    2. English
    3. Development
    4. New Adapter - Soliscloud
    • Trixx
      Trixx last edited by
      @luapsi
      I've just pushed a new version to github, I think it should include all requested additions 🙂
      Regards,
      Trixx
        Luapsi @Trixx last edited by
        @trixx
        Your performance is great, thank you very much.
        I will test extensively and give you feedback.
        I wish you a pleasant day
          Luapsi @Trixx last edited by Luapsi
          Hi @trixx,
          all data fields are correct.
          Thanks for the quick and professional work.
          As you requested, it would be great if these values ​​could be added:
          from the v1/api/InverterDetail:
          1. familyLoadPower
          2. familyLoadPowerStr
          3. id inverter id
          4. sn inverter sn
          5. iAc1 AC current R
          6. iAc2 AC current S
          7. iAc3 AC current T
          8. uAc1 AC voltage R
          9. uAc2 AC voltage S
          10. uAc3 AC voltage T
          11. inverterTemperature
          12. batteryPower
          13. batterypowerStr
          14. batteryPowerPec
          15. batteryTodayChargeEnergy
          16. batteryTodayChargeEnergyStr
          17. batteryMonthChargeEnergy
          18. batteryMonthChargeEnergyStr
          19. batteryYearChargeEnergy
          20. batteryYearChargeEnergyStr
          21. batteryTotalChargeEnergy
          22. batteryTotalChargeEnergyStr
          23. batteryTodayDischargeEnergy
          24. batteryTodayDischargeEnergyStr
          25. batteryMonthDischargeEnergy
          26. batteryMonthDischargeEnergyStr
          27. batteryYearDischargeEnergy
          28. batteryYearDischargeEnergyStr
          29. batteryTotalDischargeEnergy
          30. batteryTotalDischargeEnergyStr
          another note about the data structure:
          Is it possible to create a separate folder for each API group, which would allow the data fields to be better allocated
          • Power Station List (v1/api/userStationList)
          • Power Station Detail (v1/api/stationDetail)
          • Datalogger List (v1/api/collectorList)
          • Data logger details (v1/api/collectorDetail)
          Inverter List (v1/api/inverterList)
          • Inverter details (v1/api/inverterDetail)
            possible!
          If I can support you here, please let me know.
          Greetings from Saxony
          PS: the app currently available from Solis cannot be used in this way.
          Trixx 1 Reply Last reply Reply Quote 0
          • Trixx
            Trixx @Luapsi last edited by
            @luapsi
            I've pushed another version to github.
            The values are split up between the inverter & station details, for the values I did have to switch some things.
            The month & year values aren't exported correctly for the inverter api call (they are returned as '0'), the stationDetail does provide the correct values so they are available under stationDetails instead.
            I still have a few more to add and need to adjust some units .
            I'll try to get to those later today or later this week.
            Regards,
            Trixx
              @trixx
              Thank you for your enthusiasm and commitment!
              For me the values ​​are also "zero", I will create a ticket with "Soliscloud" so that we can achieve clarity here.
              Let me know if there is any news.
              Greetings Sven
                Luapsi @Luapsi last edited by Luapsi
                @Trixx
                The problem with the API is solved.
                An additional group is still needed 🙂
                Is it possible for you to integrate these?
                is needed to calculate data!
                Thank you very much in advance!
                from v1/api/epmDetail:
                1. state
                2. iAc1 Current U
                3. iAc2 Current V
                4. iAc3 Current W
                5. uAc1 Voltage U
                6. uAc2 Voltage V
                7. uAc3 Voltage W
                8. pAc1 Power U
                9. pAc2 Power V
                10. pAc3 Power W
                11. facMeter
                12. pEpmTotal
                13. pEpmTotalStr
                14. eTotalBuy
                15. eTotalBayStr
                16. eTotalSell
                17. etotalSellStr
                Thanks
                Trixx 2 Replies Last reply Reply Quote 0
                • Trixx
                  @luapsi
                  I'll see what I can do !
                  • Trixx
                    @luapsi
                    Sorry for the delayed response. I've taken a look at this, it should be possible to add to the adapter. But I don't have anything in the EPM result for my plant so i'll try to create this based on the documentation.
                    I do have some IRL things to take care of this week, so it might be a few days before I get to this.
                    Regards,
                    Trixx
                    • Trixx
                      Trixx last edited by Trixx
                      @luapsi
                      Hi !
                      Sorry for the long delay. I had some stuff going on that I needed to handle first...
                      I've created a new build that has an option to enable the EPM api call, there's also an option to enable logging for this call.
                      Could you try this version, enable the logging and send me a copy of the logging for the api call ?
                      With that I should be able to map the values you requested.
                      Edit; I've also added an option to send (anonymous) stacktraces of any errors that occur. This is completely opt-in and not required.
                      Happy holidays !
                      Regards,
                      Trixx
                      • M T
                        M T @Schneider_Helmut last edited by
                        Hallo
                        Können sie bitte einen Bild hochladen welche Einstellung bei der App und welche Angaben wo eingesetzt werden
                        @schneider_helmut said in New Adapter - Soliscloud:
                        @trixx
                        Thank you. Everything works great now. Grate job! I waited over a year for a Solis adapter for IO Broker because I wasn't able to use the Solis API myself.
                        Perhaps it would be important to mention that for "Station/Plant ID" you do not have to enter the ID "1668XX" from the Soli portal as expected, but rather the id from the browser address while you are logged in to your solis account "https://www.soliscloud.com/#/station/stationdetail_1?id=12984919194490002YY". "Station/Plant ID" must be entered here "12984919194490002YY".
                        mcm1957 M T 2 Replies Last reply Reply Quote 0
                        • mcm1957
                          mcm1957 @M T last edited by mcm1957
                          @m-t said in New Adapter - Soliscloud:
                          Hallo
                          Können sie bitte einen Bild hochladen .........
                          This is the english section of the forum. Please use english language only. If you want to discuss a problem in german, pleae use german area.
                          M T 1 Reply Last reply Reply Quote 0
                          • M T
                            M T @mcm1957 last edited by
                            Can you give me a screenshot of the app settings? how to enter the data
                            @mcm57 said in New Adapter - Soliscloud:
                            Hallo
                            • M T
                              M T @M T last edited by
                              Can you tell me what data I need to enter??
                              Hallo
                              @trixx
                              • mcm1957
                                @m-t
                                Did you follow the instructions at README.md (https://github.com/Trixx34/ioBroker.SolisCloud?tab=readme-ov-file#soliscloud-adapter-for-iobroker) ? Looks like that getting the required data is decribed there.
                                What information do you miss in detail?
                                • M T
                                  I'm concerned about which data and where should I enter it?
                                  IMG_4452.jpeg @mcm57 said in New Adapter - Soliscloud:
                                  @m-t
                                  • mcm1957
                                    @m-t
                                    As your screenshot shows there is exactly one field for api key and one filed for the api secret at the first line.
                                    Did you try to enter them there?
                                    Or did I misunderstand your question.
                                    What cocerns do you have?
                                    • M T
                                      @m-t
                                      I use iobroker which data I have to enter where so that I can establish a connection
                                      • Trixx
                                        Trixx @M T last edited by
                                        @m-t
                                        Hi!
                                        What you show in your screenshot should work.
                                        You will also need to add a specific interval that's used between each API call. (Between 45 & 1800 seconds).
                                        Unrelated remark: I noticed I've left some test code in the last release that logs an error every time the api is polled. This will show "This is the error" in the logging. This can be ignored, I'll push a new version during the weekend that fixes this.
                                        Regards,
                                        T
                                        • M T
                                          M T @Trixx last edited by
                                          @trixx said in New Adapter - Soliscloud:
                                          @m-t
                                          Hi!
                                          Regards,
                                          T
                                          The connection is established! Excellent ! Can't you shorten the polling time by 0-1800?
                                          • mcm1957
                                            @m-t
                                            Cloud access MUST have a reasonable minimum Intervall. Otherwise cloud service might ve overliaded an access might be blocked for all ioBroker users. So a minimum of 0bis definitly too low and would not be accepted at repository.
                                            57
                                            8523
