    4. Web Interface nach Update nicht erreichbar
      Thomas Braun Most Active @viper2033 last edited by
      @viper2033
      iob diag
      sagt?
      viper2033 1 Reply Last reply Reply Quote 0
      • viper2033
        viper2033 @Thomas Braun last edited by Homoran
        2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
        2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
        2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
        2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
        2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]: Node.js v18.19.0
        2024-01-18 13:13:15.309  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-01-18 13:13:15.309  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
        2024-01-18 13:13:24.362  - info: host.CT210 instance system.adapter.iot.0 started with pid 25033
        2024-01-18 13:13:25.155  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
        2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
        2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
        2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
        2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
        2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
        2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
        2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
        2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
        2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
        2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
        2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
        2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/googleHome.js:2:17)
        2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
        2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
        2024-01-18 13:13:25.156  - error: host.CT210 instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-01-18 13:13:25.156  - info: host.CT210 Restart adapter system.adapter.iot.0 because enabled
          Thomas Braun Most Active @viper2033 last edited by Thomas Braun
          @viper2033
          Das ist nicht die vollständige Ausgabe der Langfassung von iob diag.
          Und es steht nicht in CodeTags...
          • viper2033
            code_text
            *** BASE SYSTEM ***
               Static hostname: CT210
                     Icon name: computer-container
                       Chassis: container
                Virtualization: lxc
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.5.11-4-pve
                  Architecture: x86-64
            model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
            Docker          : false
            Virtualization  : lxc
            Kernel          : x86_64
            Userland        : amd64
            Systemuptime and Load:
             13:38:19 up  5:00,  1 user,  load average: 0.39, 0.25, 0.20
            CPU threads: 2
            *** Time and Time Zones ***
                           Local time: Thu 2024-01-18 13:38:19 UTC
                       Universal time: Thu 2024-01-18 13:38:19 UTC
                             RTC time: n/a
                            Time zone: Etc/UTC (UTC, +0000)
                          NTP service: inactive
                      RTC in local TZ: no
            *** User and Groups ***
            test
            /home/test
            test sudo iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
            Mem:            2.0G        714M        860M        0.0K        472M        1.3G
            Swap:           512M          0B        512M
            Total:          2.6G        714M        1.4G
                     2048 M total memory
                      714 M used memory
                      776 M active memory
                      294 M inactive memory
                      860 M free memory
                        0 M buffer memory
                      472 M swap cache
                      512 M total swap
                        0 M used swap
                      512 M free swap
            *** FAILED SERVICES ***
              UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
            * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
            * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
            * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            3 loaded units listed.
            *** FILESYSTEM ***
            Filesystem                       Type      Size  Used Avail Use% Mounted on
            /dev/mapper/pve-vm--210--disk--0 ext4      7.8G  4.4G  3.1G  59% /
            none                             tmpfs     492K  4.0K  488K   1% /dev
            udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
            tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
            tmpfs                            tmpfs     1.6G  112K  1.6G   1% /run
            tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
            dmesg: read kernel buffer failed: Operation not permitted
            TARGET SOURCE                           FSTYPE OPTIONS
            /      /dev/mapper/pve-vm--210--disk--0 ext4   rw,relatime,stripe=16
            /var:
            898M    /var/
            418M    /var/log
            380M    /var/log/journal/e982dcf1ad9c45638928dfce9f1ddc3d
            344M    /var/cache
            Archived and active journals take up 16.0M in the file system.
            /opt/iobroker/backups:
            34M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            366M    /opt/iobroker/iobroker-data/
            319M    /opt/iobroker/iobroker-data/files
            89M     /opt/iobroker/iobroker-data/files/echarts.admin
            67M     /opt/iobroker/iobroker-data/files/javascript.admin
            57M     /opt/iobroker/iobroker-data/files/echarts
            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
            23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
            USB-Devices by-id:
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.19.0
            /usr/bin/node           v18.19.0
            /usr/bin/npm            10.3.0
            /usr/bin/npx            10.3.0
            /usr/bin/corepack       0.22.0
            nodejs:
              Installed: 18.19.0-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
             *** 18.19.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                    500 http://security.debian.org bullseye-security/main amd64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  4.0.23
            admin:          6.12.0
            javascript:     7.1.6
            Adapters from github:   0
            Adapter State
              system.adapter.admin.0                  : admin                 : CT210                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0               : backitup              : CT210                                    -  enabled
            + system.adapter.deyeidc.0                : deyeidc               : CT210                                    -  enabled, port: 8899
            + system.adapter.discovery.0              : discovery             : CT210                                    -  enabled
              system.adapter.ebus.0                   : ebus                  : CT210                                    - disabled
            + system.adapter.echarts.0                : echarts               : CT210                                    -  enabled
            + system.adapter.heatingcontrol.0         : heatingcontrol        : CT210                                    -  enabled
            + system.adapter.history.0                : history               : CT210                                    -  enabled
              system.adapter.hm-rega.0                : hm-rega               : CT210                                    -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : CT210                                    -  enabled, port: 0
            + system.adapter.influxdb.0               : influxdb              : CT210                                    -  enabled, port: 8086
              system.adapter.iot.0                    : iot                   : CT210                                    -  enabled
            + system.adapter.javascript.0             : javascript            : CT210                                    -  enabled
              system.adapter.openknx.0                : openknx               : CT210                                    -  enabled
              system.adapter.pvforecast.0             : pvforecast            : CT210                                    -  enabled
              system.adapter.solarmanpv.0             : solarmanpv            : CT210                                    - disabled
            + system.adapter.sonos.0                  : sonos                 : CT210                                    -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : CT210                                    -  enabled
            + system.adapter.web.0                    : web                   : CT210                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.yeelight-2.0             : yeelight-2            : CT210                                    -  enabled
              system.adapter.zigbee.0                 : zigbee                : CT210                                    -  enabled, port: /dev/ttyACM0
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.12.0   , installed 6.12.0
            Adapter    "backitup"     : 2.9.8    , installed 2.9.8
            Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
            Adapter    "ebus"         : 3.2.4    , installed 3.2.4
            Adapter    "echarts"      : 1.7.2    , installed 1.7.2
            Adapter    "heatingcontrol": 2.12.2  , installed 2.12.2
            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
            Adapter    "iot"          : 2.0.11   , installed 2.0.11
            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
            Controller "js-controller": 5.0.17   , installed 4.0.23 [Updatable]
            Adapter    "openknx"      : 0.6.3    , installed 0.6.3
            Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
            Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
            Adapter    "sonos"        : 3.0.0    , installed 3.0.0
            Adapter    "weatherunderground": 3.6.0, installed 3.6.0
            Adapter    "web"          : 6.1.10   , installed 6.1.10
            Adapter    "ws"           : 2.5.8    , installed 2.5.8
            Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
            Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
            Objects and States
            Objects:        2394
            States:         1947
            Hit:1 http://ftp.debian.org/debian bullseye InRelease
            Hit:2 http://security.debian.org bullseye-security InRelease
            Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 192.168.2.52:2001       0.0.0.0:*               LISTEN      1000       90927369   5239/io.hm-rpc.0
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          90845716   314/master
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        90846217   95/systemd-resolved
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       90926356   5140/iobroker.js-co
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          90845300   1/init
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       90926339   5140/iobroker.js-co
            tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        90846211   95/systemd-resolved
            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       90926936   5305/io.web.0
            tcp6       0      0 :::3500                 :::*                    LISTEN      1000       90926644   5210/io.sonos.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          90845483   1/init
            tcp6       0      0 :::111                  :::*                    LISTEN      0          90845302   1/init
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          90845717   314/master
            tcp6       0      0 :::5355                 :::*                    LISTEN      104        90846214   95/systemd-resolved
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        90846216   95/systemd-resolved
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          90843085   85/dhclient
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          90845301   1/init
            udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        90846210   95/systemd-resolved
            udp6       0      0 :::111                  :::*                                0          90845303   1/init
            udp6       0      0 :::5355                 :::*                                104        90846213   95/systemd-resolved
            2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
            2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
            2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
            2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
            2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
            2024-01-18 13:38:43.958  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-01-18 13:38:43.958  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
            2024-01-18 13:38:46.471  - info: host.CT210 instance system.adapter.admin.0 started with pid 27872
            2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
            2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
            2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
            2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
            2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
            2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
            2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
            2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
            2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
            2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
            2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
            2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
            2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:17:15)
            2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
            2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
            2024-01-18 13:38:46.645  - error: host.CT210 instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-01-18 13:38:46.645  - info: host.CT210 Restart adapter system.adapter.admin.0 because enabled
            v.2023-10-10
                       Chassis: container
                Virtualization: lxc
            Installation:           lxc
            Kernel:                 x86_64
            Userland:               amd64
            Timezone:               Etc/UTC (UTC, +0000)
            User-ID:                1001
            X-Server:               false
            Boot Target:            graphical.target
            Pending OS-Updates:     0
            Pending iob updates:    1
            Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                    /usr/bin/npm            10.3.0
                                    /usr/bin/npx            10.3.0
            Recommended versions are nodejs  and npm
            MEMORY:
            Mem:            2.0G        726M        848M        0.0K        472M        1.3G
            Swap:           512M          0B        512M
            Total:          2.6G        726M        1.4G
            Active iob-Instances:   12
            ioBroker Core:          js-controller           4.0.23
                                    admin                   6.12.0
            Objects type: jsonl
            States  type: jsonl
            Objects:                2394
            States:                 1947
            Size of iob-Database:
            9.7M    /opt/iobroker/iobroker-data/objects.jsonl
            844K    /opt/iobroker/iobroker-data/states.jsonl
            =================== END OF SUMMARY ====================```
              @viper2033 sagte in Web Interface nach Update nicht erreichbar:
              Falsche Zeitzone. Stell das auf deine Zeitzone um.
              Stell das auf multi-user.target um.
              sudo systemctl set-default multi-user.target
              Setz den user test in die Gruppe adm rein.
              sudo usermod -a -G adm test
              Veraltet, bring das auf den aktuellen Stand.
              iob update
              iob stop
              iob upgrade self
              iob start
              iob start admin
              • viper2033
                @thomas-braun said in Web Interface nach Update nicht erreichbar:
                iob start admin
                Habe ich alles gemacht, funktioniert leider nicht :-(.
                  Dann nochmal
                  iob diag
                  Diesmal bitte besser lesbar inkl. der CodeTags.
                    @viper2033
                    Sehe ich gerade erst:
                    /usr/bin/npm            10.3.0
                    /usr/bin/npx            10.3.0
                    Das ist nicht die Version, die mit nodejs 18.19.0 gebündelt kommt. Von Hand irgendwas gefummelt? Muss ja...
                    sudo apt install --reinstall nodejs
                    • viper2033
                      Habe nodejs geupdatet leider kein Erfolg:
                      code_text`
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                                 Chassis: container
                          Virtualization: lxc
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                       16:00:19 up 1 min,  1 user,  load average: 0.52, 0.49, 0.41
                      CPU threads: 2
                                     Local time: Thu 2024-01-18 16:00:19 CET
                                 Universal time: Thu 2024-01-18 15:00:19 UTC
                                       RTC time: n/a
                                RTC in local TZ: no
                      test
                      /home/test
                      test adm sudo iobroker
                      X-Server:       false
                      Desktop:
                      Terminal:
                      Boot Target:    multi-user.target
                      *** MEMORY ***
                      Mem:            2.0G        575M        1.3G        0.0K        185M        1.5G
                      Swap:           512M          0B        512M
                      Total:          2.6G        575M        1.8G
                               2048 M total memory
                                576 M used memory
                                641 M active memory
                                 74 M inactive memory
                               1285 M free memory
                                  0 M buffer memory
                                185 M swap cache
                                512 M total swap
                                  0 M used swap
                                512 M free swap
                      *** FILESYSTEM ***
                      /dev/mapper/pve-vm--210--disk--0 ext4      7.8G  4.4G  3.1G  60% /
                      /var:
                      909M    /var/
                      429M    /var/log
                      388M    /var/log/journal/e982dcf1ad9c45638928dfce9f1ddc3d
                      344M    /var/cache
                      Archived and active journals take up 387.6M in the file system.
                      369M    /opt/iobroker/iobroker-data/
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Temp directories causing npm8 problem: 1
                      Some problems detected, please run iob fix
                      Errors in npm tree:
                      npm ERR! code ELSPROBLEMS
                      npm ERR! extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                      npm ERR! invalid: diskusage@ /opt/iobroker/node_modules/diskusage
                      npm ERR! A complete log of this run can be found in: /home/test/.npm/_logs/2024-01-18T15_00_24_400Z-debug-0.log
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        2394
                      States:         1949
                      Hit:1 http://security.debian.org bullseye-security InRelease
                      Hit:2 http://ftp.debian.org/debian bullseye InRelease
                      Pending Updates: 0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       91450790   141/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       91451539   141/iobroker.js-con
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          91450633   314/master
                      tcp        0      0 192.168.2.52:2001       0.0.0.0:*               LISTEN      1000       91451867   406/io.hm-rpc.0
                      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        91451396   101/systemd-resolve
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          91447175   1/init
                      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        91448317   101/systemd-resolve
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          91450634   314/master
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       91451245   472/io.web.0
                      tcp6       0      0 :::3500                 :::*                    LISTEN      1000       91451732   377/io.sonos.0
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          91447177   1/init
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          91448192   1/init
                      tcp6       0      0 :::5355                 :::*                    LISTEN      104        91448320   101/systemd-resolve
                      udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        91451395   101/systemd-resolve
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          91448251   86/dhclient
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          91447176   1/init
                      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        91448316   101/systemd-resolve
                      udp6       0      0 :::111                  :::*                                0          91447178   1/init
                      udp6       0      0 :::5355                 :::*                                104        91448319   101/systemd-resolve
                      2024-01-18 16:00:40.892  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
                      2024-01-18 16:00:40.893  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                      2024-01-18 16:00:40.893  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
                      2024-01-18 16:00:40.893  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2024-01-18 16:00:40.893  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
                      2024-01-18 16:00:41.567  - info: host.CT210 instance system.adapter.pvforecast.0 started with pid 940
                      2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
                      2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
                      2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                      2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
                      2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
                      2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
                      2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
                      2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                      2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
                      2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
                      2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
                      2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                      2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.pvforecast/main.js:5:15)
                      2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                      2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
                      2024-01-18 16:00:42.105  - error: host.CT210 instance system.adapter.pvforecast.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2024-01-18 16:00:42.105  - info: host.CT210 Restart adapter system.adapter.pvforecast.0 because enabled
                      2024-01-18 16:00:54.358  - info: host.CT210 instance system.adapter.yeelight-2.0 started with pid 1270
                      2024-01-18 16:00:55.733  - info: yeelight-2.0 (1270) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.19.0, js-controller: 4.0.23
                      code_text
                                              v.2023-10-10
                                 Chassis: container
                          Virtualization: lxc
                      Installation:           lxc
                      Kernel:                 x86_64
                      Userland:               amd64
                      Timezone:               Europe/Berlin (CET, +0100)
                      User-ID:                1001
                      X-Server:               false
                                              /usr/bin/npm            10.2.3
                                              /usr/bin/npx            10.2.3
                      MEMORY:
                      Mem:            2.0G        587M        1.1G        0.0K        362M        1.5G
                      Swap:           512M          0B        512M
                      Total:          2.6G        587M        1.6G
                                              admin                   6.12.0
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                2394
                      States:                 1949
                      5.8M    /opt/iobroker/iobroker-data/objects.jsonl
                      484K    /opt/iobroker/iobroker-data/states.jsonl
                      === Mark text until here for copying ===```
                        Das ist dein Problem.
                        cd /opt/iobroker
                        sudo -H -u iobroker npm install iobroker.js-controller
                        • viper2033
                          Es kommt folgende Meldung:
                          code_textnpm ERR! code ENOTEMPTY
                          npm ERR! syscall rename
                          npm ERR! path /opt/iobroker/node_modules/diskusage
                          npm ERR! dest /opt/iobroker/node_modules/.diskusage-SbL2R1mm
                          npm ERR! errno -39
                          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/diskusage' -> '/opt/iobroker/node_modules/.diskusage-SbL2R1mm'```
                            @viper2033
                            Dann
                            iob stop
                            iob fix
                            cd /opt/iobroker
                            • viper2033
                              Folgende Fehlermeldung:
                              code_text
                              pm WARN cleanup Failed to remove some directories [
                              npm WARN cleanup   [
                              npm WARN cleanup     '/opt/iobroker/node_modules/diskusage',
                              npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/diskusage'] {
                              npm WARN cleanup       errno: -39,
                              npm WARN cleanup       code: 'ENOTEMPTY',
                              npm WARN cleanup       syscall: 'rmdir',
                              npm WARN cleanup       path: '/opt/iobroker/node_modules/diskusage'
                              npm WARN cleanup     }
                              npm WARN cleanup   ],
                              npm WARN cleanup   [
                              npm WARN cleanup     }
                              npm WARN cleanup   ]
                              npm WARN cleanup ]
                              npm ERR! code 1
                              npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                              npm ERR! command failed
                              npm ERR! command sh -c node iobroker.js setup first
                              npm ERR! /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
                              npm ERR!     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!    ;J
                              npm ERR!                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                              npm ERR!
                              npm ERR! SyntaxError: Invalid or unexpected token
                              npm ERR!     at internalCompileFunction (node:internal/vm:73:18)
                              npm ERR!     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
                              npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1320:27)
                              npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                              npm ERR!     at Module.load (node:internal/modules/cjs/loader:1197:32)
                              npm ERR!     at Module._load (node:internal/modules/cjs/loader:1013:12)
                              npm ERR!     at Module.require (node:internal/modules/cjs/loader:1225:19)
                              npm ERR!     at require (node:internal/modules/helpers:177:18)
                              npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:36:33)
                              npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                              npm ERR!
                              npm ERR! Node.js v18.19.0```
        npm ERR!
                                Hab ich so auch noch nicht gesehen. Keine Ahnung was da kaputt ist.
                                  Homoran Global Moderator Administrators @viper2033 last edited by
                                  wo bist du da?
                                  bitte immer alles komplett zeigen.
                                  Ein- und Ausgaben
                                  • viper2033
                                    viper2033 @Homoran last edited by
                                    Jetzt zeigt er mir folgendes an nach eingabe von
                                    code_text
                                    npm ERR! errno -39
                                      @viper2033
                                      Nochmal:
                                      iob stop
                                      iob fix
                                      cd /opt/iobroker
                                        nach eingabe von
                                        das sehe ich nicht!
                                        bitte Prompt und Eingabebefehl zeigen!!
                                        • viper2033
                                          viper2033 @Homoran last edited by Homoran
                                          code_text
                                          root@CT210:/opt/iobroker# sudo -H -u iobroker npm install iobroker.js-controller
                                          npm ERR! errno -39
                                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-18T15_53_31_534Z-debug-0.log
                                            root@CT210
                                            War mir klar...
                                            Auch im LXC wird NICHT als root herumgehampelt.
                                            739
