    4. Web Interface nach Update nicht erreichbar
    • viper2033
      viper2033 @Thomas Braun last edited by Homoran
      2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
      2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
      2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-18 13:13:15.309  - error: host.CT210 Caught by controller[0]: Node.js v18.19.0
      2024-01-18 13:13:15.309  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-18 13:13:15.309  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
      2024-01-18 13:13:24.362  - info: host.CT210 instance system.adapter.iot.0 started with pid 25033
      2024-01-18 13:13:25.155  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
      2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
      2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
      2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
      2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
      2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
      2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
      2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
      2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/googleHome.js:2:17)
      2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-18 13:13:25.156  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
      2024-01-18 13:13:25.156  - error: host.CT210 instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-18 13:13:25.156  - info: host.CT210 Restart adapter system.adapter.iot.0 because enabled
        Thomas Braun Most Active @viper2033 last edited by Thomas Braun
        @viper2033
        Das ist nicht die vollständige Ausgabe der Langfassung von iob diag.
        Und es steht nicht in CodeTags...
        viper2033 1 Reply Last reply Reply Quote 0
        • viper2033
          code_text
          *** BASE SYSTEM ***
             Static hostname: CT210
                   Icon name: computer-container
                     Chassis: container
              Virtualization: lxc
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.5.11-4-pve
                Architecture: x86-64
          model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
           13:38:19 up  5:00,  1 user,  load average: 0.39, 0.25, 0.20
          CPU threads: 2
          *** Time and Time Zones ***
                         Local time: Thu 2024-01-18 13:38:19 UTC
                     Universal time: Thu 2024-01-18 13:38:19 UTC
                           RTC time: n/a
                          Time zone: Etc/UTC (UTC, +0000)
                        NTP service: inactive
                    RTC in local TZ: no
          *** User and Groups ***
          test
          /home/test
          test sudo iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:            2.0G        714M        860M        0.0K        472M        1.3G
          Swap:           512M          0B        512M
          Total:          2.6G        714M        1.4G
                   2048 M total memory
                    714 M used memory
                    776 M active memory
                    294 M inactive memory
                    860 M free memory
                      0 M buffer memory
                    472 M swap cache
                    512 M total swap
                      0 M used swap
                    512 M free swap
          *** FAILED SERVICES ***
            UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
          * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
          * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          3 loaded units listed.
          *** FILESYSTEM ***
          Filesystem                       Type      Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--210--disk--0 ext4      7.8G  4.4G  3.1G  59% /
          none                             tmpfs     492K  4.0K  488K   1% /dev
          udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
          tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
          tmpfs                            tmpfs     1.6G  112K  1.6G   1% /run
          tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
          dmesg: read kernel buffer failed: Operation not permitted
          TARGET SOURCE                           FSTYPE OPTIONS
          /      /dev/mapper/pve-vm--210--disk--0 ext4   rw,relatime,stripe=16
          /var:
          898M    /var/
          418M    /var/log
          380M    /var/log/journal/e982dcf1ad9c45638928dfce9f1ddc3d
          344M    /var/cache
          Archived and active journals take up 16.0M in the file system.
          /opt/iobroker/backups:
          34M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          366M    /opt/iobroker/iobroker-data/
          319M    /opt/iobroker/iobroker-data/files
          89M     /opt/iobroker/iobroker-data/files/echarts.admin
          67M     /opt/iobroker/iobroker-data/files/javascript.admin
          57M     /opt/iobroker/iobroker-data/files/echarts
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
          23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.3.0
          /usr/bin/npx            10.3.0
          /usr/bin/corepack       0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                  500 http://security.debian.org bullseye-security/main amd64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  4.0.23
          admin:          6.12.0
          javascript:     7.1.6
          Adapters from github:   0
          Adapter State
            system.adapter.admin.0                  : admin                 : CT210                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : CT210                                    -  enabled
          + system.adapter.deyeidc.0                : deyeidc               : CT210                                    -  enabled, port: 8899
          + system.adapter.discovery.0              : discovery             : CT210                                    -  enabled
            system.adapter.ebus.0                   : ebus                  : CT210                                    - disabled
          + system.adapter.echarts.0                : echarts               : CT210                                    -  enabled
          + system.adapter.heatingcontrol.0         : heatingcontrol        : CT210                                    -  enabled
          + system.adapter.history.0                : history               : CT210                                    -  enabled
            system.adapter.hm-rega.0                : hm-rega               : CT210                                    -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : CT210                                    -  enabled, port: 0
          + system.adapter.influxdb.0               : influxdb              : CT210                                    -  enabled, port: 8086
            system.adapter.iot.0                    : iot                   : CT210                                    -  enabled
          + system.adapter.javascript.0             : javascript            : CT210                                    -  enabled
            system.adapter.openknx.0                : openknx               : CT210                                    -  enabled
            system.adapter.pvforecast.0             : pvforecast            : CT210                                    -  enabled
            system.adapter.solarmanpv.0             : solarmanpv            : CT210                                    - disabled
          + system.adapter.sonos.0                  : sonos                 : CT210                                    -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : CT210                                    -  enabled
          + system.adapter.web.0                    : web                   : CT210                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.yeelight-2.0             : yeelight-2            : CT210                                    -  enabled
            system.adapter.zigbee.0                 : zigbee                : CT210                                    -  enabled, port: /dev/ttyACM0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.12.0   , installed 6.12.0
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
          Adapter    "ebus"         : 3.2.4    , installed 3.2.4
          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
          Adapter    "heatingcontrol": 2.12.2  , installed 2.12.2
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 4.0.23 [Updatable]
          Adapter    "openknx"      : 0.6.3    , installed 0.6.3
          Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
          Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
          Adapter    "web"          : 6.1.10   , installed 6.1.10
          Adapter    "ws"           : 2.5.8    , installed 2.5.8
          Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
          Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
          Objects and States
          Objects:        2394
          States:         1947
          Hit:1 http://ftp.debian.org/debian bullseye InRelease
          Hit:2 http://security.debian.org bullseye-security InRelease
          Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 192.168.2.52:2001       0.0.0.0:*               LISTEN      1000       90927369   5239/io.hm-rpc.0
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          90845716   314/master
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        90846217   95/systemd-resolved
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       90926356   5140/iobroker.js-co
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          90845300   1/init
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       90926339   5140/iobroker.js-co
          tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        90846211   95/systemd-resolved
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       90926936   5305/io.web.0
          tcp6       0      0 :::3500                 :::*                    LISTEN      1000       90926644   5210/io.sonos.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          90845483   1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          90845302   1/init
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          90845717   314/master
          tcp6       0      0 :::5355                 :::*                    LISTEN      104        90846214   95/systemd-resolved
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        90846216   95/systemd-resolved
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          90843085   85/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          90845301   1/init
          udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        90846210   95/systemd-resolved
          udp6       0      0 :::111                  :::*                                0          90845303   1/init
          udp6       0      0 :::5355                 :::*                                104        90846213   95/systemd-resolved
          2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
          2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
          2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
          2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
          2024-01-18 13:38:43.957  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
          2024-01-18 13:38:43.958  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-01-18 13:38:43.958  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
          2024-01-18 13:38:46.471  - info: host.CT210 instance system.adapter.admin.0 started with pid 27872
          2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
          2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
          2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
          2024-01-18 13:38:46.644  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
          2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
          2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
          2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
          2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
          2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
          2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
          2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
          2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:17:15)
          2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
          2024-01-18 13:38:46.645  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
          2024-01-18 13:38:46.645  - error: host.CT210 instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-01-18 13:38:46.645  - info: host.CT210 Restart adapter system.adapter.admin.0 because enabled
          v.2023-10-10
                     Chassis: container
              Virtualization: lxc
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               amd64
          Timezone:               Etc/UTC (UTC, +0000)
          User-ID:                1001
          X-Server:               false
          Boot Target:            graphical.target
          Pending OS-Updates:     0
          Pending iob updates:    1
          Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                  /usr/bin/npm            10.3.0
                                  /usr/bin/npx            10.3.0
          Recommended versions are nodejs  and npm
          MEMORY:
          Mem:            2.0G        726M        848M        0.0K        472M        1.3G
          Swap:           512M          0B        512M
          Total:          2.6G        726M        1.4G
          Active iob-Instances:   12
          ioBroker Core:          js-controller           4.0.23
                                  admin                   6.12.0
          Objects type: jsonl
          States  type: jsonl
          Objects:                2394
          States:                 1947
          Size of iob-Database:
          9.7M    /opt/iobroker/iobroker-data/objects.jsonl
          844K    /opt/iobroker/iobroker-data/states.jsonl
          =================== END OF SUMMARY ====================```
            @viper2033 sagte in Web Interface nach Update nicht erreichbar:
            Falsche Zeitzone. Stell das auf deine Zeitzone um.
            Stell das auf multi-user.target um.
            sudo systemctl set-default multi-user.target
            Setz den user test in die Gruppe adm rein.
            sudo usermod -a -G adm test
            Veraltet, bring das auf den aktuellen Stand.
            iob update
            iob stop
            iob upgrade self
            iob start
            iob start admin
            • viper2033
              @thomas-braun said in Web Interface nach Update nicht erreichbar:
              iob start admin
              Habe ich alles gemacht, funktioniert leider nicht :-(.
                Dann nochmal
                iob diag
                Diesmal bitte besser lesbar inkl. der CodeTags.
                  @viper2033
                  Sehe ich gerade erst:
                  /usr/bin/npm            10.3.0
                  /usr/bin/npx            10.3.0
                  Das ist nicht die Version, die mit nodejs 18.19.0 gebündelt kommt. Von Hand irgendwas gefummelt? Muss ja...
                  sudo apt install --reinstall nodejs
                  • viper2033
                    Habe nodejs geupdatet leider kein Erfolg:
                    code_text`
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                               Chassis: container
                        Virtualization: lxc
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                     16:00:19 up 1 min,  1 user,  load average: 0.52, 0.49, 0.41
                    CPU threads: 2
                                   Local time: Thu 2024-01-18 16:00:19 CET
                               Universal time: Thu 2024-01-18 15:00:19 UTC
                                     RTC time: n/a
                              RTC in local TZ: no
                    test
                    /home/test
                    test adm sudo iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:            2.0G        575M        1.3G        0.0K        185M        1.5G
                    Swap:           512M          0B        512M
                    Total:          2.6G        575M        1.8G
                             2048 M total memory
                              576 M used memory
                              641 M active memory
                               74 M inactive memory
                             1285 M free memory
                                0 M buffer memory
                              185 M swap cache
                              512 M total swap
                                0 M used swap
                              512 M free swap
                    *** FILESYSTEM ***
                    /dev/mapper/pve-vm--210--disk--0 ext4      7.8G  4.4G  3.1G  60% /
                    /var:
                    909M    /var/
                    429M    /var/log
                    388M    /var/log/journal/e982dcf1ad9c45638928dfce9f1ddc3d
                    344M    /var/cache
                    Archived and active journals take up 387.6M in the file system.
                    369M    /opt/iobroker/iobroker-data/
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                    Temp directories causing npm8 problem: 1
                    Some problems detected, please run iob fix
                    Errors in npm tree:
                    npm ERR! code ELSPROBLEMS
                    npm ERR! extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                    npm ERR! invalid: diskusage@ /opt/iobroker/node_modules/diskusage
                    npm ERR! A complete log of this run can be found in: /home/test/.npm/_logs/2024-01-18T15_00_24_400Z-debug-0.log
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        2394
                    States:         1949
                    Hit:1 http://security.debian.org bullseye-security InRelease
                    Hit:2 http://ftp.debian.org/debian bullseye InRelease
                    Pending Updates: 0
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       91450790   141/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       91451539   141/iobroker.js-con
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          91450633   314/master
                    tcp        0      0 192.168.2.52:2001       0.0.0.0:*               LISTEN      1000       91451867   406/io.hm-rpc.0
                    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        91451396   101/systemd-resolve
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          91447175   1/init
                    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        91448317   101/systemd-resolve
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          91450634   314/master
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       91451245   472/io.web.0
                    tcp6       0      0 :::3500                 :::*                    LISTEN      1000       91451732   377/io.sonos.0
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          91447177   1/init
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          91448192   1/init
                    tcp6       0      0 :::5355                 :::*                    LISTEN      104        91448320   101/systemd-resolve
                    udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        91451395   101/systemd-resolve
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          91448251   86/dhclient
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          91447176   1/init
                    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        91448316   101/systemd-resolve
                    udp6       0      0 :::111                  :::*                                0          91447178   1/init
                    udp6       0      0 :::5355                 :::*                                104        91448319   101/systemd-resolve
                    2024-01-18 16:00:40.892  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/lib/rega.js:16:15)
                    2024-01-18 16:00:40.893  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                    2024-01-18 16:00:40.893  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
                    2024-01-18 16:00:40.893  - error: host.CT210 instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2024-01-18 16:00:40.893  - info: host.CT210 Restart adapter system.adapter.hm-rega.0 because enabled
                    2024-01-18 16:00:41.567  - info: host.CT210 instance system.adapter.pvforecast.0 started with pid 940
                    2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]: /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
                    2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!  ;J
                    2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                    2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]: SyntaxError: Invalid or unexpected token
                    2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
                    2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
                    2024-01-18 16:00:42.104  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1320:27)
                    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
                    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
                    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
                    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.pvforecast/main.js:5:15)
                    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                    2024-01-18 16:00:42.105  - error: host.CT210 Caught by controller[1]: Node.js v18.19.0
                    2024-01-18 16:00:42.105  - error: host.CT210 instance system.adapter.pvforecast.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2024-01-18 16:00:42.105  - info: host.CT210 Restart adapter system.adapter.pvforecast.0 because enabled
                    2024-01-18 16:00:54.358  - info: host.CT210 instance system.adapter.yeelight-2.0 started with pid 1270
                    2024-01-18 16:00:55.733  - info: yeelight-2.0 (1270) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.19.0, js-controller: 4.0.23
                    code_text
                                            v.2023-10-10
                               Chassis: container
                        Virtualization: lxc
                    Installation:           lxc
                    Kernel:                 x86_64
                    Userland:               amd64
                    Timezone:               Europe/Berlin (CET, +0100)
                    User-ID:                1001
                    X-Server:               false
                                            /usr/bin/npm            10.2.3
                                            /usr/bin/npx            10.2.3
                    MEMORY:
                    Mem:            2.0G        587M        1.1G        0.0K        362M        1.5G
                    Swap:           512M          0B        512M
                    Total:          2.6G        587M        1.6G
                                            admin                   6.12.0
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                2394
                    States:                 1949
                    5.8M    /opt/iobroker/iobroker-data/objects.jsonl
                    484K    /opt/iobroker/iobroker-data/states.jsonl
                    === Mark text until here for copying ===```
                      Das ist dein Problem.
                      cd /opt/iobroker
                      sudo -H -u iobroker npm install iobroker.js-controller
                      • viper2033
                        Es kommt folgende Meldung:
                        code_textnpm ERR! code ENOTEMPTY
                        npm ERR! syscall rename
                        npm ERR! path /opt/iobroker/node_modules/diskusage
                        npm ERR! dest /opt/iobroker/node_modules/.diskusage-SbL2R1mm
                        npm ERR! errno -39
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/diskusage' -> '/opt/iobroker/node_modules/.diskusage-SbL2R1mm'```
                          @viper2033
                          Dann
                          iob stop
                          iob fix
                          cd /opt/iobroker
                          • viper2033
                            Folgende Fehlermeldung:
                            code_text
                            pm WARN cleanup Failed to remove some directories [
                            npm WARN cleanup   [
                            npm WARN cleanup     '/opt/iobroker/node_modules/diskusage',
                            npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/diskusage'] {
                            npm WARN cleanup       errno: -39,
                            npm WARN cleanup       code: 'ENOTEMPTY',
                            npm WARN cleanup       syscall: 'rmdir',
                            npm WARN cleanup       path: '/opt/iobroker/node_modules/diskusage'
                            npm WARN cleanup     }
                            npm WARN cleanup   ],
                            npm WARN cleanup   [
                            npm WARN cleanup     }
                            npm WARN cleanup   ]
                            npm WARN cleanup ]
                            npm ERR! code 1
                            npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                            npm ERR! command failed
                            npm ERR! command sh -c node iobroker.js setup first
                            npm ERR! /opt/iobroker/node_modules/axios/dist/node/axios.cjs:1444
                            npm ERR!     const hasJSONContentType = contentType.indexon$'K0qhicaTx+ljson?i*%-1;�(   #Onst"i7ObjekvPaiekad�=$etils9*ysE"Kect8dit!    ;J
                            npm ERR!                                                    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                            npm ERR!
                            npm ERR! SyntaxError: Invalid or unexpected token
                            npm ERR!     at internalCompileFunction (node:internal/vm:73:18)
                            npm ERR!     at wrapSafe (node:internal/modules/cjs/loader:1274:20)
                            npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1320:27)
                            npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                            npm ERR!     at Module.load (node:internal/modules/cjs/loader:1197:32)
                            npm ERR!     at Module._load (node:internal/modules/cjs/loader:1013:12)
                            npm ERR!     at Module.require (node:internal/modules/cjs/loader:1225:19)
                            npm ERR!     at require (node:internal/modules/helpers:177:18)
                            npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:36:33)
                            npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                            npm ERR!
                            npm ERR! Node.js v18.19.0```
        npm ERR!
                              Hab ich so auch noch nicht gesehen. Keine Ahnung was da kaputt ist.
                                Homoran Global Moderator Administrators @viper2033 last edited by
                                wo bist du da?
                                bitte immer alles komplett zeigen.
                                Ein- und Ausgaben
                                • viper2033
                                  viper2033 @Homoran last edited by
                                  Jetzt zeigt er mir folgendes an nach eingabe von
                                  code_text
                                  npm ERR! errno -39
                                    @viper2033
                                    Nochmal:
                                    iob stop
                                    iob fix
                                    cd /opt/iobroker
                                      nach eingabe von
                                      das sehe ich nicht!
                                      bitte Prompt und Eingabebefehl zeigen!!
                                      • viper2033
                                        viper2033 @Homoran last edited by Homoran
                                        code_text
                                        root@CT210:/opt/iobroker# sudo -H -u iobroker npm install iobroker.js-controller
                                        npm ERR! errno -39
                                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-18T15_53_31_534Z-debug-0.log
                                          root@CT210
                                          War mir klar...
                                          Auch im LXC wird NICHT als root herumgehampelt.
                                            @homoran da nutzt dann der ganze fix der Rechte nichts, wenn anschließend der root die Rechte wieder verbiegt.
                                            Noch schlimmer ist nur noch als root den fixer auszuführen. und dazu noch mit sudo für Hyperrechte 😂
                                            739
