    3. Einsteigerfragen
    4. *** nodejs is NOT correctly installed ***[gelöst]
    • Duffy
      Duffy last edited by Duffy
      Hallo an alle Experten,
      ich wollte soeben mein Zigbee Adapter von 1.9.5 auf 1.9.7 anheben.
      Dabei erschien folhgender Fehler:
      $ iobroker upgrade zigbee@1.9.7
      Update zigbee from @1.9.5 to @1.9.7
      host.raspberrypi Adapter "system.adapter.zigbee.0" is stopped.
      /bin/sh: 1: npm: not foundError trying to check npm version: Command failed: npm -v/bin/sh: 1: npm: not found!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Aborting install because the npm version could not be checked!Please check that npm is installed correctly.Use "npm install -g npm@8" or "npm install -g npm@latest" to install a supported version.You need to make sure to repeat this step after installing an update to NodeJS and/or npm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      ERROR: Process exited with code 30
      Aktuell habe ich npm 10.2.3 installiert.
      Eine Reparatur über: iob fix war nicht erfolgreich.
      Anbei der Auszug von iob diag: (*** nodejs is NOT correctly installed ***)
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi6-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       12:43:07 up 53 days, 21:47,  2 users,  load average: 0.87, 1.57, 1.89
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Wed 2024-01-17 12:43:08 CET
                 Universal time: Wed 2024-01-17 11:43:08 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            8.2G        2.5G        2.2G        1.2M        3.6G        5.7G
      Swap:           104M          0B        104M
      Total:          8.3G        2.5G        2.3G
               7810 M total memory
               2359 M used memory
               2912 M active memory
               2381 M inactive memory
               2104 M free memory
                191 M buffer memory
               3284 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT            LOAD   ACTIVE SUB    DESCRIPTION
      * hciuart.service loaded failed failed Configure Bluetooth Modems connected by UART
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                                        Type      Size  Used Avail Use% Mounted on
      udev                                              devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs                                             tmpfs     782M  1.2M  780M   1% /run
      /dev/sda2                                         ext4       29G  6.1G   22G  23% /
      tmpfs                                             tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                                             tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/sda1                                         vfat      510M   61M  450M  12% /boot/firmware
      //192.168.178.1/fritz.nas/BACKUPS/iobroker-backup cifs       30G  1.3G   29G   5% /opt/iobroker/backups
      tmpfs                                             tmpfs     782M     0  782M   0% /run/user/1000
      TARGET                  SOURCE                                            FSTYPE OPTIONS
      /                       /dev/sda2                                         ext4   rw,noatime
      |-/opt/iobroker/backups //192.168.178.1/fritz.nas/BACKUPS/iobroker-backup cifs   rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
      `-/boot/firmware        /dev/sda1                                         vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1017M   /var/
      349M    /var/lib
      320M    /var/cache
      314M    /var/cache/apt
      248M    /var/log
      Archived and active journals take up 246.3M in the file system.
      /opt/iobroker/backups:
      1.1G    /opt/iobroker/backups/
      57M     /opt/iobroker/backups/05.11.23
      56M     /opt/iobroker/backups/05.11.23/influxDB_2023_11_05-10_32_44_iobroker-data_backupiobroker
      19M     /opt/iobroker/backups/04.11.23
      /opt/iobroker/iobroker-data:
      680M    /opt/iobroker/iobroker-data/
      551M    /opt/iobroker/iobroker-data/files
      138M    /opt/iobroker/iobroker-data/files/vis-2
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      84M     /opt/iobroker/iobroker-data/backup-objects
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      28M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /home/iobroker/.diag.sh: line 279: npm: command not found
      /home/iobroker/.diag.sh: line 280: npx: command not found
      /home/iobroker/.diag.sh: line 281: corepack: command not found
      /home/iobroker/.diag.sh: line 290: npm: command not found
      /home/iobroker/.diag.sh: line 291: npx: command not found
      nodejs:
        Installed: 18.19.0+dfsg-6~deb12u1
        Candidate: 18.19.0+dfsg-6~deb12u1
        Version table:
       *** 18.19.0+dfsg-6~deb12u1 500
              100 /var/lib/dpkg/status
           18.19.0-1nodesource1 500
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      No problems detected
      Errors in npm tree:
      /home/iobroker/.diag.sh: line 360: npm: command not found
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      /home/iobroker/.diag.sh: line 375: npm: command not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
        system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1884, bind: 0.0.0.0
      + system.adapter.mystrom.0                : mystrom               : raspberrypi                              -  enabled
        system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
      + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
      + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
      + system.adapter.switchbot-hub.0          : switchbot-hub         : raspberrypi                              -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
        system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "device-reminder": 3.0.0  , installed 3.0.1
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "mystrom"      : 0.0.14   , installed 0.0.14
      Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "zigbee"       : 1.9.7    , installed 1.9.5  [Updatable]
      Objects and States
      Objects:        8810
      States:         8221
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://packages.grafana.com/oss/deb stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       335128048  1749772/iobroker.js
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       335128055  1749772/iobroker.js
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       335131094  1749937/io.sonoff.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          106757407  1071493/sshd: /usr/
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       335130812  1749790/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       335134895  1750307/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        664        761/influxd
      tcp6       0      0 :::3000                 :::*                    LISTEN      106        106752987  1071324/grafana
      tcp6       0      0 :::22                   :::*                    LISTEN      0          106757409  1071493/sshd: /usr/
      udp        0      0 0.0.0.0:54406           0.0.0.0:*                           104        560        549/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        558        549/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        559        549/avahi-daemon: r
      udp6       0      0 :::38177                :::*                                104        561        549/avahi-daemon: r
      2024-01-17 12:43:31.400  - error: host.raspberrypi Caught by controller[1]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-17 12:43:31.400  - error: host.raspberrypi Caught by controller[1]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-17 12:43:31.401  - error: host.raspberrypi Caught by controller[1]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-17 12:43:31.401  - error: host.raspberrypi Caught by controller[1]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      2024-01-17 12:43:31.401  - error: host.raspberrypi Caught by controller[1]:     at node:internal/main/run_main_module:28:49
      2024-01-17 12:43:31.401  - error: host.raspberrypi Caught by controller[1]: Node.js v18.19.0
      2024-01-17 12:43:31.401  - error: host.raspberrypi instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-17 12:43:31.402  - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
      2024-01-17 12:44:01.493  - info: host.raspberrypi instance system.adapter.info.0 started with pid 1750894
      2024-01-17 12:44:04.165  - error: host.raspberrypi Caught by controller[0]: /bin/sh: 1: npm: not found
      2024-01-17 12:44:04.165  - error: host.raspberrypi Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
      2024-01-17 12:44:04.166  - error: host.raspberrypi Caught by controller[1]:             adapter.log.error("Could not check npm version: " + e);
      2024-01-17 12:44:04.166  - error: host.raspberrypi Caught by controller[1]:                     ^
      2024-01-17 12:44:04.166  - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
      2024-01-17 12:44:04.166  - error: host.raspberrypi Caught by controller[1]:     at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
      2024-01-17 12:44:04.166  - error: host.raspberrypi Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
      2024-01-17 12:44:04.166  - error: host.raspberrypi Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-17 12:44:04.167  - error: host.raspberrypi Caught by controller[1]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-17 12:44:04.167  - error: host.raspberrypi Caught by controller[1]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-17 12:44:04.167  - error: host.raspberrypi Caught by controller[1]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-17 12:44:04.167  - error: host.raspberrypi Caught by controller[1]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      2024-01-17 12:44:04.167  - error: host.raspberrypi Caught by controller[1]:     at node:internal/main/run_main_module:28:49
      2024-01-17 12:44:04.167  - error: host.raspberrypi Caught by controller[1]: Node.js v18.19.0
      2024-01-17 12:44:04.167  - error: host.raspberrypi instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-17 12:44:04.167  - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
      Kann mit da bitte jemand weiter helfen?
      VG Duffy
      DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @Duffy last edited by
        @duffy
        https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version-npm-fehlt
        • Duffy
          Duffy @DJMarc75 last edited by Duffy
          @djmarc75
          Vielen Dank für den Link, den hatte ich in meiner Unruhe nicht gefunden.
          Läuft wieder, dachte schon ich muss mir Betablocker in der Apotheke holen 😧
          Gruß Duffy
            Thomas Braun Most Active @Duffy last edited by
            @duffy
            Und ich würde auch mal schauen, ob deine Backups wirklich vollständig geschrieben und gelesen werden können.
            Deine derzeitigen Mount-Optionen sind eigentlich für das FritzNAS falsch.
              Homoran Global Moderator Administrators @Duffy last edited by
              @duffy sagte in *** nodejs is NOT correctly installed ***[gelöst]:
              ist extra oben angepinnt um den Blutdruck nicht allzuhoch zu treiben
              bei dir war
              der entscheidende Hinweis im iob diag
              • Duffy
                Duffy @Thomas Braun last edited by
                Danke für den Hinweis.
                Ich habe soeben noch mal ein Backup angestoßen und es wurde auf die Nas der FB geschrieben und auch in die Dropbox.
                Started iobroker ...
                [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/fritz.nas/BACKUPS/iobroker-backup /opt/iobroker/backups"
                [DEBUG] [mount] - mount successfully completed
                [DEBUG] [mount] - done
                [DEBUG] [iobroker] - host.raspberrypi 8202 states saved
                [DEBUG] [iobroker] - host.raspberrypi 8818 objects saved
                [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2024_01_17-13_15_50_Smarthome_backupiobroker.tar.gz
                [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
                [DEBUG] [iobroker] - done
                [DEBUG] [influxDB] - InfluxDB-Backup for iobroker-data is started ...
                [DEBUG] [influxDB] - Start InfluxDB Backup ...
                [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                [DEBUG] [influxDB] - Packed 8MB so far...
                [DEBUG] [influxDB] - Packed 45MB so far...
                [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_17-13_16_09_iobroker-data_backupiobroker.tar.gz
                [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_17-13_16_09_iobroker-data_backupiobroker"
                [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_17-13_16_09_iobroker-data_backupiobroker" successfully deleted
                [DEBUG] [influxDB] - InfluxDB-Backup for iobroker-data is finish
                [DEBUG] [influxDB] - InfluxDB-Backup for IOB-Kurzzeit-1Jahr is started ...
                [DEBUG] [influxDB] - Packed 16MB so far...
                [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_17-13_17_59_IOB-Kurzzeit-1Jahr_backupiobroker.tar.gz
                [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_17-13_17_59_IOB-Kurzzeit-1Jahr_backupiobroker"
                [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_17-13_17_59_IOB-Kurzzeit-1Jahr_backupiobroker" successfully deleted
                [DEBUG] [influxDB] - InfluxDB-Backup for IOB-Kurzzeit-1Jahr is finish
                [DEBUG] [influxDB] - InfluxDB-Backup for iob-14-Tage is started ...
                [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_17-13_18_54_iob-14-Tage_backupiobroker.tar.gz
                [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_17-13_18_54_iob-14-Tage_backupiobroker"
                [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_17-13_18_54_iob-14-Tage_backupiobroker" successfully deleted
                [DEBUG] [influxDB] - InfluxDB-Backup for iob-14-Tage is finish
                [DEBUG] [influxDB] - InfluxDB-Backup for Keller is started ...
                [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_17-13_19_05_Keller_backupiobroker.tar.gz
                [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_17-13_19_05_Keller_backupiobroker"
                [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_17-13_19_05_Keller_backupiobroker" successfully deleted
                [DEBUG] [influxDB] - InfluxDB-Backup for Keller is finish
                [DEBUG] [influxDB] - done
                [DEBUG] [historyDB] - compress from historyDB started ...
                [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2024_01_17-13_19_09_Smarthome_backupiobroker.tar.gz
                [DEBUG] [historyDB] - done
                [DEBUG] [zigbee] - found zigbee database: zigbee.0
                [DEBUG] [zigbee] - done
                [DEBUG] [grafana] - Start Grafana Backup ...
                [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                [DEBUG] [grafana] - Created dashboard directory
                [DEBUG] [grafana] - Created dashboards_manually_restore directory
                [DEBUG] [grafana] - Created datasource directory
                [DEBUG] [grafana] - start Grafana request ...
                [DEBUG] [grafana] - Grafana is available ... Status: 200
                [DEBUG] [grafana] - found Dashboard: haus
                [DEBUG] [grafana] - found Dashboard: terrasse-garten
                [DEBUG] [grafana] - found Dashboard: temperatur-gefriere
                [DEBUG] [grafana] - found Dashboard: temperaturen-haus
                [DEBUG] [grafana] - found Dashboard: maschinen
                [DEBUG] [grafana] - found Dashboard: temp-pi
                [DEBUG] [grafana] - found Dashboard: stromzahler
                [DEBUG] [grafana] - found Dashboard: pv-ueberwachung
                [DEBUG] [grafana] - found Dashboard: stromverbrauch-haus-brutto
                [DEBUG] [grafana] - found Dashboard: stromverbrauch-tag
                [DEBUG] [grafana] - found Dashboard: signale-thermometer
                [DEBUG] [grafana] - found Dashboard: signale-bwm-licht-briefkasten-erschuetterung
                [DEBUG] [grafana] - found Dashboard: pv-mit-stromverbrauch
                [DEBUG] [grafana] - found Dashboard: signale-steckdose-birnen-relais
                [DEBUG] [grafana] - found Dashboard: keller
                [DEBUG] [grafana] - found Dashboard: alle-zigbee
                [DEBUG] [grafana] - found Dashboard: gasverbrauch-tag
                [DEBUG] [grafana] - found Dashboard: hobby
                [DEBUG] [grafana] - found Dashboard: mini-pv
                [DEBUG] [grafana] - found Dashboard: spuehlmaschine
                [DEBUG] [grafana] - found Dashboard: system-ueberwachung
                [DEBUG] [grafana] - found Dashboard: waschmaschine-2
                [DEBUG] [grafana] - found Dashboard: mini-pv-mit-luftentfeuchter
                [DEBUG] [grafana] - start Grafana backup compress ...
                [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2024_01_17-13_19_12_Smarthome_backupiobroker.tar.gz
                [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                [DEBUG] [grafana] - done
                [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                [DEBUG] [javascripts] - found Script: Alexa_Musik2
                [DEBUG] [javascripts] - found Script: Guten_Morgen_Alexa
                [DEBUG] [javascripts] - found Script: Licht_Arbeitszimmer
                [DEBUG] [javascripts] - found Script: Alexa_Aussentemperatur
                [DEBUG] [javascripts] - found Script: Alexa_Musik1
                [DEBUG] [javascripts] - found Script: Alexa_Musik_mit_Feiertagskalender
                [DEBUG] [javascripts] - found Script: Licht_Bad_OG
                [DEBUG] [javascripts] - found Script: Licht_Bad_OG_Feriertage
                [DEBUG] [javascripts] - found Script: Astro_Funktion
                [DEBUG] [javascripts] - found Script: Briefkasten
                [DEBUG] [javascripts] - found Script: Briefkasten_mit_BWM
                [DEBUG] [javascripts] - found Script: Esszimmer
                [DEBUG] [javascripts] - found Script: Gaszaehler
                [DEBUG] [javascripts] - found Script: Gaszaehler_Test_Runden
                [DEBUG] [javascripts] - found Script: Offene_Fenster
                [DEBUG] [javascripts] - found Script: Skript_1
                [DEBUG] [javascripts] - found Script: Vergleiche
                [DEBUG] [javascripts] - found Script: Video_1
                [DEBUG] [javascripts] - found Script: eCharts
                [DEBUG] [javascripts] - found Script: eCharts1
                [DEBUG] [javascripts] - found Script: Luftentfeuchter
                [DEBUG] [javascripts] - found Script: Licht_Arbeitsplatte
                [DEBUG] [javascripts] - found Script: Licht_Arbeitsplatte_2_BWM
                [DEBUG] [javascripts] - found Script: Alexa_Stromproduktion
                [DEBUG] [javascripts] - found Script: PV_Ertrag___Einspeisung
                [DEBUG] [javascripts] - found Script: PV_Gesamtertrag___Tag
                [DEBUG] [javascripts] - found Script: PV_Stromproduktion_aktuell
                [DEBUG] [javascripts] - found Script: Stromverbrauch_Haus
                [DEBUG] [javascripts] - found Script: 0_Einspeisung_An___Aus
                [DEBUG] [javascripts] - found Script: PV_Nulleinseisung
                [DEBUG] [javascripts] - found Script: PV_Nulleinseisung_(Backup)
                [DEBUG] [javascripts] - found Script: Tigger66
                [DEBUG] [javascripts] - found Script: Regenmelder_Echo_SZ
                [DEBUG] [javascripts] - found Script: Regenmelder_Echo_SZ_WZ
                [DEBUG] [javascripts] - found Script: Dimmer_Schlafzimmerlicht
                [DEBUG] [javascripts] - found Script: Dimmer_Schlafzimmerlicht__vereinfacht_
                [DEBUG] [javascripts] - found Script: Adapter_Updates
                [DEBUG] [javascripts] - found Script: Batterie_Sensor_Warnung
                [DEBUG] [javascripts] - found Script: Geraetestatus
                [DEBUG] [javascripts] - found Script: influxDB_Migration
                [DEBUG] [javascripts] - found Script: Timer_Steckdose_Carport
                [DEBUG] [javascripts] - found Script: Timer_Steckdose_Carport1
                [DEBUG] [javascripts] - found Script: Toilette_mit_BWM
                [DEBUG] [javascripts] - found Script: Toilette_mit_Erschüttertung
                [DEBUG] [javascripts] - found Script: Wohnzimmerbeleuchtung_Fritz
                [DEBUG] [javascripts] - found Script: Wohnzimmerbeleuchtung_Gosund
                [DEBUG] [javascripts] - found Script: Telegram_Test
                [DEBUG] [javascripts] - found Script: Test_Whatsapp
                [DEBUG] [javascripts] - found Script: Filament_Temperaturüberwachung
                [DEBUG] [javascripts] - found Script: Drucker_Abschaltung
                [DEBUG] [javascripts] - found Script: Filament_Temperaturüberwachung2
                [DEBUG] [javascripts] - found Script: Timer_Heizlüfter
                [DEBUG] [javascripts] - found Script: Wohnzimmerbeleuchtung_Tasmota
                [DEBUG] [javascripts] - found Script: Wohnzimmerbeleuchtung_Tasmota_fehlersuche
                [DEBUG] [javascripts] - found Script: Kaffeemaschine
                [DEBUG] [javascripts] - found Script: Waschmaschine_DECT
                [DEBUG] [javascripts] - found Script: Waschmaschine_Tasmota
                [DEBUG] [javascripts] - found Script: Waschmaschine_Tasmota1_Test_skript
                [DEBUG] [javascripts] - found Script: Gefriere_Temperaturüberwachung
                [DEBUG] [javascripts] - found Script: Gefriere_Paul_53
                [DEBUG] [javascripts] - found Script: Kühlschrank_Temperaturüberwachung
                [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2024_01_17-13_19_20_Smarthome_backupiobroker.tar.gz
                [DEBUG] [javascripts] - done
                [DEBUG] [cifs] - used copy path: /fritz.nas/BACKUPS/iobroker-backup
                [DEBUG] [cifs] - done
                [DEBUG] [dropbox] - Dropbox: Copy iobroker_2024_01_17-13_15_50_Smarthome_backupiobroker.tar.gz...
                [DEBUG] [dropbox] - Dropbox: Copy influxDB_2024_01_17-13_16_09_iobroker-data_backupiobroker.tar.gz...
                [DEBUG] [dropbox] - Dropbox: Copy influxDB_2024_01_17-13_17_59_IOB-Kurzzeit-1Jahr_backupiobroker.tar.gz...
                [DEBUG] [dropbox] - Dropbox: Copy influxDB_2024_01_17-13_18_54_iob-14-Tage_backupiobroker.tar.gz...
                [DEBUG] [dropbox] - Dropbox: Copy influxDB_2024_01_17-13_19_05_Keller_backupiobroker.tar.gz...
                [DEBUG] [dropbox] - Dropbox: Copy historyDB_2024_01_17-13_19_09_Smarthome_backupiobroker.tar.gz...
                [DEBUG] [dropbox] - Dropbox: Copy zigbee.0_2024_01_17-13_19_09_Smarthome_backupiobroker.tar.gz...
                [DEBUG] [dropbox] - Dropbox: Copy grafana_2024_01_17-13_19_12_Smarthome_backupiobroker.tar.gz...
                [DEBUG] [dropbox] - Dropbox: Copy javascripts_2024_01_17-13_19_20_Smarthome_backupiobroker.tar.gz...
                [DEBUG] [dropbox] - done
                [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually
                [DEBUG] [clean] - done
                [DEBUG] [telegram] - done
                [DEBUG] [historyHTML] - new history html values created
                [DEBUG] [historyHTML] - done
                [DEBUG] [historyJSON] - new history json values created
                [DEBUG] [historyJSON] - done
                [DEBUG] [umount] - mount activ, umount is started ...
                [DEBUG] [umount] - umount successfully completed
                [DEBUG] [umount] - done
                [EXIT] 0
                Kannst du mir bitte noch sagen wo du den Fehler vermustest so das ich dir von meinen Einstellungen noch einen Sc´reenshot zukommen lassen kann?
                  @duffy
                  Bei meinem FritzNAS müssen die Optionen 'noserverino' und 'cache=loose' gesetzt sein. Sonst werden da korrupte (zu kleine) Dateien geschrieben.
                  • Duffy
                    die sind bei mir auch drin.
                      Thomas Braun Most Active @Duffy last edited by Thomas Braun
                      @duffy
                      Da ist es aber anders:
                      Ist das über die ```fstab`` gemountet?
                      • Duffy
                        Duffy @Thomas Braun last edited by Duffy
                        @thomas-braun sagte in *** nodejs is NOT correctly installed ***[gelöst]:
                        Leider weis ich nicht was das ist.
                        Wenn du mir sagst was ich tun muss schaue ich gerne danach.
                        Wills ja richtig haben!
                          @duffy
                          cat /etc/fstab
                          • Duffy
                            cat /etc/fstab
                            Das schaut so aus:
                            pi@raspberrypi:~ $ cat /etc/fstab
                            proc            /proc           proc    defaults          0       0
                            PARTUUID=dd528ea5-01  /boot/firmware  vfat    defaults          0       2
                            PARTUUID=dd528ea5-02  /               ext4    defaults,noatime  0       1
                            # a swapfile is not a swap partition, no line here
                            #   use  dphys-swapfile swap[on|off]  for that
                            pi@raspberrypi:~ $
                            Will es halt nicht rikieren ein Backup wiederherzustellen wenns nicht nötig ist.
                            Sagen wir mal so, es hat schon mal funktioniert ist aber auch schon wieder ne Weile her.
                            312
