    4. [gelöst} zigbee-adapter will nicht mehr starten
      bommelmeier last edited by bommelmeier
      Moin,
      ich habe sämtliche Adapter, die angemeckert wurden, upgedated. Klappte in der grafischen Konsole zunächst perfekt.
      Allerdings will der Zigbee-Adapter nicht starten, fällt immer wieder auf die Nase.
      2024-01-09 12:46:18.157  - info: zigbee.0 (5081) starting. Version 1.9.7 (non-npm: ioBroker/ioBroker.zigbee#ef932ce47a1c5e824031179ce919640a832d1a71) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 4.0.24
      2024-01-09 12:46:18.296  - error: zigbee.0 (5081) Failed to call 'Backup' 'configure' (TypeError: Class extends value undefined is not a constructor or null
          at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/read-entry.js:97:4)
          at Module._compile (node:internal/modules/cjs/loader:1356:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          at Module.load (node:internal/modules/cjs/loader:1197:32)
          at Function.Module._load (node:internal/modules/cjs/loader:1013:12)
          at Module.require (node:internal/modules/cjs/loader:1225:19)
          at require (node:internal/modules/helpers:177:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/pack.js:27:19)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10))
      2024-01-09 12:46:18.335  - error: zigbee.0 (5081) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2024-01-09 12:46:18.337  - error: zigbee.0 (5081) unhandled promise rejection: Class extends value undefined is not a constructor or null
      2024-01-09 12:46:18.340  - error: zigbee.0 (5081) TypeError: Class extends value undefined is not a constructor or null
      2024-01-09 12:46:18.341  - error: zigbee.0 (5081) Class extends value undefined is not a constructor or null
      2024-01-09 12:46:18.367  - info: zigbee.0 (5081) cleaned everything up...
      2024-01-09 12:46:18.814  - warn: zigbee.0 (5081) Failed to stop zigbee during startup
      2024-01-09 12:46:18.816  - info: zigbee.0 (5081) terminating
      2024-01-09 12:46:18.839  - warn: zigbee.0 (5081) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-01-09 12:46:20.163  - warn: zigbee.0 (5081) get state error: DB closed
      2024-01-09 12:46:20.199  - warn: zigbee.0 (5081) get state error: Connection is closed.
      2024-01-09 12:46:20.201  - warn: zigbee.0 (5081) get state error: Connection is closed.
      2024-01-09 12:46:20.723  - error: host.pi3 Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2024-01-09 12:46:20.726  - error: host.pi3 Caught by controller[1]: TypeError: Class extends value undefined is not a constructor or null
      2024-01-09 12:46:20.728  - error: host.pi3 Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/read-entry.js:97:4)
      2024-01-09 12:46:20.730  - error: host.pi3 Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-09 12:46:20.732  - error: host.pi3 Caught by controller[1]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-09 12:46:20.733  - error: host.pi3 Caught by controller[1]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-09 12:46:20.735  - error: host.pi3 Caught by controller[1]:     at Function.Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-09 12:46:20.737  - error: host.pi3 Caught by controller[1]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
      2024-01-09 12:46:20.738  - error: host.pi3 Caught by controller[1]:     at require (node:internal/modules/helpers:177:18)
      2024-01-09 12:46:20.740  - error: host.pi3 Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/pack.js:27:19)
      2024-01-09 12:46:20.742  - error: host.pi3 Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-09 12:46:20.744  - error: host.pi3 Caught by controller[1]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-09 12:46:20.746  - error: host.pi3 Caught by controller[2]: Was not able to detect the Linky linky_mode. Default to historique
      2024-01-09 12:46:20.747  - error: host.pi3 Caught by controller[3]: Was not able to detect the Linky energy_phase. Default to single_phase
      2024-01-09 12:46:20.749  - error: host.pi3 Caught by controller[4]: Not able to detect the current tarif. Not filtering any expose...
      2024-01-09 12:46:20.751  - error: host.pi3 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2024-01-09 12:46:20.754  - info: host.pi3 Restart adapter system.adapter.zigbee.0 because enabled
      2024-01-09 12:46:50.920  - info: host.pi3 instance system.adapter.zigbee.0 started with pid 5125
      2024-01-09 12:46:59.981  - info: zigbee.0 (5125) starting. Version 1.9.7 (non-npm: ioBroker/ioBroker.zigbee#ef932ce47a1c5e824031179ce919640a832d1a71) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 4.0.24
      2024-01-09 12:47:00.097  - error: zigbee.0 (5125) Failed to call 'Backup' 'configure' (TypeError: Class extends value undefined is not a constructor or null
      2024-01-09 12:47:00.130  - error: zigbee.0 (5125) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2024-01-09 12:47:00.132  - error: zigbee.0 (5125) unhandled promise rejection: Class extends value undefined is not a constructor or null
      2024-01-09 12:47:00.134  - error: zigbee.0 (5125) TypeError: Class extends value undefined is not a constructor or null
      2024-01-09 12:47:00.135  - error: zigbee.0 (5125) Class extends value undefined is not a constructor or null
      2024-01-09 12:47:00.158  - info: zigbee.0 (5125) cleaned everything up...
      2024-01-09 12:47:00.502  - warn: zigbee.0 (5125) Failed to stop zigbee during startup
      2024-01-09 12:47:00.504  - info: zigbee.0 (5125) terminating
      2024-01-09 12:47:00.509  - warn: zigbee.0 (5125) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-01-09 12:47:01.624  - warn: zigbee.0 (5125) get state error: DB closed
      2024-01-09 12:47:01.662  - warn: zigbee.0 (5125) get state error: Connection is closed.
      2024-01-09 12:47:01.664  - warn: zigbee.0 (5125) get state error: Connection is closed.
      2024-01-09 12:47:02.109  - error: host.pi3 Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2024-01-09 12:47:02.112  - error: host.pi3 Caught by controller[1]: TypeError: Class extends value undefined is not a constructor or null
      2024-01-09 12:47:02.113  - error: host.pi3 Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/read-entry.js:97:4)
      2024-01-09 12:47:02.114  - error: host.pi3 Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-09 12:47:02.116  - error: host.pi3 Caught by controller[1]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-09 12:47:02.117  - error: host.pi3 Caught by controller[1]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-09 12:47:02.118  - error: host.pi3 Caught by controller[1]:     at Function.Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-09 12:47:02.119  - error: host.pi3 Caught by controller[1]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
      2024-01-09 12:47:02.121  - error: host.pi3 Caught by controller[1]:     at require (node:internal/modules/helpers:177:18)
      2024-01-09 12:47:02.122  - error: host.pi3 Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/pack.js:27:19)
      2024-01-09 12:47:02.123  - error: host.pi3 Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-09 12:47:02.124  - error: host.pi3 Caught by controller[1]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-09 12:47:02.125  - error: host.pi3 Caught by controller[2]: Was not able to detect the Linky linky_mode. Default to historique
      2024-01-09 12:47:02.126  - error: host.pi3 Caught by controller[3]: Was not able to detect the Linky energy_phase. Default to single_phase
      2024-01-09 12:47:02.127  - error: host.pi3 Caught by controller[4]: Not able to detect the current tarif. Not filtering any expose...
      2024-01-09 12:47:02.128  - error: host.pi3 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2024-01-09 12:47:02.130  - info: host.pi3 Restart adapter system.adapter.zigbee.0 because enabled
      Ich hatte sowohl die originale, als auch die Github-Version versucht - beide Male die selben Fehler.
      Merkwürdigerweise nutzt das zurückspielen eines Backups auch nichts.
      Auffällig ist auch der 4-er js-controller, der sich partout nicht auf die 5-er updaten läßt.
      Der "upgrade self --debug" Aufruf schmeißt auch einen Fehler, der im Startlog vom Zigbee immer wieder auftaucht:
      iobroker upgrade self --debug
      Update js-controller from @4.0.24 to @5.0.17
      Stopped Objects DB
      Stopped States DB
      NPM version: 10.2.5
      Installing iobroker.js-controller@5.0.17... (System call)
      npm WARN cleanup Failed to remove some directories [
      npm WARN cleanup   [
      npm WARN cleanup     '/opt/iobroker/node_modules/diskusage',
      npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/diskusage'] {
      npm WARN cleanup       errno: -39,
      npm WARN cleanup       code: 'ENOTEMPTY',
      npm WARN cleanup       syscall: 'rmdir',
      npm WARN cleanup       path: '/opt/iobroker/node_modules/diskusage'
      npm WARN cleanup     }
      npm WARN cleanup   ]
      npm WARN cleanup ]
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! command failed
      npm ERR! command sh -c node iobroker.js setup first
      npm ERR! /opt/iobroker/node_modules/tar/lib/read-entry.js:97
      npm ERR!   [SLURP] (ex, global) {
      npm ERR!    ^
      npm ERR!
      npm ERR! TypeError: Class extends value undefined is not a constructor or null
      npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/read-entry.js:97:4)
      npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      npm ERR!     at Module.load (node:internal/modules/cjs/loader:1197:32)
      npm ERR!     at Module._load (node:internal/modules/cjs/loader:1013:12)
      npm ERR!     at Module.require (node:internal/modules/cjs/loader:1225:19)
      npm ERR!     at require (node:internal/modules/helpers:177:18)
      npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/pack.js:27:19)
      npm ERR!
      npm ERR! Node.js v18.19.0
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-09T12_05_48_126Z-debug-0.log
      und die Version bleibt auf 4.0.2.4:
      bede@pi3:/opt/iobroker $ iobroker update
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
      Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
      Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
      Wäre für jede Hilfe dankbar...
      Bommel
      diag:
                              v.2023-10-10
         Static hostname: pi3
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               arm64
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               false
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                              /usr/bin/node           v18.19.0
                              /usr/bin/npm            10.2.5
                              /usr/bin/npx            10.2.5
                              /usr/bin/corepack       0.22.0
      Recommended versions are nodejs  and npm
      MEMORY:
      Mem:            909M        115M        190M        0.0K        603M        729M
      Swap:            99M         46M         53M
      Total:          1.0G        162M        243M
      Active iob-Instances:   12
      Active repo(s): stable
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.12.0
      ioBroker Status:        iobroker is not running on this host.
      At least one iobroker host is running.
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : ackermannn                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : ackermannn                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                7802
      States:                 7902
      Size of iob-Database:
      136K    /opt/iobroker/iobroker-data/objects.jsonl
      84K     /opt/iobroker/iobroker-data/states.jsonl
      Some problems detected, please run iob fix and try to have them fixed
        @bommelmeier sagte in zigbee-adapter will nicht mehr starten:
        und was hat das mit zgbee adapter zu utn .. ??? änder bitte den Titel.. zigbee-adapter will nicht mehr starten
        und das ist dein Problem
        #Operating System: Debian GNU/Linux 11 (bullseye)
        bring dein System up to date
          Thomas Braun Most Active @bommelmeier last edited by
          iob stop
          iob fix
          iob start
            bommelmeier @Thomas Braun last edited by
            So, erst mal danke für den Schubser.
            Bin jetzt auf Bookworm, mit taufrischem System.
            Der Zigbee-Adapter will aber immer noch nicht korrekt starten, hab ihn auch schon neu installiert.
            Jetzt ist es aber angeblich der Port - was ich mir nun gar nicht erklären kann:
            2024-01-10 00:03:23.702  - info: zigbee.0 (3076) Starting Zigbee  npm ...
            2024-01-10 00:03:25.653  - info: zigbee.0 (3076) Installed Version: iobroker.zigbee@1.9.7
            2024-01-10 00:03:45.939  - error: zigbee.0 (3076) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
            2024-01-10 00:03:45.942  - error: zigbee.0 (3076) Failed to start Zigbee
            2024-01-10 00:03:45.943  - error: zigbee.0 (3076) Error herdsman start
            2024-01-10 00:03:55.956  - info: zigbee.0 (3076) Try to reconnect. 1 attempts left
            2024-01-10 00:03:55.963  - info: zigbee.0 (3076) Starting Zigbee  npm ...
            2024-01-10 00:03:55.995  - info: zigbee.0 (3076) Installed Version: iobroker.zigbee@1.9.7
            2024-01-10 00:03:56.686  - error: zigbee.0 (3076) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
            2024-01-10 00:03:56.692  - error: zigbee.0 (3076) Failed to start Zigbee
            2024-01-10 00:03:56.693  - error: zigbee.0 (3076) Error herdsman start
            Die Einstellungen sollten aber passen:
            /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220708094955-if00
            als Typ TI Z-Stack/CCxxxx
            Neustart ist auch schon gelaufen.
            Hat noch jemand einen Tip?
              bommelmeier @bommelmeier last edited by
              Kommando zurück:
              Nach der ganzen Updaterei mußte nochmal der Typ des Adapters umgestellt werden, jetzt hauts wieder hin.
              Fehlt noch das Update vom hc-controller, aber das erst nach Backup.
              Danke.
              Bommel
              Meister Mopper N 2 Replies Last reply Reply Quote 0
              • Meister Mopper
                Meister Mopper @bommelmeier last edited by
                @bommelmeier sagte in [gelöst} zigbee-adapter will nicht mehr starten:
                Was bedeutet Typ des Adapters?
                • N
                  n811e @bommelmeier last edited by
                  @bommelmeier
                  wie meinst Du das? Was genau hast Du gemacht?
                    Dave83 last edited by Dave83
                    Ist jemand da, der sich mit Discrod auf meinen Rechner schalten könnte?
                    Ich hab den gleichen Fehler. Nun nach einem neustart, kann ich mich nicht verbinden. -.-
                    Bildschirmfoto 2024-02-29 um 20.31.19.png Bildschirmfoto 2024-02-29 um 20.31.31.png
                    @bommelmeier uns hätte es geholfen, wenn du genau gesagt hättest welcher Eintrag sich zurückgestellt hat udn was dort als richtig anerkannt wird.
                    EDIT. geht wieder. Keine Ahnugn warum.
