id="T^{diz_%%+!Y)#_R{EDZ">
                      <field name="OID">viessmannapi.0.xxx.0.features.heating.dhw.pumps.circulation.schedule.commands.setSchedule.setValue</field>
                        <block type="text" id="8X)GpX6lxkx;GB4|Wrga">
                          <field name="TEXT">{"mon":[{"start":"05:20","end":"22:00","mode":"on","position":0}],"tue":[{"start":"05:20","end":"22:00","mode":"on","position":0}],"wed":[{"start":"05:20","end":"22:00","mode":"on","position":0}],"thu":[{"start":"05:20","end":"22:00","mode":"on","position":0}],"fri":[{"start":"05:20","end":"22:00","mode":"on","position":0}],"sat":[{"start":"06:00","end":"22:00","mode":"on","position":0}],"sun":[{"start":"06:00","end":"22:00","mode":"on","position":0}]}</field>
              <statement name="ELSE">
                <block type="debug" id="8LpH6YH)D5CyLU8aT0#u">
                  <value name="TEXT">
                    <shadow type="text" id="4ZjNR|L8nlnai^{Vo2Jw">
                      <field name="TEXT">Schreibe: Warmwasserzirkulation Abwesenheit</field>
                    <block type="control" id="WE|Z9`d5uS{e{bS+[ldG">
                        <block type="text" id="e+TKy0Y6,3~2$=`4pCws">
                          <field name="TEXT">{"mon":[{"start":"14:00","end":"15:00","mode":"on","position":0}],"tue":[{"start":"14:00","end":"15:00","mode":"on","position":0}],"wed":[{"start":"14:00","end":"15:00","mode":"on","position":0}],"thu":[{"start":"14:00","end":"15:00","mode":"on","position":0}],"fri":[{"start":"14:00","end":"15:00","mode":"on","position":0}],"sat":[{"start":"14:00","end":"15:00","mode":"on","position":0}],"sun":[{"start":"14:00","end":"15:00","mode":"on","position":0}]}</field>
      Ergebnis ist die Fehlermeldung, die es wohl 2022 auch schon gab:
      Log-Auszug:
      2024-01-04 11:22:27.478 - info: javascript.0 (30162) script.js.Heizung.Warmwasser_Anwesenheit: Schreibe: Warmwasserzirkulation Abwesenheit
      2024-01-04 11:22:27.819 - error: viessmannapi.0 (31598) AxiosError: Request failed with status code 400
      2024-01-04 11:22:27.826 - error: viessmannapi.0 (31598) {"viErrorId":"|00-d0c1e5306c3c4d7097495e37a7e10403-1462f1a0dd4446f8-01.102801629_","statusCode":400,"errorType":"DEVICE_COMMUNICATION_ERROR","message":"","extendedPayload":{"httpStatusCode":"BadRequest","code":"400","reason":"VALIDATION_ERROR","details":"The parameter newSchedule=\"{\\\"mon\\\":[{\\\"start\\\":\\\"14:00\\\",\\\"end\\\":\\\"15:00\\\",\\\"mode\\\":\\\"on\\\",\\\"position\\\":0}],\\\"tue\\\":[{\\\"start\\\":\\\"14:00\\\",\\\"end\\\":\\\"15:00\\\",\\\"mode\\\":\\\"on\\\",\\\"position\\\":0}],\\\"wed\\\":[{\\\"start\\\":\\\"14:00\\\",\\\"end\\\":\\\"15:00\\\",\\\"mode\\\":\\\"on\\\",\\\"position\\\":0}],\\\"thu\\\":[{\\\"start\\\":\\\"14:00\\\",\\\"end\\\":\\\"15:00\\\",\\\"mode\\\":\\\"on\\\",\\\"position\\\":0}],\\\"fri\\\":[{\\\"start\\\":\\\"14:00\\\",\\\"end\\\":\\\"15:00\\\",\\\"mode\\\":\\\"on\\\",\\\"position\\\":0}],\\\"sat\\\":[{\\\"start\\\":\\\"14:00\\\",\\\"end\\\":\\\"15:00\\\",\\\"mode\\\":\\\"on\\\",\\\"position\\\":0}],\\\"sun\\\":[{\\\"start\\\":\\\"14:00\\\",\\\"end\\\":\\\"15:00\\\",\\\"mode\\\":\\\"on\\\",\\\"position\\\":0}]}\" does not meet the constraints {\"type\":\"Schedule\",\"modes\":[\"5/25-cycles\",\"5/10-cycles\",\"on\"],\"maxEntries\":8,\"resolution\":10,\"defaultMode\":\"off\",\"overlapAllowed\":true}: The parameter should be an object."}}
      2024-01-04 11:22:27.827 - error: viessmannapi.0 (31598) URL: https://api.viessmann.com/iot/v1/features/installations/xxx/gateways/xxx/devices/0/features/heating.dhw.pumps.circulation.schedule/commands/setSchedule
      2024-01-04 11:22:27.828 - error: viessmannapi.0 (31598) Data: {"newSchedule":"{\"mon\":[{\"start\":\"14:00\",\"end\":\"15:00\",\"mode\":\"on\",\"position\":0}],\"tue\":[{\"start\":\"14:00\",\"end\":\"15:00\",\"mode\":\"on\",\"position\":0}],\"wed\":[{\"start\":\"14:00\",\"end\":\"15:00\",\"mode\":\"on\",\"position\":0}],\"thu\":[{\"start\":\"14:00\",\"end\":\"15:00\",\"mode\":\"on\",\"position\":0}],\"fri\":[{\"start\":\"14:00\",\"end\":\"15:00\",\"mode\":\"on\",\"position\":0}],\"sat\":[{\"start\":\"14:00\",\"end\":\"15:00\",\"mode\":\"on\",\"position\":0}],\"sun\":[{\"start\":\"14:00\",\"end\":\"15:00\",\"mode\":\"on\",\"position\":0}]}"}
      Ich bin nun bei meiner Recherche häufiger darüber gestolpert, dass man es bei Postman testen soll. Komme damit aber auch nicht richtig klar.
      Wäre super einen Hinweis von Euch zu bekommen.
      Danke vorab.
        m4rgott @m4rgott last edited by
        Ich habe die Lösung schon gefunden.
        Ein Konvertierungsblock "JSON nach Objekt" vor den zu schreibenden Wert hat geholfen.
        R B 2 Replies Last reply Reply Quote 0
          Ronniboy @m4rgott last edited by
          @m4rgott
          Seit ca 6 Monate visualisiere ich meine Wp mit IOBROKER / GRAFANA.
          Da komme ich sehr gut mit klar.
          Die nächste Herausforderung ist Sollwerte verändern.
          Gibt es eine Doku oder Beschreibung wie ich in Blockly dieses umsetzen kann.
            m4rgott @Ronniboy last edited by m4rgott
            @ronniboy
            ich habe mich mit trial and error rangegeben.
            Wenn Du Dich ja schon seit 6 Monaten mit dem Adapter beschäftigst, findest Du Dich ja sicher bei der Menge an Datenpunkten schon besser zurecht als ich.
            Bei mir habe ich jetzt 2 Dinge "eingebaut".
            1. Wenn die PV-Anlage mehr als 1,5 kW (erster Testwert) Überschuss hat wird die Solltemperatur vom Brauchwasser von 50 auf 55 erhöht.
              <variables>
                <variable id="@^uFj]vII6w4tzOxrOUD">Schwellenwert</variable>
              </variables>
              <block type="comment" id="Z*Yc0h-K=sxJ1l5LAmp|" x="213" y="-63">
                <field name="COMMENT">Prüfung und Anpassung</field>
                  <block type="schedule" id="%7%jU|8(d~tTq`yV7f8C">
                    <field name="SCHEDULE">*/5 * * * *</field>
                      <block type="controls_if" id="LPs,_CHiri[M]4E,Dsm3">
                          <block type="logic_compare" id="L$ZN8QYJtzUxmxv`MLMp">
                            <field name="OP">LT</field>
                              <block type="get_value" id="!{OX~MRns0?.=Kj}w0{^">
                                <field name="OID">0_userdata.0.Energie.Zwischenzaehler_Durchschnitt_5Min</field>
                              <block type="variables_get" id="8*5PJ9nvUi+rJFr)8Kq?">
                                <field name="VAR" id="@^uFj]vII6w4tzOxrOUD">Schwellenwert</field>
                          <block type="control" id="D8I#Fdqrd/]@oe0=a8Yd">
                            <field name="OID">viessmannapi.0.xxx.0.features.heating.dhw.temperature.main.commands.setTargetTemperature.setValue</field>
                              <block type="math_number" id="Dny{rz~_UmX``x5PB,sr">
                                <field name="NUM">55</field>
                          <block type="control" id="c0={noL%jo3gdM3I.?h*">
                              <block type="math_number" id="P6JRV:6/J$dR|K=p)wnf">
                                <field name="NUM">50</field>
              <block type="variables_set" id="6:48TXub#XfY=XM;vTb~" x="313" y="-37">
                  <block type="math_number" id="AD%gIlUA{{g_hO|c?f~i">
                    <field name="NUM">-1500</field>
              <block type="comment" id="N.Lev/.WZsjuGf;=g~5L" x="213" y="212">
                <field name="COMMENT">debung und Telegram bei Änderung</field>
                  <block type="on" id="bwZ;dSkz99*[vV:NaK?]">
                    <field name="OID">viessmannapi.0.xxx.0.features.heating.dhw.temperature.main.properties.value.value</field>
                      <block type="debug" id=",Qb}*i9TtUjMOiU|)ZaI">
                        <value name="TEXT">
                          <shadow type="text" id="f_0b[Y)+yTiCdKy3Z?s~">
                          <block type="text_join" id="0jHsnZ,OVL6)h$*48ld8">
                            <mutation items="6"></mutation>
                            <value name="ADD0">
                              <block type="text" id="o=Jg2a7+k)XHd?c7e0q0">
                                <field name="TEXT">PV-Überschuss =</field>
                            <value name="ADD1">
                              <block type="math_arithmetic" id="1Ej;XL61*|mX2LoJ##0s">
                                  <shadow type="math_number" id=",J;UN`hq{;Cr5OcSL*|-">
                                    <field name="NUM">1</field>
                                  <block type="get_value" id="!Ix|JcmE8E^hW71Kc6T=">
                                  <shadow type="math_number" id="{HiC*5qx;=5Y}9-@n[ts">
                                    <field name="NUM">-1</field>
                            <value name="ADD2">
                              <block type="text" id="exRvdoWnJI?J3,Jc$8hI">
                                <field name="TEXT">. Wassertemperatur geändert auf: </field>
                            <value name="ADD3">
                              <block type="get_value_var" id="]Z^d)y5~RU5GW#S0[t[N">
                                <value name="OID">
                                  <shadow type="field_oid" id="i,tsb_mOhc;YxKP:p$4F">
                                    <field name="oid">Object ID</field>
                                  <block type="on_source" id="P]RHOe_Km2r._4mF6T~c">
              <variables>
              </variables>
                        <value name="TEXT">
                            <value name="ADD0">
                            <value name="ADD1">
                            <value name="ADD2">
                            <value name="ADD3">
                                <value name="OID">
            2.: Zirkulationspumpe für das Warmwasser soll tagsüber, wenn jemand zu Hause ist, laufen. Wenn niemand zu Hause ist, soll die Pumpe zumindest 1 h pro Tag laufen, damit das Wasser nicht in der Leitung steht.
            Da man die Zirkulationspumpe nicht direkt mit "an" oder "aus" ansteuern kann muss man hierfür den Zeitplan anpassen.
            Die Vorlage für den Zeitplan habe ich mir aus viessmannapi.0.xxx.0.features.heating.dhw.pumps.circulation.schedule.properties.entries.value geholt
                          <block type="convert_json2object" id="wfN}ISOWBPN^TaMyS9hN">
                          <block type="convert_json2object" id="3E^n5/xSCW74KBuZINbV">
            Für die anpassbaren Werte gibt es bei den Datenpunkten je einen zur Eingabe der neuen Daten. Bei dem Zeitplan ist es bei mir z.B. viessmannapi.0.xxx.0.features.heating.dhw.pumps.circulation.schedule.commands.setSchedule.setValue
            Die Blockly-Pros hätten das sicher galanter gemacht. Als Anfänger gebe ich mich gerade damit zufrieden was funktioniert 😉
            Ich hoffe, das hilft Dir weiter.
              Schweiz last edited by
              Hi, ich bekomme den Adapter leider nicht ans laufen...
              viessmannapi.0
              	2024-01-14 14:43:54.446	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
              viessmannapi.0
              	2024-01-14 14:43:54.508	debug	Objects client ready ... initialize now
              viessmannapi.0
              	2024-01-14 14:43:54.511	debug	Objects create System PubSub Client
              viessmannapi.0
              	2024-01-14 14:43:54.514	debug	Objects create User PubSub Client
              viessmannapi.0
              	2024-01-14 14:43:54.587	debug	Objects client initialize lua scripts
              viessmannapi.0
              	2024-01-14 14:43:54.599	debug	Objects connected to redis: 127.0.0.1:9001
              viessmannapi.0
              	2024-01-14 14:43:54.648	debug	Redis States: Use Redis connection: 127.0.0.1:9000
              viessmannapi.0
              	2024-01-14 14:43:54.671	debug	States create System PubSub Client
              viessmannapi.0
              	2024-01-14 14:43:54.673	debug	States create User PubSub Client
              viessmannapi.0
              	2024-01-14 14:43:54.750	debug	States connected to redis: 127.0.0.1:9000
              viessmannapi.0
              	2024-01-14 14:43:54.815	debug	Plugin sentry Initialize Plugin (enabled=true)
              viessmannapi.0
              	2024-01-14 14:43:54.826	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              viessmannapi.0
              	2024-01-14 14:43:55.067	info	starting. Version 2.4.0 (non-npm: TA2k/ioBroker.viessmannapi#3c01443c736270a8c3abe0212c651303fc15d8b3) in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v18.19.0, js-controller: 5.0.17
              viessmannapi.0
              	2024-01-14 14:43:55.587	error	AxiosError: Request failed with status code 401
              viessmannapi.0
              	2024-01-14 14:43:55.589	error	{"error":"invalid_request","error_description":"Client not registered."}
              viessmannapi.0
              	2024-01-14 14:43:55.987	error	AxiosError: Request failed with status code 400
              viessmannapi.0
              	2024-01-14 14:43:55.988	error	{"error":"invalid_request","error_description":"Invalid request: Missing or empty code parameter"}
              zugang mit der ViCare funktioniert...
              MFG Schweizer
                @schweiz
                erledigt...
                Irgendwie hab ich mir gedacht, ich gebe mal einfach ein falsches Password ein, dann muss er mir ja sagen dass das Password falsch ist... hat er auch, dann habe ich es nocheinm eingegeben und nun geht der Adapter... kommisch!???
                MFG Schweizer
                • I
                  io2345 @Tiger VI last edited by
                  @tiger-vi Hast du den genannten Datenpunkt in Betrieb und funktioniert der an heißen Tagen? Habe eben einen kurzen Test gemacht, allerdings nur Natural Cooling über den Aktorentest in der Steuerung der WP eingeschaltet. Zumindest in diesem Fall ändert sich der Status dieses Datenpunktes nicht (das müsste bei dir genauso sein, falls du es ausprobieren möchtest). Kann aber natürlich sein, dass das ein anderer Trigger ist, der trotzdem das gewünschte Ergebnis liefert.
                  • I
                    io2345 @mading last edited by io2345
                    @mading Mein Gott, was ihr für knifflige Sachen macht: Geo-Lokalisation, Wahnsinn. Aber selbst ein Wandschalter ist noch zu viel Aufwand.
                    Am einfachsten wäre doch, in der Oberfläche des ioBroker eine Art "virtuellen Schalter" zu haben, wo man drauf drückt und dann läuft die Zirkulationspumpe für fünf Minuten, bevor sie sich wieder abstellt.
                    Bin ziemlicher Anfänger in solchen Sachen (hab vorgestern erst ioBroker auf dem Raspi installiert).
                    Könnt ihr abschätzen, ob sich sowas realisieren lässt - oder hat sowas in der Art gar schon einer der Forumsteilnehmer am Laufen?
                    EDIT: Mein Gott, ich scheitere schon daran, dein Blockly-Script bei mir in Blockly einzufügen. Kann offenbar nur das anzeigen, was ich selbst zusammen-geblockt habe....
                    N M 2 Replies Last reply Reply Quote 0
                    • N
                      nobbiman @io2345 last edited by nobbiman
                      @io2345 Kann verstehen, dass du das auch im ioBroker realisieren möchtest, wobei ich dir leider auch (noch) nicht helfen kann.
                      Aber einen Tipp für die praktische Umsetzung deines Problems gebe ich dir gerne mit:
                      Ich steuere meine Zirkupumpe (Keller) über einen Funkschalter (könnte ein Shelly Plug S sein oder ein anderes Shelly-Teil). Im Bad liegt bei mir ein Shelly Button 1, den man betätigt, sobald man das Bad betritt und sich zum Duschen/Waschen vorbereitet. Der Button steuert dann den Shelly Plug S, der auf eine Laufzeit von 3-4 Min programmiert wird.
                      Vorteil dieser Lösung: Der Schalter ist vor Ort und so langsam gewöhnen sich auch die Familienmitglieder an dessen rechzeitiger Betätigung.
                      Ich hatte früher eine Steuerung über FHEM im FTUI auf einem iPad realisiert, der im EG lag. Wenn man ins OG kam und hatte vergessen den "3-Minuten-Schalter" zu betätigen, wurde doch das Wasser so lange laufen gelassen, bis es warm wurde weil niemand Lust hatte, nochmals ins EG zu gehen.
                      Mir gefällt die jetzige Lösung sehr gut!
                        mading @io2345 last edited by
                        @io2345 sagte in Test ViessmannAPI v2.0.0:
                        Ich habe eine Schaltsteck an der Zirkulationspumpe. Im Bad habe ich einen homematic Taster mit Ink Display. Drücke ich auf eine Taste, läuft die ZP für 5 Min.
                        • I
                          @mading Funktioniert astrein.
                          Falls ein Anfänger wie ich das ebenfalls importieren möchte: Hier ein paar Hinweise, wie man Frust vermeiden kann:
                          Das Blockly enthält einen Block, in dem Meldungen über einen Adapter des IM-Dienstes Telegram verschickt werden. Falls man beim Importieren des Scripts eine Fehlermeldung erhält bezüglich fehlerhafter Telegram-Konfiguration, dann fehlt bei euch wahrscheinlich dieser Adapter.
                          Der konfigurierte Datenpunkt, der geschaltet wird, muss bei euch im Blockly abgeändert werden: hinter "viessmannapi.0.... ist eine eindeutige ID, an dieser Stelle müsst ihr die eure eintragen.
                          Das Blockly verwendet einen eigenen Datenpunkt, den ihr erst anlegen müsst: Unter 0_userdata.0.EigeneDatenpunkte.Heizung einen Unterpunkt "ZirkulationAn" als Binärwert.
                          Wer das Script ohne Hardwareschalter einfach von einem Mobilgerät oder Computer aufrufen will, kann sich z.B. eine Visualisierung (wie HABpanel) als Adapter installieren und dort eine Schaltfläche einfügen, die beim Antippen in den - im letzten Abschnitt erstellten Datenpunkt - schreibt.
                            Bastler52 @m4rgott last edited by Bastler52
                            @m4rgott Kannst Du uns dann die Lösung zeigen bitte. (vor {"mon" .. ist gemeint oder?)
                              m4rgott @Bastler52 last edited by
                              Hi @bastler52
                              die obenstehenden Blocklys sind genau so bei mir im Einsatz. Deshalb weiß ich nicht welche Lösung Du suchst.
                              Ich habe nur die Anlagennummer durch "xxx" ersetzt.
                              Wie oben beschrieben habe ich für den neuen Zeitplan den bestehenden Wert aus dem Datenpunkt viessmannapi.0.xxx.0.features.heating.dhw.pumps.circulation.schedule.properties.entries.value geholt und den nach meinen Vorstellungen angepasst.
                              Ich hoffe das hilft Dir weiter.
                                @m4rgott Danke scheinbar habe ich etwas übersehen oder wurde nicht angezeigt. Wollte nur sicher gehen dass ich deinen Beitrag richtig verstanden habe f8471e71-0515-46c9-99b4-1a2c8887705f-image.png
                                genau das habe ich nicht gesehen und danach hatte ich gefragt ob och das richtig verstanden habe.
                                Ich habe an sich die Lösung auch um Einsatz aber als Java Skript.
                                DANKE für deine Reaktion
                                  MAXI885 @Guest last edited by
                                  @ilovegym
                                  aktuell nutze ich den Adapter noch nicht, hätte aber eine Frage zur Anschaffung der Hardware.
                                  Es gibt für den VITOCONNECT 100 OPT01 auch einen Nachfolger, den OPTO2, ist das für die Verwendung mit iobroker egal,
                                  welches Gerät man benutzt ?
                                  Vielen Dank & Grüße !
                                  ? T 2 Replies Last reply Reply Quote 0
                                    A Former User @MAXI885 last edited by
                                    @maxi885
                                    kann dir nicht 100% bestaetigen, da ich auch nur den Vitoconnect 100 habe.
                                    Aber, rein von der Logik des Adapters aus, sollte es funktionieren, da dieser die Daten ja von dem Viessmann-Server von der API holt.
                                    Wie die Daten dahin kommen, ob mit Modul-1 oder 2 oder X ist eigentlich egal....
                                      tombox @MAXI885 last edited by
                                      @maxi885 Kompatibilitätsliste: https://documentation.viessmann.com/static/compatibility
                                        MAXI885 @tombox last edited by
                                        @tombox said in Test ViessmannAPI v2.0.0:
                                        super, vielen Dank !
                                        Die Liste bezieht sich schon auf den neuen OPTO2, da steht meine etwas ältere Vitotronic 200 KW1 sogar dabei 🙂
                                          Backes last edited by
                                          Guten Morgen,
                                          ist es normal, dass wenn das RateLimit einmal erreicht wurde, das der Adapter manuell neugestartet werden muss damit er wieder funktioniert am nächsten Tag? Hab das RateLimit letzte Woche einmal überschritten und er hat seitdem gehangen und keine Daten mehr gezogen.
                                          Beste Grüße!
                                          Dominik F. 1 Reply Last reply Reply Quote 0
                                          • Dominik F.
                                            Dominik F. @Backes last edited by
                                            ich habe heute den Adapter installiert und soweit ich das überblicken kann funktioniert alles.
                                            Ich nutze bei meiner Heizung die geofencing Funktion. Gibt es dazu Datenpunkte wo ich sehen kann wer im Umkreis ist und wer nicht?
                                            795
                                            216614
