    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      mick70 @joergeli last edited by
      @joergeli Sieht hier genauso aus, eGolf 02/2020, aktueller Adapter aus Github.
      • joergeli
        joergeli @tombox last edited by
        @tombox
        ... OK, dann reiche ich meine Frage/Bitte an @Sneak-L8 weiter, oder wo kann man das als Issue in Github einstellen?
          tombox @joergeli last edited by
          @joergeli Bitte mal
          die GitHub version installieren
          alle Objekte löschen
          adapter neustarten
          joergeli 1 Reply Last reply Reply Quote 0
          • joergeli
            @tombox
            ... gesagt, getan -> GitHub version installiert -> sieht m.E. gut aus
            Anbei noch mal das jetzige JSON:
              "accessStatus": {
                "overallStatus": "invalid",
                "carCapturedTimestamp": "2024-01-10T13:21:30Z",
                "doors": [
                    "name": "bonnet",
                    "status": [
                      "closed"
                    "name": "frontLeft",
                    "status": [
                      "locked",
                      "closed"
                    "name": "frontRight",
                    "status": [
                      "locked",
                      "closed"
                    "name": "rearLeft",
                    "status": [
                      "locked",
                      "closed"
                    "name": "rearRight",
                    "status": [
                      "locked",
                      "closed"
                    "name": "trunk",
                    "status": [
                      "invalid",
                      "invalid"
                "windows": [
                    "status": [
                      "closed"
                    "status": [
                      "closed"
                    "name": "rearLeft",
                    "status": [
                      "closed"
                    "status": [
                      "closed"
                    "name": "roofCover",
                    "status": [
                      "unsupported"
                    "name": "sunRoof",
                    "status": [
                      "unsupported"
                "doorLockStatus": "invalid"
              "rangeStatus": {
                "carType": "gasoline",
                "primaryEngine": {
                  "type": "gasoline",
                  "currentSOC_pct": 40,
                  "remainingRange_km": 230,
                  "currentFuelLevel_pct": 40
                "totalRange_km": 230
              "lightsStatus": {
                "lights": [
                    "name": "right",
                    "status": "off"
                    "name": "left",
                    "status": "off"
              "maintenanceStatus": {
                "carCapturedTimestamp": "2024-01-10T13:21:27Z",
                "inspectionDue_days": 61,
                "inspectionDue_km": 9700,
                "mileage_km": 20319,
                "oilServiceDue_days": 61,
                "oilServiceDue_km": 9700
              "measurements_rangeStatus": {
                "gasolineRange": 230,
              "odometerStatus": {
                "odometer": 20319
              "fuelLevelStatus": {
                "currentFuelLevel_pct": 40,
                "primaryEngineType": "gasoline",
            und ein Screenshot der vw-connect Datenpunkte:
            Noch eine Verständnisfrage von mir als JSON-Unwissender:
            In der JSON steht ja z.B.
            "doors": [
            und darunter werden die dann die Türen, bzw. deren Stati nacheinader aufgelistet., so weit, so gut.
            Im ioBroker Objekt-Datenbaum werden die Türen allerdings direkt unter accessStus als doors1, doors2, etc. gelistet.
            Mit meinem JSON-Halbwissen, müsste doch der Objektbaum analog dem JSON erstellt werden,
            oder setzt das der Adapter gewollt in die jetzige Baumstruktur um?
            Wie gesagt, ist nur 'ne Verständnisfrage - die gewünschten Datenpunkte sind ja jetzt vorhanden.
            Danke für Deine prompte Reaktion und den Fix 👍
              Sneak-L8 @joergeli last edited by
              @joergeli Da kann ich dann doch mal einhaken.
              Ja, ich hatte auch mal in Tomboxs Adapter etwas ergänzt. Da ging es mir aber genau darum, mit den States näher am JSON zu sein. Im Bereich "doors" hatte ich nichts gemacht, wenn ich mich recht erinnere.
              Das Problem ist z.B., dass das JSON Arrays enthält, es in den States aber eine Arrays gibt. Tombox hat sich dafür entscheiden, an den Name des Array-Elements in diesen Fällen einfach eine Nummerierung dranzuhängen.
              An anderen Stellen werden auch Channels mit zwei Werten zu einem Key-Value-Paar.
              Ich gehe davon aus, dass es ihm darum ging, die Struktur nicht zu komplex zu machen.
              Ich finde, das ist ihm auch ganz gut gelungen. Daher ist die JSON-Struktur nicht identisch mit den Channels und States.
              • joergeli
                joergeli @Sneak-L8 last edited by
                @sneak-l8
                Ich wollte mit meiner Frage auf keinen Fall Kritik an Dir, oder an @tombox üben!
                Gelegentlich versuche ich mich ja auch an JavaScripten, JSONs, etc. und da ich mir mein Halbwissen nur ergoogelt habe, war mir das halt aufgefallen.
                Ich hatte ja schon vermutet, bzw. geschrieben, daß die jetzige Baumstruktur bewußt so gewollt ist .
                Das ist auch vollkommen OK so.
                Eine "schmale" Baumstruktur ist mir persönlich auch lieber, besonders wenn man in VIS arbeitet und dann ellenlange Pfade einkopieren muss, die man in der VIS nur noch durch mühsames link-/rechts-Scrollen überblicken kann.
                Deshalb mein Dank auch an Dich für die "Aufklärung" !
                  @joergeli Das Problem ist hier konkret das door und window die gleichen Subnamen haben.
                  Jetzt wird der index verwendet aber da gilt nur generell für den ganzen status folder und könnte andere Objekte auch umbennen
                  • joergeli
                    @tombox sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                    ... ahhh, verstehe - dann könnten u.U. die falschen Objekte umbenannt werden.
                      g.pitzer last edited by
                      Ich habe das gleiche Problem das ich meinen Akkustand nicht mehr auslesen kann. Ich denke ich habe die Ratschläge von oben versucht richtig umzusetzen und den Adapter von Github installiert.
                      leider bekomme ich die gleiche Meldung wie von anderen Usern beschrieben.
                      Habe ich trotzdem etwas falsch gemacht.
                      lg
                        ManiacKill last edited by
                        • zapfs
                          zapfs last edited by
                          Für meinen Q7 etron: Adapter aus GitHub neu installiert.
                          Funktioniert !!!!
                          Danke für die gute Hilfe
                            mading last edited by mading
                            Gibt es eine Möglichkeit, das Ladelimit hoch zu setzen? Ich habe einen Ladeort für zu Hause definiert. Per Blockly/ Steuere hoch setzen geht mit dem DP nicht: vw-connect.0.vin.status.chargingProfilesStatus.Home.targetSOC_pct
                            Den nirmalen SoC kann ich so setzen, nur beim Ladeort klappt es nicht 😞
                            • Longbow
                              Longbow last edited by
                              Seit 2-3 Tagen habe diese Fehlermeldung.
                              Nur bei dem VW, bei unserem Cupra läuft alles super.
                              vw-connect.1
                              7682	2024-01-20 09:18:22.112	error	{"error":{"message":"Bad Gateway","info":"Something went wrong. Please try to re-login. If the problem persists, please contact our support.","code":4003,"group":3,"retry":true}}
                              vw-connect.1
                              7682	2024-01-20 09:18:22.112	error	No last shortterm trips found. Block trip fetching for WVWZZZCDZLW021679
                              vw-connect.1
                              7682	2024-01-20 09:18:22.112	error	AxiosError: Request failed with status code 502
                                socke85 @Longbow last edited by
                                @tombox Ich habe aktuell V5.2 installiert (mit einem Enyaq) und seither gibt es longitude und latitude nicht mehr. Ist das so normal oder liegt bei mir ein Problem vor. Habe die Datenpunkte auch an anderer Stelle nicht finden können.
                                VG Socke
                                  tombox @socke85 last edited by
                                  @socke85 Ja Skoda hat den iobroker gesperrt. die GitHub version hat es wieder aktiv
                                  • O
                                    oxident last edited by
                                    Danke für den Adapter. Versuche mit gerade, zurechtzufinden (Seat Ateca).
                                    Ist es normal/bekannt dass man die Standheizung mit dem v2-DP zwar einschalten, aber nicht mehr ausschalten kann?
                                    Außerdem werden Dutzende "Fields" unter status angezeigt, jedoch fehlen Angaben z.B. zur Restreichweite.
                                    Habe jedoch direkt die Github-Version installiert. Ist da vielleicht noch etwas "im Umbruch"?
                                      Thormann last edited by
                                      bei mir (Audi e-tron) wird die Aussentemperatur nicht mehr aktualisiert. Gibt es hierfür einen neuen Datenpunkt, den ich dann übersehen habe?
                                      Adapter Version 0.51 und als Type ist Audi E-tron eingestellt.
                                      Danke für Hinweise,
                                      Thormann
                                      • O
                                        oneill2612 last edited by
                                        Wie bekomme ich die Batterie oder Reichweite angezeigt beim ID4 ?
                                          ChrisWitt last edited by
                                          komme mit dem VW-Connect Adapter nicht weiter.
                                          Folgende Situation:
                                          VW Passat BJ 2021
                                          ID 3 BJ 2020
                                          In den Instanzen meine Mail und PW richtig eingegeben
                                          Gebe ich bei Type vWv2 >2020 ein, verbindet er nicht
                                          gebe ich ID3 ein , verbindet er , holt sich Daten , aber keine brauchbaren. Siehe Screenshots.
                                          Was mache ich falsch?
                                          Danke und gruß
                                          Screenshot 2024-02-08 144517.png Screenshot 2024-02-08 144437.png Screenshot 2024-02-08 144319.png
                                          T K 2 Replies Last reply Reply Quote 0
                                            tombox @ChrisWitt last edited by
                                            @chriswitt korrekte version wie in Beitrag #1 installiert?
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            399
                                            3091
                                            1606690
