    4. Start aus Backup *gelöst*
      Thomas Braun Most Active @Thomas Braun last edited by
      @gluecksmann
      Wie immer.
      iob diag
        gluecksmann @Thomas Braun last edited by
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.1.0-rpi7-rpi-v8
            Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         19:37:57 up 15 min,  4 users,  load average: 0.54, 1.05, 1.02
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Wed 2024-01-17 19:37:57 CET
                   Universal time: Wed 2024-01-17 18:37:57 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            8.2G        2.3G        5.0G         16M        1.1G        5.9G
        Swap:           104M          0B        104M
        Total:          8.3G        2.3G        5.1G
                 7811 M total memory
                 2148 M used memory
                 2222 M active memory
                  522 M inactive memory
                 4780 M free memory
                  100 M buffer memory
                  919 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     782M  1.3M  780M   1% /run
        /dev/mmcblk0p2 ext4       58G  6.7G   49G  13% /
        tmpfs          tmpfs     3.9G  140K  3.9G   1% /dev/shm
        /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
        tmpfs          tmpfs     782M   36K  782M   1% /run/user/1000
        [Wed Jan 17 19:22:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9e5696c9-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
        [Wed Jan 17 19:22:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Jan 17 19:22:58 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET               SOURCE         FSTYPE      OPTIONS
        /                    /dev/mmcblk0p2 ext4        rw,noatime,commit=600
        |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        567M    /var/
        191M    /var/lib
        186M    /var/cache
        173M    /var/cache/apt
        132M    /var/lib/apt/lists
        Archived and active journals take up 87.9M in the file system.
        /opt/iobroker/backups:
        22M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        434M    /opt/iobroker/iobroker-data/
        335M    /opt/iobroker/iobroker-data/files
        78M     /opt/iobroker/iobroker-data/backup-objects
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        16M     /opt/iobroker/iobroker-data/objects.jsonl
        8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
             18.19.0+dfsg-6~deb12u1 500
         *** 18.19.0-1nodesource1 1001
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   1
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
        + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
          system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
          system.adapter.devices.0                : devices               : raspberrypi                              - disabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
        + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
        + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
          system.adapter.history.0                : history               : raspberrypi                              - disabled
        + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
        + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
        + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
        + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
        + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
        + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
          system.adapter.philips-air.1            : philips-air           : raspberrypi                              - disabled
          system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
        + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
        + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
          system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: ls -l /dev/serial/by-id
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
        Adapter    "awtrix-light" : 0.11.0   , installed 0.11.0
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "ble"          : 0.13.4   , installed 0.13.4
        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
        Adapter    "daswetter"    : 3.1.12   , installed 3.1.12
        Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
        Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
        Adapter    "hue"          : 3.10.1   , installed 3.10.1
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
        Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
        Objects and States
        Objects:        11303
        States:         9421
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       41201      8877/io.sonoff.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16825      793/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35809      8663/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       35802      8663/iobroker.js-co
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15771      774/cupsd
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15770      774/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          16827      793/sshd: /usr/sbin
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       39057      8737/io.sonos.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       41344      8984/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       38253      8683/io.admin.0
        tcp6       0      0 :::3000                 :::*                    LISTEN      1001       41952      10042/io.fullybrows
        udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       39692      9179/io.musiccast.0
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18248      1323/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        11898      521/avahi-daemon: r
        udp        0      0 0.0.0.0:54831           0.0.0.0:*                           104        11900      521/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       38531      8862/io.shelly.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       40342      8892/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       40343      8892/io.tuya.0
        udp        0      0 0.0.0.0:56284           0.0.0.0:*                           1001       40286      8847/io.philips-air
        udp6       0      0 fe80::a6e1:3ab9:3bf:546 :::*                                0          17321      660/NetworkManager
        udp6       0      0 fe80::e996:6ae8:1bc:546 :::*                                0          17225      660/NetworkManager
        udp6       0      0 :::5353                 :::*                                104        11899      521/avahi-daemon: r
        udp6       0      0 :::43656                :::*                                104        11901      521/avahi-daemon: r
        2024-01-17 19:36:26.646  - info: zigbee.0 (21674) Installed Version: iobroker.zigbee@1.9.7
        2024-01-17 19:36:50.317  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2024-01-17 19:36:50.322  - info: zigbee.0 (21674) Got terminate signal TERMINATE_YOURSELF
        2024-01-17 19:36:50.363  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
        2024-01-17 19:36:50.324  - info: zigbee.0 (21674) cleaned everything up...
        2024-01-17 19:36:50.542  - info: zigbee.0 (21674) Zigbee: disabling joining new devices.
        2024-01-17 19:36:50.633  - warn: zigbee.0 (21674) Failed to stop zigbee during startup
        2024-01-17 19:36:50.635  - info: zigbee.0 (21674) terminating
        2024-01-17 19:36:50.637  - info: zigbee.0 (21674) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-01-17 19:36:50.773  - info: zigbee.0 (21674) debug devices set to []
        2024-01-17 19:36:50.825  - info: zigbee.0 (21674) terminating
        2024-01-17 19:36:51.266  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-01-17 19:36:53.513  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 23114
        2024-01-17 19:36:58.857  - info: zigbee.0 (23114) starting. Version 1.9.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
        2024-01-17 19:36:58.970  - info: zigbee.0 (23114) Starting Zigbee  npm ...
        2024-01-17 19:36:59.349  - error: zigbee.0 (23114) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open ls -l /dev/serial/by-id'"
        2024-01-17 19:36:59.350  - error: zigbee.0 (23114) Failed to start Zigbee
        2024-01-17 19:36:59.351  - error: zigbee.0 (23114) Error herdsman start
        2024-01-17 19:36:59.355  - info: zigbee.0 (23114) Installed Version: iobroker.zigbee@1.9.7
        2024-01-17 19:37:09.355  - info: zigbee.0 (23114) Try to reconnect. 1 attempts left
        2024-01-17 19:37:09.356  - info: zigbee.0 (23114) Starting Zigbee  npm ...
        2024-01-17 19:37:09.374  - error: zigbee.0 (23114) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open ls -l /dev/serial/by-id'"
        2024-01-17 19:37:09.375  - error: zigbee.0 (23114) Failed to start Zigbee
        2024-01-17 19:37:09.376  - error: zigbee.0 (23114) Error herdsman start
        2024-01-17 19:37:09.385  - info: zigbee.0 (23114) Installed Version: iobroker.zigbee@1.9.7
        Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @gluecksmann last edited by Glasfaser
          @gluecksmann sagte in Start aus Backup:
          Steht in den Instanzeinstellung Zigbee zum Stick
            gluecksmann @Glasfaser last edited by
            @glasfaser
            Ja, das stand so in der Anleitung....
            https://www.elzershark.com/forum/index.php?thread/137-zigbee-richtig-aufbauen-mit-dem-zigbee-adapter-von-iobroker/
            evtl habe ich da was falsch verstanden...
            • Glasfaser
              @glasfaser
              Damit wird im Putty geprüft ..
                Thomas Braun Most Active @gluecksmann last edited by Thomas Braun
                Boot Target: graphical.target
                Würde ich ändern auf
                sudo systemctl set-default multi-user.target
                Du hast ja auch Quatsch in den Com-Port eingetragen....
                Statt
                gehört da das rein:
                • Glasfaser
                  Glasfaser @Homoran last edited by Glasfaser
                  @gluecksmann
                  @homoran sagte in Start aus Backup:
                  Aber hier melden sich immer wieder welche,
                  da ... die hier bei iobroker.net den besten Support bekommen 😉
                    Homoran Global Moderator Administrators @Homoran last edited by
                    @gluecksmann dein /dev/serial/by-id in der Konfiguration scheint bei der list of ports nicht dabei zu sein.
                    Du solltest aber doch inzwischen wissen dass logs als Text in code-tags gepostet werden
                    wie ich schon vor Tagen sagte
                    @glasfaser sagte in Start aus Backup:
                      @glasfaser
                      Habe die andere Anleitung genutzt, weil die ...zumindest teilweise an Stellen funktioniert hat und bebildert war... im Gegensatz zu der hier verlinkten...
                      Aber mal sehen... ging mir ja darum die garäte zu behalten...zwischendurch habe ich die auch kurz gesehen...
                        gluecksmann @gluecksmann last edited by
                        @gluecksmann
                        ist nicht besser geworden..
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                         19:56:43 up 33 min,  4 users,  load average: 0.97, 0.69, 0.75
                        CPU threads: 4
                        Current issues:
                                       Local time: Wed 2024-01-17 19:56:44 CET
                                   Universal time: Wed 2024-01-17 18:56:44 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           104M          0B        104M
                                 7811 M total memory
                                 2170 M used memory
                                 2244 M active memory
                                  527 M inactive memory
                                 4751 M free memory
                                  100 M buffer memory
                                  925 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        567M    /var/
                        191M    /var/lib
                        186M    /var/cache
                        173M    /var/cache/apt
                        439M    /opt/iobroker/iobroker-data/
                        9.5M    /opt/iobroker/iobroker-data/states.jsonl
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.6
                        Adapter State
                        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0
                        + instance is alive
                        Objects and States
                        Objects:        11553
                        States:         9447
                        Pending Updates: 0
                        2024-01-17 19:54:13.273  - error: gruenbeck.0 (9111) https://prod-eu-gruenbeck-api.azurewebsites.net/api/devices/softliQ.C/BS00072047/realtime/enter?api-version=2020-08-03
                        2024-01-17 19:54:13.274  - error: gruenbeck.0 (9111) AxiosError: Request failed with status code 404
                        2024-01-17 19:54:13.274  - error: gruenbeck.0 (9111) Failed enter SD
                        2024-01-17 19:54:13.275  - info: gruenbeck.0 (9111) Relogin
                        2024-01-17 19:54:13.595  - info: gruenbeck.0 (9111) Login step 1
                        2024-01-17 19:54:14.002  - info: gruenbeck.0 (9111) Login step 2
                        2024-01-17 19:54:14.577  - info: gruenbeck.0 (9111) Login successful
                        2024-01-17 19:54:17.758  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                        2024-01-17 19:54:21.746  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                        2024-01-17 19:54:26.256  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                        2024-01-17 19:54:39.079  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                        2024-01-17 19:54:50.090  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                        2024-01-17 19:54:55.889  - info: admin.0 (8683) <== Disconnect system.user.admin from ::ffff:192.168.2.61
                        2024-01-17 19:54:57.812  - info: admin.0 (8683) ==> Connected system.user.admin from ::ffff:192.168.2.61
                        2024-01-17 19:54:58.315  - error: zigbee.0 (59735) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                        2024-01-17 19:54:58.561  - info: zigbee.0 (59735) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"34337ce2ac9ded11ab46cfa5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                        2024-01-17 19:55:00.026  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 62862
                        2024-01-17 19:55:00.519  - warn: sonos.0 (8737) State "sonos.0.root.192_168_2_145.queue_html" has no existing object, this might lead to an error in future versions
                        2024-01-17 19:55:00.696  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                        2024-01-17 19:55:02.665  - info: dwd.0 (62862) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
                        2024-01-17 19:55:07.202  - info: dwd.0 (62862) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2024-01-17 19:55:07.970  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-01-17 19:55:08.055  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                        2024-01-17 19:55:24.744  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                        2024-01-17 19:55:30.910  - info: govee.0 (9088) State value to set for "govee.0.BB:6C:D0:33:36:31:36:78.online" has to be type "boolean" but received type "string"
                        • Glasfaser
                          Hast du jetzt einen neuen Stick ...
                          das ist der alte hier im Thread !?
                          /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
                          EDIT :
                          OK
                          überlesen :
                          So, neuer Stick.
                            @glasfaser
                            Ja, habe einen neuen Stick... wurde mir ja in diesem Threat empfohen einen neuen zu verwenden...
                              @gluecksmann
                              Starte die Kiste mal komplett sauber durch.
                              sudo reboot
                                @thomas-braun sagte in Start aus Backup:
                                sudo reboot
                                wenn ich Geräte koppeln will kommt das...
                                Error: Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0 '". undefined
                                  @gluecksmann
                                  Du hast vermutlich ein Leerzeichen hintendran.
                                    Alter! Ich muß mal ein ganz großes Lob aussprechen...im Leben wäre ich nicht auf so etwas gekommen... jetzt läuft es, sogar die alten Geräte sind da... mal sehen ob ich jetzt die Aquara Komponenten angemeldet bekomme...
                                      Homoran Global Moderator Administrators @gluecksmann last edited by
                                      warum nicht?
                                      zwischen port0 und dem abschließenden ' ist es ganz deutlich zu sehen.
                                        gluecksmann @Homoran last edited by
                                        für den Wissenden bestimmt...ich glaueb ich habe gut unter Beweis gestellt das ich nicht dazu gehöre;-)
                                        1617
