    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    • Rene55
      Rene55 @Diginix last edited by
      @diginix Ja, irgendetwas ist da faul. Ich hab den Adapter jetzt (leider) nur noch im Testbetrieb mit dem Account von DHL laufen. Ich habe gerade nochmal alles gelöscht und neu (Email&Passwort) eingegeben. Es kam keine SMS/Mail Pin nach erstem Start.
      2024-01-17 10:06:28.517 - info: host.CT113 instance system.adapter.parcel.0 started with pid 302094
      2024-01-17 10:06:30.740 - debug: parcel.0 (302094) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-01-17 10:06:30.762 - debug: parcel.0 (302094) Objects client ready ... initialize now
      2024-01-17 10:06:30.763 - debug: parcel.0 (302094) Objects create System PubSub Client
      2024-01-17 10:06:30.764 - debug: parcel.0 (302094) Objects create User PubSub Client
      2024-01-17 10:06:30.814 - debug: parcel.0 (302094) Objects client initialize lua scripts
      2024-01-17 10:06:30.819 - debug: parcel.0 (302094) Objects connected to redis: 127.0.0.1:9001
      2024-01-17 10:06:30.841 - debug: parcel.0 (302094) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-01-17 10:06:30.848 - debug: parcel.0 (302094) States create System PubSub Client
      2024-01-17 10:06:30.849 - debug: parcel.0 (302094) States create User PubSub Client
      2024-01-17 10:06:30.860 - debug: parcel.0 (302094) States connected to redis: 127.0.0.1:9000
      2024-01-17 10:06:30.891 - debug: parcel.0 (302094) Plugin sentry Initialize Plugin (enabled=true)
      2024-01-17 10:06:31.228 - info: parcel.0 (302094) starting. Version 0.0.27 in /opt/iobroker/node_modules/iobroker.parcel, node: v18.16.0, js-controller: 5.0.17
      2024-01-17 10:06:31.305 - info: parcel.0 (302094) Login to DHL
      2024-01-17 10:06:31.893 - debug: parcel.0 (302094) [object Object]
      2024-01-17 10:06:32.605 - debug: parcel.0 (302094) Please close this window to continue.
      2024-01-17 10:06:32.716 - debug: parcel.0 (302094) (janrain.capture.ui.handleCaptureResponse)({"stat":"ok","result":{"transactionId":"3LenxxxxxxxxxfxWO","status":"success","statusMessage":"signedIn",...usw.}});
      2024-01-17 10:06:33.786 - debug: parcel.0 (302094) {"access_token":"aFyAWxxxxxxxxHOLUag","refresh_token":"F_SUdK4xxxxxxxlxkOpj9c-","expires_in":1800,"token_type":"Bearer","scope":"openid offline_access",...usw.}
      2024-01-17 10:06:33.787 - info: parcel.0 (302094) Login to DHL successful
      2024-01-17 10:07:44.755 - error: parcel.0 (302094) Error: read ETIMEDOUT
      2024-01-17 10:07:44.756 - debug: parcel.0 (302094) https://www.dhl.de/int-verfolgen/data/search?piececode=&noRedirect=true&language=de&cid=app
      2024-01-17 10:07:49.578 - debug: parcel.0 (302094) {"sendungen":[{"id":"0034xxxxxxxxxxxxx98","hasCompleteDetails":true,"sendungsinfo":{"gesuchteSendungsnummer":"0034xxxxxxxxxxxxx98","sendungsname":...usw}
      2024-01-17 10:07:49.584 - debug: parcel.0 (302094) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      2024-01-17 10:07:49.591 - debug: parcel.0 (302094) dhl merge provider json
      2024-01-17 10:07:49.592 - debug: parcel.0 (302094) https://www.dhl.de/int-aviseanzeigen/advices?width=414
      2024-01-17 10:07:50.032 - debug: parcel.0 (302094) {"currentAdvice":null,"oldAdvices":[{"date":"11.01.2024","advices":[{"image_url":"https://briefankuendigung.dhl.de/pdapp-web/image/v1.0/16db1785-::: usw.,"basicAuth":"","serviceState":{"contractState":"ACTIVE","recognitionDegree":3}}
      2024-01-17 10:07:50.238 - debug: parcel.0 (302094) ""
      2024-01-17 10:07:51.254 - debug: parcel.0 (302094) dhl merge provider json
      2024-01-17 10:07:51.255 - debug: parcel.0 (302094) Write states
      Es wurden die alten Daten abgerufen und bringt weiterhin 'Error: read ETIMEDOUT'. Evtl. bringt die Auflösung von [object Object] auch noch eine Erhellung.
      • Diginix
        Diginix @Rene55 last edited by
        @rene55 sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
        Du nutzt ja die stable 0.0.27. Ich bin von Anfang an auf latest, also 0.2.6 und aktuell auf der git Version damit ich parcel.0.notDelivered habe. Ich teste mal ob mit der 0.0.27 bei DHL mehr geht.
        • Rene55
          @diginix Oha, dass kann ja einiges erklären. In beta wird mir gerade nur die 0.2.2 angeboten, obwohl es ja schon eine 0.2.6 geben soll. Ich machs mal schrittweise.
          • Diginix
            @rene55 Und mit wird der Adapter im stable Repo gar nicht angeboten 😉
            Komme im latest nur maximal auf 0.1.1 zurück.
            • Diginix
              Diginix last edited by Diginix
              Es ist echt verhext. Nun erhalte ich:
              2024-01-17 10:44:07.317 - info: parcel.0 (1104269) starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.parcel, node: v18.17.1, js-controller: 5.0.17
              2024-01-17 10:44:07.386 - info: parcel.0 (1104269) Login to DHL
              2024-01-17 10:45:08.526 - error: parcel.0 (1104269) AxiosError: Request failed with status code 504
              2024-01-17 10:45:08.530 - error: parcel.0 (1104269) "\r\n\r\n\r\n
              504 Gateway Time-out
              \r\n
              nginx
              \r\n\r\n\r\n"
              2024-01-17 10:45:08.530 - error: parcel.0 (1104269) DHL Signin failed
              2024-01-17 10:45:08.533 - warn: parcel.0 (1104269) No login session found
              Beim zweiten Versuch kam wieder de alt bekannte Fehler:
              2024-01-17 10:47:08.336 - debug: parcel.0 (1104833) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2024-01-17 10:47:08.376 - debug: parcel.0 (1104833) Objects client ready ... initialize now
              2024-01-17 10:47:08.441 - debug: parcel.0 (1104833) Objects create System PubSub Client
              2024-01-17 10:47:08.442 - debug: parcel.0 (1104833) Objects create User PubSub Client
              2024-01-17 10:47:08.523 - debug: parcel.0 (1104833) Objects client initialize lua scripts
              2024-01-17 10:47:08.529 - debug: parcel.0 (1104833) Objects connected to redis: 127.0.0.1:9001
              2024-01-17 10:47:08.587 - debug: parcel.0 (1104833) Redis States: Use Redis connection: 127.0.0.1:9000
              2024-01-17 10:47:08.619 - debug: parcel.0 (1104833) States create System PubSub Client
              2024-01-17 10:47:08.621 - debug: parcel.0 (1104833) States create User PubSub Client
              2024-01-17 10:47:08.735 - debug: parcel.0 (1104833) States connected to redis: 127.0.0.1:9000
              2024-01-17 10:47:08.797 - debug: parcel.0 (1104833) Plugin sentry Initialize Plugin (enabled=true)
              2024-01-17 10:47:09.265 - info: parcel.0 (1104833) starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.parcel, node: v18.17.1, js-controller: 5.0.17
              2024-01-17 10:47:09.334 - info: parcel.0 (1104833) Login to DHL
              2024-01-17 10:47:10.404 - debug: parcel.0 (1104833) Please close this window to continue.
              2024-01-17 10:47:10.636 - debug: parcel.0 (1104833) (janrain.capture.ui.handleCaptureResponse)({"stat":"ok","result":{"transactionId":"RrOP4lGjA0bA4EGwmdekC45uCeBddyN4rVtq2xmA","status":"success","statusMessage":"signedIn","action":"traditionalSignin","flow":"ciam_flow_001","version":"20230309140056615616","screen":"signIn","form":"signInForm","fields":["emailOrPostNumber","currentPassword"],"oneTime":false,"userData":{"uuid":"574cc929-033f-4ad4-a29a-a8d55657c4a0","email":"***","displayName":"***"},"keepMeLoggedIn":false,"accessToken":"asdcmq6mz985ban2","ssoImplicitLogin":false,"renders":false}});
              2024-01-17 10:47:12.027 - error: parcel.0 (1104833) AxiosError: Request failed with status code 400
              2024-01-17 10:47:12.027 - error: parcel.0 (1104833) {"error":"invalid_request","error_description":"code is missing"}
              2024-01-17 10:47:12.028 - warn: parcel.0 (1104833) No login session found
                Thomas Braun Most Active @Diginix last edited by
                @diginix @Rene55
                2024-01-17 10:55:52.346  - info: parcel.0 (405471) starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.parcel, node: v18.19.0, js-controller: 5.0.17
                2024-01-17 10:55:52.427  - info: parcel.0 (405471) Login to DHL
                2024-01-17 10:55:54.848  - info: parcel.0 (405471) Login to DHL successful
                Funktioniert hier...
                Allerdings mit aktuellem nodejs. Bitte auf Stand bringen.
                • Diginix
                  Diginix @Thomas Braun last edited by Diginix
                  @thomas-braun Für mein Ubuntu 22.04.3 LTS ist das die aktuelle Ver. und daran wird es wohl nicht liegen. Und es hilft auch nicht wenn sich jetzt alle melden, bei denen es geht. Ich bin nicht allein mit dem Problem und ohne Unterstützung eines Entwicklers wird es bei meinem DHL Konto wohl nicht besser.
                  T Thomas Braun 2 Replies Last reply Reply Quote 0
                    tombox @Diginix last edited by
                    @diginix Hast du mittlerweile ein dummy account der auch nicht geht?
                    • Diginix
                      Diginix @tombox last edited by
                      @tombox Nein, den Schritt bin ich noch nich gegangen.
                        @diginix sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                        Nein, ist es nicht.
                        18.19.0 ist die aktuelle empfohlene Version. Auch für dein Ubuntu.
                        • Rene55
                          @thomas-braun Ich hab den Rat befolgt und upgedatet. Aber gab es da nicht auch einen kurzen (neuen) Befehl zu?
                            Thomas Braun Most Active @Rene55 last edited by
                            @rene55
                            iob nodejs-update
                            setzt dich da wieder auf das richtige Gleis.
                            • Diginix
                              @thomas-braun Ich mache wöchentlich ein:
                              sudo apt update
                              sudo apt -y dist-upgrade
                              Dann musst du mal bei Ubuntu anrufen und denen sagen, dass sie mir nicht das richtige liefern. 😄
                              /etc/apt/sources.list.d/nodesource.list
                              deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main
                              deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main
                              Edit:
                              Hab nun in /etc/apt/sources.list.d/nodesource.list:
                              deb [arch=amd64 signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                              Und damit die 18.19.0 bekommen.
                              Und noch viel erstaunlicher ist, dass damit tatsächlich DHL wieder funktioniert!
                              Bist mein Held! Vielen Dank!
                              PS: Du wirst mir nicht sagen können wieso in der nodesource.list erst "jammy" und nun "nodistro" steht und dadurch das Update klappte?
                              Hatte nur noch mal gemacht und das hat die Quelle geändert
                              curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
                              sudo apt install -y nodejs
                              Thomas Braun Thisoft 4 Replies Last reply Reply Quote 0
                                @diginix
                                Dein Repo ist/war halt nicht aktuell. Da muss ich nicht anrufen, jedenfalls nicht bei Ubuntu sondern wenn überhaupt beim Admin von der Kiste...
                                • Diginix
                                  Hab gerade schon kommentiert dass ich immer das mache wenn eine neue Major Node Ver. kommt
                                  Aber bis zu nächsten musste ich das noch nie nochmal machen damit die Quelle stimmt.
                                  Dennoch hat es nun "jammy" zu "nodistro" geändert und dadurch kam das Update.
                                    Doch, kann ich. Ist aber nicht der richtige Thread dafür, davon ab stand das schon im passenden Thread seinerzeit dabei.
                                      Mach es über
                                      iob nodejs-update
                                      Das stellt dir das Repo richtig ein. Auch die Priority z.B.
                                        Die hat sich ja auch geändert und die alte Quelle wird nicht mehr mit neuen Versionen gefüttert, die kommen nur noch über das neue Repo.
                                        • Diginix
                                          Nochmal abschließend hier, falls es oben in der Menge der Posts unterging:
                                          Version 0.2.6 funktioniert mit DHL wenn NodeJS wirklich aktuell ist.
                                          Und auch das neue Objekt parcel.0.notDelivered in der Version von git funktioniert.
                                            mctom last edited by
                                            ich habe 2 kleine Herausforderungen mit dem Adapter. Vielleicht hat jemand eine Idee was ich machen könnte.
                                            a)
                                            No UPS address found. Please activate UPS My Choice in the UPS App
                                            myChoice ist aktiviert wenn ich das bei UPS richtig sehe. Was könnte ich noch prüfen ?
                                            b)
                                            parcel.0 2024-01-21 15:51:22.224	error	AxiosError: Request failed with status code 401
                                            parcel.0 2024-01-21 15:51:22.224	error	{"additionalInfo":{"exception":"BadCredentialsException"},"status_code":401}
                                            Mit den Zugangsdaten kann ich mich bei GLS ohne Probleme einloggen. Allerdings ist das ein Zugang für die neue GLS Seite. Kann es damit zu tun haben ?
                                            Velen Dank für eure Hilfe.
                                            Michael
                                            17track amazon briefe dhl dpd gls ups
                                            123
                                            1537
                                            536137
